Waste gate duty cycle
PatriceBE
Europe
Hi,
Could you please advise me how to log waste gate duty cycle on MED 17.1.1 ECU? the car is 2015 RS7, I’ve seen most VAG cars can be logged with waste gates, but unfortunately i can’t find it in VCDS search.
the value must be in %, I need to understand by logging the waste gates whether springs are closed and hold pressure while targeting boost.
PatriceBE
Europe
Autoscan paste
>>>>> Tuesday,13,April,2021,22:03:46:10082
>>>>>>> VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
>>>>>>> VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
>>>>>>> Data version: 20201125 DS322.1
>>>>>>> www.Ross-Tech.com
>>>>>>> VIN: WUAZZZ4GXGN900610   License Plate:
>>>>>>> Chassis Type: 4G-AU57 (4G8)
>>>>>>> Scan: 01 02 03 05 08 09 13 14 15 16 17 19 1B 22 28 36 3B 3C 42 44
>>>>>>>            46 52 53 55 5F 62 65 6C 6D 72 84 85 8B 8E 8F 90 BA
>>>>>>> VIN: WUAZZZ4GXGN900610   Mileage: 74165km-46083miles
>>>>>>> 01-Engine -- Status: OK 0000
>>>>>>> 02-Auto Trans -- Status: OK 0000
>>>>>>> 03-ABS Brakes -- Status: OK 0000
>>>>>>> 04-Steering Angle -- Status: OK 0000
>>>>>>> 05-Acc/Start Auth. -- Status: Malfunction 0010
>>>>>>> 08-Auto HVAC -- Status: OK 0000
>>>>>>> 09-Cent. Elect. -- Status: Malfunction 0010
>>>>>>> 13-Auto Dist. Reg -- Status: Malfunction 0010
>>>>>>> 14-Susp. Elect. -- Status: OK 0000
>>>>>>> 15-Airbags -- Status: OK 0000
>>>>>>> 16-Steering wheel -- Status: Malfunction 0010
>>>>>>> 17-Instruments -- Status: OK 0000
>>>>>>> 19-CAN Gateway -- Status: OK 0000
>>>>>>> 1B-Active Steering -- Status: Malfunction 0010
>>>>>>> 22-AWD -- Status: OK 0000
>>>>>>> 28-HVAC, Rear -- Status: OK 0000
>>>>>>> 36-Seat Mem. Drvr -- Status: Malfunction 0010
>>>>>>> 3B-Sensor Elect. -- Status: OK 0000
>>>>>>> 3C-Lane Change -- Status: OK 0000
>>>>>>> 42-Door Elect, Driver -- Status: Malfunction 0010
>>>>>>> 44-Steering Assist -- Status: OK 0000
>>>>>>> 46-Central Conv. -- Status: Malfunction 0010
>>>>>>> 52-Door Elect, Pass. -- Status: Malfunction 0010
>>>>>>> 53-Parking Brake -- Status: OK 0000
>>>>>>> 55-Headlight Range -- Status: OK 0000
>>>>>>> 5F-Information Electr. -- Status: OK 0000
>>>>>>> 62-Door, Rear Left -- Status: OK 0000
>>>>>>> 65-Tire Pressure -- Status: OK 0000
>>>>>>> 6C-Back-up Cam. -- Status: OK 0000
>>>>>>> 6D-Trunk Elect. -- Status: OK 0000
>>>>>>> 72-Door, Rear Right -- Status: OK 0000
>>>>>>> 84-Night Vision -- Status: OK 0000
>>>>>>> 85-On Board Cam. -- Status: OK 0000
>>>>>>> 8B-Adaptive Cruise 2 -- Status: Malfunction 0010
>>>>>>> 8E-Image Processing -- Status: OK 0000
>>>>>>> 8F-Pretens. Frt Left -- Status: OK 0000
>>>>>>> 90-Pretens. Frt Right -- Status: OK 0000
>>>>>>> BA-Motor Mounts -- Status: OK 0000
>>>>>>> Address 01: Engine (------CWUB)       Labels:. 06E-907-551-CGW.clb
>>>>>>>     Part No SW: 4G0 906 560 C    HW: 4H0 906 014
>>>>>>>     Component: 4.0l V8TFSI / H63 0002
>>>>>>>     Revision: NCH63---
>>>>>>>     Coding: 1A2A00326546110B3000
>>>>>>>     Shop #: WSC 92521 052 00000
>>>>>>>     ASAM Dataset: EV_ECM40TFS0114G0906560C 001003
>>>>>>>     ROD: EV_ECM40TFS0114G0906560C.rod
>>>>>>>     VCID: 2809F2F002716D6B1B2-807C
>>>>>>> No fault code found.
>>>>>>> Readiness: 0110 0001
>>>>>>> Address 02: Auto Trans (J217)       Labels:| 0BK-927-156.clb
>>>>>>>     Part No SW: 4G0 927 158 AN    HW: 0BK 927 156 AM
>>>>>>>     Component: 0BK 40TFSIRdW H19 1002
>>>>>>>     Revision: --H19---
>>>>>>>     Coding: 000001
>>>>>>>     Shop #: WSC 00000 000 00000
>>>>>>>     ASAM Dataset: EV_TCMAL551211 002022
>>>>>>>     ROD: EV_TCMAL551211_002_AU48.rod
>>>>>>>     VCID: 7AADF8B8AC5D2FFB3D6-802E
>>>>>>> Address 03: ABS Brakes (J104)       Labels:. 4G0-907-379-V2.clb
>>>>>>>     Part No SW: 4G0 907 379 T    HW: 4G0 907 379 T
>>>>>>>     Component: ESP9 Premium  H01 0100
>>>>>>>     Revision: --------    Serial number: --------------
>>>>>>>     Coding: 83BF994BC1FD99D29F00
>>>>>>>     Shop #: WSC 02391 785 00200
>>>>>>>     ASAM Dataset: EV_ESP9BOSCHAU57X 004018
>>>>>>>     ROD: EV_ESP9BOSCHAU57X.rod
>>>>>>>     VCID: 42DD4058840DA73B256-8016
>>>>>>> Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
>>>>>>>     Part No SW: 4H0 907 064 GP    HW: 4H0 907 064 GP
>>>>>>>     Component: BCM2 2.0      H37 0572
>>>>>>>     Revision: 00002001
>>>>>>>     Coding: 05AA6F0E000000000000
>>>>>>>     VCID: 7DA7F3A4BDF318C3184-8028
>>>>>>> 1 Fault Found:
>>>>>>> 01330 - Central Control Module for Central Convenience (J393)
>>>>>>>              013 - Check DTC Memory - Intermittent
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Status: 00101101
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>> Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-4Z.clb
>>>>>>>     Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
>>>>>>>     Component: KLIMA 4 ZONEN H14 0112
>>>>>>>     Serial number: 15051500041153
>>>>>>>     Coding: 680310B80D0000
>>>>>>>     ASAM Dataset: EV_AirCondiComfoUDS 003008
>>>>>>>     ROD: EV_AirCondiComfoUDS_003.rod
>>>>>>>     VCID: 6A8DC8F8DCFD9F7BCD6-803E
>>>>>>> Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
>>>>>>>     Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
>>>>>>>     Component: BCM1 2.0      H20 0311
>>>>>>>     Revision: 15020001    Serial number: 00001077089602
>>>>>>>     Coding: 0105C01440349FF2F90140C7A0001800CF9CC3082E08020180000894610113020040002D0B0000
>>>>>>>     VCID: 71BFDF94F1AB6CA38CC-8024
>>>>>>>     Subsystem 1 - Part No SW: 4G1 955 119     HW: 4G8 955 119   Labels: 1KX-955-119.CLB
>>>>>>>     Component: WWS57X 150427  H37 0080
>>>>>>>     Serial number:         150505000359
>>>>>>>     Coding: 0045F7
>>>>>>>     Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B   Labels: 8U0-955-559.CLB
>>>>>>>     Component: G397_RLFS  H06 0002
>>>>>>>     Serial number: 23980449
>>>>>>>     Coding: 0200EF
>>>>>>>     Subsystem 3 - Part No SW: 4G0 941 531 BF    HW: 4G0 941 531 BF
>>>>>>>     Component: E1 - LDS  H07 0044
>>>>>>>     Serial number: 22 04 2015  00001611
>>>>>>>     Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
>>>>>>>     Component: EVLS-SG  H08 0300
>>>>>>>     Serial number: WA120708000012841786
>>>>>>>     Coding: 020300
>>>>>>>     Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
>>>>>>>     Component: AQ_Hum_Sensor  H03 0003
>>>>>>>     Serial number: C5B889A7000000000001
>>>>>>> 12 Faults Found:
>>>>>>> 01316 - ABS Control Module
>>>>>>>              004 - No Signal/Communication - Intermittent
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Status: 00100100
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>> 01309 - Power Steering Control Module (J500)
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 6
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>> 01319 - Control Module for Distance Control (J428)
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>> 01321 - Control Module for Airbags (J234)
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>> 01314 - Engine Control Module
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>> 01315 - Transmission Control Module
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>> 00473 - Control Module for Elect. Park/Hand Brake (J540)
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>> 01317 - Control Module in Instrument Cluster (J285)
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>> 03278 - Functionality Limited due to Missing Messages
>>>>>>>              000 - - - Intermittent
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Status: 00100000
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>> 01320 - Control Module for Climatronic (J255)
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 6
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>> 03725 - Control Module for Seat Belt Tensioner; Left Front
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>> 01324 - Control Module for All Wheel Drive (J492)
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>> Address 13: Auto Dist. Reg (J428)       Labels:| 4H0-907-561.clb
>>>>>>>     Part No SW: 4G0 907 561 B    HW: 4G0 907 561
>>>>>>>     Component: ACC3          H21 0053
>>>>>>>     Serial number: 00000000000000
>>>>>>>     Coding: 7E04010101
>>>>>>>     ASAM Dataset: EV_AdaptCruisContrAU57X 002014
>>>>>>>     ROD: EV_AdaptCruisContrAU57X_002.rod
>>>>>>>     VCID: 290FF7F4197B546304C-807C
>>>>>>> 3 Faults Found:
>>>>>>> 95232 - Function Restriction due to Faults in Other Modules
>>>>>>>            U1113 00 [008] - -
>>>>>>>            [FAULT_CIS_QEPBACC_FAIL]
>>>>>>>            Intermittent - Confirmed - Tested Since Memory Clear
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Status: 00000001
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 1
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 74037 km
>>>>>>>                      Date: 2021.04.09
>>>>>>>                      Time: 18:44:19
>>>>>>>                      Control Module temperature: 32 °C
>>>>>>>                      Voltage terminal 15: 12.086 V
>>>>>>>                      Velocity_vehicle_reference: -0.01 m/s
>>>>>>>                      Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
>>>>>>> 95488 - Function Restriction due to Faults in Other Modules
>>>>>>>            U1113 00 [008] - -
>>>>>>>            [FAULT_CIS_QDISACC_FAIL]
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 1
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 74037 km
>>>>>>>                      Date: 2021.04.09
>>>>>>>                      Time: 18:44:19
>>>>>>>                      Voltage terminal 15: 12.090 V
>>>>>>> 148480 - Function Restriction due to Implausible Message(s)
>>>>>>>            U1112 00 [008] - -
>>>>>>>            [FAULT_CIS_MISMATCH_Motorleistung]
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 2
>>>>>>>                      Fault Frequency: 1
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 74037 km
>>>>>>>                      Date: 2021.04.09
>>>>>>>                      Time: 18:45:47
>>>>>>>                      Control Module temperature: 31 °C
>>>>>>>                      Voltage terminal 15: 12.120 V
>>>>>>> Address 14: Susp. Elect.        Labels: None
>>>>>>>     Part No SW: 4G0 907 376     HW: 4G0 907 376 A
>>>>>>>     Component: J250 DRC FahrwerH01 0040
>>>>>>>     Revision: 00000000    Serial number: 00894015678900
>>>>>>>     Coding: 0000000
>>>>>>>     VCID: 6B83CDFCDF878673B60-803E
>>>>>>> Address 15: Airbags (J234)       Labels:* 4H0-959-655.clb
>>>>>>>     Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
>>>>>>>     Component: Airbag10.43   H82 0086
>>>>>>>     Revision: --------    Serial number: 003P1004S2U7
>>>>>>>     Coding: 30333046313130313136554A304C34473853
>>>>>>>     ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
>>>>>>>     ROD: EV_AirbaAU10BPAAU64X_VW51.rod
>>>>>>>     VCID: 3B233DBCE3E7D6F3660-806E
>>>>>>>     Crash sensor for side airbag: driver side:
>>>>>>>     Serial number: 3575HRB405F3ABEAAGDE
>>>>>>>     Front Passenger's Side Airbag Crash Sensor:
>>>>>>>     Serial number: 3585HRB405B3ABEAC9JC
>>>>>>>     Rear Side Airbag Crash Sensor (on driver's side):
>>>>>>>     Serial number: 3515JRB400E54R1AO21Y
>>>>>>>     Passenger side rear thorax airbag crash sensor:
>>>>>>>     Serial number: 3525JRB400K54R1AFHOR
>>>>>>>     Crash sensor for front airbag: driver side:
>>>>>>>     Serial number: 3554VRB400G54RVGRPJ2
>>>>>>>     Crash sensor for front airbag: front passenger side:
>>>>>>>     Serial number: 3564VRB401E54RVGMH1E
>>>>>>> Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
>>>>>>>     Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
>>>>>>>     Component: Lenks.Modul   H04 0005
>>>>>>>     Revision: --------    Serial number: 90372OE90007Z
>>>>>>>     Coding: 0000FC
>>>>>>>     VCID: 372B218CDF4FF293828-8062
>>>>>>>     Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
>>>>>>>     Component: E221 - MFL  H08 0010
>>>>>>>     Serial number: 27 04 2015  10083731
>>>>>>> 1 Fault Found:
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>> Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb-SRI1
>>>>>>>     Part No SW: 4G8 920 934 N    HW: 4G8 920 934 N
>>>>>>>     Component: TBenRdwAccNv  H10 0104
>>>>>>>     Revision: 06001087    Serial number: 658200515596032
>>>>>>>     Coding: 138F010BAFD70008000500
>>>>>>>     ASAM Dataset: EV_RBD4K 004055
>>>>>>>     ROD: EV_RBD4K_AU57.rod
>>>>>>>     VCID: 3C213EA0E6E9D1CB6FA-8068
>>>>>>> Address 19: CAN Gateway (J533)       Labels:* None
>>>>>>>     Part No SW: 4G8 907 468 F    HW: 4G8 907 468
>>>>>>>     Component: J533--Gateway H14 0083
>>>>>>>     Revision: --------    Serial number: 00000001848233
>>>>>>>     Coding: C0ED07481C
>>>>>>>     ASAM Dataset: EV_GatewPkoUDS 001028
>>>>>>>     ROD: EV_GatewPkoUDS_001_AU57.rod
>>>>>>>     Battery Monitoring Control Module:
>>>>>>>     Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181
>>>>>>>     Component: J367-BDMHella  H03 8041
>>>>>>>     Serial number: 0999556703
>>>>>>>     Voltage stabilizer:
>>>>>>>     Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663 F
>>>>>>>     Component: J532_DCDCStab  H23 0022
>>>>>>>     Serial number: 15022600000000000080
>>>>>>> Address 1B: Active Steering (J792)       Labels: None
>>>>>>>     Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
>>>>>>>     Component: DYNAMIKLENK.  H06 0730
>>>>>>>     Revision: 52001005    Serial number: --------------
>>>>>>>     Coding: 010100
>>>>>>>     VCID: 392F27B4E95BE4E374C-806C
>>>>>>> 3 Faults Found:
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 4
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Count: 48
>>>>>>>                      Count: 1
>>>>>>>                      Hex Value: 0xEA34
>>>>>>>                      Hex Value: 0x7502
>>>>>>>                      Hex Value: 0x0000
>>>>>>>                      Hex Value: 0x5803
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 4
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Count: 137
>>>>>>>                      Count: 1
>>>>>>>                      Hex Value: 0xEA34
>>>>>>>                      Hex Value: 0x7502
>>>>>>>                      Hex Value: 0x0000
>>>>>>>                      Hex Value: 0x5803
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 3
>>>>>>>                      Fault Frequency: 6
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Count: 147
>>>>>>>                      Count: 1
>>>>>>>                      Hex Value: 0xEA34
>>>>>>>                      Hex Value: 0x7502
>>>>>>>                      Hex Value: 0x0000
>>>>>>>                      Hex Value: 0x5803
>>>>>>> Address 22: AWD (J492)       Labels: 4H0-907-163.clb
>>>>>>>     Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
>>>>>>>     Component: 4 Wheel Drive H17 0200
>>>>>>>     Serial number: 001603150001001
>>>>>>>     ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
>>>>>>>     ROD: EV_AllWheelDiffeQSPFR.rod
>>>>>>> Address 28: HVAC, Rear (E265)       Labels:* 4G0-919-158.clb
>>>>>>>     Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
>>>>>>>     Component: KLIMA FOND    H08 0112
>>>>>>>     Serial number: 14051500040390
>>>>>>>     Coding: 20
>>>>>>>     ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
>>>>>>>     ROD: EV_ClimaContrUnitRearUDS_003.rod
>>>>>>>     VCID: 3E2534A8F0F5C3DB41E-806A
>>>>>>> Address 36: Seat Mem. Drvr (J136)       Labels: None
>>>>>>>     Part No SW: 4G8 959 760     HW: 4G8 959 760
>>>>>>>     Component: MEM-FS        H03 0157
>>>>>>>     Revision: AA000000    Serial number: 00000148983509
>>>>>>>     Coding: 00581B0000006001000001010101102030303232203232
>>>>>>>     VCID: 77ABE18C9FCF3293428-8022
>>>>>>> 4 Faults Found:
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>> 01299 - Diagnostic Interface for Data Bus (J533)
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 6
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>> Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
>>>>>>>     Part No SW: 4G0 907 637 L    HW: 4G0 907 637 G
>>>>>>>     Component: SARA 6D red   H04 0056
>>>>>>>     Revision: --------    Serial number: EJ1BPA7E01K0ZS
>>>>>>>     ASAM Dataset: EV_SARA2 005012
>>>>>>>     ROD: EV_SARA2.rod
>>>>>>>     VCID: 372B218CDFCFF293828-8062
>>>>>>> Address 3C: Lane Change (J769)       Labels:| 5Q0-907-566.clb
>>>>>>>     Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
>>>>>>>     Component: SWA Master    H06 0060
>>>>>>>     Serial number: 0367666040
>>>>>>>     Coding: 040311
>>>>>>>     ASAM Dataset: EV_LaneChangAssis 001028
>>>>>>>     ROD: EV_LaneChangAssis_AU21.rod
>>>>>>>     VCID: 392F27B4E9DBE4E374C-806C
>>>>>>>     Lane change assistance control module 2:
>>>>>>>     Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
>>>>>>>     Component: SWA Slave  H06 0060
>>>>>>>     Serial number: 0367877546
>>>>>>>     Coding: 040311
>>>>>>> Address 42: Door Elect, Driver (J386)       Labels:. 4H0-959-793.clb
>>>>>>>     Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
>>>>>>>     Component: TSG FA        H04 0507
>>>>>>>     Coding: 011F56035E00628002080413
>>>>>>>     VCID: 45D75B4495A39003004-8010
>>>>>>> 6 Faults Found:
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 6
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>> Address 44: Steering Assist (J500)       Labels:| 4G0-909-144.clb
>>>>>>>     Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
>>>>>>>     Component: RCEPS         H43 0012
>>>>>>>     Revision: 00001000    Serial number: 0014713191
>>>>>>>     Coding: 011001010001
>>>>>>>     ASAM Dataset: EV_RCEPS 009013
>>>>>>>     ROD: EV_RCEPS_009.rod
>>>>>>> Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
>>>>>>>     Revision: 00002001    Serial number: 0369181352
>>>>>>>     Coding: 013A0E20A0B9B085C3300A840E0314470000000000000000000000000000
>>>>>>>     Subsystem 1 - Part No: 4G0 951 177 A
>>>>>>>     Component: Sensor, DWA  005 0002
>>>>>>>     Subsystem 2 - Part No: 1K0 951 605 C
>>>>>>>     Component: LIN BACKUP HO  H05 1501
>>>>>>>     Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
>>>>>>>     Component: J245 PS40.402  H03 0004
>>>>>>>     Serial number: 0000FST000B0TY200000
>>>>>>>     Coding: 901F02
>>>>>>>     Subsystem 4 - Part No SW: 4G0 947 135 F    HW: 4G0 947 135
>>>>>>>     Component: Dachelektroni  H10 0100
>>>>>>>     Serial number: 0000000AP00013019963
>>>>>>>     Coding: 010000
>>>>>>>     Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
>>>>>>>     Component: HSP-SG  H11 0029
>>>>>>>     Serial number: WA120839000013339252
>>>>>>>     Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
>>>>>>>     Component: GEB.F.Heckoef  H16 0811
>>>>>>>     Serial number: 93491319
>>>>>>> 10 Faults Found:
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>> 00317 - Rear Lid Control Module (J605)
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 6
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 6
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>> Address 52: Door Elect, Pass. (J387)       Labels:. 4H0-959-792.clb
>>>>>>>     Part No SW: 4G8 959 792 J    HW: 4G8 959 792 G
>>>>>>>     Component: TSG BF        H03 0507
>>>>>>>     Coding: 011F56035E00628002080402
>>>>>>>     VCID: 46D55C48A8A59B1B09E-8012
>>>>>>> 6 Faults Found:
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 6
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 3
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 73202 km
>>>>>>>                      Time Indication: 0
>>>>>>>                      Date: 2021.03.20
>>>>>>>                      Time: 16:42:54
>>>>>>> Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
>>>>>>>     Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
>>>>>>>     Component: EPB-4         H04 0015
>>>>>>>     Revision: --------    Serial number: 00000001472179
>>>>>>>     ASAM Dataset: EV_ParkiBrake 001028
>>>>>>>     ROD: EV_ParkiBrake_VW51.rod
>>>>>>>     VCID: 2D0703E42D934843E84-8078
>>>>>>> Address 55: Headlight Range (J745)       Labels:| 4H4-907-357-V2.clb
>>>>>>>     Part No SW: 4H4 907 357 E    HW: 7P6 907 357 B
>>>>>>>     Component: MxB-ECU       001 0100
>>>>>>>     Coding: 05FA0A202A1F0200
>>>>>>>     ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
>>>>>>>     ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
>>>>>>>     VCID: 34311680CEB9198BA7A-8060
>>>>>>>     Left LED Headlamp Power Output Stage 1:
>>>>>>>     Subsystem 1 - Part No SW: 7PP 941 472 J    HW: 7PP 941 472 J   Labels: 3D0-941-329.CLB
>>>>>>>     Component: LED LeiMo li.  H07 7560
>>>>>>>     Coding: E02100
>>>>>>>     Right LED Headlamp Power Output Stage 1:
>>>>>>>     Subsystem 2 - Part No SW: 7PP 941 472 J    HW: 7PP 941 472 J   Labels: 3D0-941-329.CLB
>>>>>>>     Component: LED LeiMo re.  H07 7560
>>>>>>>     Coding: E02100
>>>>>>>     Power module 1 for left matrix headlamp:
>>>>>>>     Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A   Labels: 3D0-941-329.CLB
>>>>>>>     Component: MxB LeiMo li.  H03 0031
>>>>>>>     Coding: E02100
>>>>>>>     Power module 1 for right matrix headlamp:
>>>>>>>     Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A   Labels: 3D0-941-329.CLB
>>>>>>>     Component: MxB LeiMo re.  H03 0031
>>>>>>>     Coding: E02100
>>>>>>> Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
>>>>>>>     Part No SW: 4G1 035 018     HW: 4G1 035 021
>>>>>>>     Component: MU-H-LND-EU   042 0389
>>>>>>>     Serial number: A588E0FB001111
>>>>>>>     Coding: 017563010000000013111102000A00132F000EE5F17001009F
>>>>>>>     ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
>>>>>>>     ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
>>>>>>>     VCID: 5DE793241DB3F8C3384-8008
>>>>>>>     Data carrier:
>>>>>>>     Subsystem 1 - Part No SW: V03 959 801 F    HW: -----------
>>>>>>>     Component: ECE 2015/2016  --- 0122
>>>>>>>     Serial number: --------------------
>>>>>>>     Multimedia System 1:
>>>>>>>     Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
>>>>>>>     Component: DU8 C7 SV  H63 0007
>>>>>>>     Serial number: AUZ8Z9FY801JFF
>>>>>>>     Multimedia system control head:
>>>>>>>     Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
>>>>>>>     Component: E380 BDT C7  H20 0250
>>>>>>>     Serial number: 90349OEC000PJ
>>>>>>>     Compact disc data bank:
>>>>>>>     Subsystem 4 - Part No SW: V03 959 800 EG    HW: -----------
>>>>>>>     Component: Gracenote2  --- 1012
>>>>>>> Address 62: Door, Rear Left (J388)       Labels:. 4H0-959-795.clb
>>>>>>>     Part No SW: 4G8 959 795 J    HW: 4G8 959 795 G
>>>>>>>     Component: TSG HL        H03 0507
>>>>>>>     Coding: 010F14024000628002080002
>>>>>>>     VCID: 49CF5774B9BB7463E4C-801C
>>>>>>> Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
>>>>>>>     Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
>>>>>>>     Component: RDKBERU25     H10 0820
>>>>>>>     Serial number: 10000000016373
>>>>>>>     ASAM Dataset: EV_RDKBERU25 003014
>>>>>>>     ROD: EV_RDKBERU25_AU57.rod
>>>>>>>     VCID: 2A0D08F81C7D5F7B0D6-807E
>>>>>>> Address 6C: Back-up Cam. (J928)       Labels:* None
>>>>>>>     Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
>>>>>>>     Component: TopView       H07 0330
>>>>>>>     Revision: 11001001    Serial number: 82330JF0227997
>>>>>>>     Coding: 0217000101010100000102000000
>>>>>>>     ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
>>>>>>>     ROD: EV_CamerSysteTopViewAUDI.rod
>>>>>>>     VCID: 2E0504E82095335BD1E-807A
>>>>>>> Address 6D: Trunk Elect. (----)       Labels:* Redir Fail!
>>>>>>>     Part No SW: 4G8 959 107 S    HW: 4G8 959 107 H
>>>>>>>     Component: HDSG-Modul    H14 0049
>>>>>>>     Revision: 11014001    Serial number: 131500088
>>>>>>>     Coding: 0A3305C022
>>>>>>>     ASAM Dataset: EV_HDSGAu573 001022
>>>>>>>     ROD: EV_HDSGAu571.rod
>>>>>>>     VCID: 45D75B4495239003004-8010
>>>>>>> Address 72: Door, Rear Right (J389)       Labels:. 4H0-959-795.clb
>>>>>>>     Component: TSG HR        H03 0507
>>>>>>> Address 84: Night Vision (J853)       Labels:* None
>>>>>>>     Part No SW: 4G0 907 547 A    HW: 4G0 907 547
>>>>>>>     Component: NV-ECU-Gen3   H08 0107
>>>>>>>     Serial number: 622352400201504
>>>>>>>     Coding: 401100
>>>>>>>     ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
>>>>>>>     ROD: EV_NightVisioGen3AE4AU64X.rod
>>>>>>>     VCID: 2C010EE01689414BFFA-8078
>>>>>>>     Night vision system camera:
>>>>>>>     Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
>>>>>>>     Component: NV-CAM-Gen3  H03 0006
>>>>>>>     Serial number: 623466500F1508400435
>>>>>>> Address 85: On Board Cam. (J852)       Labels:| 7P6-907-217.clb
>>>>>>>     Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
>>>>>>>     Component: DPC-SG        H27 0081
>>>>>>>     Revision: --------    Serial number: 262130025421000
>>>>>>>     Coding: 6A160000
>>>>>>>     ASAM Dataset: EV_OnBoardCamerDPC 001007
>>>>>>>     ROD: EV_OnBoardCamerDPC.rod
>>>>>>> Address 8B: Adaptive Cruise 2 (J428)       Labels:| 4H0-907-561.clb
>>>>>>>     Part No SW: 4G0 907 541 B    HW: 4G0 907 541
>>>>>>>     Coding: 7E04010101
>>>>>>>     ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
>>>>>>>     ROD: EV_AdaptCruisContr2AU57X_002.rod
>>>>>>>     VCID: 270BF1CC0F6F6213128-8072
>>>>>>> 3 Faults Found:
>>>>>>>            U1113 00 [008] - -
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 1
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 74037 km
>>>>>>>                      Date: 2021.04.09
>>>>>>>                      Time: 18:44:19
>>>>>>>                      Control Module temperature: 34 °C
>>>>>>>                      Velocity_vehicle_reference: -0.00 m/s
>>>>>>>            U1113 00 [008] - -
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 6
>>>>>>>                      Fault Frequency: 1
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 74037 km
>>>>>>>                      Date: 2021.04.09
>>>>>>>                      Time: 18:44:19
>>>>>>>            U1112 00 [008] - -
>>>>>>>               Freeze Frame:
>>>>>>>                      Fault Priority: 2
>>>>>>>                      Fault Frequency: 1
>>>>>>>                      Reset counter: 140
>>>>>>>                      Mileage: 74037 km
>>>>>>>                      Date: 2021.04.09
>>>>>>>                      Time: 18:45:46
>>>>>>>                      Voltage terminal 15: 12.115 V
>>>>>>> Address 8E: Image Processing (J851)       Labels:| 4H0-907-107-V2.clb
>>>>>>>     Part No SW: 4H0 907 107 H    HW: 4H0 907 107
>>>>>>>     Component: BV-SG         H33 0090
>>>>>>>     Serial number: 005000621005157
>>>>>>>     Coding: 03C0BB1B1111
>>>>>>>     ASAM Dataset: EV_BC7 001001
>>>>>>>     ROD: EV_BC7.rod
>>>>>>> Address 8F: Pretens. Frt Left (J854)       Labels: 4H0-980-94x-RGS.clb
>>>>>>>     Part No SW: 4H0 980 945 B    HW: 4H0 980 945 C
>>>>>>>     Component: RGS-VL        H13 0080
>>>>>>>     Coding: 0066E608031F0376070308014240C0010000
>>>>>>>     ASAM Dataset: EV_RGS_L 002004
>>>>>>>     ROD: EV_RGS_L.rod
>>>>>>>     VCID: 313F1F9431AB2CA3CCC-8064
>>>>>>> Address 90: Pretens. Frt Right (J855)       Labels: 4H0-980-94x-RGS.clb
>>>>>>>     Part No SW: 4H0 980 946 B    HW: 4H0 980 946 C
>>>>>>>     Component: RGS-VR        H13 0080
>>>>>>>     ASAM Dataset: EV_RGS_R 002004
>>>>>>>     ROD: EV_RGS_R.rod
>>>>>>>     VCID: 323D109834AD17BBB56-8066
>>>>>>> Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
>>>>>>>     Part No SW: 4H0 907 145 B    HW: 4H0 907 145
>>>>>>>     Component: AEM - LEAR    H09 0008
>>>>>>>     Revision: 00001001    Serial number: 97811005156702
>>>>>>>     ASAM Dataset: EV_AEMLearAU64X 002016
>>>>>>>     ROD: EV_AEMLearAU64X.rod
>>>>>>> End(Elapsed Time: 02:50, VBatt start/end: 12.0V/12.0V. VIgn 12.0V, udsna)--
Are you sure this engine has a traditional wastegate?
For "boost", look at these:
IDE00190 --Charge air pressure: specified value,LINEAR,hPa, [Boost pressure commanded value]
IDE00191 -- Charge air pressure: actual value,LINEAR,hPa, [Boost pressure]
As for wasetgate actuator, I'm not finding the the traditional one(s). Try:
IDE04002-ENG167462 -- Charge air pressure control
IDE05444 -- Air filling: specified value,LINEAR,%, [Air_charge_commanded_value]
PatriceBE
Europe
It has waste gates, i don’t understand exactly what’s the difference between traditional and not traditional waste gates, I just know exactly they are being logged by Tuner tools, such as HP tuners, DS1 etc...
I’ve already tried to log charge air pressure control, which shows me in pressure, but i really can’t understand what it stands for?!
also have tried air filling in %, which also is unrecognizable for me, since it shows 300+% when WOT and it should not be specified value i guess, but actual WG position closed or opened.
Well, it might be in there somewhere, but I haven't found it either.
