Golf 7 / MK7 Cluster/Speedometer Swap
krustyx
Canada / Netherlands
C?ID=142005
Hello Guys! I have installed a GTD cluster in my 2015 TDI (got it for 20$)
Everything went well, reprogrammed the keys, immo, mileage, etc.
Now I have a problem with TPMS. It's not detected.
Also, here's a scan of my car. There is few errors (maybe you can help), but TPMS is the main one since there is a light on the cluster.
Thank you :)
Friday,30,April,2021,20:54:51:17391
VCDS Version: 20.12.0.1 (x64)
VIN: 3VWCA7AU1FM509487   License Plate:
Mileage: 95332km-59236mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F
VIN: 3VWCA7AU1FM509487   Mileage: 95332km-59236miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 022 N    HW: 04L 907 309
   Component: R4 2.0l TDI   X23 9459
   Revision: 85X23---
   Coding: 011D0012832410080000
   ASAM Dataset: EV_ECM20TDI01104L997022N 004002
   ROD: EV_ECM20TDI01104L997022N_VW37.rod
   VCID: 3B7F12C1B2264F5C17-806E
Readiness: 0 0 0 1 1
   Part No SW: 0D9 300 041 N    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4512
   Revision: 05853104    Serial number: TFK01502080283
   Shop #: WSC 00066 790 00218
   ROD: EV_TCMDQ250021.rod
   VCID: 234FCAA12A96179C3F-8076
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Revision: 00000000    Serial number: 50625000001719
   Coding: 04FA6AA124200975007B020881CA2520562490004081A4B200630050C002
   Shop #: WSC 00046 000 00000
   VCID: 47977E31FEEE1BBC83-8012
   Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 02020104102100000000000000000000
   Shop #: WSC 01383 790 50316
   VCID: 46897335F9E402B478-8012
   Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
   Revision: --------    Serial number: 86582502151351
   Coding: 000018464041804949E44000091407001000000000000000000000000000
   Shop #: WSC 12345 123 61029
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4A914705EDFCE6D49C-801E
   Component: WWS    150118  043 0581
   Serial number:         150402053908
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM020MCE
   VCID: 51A3506900AAD50CDD-8004
   Serial number: IBH0000J150002LP540%
   Coding: 303132
   Subsystem 2 - Part No SW: -----------    HW: 480 001 202 15
   Serial number: 35700000000556692319
   Subsystem 3 - Part No SW: -----------    HW: 480 001 102 15
   Serial number: 35800000000DDC6DF215
   Subsystem 4 - Part No SW: -----------    HW: 480 400 602 15
   Serial number: 351000299196FF54E20E
   Subsystem 5 - Part No SW: -----------    HW: 480 400 602 15
   Serial number: 3520002BF1901D939333
   Subsystem 6 - Part No SW: -----------    HW: 480 400 302 15
   Serial number: 3550002AB196FF5502CK
   Subsystem 7 - Part No SW: -----------    HW: 480 400 302 15
   Serial number: 3560002B3192BC7280A6
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150221400974
   Coding: 0410
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3F8766D1A63E537C3B-806A
   Part No SW: 5G1 920 757 A    HW: 5G1 920 757 A
   Component: KOMBI         302 6420
   Coding: 07AD11882190000802086A041400000000000000
   Shop #: WSC 00046 123 12345
   VCID: 2C5D219D4748D8E48E-8078
1048578 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 237
                    Mileage: 95332 km
                    Date: 2021.04.30
                    Time: 20:50:32
16776989 - Databus
                    Reset counter: 237
                    Mileage: 95332 km
                    Date: 2021.04.30
                    Time: 20:50:32
16776980 - Databus
                    Reset counter: 237
                    Mileage: 95332 km
                    Date: 2021.04.30
                    Time: 20:50:32
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 06031510000397
   Coding: 0901000800087300EF0000081C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 00199
   ROD: EV_GatewConti_011.rod
   VCID: 71E3F0E9A0EAF50CFD-8024
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0038
   Serial number: 29150001366350085267
   Coding: 29FFFF
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0042963
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 23031506050BJW
   Coding: 003003200000040000000000
   VCID: 3E791BD5A1345A7430-806A
   Serial number: 00000000000000941524
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 438F6A21CAD6379C5F-8016
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 110315060508QB
   Coding: 003003200C00040000000000
   VCID: 3D7B1CD9AC32416C29-8068
   Serial number: 00000000000000921321
   Coding: 091000
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     014 0655
   Serial number: V7B00503150023
   Coding: 02730200FF00000021220001001800001F0106140100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 64CD89BD6F1850A486-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9RS501E33
          B11CF 53 [009] - Deactivated
                    Reset counter: 237
                    Mileage: 95332 km
                    Date: 2021.04.30
                    Time: 20:50:33
                    Voltage terminal 30: 12.1 V
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
1024 - Interface for External Media Devices (MEDIA-IN)
          B1288 13 [009] - Open Circuit
                    Reset counter: 237
                    Mileage: 95332 km
                    Date: 2021.04.30
                    Time: 20:50:33
End-------------------------(Elapsed Time: 03:22)--------------------------
Mari
C?ID=150535
Partnumber of both clusters? What was the coding of the old cluster?
krustyx
C?ID=142005
Im not home right now, I will let you know tomorrow.
As for the coding, Im afraid the guy who did the immo didnt save it, or maybe. Ill ask.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
You can always plug back old cluster and see coding, Or if you have auto scan before you install new cluster post it here .
krustyx
C?ID=142005
Will plugin my old cluster create problems? How do I find out the coding?
@krustyx: Hi. Shirley you have made previous auto-scans of the car, or perhaps you might have made changes to the hex17 module long-code string in the past? If so, look in the Ross-Tech directories (VCDS/Debug and VCDS/Scans) on the laptop that you use for VCDS for historic records.
In any event, I suspect that the donor car for your new hex17 module had direct TPMS (i.e. the kind with pressure sensors installed on each wheel) - and your car does not have this version of TPMS (because no hex65 module in your auto-scan)
I note that the long-code string on your new hex17 module has Byte 3=hex88, which means that Bit 7 is set. According to my database, this software switch has the descriptor "Tire Pressure Monitoring, yes".
However, whilst it might appear appropriate to have this Bit set for TMPS on your car, I note that on other cars with indirect TPMS in my database, this Bit is NOT set - which kind-of suggests (to me) that this Bit might refer to direct TPMS.
The same applies to Byte 11=hex04 on your auto-scan. Again this means that Bit 2 is also set on your new hex17 module, but this switch is NOT set on other cars with indirect TPMS on my database
So - because it's an easy try - I suggest that on the hex17 module:
  1. set BYTE 3, BIT 7 to zero (after the change, Byte 3 should read hex08)
  2. set BYTE 11, BIT 2 to zero (after the change, Byte 11 should read hex00)
  3. clear the DTCs - does the TPMS error re-appear?
krustyx
C?ID=142005
I found one Don! Great idea :)
Here it is
And thanks for your help! :D
VCDS Version: 19.6.2.2 (x64)
VIN: 3VWCA7AU1FM509487   Mileage: 90465km-56212miles
   Revision: 85X23---
   ROD: EV_ECM20TDI01104L997022N.rod
   VCID: 3B7F12C1B2264F97B0-806E
9127 - Actuator Module for Turbocharger 1
          P00AF 00 [101] - Stuck
                    Mileage: 90465 km
                    Date: 2020.03.18
                    Time: 13:46:13
                    Engine speed: 1047.50 /min
                    Vehicle speed: 25 km/h
                    Coolant temperature: 57 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 13.960 V
                    Turbine actuator 1 bank 1: posit.feedback - Spec.value: 100.00 %
                    Turbine actuator 1 bank 1: posit.feedback - Act.value: 25.77 %
                    Turbine actuator 1 bank 1: posit.feedback - Offset closed: -0.66 %
                    Turbine actuator 1 bank 1: monitoring - status-Bits 0-7: 0
                    Turbine actuator 1 bank 1: monitoring - status-Bits 0-7: 55
                    Turbine actuator 1 bank 1: posit.feedback - Uncnd vlt: 3371.8 mV
                    Accelerator pedal travel: raw value: 0.00 %
   VCID: 234FCAA12A96175798-8076
          P1734 00 [002] - -
   VCID: 47977E31FEEE1B7724-8012
   Revision: 00001K01
   VCID: 46897335F9E4027FDF-8012
   Shop #: WSC 00066 790 00215
   VCID: 4A914705EDFCE61F3B-801E
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 101
                    Mileage: 90465 km
                    Date: 2020.03.18
                    Time: 13:48:33
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 51A3506900AAD5C77A-8004
   Occupant Detection:
   Coding: 303132
   Front Sensor Passenger:
   Coding: 0410
   VCID: 3F8766D1A63E53B79C-806A
   Part No SW: 5G1 920 741     HW: 5G1 920 741
   Component: KOMBI         243 4270
   Coding: 0BB5120A2180880902087A001000000000000000
   VCID: 64CD89BD6F18506F21-8030
          B2010 00 [009] - -
                    Reset counter: 101
                    Mileage: 90465 km
                    Date: 2020.03.18
                    Time: 13:45:02
16777022 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
                    Reset counter: 141
                    Mileage: 90465 km
                    Date: 2020.03.18
                    Time: 13:45:06
   VCID: 71E3F0E9A0EAF5C75A-8024
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29150000483350045112
   Coding: 30FFFF
   Power Converter DC AC:
131699 - Control unit for information electronics 1
          U1054 00 [009] - No Communication
                    Reset counter: 101
                    Mileage: 90465 km
                    Date: 2020.03.18
                    Time: 13:45:08
                    Supply voltage: Terminal 30: 12.2 V
                    Terminal 15: On
   VCID: 3E791BD5A1345ABF97-806A
   Coding: 011000
   Coding: 0102
   VCID: 438F6A21CAD63757F8-8016
   VCID: 3D7B1CD9AC3241A78E-8068
   Coding: 091000
End-------------------------(Elapsed Time: 03:21)--------------------------
krustyx
C?ID=142005
I did what you suggested with byte 3 and 11 and problem is still there
krustyx
C?ID=142005
updated scan
Sunday,02,May,2021,20:10:38:17391
VIN: 3VWCA7AU1FM509487   License Plate: NEW2
Mileage: 95831km-59546mi   Repair Order:
VIN: 3VWCA7AU1FM509487   Mileage: 95831km-59546miles
   Revision: 85X23---
          P1734 00 [002] - -
16385 - TPMS Display
          C1146 F2 [009] - EEPROM Malfunction
                    Reset counter: 240
                    Mileage: 95831 km
                    Date: 2021.05.02
                    Time: 20:00:57
   Revision: 00001K01
   Coding: 303132
   Coding: 0410
   Coding: 07AD11082190000802086A001400000000000000
          B2010 00 [009] - -
                    Reset counter: 240
                    Mileage: 95831 km
                    Date: 2021.05.02
                    Time: 20:00:46
16776980 - Databus
                    Reset counter: 240
                    Mileage: 95831 km
                    Date: 2021.05.02
                    Time: 20:00:46
   Generator:
   Coding: 29FFFF
   Coding: 011000
   Coding: 0102
   Coding: 091000
                    Reset counter: 240
                    Mileage: 95831 km
                    Date: 2021.05.02
                    Time: 20:00:48
                    Voltage terminal 30: 12.0 V
                    Reset counter: 240
                    Mileage: 95831 km
                    Date: 2021.05.02
                    Time: 20:00:46
downtime
Finland
C?ID=280813
For the TPMS problem go to abs module, basic settings and from there choose the reset for tpms. It was something clear all tpms or reset tpms or something like that.
Exit module and close vcds. Ignition off and the error should go away on next start
krustyx
C?ID=142005
This is not the same thing as reseting thru the entertainment system?
Right now the problem is that cluster is not detecting the TPMS at all
@krustyx: I agree with @downtime suggestion :thumbs:
Here's how the 2 x long-code strings for the hex17 modules compare:
Hex17 ->oldoldnewnew
ByteHexBinaryHexBinary
0007000001110B00001011
01AD10101101B510110101
0211000100011200010010
0308000010000A00001010
0421001000012100100001
0590100100008010000000
0600000000008810001000
0708000010000900001001
0802000000100200000010
0908000010000800001000
106A011010107A01111010
1100000000000000000000
1214000101001000010000
1300000000000000000000
1400000000000000000000
1500000000000000000000
1600000000000000000000
1700000000000000000000
1800000000000000000000
1900000000000000000000
Your old long-code contains my previously suggested changes (which are now embedded in your new module) - but as you can see, there are lots of other variations.
Given the magnitude of the differences between the software switch settings on both modules - if this was my car, I would apply the old long-code string (in full) on the new module as a starting point and work from there (rather than the other way around)!
downtime
Finland
C?ID=280813
No it isn't. This is a problem with ABS module and what I'm asking you to do has nothing to do with resetting the TPMS. This is a master reset that clear everything and initialises the whole TPMS system.
I've had this error many times after gateway swap and cluster swap. This might be triggered after gateway dataset flash as well.
This exact error :
                    Reset counter: 240
                    Mileage: 95831 km
                    Date: 2021.05.02
                    Time: 20:00:57
I can't remember the exact basic setting in ABS module. I think there was two TPMS settings and the other is the same reset as you can do through infotainment and the other is the master init.
Some have had this error fixed after disconnecting battery for 10 minutes but didn't work for me at least. This ABS basic setting was the only way to make it go away.
Jetta 97
C?ID=81680
You can also look in your Glove box , some cars has Button for TPMS , if you have it just press and hold it for Few seconds.
downtime
Finland
C?ID=280813
The EEPROM error is not due to TPMS reset. It's different.
  • Agree
krustyx
C?ID=142005
So I tried all mentionned above, on the ABS module, and also changing hex17 to old long-code, not working.
On the ABS module, i have a ERROR : REQUEST OUT OF RANGE error
:cry:
downtime
Finland
C?ID=280813
You did the basic setting part?
can you post picture for example what are the basic settings you have selectable in ABS module?
Very important that you exit the abs module and cycle ignition after doing the basic setting
krustyx
C?ID=142005
I did! On hex17, I just activated the lap time, rest is all the same.
As for ABS, I did it. Will try to do it tonight, I'm already gone to work :(
   Revision: 85X23---
          P1734 00 [002] - -
                    Reset counter: 237
                    Mileage: 95332 km
                    Date: 2021.04.30
                    Time: 20:57:01
   Revision: 00001K01
17674 - Bulb for Front Left Side Marker Lamp
          B12BA 15 [009] - Open or Short to Plus
                    Reset counter: 238
                    Mileage: 95497 km
                    Date: 2021.05.01
                    Time: 11:52:24
17930 - Bulb for Front Right Side Marker Lamp
          B12BB 15 [009] - Open or Short to Plus
                    Reset counter: 238
                    Mileage: 95497 km
                    Date: 2021.05.01
                    Time: 11:52:24
                    Reset counter: 24
                    Mileage: 95332 km
                    Date: 2021.04.30
                    Time: 20:58:33
   Coding: 303132
   Coding: 0410
          B2010 00 [009] - -
                    Reset counter: 237
                    Mileage: 95332 km
                    Date: 2021.04.30
                    Time: 20:50:32
16776980 - Databus
                    Reset counter: 237
                    Mileage: 95332 km
                    Date: 2021.04.30
                    Time: 20:50:32
   Generator:
   Coding: 29FFFF
   Coding: 011000
   Coding: 0102
   Coding: 091000
                    Reset counter: 237
                    Mileage: 95332 km
                    Date: 2021.04.30
                    Time: 20:50:33
                    Reset counter: 237
                    Mileage: 95332 km
                    Date: 2021.04.30
                    Time: 20:50:33
End-------------------------(Elapsed Time: 03:24)--------------------------
Lots of good suggestions here and I believe Downtime is correct in regards to the ABS EEPROM Malfunction DTC. The OP has 2 BS to choose from in this ABS module:
[*IDE05060-ENG114972*] Reset to factory setting of tire pressure monitoring display
[*IDE05334-ENG114972*] Reset tire pressure monitoring display warnings
The 1st one looks like the best option followed by the second but you might want to wait for feedback. If you try either of those make sure to do so Key On, Engine Off because traditional MIB/TPMS button resets often fail if you have the engine running. Additionally, if either show an error for Security Access required you may want to have a look at Don's thread: https://forums.ross-tech.com/index.php?threads/19270/
