RNS510 + Bluetooth Upgrade - VW Polo 6R (no Bluetooth signal)
Mick.Conway
C?ID=266600
Just a quick update on this Bluetooth problem. I purchased a 5K0035730D module and did the swap using my existing harness. As predicted by @iichel it was plug and play and my phone was quickly paired. Only one remaining issue. For reasons I don’t understand I can hear callers, but they can’t hear me. The microphone is functioning, but not audible to anyone.
Before I swap the part it would helpful to ensure that I have not made an error in installing, coding or adaption that could cause this problem. The present microphone links into the harness close to the BT module plug. I have a choice of two connections, one leading to the head unit and one to the BT module. I chose the latter and as a result can see the microphone function in measuring blocks for module 77, but get a fault code for module 56. Switching off the antenna monitoring function of module 56 removes the fault code, but may have unintended consequences.
If need be I can use the aux-in of the factor quad lock to wire in an alternative mic, but hope to avoid the need to remove and reinstall more cables.
I’ll attach controller channel maps for 56 and 77 for reference. If you can spot an error in the installation this would be very my apprevisited.
langers2k
C?ID=224085
It depends if you want voice control on your RNS-510.
- If you don't want VC, connect the mic directly to the BT module
- If you do want VC, the mic needs to connect to the RNS-510 then there should be mic wiring between the RNS-510 and BT module
This diagram might help: https://www.golfmk6.com/forums/index.php?threads/rns-510-voice-command.222171/
Coding will depend which option you choose :)
Mick.Conway
C?ID=266600
Thanks @langers2k, that’s very helpful. I’ll review this information.
Regards Mick
Mick.Conway
C?ID=266600
Telephone controler map
;SW:5K0-035-730-D HW:5K0-035-730-D --- Telephone
;Component:TELEFON H09 2902Coding:0200000000010110
;EV_UHVNAA01719EV_UHVNA_A01_VW25.rod
;Tuesday
11​
May
2021​
07:13:33:03412
;VCDS Version: Release 21.3.0 (x64) Data version: 20210226 DS325.0
;VCID: 2643906259EA59BB99-8072
IDE00689-Name of universal cell phone package (UHV)VW PHONE
31​
IDE00758-Base volume of telephone+ 0.0dB
1​
IDE00759-Base volume of speech output+0.0dB
1​
IDE00760-Microphone sensitivity+ 00dB
1​
IDE00762-Setting Bluetooth PIN00 00
2​
IDE00764-User profilesDo not erase
1​
IDE00765-Delay of audio output0.0 s
1​
IDE00766-Reference channel delay0 ms
1​
IDE00769-Call number 1 for info call08 00 71 18 11
5​
IDE00770-Number 1 for roadside assistance08 00 77 71 92
5​
IDE00771-Media playback volume+00dB
1​
IDE02122-Developer modenot activated
1​
IDE02330-Call number 2 for info call00 44 80 07 11 81 1F
7​
IDE02331-Number 2 for roadside assistance00 44 80 07 77 19 2F
7​
IDE02504-Bluetooth acknowledgement signalOFF
1​
IDE03481-Emergency telephone number00 00 00 00 00 00 00 00 00
9​
ENG113809-CDMA Detectionnot activated
1​
ENG107578-ENG103154-Masking of Languages-Mask Byte 0/Bit0 Language - Germanvalid
2​
ENG107578-ENG100316-Masking of Languages-Mask Byte 0/Bit1 Language - Englishvalid
2​
ENG107578-ENG103726-Masking of Languages-Mask Byte 0/Bit2 Language - Frenchvalid
2​
ENG107578-ENG103477-Masking of Languages-Mask Byte 0/Bit3 Language - Italianvalid
2​
ENG107578-ENG102676-Masking of Languages-Mask Byte 0/Bit4 Language - Spanishvalid
2​
ENG107578-ENG100258-Masking of Languages-Mask Byte 0/Bit5 Language - Portuguesevalid
2​
ENG107578-ENG99657-Masking of Languages-Mask Byte 0/Bit6 Language - Czechvalid
2​
ENG107578-ENG100762-Masking of Languages-Mask Byte 0/Bit7 Language - Russianvalid
2​
ENG107578-ENG103078-Masking of Languages-Mask Byte 1/Bit0 Language - US-Englishvalid
2​
ENG107578-ENG99208-Masking of Languages-Mask Byte 1/Bit1 Language - French-Canadianinvalid
2​
ENG107578-ENG99771-Masking of Languages-Mask Byte 1/Bit2 Language - US-Spanishinvalid
2​
ENG107578-ENG99829-Masking of Languages-Mask Byte 1/Bit3 Language - Dutchvalid
2​
ENG107578-ENG111964-Masking of Languages-Mask Byte 1/Bit4 Language - Swedishvalid
2​
ENG107578-ENG111965-Masking of Languages-Mask Byte 1/Bit5 Language - Polishvalid
2​
ENG107578-ENG111966-Masking of Languages-Mask Byte 1/Bit6 Language - Norwegianvalid
2​
ENG107578-ENG111967-Masking of Languages-Mask Byte 1/Bit7 Language - Turkishvalid
2​
Mick.Conway
C?ID=266600
Radio Controller Map
;SW:1T0-035-686-F HW:1T0-035-686-F --- Radio
;Component:RNS-MID H31 6276Coding:0C010400040000800001
;Tuesday
11​
May
2021​
07:14:45:03412
;VCID: 377D4D268640D03332-8062
ChannelField 1Field 2Field 3Field 4
1​
ERROR:Channel 01NotAvailable
2​
ERROR:Channel 02NotAvailable
3​
ERROR:Channel 03NotAvailable
4​
ERROR:Channel 04NotAvailable
5​
ERROR:Channel 05NotAvailable
6​
ERROR:Channel 06NotAvailable
7​
ERROR:Channel 07NotAvailable
8​
ERROR:Channel 08NotAvailable
9​
ERROR:Channel 09NotAvailable
10​
0​
N/AN/AN/AN/A
11​
ERROR:Channel 11NotAvailable
12​
0​
N/AN/AN/AN/A
13​
0​
N/AN/AN/AN/A
14​
0​
N/AN/AN/AN/A
15​
0​
N/AN/AN/AN/A
16​
0​
N/AN/AN/AN/A
17​
0​
N/AN/AN/AN/A
18​
ERROR:Channel 18NotAvailable
19​
255​
N/AN/AN/AN/A
20​
0​
N/AN/AN/AN/A
21​
ERROR:Channel 21NotAvailable
22​
ERROR:Channel 22NotAvailable
23​
ERROR:Channel 23NotAvailable
24​
ERROR:Channel 24NotAvailable
25​
ERROR:Channel 25NotAvailable
26​
ERROR:Channel 26NotAvailable
27​
ERROR:Channel 27NotAvailable
28​
ERROR:Channel 28NotAvailable
29​
ERROR:Channel 29NotAvailable
30​
ERROR:Channel 30NotAvailable
31​
ERROR:Channel 31NotAvailable
32​
ERROR:Channel 32NotAvailable
33​
ERROR:Channel 33NotAvailable
34​
ERROR:Channel 34NotAvailable
35​
ERROR:Channel 35NotAvailable
36​
ERROR:Channel 36NotAvailable
37​
ERROR:Channel 37NotAvailable
38​
ERROR:Channel 38NotAvailable
39​
ERROR:Channel 39NotAvailable
40​
ERROR:Channel 40NotAvailable
41​
ERROR:Channel 41NotAvailable
42​
ERROR:Channel 42NotAvailable
43​
0​
N/AN/AN/AN/A
44​
0​
N/AN/AN/AN/A
45​
ERROR:Channel 45NotAvailable
46​
ERROR:Channel 46NotAvailable
47​
ERROR:Channel 47NotAvailable
48​
ERROR:Channel 48NotAvailable
49​
ERROR:Channel 49NotAvailable
50​
0​
N/AN/AN/AN/A
51​
ERROR:Channel 51NotAvailable
52​
ERROR:Channel 52NotAvailable
53​
ERROR:Channel 53NotAvailable
54​
ERROR:Channel 54NotAvailable
55​
ERROR:Channel 55NotAvailable
56​
ERROR:Channel 56NotAvailable
57​
ERROR:Channel 57NotAvailable
58​
ERROR:Channel 58NotAvailable
59​
ERROR:Channel 59NotAvailable
60​
ERROR:Channel 60NotAvailable
61​
ERROR:Channel 61NotAvailable
62​
ERROR:Channel 62NotAvailable
63​
ERROR:Channel 63NotAvailable
64​
ERROR:Channel 64NotAvailable
65​
ERROR:Channel 65NotAvailable
66​
ERROR:Channel 66NotAvailable
67​
ERROR:Channel 67NotAvailable
68​
ERROR:Channel 68NotAvailable
69​
ERROR:Channel 69NotAvailable
70​
ERROR:Channel 70NotAvailable
71​
ERROR:Channel 71NotAvailable
72​
ERROR:Channel 72NotAvailable
73​
ERROR:Channel 73NotAvailable
74​
ERROR:Channel 74NotAvailable
75​
ERROR:Channel 75NotAvailable
76​
ERROR:Channel 76NotAvailable
77​
ERROR:Channel 77NotAvailable
78​
ERROR:Channel 78NotAvailable
79​
ERROR:Channel 79NotAvailable
80​
ERROR:Channel 80NotAvailable
81​
ERROR:Channel 81NotAvailable
82​
ERROR:Channel 82NotAvailable
83​
ERROR:Channel 83NotAvailable
84​
ERROR:Channel 84NotAvailable
85​
ERROR:Channel 85NotAvailable
86​
ERROR:Channel 86NotAvailable
87​
ERROR:Channel 87NotAvailable
88​
ERROR:Channel 88NotAvailable
89​
ERROR:Channel 89NotAvailable
90​
ERROR:Channel 90NotAvailable
91​
ERROR:Channel 91NotAvailable
92​
ERROR:Channel 92NotAvailable
93​
ERROR:Channel 93NotAvailable
94​
ERROR:Channel 94NotAvailable
95​
ERROR:Channel 95NotAvailable
96​
ERROR:Channel 96NotAvailable
97​
ERROR:Channel 97NotAvailable
98​
ERROR:Channel 98NotAvailable
99​
ERROR:Channel 99NotAvailable
100​
ERROR:Channel 100NotAvailable
101​
ERROR:Channel 101NotAvailable
102​
ERROR:Channel 102NotAvailable
103​
ERROR:Channel 103NotAvailable
104​
ERROR:Channel 104NotAvailable
105​
ERROR:Channel 105NotAvailable
106​
ERROR:Channel 106NotAvailable
107​
ERROR:Channel 107NotAvailable
108​
ERROR:Channel 108NotAvailable
109​
ERROR:Channel 109NotAvailable
110​
ERROR:Channel 110NotAvailable
111​
0​
N/AN/AN/AN/A
112​
ERROR:Channel 112NotAvailable
113​
ERROR:Channel 113NotAvailable
114​
ERROR:Channel 114NotAvailable
115​
ERROR:Channel 115NotAvailable
116​
ERROR:Channel 116NotAvailable
117​
ERROR:Channel 117NotAvailable
118​
ERROR:Channel 118NotAvailable
119​
ERROR:Channel 119NotAvailable
120​
ERROR:Channel 120NotAvailable
121​
0​
N/AN/AN/AN/A
122​
ERROR:Channel 122NotAvailable
123​
ERROR:Channel 123NotAvailable
124​
ERROR:Channel 124NotAvailable
125​
0​
N/AN/AN/AN/A
126​
ERROR:Channel 126NotAvailable
127​
ERROR:Channel 127NotAvailable
128​
ERROR:Channel 128NotAvailable
129​
ERROR:Channel 129NotAvailable
130​
2​
N/AN/AN/AN/A
131​
3​
N/AN/AN/AN/A
132​
6​
N/AN/AN/AN/A
133​
5​
N/AN/AN/AN/A
134​
0​
N/AN/AN/AN/A
135​
ERROR:Channel 135NotAvailable
136​
ERROR:Channel 136NotAvailable
137​
ERROR:Channel 137NotAvailable
138​
ERROR:Channel 138NotAvailable
139​
ERROR:Channel 139NotAvailable
140​
ERROR:Channel 140NotAvailable
141​
ERROR:Channel 141NotAvailable
142​
ERROR:Channel 142NotAvailable
143​
ERROR:Channel 143NotAvailable
144​
ERROR:Channel 144NotAvailable
145​
ERROR:Channel 145NotAvailable
146​
ERROR:Channel 146NotAvailable
147​
ERROR:Channel 147NotAvailable
148​
ERROR:Channel 148NotAvailable
149​
ERROR:Channel 149NotAvailable
150​
ERROR:Channel 150NotAvailable
151​
ERROR:Channel 151NotAvailable
152​
ERROR:Channel 152NotAvailable
153​
ERROR:Channel 153NotAvailable
154​
ERROR:Channel 154NotAvailable
155​
ERROR:Channel 155NotAvailable
156​
ERROR:Channel 156NotAvailable
157​
ERROR:Channel 157NotAvailable
158​
ERROR:Channel 158NotAvailable
159​
ERROR:Channel 159NotAvailable
160​
ERROR:Channel 160NotAvailable
161​
ERROR:Channel 161NotAvailable
162​
ERROR:Channel 162NotAvailable
163​
ERROR:Channel 163NotAvailable
164​
ERROR:Channel 164NotAvailable
165​
ERROR:Channel 165NotAvailable
166​
ERROR:Channel 166NotAvailable
167​
ERROR:Channel 167NotAvailable
168​
ERROR:Channel 168NotAvailable
169​
ERROR:Channel 169NotAvailable
170​
ERROR:Channel 170NotAvailable
171​
ERROR:Channel 171NotAvailable
172​
ERROR:Channel 172NotAvailable
173​
ERROR:Channel 173NotAvailable
174​
ERROR:Channel 174NotAvailable
175​
ERROR:Channel 175NotAvailable
176​
ERROR:Channel 176NotAvailable
177​
ERROR:Channel 177NotAvailable
178​
ERROR:Channel 178NotAvailable
179​
ERROR:Channel 179NotAvailable
180​
ERROR:Channel 180NotAvailable
181​
ERROR:Channel 181NotAvailable
182​
ERROR:Channel 182NotAvailable
183​
ERROR:Channel 183NotAvailable
184​
ERROR:Channel 184NotAvailable
185​
ERROR:Channel 185NotAvailable
186​
ERROR:Channel 186NotAvailable
187​
ERROR:Channel 187NotAvailable
188​
ERROR:Channel 188NotAvailable
189​
ERROR:Channel 189NotAvailable
190​
ERROR:Channel 190NotAvailable
191​
ERROR:Channel 191NotAvailable
192​
ERROR:Channel 192NotAvailable
193​
ERROR:Channel 193NotAvailable
194​
ERROR:Channel 194NotAvailable
195​
ERROR:Channel 195NotAvailable
196​
ERROR:Channel 196NotAvailable
197​
ERROR:Channel 197NotAvailable
198​
ERROR:Channel 198NotAvailable
199​
ERROR:Channel 199NotAvailable
200​
ERROR:Channel 200NotAvailable
201​
ERROR:Channel 201NotAvailable
202​
ERROR:Channel 202NotAvailable
203​
ERROR:Channel 203NotAvailable
204​
ERROR:Channel 204NotAvailable
205​
ERROR:Channel 205NotAvailable
206​
ERROR:Channel 206NotAvailable
207​
ERROR:Channel 207NotAvailable
208​
ERROR:Channel 208NotAvailable
209​
ERROR:Channel 209NotAvailable
210​
ERROR:Channel 210NotAvailable
211​
ERROR:Channel 211NotAvailable
212​
ERROR:Channel 212NotAvailable
213​
ERROR:Channel 213NotAvailable
214​
ERROR:Channel 214NotAvailable
215​
ERROR:Channel 215NotAvailable
216​
ERROR:Channel 216NotAvailable
217​
ERROR:Channel 217NotAvailable
218​
ERROR:Channel 218NotAvailable
219​
ERROR:Channel 219NotAvailable
220​
ERROR:Channel 220NotAvailable
221​
ERROR:Channel 221NotAvailable
222​
ERROR:Channel 222NotAvailable
223​
ERROR:Channel 223NotAvailable
224​
ERROR:Channel 224NotAvailable
225​
ERROR:Channel 225NotAvailable
226​
ERROR:Channel 226NotAvailable
227​
ERROR:Channel 227NotAvailable
228​
ERROR:Channel 228NotAvailable
229​
ERROR:Channel 229NotAvailable
230​
ERROR:Channel 230NotAvailable
231​
ERROR:Channel 231NotAvailable
232​
ERROR:Channel 232NotAvailable
233​
ERROR:Channel 233NotAvailable
234​
ERROR:Channel 234NotAvailable
235​
ERROR:Channel 235NotAvailable
236​
ERROR:Channel 236NotAvailable
237​
ERROR:Channel 237NotAvailable
238​
ERROR:Channel 238NotAvailable
239​
ERROR:Channel 239NotAvailable
240​
ERROR:Channel 240NotAvailable
241​
ERROR:Channel 241NotAvailable
242​
ERROR:Channel 242NotAvailable
243​
ERROR:Channel 243NotAvailable
244​
ERROR:Channel 244NotAvailable
245​
ERROR:Channel 245NotAvailable
246​
ERROR:Channel 246NotAvailable
247​
ERROR:Channel 247NotAvailable
248​
ERROR:Channel 248NotAvailable
249​
ERROR:Channel 249NotAvailable
250​
ERROR:Channel 250NotAvailable
251​
ERROR:Channel 251NotAvailable
252​
ERROR:Channel 252NotAvailable
253​
ERROR:Channel 253NotAvailable
254​
ERROR:Channel 254NotAvailable
255​
ERROR:Channel 255NotAvailable
Mick.Conway
C?ID=266600
@langers2k , thanks for the information. My top priority is to get the phone microphone working. Voice control would be nice, but right now I would rather not disassemble the installation again, unless I have messed up. In hindsight I wish I has fitted an RNS315 with built-in BT. I have this in our Mk5 GTI and it was so simple by comparison.
Any advice you can provide for my current installation and microphone wired to the BT unit would be appreciated.
Regards Mick
Mick.Conway
C?ID=266600
Thank you @Dana , I will try this first thing tomorrow.
Regards Mick
