- Apr 27, 2014
- 28
- 6
- Canada / Netherlands
- C?ID=142005
Hello Guys! I have installed a GTD cluster in my 2015 TDI (got it for 20$)
Everything went well, reprogrammed the keys, immo, mileage, etc.
Now I have a problem with TPMS. It's not detected.
Also, here's a scan of my car. There is few errors (maybe you can help), but TPMS is the main one since there is a light on the cluster.
Thank you
Thank you
Friday,30,April,2021,20:54:51:17391
VCDS Version: 20.12.0.1 (x64)
Data version: 20201125 DS322.1
VIN: 3VWCA7AU1FM509487 License Plate:
Mileage: 95332km-59236mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F
VIN: 3VWCA7AU1FM509487 Mileage: 95332km-59236miles
Address 01: Engine (J623-CRUA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 997 022 N HW: 04L 907 309
Component: R4 2.0l TDI X23 9459
Revision: 85X23---
Coding: 011D0012832410080000
ASAM Dataset: EV_ECM20TDI01104L997022N 004002
ROD: EV_ECM20TDI01104L997022N_VW37.rod
VCID: 3B7F12C1B2264F5C17-806E
Readiness: 0 0 0 1 1
Part No SW: 0D9 300 041 N HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4512
Revision: 05853104 Serial number: TFK01502080283
Shop #: WSC 00066 790 00218
ROD: EV_TCMDQ250021.rod
VCID: 234FCAA12A96179C3F-8076
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 50625000001719
Coding: 04FA6AA124200975007B020881CA2520562490004081A4B200630050C002
Shop #: WSC 00046 000 00000
VCID: 47977E31FEEE1BBC83-8012
Part No SW: 5GM 907 426 A HW: 5GM 907 426 A
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 02020104102100000000000000000000
Shop #: WSC 01383 790 50316
ROD: EV_ACManueBHBVW37X_003.rod
VCID: 46897335F9E402B478-8012
Part No SW: 5Q0 937 087 R HW: 5Q0 937 087 R
Component: BCM PQ37BOSCH 028 0145
Revision: -------- Serial number: 86582502151351
Coding: 000018464041804949E44000091407001000000000000000000000000000
Shop #: WSC 12345 123 61029
ROD: EV_BCMBOSCH_014.rod
VCID: 4A914705EDFCE6D49C-801E
Wiper motor control module:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150118 043 0581
Serial number: 150402053908
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM020MCE
VCID: 51A3506900AAD50CDD-8004
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J150002LP540%
Coding: 303132
Subsystem 2 - Part No SW: ----------- HW: 480 001 202 15
Serial number: 35700000000556692319
Subsystem 3 - Part No SW: ----------- HW: 480 001 102 15
Serial number: 35800000000DDC6DF215
Subsystem 4 - Part No SW: ----------- HW: 480 400 602 15
Serial number: 351000299196FF54E20E
Subsystem 5 - Part No SW: ----------- HW: 480 400 602 15
Serial number: 3520002BF1901D939333
Subsystem 6 - Part No SW: ----------- HW: 480 400 302 15
Serial number: 3550002AB196FF5502CK
Subsystem 7 - Part No SW: ----------- HW: 480 400 302 15
Serial number: 3560002B3192BC7280A6
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150221400974
Coding: 0410
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB.rod
VCID: 3F8766D1A63E537C3B-806A
Part No SW: 5G1 920 757 A HW: 5G1 920 757 A
Component: KOMBI 302 6420
Coding: 07AD11882190000802086A041400000000000000
Shop #: WSC 00046 123 12345
VCID: 2C5D219D4748D8E48E-8078
1048578 - No Basic Setting
B2010 00 [009] - -
Reset counter: 237
Mileage: 95332 km
Date: 2021.04.30
Time: 20:50:32
16776989 - Databus
Reset counter: 237
Mileage: 95332 km
Date: 2021.04.30
Time: 20:50:32
16776980 - Databus
Reset counter: 237
Mileage: 95332 km
Date: 2021.04.30
Time: 20:50:32
Part No SW: 5Q0 907 530 AB HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2203
Revision: -------- Serial number: 06031510000397
Coding: 0901000800087300EF0000081C0F00000001050000000000000000000000
Shop #: WSC 00066 790 00199
ROD: EV_GatewConti_011.rod
VCID: 71E3F0E9A0EAF50CFD-8024
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0038
Serial number: 29150001366350085267
Coding: 29FFFF
Inverter for electrical outlet:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0042963
Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
Component: TSG FS 020 0025
Serial number: 23031506050BJW
Coding: 003003200000040000000000
VCID: 3E791BD5A1345A7430-806A
Serial number: 00000000000000941524
Coding: 011000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0102
VCID: 438F6A21CAD6379C5F-8016
Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B
Component: TSG BFS 020 0025
Serial number: 110315060508QB
Coding: 003003200C00040000000000
VCID: 3D7B1CD9AC32416C29-8068
Serial number: 00000000000000921321
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 014 0655
Serial number: V7B00503150023
Coding: 02730200FF00000021220001001800001F0106140100010002
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 64CD89BD6F1850A486-8030
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H60 0030
Serial number: VWZ8Z9RS501E33
0020 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Reset counter: 237
Mileage: 95332 km
Date: 2021.04.30
Time: 20:50:33
Voltage terminal 30: 12.1 V
Satellite radio tuner status-Satellite radio antenna status: electrically OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Not available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: Not available
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
1024 - Interface for External Media Devices (MEDIA-IN)
B1288 13 [009] - Open Circuit
Reset counter: 237
Mileage: 95332 km
Date: 2021.04.30
Time: 20:50:33
End-------------------------(Elapsed Time: 03:22)--------------------------
