Skoda OCTAVIA 2007, 2.0TDI, Engine BMM, Steering Assist!
Alex16
Blackwood, UK
C?ID=433182
Hello gent's
Please can someone with more experience advice me on the right direction for steering assist? its seems the fault code with G85 its to ABS mentioned? all ABS works fine. I tried to recalibrate the G85 but its seems nothing on this way, or i've done somthing wrong?
Many thanks,Alex
Tuesday,04,May,2021,15:09:49:53095
VCDS Version: 21.3.0.0 (x64)  HEX-NET2 CB: 0.4543.4
VIN: TMBKE21Z078026225   License Plate:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72
VIN: TMBKE21Z078026225   Mileage: 216420km-134477miles
Address 01: Engine        Labels: 03G-906-021-BMM.clb
   Part No SW: 03G 906 021 MD    HW: 03G 906 021 AB
   Component: R4 2,0L EDC  000SG  9095
   Revision: --H06---    Serial number: SKZ7Z0G4026334
   Coding: 0000172
   Shop #: WSC 80093 222 69422
   VCID: 6D8CA323219D0813545-8038
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
   Part No SW: 1K0 907 379 AB    HW: 1K0 907 379 AB
   Component: ESP 4MOTION MK60    0102
   Revision: 00H13001
   Coding: 0021122
   Shop #: WSC 20002 576 93634
   VCID: 72B6B05F38A3D7EB897-8026
   Part No: 1Z0 907 044 H
   Component: ClimatronicPQ35 084 0305
   VCID: 3B285D7B2F6956A39A1-806E
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000004705301
   Coding: 418A0F030004140000110D000000000000087F075C0000
   Shop #: WSC 26024 568 14177
   VCID: 6C8AAE271A87011B43B-8038
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 100107 022  0601
   Coding: 00055223
   Shop #: WSC 26024
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     020107 020  0105
   Coding: 00471077
   Shop #: WSC 26024
00906 - Horn (H1)
                    Fault Status: 00101001
                    Reset counter: 114
                    Mileage: 216422 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.40 V
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0Z3RK5
   Coding: 0020788
   Shop #: WSC 73430 790 00000
   VCID: 3D2C5363317D5893A45-8068
   Subsystem 1 - Serial number: 6332MSME156B5B24G
   Subsystem 2 - Serial number: 6342MSME15315C1EE
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 036 0070
   Coding: 0000012
   VCID: 74BAB64742B7D9DB9BB-8020
   Part No SW: 1Z0 920 912 D    HW: 1Z0 920 912 D
   Component: KOMBIINSTRUMENT VD1 1610
   Revision: V1610056    Serial number: SKZ7Z0G4026334
   Coding: 0007401
   VCID: 363E4C4F144B8BCB65F-8062
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 130107F2001785
   Coding: BD3F034007002303
   VCID: 2F30792BEB11BA03269-807A
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 L
   Component: Haldex 4Motion      0116
   Coding: 0000001
   Component: IMMO            VD1 1610
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         005 0954
   Coding: 0000756
   VCID: 382242771E5F7DBB773-806C
00120 - Outside Warning Light/Door exit Light Driver Side
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.070 H07 1806
   VCID: 353C4B43094D80D36C5-8060
02546 - Steering Limit Stop
                    Mileage: 216410 km
                    Temperature: 11.0°C
                    Voltage: 12.10 V
                    Voltage: 11.90 V
   Component:    KSG PQ35 G2  020 0203
   Coding: 98801A085283007F3F04850540085F96907CA0
   VCID: 0358E59B1719EE63921-8056
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 26024
   Subsystem 6 - Part No: 1K0 951 605 C
   Subsystem 7 - Component:       NGS n.mounted
                    Reset counter: 114
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000756
   VCID: 39244773255564B388D-806C
00110 - Right Mirror Turn Signal Lamp (L132)
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       019 0034
   Revision: 00019000    Serial number: SKZ7Z3G0122929
   Coding: 0000402
   VCID: 2E0E642FEC1BB30B2DF-807A
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         005 0907
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 3720414B134172C37E9-8062
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
End----------(Elapsed Time: 01:12, VBatt start/end: 12.1V/12.0V)-----------
Hi Alex,
I suspect this section of our Wiki page applies:
Special Notes​
  • When this DTC will not clear in Mk70 and MK60 ESP equipped (1K) Golf models see the WSS (Wheel Speed Sensor) notes Here.
If one of your wheel speed sensors isn't sending plausible data, which could be due to a faulty sensor or rusty pick-up, G85 will not cooperate in a pre-MK60EC1/Gen 2 Steering rack car. I would log MVB 001 while driving perfectly straight to see if you can spot a discrepancy.
