Catalytic Conv. Test & Timing Retard
morris39
Canada
C?ID=395084
Cat test:
What do these values mean? How is the test initiated?
Loc. IDE01873Loc. IDE01874Loc. IDE01874
Test of catalytic converter: measured valueTest of catalytic converter: measured valueTest of catalytic converter: result
0.078​
1.078​
Test not started
OBDII all good, see below
Ignition Timing:
Loc. IDE00155 Ignition timing angle retard cylinder 1 0
Cylinder 2-4 same.
Does this mean that the ignition does not need to be retarded i.e. all OK ?
20 Apr2021 Scan/Log
Tuesday,20,April,2021,12:15:46:47231
VIN: WAUFFRFF8F1141715   License Plate:
                Address 01: Engine  (8V0 906 259 H)
12:15:34
  IDE00021   Engine RPM 799 /min
  IDE00085   Normed load value 23.1 %
  IDE00155   Ignition timing angle retard cylinder 1 0.00 °
  IDE00156   Ignition timing angle retard cylinder 2 0.00 °
  IDE00157   Ignition timing angle retard cylinder 3 0.00 °
  IDE00158   Ignition timing angle retard cylinder 4 0.00 °
Tuesday,20,April,2021,13:38:04:47231
Readiness Status: 0000 0000
Exhaust Gas Recirculation: Passed
Oxygen Sensor Heating: Passed
Oxygen Sensor(s): Passed
Air Conditioning: Passed
Secondary Air Injection: Passed
Evaporative Emissions: Passed
Catalyst Heating: Passed
Catalytic Converter(s): Passed
Mode 01 - PID 01 : Readiness  --  Address 7E8
Number of DTCs stored: 0  --  MIL Status: MIL OFF
Misfire monitoring:  Passed
Fuel System:  Passed
Comprehensive Components:  Passed
Catalyst monitoring:  Passed
Heated catalyst monitoring: Not installed.
Evaporative system monitoring:  Passed
Secondary air system monitoring: Not installed.
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring:  Passed
Oxygen sensor heater monitoring:  Passed
Mode 07: Pending emission related fault codes
Address 7E8: No fault code found.
Address 7E9: No fault code found.
Type 02 - VIN : WAUFFRFF8F1141715 (Address E8)
Type 04 - Calibration ID : 8V0259H 0001AVCK (Address E8)
Type 04 - Calibration ID : 0D9300012L  4521 (Address E9)
Type 06 - Calibration Verification Number : 3B8D27B0 (Address E8)
Type 06 - Calibration Verification Number : 0000A11E (Address E9)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 1693
    Ignition cycle count : 5773
         Catalyst monitor bank 1 : 743 / 1693
         Catalyst monitor bank 2 : 0 / 0
         O2 Sensor monitor bank 1 : 815 / 1693
         O2 Sensor monitor bank 2 : 0 / 0
         EGR-VVT monitor : 2508 / 1603
         AIR monitor : 0 / 0
         EVAP monitor : 129 / 363
         Secondary O2 Sensor monitor bank 1 : 613 / 1693
         Secondary O2 Sensor monitor bank 2 : 0 / 0
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
Thanks. Posting here may be not be best but Non-broken cars gets no replies.
There may be a Basic Setting that initiates it. It will also self-initiate when conditions are correct, especially if the relevant Readiness bit is not set.
You should be able to see when the ECU pulls timing from the map there as a result of knock-sensing. This will generally happen under high loads, and especially if your fuel isn't up to snuff.
