- Jun 24, 2014
- 113
- 14
- Long Island
- C?ID=174376
Hello everyone hope this msg find you all well and safe,
so here we go,
I was wondering if anyone can assist me with my problem on my PDC retrofit installed on my 2017 GTI MK7 6 speed manual. I purchases this kit new form amazon/china. Anyway the module is a 5QD 919 294J other number on it 5QA 919 294. I installed all wiring as per the instructions and confirmed all connections were correct prior to power on. I also have a registered VAGCOM cable with new update. I coded the modules as per instructions, however I still keep getting these faults, see scan,
Anyway if you can offer any assistance that would be great, thanks again.
so here we go,
Monday,26,April,2021,15:22:42:09643
VCDS Version: 21.3.0.0 (x64)
Dealer/Shop Name: Tony's VW_4_life
VIN: 3VW5T7AU5HM066511 License Plate: RED GTI PDC INST
Mileage: 9470km-5884mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F 75 A9
VIN: 3VW5T7AU5HM066511 Mileage: 9470km-5884miles
Address 01: Engine (J623-CXCA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 L HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091900322424002F0000
Shop #: WSC 00066 790 00149
ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
ROD: EV_ECM20TFS0205G0906259L.rod
VCID: 377DE3BD8E682F3332-8062
Readiness: 1110 1101
Address 03: ABS Brakes (J104) Labels:* 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AQ HW: 5Q0 614 517 AF
Component: ESC H62 0400
Revision: 00000000 Serial number: 51147000001983
Coding: 01FA6BA134260972407C020180C42980D62C90024001943400435050C009430000000012121212B835351919323200
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
ROD: EV_Brake1UDSContiMK100ESP_036.rod
VCID: 000F48619B26A88BC3-8054
Part No SW: 5GM 907 426 E HW: 5GM 907 426 E
Component: AC Manuell H03 1801
Revision: 00001K04
Coding: 00020004200100000000000000000002
ROD: EV_ACManueBHBVW37X_004.rod
VCID: 4A9BAA49ED9AA2DB5D-801E
B10CD 00 [008] - -
Reset counter: 229
Mileage: 9470 km
Date: 2021.04.26
Time: 14:22:30
Voltage terminal 30: 11.3 V
CAN input signal(s) status-Back-up lamp: OFF
Part No SW: 5Q0 937 087 AN HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 032 0223
Revision: -------- Serial number: C86420041701R6
ROD: EV_BCMBOSCH_017.rod
VCID: 071D537DBE089FB382-8052
Wiper motor control module:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170304 043 0551
Serial number: 97022066170318005905
Part No SW: 5QD 919 294 J HW: 5QA 919 294
Component: PDC 8 KanalH07 0443
Serial number: 000308418218348
Coding: 0431251101
Shop #: WSC 01369 210 40505
ROD: EV_EPHVA18AU3700000.rod
VCID: 56A34E392922F63BC9-8002
12658704 - Databus
Reset counter: 189
Mileage: 9470 km
Date: 2021.04.26
Time: 14:45:16
13632273 - Databus
Reset counter: 189
Mileage: 9470 km
Date: 2021.04.26
Time: 14:45:16
Serial number: 003GCR07PRJ7
VCID: 479D937DFE885FB342-8012
Component: BF-Gewichtss. H13 0022
Serial number: IBH0000000000071T2ON
Coding: 30305A
Subsystem 2 - Part No SW: ----------- HW: 480 000 704 17
Serial number: 357000000003747D622G
Subsystem 3 - Part No SW: ----------- HW: 480 000 704 17
Serial number: 35800000000B0A2C622I
Subsystem 4 - Part No SW: ----------- HW: 480 400 704 17
Serial number: 3510001B7257C422E70/
Subsystem 5 - Part No SW: ----------- HW: 480 400 704 17
Serial number: 3520001C7257C426D476
Subsystem 6 - Part No SW: ----------- HW: 480 402 603 17
Serial number: 3550002B924F384181FA
Subsystem 7 - Part No SW: ----------- HW: 480 402 603 17
Serial number: 3560002B924F3845C28D
Part No SW: 5Q0 953 507 FT HW: 5Q0 953 549 F
Revision: -------- Serial number: 31031704221018
Coding: 0400
VCID: 0D116155DC74F5E3B8-8058
Part No SW: 5G1 920 856 B HW: 5G1 920 856 B
Component: KOMBI 344 8311
Coding: 0BBD09022180CF0502086A001000000000000000
VCID: 2D51C1D57C3495E358-8078
U1014 00 [009] - -
Reset counter: 189
Mileage: 9470 km
Date: 2021.04.26
Time: 14:07:52
Part No SW: 3Q0 907 530 B HW: 3Q0 907 530 B
Component: GW MQB Mid 517 5286
Serial number: 30051700840073
Coding: 0101000870085900FB000028080F00000001050000000000000000000000
Shop #: WSC 00066 790 00215
ROD: EV_GatewNF_VW37.rod
VCID: 2E53C6D97132EEFB61-807A
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0103
Serial number: 29170000129990067045
Coding: 30FFFF
Component: TSG FS 020 0041
Serial number: 160517A0080CLA
Coding: 003F03205000020000000000
Shop #: WSC 12345 123 61029
VCID: 4385876DCAB073939E-8016
Serial number: 00000000000006346821
Coding: 011000
Part No SW: 3QM 909 144 HW: 3QM 909 144
Component: EPS_MQB_ZFLS 506 5072
Coding: 8102
ROD: EV_SteerAssisMQB_013.rod
VCID: 0C176C51A76EFCEBAF-8058
Component: TSG BFS 020 0041
Serial number: 160517A00801Z8
Coding: 003F03205E00020000000000
VCID: 428B8269D5AA7A9B95-8016
Serial number: 00000000000005234289
Coding: 091000
Part No SW: 3Q0 035 844 A HW: 3Q0 035 844 A
Component: MU-S-S-US 710 0753
Coding: 02730000FF00000051220001001808009F0203D40120010002
ROD: EV_MUStd4CDELP_VW26.rod
Subsystem 1 - Part No SW: 5G6 919 605 C HW: 5G6 919 605 C
Component: ABT_Std-2 252 8130
Serial number: VWZ6ZMW0466181
B201A 00 [009] - -
Reset counter: 189
Mileage: 9470 km
Date: 2021.04.25
Time: 20:14:30
Voltage terminal 30: 12.5 V
Status_Software_Version_Management-module_name: C
6922 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 229
Mileage: 9470 km
Date: 2021.04.26
Time: 13:37:50
Voltage terminal 30: 11.5 V
7178 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 229
Mileage: 9470 km
Date: 2021.04.26
Time: 13:37:53
BAP-BAP_Function_ID: 02
Component: OCULowMQBUS 007 0570
Coding: 02730002C2821A017F1E06000000
ROD: EV_OCULowMQB.rod
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 170318201005
VCID: 6BD50FCD82A05BD306-803E
End-------------------------(Elapsed Time: 03:50)--------------------------
