Emissions Readiness Monitors
   #21
dantev03
Maryland, USA
C?ID=419176
Ok, so the oil cap is not hard to pull off at idle, there is definitely vacuum present, but not enough to cause the oil cap to be stuck on the valve cover. I have noticed that during the summer months, the problem seems to be getting worse. Here are the codes stored in the engine.
Wednesday,23,June,2021,11:59:57:03955
VIN: 3VWRJ71K09M044004   License Plate:
                Address 01: Engine       Labels: 06J-906-026-CCT.clb
Control Module Part Number: 1K0 907 115 AE    HW: 1K0 907 115 AA
  Component and/or Version: 2.0l R4/4V TFSI     0040
           Software Coding: 0403010A18070160
            Work Shop Code: WSC 09130 444 100827
                      VCID: 698FB9630579157338D-803C
000369 - Fuel Trim; Bank 1
               P0171 - 000 - System Too Lean - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 287829 km
                    Time: 19:05:30
                    RPM: 835 /min
                    Load: 19.6 %
                    Temperature: 64.0°C
                    Temperature: 32.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.462 V
001287 - Idle Control System RPM
               P0507 - 000 - Higher than Expected. - Intermittent
                    Mileage: 288387 km
                    Time: 23:52:58
                    RPM: 926 /min
                    Load: 15.3 %
                    Temperature: 99.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.589 V
Readiness: 0010 0001
If you guys could give me any kind of advice on what the problem could be, it would be much appreciated. The engine doesn't go straight back to idle after I take it out of gear, it will slowly rise until the car corrects for the idle. I am thinking it could possibly be the MAF sensor but I would need to know some ways of testing it to confirm. I really want to get this problem fixed so I can take it on road trips and enjoy time for a little while. I just got done replacing the ignition switch in the car, so that's one problem down. This is the only major problem left.
   #22
Those codes, especially together, are very much indicative of unmetered air getting into the engine somewhere past the MAF and past the throttle body.
dantev03
Maryland, USA
C?ID=419176
Ok, so what parts are likely to be causing this? Is there a test I can do to identify the faulty part? I just need some direction on where it could be especially because it is very intermittent.
   #24
Here are a couple suggestions: I would post a full Auto-scan , you never know what someone may see and prompt you to check - which may lead you to your problem.
You most likely have a vacuum leak ; check all hoses and their connections and around the intake manifold ; where it contacts the cylinder head.
Here is a video that may give you some ideas: It is all relevant , but note 5:45 that may help you find a leak.
   #25
dantev03
Maryland, USA
C?ID=419176
Alright, I'll post a full auto scan as soon as the codes come back. I cleared them after I disconnected the battery for the ignition switch. They will probably come back later today. Thanks for the video, I'll take a look tomorrow and hopefully figure this out. I really appreciate all the help.
   #26
dantev03
Maryland, USA
C?ID=419176
Here is the full auto scan,
Tuesday,29,June,2021,12:19:02:03955
Mileage: 288820km-179464mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRJ71K09M044004   Mileage: 288820km-179464miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 1K0 907 115 AE    HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0040
   Revision: AAH17---    Serial number: VWX7Z0H724U0Z5
   Shop #: WSC 09130 444 100827
               P0171 - 000 - System Too Lean - MIL ON
                    Fault Status: 11100000
                    Mileage: 288440 km
                    Time: 07:09:01
                    RPM: 838 /min
                    Load: 20.8 %
                    Temperature: 70.0°C
                    Temperature: 31.0°C
                    Voltage: 13.589 V
                    Mileage: 288492 km
                    Time: 04:39:51
                    RPM: 891 /min
                    Load: 14.9 %
                    Temperature: 97.0°C
                    Temperature: 38.0°C
                    Voltage: 13.462 V
   Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
   Revision: 00H35001
   Coding: 113B600D492600FE880B06E4921D00413000
   Shop #: WSC 56224 002 104857
   VCID: 76B5E21F48C7CA8BA5F-8022
01130 - ABS Operation
                    Fault Status: 01101000
                    Reset counter: 128
                    Mileage: 287818 km
                    Count: 4608
                    Count: 125
                    Count: 47630
                    Count: 65277
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   VCID: 7CA1F0377AEB90DBD3B-8028
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000001061404
   Coding: 04058E234004150007140000001400000008730B5C000120000000000000
   Shop #: WSC 00066 000 00000
   VCID: 323D1E0FE82F96AB497-8066
   Component: Wischer 020908 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0404057
   Coding: 0000100
   VCID: 33331B0B17359FA3421-8066
                    Reset counter: 114
                    Mileage: 287503 km
                    Time: 19:46:56
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M06L2M7
   Coding: 0013889
   VCID: 6C81C0770A8B005B43B-8038
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME3753362DD
   Subsystem 3 - Serial number: 6342MSME38760D6FU
   Subsystem 4 - Serial number: 6351HSME17194125/
   Subsystem 5 - Serial number: 6361HSME174A5B48I
   Subsystem 6 - Serial number: 63727SME173C5D5EK
   Subsystem 7 - Serial number: 63827SME17476B01+
   Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
   Coding: 0000021
   VCID: 03538BCB0715EF23921-8056
   Part No SW: 1K0 920 954 R    HW: 1K0 920 954 R
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0003000    Serial number: VWX7Z0H724U0Z5
   Coding: 0023203
   VCID: 3B23332B3F6557E39A1-806E
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 090708F2002568
   Coding: E9807F070003021002
   VCID: 35372513194181936C5-8060
   Component: IMMO            3HL 1222
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000789088816
   Coding: 0001205
   VCID: 6FBBD77B3B9DFB43669-803A
00109 - Left Mirror Turn Signal Lamp (L131)
                    Fault Status: 01101100
                    Reset counter: 170
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A0D066FC0FFDE6BF17-807E
   Coding: 13900F880186083F0904058FB0880F0488DCA0
   Shop #: WSC 00066 123 12345
   VCID: 045188D7021BE81BABB-8050
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 08073102471002
   Coding: 0001204
   VCID: 70B9D40726A3E4BB7F3-8024
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio ZSW       019 0035
   Revision: 00019000    Serial number: VWZ5Z7H6080280
   Coding: 0040401
   VCID: 290FF963C5F9D573F8D-807C
00856 - Radio Antenna
                    Fault Frequency: 50
                    Reset counter: 169
                    Mileage: 287607 km
                    Time: 13:42:46
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003424891
   Coding: 0001168
   VCID: 76B5E21F44C7CA8BA5F-8022
   Coding: 0100101
                    Reset counter: 150
                    Mileage: 288362 km
                    Time: 11:06:47
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003406787
   Coding: 0001168
   VCID: 77ABEF1B43CDB383BE9-8022
End----------(Elapsed Time: 01:22, VBatt start/end: 13.6V/13.6V)-----------
   #27
VIN Number
3VWRJ71K09M044004
Make
VOLKSWAGEN
Model
Jetta
Model Year
2009
Drive Type
Manufacturer
VOLKSWAGEN GROUP OF AMERICA, INC.
Engine
1.984000
Style/Body
Sedan/Saloon
Age
10
Manufactured CompnayVOLKSWAGEN GROUP OF AMERICA, INC.
Plant Company Name
Vehicle TypePASSENGER CAR
Series-
Body ClassSedan/Saloon
Doors4
Engine (CI)121.071108283
Engine (CC)1984
Fuel TypeGasoline
Cylinders4
   #28
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
Everyone is telling you false air (vacuum leak).
Even a video on understanding fuel trim to find a vac. leak.
All the auto scan tells us is ECU see's false air.
What are the fuel trims? How to answer that is in the video.
Good Luck
   #29
dantev03
Maryland, USA
C?ID=419176
Ok, So I took a test drive and made a log of the fuel trims. The fuel trims actually look pretty good. The load fuel trim looks ok. The idle fuel trim varies an incredible amount. I placed a mark when I turned on the A/C. The fuel trims shot up after I turned it on. The trims before the mark are fuel trims without A/C.
Monday    12    July    2021    17:43:48:03955-VCID:698FB9630579157338D-803C    VCDS Version: Release 21.3.0 (x64)    Data version: 20210226 DS325.0
1K0 907 115 AE        2.0l R4/4V TFSI     0040
    Group A:    '032                Group B:    '033                Group C:     Not Running
        Adaptation (Idle)    Adaptation (Partial)                  Lambda Control    Sensor Voltage
    TIME    Bank 1 Sensor 1    Bank 1 Sensor 1            TIME    Bank 1 Sensor 1    Bank 1 Sensor 1            TIME
Marker    STAMP     %     %            STAMP     %     V            STAMP
    0.01    5.4    -4.7              0.14    1.2    1.41
    0.28    5.4    -4.7              0.43    1.2    1.41
    0.57    5.4    -4.7              0.73    0.8    1.41
    0.88    5.4    -4.7              1.04    0.8    1.39
    1.2    5.4    -4.7              1.34    0.4    1.39
    1.48    5.4    -4.7              1.63    0.4    1.41
    1.78    5.4    -4.7              1.93    0.4    1.43
    2.08    5.4    -4.7              2.24    -3.1    1.43
    2.4    5.4    -4.7              2.55    -3.1    1.45
    2.71    5.4    -4.7              2.87    -3.1    1.46
    3.01    5.4    -4.7              3.15    -3.5    1.5
    3.3    5.4    -4.7              3.45    -3.5    1.5
    3.6    5.4    -4.7              3.75    -3.5    1.54
    3.89    5.4    -4.7              4.05    -3.1    1.54
    4.21    5.4    -4.7              4.37    -2.7    1.54
    4.52    5.4    -4.7              4.68    -2.3    1.54
    4.84    5.4    -4.7              5    -2.3    1.52
    5.15    5.4    -4.7              5.31    -2.7    1.52
    5.45    5.4    -4.7              5.59    -2.7    1.5
    5.75    5.4    -4.7              5.9    -2.7    1.52
    6.06    5.4    -4.7              6.21    0.8    1.52
    6.36    5.4    -4.7              6.52    0.8    1.52
    6.69    5.4    -4.7              6.84    1.2    1.52
    6.99    5.4    -4.7              7.15    1.6    1.46
    7.31    5.4    -4.7              7.47    1.6    1.43
    7.62    5.4    -4.7              7.77    1.2    1.41
    7.92    5.4    -4.7              8.06    1.2    1.41
    8.2    5.4    -4.7              8.35    1.2    1.39
    8.5    5.4    -4.7              8.64    0.8    1.39
    8.8    5.4    -4.7              8.96    0.8    1.41
    9.13    5.4    -4.7              9.28    0.8    1.41
    9.44    5.4    -4.7              9.59    0.4    1.41
    9.73    5.4    -4.7              9.88    0.4    1.41
    10.03    5.4    -4.7              10.17    0    1.41
    10.31    5.4    -4.7              10.46    -3.1    1.43
    10.61    5.4    -4.7              10.78    -3.1    1.46
    10.93    5.4    -4.7              11.09    -3.5    1.48
    11.25    5.4    -4.7              11.4    -3.5    1.5
    11.56    5.4    -4.7              11.71    -3.5    1.52
    11.87    5.4    -4.7              12.01    -3.1    1.54
    12.16    5.4    -4.7              12.31    -3.1    1.56
    12.46    5.4    -4.7              12.62    -2.7    1.54
    12.77    5.4    -4.7              12.92    -2.7    1.54
    13.06    5.4    -4.7              13.21    -2.3    1.54
    13.37    5.4    -4.7              13.53    -2.3    1.54
    13.68    5.4    -4.7              13.84    1.6    1.54
    14    5.4    -4.7              14.17    1.6    1.52
    14.32    5.4    -4.7              14.47    1.6    1.48
    14.64    5.4    -4.7              14.78    1.6    1.46
    14.93    5.4    -4.7              15.09    1.6    1.45
    15.24    5.4    -4.7              15.4    1.6    1.43
    15.56    5.4    -4.7              15.71    1.6    1.41
    15.86    5.4    -4.7              16.02    1.2    1.39
    16.17    5.4    -4.7              16.31    1.2    1.39
    16.47    5.4    -4.7              16.61    1.2    1.41
    16.78    5.4    -4.7              16.93    0.8    1.41
    17.09    5.4    -4.7              17.24    0.8    1.41
    17.4    5.4    -4.7              17.55    0.8    1.41
    17.69    5.4    -4.7              17.84    -2.7    1.41
    17.99    5.4    -4.7              18.14    -3.1    1.43
    18.3    5.4    -4.7              18.46    -3.1    1.48
    18.63    5.4    -4.7              18.79    -3.1    1.52
    18.95    5.4    -4.7              19.09    -3.1    1.52
    19.24    5.4    -4.7              19.37    -2.7    1.54
    19.51    5.4    -4.7              19.65    -2.7    1.54
    19.8    5.4    -4.7              19.95    -2.7    1.54
    20.09    5.4    -4.7              20.24    -2.3    1.54
    20.39    5.4    -4.7              20.54    -2.3    1.54
    20.69    5.4    -4.7              20.85    -2.3    1.52
    21.01    5.4    -4.7              21.17    -2.3    1.52
    21.32    5.4    -4.7              21.47    -2    1.52
    21.63    5.4    -4.7              21.79    1.2    1.52
    21.94    5.4    -4.7              22.1    1.2    1.5
    22.25    5.4    -4.7              22.39    0.8    1.43
    22.55    5.4    -4.7              22.71    0.8    1.43
    22.86    5.4    -4.7              23.02    0.8    1.43
    23.18    5.4    -4.7              23.34    0.8    1.41
    23.49    5.4    -4.7              23.65    0.4    1.43
    23.81    5.4    -4.7              23.97    0.4    1.43
    24.12    5.4    -4.7              24.27    0.4    1.43
    24.43    5.4    -4.7              24.59    0.4    1.41
    24.74    5.4    -4.7              24.9    0.4    1.41
    25.06    5.4    -4.7              25.2    -3.1    1.41
    25.34    5.4    -4.7              25.48    -3.5    1.41
    25.62    5.4    -4.7              25.79    -3.5    1.46
    25.95    5.4    -4.7              26.1    -3.1    1.52
    26.25    5.4    -4.7              26.39    -3.1    1.54
    26.54    5.4    -4.7              26.7    -2.7    1.54
    26.85    5.4    -4.7              27.01    -2.7    1.52
    27.16    5.4    -4.7              27.32    -2.7    1.52
    27.48    5.4    -4.7              27.63    -2.7    1.5
    27.8    5.4    -4.7              27.95    -2.7    1.52
    28.09    5.4    -4.7              28.23    -2.3    1.54
    28.38    5.4    -4.7              28.55    -2.3    1.54
    28.69    5.4    -4.7              28.85    1.6    1.52
    29.01    5.4    -4.7              29.15    1.6    1.52
    29.29    5.4    -4.7              29.44    1.6    1.48
    29.6    5.4    -4.7              29.75    1.2    1.45
    29.89    5.4    -4.7              30.03    1.2    1.43
    30.18    5.4    -4.7              30.33    1.2    1.41
    30.49    5.4    -4.7              30.65    1.2    1.43
    30.82    5.4    -4.7              30.97    1.2    1.43
    31.13    5.4    -4.7              31.28    1.2    1.41
    31.42    5.4    -4.7              31.56    0.8    1.39
    31.71    5.4    -4.7              31.86    0.8    1.41
    32.03    5.4    -4.7              32.18    0.8    1.43
    32.33    5.4    -4.7              32.49    0.8    1.43
    32.65    5.4    -4.7              32.8    -2.7    1.43
    32.95    5.4    -4.7              33.1    -2.7    1.45
    33.25    5.4    -4.7              33.41    -2.7    1.5
    33.57    5.4    -4.7              33.72    -2.7    1.52
    33.88    5.4    -4.7              34.03    -3.1    1.52
    34.17    5.4    -4.7              34.31    -3.1    1.52
    34.46    5.4    -4.7              34.61    -2.7    1.54
    34.77    5.4    -4.7              34.93    -2.7    1.54
    35.08    5.4    -4.7              35.25    -2.3    1.54
    35.4    5.4    -4.7              35.55    -2    1.54
    35.71    5.4    -4.7              35.87    -2    1.54
    36.01    5.4    -4.7              36.17    -2    1.54
    36.31    5.4    -4.7              36.45    2    1.56
    36.61    5.4    -4.7              36.75    2.3    1.52
    36.91    5.4    -4.7              37.07    2.3    1.45
    37.22    5.4    -4.7              37.38    2.3    1.45
    37.54    5.4    -4.7              37.7    2.3    1.43
    37.86    5.4    -4.7              38    2.3    1.45
    38.16    5.4    -4.7              38.31    2.7    1.46
    38.46    5.4    -4.7              38.62    3.1    1.48
    38.77    5.4    -4.7              38.93    3.5    1.46
    39.09    5.4    -4.7              39.25    3.9    1.46
    39.39    5.4    -4.7              39.55    7.4    1.58
    39.71    5.4    -4.7              39.86    5.5    1.43
    40.02    5.4    -4.7              40.18    5.9    1.48
    40.34    5.4    -4.7              40.48    5.5    1.37
    40.62    5.4    -4.7              40.77    4.7    1.37
    40.92    5.4    -4.7              41.07    3.5    1.27
    41.22    5.4    -4.7              41.38    -0.4    1.37
    41.55    5.4    -4.7              41.69    0    1.43
    41.85    5.4    -4.7              42    -2.3    1.11
    42.16    5.4    -4.7              42.32    -6.6    0.8
    42.48    5.4    -4.7              42.63    -9    0.98
    42.79    5.4    -4.7              42.95    -10.2    1.21
    43.11    5.4    -4.7              43.27    -10.9    1.35
    43.42    5.4    -4.7              43.57    -10.5    1.48
    43.72    5.4    -4.7              43.88    -10.2    1.56
    44.04    5.4    -4.7              44.2    -9    1.6
    44.35    5.4    -4.7              44.48    -7.8    1.62
    44.63    5.4    -4.7              44.77    -7    1.62
    44.93    5.4    -4.7              45.06    -6.3    1.6
    45.2    5.4    -4.7              45.35    -5.5    1.6
    45.5    5.4    -4.7              45.67    -1.2    1.58
    45.82    5.4    -4.7              45.98    -0.8    1.56
    46.13    5.4    -4.7              46.29    -0.4    1.54
    46.45    5.4    -4.7              46.6    0.4    1.52
    46.76    5.4    -4.7              46.92    0.8    1.48
    47.06    5.4    -4.7              47.2    1.2    1.46
    47.35    5.4    -4.7              47.48    1.2    1.45
    47.62    5.4    -4.7              47.77    1.2    1.45
    47.92    5.4    -4.7              48.06    1.2    1.41
    48.2    5.4    -4.7              48.35    9.4    1.66
    48.51    5.4    -4.7              48.66    2.7    1.5
    48.83    5.4    -4.7              48.98    5.9    1.5
    49.12    5.4    -4.7              49.26    4.3    1.43
    49.41    5.4    -4.7              49.56    4.7    1.45
    49.7    5.4    -4.7              49.84    4.3    1.41
    49.99    5.4    -4.7              50.14    3.5    1.35
    50.29    5.4    -4.7              50.44    3.9    1.43
    50.6    5.4    -4.7              50.76    3.5    1.35
    50.93    5.4    -4.7              51.09    -2.3    1
    51.23    5.4    -4.7              51.37    -5.5    0.76
    51.52    5.4    -4.7              51.67    -8.2    0.88
    51.82    5.4    -4.7              51.99    -10.2    1.05
    52.14    5.4    -4.7              52.29    -11.3    1.31
    52.44    5.4    -4.7              52.59    -10.9    1.52
    52.73    5.4    -4.7              52.88    -9.4    1.64
    53.03    5.4    -4.7              53.17    -7    1.68
    53.31    5.4    -4.7              53.47    -5.5    1.68
    53.61    5.4    -4.7              53.78    -3.5    1.7
    53.94    5.4    -4.7              54.1    9.8    1.76
    54.24    5.4    -4.7              54.37    -1.6    1.39
    54.52    5.4    -4.7              54.67    14.1    1.7
    54.83    5.4    -4.7              54.97    6.3    1.41
    55.14    5.4    -4.7              55.29    6.3    1.43
    55.45    5.4    -4.7              55.59    5.5    1.37
    55.73    5.4    -4.7              55.88    4.3    1.31
    56.04    5.4    -4.7              56.19    -1.6    1.29
    56.35    5.4    -4.7              56.51    0.8    1.54
    56.67    5.4    -4.7              56.82    -2.3    1.48
    56.98    5.4    -4.7              57.13    7    1.58
    57.3    5.4    -4.7              57.45    3.5    1.35
    57.59    5.4    -4.7              57.73    5.5    1.35
    57.89    5.4    -4.7              58.04    -2.7    1.45
    58.19    5.4    -4.7              58.37    -0.4    1.5
    58.52    5.4    -4.7              58.68    -3.1    1.43
    58.83    5.4    -4.7              58.96    -0.4    1.58
    59.13    5.4    -4.7              59.26    7.4    1.64
    59.42    5.4    -4.7              59.57    -3.1    1.29
    59.74    5.4    -4.7              59.9    -3.1    1.5
    60.04    5.4    -4.7              60.19    -2.7    1.54
    60.34    5.4    -4.7              60.48    -2.3    1.56
    60.63    5.4    -4.7              60.8    2.3    1.46
    60.95    5.4    -4.7              61.1    3.1    1.5
    61.26    5.4    -4.7              61.42    4.7    1.43
    61.57    5.4    -4.7              61.7    5.1    1.46
    61.84    5.4    -4.7              61.98    5.9    1.45
    62.14    5.4    -4.7              62.29    2.3    1.25
    62.45    5.4    -4.7              62.61    -2    1.33
    62.76    5.4    -4.7              62.92    -1.6    1.43
    63.06    5.4    -4.7              63.21    -2.3    1.39
    63.35    5.4    -4.7              63.5    -3.5    1.35
    63.66    5.4    -4.7              63.82    -4.3    1.39
    63.98    5.4    -4.7              64.14    -4.7    1.41
    64.32    5.4    -4.7              64.46    -5.1    1.45
    64.62    5.4    -4.7              64.77    -5.1    1.5
    64.94    5.4    -4.7              65.08    -4.7    1.52
    65.25    5.4    -4.7              65.4    -4.7    1.5
    65.56    5.4    -4.7              65.71    -5.1    1.52
    65.84    5.4    -4.7              65.98    -4.7    1.54
    66.14    5.4    -4.7              66.28    -3.9    1.58
    66.45    5.4    -4.7              66.6    -3.1    1.6
    66.76    5.4    -4.7              66.91    -2    1.62
    67.07    5.4    -4.7              67.22    -1.2    1.62
    67.38    5.4    -4.7              67.54    3.1    1.6
    67.7    5.4    -4.7              67.85    3.9    1.56
    68    5.4    -4.7              68.15    4.3    1.5
    68.3    5.4    -4.7              68.44    4.3    1.45
    68.57    5.4    -4.7              68.73    3.9    1.41
    68.88    5.4    -4.7              69.01    3.5    1.41
    69.16    5.4    -4.7              69.32    3.5    1.41
    69.47    5.4    -4.7              69.63    3.5    1.43
    69.79    5.4    -4.7              69.94    3.5    1.43
    70.08    5.4    -4.7              70.24    3.5    1.43
    70.39    5.4    -4.7              70.55    3.5    1.43
    70.71    5.4    -4.7              70.87    3.5    1.45
    71.03    5.4    -4.7              71.18    3.9    1.43
    71.31    5.4    -4.7              71.45    3.9    1.45
    71.59    5.4    -4.7              71.73    3.9    1.45
    71.88    5.4    -4.7              72.04    3.9    1.45
    72.2    5.4    -4.7              72.36    4.3    1.45
    72.52    5.4    -4.7              72.67    4.3    1.43
    72.83    5.4    -4.7              73    4.3    1.45
    73.16    5.4    -4.7              73.32    4.7    1.46
    73.47    5.4    -4.7              73.63    5.1    1.48
    73.78    5.4    -4.7              73.94    5.5    1.48
    74.08    5.4    -4.7              74.24    6.6    1.48
    74.37    5.4    -4.7              74.52    9.4    1.27
    74.68    5.4    -4.7              74.83    6.6    1.48
    75    5.4    -4.7              75.16    10.2    1.58
    75.31    5.4    -4.7              75.46    10.2    1.46
    75.6    5.4    -4.7              75.74    9.4    1.41
    75.88    5.4    -4.7              76.03    9.4    1.43
    76.17    5.4    -4.7              76.33    9.8    1.39
    76.49    5.4    -4.7              76.66    4.7    1.41
    76.81    5.4    -4.7              76.96    5.9    1.54
    77.11    5.4    -4.7              77.28    11.7    1.56
    77.43    5.4    -4.7              77.57    9.8    1.37
    77.72    5.4    -4.7              77.87    3.9    1.35
    78.03    5.4    -4.7              78.18    2    1.46
    78.33    5.4    -4.7              78.48    1.2    1.48
    78.64    5.4    -4.7              78.8    -0.4    1.46
    78.97    5.4    -4.7              79.13    -1.2    1.48
    79.29    5.4    -4.7              79.45    -0.8    1.54
    79.6    5.4    -4.7              79.76    5.5    1.45
    79.91    5.4    -4.7              80.06    0    1.58
    80.2    5.4    -4.7              80.36    0    2.58
    80.5    5.4    -4.7              80.67    0    1.05
    80.83    5.4    -4.7              80.98    -1.6    1.41
    81.14    5.4    -4.7              81.29    0.8    1.46
    81.44    5.4    -4.7              81.59    1.6    1.46
    81.75    5.4    -4.7              81.91    -2.7    1.45
    82.06    5.4    -4.7              82.22    4.7    1.52
    82.38    5.4    -4.7              82.53    5.1    1.46
    82.69    5.4    -4.7              82.84    0    1.99
    83    5.4    -4.7              83.16    0    2.62
    83.32    5.4    -4.7              83.49    0    1.05
    83.64    5.4    -4.7              83.8    -2.7    1.33
    83.96    5.4    -4.7              84.13    0    1.48
    84.29    5.4    -4.7              84.46    1.2    1.5
    84.63    5.4    -4.7              84.79    4.7    1.5
    84.96    5.4    -4.7              85.1    5.5    1.48
    85.24    5.4    -4.7              85.38    5.1    1.43
    85.52    5.4    -4.7              85.67    5.5    1.48
    85.82    5.4    -4.7              85.98    6.3    1.45
    86.14    5.4    -4.7              86.29    6.3    1.35
    86.45    5.4    -4.7              86.61    -1.6    1.48
    86.77    5.4    -4.7              86.93    -2.7    1.46
    87.1    5.4    -4.7              87.25    -2    1.52
    87.41    5.4    -4.7              87.55    1.2    1.54
    87.7    5.4    -4.7              87.85    1.2    1.5
    88.01    5.4    -4.7              88.17    2    1.5
    88.33    5.4    -4.3              88.49    1.6    1.5
    88.63    5.4    -4.3              88.79    1.6    1.48
    88.95    5.4    -4.3              89.11    4.7    1.45
    89.27    5.4    -4.3              89.42    1.6    1.45
    89.57    5.4    -4.3              89.73    1.6    1.5
    89.89    5.4    -4.3              90.06    4.3    1.46
    90.22    5.4    -4.3              90.37    3.9    1.43
    90.53    5.4    -4.3              90.69    0.8    1.48
    90.83    5.4    -4.3              90.99    1.6    1.54
    91.12    5.4    -4.3              91.28    -3.1    1.29
    91.43    5.4    -4.3              91.59    -4.3    1.46
    91.75    5.4    -4.3              91.9    -3.9    1.5
    92.06    5.4    -4.3              92.22    -2.3    1.52
    92.38    5.4    -4.3              92.54    0.4    1.54
    92.69    5.4    -4.3              92.83    -0.8    1.52
    92.98    5.4    -4.3              93.14    6.3    1.56
    93.28    5.4    -4.3              93.43    8.2    1.54
    93.59    5.4    -4.3              93.75    8.2    1.5
    93.9    5.4    -4.3              94.08    7.4    1.43
    94.24    5.4    -4.3              94.39    5.9    1.35
    94.54    5.4    -4.3              94.7    5.9    1.37
    94.85    5.4    -4.3              94.99    5.9    1.37
    95.14    5.4    -4.3              95.29    6.3    1.39
    95.45    5.4    -4.3              95.6    3.9    1.19
    95.75    5.4    -4.3              95.9    -2.7    1.17
    96.06    5.4    -4.3              96.22    -3.5    1.33
    96.37    5.4    -4.3              96.53    -3.9    1.41
    96.69    5.4    -4.3              96.85    0    1.6
    96.99    5.4    -4.3              97.13    0    2.19
    97.28    5.4    -4.3              97.43    0    2.4
    97.59    5.4    -4.3              97.75    0    2.68
    97.9    5.4    -4.3              98.06    0    2.7
    98.22    5.4    -4.3              98.38    0    2.73
    98.53    5.4    -4.3              98.69    0    2.71
    98.85    5.4    -4.3              98.99    0    2.66
    99.13    5.4    -4.3              99.27    0    2.77
    99.42    5.4    -4.3              99.57    0    2.77
    99.73    5.4    -4.3              99.89    0    2.66
    100.05    5.4    -4.3              100.21    0    2.73
    100.36    5.4    -4.3              100.51    0    2.68
    100.67    5.4    -4.3              100.83    0    2.64
    100.98    5.4    -4.3              101.14    0    2.77
    101.3    5.4    -4.3              101.44    0    2.7
    101.58    5.4    -4.3              101.72    0    2.75
    101.87    5.4    -4.3              102.03    0    2.79
    102.17    5.4    -4.3              102.32    0    2.71
    102.47    5.4    -4.3              102.63    0    2.13
    102.78    5.4    -4.3              102.93    0    1.54
    103.07    5.4    -4.3              103.23    0    1.25
    103.39    5.4    -4.3              103.55    0    1.29
    103.71    5.4    -4.3              103.86    0.8    1.25
    104.02    5.4    -4.3              104.15    0.8    1.25
    104.3    5.4    -4.3              104.44    2.7    1.29
    104.6    5.4    -4.3              104.76    3.9    1.29
    104.91    5.4    -4.3              105.05    5.1    1.25
    105.21    5.4    -4.3              105.35    4.7    1.21
    105.5    5.4    -4.3              105.66    4.3    1.21
    105.81    5.4    -4.3              105.96    4.3    1.21
    106.13    5.4    -4.3              106.29    4.3    1.21
    106.44    5.4    -4.3              106.58    5.1    1.45
    106.73    5.4    -4.3              106.88    4.3    1.48
    107.03    5.4    -4.3              107.19    2    1.39
    107.35    5.4    -4.3              107.49    3.5    1.41
    107.63    5.4    -4.3              107.77    0.8    1.45
    107.92    5.4    -4.3              108.08    1.2    1.48
    108.22    5.4    -4.3              108.38    0.4    1.48
    108.55    5.4    -4.3              108.71    0.4    1.5
    108.85    5.4    -4.3              108.99    0.4    1.48
    109.14    5.4    -4.3              109.3    -1.2    1.46
    109.45    5.4    -4.3              109.6    -1.2    1.48
    109.76    5.4    -4.3              109.92    -1.6    1.48
    110.07    5.4    -4.3              110.22    -1.6    1.48
    110.39    5.4    -4.3              110.55    -2.7    1.45
    110.7    5.4    -4.3              110.85    -3.9    1.45
    111.01    5.4    -4.3              111.15    -4.3    1.46
    111.31    5.4    -4.3              111.46    -4.3    1.46
    111.61    5.4    -4.3              111.77    0    1.66
    111.93    5.4    -4.3              112.09    0    2.11
    112.24    5.4    -4.3              112.38    0    2.58
    112.52    5.4    -4.3              112.66    0    2.62
    112.8    5.4    -4.3              112.95    0    2.77
    113.1    5.4    -4.3              113.26    0    2.75
    113.42    5.4    -4.3              113.58    0    2.77
    113.73    5.4    -4.3              113.89    0    2.77
    114.04    5.4    -4.3              114.19    0    2.66
    114.34    5.4    -4.3              114.5    0    2.79
    114.65    5.4    -4.3              114.8    0    2.73
    114.97    5.4    -4.3              115.11    0    2.7
    115.26    5.4    -4.3              115.41    0    2.71
    115.55    5.4    -4.3              115.69    0    2.79
    115.83    5.4    -4.3              115.98    0    2.7
    116.15    5.4    -4.3              116.31    0    2.68
    116.46    5.4    -4.3              116.62    0    2.68
    116.78    5.4    -4.3              116.93    0    2.66
    117.09    5.4    -4.3              117.25    0    2.7
    117.4    5.4    -4.3              117.56    0    2.66
    117.72    5.4    -4.3              117.87    0    2.71
    118.03    5.4    -4.3              118.18    0    2.79
    118.33    5.4    -4.3              118.47    0    2.77
    118.62    5.4    -4.3              118.77    0    2.77
    118.91    5.4    -4.3              119.05    0    2.66
    119.2    5.4    -4.3              119.35    0    2.73
    119.49    5.4    -4.3              119.63    0    2.73
    119.77    5.4    -4.3              119.92    0    2.68
    120.07    5.4    -4.3              120.23    0    2.77
    120.39    5.4    -4.3              120.54    0    2.77
    120.7    5.4    -4.3              120.86    0    2.71
    121.02    5.4    -4.3              121.19    0    2.68
    121.35    5.4    -4.3              121.52    0    2.7
    121.68    5.4    -4.3              121.84    0    2.77
    121.99    5.4    -4.3              122.15    0    2.79
    122.3    5.4    -4.3              122.45    0    2.73
    122.6    5.4    -4.3              122.76    0    2.77
    122.91    5.4    -4.3              123.05    0    2.68
    123.2    5.4    -4.3              123.35    0    2.71
    123.51    5.4    -4.3              123.67    0    2.68
    123.82    5.4    -4.3              123.98    0    2.66
    124.14    5.4    -4.3              124.29    0    2.77
    124.45    5.4    -4.3              124.61    0    2.77
    124.76    5.4    -4.3              124.92    0    2.71
    125.08    5.4    -4.3              125.23    0    2.7
    125.39    5.4    -4.3              125.54    0    2.68
    125.7    5.4    -4.3              125.86    0    2.68
    126.01    5.4    -4.3              126.19    0    2.77
    126.34    5.4    -4.3              126.5    0    2.79
    126.65    5.4    -4.3              126.81    0    2.68
    126.97    5.4    -4.3              127.13    0    2.68
    127.28    5.4    -4.3              127.43    0    2.7
    127.59    5.4    -4.3              127.75    0    2.7
    127.9    5.4    -4.3              128.06    0    2.7
    128.22    5.4    -4.3              128.37    0    2.68
    128.53    5.4    -4.3              128.68    0    2.68
    128.84    5.4    -4.3              129    0    2.68
    129.15    5.4    -4.3              129.31    0    2.75
    129.47    5.4    -4.3              129.62    0    2.75
    129.78    5.4    -4.3              129.94    0    2.7
    130.09    5.4    -4.3              130.25    0    2.38
    130.41    5.4    -4.3              130.56    0    1.39
    130.72    5.4    -4.3              130.88    0.4    1.25
    131.03    5.4    -4.3              131.18    2.3    1.29
    131.33    5.4    -4.3              131.47    2.7    1.23
    131.62    5.4    -4.3              131.77    3.5    1.25
    131.91    5.4    -4.3              132.06    4.3    1.27
    132.21    5.4    -4.3              132.37    4.7    1.23
    132.53    5.4    -4.3              132.69    4.3    1.43
    132.84    5.4    -4.3              133    5.1    1.43
    133.16    5.4    -4.3              133.32    -4.3    1.33
    133.49    5.4    -4.3              133.64    -3.1    1.45
    133.79    5.4    -4.3              133.94    -1.2    1.52
    134.09    5.4    -4.3              134.24    -0.4    1.52
    134.38    5.4    -4.3              134.54    0.4    1.52
    134.7    5.4    -4.3              134.85    -0.4    1.5
    135.01    5.4    -4.3              135.17    -2    1.46
    135.32    5.4    -4.3              135.48    -1.6    1.5
    135.64    5.4    -4.3              135.8    -2.3    1.48
    135.96    5.4    -4.3              136.13    -2.7    1.48
    136.28    5.4    -4.3              136.44    -2.7    1.48
    136.6    5.4    -4.3              136.77    -3.5    1.48
    136.92    5.4    -4.3              137.08    -3.5    1.5
    137.24    5.4    -4.3              137.39    -3.9    1.48
    137.55    5.4    -4.3              137.71    0    1.52
    137.88    5.4    -4.3              138.04    0    2.17
    138.19    5.4    -4.3              138.34    0    2.23
    138.49    5.4    -4.3              138.65    0    1.7
    138.81    5.4    -4.3              138.96    0    1.29
    139.12    5.4    -4.3              139.28    -0.4    1.21
    139.43    5.4    -4.3              139.59    0.4    1.23
    139.74    5.4    -4.3              139.88    0.8    1.25
    140.03    5.4    -4.3              140.18    1.6    1.23
    140.34    5.4    -4.3              140.5    3.1    1.25
    140.65    5.4    -4.3              140.81    1.2    1.19
    140.97    5.4    -4.3              141.12    -0.4    1.29
    141.28    5.4    -4.3              141.44    -3.9    1.27
    141.59    5.4    -4.3              141.75    -5.5    1.31
    141.91    5.4    -4.3              142.06    -4.7    1.43
    142.23    5.4    -4.3              142.39    -2    1.48
    142.55    5.4    -4.3              142.7    -1.6    1.46
    142.86    5.4    -4.3              143.02    1.2    1.54
    143.18    5.4    -4.3              143.33    2.3    1.5
    143.48    5.4    -4.3              143.64    2    1.46
    143.8    5.4    -4.3              143.96    3.5    1.48
    144.11    5.4    -4.3              144.26    5.9    1.5
    144.41    5.4    -4.3              144.55    6.6    1.48
    144.7    5.4    -4.3              144.85    8.2    1.5
    145.01    5.4    -4.3              145.17    9.4    1.48
    145.32    5.4    -4.3              145.48    9.8    1.48
    145.64    5.4    -4.3              145.79    5.9    1.33
    145.95    5.4    -4.3              146.11    3.5    1.27
    146.26    5.4    -4.3              146.42    -0.8    1.35
    146.58    5.4    -4.3              146.73    -0.8    1.41
    146.89    5.4    -4.3              147.05    -1.6    1.41
    147.21    5.4    -4.3              147.36    -2.3    1.43
    147.51    5.4    -4.3              147.67    -2.7    1.46
    147.83    5.4    -4.3              147.98    -3.1    1.46
    148.14    5.4    -4.3              148.3    -3.5    1.46
    148.45    5.4    -4.3              148.61    -4.3    1.46
    148.77    5.4    -4.3              148.92    -4.7    1.46
    149.08    5.4    -4.3              149.24    -5.1    1.48
    149.39    5.4    -4.3              149.54    -5.1    1.5
    149.7    5.4    -4.3              149.85    -4.7    1.52
    149.99    5.4    -4.3              150.14    -3.9    1.52
    150.29    5.4    -4.3              150.45    -2.7    1.54
    150.61    5.4    -4.3              150.76    -2    1.54
    150.92    5.4    -4.3              151.08    -1.6    1.56
    151.23    5.4    -4.3              151.39    -1.6    1.52
    151.55    5.4    -4.3              151.7    -2    1.52
    151.86    5.4    -4.3              152.02    -2    1.52
    152.17    5.4    -4.3              152.33    -2    1.5
    152.49    5.4    -4.3              152.64    -2    1.5
    152.79    5.4    -4.3              152.94    -2.3    1.52
    153.08    5.4    -4.3              153.23    -2    1.52
    153.38    5.4    -4.3              153.52    -2    1.52
    153.66    5.4    -4.3              153.8    -2    1.52
    153.94    5.4    -4.3              154.08    -2    1.52
    154.24    5.4    -4.3              154.38    -1.6    1.52
    154.52    5.4    -4.3              154.68    -1.6    1.52
    154.84    5.4    -4.3              155    -1.6    1.52
    155.14    5.4    -4.3              155.28    -1.2    1.52
    155.44    5.4    -4.3              155.58    -1.2    1.52
    155.72    5.4    -4.3              155.87    -1.6    1.54
    156.02    5.4    -4.3              156.18    5.9    1.39
    156.34    5.4    -4.3              156.49    2    1.39
    156.65    5.4    -4.3              156.8    7    1.7
    156.96    5.4    -4.3              157.12    4.7    1.29
    157.27    5.4    -4.3              157.42    12.5    1.62
    157.57    5.4    -4.3              157.73    12.9    1.5
    157.89    5.4    -4.3              158.05    9    1.31
    158.2    5.4    -4.3              158.36    10.5    1.43
    158.52    5.4    -4.3              158.67    11.7    1.43
    158.83    5.4    -4.3              158.99    10.9    1.35
    159.16    5.4    -4.3              159.32    10.9    1.37
    159.49    5.4    -3.9              159.64    3.5    1.31
    159.8    5.4    -3.9              159.94    2.7    1.48
    160.08    5.4    -3.9              160.24    1.2    1.45
    160.38    5.4    -3.9              160.52    -1.6    1.37
    160.67    5.4    -3.9              160.82    -0.4    1.41
    160.98    5.4    -3.9              161.13    -0.8    1.48
    161.29    5.4    -3.9              161.45    -1.6    1.45
    161.6    5.4    -3.9              161.76    -3.1    1.48
    161.92    5.4    -3.9              162.07    -3.1    1.52
    162.24    5.4    -3.9              162.39    -2.7    1.54
    162.54    5.4    -3.9              162.7    -2.3    1.54
    162.86    5.4    -3.9              163.01    3.9    1.43
    163.17    5.4    -3.9              163.32    4.3    1.39
    163.48    5.4    -3.9              163.64    -2.3    1.43
    163.79    5.4    -3.9              163.95    -3.1    1.5
    164.11    5.4    -3.9              164.27    -2.3    1.54
    164.41    5.4    -3.9              164.55    2.7    1.43
    164.69    5.4    -3.9              164.84    0    1.17
    164.99    5.4    -3.9              165.15    -5.1    1.39
    165.31    5.4    -3.9              165.46    -4.3    1.56
    165.62    5.4    -3.9              165.78    -9    1.27
    165.93    5.4    -3.9              166.09    -10.2    1.39
    166.26    5.4    -3.9              166.42    -9.8    1.52
    166.58    5.4    -4.3              166.73    -6.3    1.66
    166.89    5.4    -4.3              167.05    0.4    1.46
    167.2    5.4    -4.3              167.36    1.6    1.52
    167.52    5.4    -4.3              167.67    -0.4    1.39
    167.83    5.4    -4.3              167.98    -0.4    1.43
    168.14    5.4    -4.3              168.31    1.6    1.5
    168.47    5.4    -4.3              168.63    2.7    1.52
    168.8    5.4    -4.3              168.95    4.3    1.46
    169.11    5.4    -4.3              169.27    4.7    1.43
    169.44    5.4    -4.3              169.6    5.1    1.45
    169.77    5.4    -4.3              169.92    5.5    1.43
    170.08    5.4    -3.9              170.24    6.3    1.43
    170.41    5.4    -3.9              170.58    6.6    1.43
    170.72    5.4    -3.9              170.87    -0.8    1.41
    171.02    5.4    -3.9              171.18    -0.4    1.46
    171.34    5.4    -3.9              171.5    2.3    1.56
    171.65    5.4    -3.9              171.81    -1.6    1.54
    171.97    5.4    -3.9              172.13    0    1.52
    172.27    5.4    -3.9              172.43    -3.1    1.41
    172.59    5.4    -3.9              172.75    3.5    1.58
    172.91    5.4    -3.9              173.06    3.5    1.43
    173.22    5.4    -3.9              173.37    3.5    1.43
    173.53    5.4    -3.9              173.69    3.9    1.43
    173.85    5.4    -3.9              174.01    0    1.5
    174.16    5.4    -3.9              174.31    -2.3    1.41
    174.47    5.4    -3.9              174.62    -1.2    1.58
    174.78    5.4    -3.9              174.93    2    1.46
    175.09    5.4    -3.9              175.25    5.5    1.52
    175.4    5.4    -3.9              175.56    6.3    1.5
    175.72    5.4    -3.9              175.88    5.9    1.46
    176.02    5.4    -3.9              176.16    4.7    1.37
    176.3    5.4    -3.9              176.45    3.9    1.35
    176.61    5.4    -3.9              176.77    2.7    1.25
    176.91    5.4    -3.9              177.05    2    1.27
    177.19    5.4    -3.9              177.34    -2    1.33
    177.49    5.4    -3.9              177.63    -2.7    1.43
    177.79    5.4    -3.9              177.95    -5.9    1.31
    178.11    5.4    -3.9              178.26    -5.9    1.37
    178.42    5.4    -3.9              178.58    -7    1.37
    178.73    5.4    -3.9              178.89    0    1.5
    179.03    5.4    -3.9              179.18    0    1.93
    179.35    5.4    -3.9              179.5    0    2.29
    179.65    5.4    -3.9              179.8    0    1.23
    179.94    5.4    -3.9              180.08    -0.4    1.13
    180.23    5.4    -3.9              180.38    -1.2    1.23
    180.54    5.4    -3.9              180.7    -1.2    1.21
    180.86    5.4    -3.9              181.01    0    1.48
    181.17    5.4    -3.9              181.33    3.1    1.48
    181.48    5.4    -3.9              181.64    4.7    1.46
    181.8    5.4    -3.9              181.96    5.1    1.46
    182.12    5.4    -3.9              182.28    -0.4    1.48
    182.43    5.4    -3.9              182.59    0    1.52
    182.74    5.4    -3.9              182.89    5.5    1.45
    183.05    5.4    -3.9              183.2    4.7    1.41
    183.36    5.4    -3.9              183.52    -1.6    1.48
    183.67    5.4    -3.9              183.82    -2.7    1.5
    183.97    5.4    -3.9              184.11    -2.7    1.5
    184.26    5.4    -3.9              184.41    -2    1.52
    184.57    5.4    -3.9              184.72    3.9    1.45
    184.87    5.4    -3.9              185.02    3.9    1.45
    185.16    5.4    -3.9              185.31    -2.3    1.43
    185.46    5.4    -3.9              185.61    -2.7    1.5
    185.75    5.4    -3.9              185.9    -3.1    1.48
    186.05    5.4    -3.9              186.19    -5.5    1.48
    186.33    5.4    -3.9              186.47    -6.3    1.46
    186.61    5.4    -3.9              186.76    -6.6    1.46
    186.92    5.4    -3.9              187.07    -4.3    1.5
    187.23    5.4    -3.9              187.39    -3.9    1.52
    187.55    5.4    -3.9              187.7    1.2    1.52
    187.86    5.4    -3.9              188.01    1.2    1.48
    188.17    5.4    -3.9              188.32    0    1.43
    188.48    5.4    -3.9              188.64    -1.6    1.39
    188.8    5.4    -3.9              188.94    -1.2    1.43
    189.08    5.4    -3.9              189.23    -6.3    1.41
    189.38    5.4    -3.9              189.54    -5.9    1.46
    189.7    5.4    -3.9              189.86    -6.6    1.48
    190.02    5.4    -3.9              190.17    -7    1.48
    190.33    5.4    -3.9              190.48    -7    1.5
    190.63    5.4    -3.9              190.79    0    1.56
    190.95    5.4    -3.9              191.11    0    2.13
    191.25    5.4    -3.9              191.4    0    2.46
    191.55    5.4    -3.9              191.69    0    2.6
    191.83    5.4    -3.9              191.98    0    2.7
    192.14    5.4    -3.9              192.29    0    1.8
    192.45    5.4    -3.9              192.61    0    1.21
    192.75    5.4    -3.9              192.9    0    1.15
    193.05    5.4    -3.9              193.19    -1.6    1.13
    193.34    5.4    -3.9              193.49    -3.5    1.11
    193.64    5.4    -3.9              193.8    -4.7    1.09
    193.95    5.4    -3.9              194.1    -3.5    1.17
    194.26    5.4    -3.9              194.42    -4.3    1.17
    194.57    5.4    -3.9              194.73    -4.3    1.19
    194.88    5.4    -3.9              195.02    -4.3    1.17
    195.17    5.4    -3.9              195.32    -4.7    1.19
    195.48    5.4    -3.9              195.64    -4.7    1.19
    195.8    5.4    -3.9              195.95    -4.7    1.21
    196.1    5.4    -3.9              196.26    -5.1    1.19
    196.41    5.4    -3.9              196.56    -5.5    1.19
    196.72    5.4    -3.9              196.88    -5.1    1.21
    197.02    5.4    -3.9              197.16    -5.1    1.21
    197.3    5.4    -3.9              197.45    -5.9    1.19
    197.61    5.4    -3.9              197.76    -5.5    1.21
    197.92    5.4    -3.9              198.08    -2    1.33
    198.22    5.4    -3.9              198.36    -3.9    1.27
    198.51    5.4    -3.9              198.66    -1.6    1.37
    198.81    5.4    -3.9              198.96    -2    1.48
    199.12    5.4    -3.9              199.28    0    1.52
    199.44    5.4    -3.9              199.58    3.5    1.46
    199.72    5.4    -3.9              199.87    3.5    1.46
    200.03    5.4    -3.9              200.18    4.3    1.46
    200.34    5.4    -3.9              200.5    -1.6    1.5
    200.66    5.4    -3.9              200.8    -0.8    1.52
    200.94    5.4    -3.9              201.09    -0.4    1.37
    201.24    5.4    -3.9              201.41    1.2    1.43
    201.58    5.4    -3.9              201.73    2.7    1.48
    201.89    5.4    -3.9              202.05    3.5    1.48
    202.2    5.4    -3.9              202.37    2.7    1.45
    202.52    5.4    -3.9              202.68    -1.6    1.45
    202.84    5.4    -3.9              203    -2.7    1.45
    203.16    5.4    -3.9              203.3    -5.1    1.46
    203.44    5.4    -3.9              203.58    -5.1    1.5
    203.73    5.4    -3.9              203.88    -3.9    1.52
    204.04    5.4    -3.9              204.2    -2.3    1.52
    204.37    5.4    -3.9              204.53    2.3    1.46
    204.68    5.4    -3.9              204.83    3.9    1.46
    204.97    5.4    -3.9              205.12    4.7    1.48
    205.27    5.4    -3.9              205.43    4.3    1.45
    205.59    5.4    -3.9              205.75    5.1    1.45
    205.9    5.4    -3.9              206.06    -0.8    1.46
    206.22    5.4    -3.9              206.38    0.4    1.52
    206.53    5.4    -3.9              206.68    6.3    1.52
    206.83    5.4    -3.9              206.98    5.9    1.45
    207.13    5.4    -3.9              207.29    4.3    1.39
    207.45    5.4    -3.9              207.6    -3.9    1.33
    207.76    5.4    -3.9              207.92    -2.3    1.45
    208.08    5.4    -3.9              208.22    -3.1    1.46
    208.36    5.4    -3.9              208.51    -3.5    1.46
    208.67    5.4    -3.9              208.82    -3.9    1.46
    208.98    5.4    -3.9              209.14    -4.7    1.41
    209.3    5.4    -3.9              209.45    -5.5    1.43
    209.61    5.4    -3.9              209.76    -5.5    1.45
    209.92    5.4    -3.9              210.08    -6.3    1.43
    210.23    5.4    -3.9              210.4    -6.3    1.46
    210.55    5.4    -3.9              210.7    -7    1.41
    210.86    5.4    -3.9              211.01    -7.8    1.45
    211.17    5.4    -3.9              211.32    -7.4    1.48
    211.47    5.4    -3.9              211.61    -7.4    1.48
    211.75    5.4    -3.9              211.9    0    1.54
    212.05    5.4    -3.9              212.19    0    1.99
    212.34    5.4    -3.9              212.49    0    2.38
    212.65    5.4    -3.9              212.8    0    2.6
    212.94    5.4    -3.9              213.09    0    2.71
    213.24    5.4    -3.9              213.4    0    2.68
    213.55    5.4    -3.9              213.7    0    2.75
    213.85    5.4    -3.9              214.01    0    2.68
    214.17    5.4    -3.9              214.32    0    2.71
    214.48    5.4    -3.9              214.64    0    2.68
    214.79    5.4    -3.9              214.95    0    2.64
    215.11    5.4    -3.9              215.26    0    2.73
    215.42    5.4    -3.9              215.58    0    2.64
    215.72    5.4    -3.9              215.86    0    2.68
    216.01    5.4    -3.9              216.16    0    2.64
    216.31    5.4    -3.9              216.46    0    2.66
    216.62    5.4    -3.9              216.78    0    2.75
    216.93    5.4    -3.9              217.09    0    2.64
    217.25    5.4    -3.9              217.41    0    2.7
    217.56    5.4    -3.9              217.72    0    2.64
    217.87    5.4    -3.9              218.03    0    2.66
    218.19    5.4    -3.9              218.34    0    2.77
    218.5    5.4    -3.9              218.65    0    2.77
    218.81    5.4    -3.9              218.96    0    2.71
    219.12    5.4    -3.9              219.28    0    2.64
    219.44    5.4    -3.9              219.59    0    2.66
    219.74    5.4    -3.9              219.9    0    2.75
    220.05    5.4    -3.9              220.2    0    2.75
    220.35    5.4    -3.9              220.51    0    2.68
    220.67    5.4    -3.9              220.82    0    2.77
    220.98    5.4    -3.9              221.14    0    2.77
    221.29    5.4    -3.9              221.45    0    2.66
    221.61    5.4    -3.9              221.76    0    2.75
    221.92    5.4    -3.9              222.08    0    2.68
    222.23    5.4    -3.9              222.39    0    2.66
    222.55    5.4    -3.9              222.7    0    2.75
    222.86    5.4    -3.9              223.02    0    2.73
    223.17    5.4    -3.9              223.32    0    2.73
    223.48    5.4    -3.9              223.63    0    2.64
    223.79    5.4    -3.9              223.95    0    2.71
    224.11    5.4    -3.9              224.26    0    2.64
    224.41    5.4    -3.9              224.55    0    2.71
    224.69    5.4    -3.9              224.85    0    2.77
    225    5.4    -3.9              225.15    0    2.75
    225.31    5.4    -3.9              225.46    0    2.77
    225.62    5.4    -3.9              225.78    0    2.64
    225.93    5.4    -3.9              226.09    0    2.73
    226.25    5.4    -3.9              226.4    0    2.66
    226.56    5.4    -3.9              226.71    0    2.66
    226.87    5.4    -3.9              227.03    0    2.75
    227.18    5.4    -3.9              227.34    0    2.7
    227.5    5.4    -3.9              227.65    0    2.64
    227.81    5.4    -3.9              227.97    0    2.77
    228.11    5.4    -3.9              228.25    0    2.71
    228.39    5.4    -3.9              228.53    0    2.64
    228.68    5.4    -3.9              228.84    0    2.71
    229    5.4    -3.9              229.15    0    2.66
    229.31    5.4    -3.9              229.47    0    2.73
    229.62    5.4    -3.9              229.78    0    2.71
    229.94    5.4    -3.9              230.08    0    2.68
    230.22    5.4    -3.9              230.36    0    2.68
    230.51    5.4    -3.9              230.66    0    2.7
    230.82    5.4    -3.9              230.98    0    2.71
    231.13    5.4    -3.9              231.29    0    2.4
    231.46    5.4    -3.9              231.6    0    1.86
    231.76    5.4    -3.9              231.92    0    0.74
    232.07    5.4    -3.9              232.23    -2.7    1.25
    232.39    5.4    -3.9              232.55    -5.1    1.21
    232.7    5.4    -3.9              232.86    -4.3    1.23
    233.02    5.4    -3.9              233.18    -4.3    1.48
    233.33    5.4    -3.9              233.48    -2.3    1.46
    233.63    5.4    -3.9              233.79    -0.8    1.5
    233.95    5.4    -3.9              234.1    0.8    1.46
    234.26    5.4    -3.9              234.42    1.2    1.45
    234.57    5.4    -3.9              234.73    1.6    1.48
    234.9    5.4    -3.9              235.05    -0.8    1.5
    235.22    5.4    -3.9              235.37    2.7    1.48
    235.53    5.4    -3.9              235.69    2.7    1.45
    235.84    5.4    -3.9              235.99    0    2.34
    236.14    5.4    -3.9              236.28    0    2.34
    236.42    5.4    -3.9              236.57    0    1.05
    236.72    5.4    -3.9              236.88    0    1.46
    237.04    5.4    -3.9              237.19    2.7    1.48
    237.35    5.4    -3.9              237.52    2    1.45
    237.68    5.4    -3.9              237.83    4.7    1.5
    237.97    5.4    -3.9              238.11    4.3    1.46
    238.26    5.4    -3.9              238.41    3.5    1.43
    238.57    5.4    -3.9              238.73    1.6    1.52
    238.88    5.4    -3.9              239.04    5.9    1.41
    239.2    5.4    -3.9              239.35    5.5    1.45
    239.52    5.4    -3.9              239.68    4.7    1.45
    239.84    5.4    -3.9              239.99    -0.8    1.35
    240.15    5.4    -3.9              240.31    0    2.03
    240.48    5.4    -3.9              240.64    0    2.64
    240.8    5.4    -3.9              240.97    0    2.68
    241.13    5.4    -3.9              241.28    -0.8    0.98
    241.42    5.4    -3.9              241.56    -3.5    1.13
    241.7    5.4    -3.9              241.85    -2    1.23
    242    5.4    -3.9              242.15    -2.3    1.48
    242.31    5.4    -3.9              242.48    1.2    1.46
    242.64    5.4    -3.9              242.8    1.6    1.46
    242.94    5.4    -3.9              243.08    1.6    1.46
    243.23    5.4    -3.9              243.39    -0.8    1.48
    243.54    5.4    -3.9              243.7    2    1.48
    243.86    5.4    -3.9              244.01    2.7    1.48
    244.17    5.4    -3.9              244.32    3.9    1.48
    244.49    5.4    -3.9              244.64    0    1.45
    244.8    5.4    -3.9              244.94    -3.1    1.45
    245.1    5.4    -3.9              245.26    -2.7    1.52
    245.42    5.4    -3.9              245.57    -2.7    1.5
    245.73    5.4    -3.9              245.88    -7    1.35
    246.04    5.4    -3.9              246.2    -7    1.46
    246.36    5.4    -3.9              246.51    -6.6    1.5
    246.67    5.4    -3.9              246.82    -7    1.5
    246.98    5.4    -3.9              247.14    -5.1    1.54
    247.29    5.4    -3.9              247.45    -6.6    1.5
    247.6    5.4    -3.9              247.76    -5.5    1.52
    247.92    5.4    -3.9              248.08    0.4    1.54
    248.23    5.4    -3.9              248.39    1.2    1.52
    248.53    5.4    -3.9              248.68    2    1.46
    248.83    5.4    -3.9              248.97    -0.4    1.45
    249.12    5.4    -3.9              249.27    0.4    1.43
    249.43    5.4    -3.9              249.59    2    1.46
    249.74    5.4    -3.9              249.9    -3.1    1.52
    250.06    5.4    -3.9              250.22    2.7    1.52
    250.37    5.4    -3.9              250.53    3.5    1.48
    250.69    5.4    -3.9              250.83    4.7    1.46
    250.97    5.4    -3.9              251.12    4.7    1.45
    251.27    5.4    -3.9              251.43    0    1.27
    251.58    5.4    -3.9              251.73    -3.5    1.41
    251.88    5.4    -3.9              252.04    -2.7    1.48
    252.19    5.4    -3.9              252.34    -2.7    1.5
    252.49    5.4    -3.9              252.65    -3.1    1.48
    252.81    5.4    -3.9              252.96    -3.9    1.46
    253.12    5.4    -3.9              253.28    -4.7    1.5
    253.44    5.4    -3.9              253.6    -6.6    1.5
    253.75    5.4    -3.9              253.91    -4.3    1.54
    254.08    5.4    -3.9              254.22    -4.3    1.58
    254.36    5.4    -3.9              254.5    2.7    1.5
    254.64    5.4    -3.9              254.78    4.7    1.54
    254.93    5.4    -3.9              255.08    3.1    1.39
    255.22    5.4    -3.9              255.36    2.7    1.33
    255.5    5.4    -3.9              255.64    -3.5    1.46
    255.78    5.4    -3.9              255.93    -3.5    1.54
    256.08    5.4    -3.9              256.23    -2.7    1.56
    256.38    5.4    -3.9              256.54    2.7    1.41
    256.7    5.4    -3.9              256.86    3.1    1.39
    257.02    5.4    -3.9              257.17    -3.1    1.39
    257.33    5.4    -3.9              257.49    -2.7    1.52
    257.66    5.4    -3.9              257.83    -3.1    1.54
    257.97    5.4    -3.9              258.11    -4.3    1.46
    258.25    5.4    -3.9              258.39    -5.1    1.39
    258.54    5.4    -3.9              258.69    -4.7    1.48
    258.84    5.4    -3.9              258.99    -3.9    1.52
    259.15    5.4    -3.9              259.31    -3.9    1.52
    259.45    5.4    -3.9              259.6    -0.4    1.5
    259.75    5.4    -3.9              259.9    -0.4    1.45
    260.06    5.4    -3.9              260.21    -1.2    1.35
    260.37    5.4    -3.9              260.53    -2.3    1.31
    260.7    5.4    -3.9              260.84    -2.7    1.31
    260.99    5.4    -3.9              261.14    -7    1.27
    261.29    5.4    -3.9              261.44    -8.2    1.35
    261.59    5.4    -3.9              261.74    -8.6    1.41
    261.9    5.4    -3.9              262.06    -8.6    1.45
    262.21    5.4    -3.9              262.37    -9    1.46
    262.54    5.4    -3.9              262.7    0    1.54
    262.86    5.4    -3.9              263.02    0    2.11
    263.17    5.4    -3.9              263.33    0    2.32
    263.48    5.4    -3.9              263.64    0    2.68
    263.8    5.4    -3.9              263.97    0    2.66
    264.12    5.4    -3.9              264.25    0    2.75
    264.39    5.4    -3.9              264.53    0    2.64
    264.67    5.4    -3.9              264.82    0    2.75
    264.97    5.4    -3.9              265.11    0    2.68
    265.25    5.4    -3.9              265.4    0    2.75
    265.56    5.4    -3.9              265.71    0    2.64
    265.87    5.4    -3.9              266.03    0    2.64
    266.18    5.4    -3.9              266.34    0    2.71
    266.5    5.4    -3.9              266.65    0    2.64
    266.81    5.4    -3.9              266.97    0    2.75
    267.14    5.4    -3.9              267.3    0    2.66
    267.47    5.4    -3.9              267.62    0    2.73
    267.77    5.4    -3.9              267.93    0    2.68
    268.08    5.4    -3.9              268.23    0    2.66
    268.38    5.4    -3.9              268.54    0    2.68
    268.7    5.4    -3.9              268.86    0    2.66
    269    5.4    -3.9              269.14    0    2.7
    269.28    5.4    -3.9              269.43    0    2.7
    269.58    5.4    -3.9              269.72    0    2.66
    269.88    5.4    -3.9              270.04    0    2.54
    270.19    5.4    -3.9              270.35    0    1.97
    270.51    5.4    -3.9              270.67    0    1.62
    270.82    5.4    -3.9              270.98    0    1.41
    271.13    5.4    -3.9              271.29    0    1.25
    271.45    5.4    -3.9              271.6    0    1.15
    271.76    5.4    -3.9              271.92    0    1.09
    272.07    5.4    -3.9              272.23    -1.6    1.05
    272.39    5.4    -3.9              272.54    -3.9    1.04
    272.7    5.4    -3.9              272.86    -5.5    1.05
    273.01    5.4    -3.9              273.17    -6.6    1.09
    273.33    5.4    -3.9              273.5    -7.4    1.15
    273.66    5.4    -3.9              273.81    -7.4    1.21
    273.97    5.4    -3.9              274.12    -7.4    1.21
    274.25    5.4    -3.9              274.39    -7    1.21
    274.54    5.4    -3.9              274.7    -7    1.25
    274.86    5.4    -3.9              275    -6.3    1.27
    275.14    5.4    -3.9              275.28    0    1.54
    275.43    5.4    -3.9              275.6    0.4    1.33
    275.75    5.4    -3.9              275.9    0.8    1.37
    276.06    5.4    -3.9              276.22    4.3    1.37
    276.38    5.4    -3.9              276.53    2.3    1.29
    276.68    5.4    -3.9              276.84    2.7    1.29
    277    5.4    -3.9              277.15    2.3    1.23
    277.31    5.4    -3.9              277.47    3.5    1.23
    277.62    5.4    -3.9              277.78    3.9    1.23
    277.94    5.4    -3.9              278.11    3.5    1.19
    278.26    5.4    -3.9              278.42    0.8    1.41
    278.58    5.4    -3.9              278.75    -2.3    1.39
    278.9    5.4    -3.9              279.07    -0.8    1.52
    279.22    5.4    -3.9              279.37    3.9    1.48
    279.54    5.4    -3.9              279.68    0    2.34
    279.84    5.4    -3.9              279.98    0    2.66
    280.13    5.4    -3.9              280.28    0    0.92
    280.43    5.4    -3.9              280.58    -0.4    1.21
    280.72    5.4    -3.9              280.86    -3.5    1.43
    281    5.4    -3.9              281.15    2.3    1.52
    281.31    5.4    -3.9              281.46    5.1    1.48
    281.62    5.4    -3.9              281.78    6.3    1.46
    281.93    5.4    -3.9              282.1    0    2.32
    282.24    5.4    -3.9              282.4    0    2.58
    282.56    5.4    -3.9              282.73    0    1.05
    282.89    5.4    -3.9              283.04    1.2    1.23
    283.2    5.4    -3.9              283.36    3.9    1.5
    283.52    5.4    -3.9              283.67    4.7    1.48
    283.83    5.4    -3.9              284    4.7    1.45
    284.15    5.4    -3.9              284.31    1.6    1.5
    284.47    5.4    -3.9              284.62    4.3    1.48
    284.77    5.4    -3.9              284.92    -6.3    1.35
    285.07    5.4    -3.9              285.22    0    2.56
    285.36    5.4    -3.9              285.5    0    2.29
    285.65    5.4    -3.9              285.79    0    0.84
    285.95    5.4    -3.9              286.1    -3.1    1.37
    286.26    5.4    -3.9              286.43    -3.9    1.43
    286.58    5.4    -3.9              286.73    1.6    1.54
    286.89    5.4    -3.9              287.04    2.3    1.46
    287.2    5.4    -3.9              287.36    2.7    1.46
    287.51    5.4    -3.9              287.68    2.3    1.46
    287.81    5.4    -3.9              287.96    3.1    1.43
    288.12    5.4    -3.9              288.25    4.3    1.46
    288.39    5.4    -3.9              288.53    -5.9    1.41
    288.67    5.4    -3.9              288.82    -2.3    1.5
    288.98    5.4    -3.9              289.13    -1.6    1.5
    289.29    5.4    -3.9              289.45    1.2    1.46
    289.6    5.4    -3.9              289.76    -8.6    1.39
    289.92    5.4    -3.9              290.07    -4.7    1.5
    290.23    5.4    -3.9              290.39    -5.9    1.5
    290.54    5.4    -3.9              290.7    -4.3    1.52
    290.86    5.4    -3.9              291.01    -4.3    1.52
    291.17    5.4    -3.9              291.33    -3.9    1.52
    291.5    5.4    -3.9              291.66    -3.5    1.52
    291.81    5.4    -3.9              291.96    -3.9    1.5
    292.13    5.4    -3.9              292.28    -4.7    1.5
    292.43    5.4    -3.9              292.59    -5.5    1.48
    292.75    5.4    -3.9              292.9    -5.5    1.5
    293.05    5.4    -3.9              293.2    -8.2    1.43
    293.36    5.4    -3.9              293.51    -9.4    1.45
    293.67    5.4    -3.9              293.83    -9    1.48
    293.98    5.4    -3.9              294.14    -2.3    1.48
    294.28    5.4    -3.9              294.42    0    1.66
    294.56    5.4    -3.9              294.71    0    2.21
    294.86    5.4    -3.9              295    0    2.64
    295.15    5.4    -3.9              295.3    0    2.62
    295.46    5.4    -3.9              295.62    0    2.66
    295.77    5.4    -3.9              295.92    0    2.64
    296.07    5.4    -3.9              296.22    0    2.66
    296.36    5.4    -3.9              296.5    0    2.71
    296.65    5.4    -3.9              296.8    0    2.73
    296.96    5.4    -3.9              297.11    0    2.7
    297.25    5.4    -3.9              297.4    0    2.64
    297.56    5.4    -3.9              297.71    0    2.7
    297.86    5.4    -3.9              298    0    2.75
    298.14    5.4    -3.9              298.29    0    2.75
    298.44    5.4    -3.9              298.58    0    2.7
    298.73    5.4    -3.9              298.89    0    2.68
    299.03    5.4    -3.9              299.19    0    2.75
    299.33    5.4    -3.9              299.49    0    2.64
    299.64    5.4    -3.9              299.79    0    2.7
    299.94    5.4    -3.9              300.08    0    2.71
    300.22    5.4    -3.9              300.38    0    2.75
    300.53    5.4    -3.9              300.68    0    2.71
    300.84    5.4    -3.9              300.99    0    2.73
    301.15    5.4    -3.9              301.31    0    2.71
    301.46    5.4    -3.9              301.62    0    2.64
    301.78    5.4    -3.9              301.93    0    2.64
    302.09    5.4    -3.9              302.24    0    2.73
    302.41    5.4    -3.9              302.56    0    2.5
    302.72    5.4    -3.9              302.88    0    1.64
    303.03    5.4    -3.9              303.18    0    1.25
    303.34    5.4    -3.9              303.49    -0.4    1.25
    303.65    5.4    -3.9              303.81    0.8    1.25
    303.97    5.4    -3.9              304.12    0    1.21
    304.28    5.4    -3.9              304.44    1.2    1.19
    304.61    5.4    -3.9              304.76    3.1    1.29
    304.93    5.4    -3.9              305.07    3.1    1.25
    305.23    5.4    -3.9              305.39    3.1    1.23
    305.55    5.4    -3.9              305.7    3.9    1.23
    305.86    5.4    -3.9              306.01    4.3    1.23
    306.17    5.4    -3.9              306.33    4.3    1.23
    306.48    5.4    -3.9              306.62    4.7    1.23
    306.79    5.4    -3.9              306.94    5.1    1.25
    307.12    5.4    -3.9              307.29    3.5    1.45
    307.45    5.4    -3.9              307.61    3.1    1.46
    307.77    5.4    -3.9              307.93    5.5    1.43
    308.08    5.4    -3.9              308.23    -1.2    1.33
    308.4    5.4    -3.9              308.55    -5.1    1.31
    308.71    5.4    -3.9              308.85    -5.5    1.39
    309.02    5.4    -3.9              309.18    -5.1    1.43
    309.33    5.4    -3.9              309.49    -6.3    1.43
    309.65    5.4    -3.9              309.8    -6.6    1.43
    309.95    5.4    -3.9              310.12    -7.4    1.43
    310.27    5.4    -3.9              310.43    -8.2    1.45
    310.56    5.4    -3.9              310.73    -8.2    1.46
    310.88    5.4    -3.9              311.02    -8.2    1.46
    311.18    5.4    -3.9              311.33    -8.6    1.48
    311.48    5.4    -3.9              311.64    -9    1.48
    311.79    5.4    -3.9              311.95    -9    1.48
    312.1    5.4    -3.9              312.27    -9.4    1.48
    312.42    5.4    -3.9              312.58    -9.8    1.46
    312.74    5.4    -3.9              312.89    0    1.48
    313.05    5.4    -3.9              313.19    0    1.78
    313.36    5.4    -3.9              313.51    0    2.21
    313.67    5.4    -3.9              313.83    0    2.17
    313.99    5.4    -3.9              314.14    0    1.66
    314.29    5.4    -3.9              314.45    0    1.29
    314.61    5.4    -3.9              314.76    0    1.11
    314.93    5.4    -3.9              315.08    0    1.04
    315.25    5.4    -3.9              315.41    0    1.02
    315.57    5.4    -3.9              315.72    -0.8    1
    315.87    5.4    -3.9              316.02    -3.1    1
    316.18    5.4    -3.9              316.31    -5.5    1.02
    316.46    5.4    -3.9              316.62    -6.6    1.05
    316.78    5.4    -3.9              316.94    -7.4    1.09
    317.08    5.4    -3.9              317.25    -7.8    1.13
    317.41    5.4    -3.9              317.56    -7.8    1.23
    317.72    5.4    -3.9              317.88    -7.8    1.37
    318.03    5.4    -3.9              318.19    -7.8    1.46
    318.35    5.4    -3.9              318.49    -7.4    1.5
    318.66    5.4    -3.9              318.81    -6.6    1.5
    318.98    5.4    -3.9              319.15    -6.6    1.5
    319.29    5.4    -3.9              319.42    -4.7    1.5
    319.58    5.4    -3.9              319.73    -4.3    1.5
    319.89    5.4    -3.9              320.04    -4.3    1.46
    320.18    5.4    -3.9              320.32    -4.3    1.46
    320.47    5.4    -3.9              320.62    -4.3    1.46
    320.77    5.4    -3.9              320.93    -3.9    1.48
    321.09    5.4    -3.9              321.25    -3.5    1.48
    321.41    5.4    -3.9              321.57    -3.1    1.48
    321.74    5.4    -3.9              321.91    4.3    1.64
    322.06    5.4    -3.9              322.22    2    1.5
    322.37    5.4    -3.9              322.53    2.7    1.52
    322.69    5.4    -3.9              322.83    3.5    1.48
    323    5.4    -3.9              323.16    3.1    1.48
    323.32    5.4    -3.9              323.46    5.1    1.45
    323.62    5.4    -3.9              323.77    4.7    1.48
    323.92    5.4    -3.9              324.06    3.5    1.41
    324.2    5.4    -3.9              324.35    3.9    1.43
    324.51    5.4    -3.9              324.66    4.7    1.46
    324.83    5.4    -3.9              324.99    4.3    1.43
    325.14    5.4    -3.9              325.3    -1.2    1.45
    325.45    5.4    -3.9              325.62    -1.2    1.5
    325.79    5.4    -3.9              325.94    -2.3    1.46
    326.09    5.4    -3.9              326.25    -5.5    1.37
    326.41    5.4    -3.9              326.57    -2    1.37
    326.73    5.4    -3.9              326.88    0    1.66
    327.04    5.4    -3.9              327.2    0    1.35
    327.36    5.4    -3.9              327.51    -0.4    1.41
    327.66    5.4    -3.9              327.8    -1.6    1.46
    327.97    5.4    -3.9              328.12    3.5    1.48
    328.27    5.4    -3.9              328.43    4.3    1.46
    328.59    5.4    -3.9              328.75    5.5    1.48
    328.9    5.4    -3.9              329.04    6.3    1.48
    329.18    5.4    -3.9              329.34    6.6    1.46
    329.49    5.4    -3.9              329.65    0    1.43
    329.81    5.4    -3.9              329.97    0    1.5
    330.13    5.4    -3.9              330.29    -1.2    1.5
    330.43    5.4    -3.9              330.6    -1.6    1.5
    330.76    5.4    -3.9              330.92    3.9    1.45
    331.08    5.4    -3.9              331.23    -3.1    1.39
    331.39    5.4    -3.9              331.53    -4.3    1.48
    331.67    5.4    -3.9              331.82    -5.9    1.48
    331.98    5.4    -3.9              332.13    -7.8    1.46
    332.29    5.4    -3.9              332.45    -4.3    1.52
    332.61    5.4    -3.9              332.77    -4.3    1.52
    332.92    5.4    -3.9              333.07    -7.8    1.45
    333.24    5.4    -3.9              333.39    -9    1.48
    333.55    5.4    -4.3              333.73    -8.2    1.54
    333.9    5.4    -4.3              334.06    0.4    1.54
    334.23    5.4    -4.3              334.37    2    1.5
    334.52    5.4    -4.3              334.68    2.7    1.48
    334.82    5.4    -4.3              334.98    3.1    1.45
    335.14    5.4    -4.3              335.29    2    1.41
    335.45    5.4    -4.3              335.61    -4.7    1.43
    335.75    5.4    -4.3              335.89    -3.9    1.52
    336.05    5.4    -4.3              336.2    1.6    1.52
    336.35    5.4    -4.3              336.5    1.6    1.41
    336.66    5.4    -4.3              336.81    -1.6    1.19
    336.96    5.4    -4.3              337.12    -6.3    1.29
    337.27    5.4    -4.3              337.44    -7    1.5
    337.58    5.4    -4.3              337.75    -9.8    1.29
    337.9    5.4    -4.3              338.05    -10.9    1.41
    338.22    5.4    -4.3              338.37    -7.8    1.6
    338.52    5.4    -4.3              338.69    -5.9    1.66
    338.86    5.4    -4.3              339.02    3.5    1.54
    339.18    5.4    -4.3              339.33    3.5    1.5
    339.49    5.4    -4.3              339.65    6.3    1.52
    339.79    5.4    -4.3              339.94    3.5    1.37
    340.09    5.4    -4.3              340.25    3.5    1.37
    340.4    5.4    -4.3              340.54    -3.1    0.94
    340.7    5.4    -4.3              340.85    -3.5    1.17
    341.01    5.4    -4.3              341.16    -2.3    1.31
    341.31    5.4    -4.3              341.46    -5.9    1.35
    341.62    5.4    -4.3              341.77    -6.3    1.41
    341.93    5.4    -4.3              342.1    -7    1.46
    342.25    5.4    -4.3              342.41    -7    1.46
    342.57    5.4    -4.3              342.73    -7.4    1.46
    342.9    5.4    -4.3              343.04    -7.8    1.46
    343.18    5.4    -4.3              343.32    -7.8    1.48
    343.47    5.4    -4.3              343.62    -8.2    1.48
    343.76    5.4    -4.3              343.92    -7.8    1.5
    344.08    5.4    -4.3              344.24    -8.2    1.5
    344.4    5.4    -4.3              344.53    -8.2    1.5
    344.67    5.4    -4.3              344.82    0    1.5
    344.97    5.4    -4.3              345.13    0    1.84
    345.29    5.4    -4.3              345.44    0    2.19
    345.59    5.4    -4.3              345.75    0    2.62
    345.9    5.4    -4.3              346.05    0    2.46
    346.2    5.4    -4.3              346.36    0    1.5
    346.52    5.4    -4.3              346.66    0    1.13
    346.83    5.4    -4.3              346.99    -2    1.17
    347.15    5.4    -4.3              347.32    1.2    1.25
    347.46    5.4    -4.3              347.6    1.2    1.25
    347.74    5.4    -4.3              347.89    -2    1.15
    348.03    5.4    -4.3              348.17    -3.5    1.07
    348.31    5.4    -4.3              348.46    -4.7    1.07
    348.62    5.4    -4.3              348.77    -4.3    1.15
    348.93    5.4    -4.3              349.09    -3.1    1.21
    349.24    5.4    -4.3              349.39    -3.9    1.15
    349.54    5.4    -4.3              349.68    -4.3    1.17
    349.83    5.4    -4.3              349.97    -5.1    1.15
    350.13    5.4    -4.3              350.29    -3.9    1.37
    350.45    5.4    -4.3              350.59    -3.1    1.43
    350.73    5.4    -4.3              350.89    -4.7    1.48
    351.03    5.4    -4.3              351.17    -0.8    1.52
    351.33    5.4    -4.3              351.48    2.3    1.5
    351.64    5.4    -4.3              351.8    2.3    1.48
    351.95    5.4    -4.3              352.11    3.1    1.46
    352.27    5.4    -4.3              352.42    3.1    1.46
    352.58    5.4    -4.3              352.72    3.9    1.46
    352.91    5.4    -4.3              353.06    5.5    1.46
    353.22    5.4    -4.3              353.38    -5.1    1.33
    353.54    5.4    -4.3              353.69    -5.9    1.46
    353.85    5.4    -4.3              354    -5.5    1.52
    354.14    5.4    -4.3              354.28    -3.9    1.54
    354.43    5.4    -4.3              354.59    -3.1    1.52
    354.75    5.4    -4.3              354.9    2.3    1.45
    355.05    5.4    -4.3              355.21    3.1    1.46
    355.36    5.4    -4.3              355.51    -3.5    1.41
    355.65    5.4    -4.3              355.79    -3.5    1.5
    355.94    5.4    -4.3              356.1    -4.3    1.5
    356.25    5.4    -4.3              356.41    1.2    1.5
    356.57    5.4    -4.3              356.73    0    1.41
    356.91    5.4    -4.3              357.05    -7.8    1.37
    357.21    5.4    -4.3              357.36    -7.4    1.43
    357.5    5.4    -4.3              357.64    -5.9    1.5
    357.79    5.4    -4.3              357.94    -5.5    1.5
    358.1    5.4    -4.3              358.27    -4.3    1.54
    358.42    5.4    -4.3              358.56    -4.3    1.5
    358.71    5.4    -4.3              358.87    -5.1    1.5
    359.02    5.4    -4.3              359.18    -5.9    1.5
    359.33    5.4    -4.3              359.48    -6.3    1.48
    359.63    5.4    -4.3              359.79    -5.5    1.5
    359.95    5.4    -4.3              360.09    -6.6    1.48
    360.23    5.4    -4.3              360.38    -3.1    1.43
    360.54    5.4    -4.3              360.69    -3.1    1.35
    360.86    5.4    -4.3              361.01    -3.5    1.35
    361.16    5.4    -4.3              361.32    0    1.41
    361.47    5.4    -4.3              361.62    0    1.97
    361.78    5.4    -4.3              361.94    0    2.3
    362.09    5.4    -4.3              362.25    0    2.7
    362.4    5.4    -4.3              362.56    0    2.71
    362.71    5.4    -4.3              362.88    0    2.66
    363.01    5.4    -4.3              363.16    0    2.73
    363.31    5.4    -4.3              363.46    0    2.7
    363.61    5.4    -4.3              363.76    0    2.66
    363.93    5.4    -4.3              364.08    0    2.68
    364.24    5.4    -4.3              364.39    0    2.77
    364.55    5.4    -4.3              364.71    0    2.75
    364.86    5.4    -4.3              365.02    0    2.7
    365.18    5.4    -4.3              365.33    0    2.73
    365.48    5.4    -4.3              365.62    0    2.75
    365.78    5.4    -4.3              365.93    0    2.73
    366.08    5.4    -4.3              366.23    0    2.68
    366.37    5.4    -4.3              366.52    0    2.7
    366.67    5.4    -4.3              366.82    0    2.66
    366.98    5.4    -4.3              367.14    0    2.68
    367.29    5.4    -4.3              367.46    0    2.66
    367.61    5.4    -4.3              367.77    0    2.71
    367.92    5.4    -4.3              368.09    0    2.7
    368.24    5.4    -4.3              368.38    0    2.68
    368.53    5.4    -4.3              368.67    0    2.7
    368.81    5.4    -4.3              368.96    0    2.7
    369.11    5.4    -4.3              369.27    0    2.75
    369.43    5.4    -4.3              369.59    0    2.68
    369.75    5.4    -4.3              369.93    0    2.68
    370.08    5.4    -4.3              370.24    0    2.75
    370.4    5.4    -4.3              370.55    0    2.66
    370.7    5.4    -4.3              370.84    0    2.77
    370.99    5.4    -4.3              371.13    0    2.68
    371.27    5.4    -4.3              371.42    0    2.73
    371.56    5.4    -4.3              371.71    0    2.77
    371.86    5.4    -4.3              372.01    0    2.77
    372.17    5.4    -4.3              372.33    0    2.64
    372.49    5.4    -4.3              372.64    0    2.68
    372.8    5.4    -4.3              372.96    0    2.7
    373.11    5.4    -4.3              373.27    0    2.75
    373.43    5.4    -4.3              373.58    0    2.7
    373.73    5.4    -4.3              373.87    0    2.58
    374.02    5.4    -4.3              374.17    0    1.8
    374.32    5.4    -4.3              374.47    0    1.46
    374.63    5.4    -4.3              374.79    0    1.29
    374.95    5.4    -4.3              375.09    0    1.21
    375.25    5.4    -4.3              375.4    0    1.17
    375.56    5.4    -4.3              375.72    0    1.13
    375.87    5.4    -4.3              376.03    -0.4    1.11
    376.19    5.4    -4.3              376.34    -2    1.09
    376.5    5.4    -4.3              376.65    -3.5    1.09
    376.79    5.4    -4.3              376.92    -4.3    1.11
    377.07    5.4    -4.3              377.21    -5.1    1.13
    377.35    5.4    -4.3              377.5    -5.5    1.13
    377.65    5.4    -4.3              377.81    -6.3    1.15
    377.98    5.4    -4.3              378.13    -6.3    1.19
    378.27    5.4    -4.3              378.42    -6.3    1.21
    378.57    5.4    -4.3              378.71    -6.3    1.21
    378.87    5.4    -4.3              379.02    -6.3    1.21
    379.17    5.4    -4.3              379.32    -6.3    1.21
    379.48    5.4    -4.3              379.64    -6.3    1.21
    379.8    5.4    -4.3              379.94    -6.3    1.21
    380.1    5.4    -4.3              380.26    -6.3    1.23
    380.41    5.4    -4.3              380.57    -6.3    1.23
    380.73    5.4    -4.3              380.89    -6.3    1.23
    381.04    5.4    -4.3              381.21    -6.3    1.21
    381.35    5.4    -4.3              381.48    -6.3    1.23
    381.63    5.4    -4.3              381.79    -6.3    1.23
    381.94    5.4    -4.3              382.09    -5.9    1.23
    382.25    5.4    -4.3              382.41    -5.9    1.23
    382.56    5.4    -4.3              382.72    -5.5    1.23
    382.87    5.4    -4.3              383.03    -5.5    1.23
    383.19    5.4    -4.3              383.34    -5.5    1.21
    383.5    5.4    -4.3              383.65    -5.5    1.21
    383.81    5.4    -4.3              383.97    -5.5    1.21
    384.13    5.4    -4.3              384.28    -5.5    1.23
    384.44    5.4    -4.3              384.6    -5.5    1.23
    384.75    5.4    -4.3              384.91    -5.5    1.21
    385.07    5.4    -4.3              385.22    -5.5    1.21
    385.38    5.4    -4.3              385.53    -5.5    1.21
    385.69    5.4    -4.3              385.85    -5.5    1.21
    386    5.4    -4.3              386.16    -5.5    1.21
    386.32    5.4    -4.3              386.49    -5.5    1.23
    386.63    5.4    -4.3              386.77    -5.5    1.23
    386.91    5.4    -4.3              387.06    -5.5    1.23
    387.2    5.4    -4.3              387.35    -5.1    1.25
    387.49    5.4    -4.3              387.63    -4.7    1.25
    387.78    5.4    -4.3              387.93    -4.7    1.23
    388.07    5.4    -4.3              388.21    -4.7    1.21
    388.38    5.4    -4.3              388.53    -5.1    1.21
    388.69    5.4    -4.3              388.84    -5.1    1.21
    389    5.4    -4.3              389.16    -5.5    1.21
    389.32    5.4    -4.3              389.48    -5.5    1.21
    389.63    5.4    -4.3              389.77    -5.5    1.21
    389.92    5.4    -4.3              390.07    -5.5    1.21
    390.21    5.4    -4.3              390.35    -5.5    1.21
    390.49    5.4    -4.3              390.64    -5.5    1.21
    390.79    5.4    -4.3              390.94    -5.5    1.21
    391.09    5.4    -4.3              391.25    -5.5    1.21
    391.41    5.4    -4.3              391.56    -5.5    1.23
    391.7    5.4    -4.3              391.85    -5.5    1.23
    392.01    5.4    -4.3              392.16    -5.1    1.23
    392.32    5.4    -4.3              392.49    -5.1    1.23
    392.65    5.4    -4.3              392.8    -5.1    1.23
    392.95    5.4    -4.3              393.1    -4.7    1.25
    393.25    5.4    -4.3              393.4    -4.3    1.25
    393.56    5.4    -4.3              393.71    -3.5    1.27
    393.85    5.4    -4.3              393.99    -3.1    1.27
    394.14    5.4    -4.3              394.29    -2.3    1.27
    394.45    5.4    -4.3              394.61    -2    1.25
    394.76    5.4    -4.3              394.92    -1.6    1.29
    395.08    5.4    -4.3              395.24    -0.8    1.43
    395.39    5.4    -4.3              395.54    0.4    1.5
1    395.7    5.4    -4.3              395.86    1.2    1.5
    396.02    5.4    -4.3              396.18    0.8    1.48
    396.32    5.4    -4.3              396.46    0    1.46
    396.6    5.4    -4.3              396.75    -0.4    1.48
    396.9    5.4    -4.3              397.06    1.6    1.48
    397.2    5.4    -4.3              397.36    2    1.48
    397.51    5.4    -4.3              397.67    2    1.46
    397.83    5.4    -4.3              397.98    2    1.46
    398.14    5.4    -4.3              398.29    2    1.46
    398.45    5.4    -4.3              398.61    2    1.48
    398.76    5.4    -4.3              398.92    2.3    1.46
    399.07    5.4    -4.3              399.21    2    1.45
    399.35    5.4    -4.3              399.49    6.3    1.52
    399.64    5.4    -4.3              399.78    3.1    1.43
    399.92    5.4    -4.3              400.07    4.7    1.48
    400.22    5.4    -4.3              400.38    4.7    1.46
    400.54    5.4    -4.3              400.69    0    1.46
    400.84    5.4    -4.3              400.99    -2    1.5
    401.15    5.4    -4.3              401.31    0.4    1.52
    401.47    5.4    -4.3              401.63    6.3    1.52
    401.78    5.4    -4.3              401.94    3.1    1.41
    402.09    5.4    -4.3              402.25    5.1    1.45
    402.41    5.4    -4.3              402.56    -2    1.48
    402.72    5.4    -4.3              402.88    -1.2    1.52
    403.03    5.4    -4.3              403.19    -3.1    1.48
    403.35    5.4    -4.3              403.5    5.9    1.54
    403.66    5.4    -4.3              403.82    5.1    1.46
    403.97    5.4    -4.3              404.13    6.3    1.46
    404.29    5.4    -4.3              404.46    6.3    1.45
    404.61    5.4    -4.3              404.77    5.9    1.37
    404.93    5.4    -4.3              405.08    -0.8    1.35
    405.24    5.4    -4.3              405.39    -2.7    1.46
    405.55    5.4    -4.3              405.69    -3.5    1.46
    405.84    5.4    -4.3              405.98    -4.7    1.46
    406.14    5.4    -4.3              406.29    -5.9    1.46
    406.43    5.4    -4.3              406.58    -5.9    1.48
    406.73    5.4    -4.3              406.89    -5.9    1.52
    407.04    5.4    -4.3              407.2    -7.4    1.48
    407.35    5.4    -4.3              407.51    -7.4    1.52
    407.67    5.4    -4.3              407.83    -7.8    1.52
    407.98    5.4    -4.3              408.14    -2.7    1.5
    408.3    5.4    -4.3              408.45    -4.3    1.27
    408.61    5.4    -4.3              408.77    -5.9    1.27
    408.93    5.4    -4.3              409.08    -9    1.27
    409.24    5.4    -4.3              409.39    -10.5    1.5
    409.55    5.4    -4.3              409.7    -9.4    1.58
    409.86    5.4    -4.3              410.02    -10.5    1.5
    410.19    5.4    -4.3              410.35    -2.3    1.62
    410.51    5.4    -4.3              410.68    1.2    1.56
    410.85    5.4    -4.3              410.99    3.1    1.54
    411.13    5.4    -4.3              411.27    4.3    1.54
    411.42    5.4    -4.3              411.57    5.5    1.5
    411.72    5.4    -4.3              411.87    5.5    1.41
    412.03    5.4    -4.3              412.18    5.5    1.39
    412.32    5.4    -4.3              412.47    5.5    1.37
    412.62    5.4    -4.3              412.78    5.1    1.37
    412.93    5.4    -4.3              413.08    4.7    1.31
    413.24    5.4    -4.3              413.4    4.3    1.35
    413.56    5.4    -4.3              413.71    -2    1.46
    413.86    5.4    -4.3              414.01    -2    1.52
    414.15    5.4    -4.3              414.3    -2.3    1.52
    414.45    5.4    -4.3              414.6    3.5    1.52
    414.75    5.4    -4.3              414.9    3.9    1.39
    415.06    5.4    -4.3              415.2    -2    1.35
    415.34    5.4    -4.3              415.48    -4.3    1.45
    415.62    5.4    -4.3              415.77    -9.8    1.15
    415.92    5.4    -4.3              416.08    -4.7    1.54
    416.23    5.4    -4.3              416.38    -5.1    1.48
    416.54    5.4    -4.3              416.71    -5.9    1.48
    416.85    5.4    -4.3              417.01    -5.5    1.5
    417.17    5.4    -4.3              417.32    -5.9    1.52
    417.49    5.4    -4.3              417.63    0    1.54
    417.79    5.4    -4.3              417.93    0    2.03
    418.08    5.4    -4.3              418.23    0    2.4
    418.38    5.4    -4.3              418.55    0    2.68
    418.68    5.4    -4.3              418.84    0    2.64
    419    5.4    -4.3              419.15    0    2.73
    419.31    5.4    -4.3              419.46    0    2.71
    419.61    5.4    -4.3              419.77    0    2.66
    419.92    5.4    -4.3              420.07    0    2.7
    420.22    5.4    -4.3              420.39    0    2.68
    420.54    5.4    -4.3              420.7    0    2.71
    420.85    5.4    -4.3              420.99    0    2.32
    421.14    5.4    -4.3              421.29    0    1.64
    421.43    5.4    -4.3              421.59    0    1.27
    421.75    5.4    -4.3              421.91    0    1.15
    422.07    5.4    -4.3              422.22    -1.2    1.13
    422.38    5.4    -4.3              422.53    -2.3    1.15
    422.68    5.4    -4.3              422.83    -0.8    1.23
    422.97    5.4    -4.3              423.12    -0.8    1.21
    423.26    5.4    -4.3              423.41    -0.4    1.23
    423.57    5.4    -4.3              423.72    1.6    1.29
    423.89    5.4    -4.3              424.05    0.8    1.25
    424.2    5.4    -4.3              424.36    2.7    1.29
    424.52    5.4    -4.3              424.68    3.1    1.27
    424.83    5.4    -4.3              424.99    3.5    1.27
    425.14    5.4    -4.3              425.29    4.3    1.27
    425.44    5.4    -4.3              425.6    3.9    1.23
    425.76    5.4    -4.3              425.92    4.3    1.25
    426.07    5.4    -4.3              426.22    4.3    1.21
    426.38    5.4    -4.3              426.53    3.9    1.19
    426.7    5.4    -4.3              426.86    3.5    1.41
    427.01    5.4    -4.3              427.17    1.6    1.43
    427.33    5.4    -4.3              427.48    3.9    1.43
    427.64    5.4    -4.3              427.8    -3.1    1.43
    427.95    5.4    -4.3              428.11    -5.1    1.46
    428.26    5.4    -4.3              428.41    -6.3    1.46
    428.58    5.4    -4.3              428.73    -7.4    1.48
    428.89    5.4    -4.3              429.05    -8.2    1.48
    429.2    5.4    -4.3              429.34    -8.2    1.5
    429.48    5.4    -4.3              429.64    -9    1.48
    429.79    5.4    -4.3              429.95    -8.2    1.5
    430.11    5.4    -4.3              430.25    -9    1.5
    430.42    5.4    -4.3              430.58    -8.2    1.52
    430.73    5.4    -4.3              430.88    -3.5    1.45
    431.05    5.4    -4.3              431.2    -3.1    1.43
    431.35    5.4    -4.3              431.51    -9.4    1.43
    431.66    5.4    -4.3              431.82    -14.5    1.41
    431.97    5.4    -4.3              432.13    -11.3    1.5
    432.3    5.4    -4.3              432.46    -9.4    1.52
    432.62    5.4    -4.3              432.79    -9    1.52
    432.96    5.4    -4.3              433.11    -8.2    1.54
    433.27    5.4    -4.3              433.42    -2    1.52
    433.58    5.4    -4.3              433.74    -4.3    1.46
    433.89    5.4    -4.3              434.05    -2.3    1.46
    434.21    5.4    -4.3              434.36    -2.7    1.45
    434.52    5.4    -4.3              434.67    -2.7    1.45
    434.81    5.4    -4.3              434.96    -2.3    1.45
    435.1    5.4    -4.3              435.25    -8.2    1.45
    435.41    5.4    -4.3              435.57    -8.2    1.5
    435.72    5.4    -4.3              435.89    -8.6    1.5
    436.05    5.4    -4.3              436.21    -8.6    1.5
    436.36    5.4    -4.3              436.52    -2.3    1.52
    436.68    5.4    -4.3              436.85    -2.3    1.45
    437    5.4    -4.3              437.16    -2    1.41
    437.32    5.4    -4.3              437.47    -2.3    1.37
    437.62    5.4    -4.3              437.77    -1.6    1.41
    437.92    5.4    -4.3              438.08    -2.3    1.37
    438.24    5.4    -4.3              438.37    -9.8    1.09
    438.51    5.4    -4.3              438.66    -10.9    1.13
    438.81    5.4    -4.3              438.96    -12.1    1.29
    439.13    5.4    -4.3              439.27    -10.9    1.56
    439.44    5.4    -4.3              439.58    -8.6    1.62
    439.73    5.4    -4.3              439.88    -7    1.64
    440.02    5.4    -4.3              440.18    -6.6    1.58
    440.33    5.4    -4.3              440.49    -6.6    1.58
    440.65    5.4    -4.3              440.82    -6.6    1.56
    440.99    5.4    -4.3              441.14    -5.9    1.6
    441.3    5.4    -4.3              441.46    -5.1    1.58
    441.61    5.4    -4.3              441.77    -4.3    1.58
    441.91    5.4    -4.3              442.06    -3.9    1.58
    442.21    5.4    -4.3              442.35    0    1.58
    442.48    5.4    -4.3              442.63    0.4    1.54
    442.79    5.4    -4.3              442.96    5.1    1.82
    443.13    5.4    -4.3              443.28    -2.7    1.21
    443.44    5.4    -4.3              443.61    6.6    1.58
    443.76    5.4    -4.3              443.91    5.9    1.46
    444.08    5.4    -4.3              444.24    6.6    1.46
    444.38    5.4    -4.3              444.53    6.6    1.46
    444.68    5.4    -4.3              444.83    5.9    1.37
    444.99    5.4    -4.3              445.15    8.2    1.46
    445.31    5.4    -4.3              445.47    9    1.46
    445.6    5.4    -4.3              445.75    7    1.35
    445.9    5.4    -4.3              446.05    0.4    1.45
    446.21    5.4    -4.3              446.36    0    1.5
    446.51    5.4    -4.3              446.67    -1.6    1.48
    446.83    5.4    -4.3              446.99    -2.7    1.46
    447.13    5.4    -4.3              447.28    -3.1    1.5
    447.42    5.4    -4.3              447.57    -2.7    1.52
    447.73    5.4    -4.3              447.88    -1.6    1.19
    448.04    5.4    -4.3              448.2    1.6    1.43
    448.34    5.4    -4.3              448.49    -3.1    1.45
    448.63    5.4    -4.3              448.79    -6.3    1.37
    448.94    5.4    -4.3              449.11    -9    1.41
    449.24    5.4    -4.3              449.39    -9    1.48
    449.55    5.4    -4.3              449.69    -7.4    1.56
    449.85    5.4    -4.3              449.99    -0.4    1.58
    450.12    5.4    -4.7              450.27    0.4    1.48
    450.44    5.4    -4.7              450.59    1.6    1.46
    450.75    5.4    -4.7              450.9    2.3    1.41
    451.05    5.4    -4.7              451.21    1.6    1.37
    451.37    5.4    -4.7              451.53    1.6    1.39
    451.69    5.4    -4.7              451.83    3.9    1.52
    451.99    5.4    -4.7              452.16    -6.6    1.07
    452.33    5.4    -4.7              452.48    -7.8    1.43
    452.63    5.4    -4.7              452.78    -7    1.52
    452.95    5.4    -4.7              453.1    -5.5    1.58
    453.24    5.4    -4.7              453.38    1.2    1.48
    453.53    5.4    -4.7              453.69    0.4    1.37
    453.83    5.4    -4.7              453.99    2    1.45
    454.16    5.4    -4.7              454.33    2    1.48
    454.49    5.4    -4.7              454.63    4.3    1.56
    454.78    5.4    -4.7              454.93    3.9    1.48
    455.09    5.4    -4.7              455.25    3.5    1.46
    455.41    5.4    -4.7              455.57    3.1    1.43
    455.72    5.4    -4.7              455.87    1.2    1.25
    456.02    5.4    -4.7              456.16    0    1.19
    456.32    5.4    -4.7              456.48    -1.2    1.15
    456.64    5.4    -4.7              456.8    -5.5    1.19
    456.95    5.4    -4.7              457.11    -6.3    1.21
    457.27    5.4    -4.7              457.4    -7.4    1.23
    457.55    5.4    -4.7              457.68    -8.6    1.31
    457.84    5.3    -4.7              457.99    -9    1.39
    458.14    5.3    -4.7              458.3    -9    1.48
    458.45    5.3    -4.7              458.61    -8.6    1.5
    458.76    5.3    -4.7              458.92    -8.6    1.5
    459.08    5.3    -4.7              459.24    -8.2    1.54
    459.39    5.3    -4.7              459.55    -7.8    1.56
    459.69    5.3    -4.7              459.84    -7.4    1.56
    459.99    5.3    -4.7              460.13    -7    1.56
    460.28    5.3    -4.7              460.43    -6.6    1.58
    460.59    5.3    -4.7              460.75    -6.3    1.56
    460.9    5.3    -4.7              461.05    -5.9    1.56
    461.23    5.3    -4.7              461.39    -5.5    1.54
    461.55    5.3    -4.7              461.7    -5.1    1.58
    461.85    5.3    -4.7              462    -4.7    1.58
    462.15    5.3    -4.7              462.29    -3.9    1.58
    462.45    5.3    -4.7              462.6    -3.9    1.56
    462.77    5.3    -4.7              462.93    0    1.56
    463.1    5.3    -4.7              463.24    0    1.54
    463.38    5.3    -4.7              463.52    0    1.48
    463.67    5.3    -4.7              463.82    0.4    1.46
    463.98    5.3    -4.7              464.14    0.4    1.46
    464.29    5.3    -4.7              464.45    0.8    1.45
    464.6    5.3    -4.7              464.74    0.8    1.43
    464.9    5.3    -4.7              465.06    0.8    1.45
    465.21    5.3    -4.7              465.37    0.8    1.46
    465.53    5.3    -4.7              465.68    1.2    1.46
    465.84    5.3    -4.7              466    1.2    1.45
    466.15    5.3    -4.7              466.31    1.2    1.45
    466.46    5.3    -4.7              466.62    1.2    1.45
    466.8    5.3    -4.7              466.95    1.6    1.45
    467.1    5.3    -4.7              467.26    1.6    1.45
    467.42    5.3    -4.7              467.58    1.6    1.43
    467.73    5.3    -4.7              467.89    1.6    1.43
    468.05    5.3    -4.7              468.19    1.6    1.45
    468.35    5.3    -4.7              468.49    2    1.45
    468.65    5.3    -4.7              468.8    2    1.45
    468.97    5.3    -4.7              469.13    2    1.43
    469.28    5.3    -4.7              469.44    2    1.45
    469.58    5.3    -4.7              469.73    2    1.45
    469.88    5.3    -4.7              470.03    2.3    1.45
    470.18    5.3    -4.7              470.34    -1.6    1.41
    470.5    5.3    -4.7              470.64    -1.6    1.41
    470.81    5.3    -4.7              470.97    -1.6    1.5
    471.12    5.3    -4.7              471.27    -1.6    1.5
    471.41    5.3    -4.7              471.56    -1.6    1.54
    471.72    5.3    -4.7              471.88    -1.2    1.52
    472.03    5.3    -4.7              472.19    -1.2    1.52
    472.35    5.3    -4.7              472.48    -1.2    1.54
    472.62    5.3    -4.7              472.76    -1.2    1.52
    472.92    5.3    -4.7              473.07    -1.2    1.52
    473.22    5.3    -4.7              473.39    -1.2    1.52
    473.55    5.3    -4.7              473.71    -1.2    1.52
    473.85    5.3    -4.7              473.99    -1.2    1.54
    474.13    5.3    -4.7              474.27    -0.8    1.52
    474.44    5.3    -4.7              474.58    2.7    1.52
    474.75    5.3    -4.7              474.91    2.3    1.48
    475.05    5.3    -4.7              475.19    2    1.45
    475.34    5.3    -4.7              475.49    2    1.43
    475.63    5.3    -4.7              475.77    2    1.43
    475.92    5.3    -4.7              476.07    7    1.64
    476.22    5.3    -4.7              476.36    2    1.46
    476.52    5.3    -4.7              476.69    5.5    1.6
    476.83    5.3    -4.7              476.98    7.8    1.5
    477.13    5.3    -4.7              477.29    5.5    1.46
    477.45    5.3    -4.7              477.6    7.4    1.45
    477.75    5.3    -4.7              477.9    7    1.41
    478.06    5.3    -4.7              478.23    7.4    1.45
    478.39    5.3    -4.7              478.54    7.8    1.43
    478.7    5.3    -4.7              478.86    7    1.35
    479.01    5.3    -4.7              479.17    7.8    1.43
    479.33    5.3    -4.7              479.48    0.8    1.33
    479.64    5.3    -4.7              479.8    1.6    1.52
    479.96    5.3    -4.7              480.12    2    1.58
    480.27    5.3    -4.7              480.42    1.2    1.52
    480.57    5.3    -4.7              480.73    7.4    1.56
    480.89    5.3    -4.7              481.05    6.3    1.39
    481.2    5.3    -4.7              481.36    6.3    1.37
    481.52    5.3    -4.7              481.67    0    1.46
    481.83    5.3    -4.7              481.97    -0.8    1.5
    482.12    5.3    -4.7              482.28    -1.6    1.5
    482.43    5.3    -4.7              482.59    -2    1.5
    482.75    5.3    -4.7              482.91    3.5    1.45
    483.06    5.3    -4.7              483.22    3.1    1.33
    483.38    5.3    -4.7              483.54    -3.9    1.41
    483.71    5.3    -4.7              483.88    -4.7    1.52
    484.02    5.3    -4.7              484.16    -3.1    1.52
    484.3    5.3    -4.7              484.44    -5.1    1.45
    484.59    5.3    -4.7              484.74    -7.4    1.35
    484.89    5.3    -4.7              485.04    -8.6    1.45
    485.2    5.3    -4.7              485.36    -7.4    1.54
    485.52    5.3    -4.7              485.67    -7    1.56
    485.83    5.3    -4.7              485.99    -0.4    1.48
    486.13    5.3    -4.7              486.27    0.4    1.45
    486.41    5.3    -4.7              486.56    1.2    1.45
    486.71    5.3    -4.7              486.87    1.2    1.45
    487.03    5.3    -4.7              487.18    2    1.45
    487.34    5.3    -4.7              487.49    -3.1    1.52
    487.65    5.3    -4.7              487.81    2.3    1.43
    487.95    5.3    -4.7              488.11    2.7    1.43
    488.27    5.3    -4.7              488.41    -2.3    1.41
    488.58    5.3    -4.7              488.74    -4.7    1.43
    488.89    5.3    -4.7              489.04    -3.5    1.5
    489.19    5.3    -4.7              489.34    -4.3    1.48
    489.49    5.3    -4.7              489.63    3.5    1.58
    489.77    5.3    -4.7              489.92    -7    1.09
    490.07    5.3    -4.7              490.23    -8.2    1.45
    490.39    5.3    -4.7              490.54    -7.4    1.58
    490.7    5.3    -5.1              490.86    -3.9    1.64
    491.02    5.3    -5.1              491.17    1.2    1.45
    491.33    5.3    -5.1              491.49    2.3    1.43
    491.64    5.3    -5.1              491.8    2.3    1.41
    491.94    5.3    -5.1              492.08    2    1.37
    492.23    5.3    -5.1              492.38    -3.9    1.5
    492.52    5.3    -5.1              492.67    -3.9    1.54
    492.83    5.3    -5.1              492.98    -6.3    1.48
    493.14    5.3    -5.1              493.3    -4.3    1.54
    493.46    5.3    -5.1              493.61    2.7    1.54
    493.75    5.3    -5.1              493.91    3.1    1.45
    494.06    5.3    -5.1              494.21    1.2    1.31
    494.37    5.3    -5.1              494.53    2.3    1.41
    494.69    5.3    -5.1              494.84    -5.1    1.46
    495    5.3    -5.1              495.15    -5.1    1.5
    495.31    5.3    -5.1              495.47    -5.9    1.48
    495.62    5.3    -5.1              495.78    -5.5    1.45
    495.93    5.3    -5.1              496.09    -6.3    1.45
    496.25    5.3    -5.1              496.41    -7.4    1.48
    496.57    5.3    -5.1              496.74    -7.4    1.54
    496.91    5.3    -5.1              497.05    -0.4    1.6
    497.19    5.3    -5.1              497.35    1.2    1.5
    497.51    5.3    -5.1              497.66    3.5    1.52
    497.81    5.3    -5.1              497.97    5.1    1.52
    498.12    5.3    -5.1              498.28    6.6    1.52
    498.44    5.3    -5.1              498.58    7.8    1.5
    498.72    5.3    -5.1              498.86    8.2    1.46
    499.01    5.3    -5.1              499.16    8.6    1.45
    499.31    5.3    -5.1              499.47    9.4    1.45
    499.62    5.3    -5.1              499.78    8.2    1.31
    499.94    5.3    -5.1              500.09    6.6    1.29
    500.25    5.3    -5.1              500.41    3.1    1.09
    500.57    5.3    -5.1              500.74    2    1.07
    500.89    5.3    -5.1              501.04    -2.3    1.15
    501.19    5.3    -5.1              501.34    -3.1    1.25
    501.49    5.3    -5.1              501.65    -4.7    1.19
    501.81    5.3    -5.1              501.97    -7    1.13
    502.12    5.3    -5.1              502.28    -7    1.33
    502.44    5.3    -5.1              502.58    -6.6    1.43
    502.75    5.3    -5.1              502.91    -6.6    1.45
    503.05    5.3    -5.1              503.19    -7    1.45
    503.33    5.3    -5.1              503.47    -7.8    1.43
    503.61    5.3    -5.1              503.77    -8.2    1.45
    503.91    5.3    -5.1              504.05    -8.2    1.48
    504.19    5.3    -5.1              504.34    -8.2    1.48
    504.49    5.3    -5.1              504.63    -8.2    1.52
    504.78    5.3    -5.1              504.94    -7    1.56
    505.09    5.3    -5.1              505.25    -6.6    1.56
    505.41    5.3    -5.1              505.56    -7    1.54
    505.72    5.3    -5.1              505.88    -6.6    1.56
    506.03    5.3    -5.1              506.18    -6.3    1.56
    506.33    5.3    -5.1              506.48    -5.9    1.56
    506.64    5.3    -5.1              506.79    -6.3    1.54
    506.95    5.3    -5.1              507.11    -6.3    1.52
    507.27    5.3    -5.1              507.42    -5.9    1.54
    507.58    5.3    -5.1              507.74    -6.3    1.52
    507.91    5.3    -5.1              508.06    -6.3    1.52
    508.21    5.3    -5.1              508.36    -6.3    1.52
    508.51    5.3    -5.1              508.66    -6.3    1.54
    508.8    5.3    -5.1              508.95    -5.9    1.54
    509.1    5.3    -5.1              509.24    -1.2    1.54
    509.4    5.3    -5.1              509.56    -0.4    1.5
    509.72    5.3    -5.1              509.87    0    1.46
    510.03    5.3    -5.1              510.19    0.4    1.46
    510.34    5.3    -5.1              510.5    0.4    1.43
    510.66    5.3    -5.1              510.82    0.4    1.45
    510.97    5.3    -5.1              511.13    0.8    1.45
    511.28    5.3    -5.1              511.43    1.2    1.45
    511.59    5.3    -5.1              511.75    1.2    1.43
    511.91    5.3    -5.1              512.06    0.8    1.41
    512.21    5.3    -5.1              512.38    0.8    1.33
    512.52    5.3    -5.1              512.68    -3.9    1.43
    512.84    5.3    -5.1              513    -3.5    1.54
    513.15    5.3    -5.1              513.31    -2    1.58
    513.46    5.3    -5.1              513.62    2.3    1.45
    513.78    5.3    -5.1              513.93    3.5    1.41
    514.09    5.3    -5.1              514.25    3.5    1.39
    514.41    5.3    -5.1              514.56    3.1    1.37
    514.72    5.3    -5.1              514.88    -3.1    1.43
    515.03    5.3    -5.1              515.19    -3.5    1.5
    515.35    5.3    -5.1              515.49    -3.9    1.52
    515.63    5.3    -5.1              515.77    -4.3    1.52
    515.91    5.3    -5.1              516.05    -4.3    1.52
    516.2    5.3    -5.1              516.36    1.6    1.48
    516.51    5.3    -5.1              516.67    1.6    1.39
    516.83    5.3    -5.1              516.97    1.6    1.35
    517.12    5.3    -5.1              517.27    -4.7    1.39
    517.42    5.3    -5.1              517.58    -4.3    1.52
    517.73    5.3    -5.1              517.89    -4.3    1.54
    518.05    5.3    -5.1              518.19    -4.3    1.54
    518.33    5.3    -5.1              518.47    0.8    1.41
    518.61    5.3    -5.1              518.76    1.6    1.41
    518.91    5.3    -5.1              519.05    1.2    1.37
    519.2    5.3    -5.1              519.36    -5.1    1.39
    519.51    5.3    -5.1              519.67    -3.9    1.56
    519.82    5.3    -5.1              519.98    -4.7    1.54
    520.13    5.3    -5.1              520.28    1.6    1.54
    520.43    5.3    -5.1              520.59    -3.5    1.04
    520.75    5.3    -5.1              520.91    -3.1    1.29
    521.07    5.3    -5.1              521.22    -5.9    1.39
    521.36    5.3    -5.1              521.53    -5.9    1.45
    521.68    5.3    -5.1              521.84    -6.6    1.43
    521.99    5.3    -5.1              522.13    -7.4    1.43
    522.29    5.3    -5.1              522.45    -7.8    1.46
    522.6    5.3    -5.1              522.76    -7.8    1.5
    522.92    5.3    -5.1              523.08    -7.4    1.52
    523.23    5.3    -5.1              523.39    -7    1.54
    523.54    5.3    -5.1              523.7    -7    1.54
    523.86    5.3    -5.1              524.01    -6.6    1.56
    524.17    5.3    -5.1              524.33    -6.3    1.54
    524.48    5.3    -5.1              524.64    -6.3    1.54
    524.79    5.3    -5.1              524.95    -5.9    1.54
    525.11    5.3    -5.1              525.27    -5.9    1.54
    525.42    5.3    -5.1              525.58    -5.5    1.54
    525.74    5.3    -5.1              525.91    -5.5    1.54
    526.06    5.3    -5.1              526.22    -5.5    1.52
    526.38    5.3    -5.1              526.53    -1.6    1.54
    526.69    5.3    -5.1              526.84    -1.2    1.54
    527    5.3    -5.1              527.16    -0.8    1.5
    527.31    5.3    -5.1              527.47    -0.8    1.48
    527.61    5.3    -5.1              527.77    -0.4    1.48
    527.93    5.3    -5.1              528.08    0    1.48
    528.22    5.3    -5.1              528.38    0    1.48
    528.52    5.3    -5.1              528.67    0.4    1.46
    528.82    5.3    -5.1              528.98    0.4    1.45
    529.13    5.3    -5.1              529.29    0.4    1.45
    529.45    5.3    -5.1              529.61    0.8    1.45
    529.76    5.3    -5.1              529.92    0.8    1.45
    530.08    5.3    -5.1              530.23    0.8    1.43
    530.39    5.3    -5.1              530.55    0.8    1.45
    530.7    5.3    -5.1              530.86    1.2    1.46
    531.01    5.3    -5.1              531.17    1.6    1.45
    531.33    5.3    -5.1              531.48    1.6    1.45
    531.64    5.3    -5.1              531.8    1.6    1.45
    531.95    5.3    -5.1              532.11    1.6    1.46
    532.27    5.3    -5.1              532.44    2    1.46
    532.58    5.3    -5.1              532.72    4.3    1.23
    532.87    5.3    -5.1              533.02    -6.3    1.33
    533.18    5.3    -5.1              533.34    1.6    1.68
    533.49    5.3    -5.1              533.65    3.5    1.54
    533.81    5.3    -5.1              533.96    3.5    1.41
    534.12    5.3    -5.1              534.27    6.3    1.5
    534.42    5.3    -5.1              534.57    5.9    1.46
    534.73    5.3    -5.1              534.89    7    1.43
    535.04    5.3    -5.1              535.2    6.6    1.39
    535.36    5.3    -5.1              535.52    -0.8    1.43
    535.67    5.3    -5.1              535.83    -3.1    1.43
    535.97    5.3    -5.1              536.12    -2.7    1.54
    536.27    5.3    -5.1              536.41    0    1.58
    536.55    5.3    -5.1              536.71    4.7    1.41
    536.87    5.3    -5.1              537.03    0    1.5
    537.19    5.3    -5.1              537.34    0    2.62
    537.5    5.3    -5.1              537.66    0    1.07
    537.81    5.3    -5.1              537.96    -1.2    1.15
    538.11    5.3    -5.1              538.26    0.8    1.31
    538.42    5.3    -5.1              538.57    2.3    1.46
    538.73    5.3    -5.1              538.89    -0.8    1.48
    539.05    5.3    -5.1              539.21    5.9    1.5
    539.37    5.3    -5.1              539.52    7    1.48
    539.67    5.3    -5.1              539.83    0    2.23
    539.98    5.3    -5.1              540.14    0    2.64
    540.29    5.3    -5.1              540.45    0    1.04
    540.6    5.3    -5.1              540.76    -2.3    1.15
    540.93    5.3    -5.1              541.08    0.4    1.45
    541.23    5.3    -5.1              541.39    3.5    1.5
    541.53    5.3    -5.1              541.68    3.9    1.48
    541.84    5.3    -5.1              541.99    5.5    1.48
    542.15    5.3    -5.1              542.31    5.9    1.46
    542.47    5.3    -5.1              542.63    0    1.39
    542.8    5.3    -5.1              542.95    0    2.58
    543.11    5.3    -5.1              543.27    0    1.41
    543.44    5.3    -5.1              543.6    -3.1    1.07
    543.75    5.3    -5.1              543.9    0    1.48
    544.05    5.3    -5.1              544.19    2    1.5
    544.33    5.3    -5.1              544.47    2.3    1.46
    544.61    5.3    -5.1              544.76    3.5    1.5
    544.91    5.3    -5.1              545.06    4.7    1.46
    545.21    5.3    -5.1              545.37    2.3    1.35
    545.53    5.3    -5.1              545.68    5.9    1.48
    545.84    5.3    -5.1              545.99    6.6    1.48
    546.14    5.3    -5.1              546.29    9.4    1.46
    546.45    5.3    -5.1              546.61    -3.9    1.41
    546.77    5.3    -5.1              546.91    -4.7    1.48
    547.05    5.3    -5.1              547.2    -3.9    1.5
    547.35    5.3    -5.1              547.51    -5.5    1.48
    547.67    5.3    -5.1              547.83    -3.5    1.52
    547.98    5.3    -5.1              548.14    -5.1    1.5
    548.3    5.3    -5.1              548.45    -2    1.54
    548.61    5.3    -5.1              548.75    -0.8    1.54
    548.89    5.3    -5.1              549.04    -0.4    1.54
    549.19    5.3    -5.1              549.33    0    1.54
    549.47    5.3    -5.1              549.62    0    1.52
    549.77    5.3    -5.1              549.91    -1.6    1.48
    550.06    5.3    -5.1              550.22    -1.6    1.5
    550.37    5.3    -5.1              550.53    -1.6    1.5
    550.68    5.3    -5.1              550.84    -2.3    1.48
    551    5.3    -5.1              551.15    -4.7    1.43
    551.31    5.3    -5.1              551.47    -5.1    1.46
    551.62    5.3    -5.1              551.78    -5.5    1.46
    551.94    5.3    -5.1              552.09    0    1.46
    552.25    5.3    -5.1              552.41    0    1.95
    552.56    5.3    -5.1              552.72    0    2.36
    552.88    5.3    -5.1              553.05    0    2.64
    553.21    5.3    -5.1              553.38    0    2.62
    553.55    5.3    -5.1              553.7    0    2.7
    553.86    5.3    -5.1              554.02    0    2.66
    554.17    5.3    -5.1              554.32    0    2.64
    554.47    5.3    -5.1              554.62    0    1.76
    554.77    5.3    -5.1              554.93    0    1.35
    555.08    5.3    -5.1              555.23    0    1.19
    555.38    5.3    -5.1              555.54    -0.4    1.11
    555.7    5.3    -5.1              555.85    -3.5    1.11
    556.01    5.3    -5.1              556.17    -3.5    1.13
    556.33    5.3    -5.1              556.48    -3.9    1.13
    556.64    5.3    -5.1              556.8    -4.3    1.15
    556.96    5.3    -5.1              557.13    -4.7    1.15
    557.28    5.3    -5.1              557.44    -5.5    1.15
    557.6    5.3    -5.1              557.77    -5.5    1.15
    557.94    5.3    -5.1              558.09    -5.9    1.17
    558.25    5.3    -5.1              558.41    -6.3    1.17
    558.57    5.3    -5.1              558.72    -5.9    1.19
    558.87    5.3    -5.1              559.02    0    1.45
    559.18    5.3    -5.1              559.33    0    2.13
    559.48    5.3    -5.1              559.63    0    2.46
    559.79    5.3    -5.1              559.94    0    2.58
    560.09    5.3    -5.1              560.24    0    1.99
    560.4    5.3    -5.1              560.56    0    1.17
    560.72    5.3    -5.1              560.87    -0.8    1.23
    561.03    5.3    -5.1              561.18    2    1.29
    561.34    5.3    -5.1              561.5    0    1.21
    561.66    5.3    -5.1              561.81    1.2    1.25
    561.97    5.3    -5.1              562.13    2.3    1.25
    562.3    5.3    -5.1              562.46    3.1    1.25
    562.62    5.3    -5.1              562.77    3.5    1.27
    562.92    5.3    -5.1              563.07    4.3    1.27
    563.23    5.3    -5.1              563.39    5.1    1.25
    563.55    5.3    -5.1              563.69    4.7    1.23
    563.84    5.3    -5.1              563.99    5.1    1.25
    564.15    5.3    -5.1              564.31    5.5    1.43
    564.47    5.3    -5.1              564.63    5.1    1.48
    564.8    5.3    -5.1              564.96    7.8    1.48
    565.13    5.3    -5.1              565.3    8.2    1.45
    565.46    5.3    -5.1              565.63    2.3    1.5
    565.8    5.3    -5.1              565.97    1.6    1.5
    566.12    5.3    -5.1              566.28    2    1.5
    566.44    5.3    -5.1              566.58    7.4    1.46
    566.72    5.3    -5.1              566.87    7.8    1.45
    567.02    5.3    -5.1              567.18    1.2    1.43
    567.34    5.3    -5.1              567.51    1.2    1.5
    567.67    5.3    -5.1              567.82    0.8    1.5
    567.98    5.3    -5.1              568.14    0.4    1.5
    568.3    5.3    -5.1              568.45    6.3    1.5
    568.61    5.3    -5.1              568.75    5.9    1.43
    568.89    5.3    -5.1              569.03    3.9    1.37
    569.18    5.3    -5.1              569.33    -4.7    1.17
    569.47    5.3    -5.1              569.62    -5.1    1.33
    569.77    5.3    -5.1              569.91    -4.7    1.43
    570.05    5.3    -5.1              570.2    -5.1    1.43
    570.35    5.3    -5.1              570.51    -5.9    1.43
    570.67    5.3    -5.1              570.83    -6.6    1.43
    570.98    5.3    -5.1              571.14    -7.4    1.45
    571.3    5.3    -5.1              571.46    -7.8    1.45
    571.62    5.3    -5.1              571.77    -8.2    1.45
    571.93    5.3    -5.1              572.09    -9    1.45
    572.24    5.3    -5.1              572.4    -9    1.48
    572.57    5.3    -5.1              572.73    -8.6    1.48
    572.89    5.3    -5.1              573.04    -9    1.48
    573.2    5.3    -5.1              573.36    -9    1.5
    573.5    5.3    -5.1              573.65    0    1.48
    573.81    5.3    -5.1              573.96    0    1.64
    574.12    5.3    -5.1              574.28    0    2.07
    574.44    5.3    -5.1              574.59    0    2.4
    574.75    5.3    -5.1              574.89    0    2.52
    575.05    5.3    -5.1              575.21    0    2.5
    575.36    5.3    -5.1              575.5    0    2.15
    575.65    5.3    -5.1              575.8    0    1.7
    575.94    5.3    -5.1              576.08    0    1.45
    576.22    5.3    -5.1              576.37    0    1.31
    576.52    5.3    -5.1              576.69    0    1.21
    576.84    5.3    -5.1              576.99    0    1.19
    577.15    5.3    -5.1              577.31    -0.4    1.17
    577.47    5.3    -5.1              577.62    -0.8    1.19
    577.78    5.3    -5.1              577.93    -0.8    1.23
    578.08    5.3    -5.1              578.22    -1.2    1.15
    578.36    5.3    -5.1              578.51    -1.6    1.25
    578.66    5.3    -5.1              578.81    2    1.25
    578.96    5.3    -5.1              579.12    0    1.23
    579.28    5.3    -5.1              579.44    2    1.27
    579.61    5.3    -5.1              579.76    2.7    1.27
    579.92    5.3    -5.1              580.08    2.7    1.25
    580.22    5.3    -5.1              580.37    2.7    1.23
    580.53    5.3    -5.1              580.68    3.9    1.35
    580.84    5.3    -5.1              581    3.9    1.48
    581.15    5.3    -5.1              581.31    3.9    1.48
    581.46    5.3    -5.1              581.62    6.3    1.45
    581.78    5.3    -5.1              581.94    0.8    1.46
    582.08    5.3    -5.1              582.22    0.4    1.5
    582.36    5.3    -5.1              582.51    0    1.5
    582.66    5.3    -5.1              582.81    -1.6    1.46
    582.96    5.3    -5.1              583.12    -2.7    1.48
    583.28    5.3    -5.1              583.44    -2.7    1.5
    583.59    5.3    -5.1              583.74    3.1    1.43
    583.91    5.3    -5.1              584.06    3.9    1.45
    584.21    5.3    -5.1              584.37    -2.3    1.5
    584.53    5.3    -5.1              584.69    -2.7    1.5
    584.84    5.3    -5.1              585    3.1    1.5
    585.14    5.3    -5.1              585.29    2.3    1.41
    585.44    5.3    -5.1              585.58    -0.4    1.39
    585.73    5.3    -5.1              585.89    -2.3    1.48
    586.04    5.3    -5.1              586.2    -4.7    1.45
    586.34    5.3    -5.1              586.49    -7.4    1.43
    586.64    5.3    -5.1              586.79    -7.8    1.5
    586.94    5.3    -5.1              587.09    -5.1    1.54
    587.25    5.3    -5.1              587.41    1.2    1.48
    587.57    5.3    -5.1              587.73    2.7    1.48
    587.89    5.3    -5.1              588.05    3.5    1.46
    588.19    5.3    -5.1              588.33    3.9    1.46
    588.47    5.3    -5.1              588.61    3.9    1.46
    588.76    5.3    -5.1              588.91    3.1    1.41
    589.07    5.3    -5.1              589.23    3.9    1.43
    589.39    5.3    -5.1              589.55    7    1.5
    589.69    5.3    -5.1              589.83    -3.9    1.39
    589.98    5.3    -5.1              590.13    -5.1    1.48
    590.27    5.3    -5.1              590.41    -4.7    1.5
    590.58    5.3    -5.1              590.73    -4.7    1.54
    590.89    5.3    -5.1              591.05    -3.1    1.58
    591.2    5.3    -5.1              591.36    2.3    1.43
    591.51    5.3    -5.1              591.66    2.7    1.41
    591.81    5.3    -5.1              591.97    2.3    1.39
    592.12    5.3    -5.1              592.28    -2    1.54
    592.43    5.3    -5.1              592.58    3.1    1.43
    592.74    5.3    -5.1              592.9    3.1    1.37
    593.06    5.3    -5.1              593.21    -1.6    1.54
    593.37    5.3    -5.1              593.53    3.9    1.48
    593.69    5.3    -5.1              593.83    3.5    1.39
    593.97    5.3    -5.1              594.12    -2    1.5
    594.28    5.3    -5.1              594.43    -2    1.5
    594.6    5.3    -5.1              594.74    2    1.27
    594.9    5.3    -5.1              595.05    0    1.31
    595.2    5.3    -5.1              595.35    -3.5    1.39
    595.51    5.3    -5.1              595.67    -2.3    1.56
    595.81    5.3    -5.1              595.96    -7.8    1.37
    596.12    5.3    -5.1              596.28    -8.2    1.5
    596.44    5.3    -5.5              596.58    -6.3    1.6
    596.72    5.3    -5.5              596.87    2.3    1.64
    597.03    5.3    -5.5              597.18    3.5    1.52
    597.34    5.3    -5.5              597.49    3.9    1.46
    597.65    5.3    -5.5              597.81    6.6    1.5
    597.96    5.3    -5.5              598.12    0    1.11
    598.28    5.3    -5.5              598.44    4.7    1.5
    598.58    5.3    -5.5              598.72    3.1    1.41
    598.86    5.3    -5.5              599.01    2.7    1.39
    599.17    5.3    -5.5              599.33    3.1    1.39
    599.47    5.3    -5.5              599.62    2.3    1.33
    599.77    5.3    -5.5              599.93    0.4    1.23
    600.09    5.3    -5.5              600.25    0    1.29
    600.4    5.3    -5.5              600.56    -3.9    1.35
    600.72    5.3    -5.5              600.88    -3.9    1.45
    601.03    5.3    -5.5              601.18    -4.3    1.46
    601.33    5.3    -5.5              601.47    -7    1.35
    601.61    5.3    -5.5              601.76    -5.9    1.48
    601.91    5.3    -5.5              602.07    -5.9    1.46
    602.23    5.3    -5.5              602.39    -6.3    1.48
    602.54    5.3    -5.5              602.7    -6.3    1.5
    602.86    5.3    -5.5              603    -6.3    1.5
    603.14    5.3    -5.5              603.29    -6.6    1.48
    603.45    5.3    -5.5              603.61    -6.6    1.52
    603.76    5.3    -5.5              603.92    -6.6    1.5
    604.08    5.3    -5.5              604.24    -6.6    1.5
    604.39    5.3    -5.5              604.54    -7    1.5
    604.7    5.3    -5.5              604.85    -6.6    1.52
    605.01    5.3    -5.5              605.17    -7    1.52
    605.33    5.3    -5.5              605.47    0    1.5
    605.61    5.3    -5.5              605.75    0    1.88
    605.91    5.3    -5.5              606.08    0    2.27
    606.25    5.3    -5.5              606.41    0    2.62
    606.58    5.3    -5.5              606.73    0    2.62
    606.89    5.3    -5.5              607.04    0    2.64
    607.2    5.3    -5.5              607.36    0    2.64
    607.51    5.3    -5.5              607.67    0    2.64
    607.81    5.3    -5.5              607.96    0    2.7
    608.11    5.3    -5.5              608.26    0    2.64
    608.41    5.3    -5.5              608.57    0    2.73
    608.73    5.3    -5.5              608.88    0    2.73
    609.04    5.3    -5.5              609.19    0    2.7
    609.34    5.3    -5.5              609.49    0    2.75
    609.66    5.3    -5.5              609.81    0    2.64
    609.96    5.3    -5.5              610.12    0    2.66
    610.28    5.3    -5.5              610.45    0    2.66
    610.61    5.3    -5.5              610.75    0    2.64
    610.9    5.3    -5.5              611.05    0    2.75
    611.2    5.3    -5.5              611.35    0    2.7
    611.51    5.3    -5.5              611.67    0    2.73
    611.83    5.3    -5.5              611.98    0    2.68
    612.14    5.3    -5.5              612.28    0    2.75
    612.42    5.3    -5.5              612.57    0    2.71
    612.72    5.3    -5.5              612.86    0    2.75
    613    5.3    -5.5              613.14    0    2.7
    613.28    5.3    -5.5              613.43    0    2.64
    613.58    5.3    -5.5              613.72    0    2.64
    613.86    5.3    -5.5              614    0    2.73
    614.14    5.3    -5.5              614.28    0    2.75
    614.43    5.3    -5.5              614.58    0    2.75
    614.74    5.3    -5.5              614.89    0    2.64
    615.03    5.3    -5.5              615.18    0    2.71
    615.34    5.3    -5.5              615.49    0    2.64
    615.65    5.3    -5.5              615.82    0    2.71
    615.96    5.3    -5.5              616.12    0    2.66
    616.28    5.3    -5.5              616.44    0    2.66
    616.59    5.3    -5.5              616.74    0    2.68
    616.89    5.3    -5.5              617.03    0    2.73
    617.18    5.3    -5.5              617.34    0    2.77
    617.49    5.3    -5.5              617.65    0    2.68
    617.81    5.3    -5.5              617.97    0    2.77
    618.14    5.3    -5.5              618.3    0    2.7
    618.47    5.3    -5.5              618.62    0    2.66
    618.78    5.3    -5.5              618.93    0    2.68
    619.09    5.3    -5.5              619.25    0    2.73
    619.4    5.3    -5.5              619.56    0    2.64
    619.72    5.3    -5.5              619.87    0    2.66
    620.03    5.3    -5.5              620.19    0    2.73
    620.36    5.3    -5.5              620.51    0    2.73
    620.68    5.3    -5.5              620.84    0    2.75
    621    5.3    -5.5              621.15    0    2.73
    621.31    5.3    -5.5              621.47    0    2.48
    621.62    5.3    -5.5              621.78    0    1.72
    621.93    5.3    -5.5              622.09    0    1.33
    622.25    5.3    -5.5              622.4    0.8    1.29
    622.56    5.3    -5.5              622.72    1.2    1.23
    622.87    5.3    -5.5              623.03    1.6    1.27
    623.19    5.3    -5.5              623.33    2.3    1.25
    623.48    5.3    -5.5              623.64    0.8    1.19
    623.78    5.3    -5.5              623.94    2    1.29
    624.09    5.3    -5.5              624.25    2    1.25
    624.41    5.3    -5.5              624.58    2.7    1.23
    624.72    5.3    -5.5              624.88    2.3    1.21
    625.03    5.3    -5.5              625.18    2.7    1.21
    625.34    5.3    -5.5              625.49    5.5    1.31
    625.65    5.3    -5.5              625.81    0.4    1.41
    625.96    5.3    -5.5              626.12    -3.1    1.48
    626.28    5.3    -5.5              626.43    -1.6    1.52
    626.59    5.3    -5.5              626.75    4.7    1.48
    626.9    5.3    -5.5              627.06    4.3    1.45
    627.22    5.3    -5.5              627.36    4.3    1.43
    627.5    5.3    -5.5              627.64    0    1.5
    627.78    5.3    -5.5              627.93    4.3    1.5
    628.08    5.3    -5.5              628.23    4.7    1.45
    628.38    5.3    -5.5              628.54    0.4    1.45
    628.71    5.3    -5.5              628.86    0    1.5
    629.02    5.3    -5.5              629.2    4.7    1.45
    629.35    5.3    -5.5              629.5    4.7    1.45
    629.65    5.3    -5.5              629.8    -0.4    1.48
    629.94    5.3    -5.5              630.09    4.7    1.5
    630.24    5.3    -5.5              630.4    3.5    1.39
    630.56    5.3    -5.5              630.72    -3.9    1.5
    630.88    5.3    -5.5              631.05    -2.3    1.5
    631.19    5.3    -5.5              631.35    -3.5    1.48
    631.51    5.3    -5.5              631.67    -1.2    1.52
    631.82    5.3    -5.5              631.98    0    1.54
    632.13    5.3    -5.5              632.29    -0.8    1.5
    632.45    5.3    -5.5              632.61    -1.2    1.5
    632.75    5.3    -5.5              632.89    -2    1.5
    633.04    5.3    -5.5              633.19    -3.9    1.5
    633.34    5.3    -5.5              633.5    3.5    1.52
    633.65    5.3    -5.5              633.81    4.3    1.48
    633.97    5.3    -5.5              634.11    4.3    1.45
    634.25    5.3    -5.5              634.4    5.1    1.48
    634.55    5.3    -5.5              634.7    5.5    1.46
    634.85    5.3    -5.5              635.01    -0.8    1.48
    635.17    5.3    -5.5              635.32    -0.4    1.5
    635.49    5.3    -5.5              635.64    -2.3    1.46
    635.79    5.3    -5.5              635.95    -3.1    1.48
    636.11    5.3    -5.5              636.26    2.7    1.54
    636.41    5.3    -5.5              636.56    2.7    1.37
    636.71    5.3    -5.5              636.87    3.1    1.37
    637.03    5.3    -5.5              637.18    -2    1.54
    637.34    5.3    -5.5              637.5    3.5    1.54
    637.64    5.3    -5.5              637.8    3.1    1.37
    637.96    5.3    -5.5              638.12    -2.7    1.35
    638.27    5.3    -5.5              638.43    -2.7    1.52
    638.59    5.3    -5.5              638.76    -2.3    1.56
    638.9    5.3    -5.5              639.06    3.1    1.39
    639.21    5.3    -5.5              639.37    3.1    1.37
    639.53    5.3    -5.5              639.68    -2.7    1.52
    639.84    5.3    -5.5              640    -2.7    1.52
    640.15    5.3    -5.5              640.31    2.7    1.39
    640.47    5.3    -5.5              640.62    3.1    1.41
    640.78    5.3    -5.5              640.92    -3.5    1.45
    641.07    5.3    -5.5              641.22    -3.9    1.52
    641.38    5.3    -5.5              641.54    -3.5    1.48
    641.7    5.3    -5.5              641.85    -4.3    1.54
    642.01    5.3    -5.5              642.17    1.6    1.43
    642.33    5.3    -5.5              642.49    2.3    1.43
    642.64    5.3    -5.5              642.79    2.7    1.43
    642.94    5.3    -5.5              643.09    -2    1.52
    643.25    5.3    -5.5              643.41    3.5    1.5
    643.55    5.3    -5.5              643.69    3.9    1.41
    643.85    5.3    -5.5              644.01    3.9    1.39
    644.17    5.3    -5.5              644.33    -1.2    1.54
    644.49    5.3    -5.5              644.64    3.9    1.45
    644.79    5.3    -5.5              644.95    3.1    1.33
    645.1    5.3    -5.5              645.26    -2    1.58
    645.41    5.3    -5.5              645.57    -2    1.52
    645.72    5.3    -5.5              645.87    3.5    1.39
    646.02    5.3    -5.5              646.18    3.5    1.35
    646.34    5.3    -5.5              646.5    -3.5    1.48
    646.64    5.3    -5.5              646.79    -3.9    1.5
    646.95    5.3    -5.5              647.1    -4.3    1.5
    647.26    5.3    -5.5              647.42    1.6    1.54
    647.56    5.3    -5.5              647.7    1.2    1.37
    647.85    5.3    -5.5              648.01    1.2    1.37
    648.16    5.3    -5.5              648.32    -3.9    1.52
    648.48    5.3    -5.5              648.63    -4.7    1.54
    648.79    5.3    -5.5              648.94    -3.5    1.6
    649.1    5.3    -5.5              649.26    3.1    1.46
    649.41    5.3    -5.5              649.57    4.3    1.45
    649.73    5.3    -5.5              649.89    3.9    1.41
    650.05    5.3    -5.5              650.2    3.5    1.37
    650.35    5.3    -5.5              650.51    3.1    1.35
    650.66    5.3    -5.5              650.84    -2.3    1.45
    651    5.3    -5.5              651.15    -7.8    1.15
    651.31    5.3    -5.5              651.46    -5.5    1.45
    651.61    5.3    -5.5              651.76    -4.3    1.52
    651.91    5.3    -5.5              652.07    -4.3    1.5
    652.23    5.3    -5.5              652.39    -5.1    1.48
    652.55    5.3    -5.5              652.71    -5.5    1.48
    652.87    5.3    -5.5              653.02    -5.5    1.48
    653.18    5.3    -5.5              653.34    -5.9    1.5
    653.49    5.3    -5.5              653.65    -5.5    1.54
    653.81    5.3    -5.5              653.96    -6.6    1.52
    654.12    5.3    -5.5              654.29    -5.1    1.56
    654.45    5.3    -5.5              654.62    -5.1    1.56
    654.78    5.3    -5.5              654.92    -5.9    1.52
    655.06    5.3    -5.5              655.21    -1.6    1.45
    655.36    5.3    -5.5              655.51    0    1.43
    655.67    5.3    -5.5              655.82    0    1.37
    655.98    5.3    -5.5              656.14    -1.2    1.33
    656.28    5.3    -5.5              656.43    -7.8    1.21
    656.59    5.3    -5.5              656.75    -10.9    1.23
    656.9    5.3    -5.5              657.06    -9.4    1.48
    657.22    5.3    -5.5              657.36    -7    1.56
    657.5    5.3    -5.5              657.65    -7.4    1.52
    657.81    5.3    -5.5              657.97    -7.8    1.52
    658.11    5.3    -5.5              658.25    -7.4    1.54
    658.4    5.3    -5.5              658.56    -7.4    1.52
    658.71    5.3    -5.5              658.87    -7.4    1.52
    659.03    5.3    -5.5              659.18    -7.4    1.52
    659.34    5.3    -5.5              659.5    -7    1.52
    659.66    5.3    -5.5              659.81    -7.4    1.52
    659.96    5.3    -5.5              660.11    -7.4    1.52
    660.26    5.3    -5.5              660.41    -7    1.52
    660.57    5.3    -5.5              660.73    0    1.5
    660.89    5.3    -5.5              661.04    0    1.88
    661.2    5.3    -5.5              661.35    0    1.97
    661.5    5.3    -5.5              661.66    0    1.29
    661.81    5.3    -5.5              661.96    0    1.25
    662.12    5.3    -5.5              662.28    -0.4    1.21
    662.43    5.3    -5.5              662.59    -1.6    1.17
    662.76    5.3    -5.5              662.9    -1.2    1.19
    663.07    5.3    -5.5              663.22    2.7    1.43
    663.37    5.3    -5.5              663.53    0    1.45
    663.7    5.3    -5.5              663.86    0    1.48
    664.01    5.3    -5.5              664.17    4.3    1.5
    664.31    5.3    -5.5              664.46    4.3    1.46
    664.62    5.3    -5.5              664.77    4.7    1.43
    664.93    5.3    -5.5              665.09    -2.7    1.48
    665.25    5.3    -5.5              665.41    -2.3    1.5
    665.58    5.3    -5.5              665.73    -2    1.52
    665.9    5.3    -5.5              666.04    4.3    1.46
    666.2    5.3    -5.5              666.36    4.3    1.45
    666.52    5.3    -5.5              666.67    4.3    1.43
    666.84    5.3    -5.5              666.99    -2    1.5
    667.13    5.3    -5.5              667.29    -2.3    1.5
    667.45    5.3    -5.5              667.61    -3.1    1.5
    667.75    5.3    -5.5              667.89    3.1    1.46
    668.04    5.3    -5.5              668.2    2.7    1.43
    668.35    5.3    -5.5              668.5    -3.5    1.46
    668.64    5.3    -5.5              668.78    -6.3    1.45
    668.93    5.3    -5.5              669.08    -9.4    1.43
    669.24    5.3    -5.5              669.4    -4.3    1.52
    669.55    5.3    -5.5              669.71    -5.9    1.48
    669.87    5.3    -5.5              670.02    -5.9    1.5
    670.18    5.3    -5.5              670.34    -5.9    1.5
    670.5    5.3    -5.5              670.66    -5.9    1.5
    670.81    5.3    -5.5              670.96    -6.3    1.5
    671.11    5.3    -5.5              671.26    -7.8    1.48
    671.42    5.3    -5.5              671.58    -6.6    1.5
    671.73    5.3    -5.5              671.88    -0.8    1.5
    672.03    5.3    -5.5              672.18    -0.8    1.45
    672.33    5.3    -5.5              672.47    -2    1.41
    672.62    5.3    -5.5              672.77    -3.1    1.39
    672.93    5.3    -5.5              673.08    -9    1.43
    673.24    5.3    -5.5              673.4    -10.2    1.46
    673.56    5.3    -5.5              673.72    -10.2    1.5
    673.87    5.3    -5.5              674.03    -10.2    1.5
    674.18    5.3    -5.5              674.35    -10.9    1.5
    674.5    5.3    -5.5              674.66    -10.5    1.54
    674.82    5.3    -5.5              674.98    -10.2    1.54
    675.15    5.3    -5.5              675.32    -10.9    1.52
    675.48    5.3    -5.5              675.64    -5.1    1.5
    675.81    5.3    -5.5              675.96    -4.3    1.43
    676.12    5.3    -5.5              676.27    -3.9    1.39
    676.44    5.3    -5.5              676.58    -4.7    1.41
    676.75    5.3    -5.5              676.93    -11.3    1.21
    677.08    5.3    -5.5              677.24    -12.5    1.33
    677.4    5.3    -5.5              677.54    -10.5    1.54
    677.71    5.3    -5.5              677.87    -8.6    1.6
    678.03    5.3    -5.5              678.19    -8.2    1.58
    678.34    5.3    -5.5              678.49    -8.2    1.56
    678.65    5.3    -5.5              678.8    -7.8    1.56
    678.94    5.3    -5.5              679.1    -3.9    1.54
    679.26    5.3    -5.5              679.42    -4.3    1.45
    679.57    5.3    -5.5              679.73    -3.5    1.46
    679.88    5.3    -5.5              680.02    -3.9    1.43
    680.17    5.3    -5.5              680.32    -3.5    1.45
    680.48    5.3    -5.5              680.64    -3.9    1.41
    680.8    5.3    -5.5              680.96    -3.5    1.45
    681.11    5.3    -5.5              681.26    0    1.54
    681.43    5.3    -5.5              681.57    0    1.31
    681.71    5.3    -5.5              681.85    0    1.19
    682.01    5.3    -5.5              682.16    0.8    1.41
    682.3    5.3    -5.5              682.46    -1.2    1.45
    682.62    5.3    -5.5              682.78    1.2    1.48
    682.94    5.3    -5.5              683.09    3.9    1.48
    683.23    5.3    -5.5              683.38    5.5    1.48
    683.52    5.3    -5.5              683.67    5.9    1.46
    683.81    5.3    -5.5              683.96    5.9    1.45
    684.12    5.3    -5.5              684.26    5.5    1.45
    684.41    5.3    -5.5              684.58    -0.4    1.5
    684.73    5.3    -5.5              684.89    0.4    1.52
    685.06    5.3    -5.5              685.2    0.4    1.52
    685.35    5.3    -5.5              685.5    5.5    1.45
    685.64    5.3    -5.5              685.78    5.9    1.45
    685.94    5.3    -5.5              686.1    5.1    1.41
    686.27    5.3    -5.5              686.43    -4.3    1.15
    686.58    5.3    -5.5              686.74    -5.9    1.35
    686.9    5.3    -5.5              687.05    -4.7    1.45
    687.2    5.3    -5.5              687.35    -5.1    1.45
    687.51    5.3    -5.5              687.66    -5.5    1.45
    687.82    5.3    -5.5              687.98    -6.3    1.46
    688.12    5.3    -5.5              688.27    -6.3    1.46
    688.44    5.3    -5.5              688.59    -6.3    1.48
    688.75    5.3    -5.5              688.91    -5.9    1.5
    689.07    5.3    -5.5              689.23    -6.3    1.5
    689.39    5.3    -5.5              689.53    -6.6    1.46
    689.67    5.3    -5.5              689.81    -8.2    1.41
    689.97    5.3    -5.5              690.13    -9    1.43
    690.28    5.3    -5.5              690.43    -9.8    1.46
    690.59    5.3    -5.5              690.73    -9.4    1.5
    690.88    5.3    -5.5              691.04    -8.6    1.52
    691.19    5.3    -5.5              691.35    -8.2    1.5
    691.51    5.3    -5.5              691.67    -8.2    1.52
    691.81    5.3    -5.5              691.96    -8.2    1.54
    692.09    5.3    -5.5              692.24    -8.2    1.52
    692.4    5.3    -5.5              692.56    -8.2    1.52
    692.72    5.3    -5.5              692.86    -8.2    1.54
    693    5.3    -5.5              693.16    -7.8    1.54
    693.3    5.3    -5.5              693.47    -7.4    1.54
    693.63    5.3    -5.5              693.79    -7    1.56
    693.93    5.3    -5.5              694.1    -6.3    1.58
    694.26    5.3    -5.5              694.39    -5.9    1.58
    694.54    5.3    -5.5              694.68    -5.5    1.58
    694.82    5.3    -5.5              694.98    -5.1    1.58
    695.13    5.3    -5.5              695.29    -4.7    1.56
    695.45    5.3    -5.5              695.62    -4.3    1.56
    695.79    5.3    -5.5              695.96    -3.9    1.54
    696.12    5.3    -5.5              696.28    -3.9    1.54
    696.42    5.3    -5.5              696.57    -3.9    1.54
    696.7    5.3    -5.5              696.84    -3.9    1.54
    696.99    5.3    -5.5              697.15    -3.5    1.54
    697.31    5.3    -5.5              697.46    -3.5    1.52
    697.62    5.3    -5.5              697.78    -3.5    1.52
    697.93    5.3    -5.5              698.09    -3.5    1.54
    698.24    5.3    -5.5              698.39    -3.1    1.54
    698.55    5.3    -5.5              698.7    -3.1    1.54
    698.86    5.3    -5.5              699.02    -3.1    1.52
    699.17    5.3    -5.5              699.33    -3.1    1.52
    699.49    5.3    -5.5              699.63    -3.1    1.52
    699.8    5.3    -5.5              699.95    -3.1    1.54
    700.12    5.3    -5.5              700.27    -2.7    1.54
    700.43    5.3    -5.5              700.56    -2.7    1.52
    700.71    5.3    -5.5              700.86    0.8    1.54
    701.01    5.3    -5.5              701.14    0.8    1.5
    701.3    5.3    -5.5              701.44    0.8    1.48
    701.61    5.3    -5.5              701.76    1.2    1.48
    701.92    5.3    -5.5              702.08    1.6    1.46
    702.24    5.3    -5.5              702.39    1.6    1.45
    702.55    5.3    -5.5              702.71    1.6    1.43
    702.87    5.3    -5.5              703.02    1.2    1.43
    703.18    5.3    -5.5              703.33    1.2    1.43
    703.49    5.3    -5.5              703.65    1.2    1.43
    703.82    5.3    -5.5              703.97    1.2    1.43
    704.13    5.3    -5.5              704.29    1.2    1.43
    704.44    5.3    -5.5              704.6    1.2    1.43
    704.76    5.3    -5.5              704.89    1.2    1.43
    705.04    5.3    -5.5              705.17    1.2    1.43
    705.31    5.3    -5.5              705.47    1.6    1.45
    705.62    5.3    -5.5              705.78    1.6    1.45
    705.93    5.3    -5.5              706.09    1.6    1.45
    706.25    5.3    -5.5              706.41    2    1.45
    706.56    5.3    -5.5              706.72    2    1.45
    706.88    5.3    -5.5              707.03    -1.6    1.43
    707.19    5.3    -5.5              707.35    -1.6    1.45
    707.5    5.3    -5.5              707.65    -1.6    1.5
    707.81    5.3    -5.5              707.97    -1.6    1.5
    708.13    5.3    -5.5              708.28    -1.6    1.52
    708.44    5.3    -5.5              708.59    -1.6    1.52
    708.75    5.3    -5.5              708.91    -1.6    1.52
    709.06    5.3    -5.5              709.22    -1.6    1.52
    709.38    5.3    -5.5              709.53    -1.6    1.5
    709.69    5.3    -5.5              709.84    -1.6    1.52
    710    5.3    -5.5              710.16    -1.2    1.56
    710.31    5.3    -5.5              710.47    -1.2    1.62
    710.63    5.3    -5.5              710.78    2    1.5
    710.94    5.3    -5.5              711.1    8.2    1.7
    711.25    5.3    -5.5              711.41    11.3    1.6
    711.57    5.3    -5.5              711.72    7.4    1.45
    711.87    5.3    -5.5              712.03    8.2    1.46
    712.2    5.3    -5.5              712.35    9.4    1.48
    712.5    5.3    -5.5              712.65    7.8    1.33
    712.8    5.3    -5.5              712.95    9.8    1.45
    713.11    5.3    -5.5              713.27    9.8    1.43
    713.42    5.3    -5.5              713.58    9.4    1.41
    713.74    5.3    -5.5              713.9    6.6    1.25
    714.05    5.3    -5.5              714.21    10.5    1.46
    714.37    5.3    -5.5              714.54    9.8    1.39
    714.69    5.3    -5.5              714.85    8.6    1.31
    715.01    5.3    -5.5              715.18    -0.4    1.02
    715.33    5.3    -5.5              715.49    -1.6    1.13
    715.64    5.3    -5.5              715.8    -2    1.25
    715.96    5.3    -5.5              716.11    -0.8    1.54
    716.27    5.3    -5.5              716.43    -2.3    1.5
    716.59    5.3    -5.5              716.76    -0.8    1.54
    716.93    5.3    -5.5              717.07    0    1.56
    717.21    5.3    -5.5              717.35    0    1.56
    717.49    5.3    -5.5              717.64    6.3    1.58
    717.79    5.3    -5.5              717.94    5.9    1.39
    718.09    5.3    -5.5              718.25    6.6    1.39
    718.41    5.3    -5.5              718.56    6.6    1.37
    718.72    5.3    -5.5              718.88    -0.8    1.48
    719.03    5.3    -5.5              719.19    -1.6    1.5
    719.35    5.3    -5.5              719.5    -5.1    1.37
    719.66    5.3    -5.5              719.82    -2.3    1.52
    719.96    5.3    -5.5              720.13    -2    1.52
    720.29    5.3    -5.5              720.44    -4.7    1.37
    720.6    5.3    -5.5              720.75    -6.6    1.43
    720.91    5.3    -5.5              721.07    -6.6    1.52
    721.21    5.3    -5.5              721.35    2.3    1.64
    721.51    5.3    -5.5              721.66    4.3    1.5
    721.82    5.3    -5.5              721.98    5.9    1.48
    722.15    5.3    -5.5              722.3    4.3    1.27
    722.46    5.3    -5.5              722.61    4.3    1.41
    722.77    5.3    -5.5              722.92    5.1    1.48
    723.08    5.3    -5.5              723.24    5.1    1.23
    723.39    5.3    -5.5              723.55    -3.1    1.23
    723.7    5.3    -5.5              723.86    -3.9    1.5
    724.02    5.3    -5.5              724.17    -2.7    1.54
    724.33    5.3    -5.5              724.48    4.7    1.54
    724.64    5.3    -5.5              724.8    5.5    1.48
    724.95    5.3    -5.5              725.11    3.9    1.33
    725.26    5.3    -5.5              725.4    3.9    1.39
    725.55    5.3    -5.5              725.7    4.7    1.48
    725.86    5.3    -5.5              726.02    6.6    1.48
    726.17    5.3    -5.5              726.33    3.5    1.27
    726.49    5.3    -5.5              726.64    -1.6    1.52
    726.8    5.3    -5.5              726.96    -1.6    1.5
    727.11    5.3    -5.5              727.27    -0.8    1.52
    727.43    5.3    -5.5              727.58    0.4    1.58
    727.74    5.3    -5.5              727.89    5.9    1.6
    728.04    5.3    -5.5              728.21    6.6    1.54
    728.36    5.3    -5.5              728.52    6.3    1.46
    728.68    5.3    -5.5              728.83    5.5    1.33
    728.99    5.3    -5.5              729.15    2.3    1.19
    729.3    5.3    -5.5              729.46    1.6    1.23
    729.62    5.3    -5.5              729.78    -3.1    1.33
    729.93    5.3    -5.5              730.08    -3.5    1.46
    730.24    5.3    -5.5              730.38    -3.5    1.48
    730.53    5.3    -5.5              730.68    -4.3    1.48
    730.82    5.3    -5.5              730.97    -3.1    1.54
    731.11    5.3    -5.5              731.28    -4.3    1.54
    731.44    5.3    -5.5              731.59    -4.3    1.56
    731.75    5.3    -5.5              731.91    2.7    1.52
    732.06    5.3    -5.5              732.22    3.1    1.45
    732.38    5.3    -5.5              732.53    4.7    1.46
    732.69    5.3    -5.5              732.84    5.5    1.46
    733    5.3    -5.5              733.15    5.1    1.39
    733.31    5.3    -5.5              733.47    5.5    1.41
    733.62    5.3    -5.5              733.78    -0.8    1.5
    733.93    5.3    -5.5              734.08    0    1.56
    734.23    5.3    -5.5              734.39    5.5    1.48
    734.54    5.3    -5.5              734.68    5.9    1.39
    734.82    5.3    -5.5              734.97    5.9    1.39
    735.12    5.3    -5.5              735.28    -0.4    1.5
    735.44    5.3    -5.5              735.59    0.4    1.54
    735.75    5.3    -5.5              735.91    5.5    1.54
    736.06    5.3    -5.5              736.22    5.5    1.37
    736.37    5.3    -5.5              736.53    5.5    1.35
    736.69    5.3    -5.5              736.85    -1.2    1.5
    737    5.3    -5.5              737.16    -1.2    1.54
    737.32    5.3    -5.5              737.47    -1.6    1.52
    737.63    5.3    -5.5              737.79    3.9    1.54
    737.94    5.3    -5.5              738.11    3.5    1.35
    738.26    5.3    -5.5              738.43    -3.1    1.29
    738.58    5.3    -5.5              738.74    -4.3    1.46
    738.89    5.3    -5.5              739.05    -4.3    1.5
    739.21    5.3    -5.5              739.36    -3.9    1.54
    739.52    5.3    -5.5              739.68    2    1.54
    739.83    5.3    -5.5              739.99    2    1.43
    740.15    5.3    -5.5              740.3    2.3    1.37
    740.46    5.3    -5.5              740.61    -3.9    1.5
    740.77    5.3    -5.5              740.93    -3.9    1.52
    741.08    5.3    -5.5              741.24    -6.6    1.5
    741.4    5.3    -5.5              741.53    -4.3    1.5
    741.68    5.3    -5.5              741.82    -3.1    1.56
    741.96    5.3    -5.5              742.11    -2    1.58
    742.26    5.3    -5.5              742.42    2.7    1.6
    742.57    5.3    -5.5              742.72    3.5    1.52
    742.87    5.3    -5.5              743.03    3.1    1.46
    743.18    5.3    -5.5              743.33    2.3    1.39
    743.48    5.3    -5.5              743.64    1.2    1.33
    743.79    5.3    -5.5              743.93    0.8    1.33
    744.08    5.3    -5.5              744.23    0.4    1.31
    744.39    5.3    -5.5              744.55    -1.6    1.21
    744.7    5.3    -5.5              744.86    -5.9    1.23
    745.01    5.3    -5.5              745.17    -5.5    1.46
    745.33    5.3    -5.5              745.48    -2    1.48
    745.64    5.3    -5.5              745.8    0    1.7
    745.95    5.3    -5.5              746.11    0    2.17
    746.27    5.3    -5.5              746.43    0    2.5
    746.58    5.3    -5.5              746.74    0    2.6
    746.88    5.3    -5.5              747.04    0    2.68
    747.21    5.3    -5.5              747.37    0    2.66
    747.54    5.3    -5.5              747.69    0    2.7
    747.85    5.3    -5.5              748.01    0    2.68
    748.18    5.3    -5.5              748.33    0    2.03
    748.49    5.3    -5.5              748.65    0    1.7
    748.82    5.3    -5.5              748.97    0    1.33
    749.13    5.3    -5.5              749.28    0    1.19
    749.44    5.3    -5.5              749.6    0.4    1.27
    749.76    5.3    -5.5              749.91    -2    1.15
    750.06    5.3    -5.5              750.21    0.8    1.21
    750.36    5.3    -5.5              750.5    0.8    1.23
    750.66    5.3    -5.5              750.81    1.2    1.25
    750.97    5.3    -5.5              751.13    1.6    1.25
    751.28    5.3    -5.5              751.43    2    1.25
    751.6    5.3    -5.5              751.75    1.6    1.17
    751.91    5.3    -5.5              752.07    -0.8    1.41
    752.22    5.3    -5.5              752.38    2    1.48
    752.54    5.3    -5.5              752.71    -2    1.46
    752.86    5.3    -5.5              753.02    -2    1.5
    753.17    5.3    -5.5              753.32    3.5    1.46
    753.46    5.3    -5.5              753.61    3.9    1.45
    753.76    5.3    -5.5              753.92    -1.2    1.5
    754.08    5.3    -5.5              754.23    4.3    1.48
    754.39    5.3    -5.5              754.55    3.9    1.45
    754.7    5.3    -5.5              754.86    0    1.52
    755.02    5.3    -5.5              755.17    4.7    1.45
    755.33    5.3    -5.5              755.48    5.1    1.46
    755.64    5.3    -5.5              755.8    1.2    1.48
    755.96    5.3    -5.5              756.11    -3.1    1.46
    756.27    5.3    -5.5              756.43    0    1.5
    756.57    5.3    -5.5              756.71    -1.2    1.5
    756.87    5.3    -5.5              757.04    4.7    1.41
    757.21    5.3    -5.5              757.37    -5.5    1.37
    757.52    5.3    -5.5              757.66    -6.6    1.48
    757.81    5.3    -5.5              757.96    -6.3    1.5
    758.1    5.3    -5.5              758.24    -3.1    1.56
    758.39    5.3    -5.5              758.54    3.1    1.52
    758.7    5.3    -5.5              758.86    3.5    1.46
    759.01    5.3    -5.5              759.17    3.1    1.43
    759.33    5.3    -5.5              759.48    -1.2    1.46
    759.64    5.3    -5.5              759.79    -1.2    1.52
    759.95    5.3    -5.5              760.11    3.9    1.45
    760.26    5.3    -5.5              760.42    4.3    1.45
    760.58    5.3    -5.5              760.74    -0.4    1.52
    760.89    5.3    -5.5              761.05    4.7    1.46
    761.21    5.3    -5.5              761.37    4.7    1.45
    761.54    5.3    -5.5              761.71    -2.3    1.5
    761.86    5.3    -5.5              762.01    -1.6    1.48
    762.17    5.3    -5.5              762.32    -1.2    1.56
    762.48    5.3    -5.5              762.62    0    1.54
    762.77    5.3    -5.5              762.9    -4.7    1.41
    763.05    5.3    -5.5              763.2    -5.5    1.48
    763.34    5.3    -5.5              763.49    -3.9    1.54
    763.63    5.3    -5.5              763.78    2    1.56
    763.93    5.3    -5.5              764.08    2    1.41
    764.24    5.3    -5.5              764.4    2.3    1.45
    764.56    5.3    -5.5              764.71    0    1.33
    764.87    5.3    -5.5              765.02    1.2    1.48
    765.16    5.3    -5.5              765.33    2.3    1.48
    765.49    5.3    -5.5              765.64    1.6    1.43
    765.8    5.3    -5.5              765.96    1.2    1.41
    766.09    5.3    -5.5              766.23    1.6    1.45
    766.37    5.3    -5.5              766.52    1.2    1.37
    766.67    5.3    -5.5              766.82    0    1.31
    766.98    5.3    -5.5              767.15    -3.5    1.37
    767.31    5.3    -5.5              767.45    -3.9    1.43
    767.6    5.3    -5.5              767.75    -5.1    1.41
    767.89    5.3    -5.5              768.03    -5.1    1.45
    768.18    5.3    -5.5              768.33    -5.1    1.52
    768.49    5.3    -5.5              768.65    -4.7    1.5
    768.81    5.3    -5.5              768.95    -5.1    1.54
    769.09    5.3    -5.5              769.23    -3.9    1.56
    769.39    5.3    -5.5              769.54    -5.5    1.54
    769.69    5.3    -5.5              769.86    2    1.58
    770.01    5.3    -5.5              770.17    1.6    1.48
    770.33    5.3    -5.5              770.48    5.1    1.52
    770.63    5.3    -5.5              770.78    3.5    1.43
    770.93    5.3    -5.5              771.08    4.3    1.43
    771.24    5.3    -5.5              771.4    4.7    1.43
    771.56    5.3    -5.5              771.71    5.5    1.43
    771.86    5.3    -5.5              772.02    5.1    1.41
    772.17    5.3    -5.5              772.32    5.1    1.39
    772.47    5.3    -5.5              772.63    -0.4    1.46
    772.79    5.3    -5.5              772.95    0.8    1.56
    773.11    5.3    -5.5              773.27    5.9    1.54
    773.42    5.3    -5.5              773.57    5.5    1.41
    773.72    5.3    -5.5              773.88    5.5    1.35
    774.04    5.3    -5.5              774.2    5.5    1.35
    774.34    5.3    -5.5              774.48    -3.9    1.07
    774.63    5.3    -5.5              774.79    -4.3    1.29
    774.94    5.3    -5.5              775.1    -3.9    1.43
    775.26    5.3    -5.5              775.41    -3.5    1.48
    775.57    5.3    -5.5              775.72    -4.3    1.45
    775.87    5.3    -5.5              776.03    -5.1    1.43
    776.18    5.3    -5.5              776.33    -5.1    1.46
    776.49    5.3    -5.5              776.65    -5.9    1.48
    776.81    5.3    -5.5              776.96    -6.3    1.48
    777.11    5.3    -5.5              777.28    -5.9    1.52
    777.42    5.3    -5.5              777.56    -3.9    1.6
    777.73    5.3    -5.5              777.86    -3.9    1.58
    778.03    5.3    -5.5              778.19    3.5    1.54
    778.33    5.3    -5.5              778.49    3.9    1.48
    778.64    5.3    -5.5              778.79    5.5    1.48
    778.95    5.3    -5.5              779.11    5.9    1.43
    779.26    5.3    -5.5              779.41    6.3    1.43
    779.57    5.3    -5.5              779.7    6.6    1.43
    779.85    5.3    -5.5              780    6.6    1.41
    780.16    5.3    -5.5              780.32    7    1.41
    780.48    5.3    -5.5              780.64    1.2    1.41
    780.78    5.3    -5.5              780.92    0.4    1.52
    781.08    5.3    -5.5              781.22    0.4    1.54
    781.39    5.3    -5.5              781.54    5.5    1.5
    781.7    5.3    -5.5              781.86    1.6    1.19
    782.01    5.3    -5.5              782.16    -2.3    1.39
    782.33    5.3    -5.5              782.49    -1.6    1.52
    782.64    5.3    -5.5              782.8    -2    1.5
    782.96    5.3    -5.5              783.11    -3.9    1.48
    783.28    5.3    -5.5              783.44    -4.3    1.48
    783.59    5.3    -5.5              783.74    -4.7    1.48
    783.89    5.3    -5.5              784.04    -5.9    1.48
    784.2    5.3    -5.5              784.36    -5.9    1.5
    784.52    5.3    -5.5              784.67    -5.5    1.5
    784.82    5.3    -5.5              784.97    -5.9    1.45
    785.13    5.3    -5.5              785.29    -9    1.25
    785.44    5.3    -5.5              785.6    -9    1.41
    785.76    5.3    -5.5              785.92    -7    1.54
    786.07    5.3    -5.5              786.22    -6.3    1.54
    786.37    5.3    -5.5              786.52    -6.6    1.52
    786.68    5.3    -5.5              786.84    -6.6    1.54
    787    5.3    -5.5              787.15    -6.6    1.52
    787.31    5.3    -5.5              787.47    -6.6    1.52
    787.62    5.3    -5.5              787.78    -6.6    1.52
    787.94    5.3    -5.5              788.09    -3.1    1.52
    788.25    5.3    -5.5              788.41    -3.5    1.45
    788.57    5.3    -5.5              788.72    -3.9    1.41
    788.88    5.3    -5.5              789.03    -3.9    1.41
    789.19    5.3    -5.5              789.35    -3.9    1.39
    789.5    5.3    -5.5              789.65    0    1.6
    789.82    5.3    -5.5              789.99    0    2.19
    790.15    5.3    -5.5              790.32    0    2.52
    790.47    5.3    -5.5              790.63    0    2.64
    790.79    5.3    -5.5              790.96    0    2.64
    791.12    5.3    -5.5              791.29    0    2.64
    791.43    5.3    -5.5              791.59    0    2.68
    791.74    5.3    -5.5              791.89    0    2.7
    792.04    5.3    -5.5              792.2    0    2.68
    792.36    5.3    -5.5              792.51    0    2.66
    792.67    5.3    -5.5              792.82    0    2.66
    792.99    5.3    -5.5              793.12    0    2.58
    793.26    5.3    -5.5              793.41    0    2.21
    793.56    5.3    -5.5              793.72    0    1.76
    793.87    5.3    -5.5              794.03    0    1.46
    794.17    5.3    -5.5              794.32    0    1.33
    794.46    5.3    -5.5              794.61    0    1.25
    794.77    5.3    -5.5              794.94    0    1.21
    795.09    5.3    -5.5              795.25    -0.4    1.21
    795.4    5.3    -5.5              795.56    -0.8    1.21
    795.72    5.3    -5.5              795.87    -0.8    1.21
    796.03    5.3    -5.5              796.19    -0.8    1.21
    796.35    5.3    -5.5              796.5    -1.2    1.17
    796.66    5.3    -5.5              796.81    -1.6    1.21
    796.97    5.3    -5.5              797.13    0.8    1.29
    797.29    5.3    -5.5              797.46    1.2    1.29
    797.61    5.3    -5.5              797.77    2    1.27
    797.93    5.3    -5.5              798.1    2    1.25
    798.24    5.3    -5.5              798.4    2.7    1.27
    798.56    5.3    -5.5              798.71    3.1    1.27
    798.85    5.3    -5.5              798.99    4.3    1.31
    799.13    5.3    -5.5              799.28    5.9    1.29
    799.43    5.3    -5.5              799.58    5.5    1.23
    799.73    5.3    -5.5              799.89    4.3    1.19
    800.05    5.3    -5.5              800.2    4.3    1.19
    800.36    5.3    -5.5              800.52    4.3    1.46
    800.67    5.3    -5.5              800.83    7.4    1.48
    800.99    5.3    -5.5              801.15    0    1.43
    801.32    5.3    -5.5              801.47    -0.4    1.5
    801.63    5.3    -5.5              801.78    0    1.5
    801.94    5.3    -5.5              802.1    6.3    1.52
    802.24    5.3    -5.5              802.39    5.9    1.43
    802.55    5.3    -5.5              802.69    0    1.43
    802.83    5.3    -5.5              802.98    0    1.5
    803.14    5.3    -5.5              803.29    -3.1    1.46
    803.45    5.3    -5.5              803.6    -1.2    1.5
    803.76    5.3    -5.5              803.92    -3.5    1.48
    804.06    5.3    -5.5              804.21    -4.7    1.43
    804.36    5.3    -5.9              804.52    -5.5    1.46
    804.68    5.3    -5.9              804.84    -5.1    1.5
    805    5.3    -5.9              805.17    1.6    1.52
    805.31    5.3    -5.9              805.46    2.3    1.48
    805.62    5.3    -5.9              805.78    2.7    1.46
    805.93    5.3    -5.9              806.08    6.6    1.52
    806.23    5.3    -5.9              806.38    8.6    1.5
    806.54    5.3    -5.9              806.7    8.6    1.48
    806.85    5.3    -5.9              806.99    8.6    1.46
    807.13    5.3    -5.9              807.28    8.6    1.46
    807.44    5.3    -5.9              807.61    7.8    1.41
    807.77    5.3    -5.9              807.92    8.2    1.43
    808.08    5.3    -5.9              808.23    7.8    1.43
    808.39    5.3    -5.9              808.55    1.2    1.45
    808.69    5.3    -5.9              808.83    0    1.48
    808.99    5.3    -5.9              809.15    -0.8    1.48
    809.31    5.3    -5.9              809.46    -1.2    1.48
    809.63    5.3    -5.9              809.78    -2.7    1.46
    809.93    5.3    -5.9              810.08    -5.1    1.33
    810.22    5.3    -5.9              810.38    -5.1    1.33
    810.53    5.3    -5.9              810.68    -4.7    1.41
    810.83    5.3    -5.9              811    -4.7    1.46
    811.15    5.3    -5.9              811.3    -4.7    1.5
    811.46    5.3    -5.9              811.61    -4.3    1.54
    811.76    5.3    -5.9              811.91    -3.9    1.54
    812.06    5.3    -5.9              812.2    -3.5    1.54
    812.34    5.3    -5.9              812.5    -3.5    1.54
    812.66    5.3    -5.9              812.81    -3.5    1.54
    812.97    5.3    -5.9              813.12    -3.5    1.52
    813.28    5.3    -5.9              813.42    -3.5    1.52
    813.57    5.3    -5.9              813.72    -3.5    1.52
    813.89    5.3    -5.9              814.04    -3.5    1.54
    814.2    5.3    -5.9              814.34    -3.1    1.54
    814.49    5.3    -5.9              814.63    -3.1    1.52
    814.77    5.3    -5.9              814.92    -3.1    1.52
    815.07    5.3    -5.9              815.22    -3.5    1.52
    815.38    5.3    -5.9              815.55    -3.5    1.52
    815.71    5.3    -5.9              815.87    -3.5    1.52
    816.03    5.3    -5.9              816.19    -3.5    1.52
    816.36    5.3    -5.9              816.52    -3.5    1.52
    816.67    5.3    -5.9              816.82    -3.5    1.5
    816.97    5.3    -5.9              817.13    -3.9    1.52
    817.28    5.3    -5.9              817.44    -3.9    1.52
    817.6    5.3    -5.9              817.74    -3.5    1.54
    817.89    5.3    -5.9              818.06    -3.5    1.52
    818.21    5.3    -5.9              818.37    -3.5    1.52
    818.53    5.3    -5.9              818.69    -3.9    1.5
    818.84    5.3    -5.9              818.99    -3.9    1.5
    819.15    5.3    -5.9              819.3    -0.8    1.5
    819.44    5.3    -5.9              819.59    -0.8    1.5
    819.74    5.3    -5.9              819.89    -0.4    1.48
    820.05    5.3    -5.9              820.19    0    1.46
    820.35    5.3    -5.9              820.52    0    1.43
    820.67    5.3    -5.9              820.83    0    1.43
    820.99    5.3    -5.9              821.14    -0.4    1.41
    821.29    5.3    -5.9              821.45    -0.4    1.39
    821.6    5.3    -5.9              821.73    -0.4    1.43
    821.87    5.3    -5.9              822.02    -0.4    1.45
    822.17    5.3    -5.9              822.33    4.3    1.68
    822.48    5.3    -5.9              822.64    3.5    1.5
    822.8    5.3    -5.9              822.95    4.3    1.54
    823.1    5.3    -5.9              823.26    3.9    1.41
    823.42    5.3    -5.9              823.58    1.6    1.31
    823.73    5.3    -5.9              823.89    1.2    1.31
    824.05    5.3    -5.9              824.21    0    1.23
    824.39    5.3    -5.9              824.55    -5.9    1.05
    824.7    5.3    -5.9              824.85    -7.4    1.11
    824.99    5.3    -5.9              825.12    -8.6    1.27
    825.28    5.3    -5.9              825.43    -8.6    1.45
    825.58    5.3    -5.9              825.74    -6.6    1.58
    825.9    5.3    -5.9              826.07    -5.5    1.6
    826.22    5.3    -5.9              826.37    -5.1    1.56
    826.52    5.3    -5.9              826.68    -4.7    1.56
    826.84    5.3    -5.9              827    -4.3    1.58
    827.15    5.3    -5.9              827.3    -0.4    1.8
    827.47    5.3    -5.9              827.6    3.9    1.6
    827.77    5.3    -5.9              827.91    1.2    1.46
    828.07    5.3    -5.9              828.21    2.7    1.48
    828.36    5.3    -5.9              828.51    2    1.41
    828.67    5.3    -5.9              828.82    1.6    1.41
    828.97    5.3    -5.9              829.14    1.6    1.41
    829.3    5.3    -5.9              829.45    1.6    1.39
    829.6    5.3    -5.9              829.74    0.4    1.25
    829.89    5.3    -5.9              830.03    -1.2    1.17
    830.18    5.3    -5.9              830.32    -5.5    1.27
    830.47    5.3    -5.9              830.62    -5.5    1.39
    830.78    5.3    -5.9              830.94    -5.1    1.5
    831.1    5.3    -5.9              831.25    -4.3    1.58
    831.41    5.3    -5.9              831.55    -3.5    1.56
    831.7    5.3    -5.9              831.85    -3.1    1.56
    832    5.3    -5.9              832.16    -2.7    1.56
    832.32    5.3    -5.9              832.48    -2.3    1.56
    832.62    5.3    -5.9              832.77    -2    1.58
    832.93    5.3    -5.9              833.09    -1.2    1.6
    833.24    5.3    -5.9              833.42    3.1    1.6
    833.58    5.3    -5.9              833.72    2.7    1.5
    833.88    5.3    -5.9              834.04    2.3    1.43
    834.19    5.3    -5.9              834.34    2.3    1.43
    834.49    5.3    -5.9              834.63    2.3    1.43
    834.78    5.3    -5.9              834.93    2.3    1.41
    835.09    5.3    -5.9              835.25    2.3    1.43
    835.41    5.3    -5.9              835.56    2.3    1.43
    835.72    5.3    -5.9              835.88    2.3    1.43
    836.03    5.3    -5.9              836.19    2.3    1.43
    836.35    5.3    -5.9              836.49    2.3    1.43
    836.62    5.3    -5.9              836.77    2.3    1.43
    836.92    5.3    -5.9              837.07    2.3    1.43
    837.23    5.3    -5.9              837.39    2.3    1.41
    837.55    5.3    -5.9              837.69    2    1.39
    837.86    5.3    -5.9              838.02    2    1.41
    838.18    5.3    -5.9              838.35    4.7    1.52
    838.49    5.3    -5.9              838.63    2.7    1.46
    838.77    5.3    -5.9              838.92    2.3    1.39
    839.07    5.3    -5.9              839.23    3.9    1.48
    839.39    5.3    -5.9              839.53    -1.6    1.43
    839.69    5.3    -5.9              839.86    -0.8    1.52
    840.02    5.3    -5.9              840.18    -2    1.52
    840.33    5.3    -5.9              840.48    -3.5    1.5
    840.63    5.3    -5.9              840.77    -3.1    1.5
    840.92    5.3    -5.9              841.06    -3.1    1.52
    841.22    5.3    -5.9              841.37    2.3    1.43
    841.53    5.3    -5.9              841.69    2.3    1.37
    841.84    5.3    -5.9              842    -4.7    1.21
    842.16    5.3    -5.9              842.3    0    1.45
    842.45    5.3    -5.9              842.6    0    2.07
    842.74    5.3    -5.9              842.88    0    2.3
    843.03    5.3    -5.9              843.19    0    2.6
    843.34    5.3    -5.9              843.5    0    2.68
    843.65    5.3    -5.9              843.81    0    2.23
    843.97    5.3    -5.9              844.13    0    1.39
    844.27    5.3    -5.9              844.41    0    1.17
    844.56    5.3    -5.9              844.71    0    1.11
    844.85    5.3    -5.9              845    0    1.11
    845.17    5.3    -5.9              845.33    0    1.13
    845.47    5.3    -5.9              845.62    -1.2    1.13
    845.77    5.3    -5.9              845.91    -2.3    1.13
    846.06    5.3    -5.9              846.21    -2.7    1.15
    846.36    5.3    -5.9              846.51    -3.5    1.15
    846.67    5.3    -5.9              846.83    -3.9    1.15
    846.99    5.3    -5.9              847.14    -3.9    1.19
    847.29    5.3    -5.9              847.44    -3.9    1.21
    847.6    5.3    -5.9              847.74    -3.5    1.25
    847.88    5.3    -5.9              848.01    -3.1    1.25
    848.16    5.3    -5.9              848.32    -2.7    1.25
    848.48    5.3    -5.9              848.64    -2.3    1.25
    848.79    5.3    -5.9              848.95    -2    1.25
    849.11    5.3    -5.9              849.26    -2    1.25
    849.43    5.3    -5.9              849.58    -1.6    1.25
    849.73    5.3    -5.9              849.89    -1.2    1.25
    850.04    5.3    -5.9              850.2    -1.2    1.25
    850.35    5.3    -5.9              850.5    -0.8    1.23
    850.65    5.3    -5.9              850.81    -0.8    1.23
    850.97    5.3    -5.9              851.13    -0.8    1.23
    851.27    5.3    -5.9              851.43    -0.8    1.23
    851.58    5.3    -5.9              851.73    -0.4    1.23
    851.89    5.3    -5.9              852.05    -0.4    1.23
    852.21    5.3    -5.9              852.36    -0.4    1.23
