2016 Golf R no start, multi malfunctions-no communication
Zeljo
Edmonton, AB, Canada
C?ID=123505
2016 Golf R no start, multi malfunctions-no communication. Turbo area caugh on fire and some wirring was burned, complete wirring harness was replaced, now has multiple no communications, engine scan communicated once or twice but cant get it to do it again. all fuses and relays are good. Anyone ????
Monday,03,May,2021,15:43:49:09301
VCDS Version: 21.3.0.0 (x64)
VIN: WVWLF7AU1GW120743   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
          55 5F A5 A9
VIN: WVWLF7AU1GW120743   Mileage: 126792km-78784miles
01-Engine -- Status: Cannot be reached 0100
02-Auto Trans -- Status: Cannot be reached 0100
03-ABS Brakes -- Status: Cannot be reached 0100
08-Auto HVAC -- Status: Cannot be reached 0100
10-Park/Steer Assist -- Status: Cannot be reached 0100
13-Auto Dist. Reg -- Status: Cannot be reached 0100
14-Susp. Elect. -- Status: Cannot be reached 0100
15-Airbags -- Status: Cannot be reached 0100
22-AWD -- Status: Cannot be reached 0100
3C-Lane Change -- Status: Cannot be reached 0100
44-Steering Assist -- Status: Cannot be reached 0100
47-Sound System -- Status: Cannot be reached 0100
55-Headlight Range -- Status: Cannot be reached 0100
A5-Frt Sens. Drv. Assist -- Status: Cannot be reached 0100
A9-Struct. Borne Sound -- Status: Cannot be reached 0100
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
   Revision: 00021000    Serial number: 0379254649
   Coding: 030C0C
   VCID: 3A71CCCFBD7BCC5BCD-806E
Address 08: Auto HVAC
   Part No SW: 5Q0 937 085 AJ    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061524600182
   Coding: 00011A46C041A2E149E44000091C07201800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 01037B23902D5F83CC-8054
   Component: WWS    150707  043 0551
   Serial number:         150804122100
   Component: RLHS  037 0059
   Serial number: S4Y15M09D16H10M37S54
   Coding: 90A8DD
136455 - Terminal 15
          B1148 11 [009] - Short to Ground
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 00:32:21
137217 - Outside temperature sensor
          B103F 1B [009] - Resistance Too High
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 00:32:21
          U1101 00 [009] - Active
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 00:32:21
Address 10: Park/Steer Assist
Address 13: Auto Dist. Reg
Address 14: Susp. Elect.
Address 15: Airbags
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 09091504400595
   Coding: 0C10
   VCID: 09136303A81D17C394-805C
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
   Part No SW: 5G1 920 758 A    HW: 5G1 920 758 A
   Component: KOMBI         302 6420
   Coding: 0BAD081A7F88880902886A0B5400000000000000
   VCID: 2D5BF7937C356BE358-8078
16 Faults Found:
16776960 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 01:09:51
16776961 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 01:09:51
16776962 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 01:09:51
16776966 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 01:09:51
16776967 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 01:09:51
16776968 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 01:09:51
16776969 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 01:09:51
16776970 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 01:09:51
16776971 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 01:09:51
16776973 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 01:09:51
16776978 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 01:09:51
16776982 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 01:09:51
16776983 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 01:09:51
16776988 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 01:09:51
13639936 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 01:09:51
16776993 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 01:09:51
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1223
   Revision: --------    Serial number: 0003899254
   Coding: 0101000830085900FB00023A9C0F00000001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 75EB1FF3D4E56323E0-8020
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0040
   Serial number: 29150001780210045373
   Coding: 35FFFF
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 00:47:08
                    Terminal 30 power supply: 12.2 V
                    Terminal 15: OFF
66562 - Data Bus for Suspension
          U10A9 00 [009] - Defective
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 00:47:05
                    Terminal 15: OFF
0513 - Terminal 15
          U1405 00 [009] - Implausible signal
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 00:32:22
                    Terminal 30 power supply: 12.3 V
                    Terminal 15: OFF
Address 22: AWD
   Revision: 00000000    Serial number: 15000191590006
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 346DE2F79F1F3A2B17-8060
Address 3C: Lane Change
   Serial number: 020915BI110068
   Coding: 003E13208000040000000000
   VCID: 438FB12BCAB18D939E-8016
   Serial number: 00000000000007190532
   Coding: 111000
Address 44: Steering Assist
Address 47: Sound System
   Serial number: 200815BHK03573
   Coding: 003E13208000040000800000
   VCID: 4281B42FD5AB849B95-8016
   Serial number: 00000000000007265534
   Coding: 091000
Address 55: Headlight Range
   Part No SW: 3G0 035 047 D    HW: 3G0 035 047
   Component: MU-H-NS-US    H42 0344
   Serial number: A296I0F7501479
   Coding: 027300020000000051220002001828001F0207F401200105DE
   VCID: 21431BA330EDBF83EC-8074
   Subsystem 1 - Part No SW: 5G0 919 606 B    HW: 5G0 919 606 B
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU9001DY
   Subsystem 2 - Part No SW: V03 959 801 BS    HW: -----------
   Component: NAR 2015/2016  --- 0044
   Compact disc data bank:
   Component: Gracenote2  --- 3007
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 00:32:23
                    Voltage terminal 30: 12.4 V
1637 - Interface for External Media
          U11B8 00 [009] - No Communications
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.17
                    Time: 00:32:24
                    Voltage terminal 30: 12.5 V
                    Interface for external media: status-Status: Open circuit
Address A5: Frt Sens. Drv. Assist
Address A9: Struct. Borne Sound
End-------------------------(Elapsed Time: 04:13)--------------------------
hmm........ mighty sick auto-scan - at least 2 x CAN buses (i.e. Powertrain and Running-gear) not operational. Common point is J533 (hex19 module), so perhaps this is the starting point. Suggest removing ALL modules on the Powertrain bus (say), then plug-in a module (ECU, say) then re-run auto-scan. Do you get comms? If not-start tracing CAN high/low lines from J533 connector into the car's wiring loom (ofcourse, you need a WD). If yes, plug-in another Powertrain module and repeat. Then do same with Running-gear CAN bus
This might help (ignore circled modules - I originally used this picture for another purpose):
Jef
HQ
So the Access Start is the starting point for powering up the car... no fault codes so I will assume it is giving the thumbs up signal to allow other modules to do their job.
Terminal 15 B1148 11 [009]
Short to Ground Confirmed - Tested Since Memory Clear
So here is were I think you are having a major point of failure. Termianl 15 is "ignition on". The J519 powers up a relay that in turn feeds that glorious Terminal 15 power to just about everything... but the J519 is politely saying "that relay is ph#cked up".
The relay in question, it is the J329 Terminal 15 relay. This is located on a fuse/relay block up under the dash, left of steering column, position R4:
Is the wire from the J519 to the J329 relay good? Relay itself good? Ground wire from J329 relay good?
The J519 isn't happy with that circuit.... solve that issue and lets see how much happier the car it.
Zeljo
C?ID=123505
Everything on J329 is good, i m suspecting J519 is bad is there a way for me to confirm faulty J519 ?? here is my new auto -scan when i reconnect the battery i can access engine and trans modules only Once, then i need to reconnect battery again to access them again otherwise shows no communication.
I cant access ABS or Airbag modules at all.
Wednesday,05,May,2021,14:14:50:09301
          55 5F A5 A9
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 H    HW: 06K 907 425 E
   Revision: --H13---
   Coding: 091D00122466000E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
   ROD: EV_ECM20TFS0208V0906259H.rod
   VCID: 458BAF33C485B3A3B0-8010
Readiness: N/A
   Coding: 030C0C
1069319 - Wake-Up Signal from Control Module for Access/Start Authorization
          U1093 00 [008] - Short to GND
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:51
   Coding: 90A8DD
12 Faults Found:
132363 - Voltage Supply; Terminal 30; Left
          B140D 13 [008] - Open Circuit
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:52
133131 - Voltage Supply Terminal 30
          B1423 13 [008] - Open Circuit
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:52
133643 - Voltage Supply; Terminal 30 for Anti-Theft Alarm System
          B1410 13 [008] - Open Circuit
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:51
                    Fault Frequency: 22
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:08:24
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:08:24
395273 - Control Circuit for Signal Horn
          B1344 14 [008] - Open or Short to Ground
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:02:33
460041 - Heated Rear Window
          B1265 14 [008] - Open or Short to Ground
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:51
919810 - Dimmer Control for Instrument Panel Illumination
          B1201 21 [008] - Signal Amplitude Too Low
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:51
934148 - No Communications with Rain/Light Sensor
          U10F6 00 [008] - -
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:51
939524 - No Communications with Humidity Sensor
          U10F5 00 [008] - -
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:51
947204 - Control Module for Wiper Motor
          U10A3 00 [008] - No Communications
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:02:33
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:08:24
Address 15: Airbags
   Coding: 0C10
19 Faults Found:
16777008 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:00:10
16777010 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:00:10
16777028 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:00:10
16776960 - Databus
                    Fault Frequency: 21
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:29
16776961 - Databus
                    Fault Frequency: 21
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:29
16776962 - Databus
                    Fault Frequency: 21
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:29
16776966 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:29
16776967 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:29
16776968 - Databus
                    Fault Frequency: 23
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:29
16776969 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:29
16776970 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:29
16776971 - Databus
                    Fault Frequency: 21
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:29
16776973 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:29
16776978 - Databus
                    Fault Frequency: 23
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:29
16776982 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:29
16776983 - Databus
                    Fault Frequency: 21
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:29
16776988 - Databus
                    Fault Frequency: 21
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:29
13639936 - Databus
                    Fault Frequency: 20
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:29
16776993 - Databus
                    Fault Frequency: 23
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:01:29
   Generator:
   Coding: 35FFFF
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:00:33
                    Terminal 30 power supply: 11.9 V
                    Terminal 15: OFF
0513 - Terminal 15
                    Fault Frequency: 22
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:00:33
                    Terminal 15: OFF
Address 22: AWD
   Coding: 111000
65799 - Door Warning / Entry Lighting
          B1775 01 [009] - Electrical Failure
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:00:01
   Coding: 091000
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:08:26
                    Voltage terminal 30: 12.2 V
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:08:28
End-------------------------(Elapsed Time: 04:22)--------------------------
Zeljo
C?ID=123505
Anyone guys ??? Also wondering if i swap BCM-J519 (got used one, same part number, same vehicle as mine) will i be able to crank or start the engine without coding it or anything, its keyless ignition ???
Jef
HQ
It is possible the J519 is bad. I see some Terminal 30 codes in there now... not good but the are listed as "Intermittent". Do they come back if cleared?
As for plugging up another J519, if that is the fix, you will get a car that wakes up (Terminal 15) and be able to scan other modules.
@Zeljo: "got used one"?
hmm....... is the BCM that's reported in both auto-scans the factory original? Reason for asking is that the hex09 module reports Component Protection DTC being active (odd that the hex19 doesn't also report CP). There's also CP error on hex5F module, but I assume that the infotainment unit has been replaced with hacked module- so not relevant to your problem.
Regardless of whether the BCM is original, or not - the confirmed CP error in both scan suggests that the hex09 module isn't reporting the correct identity to the CP master (hex19 module) at ignition switch-on - which means that the BCM isn't registered to be connected to the car's CAN network - which could explain some (many?) of the hex09 errors.
As to why the BCM isn't reporting its identity during the CP challenge/response procedure (if the BCM is indeed the factory original)- this could be because of an internal module error - maybe?
In any event, if the BCM is replaced as part of the current exercise, a new CP error will be generated which will necessitate a trip to a dealer (a FAZIT connection is needed) to make the new module fully operational.
PS: Of itself, a CP error (alone) on the BCM should not stop the hex09 module from generating a switch-on signal for T15 on J329 relay
PPS: Please confirm - does J329 relay operate after ignition switch-on (as per @Jef post above)?
PPPS: Even if the BCM is faulty - it's possible to force a T15 rail voltage because the good thing about electo-mechanical relays is that their contacts are completely isolated (electrically and physically) from the coil. So a T15 voltage can be manually forced (after ignition switch-on) by simply shorting the 2 x contact-pins (i.e, pin#30 & pin#87) on the plug for J329 - see relay pin-out below. However - given that in this case a part of the car's wiring loom was subjected to fire damage - it might be prudent to include an in-line fuse into the shorting wire (for added protection) if you proceed with my suggestion
Zeljo
C?ID=123505
yes
tried different J519 and no change, had exact same codes
yes it was original BCM, i had factory amp under the driver seat unplugged, plugged it back in but CP is still present
plugged in another BCM but it showed same codes didnt change a thing
tried jumping and again absolutely nothing happened
got another used ABS and Air bag module to see if i could get communication but again nothing changed at all.
any other suggestion guys ?????
myounus
Northwest UK
C?ID=321059
Databus and terminal 15 errors on your gateway suggest some of the car’s loom may still be damaged. I would personally check if any wires have welded together and continuity test them all using a proper wiring diagram. Also check plugs have got proper clean connections
To be clear - with ignition switched-on, have you actually measured voltages on the 4 x pins of J329 with a multi-meter.
With the relay in-situ, a healthy car you should have battery bolts on the 3 x relay pins excluding the earth pin - and with the relay un-plugged, volts should appear on "T30" and "J519" pins (of course a check should also be made on the integrity of the earth pin on the relay socket).
Zeljo
C?ID=123505
Databus and terminal 15 errors on your gateway suggest some of the car’s loom may still be damaged. I would personally check if any wires have welded together and continuity test them all using a proper wiring diagram. Also check plugs have got proper clean connectons
wiring harness for engine and engine bay harness complete with fuse box was replaced from same model running vehicle.
ground is good at relay socket, i only get voltage at T30, I wire jumped pin 30 and pin 87 and got vehicle to communicated bit better, here is current autoscan with relay terminals wire jumped but still no start or crank. Note: airbag module is from donor car as looks like mine was fried (had no comm), also my ABS pump is not connected at all i just left if unplugged as its fried from fire, do you think i need to have ABS pump connected in order for engine to start ????? also would dash fuse box have some kind internal fuse that might be broken causing these issues for terminal 15 ?????
Wednesday,04,August,2021,15:46:42:09301
VIN: WVWLF7AU1GW120743   License Plate: R
Mileage: 126792km-78784mi   Repair Order:
          55 5F A5 A9
47-Sound System -- Status: Malfunction 0110
   Revision: --H13---
21400 - Valve for Exhaust Flap 2 (N322)
          P3022 00 [109] - Short to Ground
                    Mileage: 124316 km
                    Date: 2019.11.09
                    Time: 04:13:00
                    Engine RPM: 739.75 /min
                    Normed load value: 28.6 %
                    Coolant temperature: 102 °C
                    Intake air temperature: 65 °C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 13.632 V
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 7 s
                    MAP_MES_SAE: 43 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.982 V
                    FAC_TPS_1_SAE: 13.281250 %
                    FUP_H_SAE: 5890.0 kPa
23648 - Heater support pump
          P16C1 00 [039] - Open circuit
                    Mileage: 126765 km
                    Engine RPM: 0.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 28 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 12.597 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 93 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 15.625000 %
                    FUP_H_SAE: 430.0 kPa
15282 - Starter Will Not Turn
          P3054 00 [096] - Jammed or Electrical Malfunction
17178 - Databus
          U1123 00 [096] - Received Error Message
Readiness: N/A
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4904
   Revision: 06253104    Serial number: TFK01509020222
   ROD: EV_TCMDQ250021.rod
   VCID: 53AF816B3AD11D132E-8006
   Coding: 030C0C
   Coding: 90A8DD
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:11:57
934664 - Rain/Light Recognition Sensor
          B1366 29 [008] - Signal Implausible
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:00:02
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:11:57
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM01PZJF
   Shop #: WSC 01383 790 50316
   VCID: 51A38B6300CD6F031C-8004
   Subsystem 1 - Part No SW: -----------    HW: -----------
   Component: BF-Gewichtss.  --- ----
   Serial number: ---0000---000-----09
   Subsystem 2 - Part No SW: -----------    HW: 480 000 209 15
   Serial number: 35700000000515CC361H
   Subsystem 3 - Part No SW: -----------    HW: 480 000 209 15
   Serial number: 3580000000086CEC261Y
   Subsystem 4 - Part No SW: -----------    HW: 480 400 709 15
   Serial number: 3510002B51D1B5D3030Y
   Subsystem 5 - Part No SW: -----------    HW: 480 402 408 15
   Serial number: 3520002B91CF2D85D30I
   Subsystem 6 - Part No SW: -----------    HW: -----------
   Component: FrontSensor_D  --- ----
   Serial number: -------------------$
   Subsystem 7 - Part No SW: -----------    HW: -----------
   Component: FrontSensor_P  --- ----
10 Faults Found:
9440027 - Driver's side; side-airbag igniter
          B100B 1B [137] - Resistance Too High
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:03:56
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [137] - Resistance Too High
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:03:56
9443861 - Driver's Front Airbag Crash Sensor
          B101A 15 [137] - Open or Short to Plus
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:03:59
9444117 - Front Passenger's Front Airbag Crash Sensor
          B101B 15 [137] - Open or Short to Plus
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:03:59
9444885 - Driver's seat position sensor
          B101E 15 [137] - Open or Short to Plus
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:03:57
9445141 - Passenger's seat position sensor
          B101F 15 [137] - Open or Short to Plus
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:03:55
15360768 - Component Protection
          U1101 00 [137] - Active
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:03:55
9445937 - Seat occupied recognition control module
          B1022 31 [137] - No Signal
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:03:59
1052928 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:03:56
1052672 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:03:56
   Coding: 0C10
18 Faults Found:
          U1110 00 [008] - -
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:00:31
          U1110 00 [008] - -
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:00:31
          U1110 00 [008] - -
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:12:00
16776960 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:11:57
16776961 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:11:57
16776962 - Databus
                    Fault Frequency: 8
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:11:57
16776966 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:11:57
16776967 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:11:57
16776968 - Databus
                    Fault Frequency: 9
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:11:57
16776969 - Databus
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:02:53
16776970 - Databus
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:02:53
16776971 - Databus
                    Fault Frequency: 8
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:11:57
16776973 - Databus
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:11:57
16776978 - Databus
                    Fault Frequency: 9
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:11:57
16776982 - Databus
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:02:53
16776983 - Databus
                    Fault Frequency: 8
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:11:57
16776988 - Databus
                    Fault Frequency: 8
                    Reset counter: 227
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:11:57
16776993 - Databus
                    Fault Frequency: 9
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:11:57
   Generator:
   Coding: 35FFFF
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:12:36
                    Terminal 30 power supply: 12.5 V
                    Terminal 15: OFF
0513 - Terminal 15
                    Fault Frequency: 8
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:11:57
                    Terminal 30 power supply: 12.6 V
                    Terminal 15: OFF
Address 22: AWD
   Component: HRE_Master    H11 0071
   Serial number: 0378842561
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C7DCAD7B74FF26BDF-8068
   Component: HRE_Slave  H11 0071
   Serial number: 0378933384
   Coding: 020111
   Coding: 111000
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:00:01
   Coding: 091000
   Coding: 022202010B010400
   VCID: 4085BE27DBA7968B83-8014
   Subsystem 1 - Part No SW: ID-L fehlt     HW: -----------  Labels: ID-55-01.CLB
   Component: LeiMo links  ... ....
   Coding: FF0000
   Subsystem 2 - Part No SW: ID-R fehlt     HW: -----------  Labels: ID-55-02.CLB
   Component: LeiMo rechts  ... ....
   Coding: FF0000
5276144 - Power Output Module for Left Headlamp
          C1081 F0 [137] - Not Coded
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:11:56
5276400 - Power Output Module for Right Headlamp
          C1082 F0 [137] - Not Coded
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:11:56
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:11:59
                    Voltage terminal 30: 12.8 V
                    Reset counter: 187
                    Mileage: 126792 km
                    Date: 2020.01.18
                    Time: 00:12:00
Address A5: Frt Sens. Drv. Assist (R242)       Labels:. 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Serial number: 10000421702
   ROD: EV_MFKBoschAU370.rod
End-------------------------(Elapsed Time: 04:39)--------------------------
Zeljo
C?ID=123505
changed ABS pump/module with working one and still no comm.
Zeljo: hmm............ with no offense intended, your car is a mess! Nevertheless the "forced T15" trick does confirm (for me, at least) that @Jef suggestion above is sound!
I sense that getting the car to crank is a priority for you - but given the raft of other issues that is evident in your auto-scan, I suspect that there are a bunch of pre-cursor matters that must be addressed first
To this end, perhaps consider that this multi-headed beast of a problem is best tackled in a very disciplined manner; by systematically fixing one fault at a time - starting with the T15 DTC (because this facility affects so many other modules in the car).
So, this is a copy of @Jef WD:
As you can read and on a Yankee mk7 (I assume), the J329 relay triggers the car's T15 rail voltage to energize via pin #13, Socket A on the BCM. On MQB platform vehicles, this happens after the BCM recognizes that the key is turned to the ignition-ON position. Aprops of this latter point and notwithstanding that there are lots of modules on your auto-scan that "cannot be reached" - there is ample evidence IMO that the ignition wake-up message is being sent to the CAN network from the hex16 module (J527) to which the ignition key switch is connected.
So, if your observation is that with ignition-ON "i only get voltage at T30" - the only compelling conclusion is that the trigger signal from the BCM to J329 isn't happening!! Why?
Maybe trace the absence of this trigger signal through the wiring loom back to the connector on the BCM housing - is there a 12V signal on BCM Socket A, pin #13 housing connector with the ignition-ON?
kyle_h
Canada
C?ID=206710
Terminal 15 on the MQB cars is done through CAN-BUS ayways, the "terminal 15 relay" stuff is a "backup" type thing.
I'd suggest to unplug one module at a time on said CAN-BUS until communication restores, which should work if it's a module that's taking it down. If it's a wiring issue, this may not work.
@kyle_h: Hi. hm....... I have absolutely no intention of questioning your statement and I hope that we are saying the same thing - just using different words!!
My experience (and as I have already said) is that the general CAN network on MQB platform vehicles needs a "wake-up" message to initiate and to sustain inter-module communications. And, the wake-up message is indeed a CAN-Bus message. This message is generated continuously on the CAN bus whenever the hex44 module (J527) senses that the contacts on the multi-switch at the back of the key cylinder lock are in the ignition-on position.
Of course the wake-up message results in different modules doing different things - but one of the consequences of the BCM receiving this message is that the trigger signal for the coil on J329 is energized.
Now, some modules on the CAN bus need both the wake-up message and they need a T15 voltage to operate correctly. So in this sense, a T15 voltage is a kind-of health check for some modules - maybe this is what you mean by "the "terminal 15 relay" stuff is a "backup" type thing".
Without wishing to get into a semantic debate about the raison-d'etre for a T15 rail on MQB vehicles and whether the "back-up" function described above is incidental to the primary role of the switched-battery voltage to actually energize equipment - the fact is that having a properly functioning T15 rail is essential to fault-finding (IMO of course). In this sense, I can't agree that the other way of interpreting "terminal 15 relay" stuff is a "backup" type thing" is correct - but I suspect that it was not your intention to have your statement read in this way!!
Again, my plea to OP is to make sure that the car fundamentals are operating correctly first (i.e. before attempting to problem-solve more complex faults - like cranking). A stable and correctly operating T15 rail is key to this primary imperative - IMO of course!
Jef
HQ
J329 relay is used to power up several fuses...
  • SC32 = dist reg (J428) and park/steer assist (J446)
  • SC33 = airbag (J234)
  • SC34
  • SC35 = T16/1 of OBDII port
  • SC36 = right headlight
  • SC37 = left headlight
  • SC47
  • SC48
  • SC49
So we have no comm with dist reg and airbag, and the headlight range control states both headlights are "fehlt" (missing). So that J329 relay is kind of a big deal.
Now the ABS module seems to be a bit more oddball... looking at the wiring diagram, 3 fuses are listed, all are Terminal 30 fuses (power all the time).... what wakes up the ABS? Took me a few minutes but I found T46a/35 is a wire that has a weld point of "D51" which is noted as "Positive connection1 (15) (in engine compartment wiring harness)". Follow this wire further back, it goes to to another wed point "A192" which is noted as "Positive connection 3 (15a) (in instrument panel wiring harness). Said wire ends up at the J519 T73a/14.
Start hunting down other items that are split from weld points D51 or A192 and I find the address 01 and 14.
I stopped digging at this point... so some stuff is directly tied to the operation of that J329 relay. I'm not sure about the logic used for the weld points A192 and D51 that come from the J519.
no signal at all on pin#13
@Zeljo: Good - this is useful diagnostic information!!
The fact that the BCM has responded correctly to your auto-scan means that it is receiving the CAN wake-up message. Both auto-scans report B1148 11 [009] - Short to Ground for the BCM T15 fault.
To be clear and because your response is a tad "economic" (no offense intended) -With ignition-ON, if you measured the voltage on BCM pin#13, Socket A with the the connecting wire to the loom still in place - de-pin this wire and measure the voltage again on Socket A.
If you measured NO-voltage on BCM pin#13, Socket A with the connecting wire to the car-loom de-pinned - then this result suggests (to me) that the internal circuits inside the hex09 module are faulty (the T15 trigger signal in the BCM is not affected by the CP error)! In which case, this is an unusual fault since I believe that these circuits would be monitored/protected - was the BCM in your auto-scans original to this car and do the 3 x sockets on the BCM look OK physically ( maybe remove sockets and check mating pins)?
Also, before concluding that the BCM is faulty - check continuity (and isolation from chassis earth) for the "rt/sw" (meaning red/black) wire on @Jef WD. This wire terminates on BCM pin#13 Socket A and on either pin#85, or pin #66 (not sure which - but definitely not both) on the J329 relay plug.
