Golf MK7 all stock, cranks but no start?
Mark Hutchinson
Calgary, AB, Cananda
C?ID=424506
Love the Ross-tech tool. Nice to have some control and diagnostic capability.
MY PROJECT: (cranks but no start...)
I have a 2016 MK7 VW Golf R that had accident damage on the frontend.
I purchased it to work on and fix up in my spare time as I really enjoy it. Time away from computers on weekends :)
I had to replace much of the frontend which also included the:
-Mechtronic unit (cracked the top connector)
-Radar, front ACC distance unit
-Driver, passenger seatbelts / steering wheel airbag, drivers side curtain airbag, main Airbag controller unit have all been replaced.
-Essentially all the frontend forward from the engine. Hood, fenders, lights, most all of it etc.....
ODIS WORK IS DONE AND LOCKS/COMPONENT PROTECTION IS CLEARED:
I had a person from a VW shop clear all of the Protection locks and immobilizer with ODIS, so now the rest is up to me to fix. Hence the Ross-tech coming into play!
There are still 5 problem areas showing up. All but two or three will be remedied as soon as the car is driven I think.
REMAINING ISSUES:
My main issues now are:
-It won’t start (it did once for about 15 seconds, then I put it in reverse, then the immobilizer came on and it still won’t start after that was removed)
-Just cranks but no start…. (Maybe the VCDS can help find out why, but this starts to go beyond my knowledge…...
There are a number of codes and such remaining, and I really want to ensure I get all of this 100% correct.
Look forward to getting to understand things better on this forum.
Thanks all.
Mark Hutchinson
C?ID=424506
Here is my full auto scan.
I would really like to know if there is anything in it that should why it will crank, but not start....
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
55 5F A5 A9
VIN: WVWLF7AUXGW105593 Mileage: 68684km-42678miles
Address 01: Engine (J623-CYFB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 H HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00122466000E3004
ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
ROD: EV_ECM20TFS0208V0906259H.rod
VCID: 45D75A57F52BEED3FC5-8010
17178 - Databus
U1123 00 [039] - Received Error Message
Mileage: 68684 km
Date: 2021.04.20
Time: 16:42:00
Engine RPM: 0.00 /min
Coolant temperature: 15 °C
Intake air temperature: 21 °C
Ambient air pressure: 880 mbar
Voltage terminal 30: 12.578 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-ESP system error: No
Readiness: 1110 0101
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4934
Revision: 06253104 Serial number: TFK01602251763
ROD: EV_TCMDQ250021.rod
VCID: 53F3740F0B7F4063621-8006
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 62295000002323
Coding: 01FA6BA154200971057C030941C66980D62A90A0C08296B7184050D8C288
VCID: 7AADF9ABCC55512BC17-802E
0297 - Steering angle sensor
B1168 16 [137] - Voltage Too Low
Reset counter: 65
Date: 2021.04.19
Time: 18:01:35
16412 - Display for Tire Pressure Monitoring
C1146 02 [137] - Signal Failure
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:01:47
16413 - Display for Tire Pressure Monitoring
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:01:47
Revision: 00021000 Serial number: 0376853829
Coding: 030C0C
VCID: 3A2D39AB8CD5912B817-806E
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020004200100010105000000101002
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 6A8DC9EBBCF5E1AB317-803E
Air quality sensor:
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.20
Time: 15:56:36
Outside temperature: 16.0 °C
Engine RPM: 0 /min
Temperature downstream of evaporator: 16.0 °C
System run time-Terminal 15 on: 6 s
1048839 - Function limitation due to crash signal
B1397 00 [009] - -
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:10:50
Part No SW: 5Q0 937 085 AJ HW: 5Q0 937 085 AF
Component: BCM MQBAB HNA H24 0175
Serial number: 01061523000155
Coding: 00011A46C041A2E149E44000091C07201800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 015F8E47A18302F380D-8054
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150716 043 0551
Serial number: 150812012330
Component: RLHS 037 0059
Serial number: S4Y15M09D02H03M53S40
Coding: 90A8DD
558100 - Databus
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:01:35
786954 - Heater for Spray Nozzles
B1224 15 [009] - Open or Short to Plus
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:01:34
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331524302153
Coding: 0071155011
VCID: 43D3444FFB1FD0E3D21-8016
13637426 - Databus
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:03:29
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Serial number: 02041503210652
Coding: 01041700FE0739
VCID: 382923A3B2D9833B773-806C
1058 - Databus
[FAULT_CIS_ECD_NOTAVAILABLE]
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:02:55
Control Module temperature: 32 °C
Voltage terminal 15: 13.2 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1059 - Databus
[FAULT_CIS_ESP_FAIL]
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:02:55
1078 - Databus
[FAULT_CIS_SAS_INIT]
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:02:55
1043 - Automatic Distance Control
B10E7 F0 [009] - Disconnected
[FAULT_CIS_TSK_IRREV_FAIL]
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:02:55
1792 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_WORKSHOP_ALIGNMENT_NOT_DONE]
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:02:55
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H16 0120
Serial number: 02081541350200
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 372B209FBFC78C437E9-8062
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM0281PE
Shop #: WSC 01383 790 50316
VCID: 51FF7E073163327350D-8004
Component: BF-Gewichtss. H11 0021
Serial number: IBH0000J150003B8PP0E
Coding: 303058
Subsystem 2 - Part No SW: ----------- HW: 480 001 808 15
Serial number: 35700000000E3614F51L
Subsystem 3 - Part No SW: ----------- HW: 480 001 808 15
Serial number: 3580000000085689F51U
Subsystem 4 - Part No SW: ----------- HW: 480 402 108 15
Serial number: 35100029D1CF1D30A338
Subsystem 5 - Part No SW: ----------- HW: 480 402 108 15
Serial number: 35200029D1CF1D30A28D
Subsystem 6 - Part No SW: ----------- HW: 480 400 701 21
Component: FrontSensor_D 004 6149
Serial number: 35500011E66C8C7632BG
Subsystem 7 - Part No SW: ----------- HW: 480 400 110 20
Component: FrontSensor_P 004 6149
Serial number: 35600011863817E274C2
9445973 - Seat occupied recognition control module
B1022 55 [137] - Not configured
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:04:58
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 20081504401774
Coding: 0C10
VCID: 094F966799B34AB3D8D-805C
Part No SW: 5G1 920 758 A HW: 5G1 920 758 A
Component: KOMBI 302 6420
Coding: 0BAD081A7F88880902886A0B5400000000000000
VCID: 2D0702F74D9B3693145-8078
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1223
Revision: -------- Serial number: 0003875530
Coding: 0101000830085900FB00023A9C0F00000001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 75B7EA97E54B3E53AC5-8020
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 S HW: 5G0 959 442 S Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29180000257860028083
Coding: 340000
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7082
Serial number: HA1-00001.07.15
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
VCID: 46D55D5BC82DE5CBF5F-8012
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000180715005
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 34311793AEB1675B5BB-8060
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H11 0071
Serial number: 0377247330
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
VCID: 3C213FB386E1AF1B93B-8068
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H11 0071
Serial number: 0378416173
Coding: 020111
Component: TSG FS 020 0041
Serial number: 190815BHI02835
Coding: 003E13208000040000000000
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000007073282
Coding: 111000
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 9102
VCID: 392F26A789D39A3388D-806C
16130 - Steering Angle Sensor
B1168 F2 [009] - Not Initialized
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:01:34
Motor status: 00
Supply voltage: 13.00 V
Temperature: 24.0 °C
KFC: 3F
KFA: 00 02
Freeze frame conditions: 5F
uioUdNotFilt_xdu16: 13.11 V
uAdSensI_SwitchedKl30_xdu16: 13.11 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0110
Revision: 00000001 Serial number: VWZ8Z1FBA00S6PM
Coding: 2200000000AAAAAA000000000000
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 6D87C2F78D1BF693545-8038
Component: TSG BFS 020 0041
Serial number: 200815BHJ16059
Coding: 003E13208000040000800000
VCID: 42DD414BE405D9EBD97-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000007221529
Coding: 091000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 022202010B010400
VCID: 40D94B43EA09CBFBCF3-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Part No SW: 3G0 035 047 D HW: 3G0 035 047
Component: MU-H-NS-US H42 0344
Serial number: A296H0F7501160
Coding: 027300020000000051220002001828001F0207F401200105DE
VCID: 211FEEC70143E2F3A0D-8074
Subsystem 1 - Part No SW: 5G0 919 606 B HW: 5G0 919 606 B
Component: ABT_High H62 0031
Serial number: VWZ8Z9RU90012F
Subsystem 2 - Part No SW: V03 959 801 BS HW: -----------
Component: NAR 2015/2016 --- 0044
Compact disc data bank:
Component: Gracenote2 --- 3007
B11CF 53 [009] - Deactivated
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:09:46
Voltage terminal 30: 13.4 V
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000411755
Coding: 0100000000020308000400010100000100
ROD: EV_MFKBoschAU370.rod
6553600 - Databus
[LH_EPS_03_BERECHN_LW_SIG_FAILURE]
Fault Frequency: 9
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:01:35
Control Module temperature: 46 °C
Outside temperature: 8.0 °C
Vehicle speed: 0.00 km/h
Voltage terminal 15: 13.1 V
Terminal 15 on: 102.7 s
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 150722200509
VCID: 2F3B18FF47974483269-807A
End----------(Elapsed Time: 02:00, VBatt start/end: 12.9V/12.9V)-----------
Mark Hutchinson
C?ID=424506
Hello all,
Looking for some assistance on a 2016 VW Golf R.
Frontend damage now fixed.
Replaced the front radar sensor, airbags, mechtoronic.
Had a VW tech clear the immobilizer and protection faults.
It originally started for about 15 seconds, before I put it in reverse (6 speed DSG) to get new fluid circulating, then it went into protection mode. So it did start, which is odd.
Here is the full scan if anyone can see anything that sticks out that could cause no start?
Thanks for looking:
55 5F A5 A9
Revision: --H13---
17178 - Databus
Mileage: 68684 km
Date: 2021.04.20
Time: 16:42:00
Reset counter: 65
Date: 2021.04.19
Time: 18:01:35
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:01:47
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:01:47
Coding: 030C0C
Revision: 00001K08
Air quality sensor:
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.20
Time: 15:56:36
Engine RPM: 0 /min
B1397 00 [009] - -
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:10:50
Coding: 90A8DD
558100 - Databus
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:01:35
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:01:34
Coding: 0071155011
13637426 - Databus
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:03:29
1058 - Databus
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:02:55
1059 - Databus
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:02:55
1078 - Databus
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:02:55
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:02:55
C1103 00 [009] - -
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:02:55
Coding: 303058
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:04:58
Coding: 0C10
Generator:
Coding: 340000
Coding: 0001
Coding: 02011103
Coding: 020111
Coding: 111000
Coding: 9102
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:01:34
Motor status: 00
KFC: 3F
KFA: 00 02
Coding: 091000
Coding: 2E0000
Coding: 2E0000
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:09:46
6553600 - Databus
Fault Frequency: 9
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:01:35
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Not seeing a heck of a lot that would immediately explain a crank-no-start. Check that the battery is fully charged, though the freeze-frame voltages we see appear okay.
Most of the databus error-received and other random fault codes you have trace back to the steering-angle sensor not being calibrated, which is something that will self-correct after a short drive to calibrate it, and shouldn't cause a no-start.
Immo constellation on MQB includes the DSG mechatronic that you replaced, but you say you had the Immo matched, and I think on pushbutton start you're not going to crank unless it sees a key the Immo is happy with, so that part should be okay.
B1397 00 [009] - -
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:10:50
What happens if you try to clear codes in 08-Auto HVAC? Does that function limitation fault come back?
I'm not super stoked about the date/time on that freeze-frame. Unless you crashed it yesterday, that means it's still a problem. I'm not sure if there's some reset procedure you need to do on Climatronic specifically after a crash, sometimes that's a thing.
If not... one of the things the airbag crash signal does is stop the engine. If that line were still active, there should really be forensic traces of that in other modules beyond Climatronic, but here you are with a no-start and a funky crash signal DTC... it'd be nice to run down that potential lead.
Mark Hutchinson
C?ID=424506
B1397 00 [009] - -
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:10:50
I am going to try this today.
I dont understand how HVAC can effect this though. AC lines are not charged etc.... but that shouldn't make a no-start. Limited AC function yes.....
I do see the passenger occupancy seat sensor error.
Could that cause an issue with AIRBAGS and then a no-start/immobilize?
Nothing really obvious there.
Fuel pressure good?
Mark Hutchinson
C?ID=424506
Fuel pressure good?
I can probably get more accurate information, but here is what I did to try to find that out:
I went into engine, then adaptation, then selected several of the fuel pressure options.
I did see several values go up on crank. (then my comp crashed before I could screenshot...)
Can you reccomend what values to select that could help diagnose a fuel problem as you mention?
Low pressure, high pressure? Injector, rail?
I also wonder what pressures I should be seeing?
Some guidance for a new user on where to go in the interface, and what to select and expect on pressures would really be appreciated.
Because I bet you are correct on the fuel...
Appreciate the help very much. Really excited about getting this started. Its a new car to me, so I have never seen it run.
In Measuring Values:
IDE00186 -- Fuel low pressure: actual value
IDE00202 -- Low fuel pressure: specified value
IDE00188 -- Fuel high-pressure: actual value
IDE00201 -- High fuel pressure: specified value
Specified value can vary based on operating conditions, but the ECU is kind enough to provide them.
PS: I've merged your threads. No sense in having two threads open with the same question about the same car.
Mark Hutchinson
C?ID=424506
Agreed. Thank you for doing that.
I am going to try all of the suggested things today and will get back. Thanks again.
Mark Hutchinson
C?ID=424506
Mark Hutchinson
C?ID=424506
B1397 00 [009] - -
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:10:50
I tried to clear this, but it just came back. No idea why it would be under the HVAC area??
Mark Hutchinson
C?ID=424506
B1397 00 [009] - -
Reset counter: 65
Mileage: 68684 km
Date: 2021.04.19
Time: 18:10:50
I tried to clear this as you suggested. It just comes back after being cleared.
No idea why it would be under HVAC.
The AC has not been charged yet.
Still would not think this would be a cause for crank but no start, but who knows....
Mark Hutchinson
C?ID=424506
Before clearHi and welcome.
Please post an Auto-Scan for context.
I also tried to fix the "9445973 seat occupied recognition control module" in the AIRBAGS 15 Area.
I can clear the code, rescan and it does not come back.
Then when I crank the engine over, with no start obviously, the fault comes back for the Airbag.
Could this be causing the no start? Maybe it wont start with an airbag fault??
Here are some pics:
Let me know what you think pls.
Before fault clear on 15 airbag
After code clear and rescan
Right after cranking the engine. Fault returns
Also, if I follow the wiki directions and try to clear this with basic settings, I get this error:
Bad module? Or need coding? This part has not been changed. Just the main airbag module rebuilt/reset
Here is a pic of the result of that:
Error, conditions not correct or request sequence error
I see now that the fault actually says "not configured"
So do I need to configure that occupancy sensor module?
@Mark Hutchinson: Hi. I've not played with the passenger seat occupied sensor (called G128 in the WD) - so I'm guessing (a lot). However, reading the repair manual, there seems to be a required sequence when the switch is disconnected/reconnected - which in relativity terms (the Einstein sort) kind-of, must-have happened when you replaced the hex15 module.
Not sure if it helps, but this is what the repair manual says after G128 has been re-installed (my highlight):
– Connect battery earth cable with ignition switched on
WARNING​
If the ignition has not yet been switched on after the battery has​
been reconnected “warning lamps in dash panel insert are off”,​
the ignition (key or button) must only be switched on while sitting
on the driver seat and with the seat set to rearmost
position.
So - because it's easy and given that you have already retrofitted and re-energized the new hex15 module, maybe try simulating the fitment process in the repair manual? Disconnect battery earth cable with ignition switched on - unplug/wait a while/reconnect the G128 connector - then complete above procedure
Again, a guess!!
EDIT: included reference to "Al" for clarity
Mark Hutchinson
C?ID=424506
@Mark Hutchinson: Hi. I've not played with the passenger seat occupied sensor (called G128 in the WD) - but looking at the repair manual, there seems to be a required sequence when the switch is disconnected/reconnected (which kind-of happened when you replaced the hex15 module).
WARNING​
position.
So - because it's easy and given that you have already retrofitted and re-energized the hex15 module, maybe try simulating the fitment process again? Disconnect battery earth cable with ignition switched on - unplug/reconnect the G128 connector - then complete above procedure
Again, a guess!!
I actually never had that unplugged or changed.
I only replaced the drivers and passenger seatbelts in the front, the drivers side curtain airbag, the steering wheel airbag and had the main airbag module rebuilt and reset. Never needed to replace or touch passenger sensors.
Any further thoughts?
thanks
I actually never had that unplugged or changed....................Never needed to replace or touch passenger sensors.
Mark: I like the finality and the absolute conviction of your assertion (above) - but this man would disagree (if he was still alive)!!
When you had the "main airbag module rebuilt and reset", you must have disconnected the hex15 module. Relativity (the Einstein kind) dictates that this is equivalent to disconnecting the G128 sensor from the main module.
As I said, my suggestion is just a guess - it's entirely your prerogative to proceed in any way you see fit!!
Mark Hutchinson
C?ID=424506
Mark: this man would disagree (if he was still alive}!!
hmm.......... as a very intelligent man once said
Oh, I misunderstood! Sorry, I thought you meant the occupancy sensor was disconnected. I totally understand you now. Yes, I will try that for sure.
Thanks for the help.
Mark
Well, some results!
Fuel pressures.
I took a couple pics before cranking, and a couple during cranking.
Let me know your thoughts pls
Am I seeing this correctly, the high pressure actual never gets above 5 bar?
This being a direct-injection engine, 5 bar isn't near enough to start it. How about logging those four values, plus RPM during a start attempt?
Mark Hutchinson
C?ID=424506
Mark
Tried this. Took off the batt cables, unplugged the sensor under the passenger seat, ground on batt, seat all the way back, switched it on.
Got an error on Airbag system. Tried to start. Just cranked, no joy.
Had to reset the same Airbag error as before.....
