Saturday,01,May,2021,19:07:09:47642
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 21.3.0.0 (x64) HEX-NET2 : 0.4544.4
Dealer/Shop Name: Porsche
Workshop Code: 460 23321 034560
VIN: WVWZZZ6EZ1W007574 License Plate:
Chassis Type: 6E (6X - VW Lupo (1999 > 2006))
Scan: 01 02 03 08 15 17 19 25 35 37 44 45 55 56
VIN: WVWZZZ6EZ1W007574 Mileage: 237060km-147302miles
Address 01: Engine Labels: 045-906-019-ANY.clb
Part No: 045 906 019 AA
Component: 1,2l R3 0001DS 1313
Coding: 00002
Shop #: 01286
VCID: 54FA1602E7E0EE0B7BB-4B5C
WVWZZZ6EZ1W007574 VWZ1Z0A1319016
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 35-10 - Electrical Fault - Intermittent
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 35-10 - Electrical Fault - Intermittent
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 35-10 - Electrical Fault - Intermittent
16485 - Mass Air Flow Sensor (G70)
P0101 - 35-10 - Implausible Signal - Intermittent
19557 - Motor for Intake Manifold Flap (V157)
P3101 - 35-10 - Open or Short to Ground - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
Readiness: 0 0 X X X
Address 02: Auto Trans Labels: 6N0-927-735.lbl
Part No: 6N0 927 735 F
Component: DS085 Getriebe 1370
Coding: 00000
Shop #: 00000
VCID: 3B285DBE6A7E01739A1-0964
01605 - Potentiometer 2 for Gear Recognition (G240)
16-00 - Signal Outside Specifications
Address 03: Brakes Labels: 6E0-907-379.clb
Part No: 6E0 907 379 A
Component: 30 IE CAN V006
Coding: 05623
Shop #: 01286
VCID: 2F3079EEAE06EDD3269-4B3C
16-10 - Signal Outside Specifications - Intermittent
Part No: 6E0 909 605
Component: 02 AIRBAG VW5 0005
Coding: 12338
Shop #: 01286
VCID: 6882D2F24B687AEB273-4B5C
32-00 - Resistance Too High
Address 17: Instruments Labels: 6X0-920-xxx-17.lbl
Part No: 6E0 920 800 J
Component: KOMBIINSTRUMENT BOO X96
Coding: 00134
Shop #: 12345
VCID: 280292F28BE8BAEBE73-5184
01316 - Control Module
Part No: 6N0 909 901
Component: Gateway K<->CAN
Coding: 00006
Shop #: 01286
VCID: 70B2BA9273B8B22B7F3-5184
Address 25: Immobilizer Labels: 6X0-953-257.lbl
Part No: 6X0 953 257
Component: IMMO 0008
Coding: 00001
Shop #: 00000
VCID: 7DAC93A634EACF43E45-4B1E
01176 - Key
65-10 - Unauthorized - Intermittent
Address 35: Centr. Locks Labels: 1C0-962-258-II.lbl
Part No: 1C0 962 258 J
Component: 03 Zentr.Verriegel. 0002
Coding: 00257
Shop #: 01286
VCID: 2E0E64EAA90CE4DB2DF-4B9A
00849 - S-contact at Ignition/Starter Switch (D)
25-00 - Unknown Switch Condition
End----(Elapsed Time: 02:59, VBatt start/end: 11.1V/10.8V. VIgn 0.0V)------
