C7 S6 Transmission fault
M1Audi
Queens, NY, USA
C?ID=253353
Hello guys, first time in these forums, but had my ross-tech cable for a while now.
Anyway, need some help. Long story short, car was in bodyshop for minor front end repairs, acc calibration, front camera, and 4 wheel alignment.
When I drove out the body shop, car would lag in shifting but all was fine better repairs.
I have changed the filters and DSG fluid, but obviously the issue is still there. Wondering what direction I should take before dropping the Mechatronic unit.
Any fuses, sensors that may cause issues in relation to vehicle speed and transmission. Car is tuned.
A lot of faults have to do with the fact that I have a few things disconnected.
Very curious about the ABS fault code.
Saturday,01,May,2021,16:29:55:36438
VCDS Version: 20.12.0.1 (x64)
VIN: WAUF2AFC2GN------   License Plate: FAULT AFTER FLUSH
Mileage: 80344km-49923mi   Repair Order:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 28 34 36 3B 3C 42 44 46
          52 53 5F 62 6C 72 85 8B 8E 8F 90 A9 BA
VIN: WAUF2AFC2GN------   Mileage: 80344km-49923miles
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CTGE)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 014 D    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H63 0001
   Revision: NCH63---
   Coding: 0A2500326546010E3000
   ASAM Dataset: EV_ECM40TFS0114G0906014D 001001
   ROD: EV_ECM40TFS0114G0906014D.rod
   VCID: 2345BDD92A5BAE9C3F-8076
17875 - Exhaust Pressure Control Valve
          P0475 00 [039] - Electrical Malfunction
                    Mileage: 80344 km
                    Date: 2021.03.17
                    Time: 19:22:33
                    Engine RPM: 0.00 /min
                    Coolant temperature: 32 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 11.850 V
                    Engine status: COENG_READY
17876 - Exhaust Pressure Control Valve 2
          P049F 00 [039] - Malfunction
                    Mileage: 80344 km
                    Date: 2021.03.17
                    Time: 19:22:33
Readiness: 1110 1100
   Part No SW: 4G0 927 166 F    HW: 0B5 927 156 K
   Component: 0B5 40TFSINAR H03 0006
   Revision: --H03---
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL501021 001022
   ROD: EV_TCMDL501021.rod
   VCID: 306F42956BAD0504B2-8064
18022 - Valve 1 in Transmission Part 2
          P174C 00 [101] - Electrical malfunction
                    Mileage: 80344 km
                    Date: 2021.03.17
                    Time: 19:23:22
                    Engine RPM: 918 /min
                    Transmission input speed: 918 /min
                    Engine torque: -20 Nm
                    ATF temperature: 21 °C
                    Accelerator pedal position: 0.0 %
                    Clutch status: Beide Kupplungen offen
                    Voltage terminal 30: 14.200 V
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 65A6D649A6656B921B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41891751D0079C8C4D-8014
200192 - Function Restriction due to Implausible Message(s)
          U1112 00 [047] - -
                    Mileage: 80344 km
                    Date: 2021.03.17
                    Time: 19:22:32
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    Uz: 9B
   Part No SW: 4H0 907 064 GR    HW: 4H0 907 064 GR
   Component: BCM2 2.0      H37 0572
   Coding: 0DA86F4E000000000000
   VCID: 7F0D51A9EE732A7C7B-802A
   Serial number: 3216000062719015
   Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
   Serial number: 25041600040191
   Coding: 688130B84D0000
   VCID: 6ADB90FD8DF1BFD4BC-803E
   Part No SW: 4H0 907 063 DM    HW: 4H0 907 063 AM
   Component: BCM1 2.0      H20 0311
   Revision: 21020001    Serial number: 00001342799101
   Coding: 26008015017C9FE28901408780003D0CCF9CD208AE09022180000820710011020060002D0B0000
   Shop #: WSC 42936 001 104857
   VCID: 76E3B48DC1496B3428-8022
   Component: WWS57X 160319  H38 0080
   Serial number:         160406141619
   Coding: 0045F7
   Serial number: 61753962
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
   Component: E1 - LDS  H07 0044
   Serial number: 20 04 2016  00001294
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z0242CBB4
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA123487000020426363
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H03 0005
   Serial number: 9819842800PAG0MUFU01
                    Fault Status: 01100101
                    Reset counter: 53
                    Mileage: 80344 km
                    Date: 2021.03.17
                    Time: 20:45:22
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0055
   Coding: 7E01010102
   ASAM Dataset: EV_AdaptCruisContrAU57X 002015
   VCID: 2959AFF1487774CC75-807C
103168 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 93
                    Mileage: 80344 km
                    Date: 2021.03.17
                    Time: 19:23:22
                    Control Module temperature: 22 °C
                    Voltage terminal 15: 14.079 V
                    Velocity_vehicle_reference: -0.00 m/s
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G00033ZHY
   Coding: 303331343135303334354A55304C34473053
   VCID: 34674E859FB53924D6-8060
   Component: BF-Gewichtss.  H15 0046
   Serial number: 6940000Y160001GVUN0W
   Serial number: 3575HRB405T436HUCO60
   Serial number: 3585HRB405T42D1O291+
   Serial number: 3515JRB4002570BQFHM8
   Serial number: 3525JRB401A570BSS183
   Serial number: 3554VRB400G5718470PY
   Serial number: 3564VRB400G57184J0P4
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372PDJ0006H
   Coding: 0004FC
   VCID: 387F7AB58BDDDD44FA-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 30 03 2016  C0090265
   Part No SW: 4G0 920 982 L    HW: 4G0 920 982 L
   Component: TBenUsaAccNv  H11 0106
   Revision: 09001103    Serial number: 658250416596031
   Coding: 0BCF09051F51D705020200
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K_AU57.rod
   VCID: 3561738194CF202CE1-8060
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002235189
   Coding: C0ED074814
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: 3B7565B9B2EBF65C17-806E
   Serial number: 1895380004
   Voltage stabilizer:
   Serial number: 16021900000000000126
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 02018264747464545425363E00
   VCID: 67DDE9C996E382BCA3-8032
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Component: KLIMA FOND    H08 0113
   Serial number: 28041600040961
   Coding: 20
   VCID: 3E736CADA1F9E37430-806A
   Coding: 008002
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F6D41E976931AFCAB-807A
          C10C8 00 [009] - -
                    Reset counter: 53
                    Mileage: 80344 km
                    Date: 2021.03.17
                    Time: 19:22:32
   Revision: AA000000    Serial number: 00000196676216
   VCID: 77FDB989C643123C33-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA820BG7RM
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3663748D89C92B34E8-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H08 0070
   Serial number: 0402929750
   Coding: 040211
   VCID: 39797FB1B8D7C44C05-806C
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0070
   Serial number: 0402095121
   Coding: 040211
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F17015E00628002000013
   VCID: 45810341CC2FB0AC71-8010
   Component: RCevo         H56 0202
   Revision: 00000001    Serial number: 0000942385
   Coding: 101001010001
   Shop #: WSC 42936 001 1048576
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A7B60BDBDD1CF540C-806E
   Revision: 00002001    Serial number: 0402754426
   Coding: 0106063A00FA408583B0080402070E470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000346493
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST000XMSU500000
   Coding: 101F02
   Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93802284
   Component: TSG BF        H03 0511
   Coding: 011F17015E00628002000002
   VCID: 4683044DF129BBB478-8012
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000001815963
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 3169479160A70C0CBD-8064
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 025 B    HW: 4G1 035 025
   Component: MU-H-LNS-US   043 0387
   Serial number: A278D0GB030536
   Coding: 017551020000000013220002041A00102F0007E5F17001047E
   VCID: 1D318B210C3F986C09-8048
   Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
   Component: NAR 2018  --- 0063
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9GY804U2E
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349PDS000M2
   Compact disc data bank:
   Component: Gracenote2  --- 3006
          B11CF 53 [009] - Deactivated
                    Reset counter: 53
                    Mileage: 80344 km
                    Date: 2021.03.17
                    Time: 20:45:35
                    Voltage terminal 30: 12.2 V
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Component: TSG HL        H03 0511
   Coding: 010F17004000628002000002
   VCID: 49990F71E03754CC95-801C
   Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
   Component: TopView       H09 0361
   Revision: 11001001    Serial number: 82330JG0163816
   Coding: 0212000001010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
9617993 - Proximity Camera
          B145C 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 53
                    Mileage: 80344 km
                    Date: 2021.03.17
                    Time: 19:22:32
                    Voltage terminal 30: 11.8 V
                    Terminal 15 status: Terminal 15 on
   Component: TSG HR        H03 0511
   Component: DPC-SG        H27 0081
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C5756E5478561E48E-8078
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E01010102
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
   VCID: 275DA9C95E6342BC63-8072
          U1113 00 [008] - -
                    Reset counter: 93
                    Mileage: 80344 km
                    Date: 2021.03.17
                    Time: 19:23:22
                    Control Module temperature: 24 °C
                    Voltage terminal 15: 14.116 V
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000621904167
   Coding: 04C1BA180111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Component: RGS-VL        H16 0080
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   Component: RGS-VR        H16 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 326B489D65A13714C4-8066
   Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0010
   Serial number: 160225200386
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H10 0008
   Revision: 00001001    Serial number: 97813006723801
   ROD: EV_AEMLearAU64X.rod
   VCID: 285FAAF5537D4DC46A-807C
1294 - Actuator 1 for Drivetrain Mounts
          C1131 07 [009] - Mechanical Failure
                    Reset counter: 53
                    Mileage: 80344 km
                    Date: 2021.03.17
                    Time: 19:22:36
End-------------------------(Elapsed Time: 07:11)--------------------------[\code]
M1Audi
Queens, NY, USA
C?ID=253353
Here is another scan with cleared faults right after.
Here is a scan after clearing fault codes.
Saturday,01,May,2021,16:41:03:36438
VIN: WAUF2AFC2GN------   License Plate: CLEARAFTERF;USH
   Revision: NCH63---
                    Mileage: 80344 km
                    Date: 2021.03.17
                    Time: 20:54:47
                    Coolant temperature: 27 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 11.991 V
                    Mileage: 80344 km
                    Date: 2021.03.17
                    Time: 20:54:47
   Revision: --H03---
          U1112 00 [047] - -
                    Mileage: 80344 km
                    Date: 2021.03.17
                    Time: 20:54:46
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    Uz: 9B
   Coding: 0045F7
   Coding: 02006D
   Coding: 020300
   Coding: 7E01010102
   Coding: 0004FC
   Coding: C0ED074814
   Voltage stabilizer:
   Revision: AA001002
   Coding: 20
   Coding: 008002
          C10C8 00 [009] - -
                    Reset counter: 53
                    Mileage: 80344 km
                    Date: 2021.03.17
                    Time: 20:54:46
   ROD: EV_SARA2.rod
   Coding: 040211
   Coding: 040211
   Coding: 101F02
                    Reset counter: 53
                    Mileage: 80344 km
                    Date: 2021.03.17
                    Time: 20:54:47
                    Voltage terminal 30: 12.0 V
   Coding: EA060000
   Coding: 7E01010102
   ROD: EV_BC7.rod
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
                    Reset counter: 53
                    Mileage: 80344 km
                    Date: 2021.03.17
                    Time: 20:54:48
Since the OP is now Verified, moving this to Car Repair Support.
