2012 VW T5.1 2.0Tdi EGR adaptation
Sunset
C?ID=433028
Hi, I'm after some help with running the adaptation for a new EGR I've just fitted. I can't find it anywhere in VCDS. I'm running version 21.3.0.
Trowbridge, UK
I suspect that you'll be asked for a full unedited VCDS Auto-Scan - so might be an idea to post one now (open the .txt file that VCDS saves using Notepad, select all and copy, then paste it here using the </> icon in the forum editor).
Sunset
C?ID=433028
Thanks Dave.
Sunset
C?ID=433028
Thursday,22,April,2021,16:42:04:07014
VIN: WV1ZZZ7HZCH124374   License Plate: DS12WUK
Mileage: 200700km-124709mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 09 10 15 17 19 25 56 0B
VIN: WV1ZZZ7HZCH124374   Mileage: 200700km-124709miles
Address 01: Engine (J623-CAAA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CB    HW: 03L 907 309 K
   Component: R4 2,0L EDC   X43 9116
   Revision: 26X43---    Serial number: 00000000000000
   Coding: 01114010232400080000
   Shop #: WSC 26214 051 00000
   ASAM Dataset: EV_ECM20TDI01103L906022CB 002012
   ROD: EV_ECM20TDI01103L906022CB_002.rod
   VCID: 678BB184FFEC62532E9-8032
4900 - EGR Sensor 1
          P0405 00 [036] - Signal too Low
                    Mileage: 200707 km
                    Date: 2021.04.22
                    Time: 15:42:04
                    Engine RPM: 0.00 /min
                    Coolant temperature: 44 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 11.800 V
                    Air mass: actual value (mg/stroke): 0.0 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                    EGR Solen.val.: actual value: 116.19 %
                    EGR valve: offset closed: -2.06 %
                    Actuator for high pressure EGR: status-Bits 0-7: 0
                    Actuator for high pressure EGR: status-Bits 0-7: 55
                    High press EGR actuator: actual unconditioned volt val: 14.6 mV
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 J    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0109
   Revision: 00H43001
   Coding: 508724AD89A60A9924A59178A96210
   Shop #: WSC 02736 790 49152
   VCID: 392F27FCD95824A388D-806C
   Part No SW: 7H0 937 087 H    HW: 7H0 937 087
   Component: BCM T5GP H+4  H47 0254
   Revision: BO047001    Serial number: 0429 086121343
   Coding: A0A0303A0E612431802848102C2B8C500080430F60060000300000000000
   Shop #: WSC 02736 790 12345
   Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3311
   Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3311
   Subsystem 4 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Component: E221__MFL-TAS  H07 0013
   Serial number: 0144524
   Coding: 820000
03301 - Response Closing Status of Drivers Door
                    Reset counter: 238
                    Mileage: 200706 km
                    Date: 2015.09.13
                    Time: 11:54:31
03302 - Response Closing Status of Passenger's Door
                    Reset counter: 238
                    Mileage: 200706 km
                    Date: 2015.09.13
                    Time: 11:54:31
03303 - Response Closing Status of Rear Left Door
                    Fault Status: 01101000
                    Fault Frequency: 9
                    Reset counter: 197
                    Mileage: 200310 km
                    Date: 2015.09.07
                    Time: 17:20:33
03442 - Return Message Closing Status of Rear Lid
                    Reset counter: 238
                    Mileage: 200706 km
                    Date: 2015.09.13
                    Time: 11:54:31
   Part No SW: 7E0 919 475 D    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361206900783
   Coding: 108001
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_VW75XParkAssis4K A01006
   ROD: EV_VW75XParkAssis4K_A01.rod
   VCID: 333315D4FBB4DEF3421-8066
   Component: VW10Airbag009 H07 0013
   Revision: --------    Serial number: 003HL00B6KUM
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750_VN75.rod
   VCID: 35372BCCF5C0C0C36C5-8060
   Part No SW: 7E0 920 960 E    HW: 7E0 920 960 E
   Component: KOMBI         H04 0305
   Coding: 440A01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 2B030DB4238486330A1-807E
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H47 0254
   Revision: BO047001
   Coding: 042300
   VCID: 70B9DAD8CAA2A5EB7F3-8024
                    Fault Frequency: 148
                    Reset counter: 198
                    Mileage: 200310 km
                    Date: 2015.09.07
                    Time: 13:55:58
   Component: IMMO          H04 0305
   VCID: 6A8DC8B0ECFE5F3B317-803E
Address 56: Radio
End----(Elapsed Time: 01:37, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
That ECU has a a Basic Setting called:
IDE00785 -- Adaptation of EGR vacuum regulator solenoid valve
Sunset
C?ID=433028
Hi, I've run that adaptation for the solenoid valve but I can't find one for the EGR itself. I've seen on youtube videos where people are using older version of VCDS going into (measure blocks 08) to run EGR adaptations but I'm is grayed out for some reason.
Trowbridge, UK
but is that on a diferent engine ECU? Not all VAG engine ECUs support the same featues, the ECU is more important than the VCDS version - Ross-Tech do not knowingly remove features from later VCDS versions.
Sunset
C?ID=433028
Ok so it's greyed out because it's not compatible with this ECU. I understand thanks.
How do I run the adaptations for the EGR then? Or is it just the solenoid you need to adapt with this ECU?
Sunset
C?ID=433028
Or is it that my new EGR value is faulty? 🤔
Please see:
Well, the "EGR Sensor 1 - Signal too Low" isn't exactly encouraging.
What is the source of this EGR valve? Would it happen to be a Chinese Replacement Auto Part? ;)
J0N
C?ID=395985
I’m having the same issue with a 2012 Sharan but I can’t even run the IDE00785 Adaptation of EGR vacuum regulator solenoid valve. I get ‘ERROR: Service not supported in active session’. Could this be because the EGR valve is non genuine?
J0N
C?ID=395985
Saturday,24,April,2021,10:12:22:28516
VIN: WVWZZZ7NZDV014006   License Plate: EK62 GSU
Mileage: 96970km-60254mi   Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 2E 42 44 46 4C 52 53 56 61
          62 72 77
VIN: WVWZZZ7NZDV014006   Mileage: 96970km-60254miles
   Part No SW: 03L 906 018 HH    HW: 03L 907 309 Q
   Component: R4 2.0l TDI   H28 9980
   Revision: 44H28---    Serial number:
   Coding: 0019001A042501080000
   Shop #: WSC 00722 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018HH 003015
   ROD: EV_ECM20TDI01103L906018H_VW36.rod
   VCID: 77AA10349F4BB2F3BE9-8022
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 R    HW: 7N0 614 109 R
   Component: J104   C3 450M VDC8 0023
   Revision: --H07---    Serial number: 00000006162285
   Coding: 0019991
   Shop #: WSC 00020 790 00000
   VCID: 3C20CF18EA6D51AB93B-8068
   Part No SW: 7N0 907 044 E    HW: 7N0 907 044 E
   Component: Clima-Sharan  H01 0202
   Revision: 00001K03
   Coding: 0210004449
   Shop #: WSC 00020 999 00000
   VCID: 323CE12034A997DB497-8066
   Part No SW: 5K0 937 084 H    HW: 5K0 937 084 H
   Component: BCM PQ35 B    021 0068
   Revision: BA021001
   Coding: 40180A3B8125F1C0408800C1340000E443511308426D29626480872000C1
   Shop #: WSC 00020 790 12345
   VCID: 372AD034DF4B72F37E9-8062
   Subsystem 1 - Part No SW: 7N2 955 119 A    HW: 7N2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    120608  31  0032
   Serial number:         120706150707
   Coding: 004DBD
   Component: RLFS  024 0042
   Serial number: Y12M09D10H05M26S14S4
   Coding: BB2802
   Subsystem 3 - Part No: 7N0 951 171 A
   Component: DWA-Sensor 00  002 0206
                    Reset counter: 240
                    Mileage: 96869 km
                    Date: 2015.09.13
                    Time: 08:51:51
                    Voltage: 14.70 V
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 7N0 919 475 A    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0012
   Revision: --------    Serial number: 28261225601143
   Coding: 108001
   ASAM Dataset: EV_EPHVA18VW4280000 001005
   ROD: EV_EPHVA18VW4280000.rod
   VCID: 392ED60CE9DF648388D-806C
   Part No SW: 7N0 959 655 C    HW: 7N0 959 655 C
   Component: VW10Airbag00M H10 0014
   Serial number: 003LGPHFC6H3
   Coding: 00304D
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 3FDAB814F7FB4AB3B69-806A
   Serial number: 3493ETS603A40AC16DD$
   Serial number: 3503ETS605A0AAA169DX
   Serial number: 3513ETS60005BAC16DDV
   Serial number: 3523ETS60A7DFA9169DB
   Serial number: 35540TS60CC70A8169DT
   Part No SW: 5K0 953 521 BD    HW: 5K0 953 569 B
   Revision: FF010041    Serial number: 20120902100511
   Coding: 1082240000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 6FBA2854E71BFA33669-803A
   Component: E221__MFL-TK6  H07 0022
   Coding: E20000
   Part No SW: 7N0 920 970 G    HW: 7N0 920 970 G
   Component: KOMBI         H05 0705
   Coding: 440F01
   VCID: 372AD034DFCB72F37E9-8062
   Part No: 7N0 963 271 E
   Component: Zuheizer        051 2940
   Revision: 00051000    Serial number: 09024297000000
   Coding: 0000041
   VCID: 3634DD30D4418BFB65F-8062
   Part No SW: 7N0 907 530 AC    HW: 7N0 907 530 AC
   Component: J533  Gateway H48 1633
   Revision:   H48       Serial number: 210812F2000042
   Coding: 468003
   VCID: 71BE2E2CF1AFECC370D-8024
   Component: IMMO          H05 0705
   VCID: 6A8C3940DCF91F1B317-803E
   Revision: A1001003    Serial number: 7663369657
   Coding: 010100
   VCID: 2A0CF9401CF9DF1BF17-807E
   Part No SW: 7N0 959 793 F    HW: 7N0 959 793 F
   Component: TSG FA        H02 0553
   Revision:             Serial number: 0000036942249
   Coding: 011006208001411011
   VCID: 45D6AAFC95A71063FC5-8010
   Part No: 7N0 909 144 P
   Component: EPS_ZFLS Kl. 272    3305
   Revision: 00H21000
   VCID: 40D8BBE88685354BCF3-8014
   Part No SW: 7N0 959 792 F    HW: 7N0 959 792 F
   Component: TSG BF        H02 0553
   Revision:             Serial number: 0000035912829
   Coding: 011004208001411011
   VCID: 44D0B7F89E9D296BEBB-8010
   Revision:   H19       Serial number: 00000000419387
   Coding: 0024167
   Part No SW: 5M0 035 186 L    HW: 5M0 035 186 L
   Component: Radio RCD310  004 0119
   Revision: 01000001    Serial number: VWZ1Z2M2183934
   Coding: 0100040004000D
   VCID: 3536DA3CC54780E36C5-8060
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AC
   Component: Batt.regelung H48 1633
   Coding: 030F1859
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900195352
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 G    HW: 7N0 959 794 G
   Component: TSG HL        H03 0553
   Revision:             Serial number: 0000038752041
   Coding: 010004200001411001
   VCID: 47CAA0F4AFAB02730E9-8012
   Component: TSG HR        H03 0553
   Revision:             Serial number: 0000038748979
   Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
   Revision: 1B001001    Serial number: 00007663365486
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002_VW25.rod
End----------(Elapsed Time: 01:39, VBatt start/end: 11.8V/12.1V)-----------
Address 09: DTCs cleared
J0N
C?ID=395985
I still have the greyed out button on a 2014 Golf GTD which is still fitted with its original factory EGR...
Saturday,24,April,2021,12:36:50:28516
VIN: WVWZZZAUZEW295673   License Plate: HY14 NZA
Mileage: 104078km-64671mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A9
VIN: WVWZZZAUZEW295673   Mileage: 104078km-64671miles
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EP    HW: 04L 907 309 A
   Component: R4 2,0L EDC   H22 7539
   Revision: 81H22---
   Coding: 01190012034505082000
   ASAM Dataset: EV_ECM20TDI01104L906021EP 002008
   ROD: EV_ECM20TDI01104L906021AE.rod
18111 - Oxygen (Lambda) Sensor B1 S1
          P2237 00 [096] - Pump Current Open Circuit
4986 - Cylinder 3 Glow Plug Circuit (Q12)
          P0673 00 [237] - Electrical Fault
                    Mileage: 103953 km
                    Date: 2021.04.20
                    Time: 08:24:47
                    Engine RPM: 928.00 /min
                    Normed load value: 38.0 %
                    Coolant temperature: 12 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 11.820 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 146
                    Electric auxiliary heater: relay activation-Bits 0-7: 0
                    Pre-glow time: 2100 ms
                    Glow status-Bits 0-7: 0
                    Glow cycles above temperature threshold-Bits 0-7: 0
                    Glow cycles above temperature threshold-Bits 0-7: 11
                    Glow cycles below temperature threshold-Bits 0-7: 2
                    Glow cycles below temperature threshold-Bits 0-7: 175
                    Outside temperature sensor 1: B1: raw value: 11.0 °C
Readiness: 1 1 0 0 0
   Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
   Component: ESC           H31 0472
   Revision: 00000000    Serial number: 6024400000010F
   Coding: 01FA8AA134290971037D060741C62980512C90C0608294F5F4605078C009
   VCID: 074A60F4EFABC273CE9-8052
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 00120104202100011005000000101000
   VCID: 66944D70C8E13B7B15F-8032
   Air quality sensor:
1048834 - Functional Limitation due to Energy Management
          B10CD 00 [008] - -
          [PTC-Reduzierung durch BCM]
                    Fault Frequency: 13
                    Reset counter: 95
                    Mileage: 101625 km
                    Date: 2021.01.30
                    Time: 13:59:06
                    Voltage terminal 30: 11.1 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: No enabling
                    Auxiliary heater: in stages-Act.val.: 1
                    Auxiliary heater: in stages-Target value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
          [PTC-Reduzierung durch MSG]
                    Reset counter: 118
                    Mileage: 96916 km
                    Date: 2020.08.25
                    Time: 05:31:05
                    Voltage terminal 30: 13.5 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011403200696
   Coding: 03000A46C20122FB0B244080B11C07281000000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   VCID: 7BA20C04A3639693DA1-802E
   Component: WWS    140131  042 0551
   Serial number:         140203063702
   Serial number: Y14M02D10H07M02S12S7
   Coding: 00A8DD
   Serial number: 000000000ZY1401622GJ
   Serial number: 00000000000058603491
          B1263 01 [008] - Electrical Failure
                    Fault Frequency: 76
                    Reset counter: 113
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 95
                    Mileage: 89905 km
                    Date: 2020.01.05
                    Time: 06:44:05
   Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0142
   Revision: --------    Serial number: 39331403700142
   Coding: 0071051001
   VCID: 3E24C510F0F143BBBDF-806A
   Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
   Component: ACC Bosch MQB H04 0200
   Serial number: 20011477030073
   Coding: 00000300FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001014
   VCID: 3634DD30D8C18BFB65F-8062
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR03B4TY
   VCID: 7F5AF814B77B8AB3F69-802A
   Left seat belt tensioner:
   Serial number: 34169661C31011450027
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169662C31011450013
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 003 101 14
   Serial number: 3576700000032874DE0-
   Subsystem 4 - Part No SW: -----------    HW: 480 002 901 14
   Serial number: 3586700000066688BE02
   Subsystem 5 - Part No SW: -----------    HW: 480 400 302 14
   Serial number: 3516502BD13013F46171
   Subsystem 6 - Part No SW: -----------    HW: 480 400 302 14
   Serial number: 3526502C112AB1B413E8
   Subsystem 7 - Part No SW: -----------    HW: 480 402 801 14
   Serial number: 3556502A312AB1B212E8
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 04021404400893
   Coding: 0C00
   Part No SW: 5G6 920 970 A    HW: 5G6 920 970 A
   Component: KOMBI         314 2210
   Coding: 27AD01002F80260001886A01040000
   VCID: 2E04F5502091B33B2DF-807A
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001535919
   Coding: 030100040B087300EF00027E080F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_010.rod
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H06 0038
   Serial number: 29130000553530064043
   Coding: 2CFFFF
   Serial number: 6133142503
8526355 - Voltage Drop in Generator Leads too large
          P30DE 00 [008] - -
                    Fault Frequency: 14
                    Reset counter: 85
                    Mileage: 103657 km
                    Date: 2021.04.09
                    Time: 05:10:16
                    Terminal 30 power supply: 13.8 V
                    Terminal 15: On
   Serial number: 27011406071065
   Coding: 003F0220D001048100001000
   VCID: 40D8BBE88A05354BCF3-8014
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3536DA3CC5C780E36C5-8060
   Serial number: 25011401100969
   Coding: 003F0020DE01048100801000
65558 - Heated Exterior Mirror
          B11F8 14 [009] - Open or Short to Ground
                    Reset counter: 173
                    Mileage: 101377 km
                    Date: 2021.01.21
                    Time: 15:37:41
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029E01000B000200
   VCID: 3D26C21CFDF758A3A45-8068
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
   Part No SW: 5G0 035 874     HW: 5G0 035 874
   Component: MU-S-ND-ER    040 0430
   Serial number: V7F02801141155
   Coding: 02730001FF00000021111201002800001F0202060100010045
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 678A4074CFEB22732E9-8032
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H51 0022
   Serial number: VWZ8Z9PJ903G4R
   Subsystem 2 - Part No SW: 5G0 919 866 F    HW: -----------
   Component:  ECE 2014  --- 0036
   Component: SAS-GEN 2     H06 0013
   Serial number: 140110201282
   VCID: 6B823C44D30306134A1-803E
End----------(Elapsed Time: 01:23, VBatt start/end: 12.0V/12.0V)-----------
Address 01: DTCs cleared
Address 08: DTCs cleared
Address 19: DTCs cleared
Address 52: DTCs cleared
Which button is grayed out? I'll note that car has a UDS ECU...
J0N
C?ID=395985
[Meas. Blocks - 08] is greyed out, this is the first time I’ve come across the different ECU types. If this is the case, how do I go about an EGR adaptation.
I’m pretty new to this but I’m trying to get a bit of knowledge and experience because at the moment I have a £300 code reader.
Please see post #10 in this thread, the one right above your first post.
I don't think you can do an EGR adaptation via Measuring Blocks in any ECU. ;)
Your ECU should have the following Basic Settings:
IDE05936 -- Low-pressure EGR differential pressure sensor adaptation
IDE05937 -- Low pressure EGR valve adaptation
But why do you want to do this? I see no EGR issues apparent in your scan.
J0N
C?ID=395985
Thanks for the information, I appreciate it.
I’ve just messaged the friend with the 2012 VW Sharan who is having the issue, the following was his reply;
“The codes have been cleared loads of times, in hope of the EGR finding its feet and working as it should.
Original issue was 'egr open circuit', removed part found cooler side had leaked into egr side. Valve well knackered.
Bought an NRF replacement from auto spares.
Fitted that, started with really poor fuel economy (expected a bit of a dip), but over the next couple days, started loosing power.
EML came on and limp mode engaged, read code, 'turbo under boost', removed all air inlet and turbo checked float in impeller, all okay, no splits in hose etc..
Now suffering with lack of power, no torque at all and the occasion jump into limp mode due to the 'turbo under boost' code”.
I have to admit that I’m not familiar with diesels and I was hoping that an EGR adaptation might solve the issue?
I'm not familiar with "NRF", but the results people have had with aftermarket EGR parts have been generally poor.
J0N
C?ID=395985
Ok. Thanks for your help Uwe, I appreciate it.
