Alternator LIN bus version
andythechief
Barnstaple, England and Linz, Austria
C?ID=65958
Is there a readily available method to determine which LIN bus version a given alternator regulator uses, or needs to use?
The reason I ask- a Bosch alternator from my 2009 Audi A5 was rebuilt and afterwards it worked fine, but only for short while ( few minutes) whereupon charge voltage drops to nominal battery voltage despite battery clearly needing more charge. The alternator has been turned off so to speak.
Reading around I find that LIN bus type is important, and on the car itself I find that the replacement regulator is not the same brand let alone part number as the old one I luckily photographed before it was sent away for repair. Photos of the alternator cover part number and the regulator itself are below:
I am due a new VAG supplied genuine regulator early next week, and will of course report back the results in due course, but I thought perhaps someone could save a little skin from my knuckles in the future with a method to discern which LIN bus version a particular car is using, and therefore minimise the need to get the old regulator off ( it is an absolute ****** to get off on this car ) if it is the correct one ( which appears to be possible to find from online datasheets in some cases at least, but of course not Bosch that I can find )
thanks in advance.
Here is a recent fault scan to give car details- ignore module 19 fault as this was caused by an incorrectly coded replacement battery which was since sorted. The fault which eventually came up and pointed to the incorrect regulator being used was also under module 19 but was related to 'intermittent communication' but the scan eludes me at this time. I will get hold of it from another computer and share.
Thursday,29,April,2021,22:40:51:61795
VCDS Version: 21.3.0.0 (x64)
VIN: WAUZZZ8T59A057623   License Plate: xxxxxxx
Mileage: 293070km-182105mi   Repair Order:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
          6C
VIN: WAUZZZ8T59A057623   Mileage: 293070km-182105miles
Address 01: Engine (J623-CCWA)       Labels:| 059-907-401-V1.clb
   Part No SW: 8K2 907 401 A    HW: 8K1 907 401 A
   Component: 3.0TDI EDC17  H01 0006
   Revision: 15H01---
   Coding: 0114002C180F0118
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM30TDI0118K2907401A 001006
   ROD: EV_ECM30TDI0118K2907401A.rod
   VCID: 2B528BF242F453D346-807E
   Part No SW: 8K0 907 379 AF    HW: 8K0 907 379 AF
   Component: ESP8 quattro  H04 0210
   Coding: 1B0500
   VCID: 7DF675AAE4000D63A8-8028
   Part No SW: 8K0 907 064 AD    HW: 8K0 907 064 AD
   Component: BCM2 1.1      H80 0145
   Coding: 071000
   VCID: 72EC5696AD5E421BC5-8026
   Component: J764 ELV MLB  H36 0042
   Serial number: 0209000030012007
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
   Component: MEM-BFS       H09 0043
   Revision: AA000000    Serial number: 00001001269954
   Coding: 08217025002400001000
   VCID: 428CC656DD7EB29B95-8016
   Part No SW: 8T2 820 043 T    HW: 8T2 820 043 T
   Component: KLIMA 3 ZONEN H06 0150
   Revision: D1000000    Serial number: 01120520090989
   Coding: 36160000
   VCID: 4382C352C264BB939E-8016
   Component: BCM1 1.0      H26 0253
   Revision: 05026001    Serial number: 00000000371554
   Coding: 260050914034AF010009000300005D5D001D038800010141000000
   VCID: 30689C9E63D2300B73-8064
   Subsystem 1 - Part No SW: 8T2 955 119 C    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 160208  H11 0040
   Serial number: SWFBIE 0000864
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10467211
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
   Component: E1 - LDS  H07 0090
   Serial number: 00000000000405091253
   Part No SW: 8K0 919 475 G    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0040
   Revision: 11001001    Serial number: 40040912702081
   Coding: 300001
   VCID: 3D76B5AAA480CD63E8-8068
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H37 0520
   Serial number: 003EFD02DK60
   Coding: 30323433363030303030554A305238543053
   VCID: 418EC95AD078A9838C-8014
   Serial number: 6334MSME48007220$
   Serial number: 6344MSME47332A5EM
   Serial number: 6352QSME3B292E32N
   Serial number: 6362QSME2D26190AL
   Serial number: 63732SME76241038U
   Serial number: 63832SME70283410P
   Revision: --------    Serial number: 90315IE4000B7
   Coding: 000016
   Part No SW: 8T0 920 981 B    HW: 8T0 920 981 B
   Component: KOMBIINSTR.   H32 0224
   Revision: 00200000    Serial number: 9D621F459
   Coding: 2F05010002002600010000
   VCID: 3B72BBB2BA94C353D6-806E
   Part No SW: 8T0 907 468 P    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0095
   Revision: EB500046    Serial number: 4600E0942480FF
   Coding: 000303
   VCID: 4E94E266192646FB01-801A
   Component: J367-BDM  H06 0160
   Serial number: 19079271240409
                    Reset counter: 245
                    Mileage: 293032 km
                    Date: 2021.04.29
                    Time: 21:12:00
   Component: MEM-FS        H09 0043
   Revision: AA000000    Serial number: 00001001270438
   Coding: 08397B25002400001000
   Part No SW: 8T0 959 793 J    HW: 8T0 959 793 D
   Component: TSG FA        H07 1301
   Coding: 011012225E01120102
   Shop #: WSC 51483 001 1048576
   VCID: 50A8FC1E0312500B13-8004
   Revision: 00002001    Serial number: 0117536056
   Coding: 011B0E82003904C1002000
   Part No SW: 8T0 035 223 AL    HW: 8T0 035 223 H
   Component: DSP Prem      H04 0200
   Revision: 00004001    Serial number: 34880004960803
   VCID: 78F864BECB22284BFB-802C
00420 - Front Right DSP Midrange Speaker (R104)
                    Reset counter: 205
                    Voltage: 12.40 V
                    Temperature: 30.0°C
                    Temperature: 35.0°C
                    Bin. Bits: 00000100
   Part No SW: 8T0 959 792 G    HW: 8T0 959 792 G
   Component: TSG BF        H09 0302
   VCID: 4C90E86EEF3A74EB6F-8018
   Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
   Component: EPB Audi B8   H08 0080
   Revision: 00000003    Serial number: 00000000364862
   VCID: 3362939292C40B130E-8066
   Part No: 8K5 907 357
   Coding: 0000002
   Shop #: WSC 06324 000 00000
   VCID: 77FA6782063C2733F2-8022
   Part No SW: 4F0 035 061 K    HW: 4F0 035 061
   Component: Radio U DAB   H45 0074
   Revision: AB001007    Serial number: 343DW097520875
   Coding: 010103010000000001
   VCID: 244060CE272A9CAB87-8070
   Part No SW: 8T2 035 666 M    HW: 8T2 035 666
   Component: H-BN-EU       H65 0187
   Revision: --------    Serial number: 344DQ097514343
   Coding: 01010102010681EF41000B1E000000010000
   Shop #: WSC 00426 210 85279
   VCID: 4586DD4ACC5085A3B0-8010
   Subsystem 1 - Part No: 8R0 060 884 BK
   Component: EUR 2014  1703
   Component: DU7 High  H43 0306
   Serial number: 9356DV091095392
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Serial number: 00000000279352
   Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J93902K
   Coding: 1022008
   VCID: 377AA78246BCE73332-8062
End-------------------------(Elapsed Time: 03:08)--------------------------
Thursday,29,April,2021,22:50:44:61795
                Address 19: CAN Gateway  (8T0 907 468 P)
22:50:36 Group 018: Power Supply (Battery)
  12.200 V  Battery Voltage
  -9.9 A  Battery Current
  18.0°C  Battery Temp. (Estimate)
  14.0°C  Battery Temp. (Ambience)
22:50:36 Group 019: Power Supply (Battery)
  42.0 %  Battery State of Charge (SOC)
  40.0 %  Battery State (as shown in MMI)
  65.0 %  Battery Aging (derived fr. Load)
  109.0 %  Battery Aging (derived fr. Output)
22:50:36 Group 020: Power Supply (Battery)
  4.2 mOhm  Internal Battery Resistance (actual)
  2.6 mOhm  Internal Battery Resistance (stan.)
  11 Ah  Battery Capacity (actual/available)
  12.10 V  Quiescent Voltage
Thursday,29,April,2021,23:14:30:61795
23:14:22 Group 018: Power Supply (Battery)
  14.100 V  Battery Voltage
  25.6 A  Battery Current
  20.0°C  Battery Temp. (Estimate)
  17.0°C  Battery Temp. (Ambience)
23:14:22 Group 019: Power Supply (Battery)
  45.0 %  Battery State of Charge (SOC)
  90.0 %  Battery State (as shown in MMI)
  110.0 %  Battery Aging (derived fr. Output)
23:14:22 Group 020: Power Supply (Battery)
  3.6 mOhm  Internal Battery Resistance (actual)
  14 Ah  Battery Capacity (actual/available)
  12.20 V  Quiescent Voltage
Thursday,29,April,2021,23:19:25:61795
Long Adaptation Channel 004:
Stored value 8K0915105F  MLA 1905088IZ3
Battery Information/Replacement
  N/A
  N/A
  N/A
  N/A
andythechief
C?ID=65958
And here is the remaining fault in module 19, which I hope will disappear with the correct regulator:
   Coding: 000303
02252 - Generator
                    Reset counter: 246
                    Mileage: 293083 km
                    Date: 2021.04.29
                    Time: 23:44:09
I'm having a hard time with the term "LIN Bus Version". LIN bus hardware is pretty well standardized. Of course the protocol/messages being exchanged might vary, but I doubt that an incompatibility here would produce a "No Signal/Communication - Intermittent" fault. Have you checked what's going on with that LIN bus using an oscilloscope?
andythechief
C?ID=65958
Hi Uwe- yes I have to admit I am slightly clutching at straws with my hypothesis because, and answer to your question, I have not scoped the signal. I don't have a scope tool and to be honest, even if I did I do not know what I would expect to see. At present I can only replace the regulator and see what happens- if it does not improve the issue, I will of course revert to examine basic connectivity issues given there are no other coms errors.
To give some more background, the issue/fault came about in a strange sequence. The alternator can be seen to work for a while as I mentioned before, as judged looking at MBV 018, 019, 020 of CAN gateway 19. The voltage it is outputting ( around 14 or so volts ) then drops to battery voltage of just over 12V and the current flow value then turns negative to the tune of about -10 Amps. At this point when I went back into module 19 there was no error code so I thought ok, perhaps the ECU intentionally told the alternator to stop charging. But then, when I stopped the car, turn ignition off for 20 / 30 seconds, turned it back on but did not start the car, logged into module 19 I had the single remaining error code.
To be honest I got lost with the number of times I tried different combinations of on/off, run/not run.
I am quite pleased to have got the original faults down to just this one. Before I had the alternator rebuilt and replaced the original OEM battery the faults were:
   Coding: 000303
   VCID: 4E94E2661926463F65-801A
02252 - Generator
                    Fault Status: 00101100
                    Reset counter: 228
                    Mileage: 292699 km
                    Date: 2019.10.23
                    Time: 08:25:19
02252 - Generator
                    Fault Status: 00100011
                    Reset counter: 228
                    Mileage: 292699 km
                    Date: 2019.10.23
                    Time: 08:25:19
                    Reset counter: 228
                    Mileage: 292699 km
                    Date: 2019.10.23
                    Time: 08:13:00
I had the alternator rebuilt because there was no charging output as judged with a multimeter. With such high mileage I assumed brushes were worn out or a rectifier problem so simply removed it and said "rebuild please". It is of course possible I have had the alternator built for no useful purposes and there was another issue before all this, and that remains.... but I do not have all the same codes as before, but instead this new one. The only thing different now that before which would affect communication is the regulator.
LIN Bus version
It says here on page 15, and a few other web based sources, that "The LIN 2.2 physical layer is backwards compatible with the LIN1.3 physical layer. But not the other way around. The LIN 2.2 physical layer sets harder requirement, i.e. a node using the LIN 2.2 physical layer can operate in a LIN 1.3 cluster."
This is why I am wondering if for example my car is using one LIN version and the recently purchased regulator used by the alternator repair company was effectively too new. I can determine from the replacement Mobiletron VRB4197 part datasheet that it appears to be LIN 1.3 but this does not help unless I know what the car is using, or at least that was my logic for asking the question.
I have found and read SSP_395 Audi A5 networking but it does not give LIN bus version details. The most useful thing it says on page 27 is below, which admittedly I have not checked in VCDS to see if I can get:
"Diagnostics
As the data bus diagnostic interface J533 is the master control unit for the alternator as a LIN bus user, the
address word "19" must be selected for alternator diagnostics using the VAS tester. The data blocks contain
information on the status of the alternator.
Among other things, the following information is displayed:
– Alternator communication status
– Alternator type, manufacturer and size
– Alternator status, electrical / mechanical / thermal
In the event of sporadic alternator faults, data is available in the following format in set 13 of the history data
on the data bus diagnostic interface J533:
YYYY-MM-DD-hh:mm*I-J-K-L*RRR.R*AAAAA**
This means:
YYYY-MM-DD = date
hh:mm = time
I = 1 means there was an electrical fault in the alternator
= 0 means there was no electrical fault in the alternator
K = 1 means there was a mechanical fault in the alternator
= 0 means there was no mechanical fault in the alternator
L = 1 means there was a thermal fault in the alternator
= 0 means there was no thermal fault in the alternator
M = continuously negative energy balances
This means: the battery becomes discharged, as more electrical current is consumed than is supplied by the alternator
RRRR.R = duration of last trip in hours
AAAAA = number of data entries on sporadic faults
Any thoughts/comments appreciated. By Tuesday I will have installed the new Audi supplied regulator so we will know if there is anything left to do, but it annoys me I cannot get to the bottom of this by means other than part replacement. On the plus side, at least I avoided a completely new alternator, so far £££££
South Molton, UK
The alternator taking current OUT of the battery is never right, especially as much as 10 Amps.
Since you don't have a 'scope maybe it's worth doing a simple continuity check on the LIN connection between the alternator and J533?
Zenerdiode
Newcastle, England
C?ID=24330
That’s not current flow through the alternator, it’s net current at the battery negative terminal; where the BDM is. 10A is a pretty nominal current when ignition on or engine running and battery not charging. Hence the battery voltage dropping to normal cell values.
andythechief
C?ID=65958
Sorry I wasn’t specific- as mentioned by another above I was quoting the negative current value quoted by MBV 018. I didn’t know but I’m glad this at least is typical value.
yes I will revert to testing wires but the circuit diagram of the LIN network may take some unpicking as it seems there are various branches and links to other slave devices.
I’m pinning my non-evidence based hope on the new regulator at the moment.
NEtech
Denmark
C?ID=56995
From Partslink24, a 059 903 019 A Bosch Alternator, use 07K 903 803 Voltage regulator
Please post Controller Channel Maps from the CAN Gateway and Battery history file
[Applications]
[Controller Channel Map]
- Controller Address = 19
- Login or security code: Leave blank
- Function: Measuring values and Adaptation
- Output: CSV file
[Go]
[Applications]
[History Data]
- Choose an Address = 19
[Start]
Files is placed in C:\Ross-Tech\VCDS\Logs
Open the 3 text files and copy and paste it here
golfi_vend
Tartu, Estonia
C?ID=195131
Cheap and incorrect Voltage Regulators almost never work correcty on these cars.
Main issues are incorrect charging and/or fault code indicating no communication to alternator although charging is OK.
andythechief
C?ID=65958
Thanks. I’ll collect the diagnostic info mentioned as soon as wiring is reconnected.
Partlink24 part number on an after market supplier WAI Global website shows a protocol, ID number and COM speed. I assume if any of these are wrong there will be communication problems.
The part number was useful thanks. A Bosch unit is very cheap- £25 from AUTODOC so I’m surprised an even cheaper one was used. Let’s see what Audi supply.
Sounds like I’m going in the right direction.
andythechief
C?ID=65958
Update: Audi, or more specifically TPS, just delivered part# 07K 903 803 which is a Bosch part marked BR14-C-L and F 00M 144 197
So right part number so far. Now let's see what it does...
andythechief
C?ID=65958
[Applications]
- Output: CSV file
[Go]
[Applications]
[History Data]
[Start]
The car is now fixed- the new Audi supplied regulator did the trick so I can only assume it was a communication issue of some description which was causing the error. Of course a long term test will be the final judge.
For completeness should someone else get the same/similar issues, here are the contents of two text files created by following the above instructions. I'm not able to annote or highlight what this all means, perhaps you can comment @NEtech ? The third file output was a CSV spreadsheet file so not pasted here.
1)
;Tuesday,04,May,2021,16:55:15:61795
;                Address 19: CAN Gateway
;Control Module Part Number: 8T0 907 468 P
;  Component and/or Version: GW-BEM 4CAN-M H09 0095
;           Software Coding: 000303
;            Work Shop Code: WSC 06325
;                      VCID: 4E94E266192646FB01-FFFE
;History Data
Record 1/16: No-load voltage underranging
2021-04-30-11:13*15.5*02*00015***
2021-04-29-19:54*00.8*01**
2021-04-26-09:37*13.1*01**
2021-04-25-09:37*05.0*01**
2021-04-24-09:37*05.3*01**
2021-04-23-09:37*05.1*01**
2021-04-21-09:37*03.1*01**
2021-04-30-16:12*01.7*01*00000***
2021-04-29-16:12*24.0*01**
2021-04-28-16:12*24.0*01**
2021-04-27-09:37*15.8*01**
2021-04-26-09:37*24.0*01**
2021-04-25-09:37*18.9*01**
2021-04-24-09:37*18.6*01**
2020-07-09-09:47*02.0*01*00000***
2020-07-08-09:47*24.0*01**
2020-07-07-09:47*24.0*01**
2020-07-06-09:47*24.0*01**
2020-07-05-09:47*24.0*01**
2020-07-04-09:47*24.0*01**
2020-07-03-09:47*24.0*01**
Record 2/16: No-load current overranging
2017-12-24-22:01*0002*039*-02.08*0-1-0-0-0-0*0*01*00006**
2013-01-05-21:04*0004*036*-02.08*0-1-0-0-0-0*0*01**
2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00**
Record 3/16: Shut-off stage history
2021-04-29-21:46*1*0*035*002*-07.06*0-0-0-0-0-0*0*0*00.1*00.2**
2021-04-29-21:22*1*0*036*002*-10.39*0-0-0-0-0-0*0*0*00.1*00.1**
2021-04-29-21:16*2*0*036*002*-04.15*0-0-0-0-0-0*0*0*00.1*00.1**
2021-04-29-21:12*1*0*036*003*-04.65*0-0-0-0-0-0*0*0*00.0*00.0**
2021-04-29-21:01*1*0*037*003*-10.11*0-0-0-0-0-0*0*0*00.0*00.0**
2021-04-29-20:35*1*0*032*001*-10.62*0-0-0-0-0-0*0*0*00.0*00.0**
2021-04-29-20:32*1*0*033*001*-12.42*0-0-0-0-0-0*0*0*00.0*00.0**
2021-04-29-19:57*1*0*033*002*-11.94*0-0-0-0-0-0*0*0*00.0*00.0**
2021-04-29-19:55*1*0*033*003*-09.22*0-0-0-0-0-0*0*0*00.0*00.0**
2021-04-29-18:45*1*0*031*001*-09.79*0-0-0-0-0-0*0*0*00.0*00.0**
2021-04-29-10:40*1*0*034*001*-08.99*0-0-0-0-0-0*0*0*00.0*00.0**
2021-04-27-15:56*1*0*031*001*-11.68*0-0-0-0-0-0*0*0*00.0*00.0**
2021-04-27-12:44*3*0*032*000*-07.36*0-0-0-0-0-0*0*0*00.0*00.0**
2021-04-27-12:44*1*0*032*000*-09.05*0-0-0-0-0-0*0*0*00.0*00.0**
2021-04-26-21:03*1*0*036*003*-11.65*0-0-0-0-0-0*0*0*00.0*00.0**
Record 4/16: Battery change history
2021-04-29-23:16*02*8K0915105F *MLA*1905088IZ3*09999*00009*0000*0000*0000**
2008-05-27-00:00*01*8K0915105F *MLA*1905088IZ4*09518*11997*0000*0000*0000**
2000-01-01-00:00*00*-----------*XXX*----------*10000*00000*0000*0000*0000**
2000-01-01-00:00*00*-----------*XXX*----------*00000*00000*0000*0000*0000**
Record 5/16: Energy-critical vehicle states
2021-02-08-17:20*-00.01*-00.01*-06.39*11.95*000*06*-31.5*11952*09500*
293031*0-0-0-0-0-0*0*00.0*00.0*999.9*01*00*03**
2020-05-14-07:45*-00.02*-00.02*-06.41*11.77*000*06*-46.7*11844*09561*
292984*0-0-0-0-0-0*0*00.0*00.0*999.9*00*00*02**
2019-01-10-23:33*-00.02*-00.02*-06.53*11.79*000*05*-12.8*11286*09620*
286814*0-0-0-0-0-0*0*00.0*00.0*461.3*00*00*01**
2000-01-01-00:00*+00.00*+00.00*+00.00*00.00*000*00*+00.0*00000*00000*
000000*0-0-0-0-0-0*0*00.0*00.0*000.0*00*00*00**
Record 6/16: Energy balances (last 20 trips)
2021-04-30-11:13*037*+09*+000.7*00.07**
2021-04-30-00:20*028*+21*+000.2*00.00**
2021-04-29-23:47*023*+22*+001.6*00.06**
2021-04-29-23:26*012*+22*+002.9*00.33**
2021-04-29-23:18*018*+20*+001.6*00.07**
2021-04-29-23:04*017*+20*+004.7*00.17**
2021-04-29-22:10*015*+18*+007.5*00.48**
2021-04-29-20:38*004*+15*+007.5*00.36**
2021-04-29-20:26*002*+12*+001.6*00.07**
2021-04-29-18:22*001*+11*+004.2*00.37**
2021-04-29-10:31*001*+07*+001.0*00.13**
2021-04-27-15:47*001*+09*+001.1*00.12**
2021-04-27-12:40*000*+06*+000.3*00.04**
2021-04-26-20:58*005*+13*+000.7*00.06**
2021-04-26-20:47*006*+13*+000.6*00.07**
2021-04-16-15:02*001*+05*+000.2*00.02**
2021-04-16-11:18*001*+03*+000.3*00.04**
2021-04-16-10:02*001*+03*+000.3*00.06**
2021-04-05-14:05*001*+08*+000.3*00.03**
2021-03-20-17:51*010*+11*+001.5*00.06**
Record 7/16: Energy balances (last 20 standing times)
2021-04-30-00:21*036*-001.1*010.8*00.0*00.0**
2021-04-29-23:51*028*-002.0*000.4*00.1*00.0**
2021-04-29-23:46*018*-000.3*000.0*00.0*00.0**
2021-04-29-23:23*015*-000.5*000.0*00.0*00.0**
2021-04-29-23:15*014*-000.4*000.0*00.0*00.0**
2021-04-29-22:39*010*-004.2*000.4*00.4*00.3**
2021-04-29-21:00*010*+000.2*001.0*00.2*00.1**
2021-04-29-20:31*001*-001.0*000.1*00.0*00.0**
2021-04-29-19:56*002*-000.8*000.4*00.0*00.0**
2021-04-29-10:39*001*-000.9*007.6*00.0*00.0**
2021-04-27-15:55*001*-001.4*042.5*00.0*00.0**
2021-04-27-12:43*001*-000.7*003.0*00.0*00.0**
2021-04-26-21:02*001*-001.2*015.5*00.0*00.0**
2021-04-26-20:52*004*-000.5*000.0*00.0*00.0**
2021-04-16-15:04*003*+000.1*245.4*00.0*00.0**
2021-04-16-12:20*001*-001.7*002.5*00.0*00.0**
2021-04-16-10:06*001*-000.9*001.1*00.0*00.0**
2021-04-05-14:07*001*-001.3*259.5*00.0*00.0**
2021-03-20-17:55*001*-005.5*379.5*00.0*00.0**
2021-03-20-16:58*009*-001.8*000.8*00.0*00.0**
Record 8/16: Battery manipulation (e.g. charging)
2008-05-27-00:00*4*00*27*00*07*2021-04-30-19:20*02**
2020-07-10-17:04*2*00*27*00*06*2000-01-01-00:00*01**
2020-07-10-17:02*2*00*26*00*06*2000-01-01-00:00*01**
2020-07-10-17:00*2*00*25*00*06*2000-01-01-00:00*01**
2020-07-10-07:15*2*00*24*00*06*2000-01-01-00:00*01**
Record 9/16: Battery aging
2021-04-26-20:47*084*109*037*007*11982*12.00*+12*01**
2021-04-05-14:02*084*107*031*001*11974*12.00*+07*01**
2021-03-20-16:34*084*100*038*002*11965*12.00*+08*01**
2021-02-08-17:20*084*100*033*000*11953*12.00*+01*01**
2020-12-02-09:08*098*098*066*030*11914*12.40*+05*01**
2020-11-08-15:26*098*079*073*038*11901*12.50*+12*01**
2020-09-06-15:57*098*079*080*048*11889*12.60*+15*01**
2020-08-18-18:16*098*079*075*047*11888*12.50*+19*01**
2020-07-08-13:11*059*105*000*000*11881*11.50*+15*01**
2020-05-14-07:45*059*105*030*000*11844*11.90*+06*01**
2020-02-19-15:53*059*101*062*026*11794*12.30*+06*01**
2020-01-13-09:35*060*094*066*029*11771*12.40*+06*01**
Record 10/16: Dynamic energy management
2021-04-29-23:46*1*001.0*1*002.0*000.3**
2008-05-27-00:31*1*001.0*1*005.2*000.1**
2008-05-27-00:04*1*000.9*0*000.0*000.0**
2019-10-24-22:28*1*001.0*1*000.9*000.0**
2019-10-24-22:05*1*001.0*1*009.3*000.1**
2000-01-01-00:00*0*0*0*000.0**
2021-04-29-23:46*2*003.0*000.3**
2008-05-27-00:31*2*006.2*000.1**
2008-05-27-00:04*2*000.9*000.0**
2019-10-24-22:28*2*001.9*000.0**
2019-10-24-22:05*2*010.3*000.1**
Record 11/16: Recuperation
2000-01-01-00:00*000*000*000*000*0000*000*00.0*+00.0*000*000*000*000*00*00000*00000*00000**
2000-01-01-00:00*000*000*000*000*0000*000*00.0*+00.0*000*000*000*000*00**
Record 12/16: Start-Stop
Record 13/16: Sporadic alternator faults
2008-05-27-00:24*1-1-0-0-0*000.0*00015**
2008-05-27-00:03*1-1-0-0-0*000.0**
2019-10-24-22:26*1-1-0-0-0*000.0**
2019-10-24-21:55*1-1-0-0-0*000.0**
2019-10-23-08:26*1-1-0-1-0*000.0**
Record 15/16: Local activ.
2000-01-01-00:00*000*00*00*000*00*00*000*00*00**
Record 16/16: Vehicle energy balance
293082**
00390*04379*06170*00140*00038**
11026*00102*00051*00015**
15354*11408*00242*00000**
01745*02410*02161*04332**
05409*02834*02405**
00000*00000*00000*00000**
16217*00853*00131*00014**
03428*00065*00011**
00046*00008*00014**
00013*00002*00000**
2)
Tuesday,04,May,2021,16:56:56:61795
History Data
293082**
05409*02834*02405**
03428*00065*00011**
00046*00008*00014**
00013*00002*00000**
As always- VCDS never fails to add value. Many, many thanks one and all. :thumbs:
NEtech
Denmark
C?ID=56995
Just open CSV files as text (Notepad), copy and paste.
Here is History data for Alternator:
