Wheel size change
lukas_amarok_13
Poland
C?ID=269551
is it possible to change the wheel size in vcds or the tire size in vw amarok, I changed the wheels to larger ones and I would like it to count kilometers correctly
downtime
Finland
C?ID=280813
From instruments. There's drop down list for different wheel sizes. It may work or it may not. Some cars it does and it changes the speedometer to more accurate but on some cars it does not have any effect.
Only way to find out is to try. Use GPS speed mobile app or similar to record the actual speed. This makes it easy to compare reading vs actual.
South Molton, UK
How much has the overall diameter of the wheel & tyre combination changed? There are many online tyre calculators which will tell you the difference between your OE fitment and your new fitment.
It's usual when fitting larger diameter wheels to fit lower profile tyres,which means the overall diameter is only very slightly changed.
Given that it's a requirement for Type Approval for the speedo to over-read by between 0% and 10% (usually with the OE wheel/tyre combination it's around 5%) so the need to actually change the calibration is rare (except for those with OCD).
lukas_amarok_13
Poland
C?ID=269551
the diameter of my wheel is now 38.5 mm larger, the odometer shows a lower speed than in truth, the odometer also counts differently
South Molton, UK
But how much larger is the outside diameter of the tyre? The wheel diameter is not important, it's the combined diameter of the wheel PLUS tyre that's important.
To help please post the wheel and tyre sizes (wheel diameter and tyre width plus profile) of both the original and new fitments.
An example: my previous second car came with 14" wheels and 155/65 tyres but I fitted 16" wheels with 195/40 tyres - but the combined diameter was only 5mm larger despite the wheels being 50mm larger - with the result that the wheels only made 6 turns less per km and the speedo/odometer was only reading 0.9% less (less difference than between new and worn tyres!).
lukas_amarok_13
Poland
C?ID=269551
my original tires are 255 / 60R18, my new tires are 265 / 65R18. The diameter of the wheel increased by 38.5 mm.
Previously, the wheel was 763.2 mm in diameter, now it is 801.7 mm
South Molton, UK
OK, I see the confusion you are saying the "wheel" diameter has changed when actually the wheel (the metal part) is unchanged at 18", it's only the tyre that you have changed ;).
I guess you'll be asked to post an adaptation channel list from your instruments at #17 for someone to tell if your instruments can be told about your new larger size tyres.
I agree with the above contributions. We should start with the complete Auto-Scan. That should be enough to identify the instrument cluster type and current coding.
lukas_amarok_13
Poland
C?ID=269551
Hello
Here is my Auto scan, sorry for the form and language but I don't know how to do it otherwise.
Does anyone know how to resize the wheel on the Amarok
Typ podwozia: 2H-VN81 (6N0)
Skanowanie: 01 02 03 04 08 09 10 15 17 19 25 32 37 56 69 6C 0B
VIN: WV1ZZZ2HZDH017514   Przebieg: 123890km
01-Silnik -- Stan: OK 0000
02-Skrzynia biegów -- Stan: OK 0000
03-ABS/hamulce -- Stan: OK 0000
04-Kąt skrętu kierow. -- Stan: OK 0000
08-Klimatyzacja -- Stan: Usterka 0010
09-Centr.zesp.elektr. -- Stan: OK 0000
10-Asyst.park./kierow. -- Stan: OK 0000
15-Airbag -- Stan: OK 0000
17-Zest.wskaźników -- Stan: OK 0000
19-CAN Gateway -- Stan: OK 0000
25-Immobiliser -- Stan: OK 0000
32-Blok.dyferencjału -- Stan: OK 0000
37-Nawigacja -- Stan: OK 0000
56-Radio -- Stan: OK 0000
69-Przyczepa -- Stan: OK 0000
6C-Kamera wsteczna -- Stan: OK 0000
Adres 01: Silnik (J623-CSHA)       Plik etykiet:. 03L-906-022-CFC.clb
   Oznaczenie elementu SW: 03L 906 012 AF    HW: 03L 907 309 AC
   Komponent: R4 2,0L EDC   H24 5936
   Weryfikacja: 74H24---    Numer seryjny: 00000000000000
   Kodowanie: 012A4012232600080001
   Kod serwisu: WSC 02739 790 50316
   Zbiór danych ASAM: EV_ECM20BTD01103L906012AF 001009
   ROD: EV_ECM20BTD01103L906012AF_001.rod
   VCID: 6889BD5DB2F8A3CB273-803C
Nie znaleziono błędów.
Kody gotowości: 0 0 0 0 0
Adres 02: Skrzynia biegów (J217)       Plik etykiet:| 0CM-325-025.clb
   Oznaczenie elementu SW: 2H0 927 158 B    HW: 0CM 325 025
   Komponent: 2H0 20RTDIRdW H16 3009
   Weryfikacja: --H16---
   Kodowanie: 000001
   Kod serwisu: WSC 00000 000 00000
   Zbiór danych ASAM: EV_TCMAL450211 002011
   ROD: EV_TCMAL450211_002_VN81.rod
   VCID: 2C01014D66804FEB03B-8078
Adres 03: ABS/hamulce (-----)       Plik etykiet: 2H0-907-37x-ESP.clb
   Oznaczenie elementu SW: 2H0 907 379 L    HW: 2H0 907 379 D
   Komponent: ESP MK25A XT  H44 0110
   Weryfikacja: 00H44001
   Kodowanie: C07324B69A95039C24A759A46F5490
   Kod serwisu: WSC 02739 790 49152
   VCID: 392F28199952EA4388D-806C
Adres 08: Klimatyzacja (J255)       Plik etykiet:| 7E5-907-040.clb
   Oznaczenie elementu SW: 2H0 907 040 E    HW: 2H0 907 040 E
   Komponent: ClimatronicT5 H19 0406
   Weryfikacja: 00001003
   Kodowanie: 0000000002
   Zbiór danych ASAM: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 2313EA710B5E8093B21-8076
2 - ilość znalezionych błędów. Oto one:
9473137 - Silnik nastawczy klapy temperatury z lewej strony
          B108C 71 [008] - Nastawnik zablokowany
          Sporadyczny - Potwierdzony - Testowany od skasowania kodów błędów
             Ramka zamrożona:
                    Stan błędu: 00000001
                    Priorytet błędu: 2
                    Częstość błędu: 1
                    Wew.licznik błędów: 66
                    Przebieg: 122776 km
                    Data: 2021.04.11
                    Czas: 20:13:50
9473393 - Silnik nastawczy klapy temperatury z prawej strony
          B108D 71 [008] - Nastawnik zablokowany
             Ramka zamrożona:
                    Priorytet błędu: 2
                    Częstość błędu: 3
                    Wew.licznik błędów: 72
                    Przebieg: 122815 km
                    Data: 2021.04.11
                    Czas: 20:34:46
Adres 09: Centr.zesp.elektr. (J519)       Plik etykiet:. 7H0-937-08x-09.clb
   Oznaczenie elementu SW: 7H0 937 090     HW: 7H0 937 090
   Komponent: BCM PQ25 Max4 H72 0708
   Weryfikacja: B9072001    Numer seryjny: 0531 102131843
   Kodowanie: 310002380CF3040093380EB17C8B96D50F88672F60853041300000020003
   Kod serwisu: WSC 45678 345 34567
   VCID: 6B83C251A38E88D34A1-803E
   Podsystem 1 - Oznaczenie elementu: 1K0 955 559 AH  Plik etykiet: 1K0-955-559-AG.CLB
   Komponent: RLS 020413 05  54  0403
   Kodowanie: 02302D
   Podsystem 2 - Oznaczenie elementu SW: 6R0 959 801 M    HW: 6R0 959 801 M  Plik etykiet: 6R0-959-801.CLB
   Komponent: J386__TSG_FT  002 3322
   Numer seryjny: --------------------
   Kodowanie: 040000
   Podsystem 3 - Oznaczenie elementu SW: 6R0 959 802 P    HW: 6R0 959 802 P  Plik etykiet: 6R0-959-802.CLB
   Komponent: J387__TSG_BT  002 3322
   Kodowanie: 040000
   Podsystem 4 - Oznaczenie elementu: 1K8 951 171 A
   Komponent: DWA-Sensor 00  001 0103
   Kodowanie: 000000
   Podsystem 5 - Oznaczenie elementu: 1K8 951 605 B
   Komponent: LIN BACKUP HO  H11 9005
   Kodowanie: 000000
   Podsystem 6 - Oznaczenie elementu: 1K8 951 171 A
   Kodowanie: 000000
   Podsystem 7 - Oznaczenie elementu SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Komponent: E221__MFL-TAS  H31 0033
   Numer seryjny: 0559304
   Kodowanie: 020000
   Podsystem 8 - Oznaczenie elementu SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Komponent: J388__TSG_HL  002 3322
   Kodowanie: 000000
   Podsystem 9 - Oznaczenie elementu SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Komponent: J389__TSG_HR  002 3322
   Kodowanie: 000000
Adres 10: Asyst.park./kierow. (J446)       Plik etykiet:| 7E0-919-475.clb
   Oznaczenie elementu SW: 7E0 919 475 L    HW: 7N0 919 475
   Komponent: PARKHILFE 8K  H06 0106
   Weryfikacja: --------    Numer seryjny: 28231308501847
   Kodowanie: 318103
   Kod serwisu: WSC 00120 259 177408
   Zbiór danych ASAM: EV_VW75XParkAssis8K 001003
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 3B23321193EED8539A1-806E
Adres 15: Airbag (J234)       Plik etykiet:| 5K0-959-655.clb
   Oznaczenie elementu SW: 2H0 959 655 B    HW: 2H0 959 655 B
   Komponent: VW10Airbag00B H07 0013
   Weryfikacja: --------    Numer seryjny: 003HN00C6NHF
   Kodowanie: 000000000000000000000000000000003042
   Zbiór danych ASAM: EV_AirbaVW10BPAVN750 A01026
   ROD: EV_AirbaVW10BPAVN750_VN75.rod
   VCID: 33331A31BBBE1013421-8066
   Czujnik zderzenia bocznej poduszki bezpieczeństwa kierowcy:
   Numer seryjny: 3495RRB400G50GBONPSN
   Czujnik zderzenia bocznej poduszki bezpieczeństwa po stronie przedniego pasażera:
   Numer seryjny: 3505RRB400G50GBOD9BF
   Czujnik zderzenia przedniej poduszki bezpieczeństwa kierowcy:
   Numer seryjny: 3555YRB400850DLK9907
   Czujnik zderzenia przedniej poduszki bezpieczeństwa przedniego pasażera:
   Numer seryjny: 3565YRB400C50DLKR9QD
Adres 17: Zest.wskaźników (J285)       Plik etykiet:| 5K0-920-xxx-17.clb-SRI1
   Oznaczenie elementu SW: 2H0 920 863 C    HW: 2H0 920 863 C
   Komponent: KOMBI         H03 0307
   Numer seryjny: 00000015750349
   Kodowanie: 150800
   Zbiór danych ASAM: EV_DashBoardUDSJCIPQ25 A01720
   ROD: EV_DashBoardUDSJCIPQ25_A01.rod
   VCID: 290FF85969725AC3F8D-807C
Adres 19: CAN Gateway (J533)       Plik etykiet:. 6N0-909-901-6R.clb
   Oznaczenie elementu SW: 6N0 909 901     HW: 7H0 937 090
   Komponent: GW-K-CAN TP20 H72 0708
   Kodowanie: 742200
   VCID: 70B9D53D8AA86B0B7F3-8024
Adres 25: Immobiliser (J285)       Plik etykiet:. 5K0-920-xxx-25.clb
   Komponent: IMMO          H03 0015
   Numer seryjny:
   Zbiór danych ASAM: EV_ImmobUDSJCIPQ25 A01003
   ROD: EV_ImmobUDSJCIPQ25.rod
Adres 32: Blok.dyferencjału (J647)       Plik etykiet:* 2H0-927-771.clb
   Oznaczenie elementu SW: 2H0 927 771 A    HW: 2H0 927 771
   Komponent: Quersperre    H04 0017
   Weryfikacja: 11001001    Numer seryjny: 4DG 30.01.13 00
   Kodowanie: 000001
   Zbiór danych ASAM: EV_QuersUDSAAMVN817 A01606
   ROD: EV_QuersUDSAAMVN817.rod
Adres 37: Nawigacja (J0506)       Plik etykiet:. AKP\1T0-035-680.clb
   Oznaczenie elementu SW: 2H0 035 680     HW: 2H0 035 680
   Komponent: RNS-MID       H09 5238
   Weryfikacja: AB001001    Numer seryjny: VWZ6Z7N7063155
   Kodowanie: 04000402020000A00016
   Kod serwisu: WSC 02739 790 00000
   VCID: 6099A57D5A48DB8BEF3-8034
   Podsystem 1 - Oznaczenie elementu: 1T0 919 859 C
   Komponent: EU East V12  8196
Adres 56: Radio (J0506)       Plik etykiet:. AKP\1T0-035-680.clb
Adres 69: Przyczepa (J345)       Plik etykiet:. AKP\1K0-907-383-V2.clb
   Oznaczenie elementu SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Komponent: Anhaenger     H09 0100
   Weryfikacja: 3A001001    Numer seryjny: 00008030422177
   Kodowanie: 0100000100000000
   VCID: 3039153D4A282B0B3F3-8064
Adres 6C: Kamera wsteczna        Plik etykiet: 5N0-907-441.clb
   Oznaczenie elementu SW: 2H0 907 441     HW: 2H0 907 441
   Komponent: J772__Rearview      0020
   Weryfikacja: 00H11000    Numer seryjny: 525 PA8J330004
   Kodowanie: 0020017
   Kod serwisu: WSC 02757 790 00000
   VCID: 6393AA71475EC093F21-8036
Instrument Cluster coding, Byte 0, bits 0-3 have 8 possibilities for "K-Number". I believe this is will set the impulses / km, but there is nothing documented how the index value there (0-7) correlates to the actual number of impulses, so some experimentation may be necessary. Assuming the cluster allows changes to that field, perhaps one of them will get you close.
There is also an interesting measuring value:
IDE00845 -- Wheel circumference (mm)
You might want to check what's there and if it changes when you change the above coding field.
PS: You can install the English version of VCDS from this page and it will happily coexist on your PC with the Polish translation you are currently using.
