Dynamic environmental data - what is it?
As the title implies, I'm trying to understand the part of the DTC detail information that's labelled "Dynamic environmental data".
The entry sometimes appears in the list of other fault event measurements and its value seems to be a string of hexadecimal numbers - but with a variable Byte count (I think) .
Here's some examples taken from random auto-scans that have been posted on the forum:
  • Dynamic environmental data: 20 96
  • Dynamic environmental data: 0000001812000000AB000000000000F702430D01010010
  • Dynamic environmental data: 02 8D
Does anyone know what this entry is attempting to display and how to interpret the Byte values? For example, is it a historic list of readiness Bits - maybe?
Thanks in advance
iichel
Eindhoven, NB, NL
C?ID=284912
In what module is this found? Given that it's you, it's probably 5Q0 MQB, but apart from that... :)
hahaha.... yes I do tend to gravitate to MQB cars - but Dynamic environmental data is not peculiar to this platform type. From the little that I can glean (which ain't much), the DTC entry might be something that's defined by an OBD standard -perhaps (but this is a wild guess at best).
The DTC entry also seems to be module non-specific; it appears across ALL modules (I think)
Here's examples from auto-scans that have been posted on the forum which contain the curious entry (ain't nothing special about these- just selected at random)
Audi S3
01 Engine Control Module 1
System description: 2.0l R4 TFSI
Software number: 8V0906259
Software version: 0007
Hardware number: 06K907425A
Hardware version: H09
ODX name: EV_ECM20TFS0218V0906259
ODX version: 001009
Long coding: 0A1D00322426010B2000
Trouble codes:
P164700 - Checking coding/versions of control modules in drivetrain
static
Date: 2020-01-25 16:59:37
Mileage: 70227 km
Priority: 2
Malfunction frequency counter: 11
Unlearning counter: 255
Engine speed: 0.00 1/min
Coolant temperature: 95 °C
Intake air temperature: 30 °C
Voltage terminal 30: 12.207 V
Dynamic environmental data: 209628416F01416D0143832000416C00
2017 Jetta
Address 01: Engine (J623-CPRA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 906 071 BE HW: 06K 907 425 C
Component: R4 1.8l TFS H13 3683
Revision: --H13---
Coding: 001A0092244400175000
Shop #: WSC 00066 790 00015
ASAM Dataset: EV_ECM18TFS02006K906071BE 001005
ROD: EV_ECM18TFS02006K906071BE.rod
VCID: 6FEDB228B6A69B3E78-803A
17176 - Databus
17178 - Databus
23955 - Active Radiator Shutter 1
P05A3 00 [168] - Implausible Signal
Mileage: 29502 km
Date: 2017.12.12
Time: 18:47:41
Engine speed: 753.75 /min
Normed load value: 14.5 %
Vehicle speed: 17 km/h
Coolant temperature: 44 ∞C
Intake air temperature: -4 ∞C
Voltage terminal 30: 14.765 V
Engine: operating status: IS
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 206 s
MAP_MES_SAE: 33 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 10.937500 %
FUP_H_SAE: 6620.0 kPa
VW Arteon
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 32057FDB5DFFC728949C812481400600000000000000000000
   Shop #: WSC 05311 115 00061
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   ROD: EV_ACCBOSCHVW416.rod
   VCID: 3E30E78CA1569CB6A3-806A
1538 - Sensor for Automatic Distance Control
          U4EC550 F0 [008] - Limited Visibility
                    Fault Frequency: 22
                    Reset counter: 175
                    Mileage: 2956 km
                    Date: 2017.11.11
                    Time: 15:10:55
                    Control Module temperature: 17 °C
                    Voltage terminal 15: 14.3 V
                    Velocity_vehicle_reference: 8.72 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.72 m/s²
1396 - Sensor for Automatic Distance Control
                    Fault Frequency: 13
                    Reset counter: 175
                    Mileage: 2999 km
                    Date: 2017.11.11
                    Time: 20:02:39
                    Control Module temperature: 2 °C
                    Voltage terminal 15: 11.5 V
                    Longitudinal_acceleration_vehicle_reference: -0.00 m/s²
                    Status_ACC_System: ACC_Init
Hope someone can help decipher this mysterious measurement!
Does ODIS provide any decipherment for this?
Because if it doesn't, I'm not sure how anyone is supposed to figure out what it means. ;)
Eric
HC800000
It does not. I think it's something the module manufacturer puts in there when there isn't a readily available formula for it, and they feel only they would ever need to decode it.
@Uwe, @Eric : Many thanks for responding - I guess the mysterious measurement will never be understood by us mere mortals (I will add it to the increasing number of "known unknowns" (to quote a famous American) on my too-hard list
NEtech
Denmark
C?ID=56995
These are not good examples, they are not made with VCDS.
If they where made with VCDS, I would think, the extra freeze frame data where showed, like this random example:
T_AST_SAE: 206 s
MAP_MES_SAE: 33 kPa
The 2 Byte, it is maybe something about the current controller:
[01] = 20 96
[08] = 02 86
[13] = 02 85
[13] = 02 8D
[5F] = 02 86
@NEtech: Brilliant - thanks for the insight! Yes, you could be correct that Byte 0 -1 is some kind of module address identifier.
However, why it takes 2 x Bytes (i.e. 65,536 different states) for this purpose is more than a tad strange! And, the 2 x different entries for hex13 module in your post suggests that something more is happening in these 2 x Bytes.
So, if I could press you further and just to be clear - are you suggesting that "other", non-VCDS devices report different (i.e. larger Byte-count) values for Dynamic environmental data entry?
NEtech
Denmark
C?ID=56995
I don't know what other tester show or not show, but the 2 examples you showed, seems to come from this thread.
And from the text, it is from obdeleven.
Do you have any VCDS Autoscan where similair "Dynamic environmental data" is showed ?
