Caddy VAN lost ABS Coding (MK60EC1)
MNZ
New Zealand
C?ID=155812
Hey guys,
Scan attached, but story: Van was originally a 1.2TSI, we have swapped in BWS R36 engine and are working through some codings and engine faults, however the customer fitted Mk6 Golf R clocks to test them and the coding has vanished from the ABS unit. Can anyone help with what the coding should be?
Regards,
Barry
Thursday,29,April,2021,16:33:00:18608
VCDS Version: 19.6.1.0 (x64)
VIN: WV1ZZZ2KZCX148239   License Plate: GZY237
Mileage: 119070km-73986mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
VIN: WV1ZZZ2KZCX148239   Mileage: 119070km-73986miles
Address 01: Engine (BWS)       Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 906 032 AM    HW: 03H 906 032 AB
   Component: R3.6-FSI-EU4    G   2150
   Revision: 5GH04---    Serial number: VWZCZ000000000
   Coding: 0000175
   Shop #: WSC 05311 000 08193
   VCID: 6DDBF18E74D94E2742-8038
               P1653 - 004 -
                    Mileage: 119075 km
                    Date: 2015.09.20
                    Time: 00:27:15
                    Temperature: 63.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 13.843 V
049682 - Steering Column Control Module
               U0212 - 008 - No Communications
                    Fault Status: 01101000
                    Mileage: 119075 km
                    Date: 2015.09.20
                    Time: 00:27:16
                    Temperature: 63.0°C
                    Temperature: 39.0°C
                    Voltage: 13.970 V
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
               P0036 - 004 - Malfunction / Open Circuit
                    Mileage: 119075 km
                    Date: 2015.09.20
                    Time: 00:29:09
                    RPM: 1693 /min
                    Load: 26.7 %
                    Temperature: 63.0°C
                    Temperature: 39.0°C
                    Voltage: 11.811 V
000086 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
               P0056 - 004 - Malfunction / Open Circuit
                    Mileage: 119075 km
                    Date: 2015.09.20
                    Time: 00:29:09
                    RPM: 1693 /min
                    Load: 26.7 %
                    Temperature: 63.0°C
                    Temperature: 39.0°C
                    Voltage: 11.811 V
Readiness: 0000 0100
   Part No SW: 1K0 907 379 BH    HW: 1K0 907 379 BH
   Revision: 00H31001
   Shop #: WSC 35110 377 08192
   VCID: 79F3D5DEF091E287DE-802C
                    Reset counter: 197
                    Date: 2015.09.20
                    Time: 00:28:40
                    Count: 3
                    Count: 20992
                    Count: 195
                    Count: 42496
                    Fault Status: 01100101
                    Reset counter: 197
                    Mileage: 119075 km
                    Date: 2015.09.20
                    Time: 00:28:19
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 279
                    Count: 42496
                    Reset counter: 197
                    Mileage: 119075 km
                    Date: 2015.09.20
                    Time: 00:28:19
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 295
                    Count: 42496
                    Reset counter: 197
                    Mileage: 119075 km
                    Date: 2015.09.20
                    Time: 00:28:19
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 270
                    Count: 42496
   Part No SW: 7N0 907 426 AM    HW: 7N0 907 426 AM
   Component: AC Manuell    H19 0404
   Revision: 00001018
   Coding: 0000004002
   Shop #: WSC 35110 790 50316
   VCID: 7F073BC6E6B5CCB7E0-802A
   Part No SW: 5K0 937 085 R    HW: 5K0 937 085 R
   Component: BCM PQ35 B+   021 0064
   Revision: BB021001
   Coding: 411A0A3A8025186A088000829000006403017288524F8960648000000040
   VCID: 42817232DDC7615FCF-8016
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 11041  26  0512
   Coding: 009795
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 197
                    Mileage: 119075 km
                    Date: 2015.09.20
                    Time: 00:27:44
                    Voltage: 11.75 V
   Component: VW10Airbag02F H07 0013
   Revision: --------    Serial number: 003HL00BD71U
   Coding: 000000000000000000000000000000003246
   VCID: 356B19EE9409C6E77A-8060
   Part No SW: 5K0 953 507 AR    HW: 5K0 953 549 C
   Revision: --------    Serial number:  90422LDD000RV
   Coding: 1080060000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 0005B83A9B4BB34F99-8054
   Part No SW: 2K0 920 865 D    HW: 2K0 920 865 D
   Component: KOMBI         H03 0606
   Coding: 180201
   VCID: 2F672B867655FC3730-807A
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 140412F1001176
   Coding: 357401
   VCID: 3A710AD2B517299F97-806E
                    Reset counter: 237
   Component: IMMO          H03 0606
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD1FA928D37591F27-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0000560
   VCID: 4895601A3BFB4B0F11-801C
00913 - Window Regulator Switch; Front Right Driver (E81)
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 140    3305
   Revision: 00H22000
   VCID: 377713E6460534F768-8062
                    Fault Status: 11100101
                    Mileage: 119075 km
                    Date: 2015.09.20
                    Time: 00:27:57
                    Battery Volts: 12.0 V
                        DD
                    Temperature: 23.0°C
                    Count: 3
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000560
   VCID: 4797632636E5447718-8012
   Part No SW: 6RD 035 187 A    HW: 6RD 035 187 A
   Component: MIB2-S-R-CN   025 0210
   Revision: -----001    Serial number: 04145GD0065960
   Coding: 0000044004000A
   Shop #: WSC 00081 790 00127
   VCID: 458B692ECCE95667EA-8010
00856 - Radio Antenna
                    Fault Status: 00100111
                    Fault Frequency: 26
                    Reset counter: 116
                    Mileage: 94757 km
                    Date: 2013.12.01
                    Time: 16:52:40
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 204
                    Mileage: 88380 km
                    Date: 2013.06.01
                    Time: 09:44:49
                    Reset counter: 204
                    Mileage: 88380 km
                    Date: 2013.06.01
                    Time: 09:44:49
                    Reset counter: 202
                    Mileage: 88377 km
                    Date: 2013.05.31
                    Time: 14:08:03
                    Reset counter: 202
                    Mileage: 88377 km
                    Date: 2013.05.31
                    Time: 14:08:03
End-------------------------(Elapsed Time: 02:01)--------------------------
That's going to be something of a challenge with an engine swap...
Let's start with the basics: Do the VINs stored in the ECU and the Immo/Cluster match, and do they match the physical VIN of the vehicle?
MNZ
New Zealand
C?ID=155812
Hi Uwe,
The vehicle has been running for two months as it was, with the original Caddy cluster and key. The ECU has had the Immo removed from it and the ABS coding was still the original 1.2TSI coding. Everything was ok.
But after swapping in the Golf R cluster to test it, the coding has gone. This cluster wasn't coded to the car, he just wanted to test some functions.
It is now back with the original Caddy cluster but coding missing in ABS now.
Barry
totaltuning
C?ID=255206
You can try
totaltuning
C?ID=255206
You can try, Online Calculator has been good for me in the past, and they are quite helpful if it at first doesn't work.
racofuy
New Zealand
C?ID=197081
Hi Barry, Going through this now with a AWD 20TSI swap in a Beetle.
The Caddy vin must appear in the ECU and in the cluster otherwise as I've understood it the ABS is not able to be coded.
I'm still trying to find someone that can put the Beetle vin in the Golf ECU without sending it abroad.
@MNZ I attempted to put my blinders on and build this coding as if the factory installed engine, trans, brakes, etc. were installed with the VIN digits of WV1ZZZ2KZCX148239 however we don't have a single scan from a CBZB engine installed in a 2K / 3CA chassis vehicle. I resorted to a few Google searches as well but the scan results were not from Caddy models.
I certainly can't fault the owner for putting a proper engine in this van however I don't believe we can assist. If you happen to have (or find) any scans from one of these 77 kW TSI CBZB equipped vans with the VIN and ABS coding string present please drop a link here so one of us can try to dig into it.
NEtech
Denmark
C?ID=56995
This is maybe as factory:
433C400D09260302C20D02E79022C080300000
MNZ
New Zealand
C?ID=155812
So, just to help anyone that reads this, I found the original coding in my debug list. Seems I must have tried some coding changes on it.
The correct coding was:
623C200D09260302460D04E79022C081300000
However..... I am trying to re-code to remove the fault, the vehicle has an R36 engine swap but with a manual transmission. However the vehicle was manual prior to the swap, so I can only imagine this fault is being generated by the engine control unit as it is missing the DSG control unit.
Yet the engine control unit doesn't have a fault for no communication with DSG?? We are worried there is hard coding in the ECU that won't allow manual, we have tried changing to manual with VCDS coding but it is rejected.
New autoscan:
Sunday,23,May,2021,08:30:07:62654
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
VIN: WV1ZZZ2KZCX148239   Mileage: 119200km-74067miles
   Coding: 0000175
   VCID: ED926C2BF465C0E398-80B8
               P1653 - 004 -
                    Mileage: 119200 km
                    Date: 2015.10.14
                    Time: 08:26:38
                    Temperature: 6.0°C
                    Temperature: 12.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.589 V
                    Mileage: 119200 km
                    Date: 2015.10.14
                    Time: 08:26:39
                    Temperature: 6.0°C
                    Temperature: 12.0°C
                    Voltage: 14.732 V
   Revision: 00H31001
   Coding: 623C200D09260302460D04E79022C081300000
   VCID: F9BA487B702D6C4304-80AC
                    Reset counter: 203
                    Mileage: 119200 km
                    Date: 2015.10.14
                    Time: 08:27:03
                    Count: 2
                    Count: 14
                    Count: 12800
                    Count: 8195
                    Count: 44288
                    Count: 1
   Revision: 00001018
   Coding: 0000004002
   VCID: FF4EA663660942733A-80AA
   Revision: BB021001
   VCID: C2C8EF975D7BEF9B15-8096
   Coding: 009795
                    Reset counter: 203
                    Mileage: 119200 km
                    Date: 2015.10.14
                    Time: 08:27:59
                    Voltage: 12.35 V
   VCID: B522844B14B54823A0-80E0
   Coding: 1080060000
   VCID: 804C259F1BF73D8B43-80D4
   Coding: 180201
   VCID: AF2EB623F6E972F3EA-80FA
   Coding: 357401
   VCID: BA38977735ABA75B4D-80EE
   VCID: EA9867370D8BD7DBFD-80BE
   Coding: 0000560
   VCID: C8DCFDBFBB47C5CBCB-809C
   Revision: 00H22000
   VCID: B73E8E43C6B9BA33B2-80E2
   Coding: 0000560
   VCID: C7DEFE83B659CAB3C2-8092
   VCID: C5C2F48B4C55D8A330-8090
                    Fault Frequency: 26
                    Reset counter: 116
                    Mileage: 94757 km
                    Date: 2013.12.01
                    Time: 16:52:40
                    Reset counter: 204
                    Mileage: 88380 km
                    Date: 2013.06.01
                    Time: 09:44:49
                    Reset counter: 204
                    Mileage: 88380 km
                    Date: 2013.06.01
                    Time: 09:44:49
                    Reset counter: 202
                    Mileage: 88377 km
                    Date: 2013.05.31
                    Time: 14:08:03
                    Reset counter: 202
                    Mileage: 88377 km
                    Date: 2013.05.31
                    Time: 14:08:03
End----------(Elapsed Time: 00:54, VBatt start/end: 12.4V/12.4V)-----------
NZDubNurd
New Zealand
C?ID=230482
Correct.
I'm in Whangarei, and have an R32 drive train in my Touran. It's manual, but I ran it with the DSG Engine ECU during testing. Once the engine ECU was replaced with a manual version, that ABS fault disappeared.
I brought a new R32 manual ECU... I don't think the R36 engine ever came with a manual trans though :(
I didn't get too deep into it... but just deleting the fault code from the engine ECU did not stop the fault. It either needs some deeper changes so it doesn't even look for the trans, or the ABS itself may need modifying... but I'd be loathe to do that, in case it doesn't function as intended, when required!
It *may* be as simple as the ECU coding reflecting a manual trans... but the auto ECU won't accept it during normal coding (as you know) - It'd have to be an EEPROM edit, and that may be a-whole-nother rabbit hole.
