Audi A3 needle sweep
SmittyS
South Africa
Hi
I currently have an audi a3 2006 2.0T. Would RossTech vcds's be able to activate the needle sweep on this car?
Kind regards
Llewellyn
Bruce
Near Philadelphia, PA, USA
Please see this page in our Wiki: Audi A3/S3 & A3 Cabriolet (8P) In particular, please see the "small" list of Common Modifications & Tweaks
I do not see anything that indicates your instrument cluster supports needle sweep. That said, there may be others here who know the platform better than I and who can comment further.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Hi
Kind regards
Llewellyn
It is not possible just like that , some software modification needs to be done and will support Lap Timer and Needles sweep. This means it require different tool to do this .
Jetta 97
C?ID=81680
You can go and try , go to 17 -Instruments to Adaptation,Ch36 and see if you can change value form 0 to 1 . If you can SAVE value to 1 , then you can activated it.
Forgot to mention above , Lap timer in not support in all clusters.
My guess is that the cluster in this car does not support that.
Here you go 2011 A3 :
OK, but a 2011 cluster isn't the same as a 2006 cluster. 2011 is "Mk.6" generation, and probably UDS, while 2006 is very much still Mk.5.
Jetta 97
C?ID=81680
Audi cluster is very similar from 2006-2009 Red Display and 2009 and up with White Display ,I install many While LCD to older 2006-2009 cars and they share almost same technology , Only one that does not support tweek, will be early 2003-2006 with fujitsu MCU.
