14 audi a7 no crank
Fattues111
Las Vegas, USA
C?ID=380963
hi ihave a a7 that was hit in front lh sde hurt aux pump condensor and radiator headlight .was fixing aux pump and wiring then no start fuses all good dash lights up batt good.no crank no start any help appreciated
Thursday,08,April,2021,17:30:53:58883
VIN: WAU2GAFCXEN104272   License Plate: A7 NOSTART
Mileage: 101760km-63230mi   Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 47
          52 53 55 56 5F 62 6C 6D 72 85 8B 8E 8F 90
VIN: WAU2GAFCXEN104272   Mileage: 101760km-63230miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
85-On Board Cam. -- Status: Malfunction 0010
8B-Adaptive Cruise 2 -- Status: Cannot be reached 0100
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CTUA)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551 J    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0004
   Revision: --H07---
   Coding: 1A2A0034056601060000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551J 001004
   ROD: EV_ECM30TFS0214G0907551J.rod
   VCID: 3039101A5AAD33BB3F3-8064
6058 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [037] - -
                    Fault Frequency: 8
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:11:52
                    Engine RPM: 0.00 /min
                    Coolant temperature: 27 °C
                    Intake air temperature: 29 °C
                    Ambient air pressure: 920 mbar
                    Voltage terminal 30: 12.085 V
                    Engine speed: actual: 0 /min
                    T_AST_ENVD: 0.00 s
                    Gear: 0
                    Engine: operating status: ES
                    Battery voltage: 12.085938 V
                    Vehicle speed: actual: 0 km/h
6455 - ECM Power Relay Control Circuit
          P0687 00 [037] - Short to Plus
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:11:51
                    MAF_ENVD: 0.00000 mg/stroke
                    Coolant temperature (unfiltered): 27.75 °C
                    Engine load: 0.000000 %
6450 - System Voltage
          P0562 00 [037] - Too Low
                    Fault Frequency: 8
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:11:51
10448 - Starter Relay
          P3088 00 [229] - Electrical Malfunction
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:23:57
                    Voltage terminal 30: 11.984 V
                    Battery voltage: 11.984375 V
9675 - Evap System Leak Detection or Fuel Vapor Temp Sensor
          P2025 00 [037] - Implausible Signal
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:11:58
                    CTR_NR_DIAG_SMALL_LEAK_NVLD: 0
                    CTR_NR_DIAG_TGT_NVLD: 0
                    CTR_NR_RESP_REP_COMC_NVLD_ENVD: 32
                    Ambient temperature: 27.75 °C
                    AMP_ENVD: 864.9824 hPa
                    FTL_CAN: 26 l
Readiness: 1110 1101
   Part No SW: 4G1 927 158 A    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H16 1006
   Revision: --H16---
   Coding: 000002
   VCID: 2D07096E4D9F5E53145-8078
   Part No SW: 4G0 907 379 M    HW: 4G0 907 379 M
   Component: ESP PREMIUM   H09 0450
   Coding: 44A7970322E5E9C05B00
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: 3B23373683EBC0E39A1-806E
7 Faults Found:
0040 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ComScl_PDU_ACC_05_Timeout]
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:26:07
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: 9F
                    Uz: 9D
0042 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ComScl_PDU_ACC_10_Timeout]
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:26:07
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: A5
                    Uz: 9D
0604 - Tire Pressure Warning
          C102D 00 [009] - -
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:26:07
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 2C
                    Uz: 9D
0629 - Tire Pressure Warning
          C102D 00 [009] - -
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:26:07
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 30
                    Uz: 9D
0784 - Function Restriction due to Implausible Message(s)
          U1112 00 [009] - -
          [SCL_LWR_Hoehenwert_VL_Invalid]
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:26:07
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: E6
                    Uz: 9D
0276 - Supply Voltage for ABS Valves
          C106A 01 [137] - Electrical Failure
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:26:08
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: 41
                    Uz: 9D
0849 - Internal Control Module Memory Check Sum Error
          B2000 00 [129] - -
          [VlvUvrLowSPIBitFailure]
   Part No SW: 4H0 907 064 ER    HW: 4H0 907 064 ER
   Component: BCM2 2.0      H36 0521
   Coding: 0DAA2046000000000000
   VCID: 7DA7F92EDDFF0ED3E45-8028
   Serial number: 0213000386911005
   Part No SW: 4G0 820 043 AN    HW: 4G0 820 043 AN
   Component: KLIMA 4 ZONEN H14 0093
   Serial number: 07121300040386
   Coding: 6603207A4D
   ASAM Dataset: EV_AirCondiComfoUDS 004003
   ROD: EV_AirCondiComfoUDS_004.rod
   VCID: 6B83C776B30B90634A1-803E
0267 - Sensor for Refrigerant Pressure and Temperature
          B10C2 21 [009] - Signal Amplitude Too Low
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:44
                    Compressor current: actual value: 0 mA
                    Outside temperature: 29.0 °C
                    Temperature downstream of evaporator: 28.38 °C
                    Engine RPM: 0 /min
0276 - Engine Off Timer Performance
          P150A 00 [009] - -
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:00:12
                    Voltage terminal 30: 11.58 V
                    Terminal 15 status: Terminal 15 on
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001677578
   Coding: 02002091163C9FE2C1008884A0003928CF9CD208A6080225800008406000
   VCID: 6FBBD36687936C43669-803A
   Component: WWS57X 131203  H36 0080
   Serial number:         131205125749
   Coding: 0045F7
   Serial number: 22105348
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 11 12 2013  00000709
   Subsystem 4 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0085680489
   Coding: 853000
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA107205000005545540
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 2538C1E6000000000001
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 01101100
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:00
02258 - Door Opener Transmitter
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:00
01319 - Control Module for Distance Control (J428)
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:00
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061335603220
   Coding: A8EB04
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71BFD51E91277AB370D-8024
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 [009] - Open Circuit
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:46
12727552 - Databus
          [Steuergerät für Abstandsdistanzregelung - ACC_02_FR - kein Signal/keine Kommunikation]
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:45
Address 13: Auto Dist. Reg
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D8003SZ26
   Coding: 303145313131303031304A55304C34473853
   VCID: 33331F16ABBB08A3421-8066
   Serial number: 6940000Y13000108ZB0Q
   Serial number: 3575HRB405L2AIFU9G6$
   Serial number: 3585HRB40552A84KBHOE
   Serial number: 3515JRB401050PQ2LI45
   Serial number: 3525JRB401C50PGER8V0
   Serial number: 3564VRB404V2FD2MG0UB
9443861 - Driver's Front Airbag Crash Sensor
          B101A 15 [137] - Open or Short to Plus
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:49
1050368 - Databus
          [CAN: 0x323 PCF_01 Timeout]
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:47
   Revision: --------    Serial number: 90372MLA000CM
   Coding: 0000FC
   VCID: 372B2B06BF43E4837E9-8062
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 07 12 2013  C0395834
   Part No SW: 4G8 920 984 R    HW: 4G8 920 984 R
   Component: TBenUsaAcc    H58 0621
   Revision: 29460235    Serial number: 658081113596017
   Coding: 0BC601060F53D705020100
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 45D751CEF52F8613FC5-8010
16776960 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC_02_FR keine Kommunikation]
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:45
16776961 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC_04_FR keine Kommunikation]
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:45
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001219408
   Coding: 00CD073000
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 72BDDA12942141AB897-8026
   Serial number: 2550481903
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 13100800000000000110
4365 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:43:08
                    Voltage terminal 30: 12.1 V
                    Voltage terminal 15: 12.1 V
                    Control Module temperature: 41 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
6654 - Automatic distance regulation 2
          U1071 00 [009] - No communication
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:43:08
                    Control Module temperature: 40 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Part No SW: 4G0 919 158 M    HW: 4G0 919 158 M
   Component: KLIMA FOND    H08 0093
   Serial number: 10121300040714
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
   VCID: 392F2D3E89D7F2F388D-806C
0033 - Motor for Rear Right Upper Body Vent
          B10D4 22 [008] - Signal Amplitude Too High
                    Reset counter: 17
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:09:54
                    Voltage terminal 30: 12.25 V
                    Outside temperature: 28.0 °C
                    Right Rear Upper Body Vent Motor-Act.val.: 11715
                    Right Rear Upper Body Vent Motor-Target value: 11715
                    Right Rear Upper Body Vent Motor-Stop open: 11414
                    Right Rear Upper Body Vent Motor-Stop closed: 10000
                    Right Rear Upper Body Vent Motor-Last active operating mode: 5
                    Right Rear Upper Body Vent Motor-Active operating mode before last: 7
   Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000083510828
   Coding: C0581B008F006001000001010101102030303232203232
   VCID: 3829283AB25DEBFB773-806C
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H03 0056
   Revision: --------    Serial number: EJ1BPA8205V78C
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 36352602B8C91D8B65F-8062
   Part No SW: 4G0 907 566 J    HW: 4G0 907 566
   Component: J769  SWA MasterH04 0060
   Revision: 00H04000    Serial number: 6PZ 010 287-08
   Coding: 0000007
   VCID: 36352602B4491D8B65F-8062
   Subsystem 1 - Part No: 4G0 907 568 J
   Component: J770  SWA Slave H04 0060
   Subsystem 2 - Serial number: 6PZ 010 287-28
   Subsystem 3 - Serial number: 5F03.12.1300H04000AMS14027ÿ
   Subsystem 4 - Serial number: S14027ÿ
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F57025E00628002000413
   VCID: 45D751CEF5AF8613FC5-8010
   Component: RCEPS         H40 0010
   Revision: 00001000    Serial number: 0021167418
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D1A1254A101AB497-8066
18689 - Terminal 30
          U140A 00 [008] - Open Circuit
          [Ausfall der Versorgungsspannung (Kl30 oder Kl31) im Stillstand (unkritisch)]
                    Reset counter: 17
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:02:13
                    Write only channel
   Revision: 00002001    Serial number: 0322420022
   Coding: 0126023A20FAF08580B00A8402030D470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000197071
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO2612200U
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00005643150
   Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA107824000005729431
   Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93112301
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:46
   Revision: CJ007001    Serial number: 00000000061757
   Coding: 030000
   VCID: 1D67D9AE3DBFAED3845-8048
   Component: TSG BF        H03 0507
   Coding: 011F57025E00628002000402
   VCID: 46D556C2C8A98D0BF5F-8012
   Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
   Component: EPB-4         H03 0014
   Revision: --------    Serial number: 00000000925797
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2C01046A7685575B03B-8078
327936 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [FC_ACC_05_MESSAGE_TIMEOUT]
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:45
                    Voltage terminal 30: 12.4 V
                    Internal Fault ID: 86
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: applied
                    Status ParkingBrake right: applied
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 C    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0020
   Serial number: 131217-0004-025
   Coding: 1223A633701AA500
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
530180 - Local Data Bus
          U10BA 00 [137] - No Communication
                    Fault Frequency: 17
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:48
   Revision: AB001007    Serial number: 156L30D7950282
   Coding: 020007010000000001
   VCID: 2411EC4A1ED59F1BCBB-8070
   Part No SW: 4G0 035 746 F    HW: 4G0 035 746 E
   Component: H-BNT-NA      H41 0757
   Revision: --------    Serial number: 194LJ0D7598747
   Coding: 090200040003E9EF7D12CB3E00000003100001000000000000
   VCID: 2A0D02727CF1496BF17-807E
   Subsystem 1 - Part No: 8R0 060 884 BL
   Component: NAR 2014  0902
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDDD003ERG2
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349ML6000YC
   Component: CD-Database  5571
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:02:18
                    Bin. Bits: 00000000 00100000
                    Bin. Bits: 00001000 00000000
                    Bin. Bits: 00000000 00000000
   Component: TSG HL        H03 0507
   Coding: 010F17024000628002000002
   VCID: 49CF5DFED9B7627318D-801C
   Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
   Component: TopView       H05 0220
   Revision: 11001001    Serial number: 82330JF0126350
   Coding: 0205000001010100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
   ROD: EV_CamerSysteTopViewAUDI_007.rod
9616922 - Supply Voltage for Front Surroundings Camera
          B1284 14 [009] - Open or Short to Ground
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:44
                    Voltage terminal 30: 12.3 V
   Part No SW: 4G8 959 107 R    HW: 4G8 959 107 G
   Component: HDSG-Modul    H13 0043
   Revision: 12013001    Serial number: 338300603
   Coding: 0A3305C102
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 44D14CCAFE15BF1BEBB-8010
   Component: TSG HR        H03 0507
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2615F64268696D0BD5F-8072
0724 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC_timeout]
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:45
                    Outside temperature: -35.5 °C
                    Voltage terminal 15: 12.3 V
                    Control Module temperature: 48.0 °C
Address 8B: Adaptive Cruise 2
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H32 0041
   Serial number: 005000120901147
   Coding: 03C198180111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 2809F87A627D7B7BE73-807C
0028 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [ESP_ESP_01_Signal_Error]
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:45
                    Control Module temperature: 38.0 °C
0046 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC_timeout]
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:45
                    Voltage terminal 15: 12.4 V
0049 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Airbag_Airbag_01_System_error]
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:45
0173 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [APS_Signal_Error_Master]
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:45
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F151E51A73AB330D-8064
12583680 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:44
12583693 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:44
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
          U1111 00 [009] - -
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:44
          U1111 00 [009] - -
                    Reset counter: 232
                    Mileage: 101760 km
                    Date: 2021.04.07
                    Time: 00:14:44
End----------(Elapsed Time: 02:50, VBatt start/end: 12.2V/12.2V)-----------
Hi and welcome.
I would start with this:
6455 - ECM Power Relay Control Circuit P0687 00 [037] - Short to Plus
"Short to Plus" can often mean no connection to ground on the other side.
Fattues111
Las Vegas, USA
C?ID=380963
thanks ill look at the ground leads
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Also could be Relay bad, I have seen this , There is a relay next to ECU
Fattues111
Las Vegas, USA
C?ID=380963
i swapped them around.still no luck .thanks
