Audi TTS 2009 2.0 TFSI - cranks but won't start
tekguild
Oakland, CA, USA
C?ID=417434
Hello all! New(ish) user here in need of some guidance/expertise. Following the JPPSG:
1. I could not find a PR code sticker anywhere near the spare tire well.
2. Modifications:
• Replaced the RNS-E stereo with an aftermarket Pioneer and, in the process, removed all the other hardware other than the bluetooth module and Bose amplifier (Sirius module, CD changer, etc)
• New AGM Battery less than a year old
3. Complete scan below
4. I found a DSG fluid leak due to the bolt not being tight. I had DSG service in January of 2018 so my guess is the bolt shook loose? Replaced fuel filter, spark plugs and ignition coils (NGK 1675 plugs, these coils: https://www.ecstuning.com/b-nfis-original-equipment-parts/ignition-coil-priced-each/06e905115e~brp/ and this filter: https://www.ecstuning.com/b-hengst-parts/fuel-filter/1k0201051k~hen/ ) and fixed/replaced the ignition coil harness as all of the connector tabs were broken and, after opening up the plastic harness raceway, discovered a previous repair that was shoddy, as well as a few wires with nicks/cuts and brittleness. I cut off the old wiring near the right side of the plastic raceway and rewired everything with equal or higher gauge wire, using the same 'layout' as the original. The first time I started the engine after doing this work, it started fine, but had a misfire in cylinder 3. I pulled the spark plug and coil, cleaned them off, reinserted and tried again - it would crank, but not start. I got a couple codes: P1355 - Cylinder 1 open circuit, P1602 - Power Supply terminal 30 voltage too low and 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 . I went back and resoldered all the connections, then tried again. It would again crank, but not start. The open circuit and power supply faults went away, but the 01826 error remains as do 01206 - Signal for Duration of Ignition Off Time, 01316 - ABS Control Module, 00778 - Steering Angle Sensor (G85) and other expected ones (due to the removal of the original stereo/nav system). You can see them in the scan.
I have tried swapping out the spark plugs for the old ones, coils for the old ones (these, which I got from a friend when I had a previous misfire code and, yes, I do realize that red tops make no difference: https://smile.amazon.com/Bravex-Professional-Racing-Replaces-06E905115E/dp/B07G4CFR5Z/ref=sr_1_7?crid=399DB8567MB9M&dchild=1&keywords=bravex+ignition+coils&qid=1618964408&sprefix=bravex+,aps,226&sr=8-7), cleaning the plugs and coils, everything torqued down to the proper specs. I checked the battery (DMM test says 12.96V or thereabouts. I use a charger/maintainer to keep it fresh. VCDS says 12.2+V. Could it be a bad battery?).
I've Googled this to death and can't tell what to do next. Get a new battery? New OEM coils? Something else? I've run a couple injector, fuel pressure, etc. tests with VCDS, but I don't see anything amiss - but I may be missing something! I'm usually very technically inclined and have fixed my car and friends cars fairly easily in the past. This is the first issue that's got me stumped! All maintenance is done on schedule and the car is kept immaculately clean. I've looked through the engine bay for anything amiss, made sure all connections were solid, all belts/hoses, etc. were in great condition. The car ran absolutely fine prior to this.
5. I've already discussed the non-OEM parts in #2 and #4
6. The cranks but won't start issue is what I'm here to try to solve!
7. Yes and yes. Pulled every fuse in the drivers side compartment, checked it and reinserted. Same for the engine bay fuse compartment. Battery connections are solid - the connectors are spotless and always have been.
I understand the 'air/fuel/compression' requirements but don't know where to go from here - I'm hoping someone can get me pointed in the right direction.
The VCDS Scan:
Tuesday,20,April,2021,11:34:39:38431
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 21.3.0.0 (x64)  HEX-V2 CB: 0.4543.4
VIN: TRUUF38J091024682   License Plate:
Mileage: 155290km-96492mi   Repair Order:
Chassis Type: 8J (1K0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 22 25 42 44 46 47 52 55 56
          65 77
VIN: TRUUF38J091024682   Mileage: 155290km-96492miles
56-Radio -- Status: Not registered 1011
Address 01: Engine (CDM)       Labels:. 06F-907-115-CDL.clb
   Part No SW: 8J0 907 115 R    HW: 8J0 907 115
   Revision: 5BH16---    Serial number: AUX7Z0H9FNU0JQ
   Coding: 0113010A1C0F0160
   Shop #: WSC 01236 785 00200
   VCID: 3B2333739F6CC1239A1-806F
Readiness: 0110 0101
Address 02: Auto Trans        Labels:
   VCID: 55F785CB1C0837538C5-FFFF
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
   Part No SW: 8J0 614 517 A    HW: 8J0 614 517 A
   Component: ESP MK60E1          0020
   Revision: 00H60001
   Coding: 0618294
   VCID: 2B0303336F0C51A30A1-807F
                    Reset counter: 250
                    Mileage: 155290 km
                    Date: 2021.04.13
                    Time: 22:25:12
                    Count: 128
                    Count: 8517
                    Count: 297
                    Count: 44288
   Part No SW: 8J0 820 043 AJ    HW: 8J0 820 043 AJ
   Component: J255  Klima 1 Zone  0080
   Revision: 00H08006    Serial number: 00000001117655
   Coding: 1572900
   VCID: 6E85CA279C9E648B6DF-803B
                    Fault Status: 01101000
                    Reset counter: 250
                    Mileage: 155290 km
                    Date: 2021.04.13
                    Time: 22:31:00
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 P    HW: 8P0 907 279 P
   Component: Bordnetz-SG     H54 2903
   Revision: 00H54000    Serial number: 00000009119237
   Coding: F1061E82C0141C80CF18000A1800000000284E075B260802000000000000
   VCID: 4ACD66B7C0B668AB117-801F
   Subsystem 1 - Part No: 8J1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer AU354   H07 0070
   Coding: 00064784
   Shop #: WSC 01236
   Coding: 00149804
   Shop #: WSC 01236
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 F    HW: 8P0 919 475
   Component: PARKHILFE 4K  H06 0102
   Revision: 11001001    Serial number: 52340831104658
   Coding: 00010B
   Shop #: WSC 01236 758 00200
   VCID: 41DF419BF180ABF3C0D-8015
Address 14: Susp. Elect.        Labels: 8P0-907-376.lbl
   Part No SW: 8J0 910 376 B    HW: 8J0 907 376 B
   Component: J250 Raddaempfung   0050
   Revision: --H18---    Serial number: 190DPH 8267420
   Coding: 0000032
   VCID: 2E050A275C1E248B2DF-807B
                    Fault Status: 11101101
                    Reset counter: 250
                    Mileage: 155290 km
                    Date: 2021.04.19
                    Time: 14:30:06
                    Voltage: 11.64 V
                    Voltage: 4.99 V
Address 15: Airbags        Labels: 8J0-959-655.lbl
   Part No SW: 8J0 959 655     HW: 8J0 959 655
   Component: -E Airbag 9.43  H02 0020
   Revision: 93H02002    Serial number: 0036K003C9Z2
   Coding: 0011589
   VCID: 79AFE97BD5D03333C8D-802D
   Subsystem 1 - Part No: 8J0 910 339 A
   Component: BF-Gewichtsens. H02 0030
   Subsystem 2 - Serial number: 02FZM
   Subsystem 3 - Serial number: 0001.01.0000H0200000000000ˇÜ63
   Subsystem 4 - Serial number: 000000ˇÜ6332DRB4081D9525QˇÜ63
   Subsystem 5 - Serial number: D9525QˇÜ6342DRB4081C0823IˇÜ63
   Subsystem 6 - Serial number: C0823IˇÜ63747RB404917C5F-ˇÜ63
   Subsystem 7 - Serial number: 17C5F-ˇÜ63847RB4047ED12D ˇ
   Subsystem 8 - Serial number: ED12D ˇ
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0014141
   VCID: 41DF419BFD80ABF3C0D-8015
   Component: E0221           H06 0030
01301 - Control Module for Voice Recognition (J507)
Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
   Part No SW: 8J0 920 990 A    HW: 8J0 920 990 A
   Component: KOMBIINSTR. VDO H14 0330
   Revision: D0H14006    Serial number: 2249H006000682
   Coding: 0081288
   Shop #: WSC 26131 067 57207
   VCID: 3039145F462A327B3F3-8065
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533__Gateway   H16 0210
   Revision:   H16       Serial number: 3400K08A0280AF
   Coding: EDAB1F07100402004100
   VCID: 372B2F43A344E5437E9-8063
                    Reset counter: 34
                    Mileage: 155290 km
                    Date: 2021.04.13
                    Time: 00:41:05
02649 - Digital Radio Tuner
                    Reset counter: 34
                    Mileage: 155290 km
                    Date: 2021.04.13
                    Time: 00:41:05
01304 - Radio
                    Fault Frequency: 24
                    Reset counter: 34
                    Mileage: 155290 km
                    Date: 2021.04.13
                    Time: 00:50:36
                    Reset counter: 250
                    Mileage: 155290 km
                    Date: 2021.04.13
                    Time: 05:49:45
                    Reset counter: 250
                    Mileage: 155290 km
                    Date: 2021.04.18
                    Time: 21:27:38
   Part No SW: 0BR 907 554 A    HW: 0BR 907 554 A
   Component: Haldex 4Motion      3016
   Coding: 0000005
   VCID: 43D34B93E79CB9E3D21-8017
   Revision: D0H14006    Serial number: AUX7Z0H9FNU0JQ
   Part No SW: 8J8 959 801 E    HW: 8J8 959 801 E
   Component: Tuer-SG         H03 0080
   Coding: 0001149
   VCID: 3FDB47638B74DD03B69-806B
   Part No: 8J1 909 143 C
   Component: EPS_ZFLS Kl.167 H08 1903
Address 46: Central Conv.        Labels:. 8J0-959-433.lbl
   Part No: 8J0 959 433 C
   Component:    KSG          H11 0080
   Coding: 1B90328201382D290F0FC88A0477
   VCID: 36352247A44E1C4B65F-8063
Address 47: Sound System        Labels: 8J0-035-223.lbl
   Part No SW: 8J0 035 223 D    HW: 8J0 035 223 D
   Component: J525 Amp High   H04 0160
   Revision: PROD_01     Serial number: 00000000001270
   Coding: 0246316
   VCID: 2517F50B09E867D3DC5-8071
                    Reset counter: 250
                    Mileage: 155290 km
                    Date: 2021.04.18
                    Time: 21:30:45
   Part No SW: 8J8 959 802 E    HW: 8J8 959 802 E
   Coding: 0001148
   VCID: 40D9449FF68AA2FBCF3-8015
00940 - Mirror Adjust Motor; Passenger Side (V150)
00110 - Right Mirror Turn Signal Lamp (L132)
   Part No: 8P0 907 357 H
   Coding: 0000011
Address 56: Radio
Address 65: Tire Pressure        Labels: 8J0-907-273.lbl
   Part No SW: 8J0 907 273 A    HW: 8J0 907 273 A
   Component: J502-RDK        H03 0370
   Revision: --H03-H0    Serial number: 13137782110082
   Coding: 0860021
   VCID: 2F3B17235B142D83269-807B
Address 77: Telephone
End----(Elapsed Time: 01:26, VBatt start/end: 11.7V/11.6V. VIgn 11.7V)-----
Additional VCDS Data
Engine Codes from April 13th - post fuel filter install, new wiring and new plugs/coils but BEFORE resoldering/checking wiring.
Tuesday,13,April,2021,11:39:10:38431
VCDS Version 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
VIN: TRUUF38J091024682   License Plate: TROPOS
                Address 01: Engine       Labels: 06F-907-115-CDL.clb
Control Module Part Number: 8J0 907 115 R    HW: 8J0 907 115
  Component and/or Version: 2.0l R4/4V TFSI     0010
           Software Coding: 0113010A1C0F0160
            Work Shop Code: WSC 01236 785 00200
                      VCID: 3B2333739F6CC123660-806F
004949 - Cylinder 1 Ignition Circuit
               P1355 - 004 - Open Circuit - Intermittent
                    Fault Status: 00110100
                    Mileage: 155289 km
                    Date: 2021.04.12
                    Time: 19:27:56
                    RPM: 249 /min
                    Load: 65.9 %
                    Temperature: 35.0∞C
                    Temperature: 24.0∞C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 10.287 V
                    Temperature: -40.0∞C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Tuesday,13,April,2021,11:40:14:38431
Control Module Part Number: 8J0 614 517 A    HW: 8J0 614 517 A
  Component and/or Version: ESP MK60E1          0020
           Software Coding: 0618294
                      VCID: 2B0303336F0C51A3F60-807F
                    Reset counter: 250
                    Mileage: 155290 km
                    Date: 2021.04.13
                    Time: 00:01:10
                    Count: 192
                    Count: 9029
                    Count: 297
                    Count: 41984
Tuesday,20,April,2021,10:52:43:38431
                Address 01: Engine  (8J0 907 115 R)
10:52:10
  0 /min   Engine Speed (G28)
  0   Misfire Counter
  1.00   Lambda Control Bank 1 (actual)
  0.0 %   Accel. Pedal Pos. Sensor 1 (G79)
  7.1 %   Throttle Valve Angle
  0.00 ms   Injection Timing
  7.29 bar   Current Fuel Pressure
  0.0 %   Boost Pressure Control (N75)
  430.0 mbar   Boost Pressure (specified)
  1010.0 mbar   Boost Pressure (actual)
  50.00 bar   Rail Pressure (specified)
  64.06 bar   Rail Pressure (actual)
Log of VCDS data related to engine functions, fuel injection, etc:
Jef
HQ
What is the fuel pressure when cranking the engine? 01-08-106.1
Please do a compression test as well and post the results.
tekguild
Oakland, CA, USA
C?ID=417434
Fuel pressure test:
Generally between 57 and 61 when cranking
Compression test has all cylinders right around 175 +/- 2PSI (Dry) and 180 +/- 2PSI (Wet)
I also borrowed a GTC505 Analyzer and...nada. Apparently there is no spark. Why would that be? I tested the coils using a DMM and they seem fine, as do the plugs.
Bad ECU? Is there some way to test for a control signal?
I tested the coil wires from the splice point to the connector pins and all seem OK - I'm assuming the 2 and 4 pins are meant to show no resistance between each other (connecting to the Pin 2 splice and touching Pin 4 on a connector shows a 0 ohm resistance on my DMM).
Is Pin 1 supposed to be energized (12V) when ignition is set to 'On' or only when cranking?
No further/different codes. Battery test shows A-OK (12.96V).
Thank you SO MUCH for any assistance you can provide. I greatly appreciate it.
tekguild
Oakland, CA, USA
C?ID=417434
FIXED! Here's a lesson in 'don't assume ANYTHING' - it turned out to be a blown fuse. A fuse that I had checked (along with all other fuses) with a DMM earlier, so it must have blown somewhere in this process.
Also, in merely looking at this fuse, do NOT rely on a visual check. Unless I looked at it *really* close I could never tell by looking that it was blown.
