Golf GTD Mk7 Fault Codes Post Timing Belt Change
Dave Witchdoktor
C?ID=350089
Hi
Just had my timing belt changed and when i drove away from the garage, the coil light came on flashing, im getting a cmp sensor (g40) fault from the auto scan.
Any ideas on what could be causing this?
Tia
Dave
Tuesday,27,April,2021,10:42:36:13806
VIN: WVWZZZAUZFW090998   License Plate: WD07TOR
Mileage: 156311km-97127mi   Repair Order: 27/4/21 10.42am
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A9
VIN: WVWZZZAUZFW090998   Mileage: 156311km-97127miles
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EP    HW: 04L 907 309 A
   Component: R4 2,0L EDC   H22 7539
   Revision: 81H22---
   Coding: 01190012034505082000
   ASAM Dataset: EV_ECM20TDI01104L906021EP 002008
   ROD: EV_ECM20TDI01104L906021AE.rod
   VCID: 77ABE8371F4E1A53BE9-8022
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
          P0016 00 [101] - Incorrect Correlation
                    Mileage: 156311 km
                    Date: 2021.04.27
                    Time: 10:27:21
                    Engine RPM: 769.50 /min
                    Normed load value: 37.3 %
                    Coolant temperature: 60 °C
                    Intake air temperature: 43 °C
                    Voltage terminal 30: 13.920 V
                    Engine start: start synchronization: EPM_MODE_OK
                    Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE: 48
   Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
   Component: ESC           H31 0472
   Revision: 00000000    Serial number: 62134000000140
   Coding: 01FA8AA13429096C0380060941CB2980512C90C0608294F5F4605078C009
   VCID: 074B98F76FAE6AD3CE9-8052
32837 - Lamp in Switch for Electronic Parking Brake
          C1145 13 [009] - Open Circuit
                    Reset counter: 38
                    Mileage: 112647 km
                    Date: 2019.01.07
                    Time: 15:47:00
   Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
   Component: Climatronic   H03 0907
   Revision: 00001K08
   Coding: 00120114202100011005000000101000
   VCID: 73B3DC270B367673821-8026
   Air quality sensor:
459025 - Databus
          [Radio - kein Signal/Kommunikation]
                    Reset counter: 38
                    Mileage: 156311 km
                    Date: 2021.04.27
                    Time: 10:06:53
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011421804296
   Coding: 03100A46C24122FB0BA44080B10C07281000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 005983EB4A805DEB8F3-8054
   Component: WWS    140724  042 0551
   Serial number:         140728105227
   Component: RLHS  037 0059
   Serial number: S4Y14M08D18H02M34S13
   Coding: 00A8DD
   Serial number: 000000000ZY1420200U3
   Serial number: 00000000000060218428
   Sunroof control module:
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO31547633
   Coding: 181901
          B1263 01 [009] - Electrical Failure
                    Reset counter: 38
                    Mileage: 156311 km
                    Date: 2021.04.27
                    Time: 10:08:32
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331420904094
   Coding: 0071051001
   VCID: 3D273A1F7DF2F003A45-8068
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 11081477030458
   Coding: 00000300FE0739
   VCID: 38292B0B52D0D52B773-806C
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR07UDSM
   VCID: 7F5B0017377E2213F69-802A
   Left seat belt tensioner:
   Serial number: 34169677B18081470610
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169676B14081441038
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 408 14
   Serial number: 35767000000E5931A01S
   Subsystem 4 - Part No SW: -----------    HW: 480 001 408 14
   Serial number: 35867000000A4C7C901+
   Subsystem 5 - Part No SW: -----------    HW: 480 401 108 14
   Serial number: 3516502BB16DB81391BM
   Subsystem 6 - Part No SW: -----------    HW: 480 401 208 14
   Serial number: 35265029D16FC225A35K
   Subsystem 7 - Part No SW: -----------    HW: 480 401 408 14
   Serial number: 3556502B916DB811D13I
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 12081404220638
   Coding: 0C00
   VCID: 7BA3F40723663E33DA1-802E
   Part No SW: 5G1 920 957     HW: 5G1 920 957
   Component: KOMBI         301 4270
   Coding: 27AD09002F80260001886A011400000000000000
   VCID: 6D87CA5F6D12A083545-8038
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002351792
   Coding: 030100040B087300EF00027E080F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011.rod
   VCID: 42DD49E3040C8FFBD97-8016
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0038
   Serial number: 27140001959420024324
   Coding: 2CFFFF
   Serial number: 8808324003
131699 - Control unit for information electronics 1
          U1054 00 [009] - No Communication
          [Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
                    Reset counter: 38
                    Mileage: 156311 km
                    Date: 2021.04.27
                    Time: 10:06:53
                    Terminal 30 power supply: 11.9 V
                    Terminal 15: On
   Serial number: 30071401101297
   Coding: 003F0220D001048000001000
   VCID: 40D943EB0A009DEBCF3-8014
   Serial number: 00000000000003469395
   Coding: 1D0000
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3537223F45C228436C5-8060
   Serial number: 30071406070075
   Coding: 003F0020DE01048000801000
   VCID: 3FDB401777FEE213B69-806A
   Serial number: 00000000000003506153
   Coding: 050000
   Coding: 029E01000B000200
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Component: SAS-GEN 2     H06 0014
   Serial number: 140716200280
   VCID: 6B83C4475306AEB34A1-803E
End----(Elapsed Time: 01:47, VBatt start/end: 12.0V/11.9V. VIgn 11.8V
Bruce
Near Philadelphia, PA, USA
Yes. They did not get the timing belt on right and things are not properly aligned. I would suggest getting it back to the garage as soon as possible. Don't keep driving it.
Dave Witchdoktor
C?ID=350089
The mechanic came back from home (sat afternoon).Stripped it down and re done the job, with that fault code re occurring, could it be the sensor failing, would you incorrectly fit the belt twice? Im not sure you would. Not ruling it out obviously, ive sent the scan to him also, see what he says.
Bruce
It does not report as a sensor fail. It reports a correlation error. That means the 2 sensors, the CAM and the Crank sensors are not syncing - ie, it is out of time. I doubt this is a failed sensor. I think it is a failed job on the timing belt.
Dave Witchdoktor
C?ID=350089
Ok, thanks for the info, thats very helpful
Dave Witchdoktor
C?ID=350089
So, the cars going in today, but what i have noticed is, when i clear the code, the next morning the fault isnt there until the car gets up to temperature? Any ideas why that could be?
Cheersq
DGMotors
C?ID=57532
Cheersq
Because as the engine warms up everything expands and the timing then goes out. I would be very worried that he not using the proper locking tools as to get it wrong twice already.
