2007 2.5 Jetta secondary air injection fails to be ready
wmcilmoil
CA, USA
C?ID=374154
OK So I have been trying to get my jetta to pass smog but the secondary injection fails to be ready. I have ran the auto scan (see below) and there are no codes. I cleared the codes after I fixed the P2279 error. Once I cleared the codes the secondary air injection won't come ready so I can take it to pass smog. I have driven the car multiple times trying to get it to be ready and I have used the VCDS to try to set the readiness but it won't. Is there something I am missing?
Monday,19,April,2021,17:00:28:30803
VIN: 3VWGG71K27M135620   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWGG71K27M135620   Mileage: 219700km-136515miles
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 R    HW: 07K 906 032 Q
   Component: 2.5l R5/4V      G   9651
   Revision: --H01---    Serial number: VWZ7Z0G9033234
   Coding: 0000001
   Shop #: WSC 00066 000 00000
   VCID: 382928D14E540EFB773-806C
Readiness: 0000 1000
   Part No: 1K0 907 379 P
   Coding: 0017025
   VCID: 3FDB43CD6B7A39C3B69-806A
   Part No: 1K0 820 047 GR
   Component: Climatic PQ35   120 0606
   VCID: 7AADF2D930D8DCEBC17-802E
   Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000000569749
   Coding: 14050E234004150007140000001400000008730B5C0000
   VCID: 6B83C79D4F8275634A1-803E
   Component: Wischer 190207 020  0501
   Coding: 00038805
                    Fault Status: 01101100
                    Fault Frequency: 75
                    Reset counter: 38
                    Mileage: 210219 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.75 V
                    Reset counter: 73
                    Mileage: 216858 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.50 V
                    Reset counter: 73
                    Mileage: 219679 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.35 V
00927 - Terminal 30 (Right)
                    Fault Status: 00101011
                    Reset counter: 71
                    Mileage: 219673 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.95 V
   Part No SW: 1K0 909 605 AC    HW: 1K0 909 605 AC
   Component: 74 AIRBAG VW8R  040 8600
   Revision: 08040000    Serial number: 003E7D20D6X5
   Coding: 0014132
   Shop #: WSC 22155 210 01865
   VCID: 6D87C98571967B53545-8038
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME15460D68E
   Subsystem 3 - Serial number: 6342MSME15680042+
   Subsystem 4 - Serial number: 6351HSME0C465E74J
   Subsystem 5 - Serial number: 6361HSME0C460D7EO
   Subsystem 6 - Serial number: 63727SME0B774A65A
   Subsystem 7 - Serial number: 63827SME0B700408Y
02513 - Belt Force Sensor for Seat Occupied Recognition (G453)
   Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
   Component: Lenksäulenmodul 036 0070
   Coding: 0000021
   VCID: 005980315604863B8F3-8054
   Part No SW: 1K0 920 953 P    HW: 1K0 920 953 P
   Component: KOMBIINSTRUMENT 3HL 1610
   Revision: V0003000    Serial number: VWZ7Z0G9033234
   Coding: 0023207
00771 - Fuel Level Sensor (G)
                    Fault Status: 00101010
                    Reset counter: 78
                    Mileage: 219701 km
                    Time: 16:33:53
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 070207F1000831
   Coding: 3DBF034007001002
   VCID: 2F3B138DBB1AC943269-807A
                    Fault Status: 00110100
                    Reset counter: 73
                    Mileage: 219249 km
                    Time: 16:12:51
                    Reset counter: 73
                    Mileage: 219679 km
                    Time: 15:53:34
   Component: IMMO            3HL 1610
   Component: J386  TUER-SG FT    1133
   Revision: 32008001    Serial number: 00000512078123
   Coding: 0001205
   VCID: 3B2337DD7F6225E39A1-806E
01552 - Motor for Central Locking; Drivers Door (V56); Lock
                    Fault Status: 00101100
                    Fault Frequency: 25
                    Reset counter: 54
                    Mileage: 217680 km
                    Fault Frequency: 9
                    Reset counter: 59
                    Mileage: 217680 km
00105 - Signal Central Locking SAVE/LOCK Drivers Side
                    Reset counter: 73
                    Mileage: 219679 km
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.070 H07 1806
   Shop #: WSC 02069 000 90108
   VCID: 34311CE1523CEA9B5BB-8060
   Component:    KSG PQ35 RDK 052 0218
   Coding: 13900F880186281B0904058FB0880F0488DCA0
   VCID: 04518C21421C9A1BABB-8050
                    Reset counter: 61
                    Mileage: 219279 km
                    Time: 18:35:18
   Component: J387  TUER-SG BT    1133
   Revision: 32008001    Serial number: 00000562778125
   Coding: 0001204
   VCID: 3C2134C17A6C22DB93B-8068
01553 - Motor for Central Locking; Passenger Door (V57); Lock
                    Reset counter: 54
                    Fault Status: 00111000
                    Reset counter: 54
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 B    HW: 1K0 035 161 B
   Component: Radio DE2       014 0017
   Revision: 00014000    Serial number: VWZ4Z7G6217464
   Coding: 0040401
   VCID: 1E65DE49CCB050CB9DF-804A
   Component: J388   TUER-SG HL   1120
   Revision: 12006001    Serial number: 00000001184948
   Coding: 0001168
   VCID: 3E253EC96C7030CBBDF-806A
   Component:    RDK              0440
   Coding: 0100101
                    Reset counter: 77
                    Mileage: 219263 km
                    Time: 18:39:59
   Component: J389   TUER-SG HR   1120
   Revision: 12006001    Serial number: 00000001143810
   Coding: 0001168
End----------(Elapsed Time: 01:22, VBatt start/end: 12.2V/12.1V)-----------[/ode]
Hi and welcome.
Have you tried running through the output test sequence (with the engine not running) to see if the pump runs when it comes up in the sequence?
wmcilmoil
CA, USA
C?ID=374154
I did not run the output test but I did just now. When it came to the pump test, I did hear like a revving of a pump. It revved like 4 times I believe.
Moving this to Car Repair Support from General VW/Audi Repair.
Maybe @Peter, @Dana, or @Jef will have some suggestion(s) for you.
Jef
HQ
Go into OBDII mode from the first screen of VCDS, then go into [Mode 10 Perm. DTCs], any codes in there?
As a general rule of thumb... if everything is to factory design, it will set the Readiness codes... eventually. If there is something wrong, it tends to fail quickly and you get a fault code. So if no codes are getting flagged when you scan address [01-Engine], that is good.
SAI is usually the last self-test that will run and this 2.5L was really fussy in that area when forcing readiness via Basic Settings (even on a car that didn't have an air leak or SAI problem previously). Although the notes here are 2.0T BPY specific any additional vacuum or PCV problems will cause you problems:
Since you drove it after repairs I would take a look at MVB 032:
If the numbers are outside of +/- 4% in either field I would clear codes at idle (which will revert your Readiness progress) as per the video to see where the short term immediate reaction values are in MVB 033. If you see anything greater than 10% in 033 I would suspect an Air leak or PCV type of concern preventing the SAI from completing.
wmcilmoil
CA, USA
C?ID=374154
So no fault codes still and the 032 sits at .4% and 0.0% and 033 shows no more than +/- 3% and 1.460V. 33 mostly shows negative numbers.
wmcilmoil
CA, USA
C?ID=374154
@Jef I went into 10 and it shows no fault codes.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Sec Air on this engine take long time to get ready, Sometimes needs 6-8 Cycles (Means From clod engine to normal operating temp on engine) with at least 40 miles drive in Cycle .
BTW, I am not sure in CA but here in TX , you can have one monition not ready to pass emission test .
Jef
HQ
Then I suspect this will fall into the "if everything is to factory design, it will pass.... eventually" category.
wmcilmoil
CA, USA
C?ID=374154
I guess I need to drive my car more often then and for longer period of time. In California there are some items that can fail or not check in but the secondary air injection I have been told is a must for the car to pass smog.
wmcilmoil
CA, USA
C?ID=374154
I don't get it. I have tacked on another 200 miles on this car and driven it anywhere from 4 miles round trip to 50 miles round trip and the stupid secondary air injection still will not check in. I guess it is time to hand it over to a mechanic.
Jetta 97
C?ID=81680
Like I said on 2.5L it takes for ever .
