GTI MK7 base model S 8 sensor PDC install
   #21
myounus
Northwest UK
C?ID=321059
MAS12843-Maneuvering brake function activated 1
Deactivate that and see if that makes a difference. If not, then re-activate it.
What exact error are you experiencing when trying to use the PDC? Do the sensors come on and display on the screen? What would help is a scan using a V2 cable.
   #22
aljb320
Long Island
C?ID=174376
Myounus,
ok I'll try that, so what happens is, as soon as I turn the key to on I immediately get a park pilot fault on the cluster display, radio display, and center console with switch flashing. If i press the switch the system goes off and flashing stops. I then reset thru VCDS and faults clear until i restart car again and it all come s back.
The display never shows the lines when I shift in reverse I see my display come on with video but no park sensors indicate in the display.
the VCDS faults are the same in both controllers 5F 1555 - Check Software Version Management B201A 00 [009] [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
10 Databus U1121 00 [009] - Missing Message [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
   #23
aljb320
Long Island
C?ID=174376
Myounus,
ok I entered the security code and opened adaptations and found AS12843-Maneuvering brake function activated
I tried deactivating and still nothing.
   #24
aljb320
Long Island
C?ID=174376
one more thing is whats a V2 cable?
   #25
aljb320
Long Island
C?ID=174376
oh never mind your talking about the new Ross-tech HEX-V2 cable, yea im a strapped for cash.
   #26
downtime
Finland
C?ID=280813
With hex+can (the old cable) it's really difficult to get to the root problem as it does not show from which source the missing messages are coming from. Hex-V2 shows the extended UDS data for trouble codes as well and it helps to understand what exactly is missing or is incorrectly coded.
With MQB platform cars it is more than required to have a newer cable. The old one unfortunately is getting really badly outdated.
   #27
aljb320
Long Island
C?ID=174376
ok got it thanks, i guess ill have to purchase one.
   #28
myounus
Northwest UK
C?ID=321059
You will but it makes fault finding really easy or is this case coding issues. Speak to UWE and see what deals are on.
   #29
aljb320
Long Island
C?ID=174376
I will thank you.
   #30
aljb320
Long Island
C?ID=174376
ok just made my purchase, (dont tell my wife LoL). hope to have it by next week and will go from there.
   #31
downtime
Finland
C?ID=280813
:thumbs: Good. Because the pdc module should work no matter basically what are the parameters in it. Now that it does not, indicates something is not correct in the coding or incorrect connection somewhere. Hex2 will give you much more detailed information about that.
   #32
aljb320
Long Island
C?ID=174376
Oh I agree, I have gone over the connections 5 times and as per the sellers instructions they are correct. Noe the thing is that the switch works, the module powers up, im able to code, so that tells me the as for wiring I should be ok. Again I'll wait and will up date you, thanks again.
   #33
downtime
Finland
C?ID=280813
Yes, but your cable only shows the descriptions for the bits in the static label file. New cable deciphers the UDS data and it shows much more + like said many times before, it tells you the extended info for the trouble codes as well
   #34
aljb320
Long Island
C?ID=174376
Ok everyone here is the new scan with my new V2 cable, this thing is awsome and thanks to ross tech for your help with the purchase.
anyway here we go again LoL
oh ignore the light code fault as i had my light disconnected for bumper cover install
I see a fault with the Ebrake but if Im reading this correct its for a electronic brake which I dont have plus dont know where to change this?
Friday,30,April,2021,12:57:02:08609
Dealer/Shop Name: Tony's VW_4_life
VIN: 3VW5T7AU5HM066511   License Plate: RED GTI PDC FLTS
Mileage: 9470km-5884mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F 75 A9
VIN: 3VW5T7AU5HM066511   Mileage: 9470km-5884miles
Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091900322424002F0000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
   ROD: EV_ECM20TFS0205G0906259L.rod
   VCID: 372B22D73FCF9EA37E9-8062
Readiness: 1110 0101
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
   Component: ESC           H62 0400
   Revision: 00000000    Serial number: 51147000001983
   Coding: 01FA6BA134260972407C020180C42980D62C90024001943400435050C009430000000012121212B835351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036.rod
   VCID: 0059890B2A81191B8F3-8054
   Part No SW: 5GM 907 426 E    HW: 5GM 907 426 E
   Component: AC Manuell    H03 1801
   Revision: 00001K04
   Coding: 00020004200100000000000000000002
   VCID: 4ACD6B235C3D134B117-801E
   Part No SW: 5Q0 937 087 AN    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: C86420041701R6
   Shop #: WSC 00066 790 00149
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 074B92170FAF2E23CE9-8052
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170304  043 0551
   Serial number: 97022066170318005905
15626 - Bulb for Left Brake Lamp / Turn Signal
          B1333 15 [009] - Open or Short to Plus
                    Reset counter: 195
                    Mileage: 9470 km
                    Date: 2021.04.30
                    Time: 10:37:53
15882 - Bulb for Right Brake Lamp / Turn Signal
          B1334 15 [009] - Open or Short to Plus
                    Reset counter: 195
                    Mileage: 9470 km
                    Date: 2021.04.30
                    Time: 10:37:53
   Part No SW: 5QD 919 294 J    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0443
   Serial number: 000308418218348
   Coding: 0431651001
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 56F58F53988547AB85F-8002
12658704 - Databus
          [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                    Reset counter: 195
                    Mileage: 9470 km
                    Date: 2021.04.30
                    Time: 12:54:57
   Serial number: 003GCR07PRJ7
   VCID: 47CB52174F2FEE230E9-8012
   Serial number: IBH0000000000071T2ON
   Coding: 30305A
   Subsystem 2 - Part No SW: -----------    HW: 480 000 704 17
   Serial number: 357000000003747D622G
   Subsystem 3 - Part No SW: -----------    HW: 480 000 704 17
   Serial number: 35800000000B0A2C622I
   Subsystem 4 - Part No SW: -----------    HW: 480 400 704 17
   Serial number: 3510001B7257C422E70/
   Subsystem 5 - Part No SW: -----------    HW: 480 400 704 17
   Serial number: 3520001C7257C426D476
   Subsystem 6 - Part No SW: -----------    HW: 480 402 603 17
   Serial number: 3550002B924F384181FA
   Subsystem 7 - Part No SW: -----------    HW: 480 402 603 17
   Serial number: 3560002B924F3845C28D
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 31031704221018
   Coding: 0400
   VCID: 0D47A03F6DD34473F45-8058
   Part No SW: 5G1 920 856 B    HW: 5G1 920 856 B
   Component: KOMBI         344 8311
   Coding: 0BBD09022180CF0502086A001001000000000000
   VCID: 2D0700BFCD932473145-8078
   Part No SW: 3Q0 907 530 B    HW: 3Q0 907 530 B
   Component: GW MQB Mid    517 5286
   Serial number: 30051700840073
   Coding: 0101000870085900FB000028080F00000001050000000000000000000000
   Shop #: WSC 00066 790 00215
   ROD: EV_GatewNF_VW37.rod
   VCID: 2E0507B3C0955F6B2DF-807A
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29170000129990067045
   Coding: 30FFFF
   Serial number: 160517A0080CLA
   Coding: 003F03205000020000000000
   VCID: 43D346077B17C203D21-8016
   Serial number: 00000000000006346821
   Coding: 011000
   Part No SW: 3QM 909 144     HW: 3QM 909 144
   Coding: 8102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 0C41AD3B16C94D7BE3B-8058
   Serial number: 160517A00801Z8
   Coding: 003F03205E00020000000000
   VCID: 42DD4303640DCB0BD97-8016
   Serial number: 00000000000005234289
   Coding: 091000
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0753
   Coding: 02730000FF00000051220001001808009F0203D40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  252 8130
   Serial number: VWZ6ZMW0466181
6922 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 235
                    Mileage: 9470 km
                    Date: 2021.04.29
                    Time: 14:26:15
                    Voltage terminal 30: 12.2 V
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 235
                    Mileage: 9470 km
                    Date: 2021.04.29
                    Time: 14:26:18
                    BAP-BAP_Function_ID: 02
   Coding: 02730002C2821A017F1E06000000
   ROD: EV_OCULowMQB.rod
   Component: SAS-GEN 2     H06 0014
   Serial number: 170318201005
   VCID: 6B83CEA73307EA434A1-803E
End----------(Elapsed Time: 01:14, VBatt start/end: 11.8V/12.3V)-----------
   #35
aljb320
Long Island
C?ID=174376
Als forgive my ignorance but whats up with my ABS coding Coding: 01FA6BA134260972407C020180C42980D62C90024001943400435050C009430000000012121212B835351919323200
I've never seen one this long no punt intended.
so I was trying to go to long coding in ABS to see if there is a bit for Electronic Ebrake but its all check boxes with no way to know what they mean.
reason for my search is the park assist fault about ebrake msg in module 10
( U1121 00 [009] - Missing Message [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation] )
google translater
( U1121 00 [009] - Missing Message [Control unit for electric parking / handbrake-J540 - EPB_01 - no signal / no communication])
Im I in the rite path? probably not lol. or should I be looking in CAN bus Module? anyway any help is great thanks.
   #36
downtime
Finland
C?ID=280813
Electronic parking brake is in the module 10 dataset. That is something you can’t change with coding. You need to flash it with proper dataset, which VCDS cannot do unfortunately.
But that is not the problem why pdc does not work.
Just to be sure, to which can bus you connected the park pilot module?
   #37
aljb320
Long Island
C?ID=174376
oh ok, well as per the instructions I connected the two wires from module 10 26 pin connector T26 pins 17 and 23 to the CAN bus module 10 pin connector pins 8 and 18 and I confirmed per the kit wiring instructions.
But I know that these Chinese kits some times are not correct. Unfortunately I don't have wiring diagrams for this car. But I can get alldate from a friend of mine jsut dont know if they have VW prints, but Ill ask a friend who has access, thanks.
   #38
aljb320
Long Island
C?ID=174376
as per what I found on line I'm connected to the can bus connector module 20 pin.
running gear sensors can bus low pin 8
running gear sensors can bus high pin 18
can you confirm, thanks.
   #39
^^^^hmmm.......... from my MK7 WD:
Again according to my WD, pin # T26i /17 on the J446 connector is wired to K136 Parking aid warning lamp on the EX30 Switch module 2 in centre console
   #40
aljb320
Long Island
C?ID=174376
yes thats what I have and I even had a second set of eyes and sure is connected that way, thanks DV52.
Well here is an update I just received the park assist controller I purchased from ebay and according to seller its from a GTI Mk7 and every thing seems to work but still have the dreaded fault on my display maneuver braking function currently not available however when I shift in reverse all sensors come up.
Ill post new scan in a bit.
