Traffic Sign Recognition on Canadian Audi A3
dr_torch
Ottawa, Canada
C?ID=442284
Good afternoon all!
Hope you are all well.
I have question for you all. I own a 2019 Audi A3 in Canada. It has a front mounted camera and does the active lane assist and the adaptive cruise control.
The A4's in Canada have the option to read the traffic signs and display the speed limit onto the virtual cockpit - but not the A3's.
Is this is feature that I could use VCDS to activate on my A3 or is there more missing on the car than just a software change?
I was reading that I may require a certain type of camera but I have no idea how to determine which one I have.
Thanks for reading and I appreciate any help you can offer.
Cheers!
Unfortunately, this kind of question is a conundrum. I don't it's possible to give a definitive answer knowing exactly what camera is installed, and that's best determined by a scan.
dr_torch
Ottawa, Canada
C?ID=442284
Awesome. I love conundrums. They are my favourite :)
So - assuming it would be the correct camera - does that mean it would simply be a software change?
dr_torch: Hi. So you view this particular conundrum as a possible challenge to be pursued rather than a futile problem- excellent approach !!
As a separate but related question - I invite that you consider perhaps a more pivotal matter as to the way forward for someone in your position; do you believe that a VCDS cable/dongle would be of value in the coming years as an adjunct to your new-ish A3, or maybe for other VAG vehicles?
If the answer is yes - then of course the first-step in resolving this particular enigma is clear and I would recommend a visual trip to the shop
In the alternative that the answer is less clear, then the corollary question arises - how do you intend to pursue the two quintessential parts of the conundrum being the identity of the front facing camera type in your car and more importantly, how do you intend to manage the coding changes (if the correct camera is fitted)?
Maybe a low -risk solution in this early part of your investigation might be to find someone in your neighborhood who already has VCDS and is willing to provide an autoscan of the car. I'm not familiar with Ottawa, but I would think that VCDS onwers can't be too scarce! Down here -the accepted currency for such a service is a "slab" (carton of beer)
dr_torch
Ottawa, Canada
C?ID=442284
Good evening @DV52 and @Uwe - thank you again for your replies.
I totally agree with you that VCDS will be useful in the future. I'm just not quite ready to commit to $200US right now - especially if it's unclear if I can do what I want.
I went ahead and ordered the baby brother - ODB11 and will use that as a bit of a learning curve and hopefully not break the car :) I just need to wait for it to arrive now. I paid for the cheapo shipping and it looks like it will take forever to get to Canada!
Once I feel I am a bit more comfortable I can go ahead and order VCDS.
Thanks again for your help. I will keep you updated.
Cheers!
dr_torch
Ottawa, Canada
C?ID=442284
Ok - so I gave up on waiting for ODBII to arrive and I bought VCDS lol. I did an autoscan and got the following:
Tuesday,18,May,2021,14:14:02:46467
VIN: WAUKEGFF0K1025876   License Plate:
Mileage: 21663km-13460mi   Repair Order:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 39 3C 42 44 47 4B
          52 5F 6C A5 BB BC CF D6 D7
VIN: WAUKEGFF0K1025876   Mileage: 21663km-13460miles
Address 01: Engine (J623-DHHA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Revision: --H13---
   Coding: 0A2500324466010F3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001003
   ROD: EV_ECM20TFS0205G0906259Q.rod
   VCID: 3C213DFB86E0FFDB93B-8068
   Part No SW: 0GC 300 013 M    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2402
   Revision: 00H06V08
   ROD: EV_TCMDQ381061_VW37.rod
   VCID: 2E0507B3409C1D4B2DF-807A
   No subsystems:
   Part No SW: 5Q0 614 517 EJ    HW: 5Q0 614 517 BS
   Component: ESC           H82 0107
   Revision: 00000000    Serial number: 63278000000115
   Coding: 13FF6B9250222271897F0B07A0C969C8D60A4491D00596741841500412A84A0B0000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 7DA7F0FFDD7A36D3E45-8028
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0505907269
   Coding: 030C0C1720
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D34607FB1E8023D21-8016
65794 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Function restriction due to temp low voltage]
                    Reset counter: 30
                    Mileage: 21414 km
                    Date: 2021.04.24
                    Time: 10:59:33
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition met
                    Control Module Voltage: 8.423 V
                    Vehicle speed: 0.0 km/h
                    Engine RPM: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: No response
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 8V0 820 043 AF    HW: 8V0 820 043 AF
   Component: AC Automat    H03 0150
   Revision: 20003000    Serial number: 00000001734931
   Coding: 03000014010000001000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
   VCID: 76B5EFD3F84C658BA5F-8022
   Humidity sensor: exterior:
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 6B60D98900PAG0MUFU03
   Part No SW: 5Q0 937 085 BS    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H38 0273
   Serial number: 00001902300245
   ROD: EV_BCMBOSCH_019.rod
   VCID: 0B43AE2793CE0863EA1-805E
   Component: WWS371 181213  043 0585
   Serial number:         190112033217
   Coding: 0A47F7
   Serial number: 21772308X81A955547A0
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 08 11 2018  20000037
   Serial number: 00000000000046275132
   Sunroof control module:
   Component: J245 PS73.404  H04 0005
   Serial number: 0000FST00288BWP00000
   Coding: 101F00
   Steering Column Switch:
   Subsystem 6 - Part No SW: 82A 953 521 CQ    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000026011904406473
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
                    Reset counter: 208
                    Mileage: 20805 km
                    Date: 2021.03.23
                    Time: 16:00:14
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417318272
   Coding: 0270167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 51FF7C4F316262B350D-8004
   Part No SW: 5Q0 907 572 P    HW: 5Q0 907 572 J
   Coding: B50087C119FFC428949C815580302600000000000000000004
   VCID: 44D1451BFE10871BEBB-8010
   Serial number: 003GCR0B4RR+
   VCID: 47CB5217CF26AC030E9-8012
   Left seat belt tensioner:
   Serial number: 34230167A22011920725
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34230168A23011921267
   Coding: 333135
   Serial number: 694000000000001VF7ZM
   Coding: 303436
   Subsystem 4 - Part No SW: -----------    HW: 480 001 701 19
   Serial number: 3570000000080C54D73O
   Subsystem 5 - Part No SW: -----------    HW: 480 001 701 19
   Serial number: 358000000005801CE73N
   Subsystem 6 - Part No SW: -----------    HW: 480 402 301 19
   Component: SideSensor_Dr  004 6149
   Serial number: 3510001022BFE091D34+
   Subsystem 7 - Part No SW: -----------    HW: 480 402 301 19
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001022BFE091F611
   Subsystem 8 - Part No SW: -----------    HW: 480 400 801 19
   Component: FrontSensor_D  003 6149
   Serial number: 3550001AD2E6FB1471EQ
   Subsystem 9 - Part No SW: -----------    HW: 480 400 801 19
   Component: FrontSensor_P  003 6149
   Serial number: 3560001AD2E6FB1435FS
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 790 C    HW: 8V0 920 790 C
   Component: FBenRDW       H19 0109
   Coding: 088618516E9800080285E8001800000000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001032
   ROD: EV_DashBoardFPKAU37X.rod
   Serial number: 25011911601437
   Coding: 030100043F0859005B00005E180B00000001010000000000000000000000
   ROD: EV_GatewNF_AU37.rod
   VCID: 6E85C7B3801C5D4B6DF-803A
   Generator:
   Component: 1-01-0d-01-04
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20190125143737 21735
   Serial number: 75886003911901280E70
8526361 - LV Energy Management
          B1802 F1 [008] - Warning Triggered
                    Reset counter: 30
                    Mileage: 21437 km
                    Date: 2021.04.27
                    Time: 15:30:05
                    Terminal 30 power supply: 11.0 V
                    Terminal 15: On
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00023.11.18
   Coding: 0001
   VCID: 4CC16D3BD6404F5B23B-8018
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H07 0022
   VCID: 42DD4303E404892BD97-8016
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 18000420367007
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F1CCF51A202B330D-8064
Address 39: Right Light
   Part No SW: 3Q0 907 566 H    HW: 3Q0 907 566
   Component: MRR1Rear      H23 0630
   Revision: --------
   Coding: 04C002
   VCID: 3D2730FF9DFAF6D3A45-8068
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007RLB2427B
   Coding: 005E1B204000008000000002
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1082
   Coding: 931F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1D5DBEE30779B9BB-8020
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAJ5F024A9K
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 2411E59B1E50A71BCBB-8070
   Component: FCM MQB Low   002 0345
   Serial number: 23011911600048
   Coding: 000000050900147200112300040000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   VCID: 353728DFA5CA2E936C5-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007RLE05385
   Coding: 005E13204000008000000002
   Part No SW: 8V1 035 880 C    HW: 8V1 035 880 C
   Component: MU-P-LNS-US   055 1363
   Serial number: A702A0KS014685
   Coding: 017301020000000011220002041A00332F002BE4017001047E
   VCID: 3A2D3BE38CD4C1EB817-806E
   Subsystem 1 - Part No SW: V03 959 803 AK    HW: -----------
   Component: NAR 2021  --- 0081
   Multimedia System 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9J1Y0FXN8
   Subsystem 3 - Part No SW: 8V0 919 614 BT    HW: 8V0 919 614 BT
   Component: ControlUnit_H  H85 0858
   Serial number: ALJAL115101800050049
   Compact disc data bank:
   Component: Gracenote2  --- 3013
   Component: RVC Compact   H15 0231
   Coding: 0273010102002001400040
   VCID: 392F24EF89D2CAF388D-806C
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0610
   Serial number: 15111815K24085
   Coding: 040307010000020101222346C14E490080000E20012000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D9490BEA089B3BCF3-8014
   Part No SW: 8W1 959 395 D    HW: 8W1 959 395 D
   Component: TSG HFS003 0187
   Serial number: YE007RLE34671
   Coding: 000C13204000008000000002
   ROD: EV_DCU2RearDriveMAXHCONT_VW41.rod
   Component: TSG HBFS003 0187
   Serial number: YE007RLE3467D
   ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
   Part No SW: 3Q0 907 590 H    HW: 3Q0 907 590
   Revision: --------
   Coding: 04C002
   VCID: 176BC257DF06FC835E9-8042
End----(Elapsed Time: 02:04, VBatt start/end: 11.4V/11.3V. VIgn 11.3V)-----
Does this help us to determine if I have the correct camera to do traffic sign recognition? I'm happy to scan specific modules for you but I am very very new to this so I am going slowly as to not break the car haha.
dr_torch
Ottawa, Canada
C?ID=442284
As a side note I did adjust the active lane assist from "late" to "early" and it now keeps me right in the middle of the lane which is pretty cool. I kind of wonder why Audi did not do that to begin with in the Canadian market - or at least have an option on the MMI to change it.
Trowbridge, UK
-------------------------------------------------------------------------------[/CODE]
Yep, you've got the necessary A5 camera.
dr_torch
Ottawa, Canada
C?ID=442284
Awesome! So where do I go from here? Does anybody know if it's just adaptation I need to do or is it the scary long coding (that I am scared of) :)
dr_torch: Of course your Canadian cars are not the same as our Aussie vehicles and notwithstanding that your cars oddly have their steering wheel on the not-correct (i.e. not-right) side - doesn't your MY19 A3 have this MMI screen?
The setting that the driver selects in "Steering Input" does the same as the long-code switches - and whilst I haven't personally checked - I suspect that it actually makes the Bit change that you made via VCDS.
dON
dr_torch
Ottawa, Canada
C?ID=442284
My car does have that screen @DV52 however it only has the Vibration warning option and nothing else.
I changed A5 - IDE10407-Personalization of intervention moment at T. 15. It was set to "last setting" which makes no sense to me as there is not a setting. I set it to early but still nothing shows up in the MMI.
@dr_torch. Alas yes - you must confront and defeat your dread of the feared long-code for this tweak - but if this is the worst of your phobias, I suspect that you aren't doing too bad !!
As for the instruction-set for the tweak, a fellow countryman of yours has listed the steps HERE - it shouldn't matter that the vehicle in the link is not an A3 because the Sportswagen shares the same MQB platform DNA as your car - note the hexA5 module in the link has an almost identical Part Number
Try hexA5 module:
  • IDE10870-Switch-on condition: lane depart. warn. set value to off (setting via menu)
  • IDE10873-BAP personalization set value to activated
PS: setting IDE10407 to "last setting" means that Lane Assist will remember the ON/OFF status on the subsequent ignition cycle
dr_torch
Ottawa, Canada
C?ID=442284
Try hexA5 module: IDE10870-Switch-on condition: lane depart. warn. set value to off (setting via menu)
Unfortunately it looks like that is the current setting :(
dr_torch
Ottawa, Canada
C?ID=442284
Okey dokey @DV52 - I will give it a shot tomorrow. I guess the worst that can happen is that it does not work and I will revert the settings back.
Stupid question - that guide end with rebooting the MMI ... how do I go about doing that? :)
dr_torch
Ottawa, Canada
C?ID=442284
BTW - thank you so much for your help. I really appreciate it.
You responded too soon - re-look at my reply!!
It's called "the three finger salute" - like this
dr_torch
Ottawa, Canada
C?ID=442284
Awesome @DV52 .... I shall give it a shot tomorrow as well and I will keep you updated!
I forgot to mention that you should note the last post in my link
@Swaizer says:
"........I put this feature to work... but, in fact here, in Canada or the US, will not work. Why? Because of the speed signs profile.​
That system was designed to work with rounded speed signs, very common in Europe and some South American countries."​
darkchina811
ITALY
C?ID=333184
I don't mean to kill your enthusiasm but TSR is an option you will likely want OFF, as it's rather annoying
it does not detect every sign at all, and, mostly, why would I want my car to warn me that I am speeding when... I am perfectly aware of what I am doing :D
