B6 Passat Steering Column Lock ELV failure
kamold
Australia
C?ID=241363
Hi All,
I have an issue with my friend's 2010 R36 that I'd be interested in any input to try and solve.
At Christmas last year he had his battery replaced. Once the new battery was in he got an immo fault and the car would not start. He had it towed to a workshop but they were too busy to look at it leading up to shutdown over the holidays.
After some attempts to resolve it I determined that the ELV had somehow become corrupted. Managed to order a new ELV from VW spares just before they shut also.
Replaced the ELV and much to everyone's relief the car was able to start again and he didn't have to leave it outside the workshop.
Fast forward to yesterday. I had rebuilt a set of headlights with new projectors to replace his that had burnt out so were very dull. Took the bumper off, replaced the headlights. Bumper back on, quick adjustment, then we drove out to a dark area to test them and do a better alignment. Car would have been turned off and started again maybe half a dozen times.
Very happy with the result he drove home.
The next morning he went to start the car. Instrument cluster comes on, but no crank at all. Disconnect battery, try again - nothing.
I checked for faults - no immo or other faults logged.
Checked measuring values and can see in immo that engine start is not permitted.
Pulled out the 3AA CCM, read eeprom and compare immo data against backups of this original 3C0 CCM and ELV, as well as the newer 3AA CCM and the new replacement ELV from the beginning of the year. Data all looks good.
Swapped out the CCM for a spare just in case after copying in the data - still no start.
Unplugged ELV and plugged in the original factory part which I still have, reverted CCM data to the original ELV MAC.
Now the car is back to how it was at Christmas - key doesn't turn on the cluster any more. Diagnostics on immo is flaky - can't clear faults, PIN is not accepted. So it appears that my original diagnosis of a corrupt ELV is still valid.
Plugged new ELV back in and CCM eeprom data to match.
At this point I think I may possibly have made a mistake - I thought I could possibly 'resynch' the ELV, as it was already matched to this car. I used the procedure (enter immo, adaptation channel 0, save, then enter PIN in SA, change value 32000 to PIN) but WAIT status changes straight away to NOT OK. Many variations of trying to get this sequence to complete and it's always the same. I tried the procedure through ODIS and it fails reporting that ELV is not a new part. Which it isn't (although it's from this car having been working successfully for months).
Have checked all fuses etc the problem appears on the surface to be another ELV failure. Seems WAY too coincidental that I did some (seemingly) unrelated work on it, car was then fine but following morning was a large paperweight in his driveway)
So if you're still with me after this lengthy story there are a few questions...
1. can a 'used' ELV be relearnt IF IT IS FROM THE SAME CAR?
2. has anyone seen a rev J ELV just stop working out of the blue like this?
3. Any other suggestions before I buy another ELV and hope that fixes it?
4. Any theories as to why this might have occurred? (there is much FOD in this car but as mentioned it was working well for quite some time now)
Below is an autoscan which is not current. Apologies I was working late last night in much frustration and didn't save a scan. Current fault in immo is ELV no basic settings.
Saturday,03,February,2018,12:52:14:58930
VCDS Version: 18.1.0.2 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20180122 DS285.1
VIN: WVWZZZ3CZAE192421   License Plate:
Mileage: 83960km-52170mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 06 08 09 10 15 16 17 19 22 25 36 42 44 46 47 52 53
          55 56 62 65 69 6C 72 77
VIN: WVWZZZ3CZAE192421   Mileage: 83960km-52170miles
19-CAN Gateway -- OK 0000
Address 01: Engine (BWS)       Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 906 032 FS    HW: 03H 906 032 AB
   Component: CC3.6-FSI-EU5   G   4855
   Revision: 5GH09---    Serial number: VWZCZ000000000
   Coding: 0000175
   Shop #: WSC 05311 000 00000
   VCID: 78A9162BCEDD28E7505-802C
   Part No SW: 02E 300 012 L    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2103
   Revision:    51112    Serial number: 00001007251034
   VCID: 196F33AF1597D1EF8FB-804C
   Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
   Component: J104    C4 440 V2   0015
   Revision: --026---    Serial number: 00000706041330
   Coding: 0001443
   VCID: 629D54437841D2371E1-8036
   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000001002
   Shop #: WSC 05311 115 00000
   VCID: 7EA50033E07916D71A9-802A
   Revision: 00H54000    Serial number: 00000004063456
   Coding: E68E8F0700041A00470A00000F000000000A59435C000120000000000000
   Shop #: WSC 05124 000 00000
   VCID: 3333E107973B0BBFA57-8066
   Subsystem 1 - Part No: 3C2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 280710 022  0612
   Coding: 00046997
   Shop #: WSC 05124
   Component: RLS     090810 054  0403
   Coding: 00209133
   Shop #: WSC 05124
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 3C8 919 475 A    HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0009
   Revision: --------    Serial number: 08791022429691
   Coding: 300102
   Shop #: WSC 12345 123 61029
   VCID: 323DE403642102B7AE1-8066
   Part No SW: 5N0 959 655 M    HW: 5N0 959 655 M
   Component: J234__003 VW10 HI   1916
   Revision: 21014000    Serial number: 003GGPD5T1XC
   Coding: 0012339
   VCID: 47CBA5D7F3A3971FE9F-8012
   Subsystem 1 - Serial number: 6332MTS634181740
   Subsystem 2 - Serial number: 6342MTS607751890
   Subsystem 3 - Serial number: 6351HTS6R17PA6KJ
   Subsystem 4 - Serial number: 6361HTS61G2SB6KJ
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C9 953 501 BG    HW: 5K0 953 569 T
   Component: LENKS.MODUL   009 0135
   Revision: FF010037    Serial number: 20100805300608
   Coding: 9998270002
   VCID: 6FBB2D77B7136F5F81F-803A
   Part No SW: 3C0 920 872 J    HW: 3C0 920 872 J
   Component: KOMBI         H03 0305
   Coding: 161F00
   Shop #: WSC 05314 115 00000
   VCID: 2C01FA7B46855447E4D-8078
12716288 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Sitz-/Spiegelpos. Beifahrerseite: keine Kommunikation]
                    Reset counter: 0
                    Mileage: 83962 km
                    Date: 2018.02.03
                    Time: 12:15:16
   Part No SW: 7N0 907 530 BE    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1674
   Revision:   H58       Serial number: 0906201500F124
   Coding: 352007
   VCID: 74B1221BDEB54C877CD-8020
   Part No SW: 0BS 907 554 B    HW: 0BS 907 554 B
   Component: Haldex 4Motion      4015
   Coding: 0000005
   VCID: 45D7AFDFC9AF850F1B3-8010
   Part No SW: 3C0 959 433 AM    HW: 3C0 959 433 AM
   Component:    IMMO         052 0383
   Revision: 00052000    Serial number: VWZCZ000000000
   VCID: 75B71F1FD9CF558F4B3-8020
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
   Component: Sitzverstellung     1101
   Revision: 00005000    Serial number: 00000000000000
   VCID: 2F3BED777B132F5FC1F-807A
   Part No SW: 3C0 959 701 A    HW: 3C0 959 793 A
   Component: TUER-SG FT    002 0306
   Revision: 12101005    Serial number: 0000973158
   Coding: 0013B7
   Shop #: WSC 05311 115 08193
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 2615085358696E17329-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0401
   Serial number: 00000001612195
   Coding: 000290
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 143    3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 313FEB0F6D2739AFD7B-8064
   Component:    KSG PQ46 RDK 052 0412
   Coding: 0091020051030E76300494157008DFCE105801
   Shop #: WSC 20095 959 99354
   Subsystem 1 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HORN H11 9004
   Component: Neigungssensor  004 0611
   Part No SW: 5K0 035 456     HW: 5K0 035 456
   Component: KonzernAmp 8K H06 0340
   Revision: --------    Serial number: BP218109096839
   ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
   ROD: EV_AudioVerst8KanalBNO2.rod
   VCID: 678B45579FE3B71FC9F-8032
   Part No SW: 3C0 959 702 A    HW: 3C0 959 792 A
   Component: TUER-SG BT    002 0306
   Revision: 14101005    Serial number: 0000947613
   Coding: 0013B6
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 270B05575F63771F09F-8072
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0401
   Serial number: 00000001611133
   Coding: 000290
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   011       Serial number: 00000000360268
   Coding: 0000057
   VCID: 2C01FA7B4A055447E4D-8078
   Component: AFS-Steuergeraet    0142
   Coding: 2344385
   VCID: 3431E21B92350C87BCD-8060
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         541 5314
   Revision: --------    Serial number: VWZZZ4H6281562
   Coding: 16000440040011
   VCID: 46D5A8D3F8A98E17129-8012
   Component:    RDK              0453
   Coding: 0161211
   Component: Anhaenger     H07 0100
   Revision: 3A001001    Serial number: 00000132656335
   Coding: 4100000100000000
   Shop #: WSC 05314 000 00000
   VCID: 3039EE0B6A2D30A7D85-8064
   Part No SW: 3C9 907 441     HW: 3C9 907 441
   Component: J772__Rearview      0020
   Revision: 00H08000    Serial number: 525PA8-J070033
   Coding: 0030007
   Shop #: WSC 05311 000 08193
   VCID: 6889466B9E7DB867C05-803C
End----(Elapsed Time: 01:42, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Why on the Earth you would think something is wrong with immobilizer or EVL if the car do not crank. Maybe is simply Starter when out or Ignition switch (yes Part that you put key in ,I have seen this fail.)
In most of the time it will be like that on this car till you start Engine .
kamold
Australia
C?ID=241363
Yes the ignition switch (funky one in the Passat is the 3 stage hole where the fob goes in) can fail. I don't believe this is the case here but it's certainly worth investigating further.
MVB 1-1 (engine start permitted) shows 'No'. So either the ECU, CCM or ELV don't agree to allow engine start. This is with key at ign position.
I checked this against my car, which shows 'yes' when key is at this same second position- terminal 15.
Key status is valid for both keys.
I'm confident I've ruled out the CCM as I've validated the data, and used another CCM. ECU I can't rule out as I haven't got another ECU on hand, but I think this is likely a low probability. I can get hold of another MED9.1 and get the immo data transfered over using tuning tools at a friend's workshop if that something that is required.
Either way I feel like I've now broken the ELV by attempting the learning procedure on a 'used' part. So I think I'll have to get a new one next week at a minimum, unless there is some way of getting this one back to a synchronised state?
Jetta 97
C?ID=81680
This will not stop car form Cranking, Car will still crank , start and turn off after 2-3 seconds if ECU in not Authorized , You said car will NOT CRANK, That means you have other problem besides this .So you started with wrong diagnostic . Maybe now all is mess up since you tried many unnecessary thing.
kamold
Australia
C?ID=241363
Yes so I definitely went down the rabbit hole on that given the experience I had last time with the ELV (it had an internal checksum fault.)
So I went back to my friend's place last night with a new ELV.
Before I started pulling out the steering column I thought I'd take another autoscan and at least save it this time.
The missing basic settings fault on ELV was gone!
Engine start permitted was now 'yes'.
Using the multimeter I tested all the engine bay fuses (my friend had inspected but just visually) and found a faulty 10amp fuse (SB33 I think from memory).
Car started fine :)
Will return the unused ELV as they aren't that cheap...
kamold
Australia
C?ID=241363
Good advice as always. I troubleshoot for a living (not cars) and should take my own advice - step back, start with the basics and only then move forward. haha
Jetta 97
C?ID=81680
Car started fine :)
I guess I was right :D.
I miss JACK as well, He would be all over this thread :cry:
