VW Transporter 2015 Misfire / ruff idle
kaddrison
C?ID=295269
had a loose injector - tightened and all was good
was told to replace so ordered a replacement
It came loose again and a misfire - stretch bolt replaced but still have the misfire
Injector quantity deviation on 3 is + 3
is there any chance it could be the seal
any ideas from this scan
;SW:03L-906-019-GG   HW:03L-907-309-M ---  Engine
;Component:R4 2    0L EDC   X45 6291     Coding:01114012232400080000
;EV_ECM20TDI01103L906019GG    3004    EV_ECM20TDI01103L906019FG_003.rod
;Tuesday    20    April    2021    19:48:37:60567
;VCDS Version: Release 21.3.0 (x64)  Data version: 20210226 DS325.0
;VCID: 76B6ECACF849F4CBA5F-8022
Group    Description    Actual
IDE00011    Vehicle Identification Number (VIN)    WV1ZZZ7HZFH140224
IDE00019    Voltage terminal 30    13.92     V
IDE00020-ENG57549    Terminal 15 status-Bits 0-7    1
IDE00021    Engine RPM    877     /min
IDE00022    Transmission input speed    10000     /min
IDE00025    Coolant temperature    87     °C
IDE00030    Status of actuator test    not active
IDE00075    Vehicle speed    0     km/h
IDE00076    Status of initial fuel filling    was not yet started
IDE00078    Time since engine start    950     s
IDE00083    Throttle valve position (absolute)    83.9     %
IDE00085    Normed load value    31.8     %
IDE00086    Accelerator pedal position    15     %
IDE00090-ENG57549    selected gear-Bits 0-7    0
IDE00097    OBD - requirements for which this vehicle is designed    Euro-OBD
IDE00100    Engine torque    50.1     Nm
IDE00102    Control Module temperature    41.7     °C
IDE00151    Oil fill level    43.736     mm
IDE00152    Oil warning threshold    28.412     mm
IDE00172    A/C compressor torque    20     Nm
IDE00173    Cruise Control System: specified speed    0     km/h
IDE00182    Camshaft adaptation intake bank 1: phase position    -0.2     °
IDE00188    Fuel high-pressure: actual value    273200     hPa
IDE00190    Charge air pressure: specified value    1058     hPa
IDE00191    Charge air pressure: actual value    1092.6     hPa
IDE00192    Coolant temperature at radiator outlet: actual value    75.7     °C
IDE00194    Coolant temperature at radiator output: specified value    90     °C
IDE00196    Engine oil temperature    90.1     °C
IDE00201    High fuel pressure: specified value    280000     hPa
IDE00304    Fuel level    32     l
IDE00322    Status of basic setting    was not yet started
IDE00323    Security Access: Number of invalid keys    0
IDE00347    Air mass: actual value:    13.97     g/s
IDE00348    Intake air temperature    40     °C
IDE00349    Throttle valve position: normed    100     %
IDE00350    Air mass: specified value    279.1     mg/stroke
IDE00351    Main injection: start of activation    -1.1     °
IDE00352    Main injection: duration of activation    555.2     µs
IDE00353    Engine start: start quantity    14.41     mg/stroke
IDE00354    Engine start: start synchronization    EPM_MODE_OK
IDE00354-ENG127291    Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE    48
IDE00355-ENG57549    Cruise Control System (CCS): status-Bits 0-7    40
IDE00356-ENG57549    Cruise Control System (CCS): switch position-Bits 0-7    129
IDE00357    Fuel temperature    40.6     °C
IDE00358    Limitation: torque    169.8     Nm
IDE00359    Limitation: smoke    159.2     Nm
IDE00360    Limitation: accelerator pedal    0     Nm
IDE00361    Ambient air pressure    1017     hPa
IDE00362    Charge Pressure Actuator: activation    100     %
IDE00363-ENG57549    Glow status-Bits 0-7    255
IDE00363-ENG57549    Glow status-Bits 0-7    0
IDE00364    Pre-glow time    0     ms
IDE00365    Injection quantity deviation cylinder 1    0.17     mg/stroke
IDE00366    Injection quantity deviation cylinder 2    -3     mg/stroke
IDE00367    Injection quantity deviation cylinder 3    2.99     mg/stroke
IDE00368    Injection quantity deviation cylinder 4    -0.51     mg/stroke
IDE00371    Fuel consumption    1.01     l/h
IDE00373-ENG57549    Electric auxiliary heater: shut-off conditions-Bits 0-7    0
IDE00374-ENG57549    Electric auxiliary heater: relay activation-Bits 0-7    0
IDE00375    Generator: load signal    33.95     %
IDE00380    Coolant fan 1: activation    10     %
IDE00381    Coolant fan 2: activation    0     %
IDE00383    Pre-injection 1: activation start    3.8     °
IDE00384    Pre-injection 1: activation duration    258     µs
IDE00385    Pre-injection 2: activation start    9.03     °
IDE00386    Pre-injection 2: activation duration    244.4     µs
IDE00387    Post-injection 1: activation start    0     °
IDE00388    Post-injection 1: activation duration    0     µs
IDE00389    Post-injection 2: activation start    0     °
IDE00390    Post-injection 2: activation duration    0     µs
IDE00392    Accelerator pedal: sensor voltage 1    746     mV
IDE00393    Accelerator pedal: sensor voltage 2    367.2     mV
IDE00394    Camshaft position: start of phase window    121.73     °
IDE00395    Camshaft position: end of phase window    250.27     °
IDE00396    Charge air pressure actuator: acknowledgment    100.01     %
IDE00399    Regulation factor: total    1
IDE00404    Throttle valve: activation    10.68     %
IDE00405    Crankshaft speed (RPM)    819.5     /min
IDE00406    Camshaft RPM    431.8     /min
IDE00407-ENG57549    Rail pressure regulation: status-Bits 0-7    15
IDE00412-ENG57549    Starter control: terminal 50-Bits 0-7    0
IDE00413-ENG57549    Starter control: Interlock- or P/N-signal-Bits 0-7    0
IDE00414-ENG57549    Starter control: relay 1-Bits 0-7    0
IDE00416-ENG57549    Starter control: terminal 50 feedback-Bits 0-7    0
IDE00417-ENG57549    Starter control: shut-off conditions 1-Bits 0-7    0
IDE00420    Service regeneration: current duration    0     s
IDE00422-ENG57549    Service regeneration: release conditions 1-Bits 0-7    0
IDE00424-ENG57549    Service regeneration: cancel conditions-Bits 0-7    0
IDE00425-ENG57549    Service regeneration: phase-Bits 0-7    0
IDE00425-ENG57549    Service regeneration: phase-Bits 0-7    1
IDE00427    Particle filter: difference pressure    5     hPa
IDE00428    DPF: offset for differential pressure    2     hPa
IDE00430-ENG57549    Particle filter: field regeneration request status-Bits 0-7    0
IDE00431-ENG57549    Particle filter: field regeneration lock status-Bits 0-7    0
IDE00432    Particle filter: time since last regeneration    17288     s
IDE00433    Particle filter: oil ash volume    0.05     l
IDE00434    Particle filter: soot mass calculated    22.01     g
IDE00435    Particle filter: soot mass measured    1.29     g
IDE00436    Particle filter: kilometers since last regeneration    115849     m
IDE00443-ENG57549    Accelerator pedal: switch positions-Bits 0-7    8
IDE00445    Unlearning counter according OBD    255
IDE00450    Operating instruction    ---
IDE00451    Currently running routine    0
IDE00472    Mean injection quantity    10.37     mg/stroke
IDE00473    EGR Vacuum Regulator Solen.val.: activation    100     %
IDE00474    Ambient air pressure    101     kPa abs
IDE00475    Fuel Pressure Regulator Valve    17.9     %
IDE00476    Fuel Metering Valve    32.06     %
IDE00477    Torque request: sum of auxiliary aggregate    3.6     Nm
IDE00478    Engine-drag torque    30.2     Nm
IDE00481-ENG57549    Limitation: status of clutch protection-Bits 0-7    1
IDE00482    Limitation: torque of clutch protection    61077.6     Nm
IDE00541    Acceleration    0     m/s²
IDE00556    Outside temperature    25     °C
IDE00558    Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor)    0.332 Lambda / 0.985 V
IDE00581    EGR specified value    0     %
IDE00583    Throttle valve specified value    100     %
IDE00584    Distance driven since erasing DTC memory    95     km
IDE00585    Dist. driven with exh. Malfunction Indicator Lamp activated    0     km
IDE00586    Deviation of exh.gas recirc. rate    -100     %
IDE00589    Fuel pressure    24330     kPa rel
IDE00594    Absolute intake pressure    109     kPa abs
IDE00595    Allocation of oxygen sensors    B1S1
IDE00600    Conversion factors
IDE00601    Monitoring status since erasing DTC memory
IDE00602    Monitoring status in current driving cycle
IDE00603    Number of driving cycles since erasing DTC memory    5
IDE00699    ESI: minimum oil level in service interval    32     mm
IDE00700    ESI: maximum oil level in service interval    -32     mm
IDE00727    Test steps still to be performed    0
IDE00784    Current test step    0
IDE00787    Cause for cancellation    0
IDE00973    Outside temperature    25.5     °C
IDE01076    Time since ignition off    145     s
IDE01259    EGR Solen.val.: actual value    99.62     %
IDE01260    Generator performance    0     W
IDE01361    exh.gas recirc. (EGR) cooler pump: specified value    95     %
IDE01363-ENG57549    exh.gas recirc.: shut-off conditions-Bits 0-7    255
IDE01363-ENG57549    exh.gas recirc.: shut-off conditions-Bits 0-7    37
IDE01363-ENG57549    exh.gas recirc.: shut-off conditions-Bits 0-7    0
IDE01367    Turbocharger boost control: offset closed    5.03     %
IDE01368    Turbocharger boost control: offset open    -5.03     %
IDE01373    EGR valve: offset closed    -0.63     %
IDE01374    EGR valve: offset open    0.63     %
IDE01375    Throttle valve adapter: offset closed    0.09     %
IDE01376    Throttle valve adapter: offset open    -0.09     %
IDE01377    Throttle valve adapter: actual value    100.01     %
IDE01378    Fuel high pressure: control deviation    -2200     hPa
IDE01380    Pre-injection 3: activation start    0     °
IDE01381    Pre-injection 3: activation duration    0     µs
IDE01382    Post-injection 3: activation start    0     °
IDE01383    Post-injection 3: activation duration    0     µs
IDE01385    Wear index    4     m
IDE01386    Soot index    1     m
IDE01387    Injector 1: rail pressure calibration point 1    -12.5     µs
IDE01388    Injector 1: rail pressure calibration point 2    -15     µs
IDE01389    Injector 1: rail pressure calibration point 3    -9.9     µs
IDE01390    Injector 2: rail pressure calibration point 1    -34.05     µs
IDE01391    Injector 2: rail pressure calibration point 2    -22.6     µs
IDE01392    Injector 2: rail pressure calibration point 3    -20.55     µs
IDE01393    Injector 3: rail pressure calibration point 1    0.2     µs
IDE01394    Injector 3: rail pressure calibration point 2    -5.4     µs
IDE01395    Injector 3: rail pressure calibration point 3    -10.6     µs
IDE01396    Injector 4: rail pressure calibration point 1    -11.55     µs
IDE01397    Injector 4: rail pressure calibration point 2    -15.1     µs
IDE01398    Injector 4: rail pressure calibration point 3    -15.85     µs
IDE01405-ENG57549    Starter activation: status-Bits 0-7    0
IDE01406-ENG57549    Service regeneration: status-Bits 0-7    0
IDE01407    Particle filter: fuel consumption since last regeneration    8.71     l
IDE01408    Charge limit for field regeneration    24.1     g
IDE01409    Charge limit for service regeneration    40     g
IDE01410    Charge limit over-charge    45     g
IDE01834    Battery voltage    13980     mV
IDE01880    Accelerator pedal position 2    15     %
IDE01922    Vehicle distance driven    64821     km
IDE02228    Fuel pressure regulator valve: specified value rail pressure    238200     hPa
IDE02229    Exhaust gas temperature sensor 1    241.8     °C
IDE02230    Torque reduction due to exhaust temperature    1
IDE02233    Exhaust gas temperature sensor 2    137.8     °C
IDE02234    Exhaust gas temperature sensor 3    131.2     °C
IDE02236    Exhaust gas temperature sensor 4    122.3     °C
IDE02247    Static maximum speed limit    300     km/h
IDE02248    Individually adjustable top speed limit    300     km/h
IDE02540-ENG57549    Longitudinal acceleration sensor: status-Bits 0-7    0
IDE02632    Activation of static maximum speed limit    0
IDE02756-ENG57549    Number of manual engine starts-Bits 0-7    0
IDE02757-ENG57549    Number of automatic engine starts-Bits 0-7    0
IDE03015    Compression test cylinder 1    0     /min
IDE03016    Compression test cylinder 2    0     /min
IDE03017    Compression test cylinder 3    0     /min
IDE03018    Compression test cylinder 4    0     /min
IDE03140    NOx sensor 1: NOx concentration    0     ppm
IDE03141    NOx sensor 2: NOx concentration    0     ppm
IDE03145    NOx sensor 2: offset for correction factor    0     ppm
IDE03187    Checksum of flash    46B6
IDE03189-ENG102843    Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Air Density    0     counts
IDE03189-ENG102547    Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Brake Boost    0     counts
IDE03189-ENG103808    Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Fuel Mixture Adaption    0     counts
IDE03189-ENG101159    Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Random    0     counts
IDE03189-ENG104187    Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Regeneration Mode    0     counts
IDE03189-ENG100165    Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Start Behavior    0     counts
IDE03189-ENG99535    Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Air Density    0
IDE03189-ENG103192    Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Brake Boost    0
IDE03189-ENG99739    Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Fuel Mixture Adaption    0
IDE03189-ENG100597    Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Random    0
IDE03189-ENG101689    Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Regeneration Mode    0
IDE03189-ENG100582    Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Start Behavior    0
IDE03189-ENG101720    Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Air Density    0
IDE03189-ENG100669    Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Brake Boost    0
IDE03189-ENG100932    Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Fuel Mixture Adaption    0
IDE03189-ENG101264    Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Random    0
IDE03189-ENG102430    Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Regeneration Mode    0
IDE03189-ENG101165    Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Start Behavior    0
IDE03189-ENG101829    Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Air Density    0     km
IDE03189-ENG99286    Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Brake Boost    0     km
IDE03189-ENG102800    Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Fuel Mixture Adaption    0     km
IDE03189-ENG102751    Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Random    0     km
IDE03189-ENG101356    Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Regeneration Mode    0     km
IDE03189-ENG99669    Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Start Behavior    0     km
IDE03189-ENG103828    Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Air Density    0
IDE03189-ENG103959    Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Brake Boost    0
IDE03189-ENG102465    Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Fuel Mixture Adaption    0
IDE03189-ENG102710    Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Random    0
IDE03189-ENG103568    Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Regeneration Mode    0
IDE03189-ENG100877    Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Start Behavior    0
IDE03189-ENG101280    Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Air Density    0
IDE03189-ENG99226    Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Brake Boost    0
IDE03189-ENG101471    Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Fuel Mixture Adaption    0
IDE03189-ENG102877    Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Random    0
IDE03189-ENG100198    Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Regeneration Mode    0
IDE03189-ENG101676    Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Start Behavior    0
IDE03189-ENG103694    Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Air Density    0
IDE03189-ENG104142    Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Brake Boost    0
IDE03189-ENG100353    Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Fuel Mixture Adaption    0
IDE03189-ENG100878    Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Random    0
IDE03189-ENG101433    Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Regeneration Mode    0
IDE03189-ENG100557    Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Start Behavior:    0
IDE03190-ENG100538    Number of requested start processes (statistics)-SSEUI Counter Start Desired By Brake Boost    0     counts
IDE03190-ENG100036    Number of requested start processes (statistics)-SSEUI Counter Start Desired By High Engine Temperature    0     counts
IDE03190-ENG103639    Number of requested start processes (statistics)-SSEUI Counter Start Desired By Low Engine Temperature    0     counts
IDE03190-ENG102427    Number of requested start processes (statistics)-SSEUI Day Start Desired By Brake Boost    0
IDE03190-ENG99459    Number of requested start processes (statistics)-SSEUI Day Start Desired By High Engine Temperature    0
IDE03190-ENG99665    Number of requested start processes (statistics)-SSEUI Day Start Desired By Low Engine Temperature    0
IDE03190-ENG99329    Number of requested start processes (statistics)-SSEUI Hours Start Desired By Brake Boost    0
IDE03190-ENG100944    Number of requested start processes (statistics)-SSEUI Hours Start Desired By High Engine Temperature    0
IDE03190-ENG100535    Number of requested start processes (statistics)-SSEUI Hours Start Desired By Low Engine Temperature    0
IDE03190-ENG102737    Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Brake Boost    0     km
IDE03190-ENG101377    Number of requested start processes (statistics)-SSEUI Mileage Start Desired By High Engine Temperature    0     km
IDE03190-ENG99682    Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Low Engine Temperature    0     km
IDE03190-ENG102760    Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Brake Boost    0
IDE03190-ENG103163    Number of requested start processes (statistics)-SSEUI Minutes Start Desired By High Engine Temperature    0
IDE03190-ENG101771    Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Low Engine Temperature    0
IDE03190-ENG100816    Number of requested start processes (statistics)-SSEUI Month Start Desired By Brake Boost    0
IDE03190-ENG104013    Number of requested start processes (statistics)-SSEUI Month Start Desired By High Engine Temperature    0
IDE03190-ENG104020    Number of requested start processes (statistics)-SSEUI Month Start Desired By Low Engine Temperature    0
IDE03190-ENG103223    Number of requested start processes (statistics)-SSEUI Year Start Desired By Brake Boost    0
IDE03190-ENG103563    Number of requested start processes (statistics)-SSEUI Year Start Desired By High Engine Temperature    0
IDE03190-ENG103316    Number of requested start processes (statistics)-SSEUI Year Start Desired By Low Engine Temperature    0
IDE03234    Pressure sensor after air cleaner: unconditioned voltage    4100.6     mV
IDE03235    Neutral position sensor: current transmission angle    20     °
IDE03236    Neutral position sensor: adapted transmission angle    0     °
IDE03244    Kilometers after completing leak detection diagnostic function    64111     km
IDE03245    Last valid O2 difference mean value in deceleration    0.00036
IDE03246    Neutral position sensor: upper adaptation value    0     mV
IDE03247    Neutral position sensor: lower adaptation value    0     mV
IDE03248    Pressure control valve adaptation factor    1.0216
IDE03266    Fuel temperature: unconditioned voltage    1343.8     mV
IDE03267    Intake air temperature: unconditioned voltage    1046     mV
IDE03270    Exh.gas temp.sen 1: unconditioned voltage    0     mV
IDE03271    Exh.gas temp.sen 2: unconditioned voltage    767.6     mV
IDE03273    Exh.gas temp.sen 3: unconditioned voltage    758     mV
IDE03275    Exh.gas temp.sen 4: unconditioned voltage    745     mV
IDE03276    Charge air pressure sensor: unconditioned voltage    1753.8     mV
IDE03328    Transmission neutral position sensor voltage    0     mV
IDE03353    Particle filter differential press. sensor: uncond. voltage    1029.8     mV
IDE03362    Requested transmission torque    1000     Nm
IDE03375-ENG57549    Adaptation status of neutral position sensor-Bits 0-7    4
IDE03377    Coolant temp at radiator output: unconditioned voltage    848.2     mV
IDE03383    Exhaust mass flow of EGR    0     kg/h
IDE03405-ENG57549    Particle filter field regeneration: cancel conditions-Bits 0-7    0
IDE03583-ENG57549    Engine shut-down overrides-Bits 0-7    24
IDE03584-ENG57549    Engine starting requirements-Bits 0-7    0
IDE03585    System status for the start/stop function master    0
IDE03586-ENG57549    Starting requirements for active participants-Bits 0-7    0
IDE03587-ENG57549    Stopping requirements for active participants-Bits 0-7    2
IDE03587-ENG57549    Stopping requirements for active participants-Bits 0-7    0
IDE03588-ENG57549    System malfunctions for active participants start/stop-Bits 0-7    0
IDE03589-ENG57549    Error status for start-stop related sensors-Bits 0-7    10
IDE03660    Longitudinal acceleration    0     m/s²
IDE03712-ENG57549    Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7    255
IDE03712-ENG57549    Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7    247
IDE03712-ENG57549    Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7    208
IDE03712-ENG57549    Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7    54
IDE03767    Engine status    COENG_RUNNING
IDE03767-ENG127290    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE    3
IDE03768    NOx sensor 1: feed voltage    0     mV
IDE03769    NOx sensor 2: feed voltage    0     mV
IDE03892    Fuel high pressure sensor: unconditioned voltage    982.2     mV
IDE03949    Air mass: actual value (mg/stroke)    467.4     mg/stroke
IDE03966    Transmission neutral position sensor PWM signal    0     %
IDE04256    Temp sensor for engine coolant: unconditioned voltage    699.8     mV
IDE04257    High pressure EGR actuator: activation    13.1     %
IDE04258-ENG57549    Actuator for high pressure EGR: status-Bits 0-7    55
IDE04258-ENG57549    Actuator for high pressure EGR: status-Bits 0-7    2
IDE04258-ENG57549    Actuator for high pressure EGR: status-Bits 0-7    70
IDE04258-ENG57549    Actuator for high pressure EGR: status-Bits 0-7    0
IDE04259    High press EGR actuator: actual unconditioned volt val    737.8     mV
IDE04260-ENG57549    Learning cycle counter of zero quant calib: bottom press pt-Bits 0-7    1
IDE04260-ENG57549    Learning cycle counter of zero quant calib: bottom press pt-Bits 0-7    54
IDE04261-ENG57549    Lrn cyc cntr of zro quan calib: mid press. point-Bits 0-7    54
IDE04261-ENG57549    Lrn cyc cntr of zro quan calib: mid press. point-Bits 0-7    1
IDE04262-ENG57549    Learning cycle counter of zero quant calib: top press pt-Bits 0-7    1
IDE04262-ENG57549    Learning cycle counter of zero quant calib: top press pt-Bits 0-7    55
IDE04263    Sensor for particle filter differential press: raw value    8     hPa
IDE04264-ENG57549    Throttle valve adapter: status-Bits 0-7    4
IDE04264-ENG57549    Throttle valve adapter: status-Bits 0-7    8
IDE04264-ENG57549    Throttle valve adapter: status-Bits 0-7    55
IDE04264-ENG57549    Throttle valve adapter: status-Bits 0-7    2
IDE04265    Throttle valve adapter: uncond voltage actual value    4197.2     mV
IDE04266    High press turbocharger actuator: activation    95     %
IDE04267-ENG57549    High press turbocharger actuator: status-Bits 0-7    0
IDE04267-ENG57549    High press turbocharger actuator: status-Bits 0-7    55
IDE04267-ENG57549    High press turbocharger actuator: status-Bits 0-7    70
IDE04268    High press turbocharger actuator: actual uncond volt value    3652.2     mV
IDE04272    Counter for regeneration time of particulate filter    0     s
IDE04273    Intake air pressure sensor after air cleaner: raw value    1013     hPa
IDE04468    Air mass at air mass meter 1    51.2     kg/h
IDE04604    Accelerator pedal travel    0     %
IDE04623    Kick-down threshold    4125.2     mV
IDE04650    Particle filter: differential pressure: dynamic offset    4     hPa
IDE04651    Torque request: A/C compressor    0     Nm
IDE04652    Exhaust gas jet volume in particle filter    60.6     m³/h
IDE04653    Simulated particle filter surface temperature    132.4     °C
IDE04654-ENG57549    CAN status - engine control module-Bits 0-7    0
IDE04655-ENG57549    CAN status - transmission control module-Bits 0-7    0
IDE04656-ENG57549    CAN status - brake control module 1-Bits 0-7    0
IDE04657-ENG57549    CAN status - brake control module 2-Bits 0-7    0
IDE04658-ENG57549    CAN TimeOut meter - battery manager-Bits 0-7    0
IDE04659-ENG57549    CAN TimeOut meter - parking brake-Bits 0-7    0
IDE04660-ENG57549    CAN TimeOut meter - gateway-Bits 0-7    0
IDE04661-ENG57549    CAN TimeOut meter - steering angle-Bits 0-7    0
IDE04662-ENG57549    CAN TimeOut meter - transmission-Bits 0-7    0
IDE04663-ENG57549    Cruise control switch-off: irreversible-Bits 0-7    255
IDE04664-ENG57549    Cruise control switch-off: reversible-Bits 0-7    255
IDE04665-ENG57549    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7    0
IDE04666    Heat delivery temperature in cooling system    -273.1     °C
IDE04667-ENG57549    Bypass valve for EGR cooler: status-Bits 0-7    1
IDE04668-ENG57549    EGR cooling function: status-Bits 0-7    0
IDE04669    Camshaft slope position    0     °
IDE04670    Crankshaft signal evaluation: status    GAPFOUND
IDE04670-ENG127292    Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE    7
IDE04671    Fuel volume adaptation correction volume    0     mg/stroke
IDE04672-ENG57549    Fuel volume adaptation switch-off condition-Bits 0-7    2
IDE04673    O2 sensor 1 bank 1: duty cycle O2 heater    39.44     %
IDE04674    O2 sensor 1 bank 1: adjusted oxygen value    0.00251
IDE04675    O2 sensor 1 bank 1: air flow volume    0     g
IDE04676    Oxygen sensor 1 bank 1: Ri calibration value    9.3     Ohm
IDE04677    Oxygen sensor 1 bank 1: lambda actual value    5.555
IDE04678-ENG57549    Oxygen sensor 1 Bank 1: Status Calibration O2-Signal-Bits 0-7    1
IDE04679-ENG57549    O2 sensor 1: bank 1: status O2 signal: validity-Bits 0-7    1
IDE04680    Oxygen sensor 1 bank 1: voltage raw value O2 signal    976.8     mV
IDE04681    Oxygen sensor 1 bank 1: voltage value Ri-signal filtered    1006.2     mV
IDE04682-ENG57549    Allowed number of injections-Bits 0-7    3
IDE04683-ENG57549    Injection release status-Bits 0-7    56
IDE04684-ENG57549    Desired injection characteristic-Bits 0-7    56
IDE04685    Setpoint generation interior torque    45.5     Nm
IDE04686    Calculated clutch limit torque    -30.7     Nm
IDE04688-ENG57549    Engine control module reset status-Bits 0-7    0
IDE04689    Starter control: Start interruption status    0
IDE04690-ENG57549    Transmission torque intervention status-Bits 0-7    4
IDE04690-ENG57549    Transmission torque intervention status-Bits 0-7    0
IDE04691    Calculated reducing transmission intervention torque    1000     Nm
IDE04692    Reducing desired torque intervention of ESP    50000     Nm
IDE04693    Increasing desired torque intervention of ESP    -50000     Nm
IDE04694-ENG57549    Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7    255
IDE04694-ENG57549    Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7    253
IDE04695-ENG99946    Immobilizer snapshot A-Sia Error Snap A    00 00 00
IDE04696-ENG102592    Immobilizer snapshot B-Sia Error Snap B    00 00 00
IDE04706-ENG57549    Activation condition ACC interface-Bits 0-7    8
IDE04707-ENG57549    Status of reversible shut-off conditions ACC 2-Bits 0-7    0
IDE04708-ENG57549    Status of reversible shut-off conditions ACC 3-Bits 0-7    16
IDE04709-ENG57549    Status of ACC/CCS acceleration interface-Bits 0-7    0
IDE04710-ENG57549    ACC control module: received status-Bits 0-7    6
IDE04711-ENG57549    Next Status ACC/Cruise status machine-Bits 0-7    2
IDE04712-ENG57549    Active brake system error status-Bits 0-7    0
IDE04713-ENG57549    Active brake system status-Bits 0-7    0
IDE04868-ENG57549    Glow cycles above temperature threshold-Bits 0-7    6
IDE04868-ENG57549    Glow cycles above temperature threshold-Bits 0-7    239
IDE04869-ENG57549    Glow cycles below temperature threshold-Bits 0-7    67
IDE04869-ENG57549    Glow cycles below temperature threshold-Bits 0-7    4
IDE04870-ENG57549    Glow cycles upon reaching temperature threshold-Bits 0-7    11
IDE04870-ENG57549    Glow cycles upon reaching temperature threshold-Bits 0-7    50
IDE04887    Powertrain target torque    -575.9     Nm
IDE04937    Sensor for engine block temperature: raw value    87.3     °C
IDE04938    Sensor for temp after charge air cooler: raw value    41.6     °C
IDE05134    ACC specified acceleration    0     m/s²
IDE05135-ENG57549    Status of compressor release-Bits 0-7    0
IDE05136-ENG57549    Current operating mode_2-Bits 0-7    16
IDE05136-ENG57549    Current operating mode_2-Bits 0-7    0
IDE05137-ENG57549    Shut-off timer: instrum panel counter: open circuit in term 30-Bits 0-7    0
IDE05138    Shut-off timer: last engine shut-off time    141     s
IDE05139    Shut-off timer: last ECM after-run time    38     s
IDE05261-ENG57549    Gear position sensor: last valid value-Bits 0-7    14
IDE05343-ENG57549    Target value of heating temperature of NOx sensor 2-Bits 0-7    0
IDE05344    Air mass to enable NOx sensor 2 offset test    0     g
IDE05345    Air mass to enable NOx sensor 1 offset test    0     g
IDE05346    NOx Emission NOx-Sensor 2    0     ppm
IDE05347    NOx Emission NOx Sensor    0     ppm
IDE05348    NOx-Sensor 2: O2-Concentration    0.2067
IDE05349-ENG57549    Status of electrical malfunction of NOx sensor 2-Bits 0-7    0
IDE05350-ENG57549    Status of electrical malfunction of NOx sensor 1-Bits 0-7    0
IDE05351    Time counter for invalid NOx signal from NOx sensor 2    0     s
IDE05352-ENG57549    Status of trailing throttle detec in trailing throttle coord-Bits 0-7    0
IDE05359    Exhaust mass flow of low-pressure EGR    0     kg/h
IDE05385-ENG57549    Activation signal of presupply pump-Bits 0-7    1
IDE05386    Exhaust gas model temperature 0    0     °C
IDE05387    Exhaust gas model temperature 1    0     °C
IDE05388    Exhaust gas model temperature 2    0     °C
IDE05440    ESI: Soot equiv 2 calculated from soot index    0.00000006
IDE05441    ESI: Wear equivalent 2 calculated from wear index    0.00000024
IDE05442    Roadway slope angle acceleration interface: calculated    0     rad
IDE05443    Acceleration interface braking torque specified value    0     Nm
IDE05493    Air cleaner degree of soiling    3.1     %
IDE05494-ENG57549    Air cleaner full/empty detection-Bits 0-7    0
IDE05495-ENG57549    Suspicion of air cleaner icing-Bits 0-7    0
IDE05496-ENG57549    Air cleaner defrosted and cleared after suspicion of icing-Bits 0-7    0
IDE05507-ENG57549    Current particulate filter statistics memory range-Bits 0-7    7
IDE05521    Correction factor of the eng temp for eng protection    1
IDE05522    Correction factor of the oil temp for eng protection    1
IDE05523    Correction factor of the fuel temp for eng protection    1
IDE05524    Charge air press temp correction factor for engine prot    1
IDE05625    Speed regulation requested torque    -575.9     Nm
IDE05626    Calculated temperature at reduction agent injection valve    -273.1     °C
IDE05629-ENG57549    Presupply pump activation status-Bits 0-7    0
IDE05631    Reducing agent tank transfer pump request status    0
IDE05797    Throttle valve adapter: specified value    100     %
IDE05805    Calculated temperature of compressor wall    18.3     °C
IDE05846    DPF statistics: current average speed    24.07     km/h
IDE05849    DPF statistics: current average torque gradient    29.7     Nm/s
IDE05851    DPF statistics: current average RPM    1266     /min
IDE05853    DPF statistics: current avg temperature after part filter    162.6     °C
IDE05855    DPF statistics: current regeneration time slice not possible    0
IDE05857    DPF statistics: current measured charging rate    0.0111     g/km
IDE05859    DPF statistics: current calculated charging rate    0.1283     g/km
IDE05861-ENG57549    DPF statistics: number of interrupted regenerations-Bits 0-7    0
IDE05863    DPF statistics: soot mass at start of regeneration    0     g
IDE05865    DPF statistics: soot mass measured at start of regeneration    0     g
IDE05867    DPF statistics: soot mass calculated at start of regen    0     g
IDE05869    DPF statistics: current average speed in charge cycle    0     km/h
IDE05871    DPF statistics: current avg torque gradient in charge cycle    0     Nm/s
IDE05873    DPF statistics: average RPM in charge cycle    0     /min
IDE05875    DPF statistics: average temp after DPF in charge cycle    -273.1     °C
IDE05877    DPF statistics: regen time slice not poss in charge cycle    0
IDE05879    DPF statistics: measured charging rate in charge cycle    0     g/km
IDE05881    DPF statistics: calculated charging rate in charge cycle    0     g/km
IDE05883    DPF statistics: regeneration time    0     s
IDE05885    DPF statistics: soot mass measured at end of regeneration    0     g
IDE05887    DPF statistics: soot mass calculated at end of regeneration    0     g
IDE05889    DPF statistics: max temperature before DPF during regen    -273.1     °C
IDE05891    DPF statistics: max temperature after DPF during regen    -273.1     °C
IDE05893    DPF statistics: average soot burn-off during regeneration    0
IDE05895    DPF statistics: average speed during regeneration    0     km/h
IDE05897    DPF statistics: average RPM during regeneration    0     /min
IDE05899    DPF statistics: average torque gradient during regeneration    0     Nm/s
IDE05901    DPF statistics: route in charge cycle    0     m
IDE05903    DPF statistics: avg driv cycle time during charge cycle    0     s
IDE05906    DPF statistics: route since successful regeneration    115836     m
IDE05908-ENG57549    DPF statistics: regeneration request-Bits 0-7    0
IDE05910    DPF statistics: exhaust temperature regulation average value    0
IDE05912-ENG57549    DPF statistics: reason for regeneration interruption-Bits 0-7    0
IDE05914-ENG57549    DPF statistics: reason 2 for regeneration interruption-Bits 0-7    0
IDE05916-ENG57549    DPF statistics: regeneration end status-Bits 0-7    0
IDE05918-ENG57549    DPF statistics: regeneration blocked status-Bits 0-7    0
IDE05920-ENG57549    DPF statistics: regeneration data index-Bits 0-7    0
IDE05922-ENG57549    DPF statistics: error status-Bits 0-7    0
IDE05943-ENG57549    Release for supply to fuel pump-Bits 0-7    1
IDE06013    Engine start: start synchronization 2    EPM_FULL_SYNC
IDE06013-ENG127375    Engine start: start synchronization 2-Test_Program_Epm st Sync State t UBYTE    30
IDE06041-ENG57549    PDTC drive cycle conditions status-Bits 0-7    37
IDE06058-ENG57549    Engine control module reset status info-Bits 0-7    0
IDE06059    Particulate filter: oil ash mass    22.8     g
IDE06060    Particulate filter ash load limit    0     g
IDE06216    DPF Statistics: average val.: exhaust temp. ctrl before DPF    0
IDE06255    Vehicle lateral acceleration    -0.01     g
IDE06256    Vehicle lateral acceleration: raw value    -0.01     g
IDE06257    Vehicle inclination acceleration angle: raw value    0     m/s²
IDE06258    Charge air temperature at the turbocharger outlet: calculated    18.8     °C
IDE06298-ENG57549    Status of engine during start-Bits 0-7    0
IDE06386    Oil level: static measurement    0     mm
IDE06387    Oil level: last valid dynamic value    0     mm
IDE06391    Oil temperature sensor 2    0     °C
IDE06392    Oil temperature sensor 2: raw value    0     mV
IDE06393    Oil level: dynamic average value    131.068     mm
IDE06433    Standardized airflow ratio: filtered    0.9967
IDE06435    A/C compressor: refrigerant pressure    8200     hPa
IDE06445    Longitudinal acceleration: raw value    0     m/s²
IDE06446-ENG57549    Status: incline angle-Bits 0-7    1
IDE06647-ENG57549    Start-stop switch status-Bits 0-7    0
IDE06706-ENG57549    ACC variants-Bits 0-7    0
IDE06709-ENG57549    ACC variants (coding)-Bits 0-7    1
IDE06946-ENG57549    Brake actuated status-Bits 0-7    0
IDE07050-ENG57549    Starter control: release conditions-Bits 0-7    0
IDE07373    Top dead center adaptation    -1.03     °
IDE08212    Standardized air flow ratio    0.9487
IDE08213-ENG57549    Standardised airflow ratio plausibility-Bits 0-7    0
ENG105146    Air_flow_sensor_temperature_raw_value    38.5     °C
ENG101413    Calibration Identification    03L906019GG 6291
ENG99697    Calibration Verification Number    1A A4 28 49
ENG105483-ENG57549    Charge_press_positioner_counter_of_mechanic_hitting-Bits 0-7    2
ENG105483-ENG57549    Charge_press_positioner_counter_of_mechanic_hitting-Bits 0-7    104
ENG105483-ENG57549    Charge_press_positioner_counter_of_mechanic_hitting-Bits 0-7    0
ENG105483-ENG57549    Charge_press_positioner_counter_of_mechanic_hitting-Bits 0-7    163
ENG100152-ENG104003    ECUNAME-ECU    ECM
ENG100152    ECUNAME    EngineControl
ENG106084    EGR_governor_deviation    -192.3     mg/stroke
ENG106085    EGR_governor_deviation_lower_limit    -3276.8     mg/stroke
ENG106086-ENG57549    EGR_governor_deviation_monitoring_enabling-Bits 0-7    0
ENG106087    EGR_governor_deviation_upper_limit    1500     mg/stroke
ENG106223    Engine_torque_limitation_mechanical    174     Nm
ENG106696    Fuel_injection_nominal_voltage_calibration_learning_value_cylinder_1    0.049
ENG106697    Fuel_injection_nominal_voltage_calibration_learning_value_cylinder_2    0.0007
ENG106698    Fuel_injection_nominal_voltage_calibration_learning_value_cylinder_3    0.0276
ENG106699    Fuel_injection_nominal_voltage_calibration_learning_value_cylinder_4    0.0468
ENG106705    Fuel_Mean_Value_Adaptation_Engine_Speed_Node    1900     /min
ENG106706    Fuel_Mean_Value_Adaptation_Fuel mass node    30     mg/stroke
ENG106707-ENG57549    Fuel_Mean_Value_Adaptation_Learning_Index-Bits 0-7    2
ENG106708    Fuel_Mean_Value_Adaptation_Value    0     mg/stroke
ENG106774-ENG57549    General_rail_press_calibr_ctrl_duration_enble_stat-Bits 0-7    255
ENG111022    Glow_period_control_unit_calculated_glow_voltage    0     mV
ENG111025    Glow_period_control_unit_energy_integrator_calculated_value    215     V²s
ENG111024    Glow_period_control_unit_energy_integrator_input_voltage    0     mV
ENG111026    Glow_period_control_unit_engine_temperature    87.5     °C
ENG106877-ENG57549    High_press_EGR_vlv_cnter_strtd_jam_off_trial-Bits 0-7    0
ENG106876-ENG57549    High_press_EGR_vlv_counter_of_mech_hitting-Bits 0-7    21
ENG106876-ENG57549    High_press_EGR_vlv_counter_of_mech_hitting-Bits 0-7    218
ENG106876-ENG57549    High_press_EGR_vlv_counter_of_mech_hitting-Bits 0-7    0
ENG107036-ENG57549    Injctr_spec_rail_press_calibr_ctrl_dur_enbl_stat-Bits 0-7    15
ENG103875-ENG99452    In-use perform. track.: 16 counters-Boost Pressure Monitor Completion Condition Counts    584     counts
ENG103875-ENG103994    In-use perform. track.: 16 counters-Boost Pressure Monitor Conditions Encountered Counts    610     counts
ENG103875-ENG100817    In-use perform. track.: 16 counters-EGR and/or VVT Monitor Completion Condition Counts    3782     counts
ENG103875-ENG101113    In-use perform. track.: 16 counters-EGR and/or VVT Monitor Conditions Encountered Counts    610     counts
ENG103875-ENG104133    In-use perform. track.: 16 counters-Exhaust Gas Sensor Monitor Completion Condition Counts    302     counts
ENG103875-ENG104165    In-use perform. track.: 16 counters-Exhaust Gas Sensor Monitor Conditions Encountered Counts    610     counts
ENG103875-ENG28750    In-use perform. track.: 16 counters-Fuel Monitor Completion Condition Counts    0     counts
ENG103875-ENG28751    In-use perform. track.: 16 counters-Fuel Monitor Conditions Encountered Counts    0     counts
ENG103875-ENG102823    In-use perform. track.: 16 counters-Ignition Cycle Counter    6049     counts
ENG103875-ENG99234    In-use perform. track.: 16 counters-NMHC Catalyst Monitor Completion Condition Counts    0     counts
ENG103875-ENG99167    In-use perform. track.: 16 counters-NMHC Catalyst Monitor Conditions Encountered Counts    0     counts
ENG103875-ENG101363    In-use perform. track.: 16 counters-NOx Adsorber Monitor Completion Condition Counts    0     counts
ENG103875-ENG103522    In-use perform. track.: 16 counters-NOx Adsorber Monitor Conditions Encountered Counts    0     counts
ENG103875-ENG125933    In-use perform. track.: 16 counters-NOx/SCR Catalyst Monitor Completion Condition Counts    0     counts
ENG103875-ENG125934    In-use perform. track.: 16 counters-NOx/SCR Catalyst Monitor Conditions Encountered Counts    0     counts
ENG103875-ENG99988    In-use perform. track.: 16 counters-OBD Monitoring Conditions Encountered Counts    610     counts
ENG103875-ENG100240    In-use perform. track.: 16 counters-PM Filter Monitor Completion Condition Counts    63     counts
ENG103875-ENG103730    In-use perform. track.: 16 counters-PM Filter Monitor Conditions Encountered Counts    39     counts
ENG110883    IUMPR_minimum_ratio_group_0    0
ENG110884    IUMPR_minimum_ratio_group_1    0
ENG110885    IUMPR_minimum_ratio_group_2    0
ENG110886    IUMPR_minimum_ratio_group_3    1.6154
ENG110887    IUMPR_minimum_ratio_group_4    0.495
ENG110888    IUMPR_minimum_ratio_group_5    6.2
ENG110889    IUMPR_minimum_ratio_group_6    0.9573
ENG110890    IUMPR_minimum_ratio_group_7    0.7557
ENG107569    Main_injection_quantity    4.76     mg/stroke
ENG107671    Model_corr._factor_of_effective_cross_section_of_EGR_valve    1.4937
ENG107673    Model_corr._factor_of_exh._mass_flow_rate_into_exh._manifold    1
ENG107672    Model_correction_factor_of_exhaust_gas_temperature_1    1
ENG107674    Model_correction_factor_of_volumetric_efficiency    0.9828
ENG107675    Model_correction_factor_of_volumetric_efficiency_including_variable_swirl_correction    1
ENG108162    Particle_filter_service_regeneration_duration_with_headup    0     s
ENG108252    Postinjection_1_quantity    0     mg/stroke
ENG108253    Postinjection_2_quantity    0     mg/stroke
ENG108254    Postinjection_3_quantity    0     mg/stroke
ENG108270    Preinjection_1_quantity    0     mg/stroke
ENG108271    Preinjection_2_quantity    1.23     mg/stroke
ENG108272    Preinjection_3_quantity    1.11     mg/stroke
ENG109107    Stat_of_adaption_of_toothed_spd_snsr_disc_fr_TDC    EPMTDC_FILT_STP
ENG109107-ENG127376    Stat_of_adaption_of_toothed_spd_snsr_disc_fr_TDC-Test_Program_Epm TDC st Adap Val Signal t UBYTE    1
ENG109106-ENG57549    Status_of_adaption_of_toothed_speed-Bits 0-7    0
ENG109108-ENG57549    Status_tooth_angle_adaption_learning-Bits 0-7    3
ENG109431-ENG57549    Throttle_valve_counter_of_mech_hitting-Bits 0-7    88
ENG109431-ENG57549    Throttle_valve_counter_of_mech_hitting-Bits 0-7    0
ENG109431-ENG57549    Throttle_valve_counter_of_mech_hitting-Bits 0-7    41
ENG109432-ENG57549    Thrttle_vlv_cntr_strtd_jam_off_trial-Bits 0-7    0
ENG109657-ENG57549    Trbochrgr_press_postionr_cnter_strtd_jam_off_trial-Bits 0-7    0
Did you tell the ECU about the new injector when you installed it?
kaddrison
C?ID=295269
didn't replace the injector - bolt is on a bracket that holds 2 injectors - that's all I have changed up to now
Ah, sorry, misunderstood.
NZDubNurd
New Zealand
C?ID=230482
If it was loose, there was probably a reason.. is the thread pulling from the head???
Also, the seat in the head may be worn from movement and exhaust pushing past, and need reaming. Then fit the injector with a new seal and bolt.
