Automatic highbeam memory
CuturiloD
Serbia
C?ID=361908
I want to enable memorized Automatic highbeam.
Everytime when I start engine automatic highbeam is switched off.
Audi A6 C8
CuturiloD
Serbia
C?ID=361908
My friend have S6 and Auto High Beam always ON.
Here is auto scan a #09 adaptations:
Sunday,11,April,2021,09:35:19:48786
VIN: WAUZZZF21LN028971   License Plate: ZOLI
Mileage: 8179km-5082mi   Repair Order:
Chassis Type: F2-AU58 (4N2)
Scan: 01 02 03 09 13 15 16 17 18 19 1B 32 36 3C 42 44 46 47 52 5F
          61 65 69 6C 6D 74 81 82 A5 A9 AC BB BC C0 C4 CA CB CC CF D6
          D7 DB DC DD DE
VIN: WAUZZZF21LN028971   Mileage: 8179km-5082miles
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
DD-Sunroof 2 -- Status: OK 0000
Address 01: Engine (J623-DEWA)       Labels: None
   Part No SW: 4K8 907 589     HW: 059 907 309 L
   Component: 3.0l V6 TDI   H26 0005
   Revision: CAH26---
   Coding: 122A403A057E050335286400000400000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114K8907589 001006
   ROD: EV_ECM30TDI0114K8907589.rod
   VCID: 7DA7FB09FD7A87C3E45-8028
   Electrical compressor:
   Subsystem 1 - Part No SW: 059 145 605 C    HW: 059 145 605 C
   Component: J1123 - EAV  H04 0007
   Serial number: VS5-2-ESC402-0006308
Address 02: Auto Trans (J217)       Labels:* Redir Fail!
   Part No SW: 4K0 927 158 C    HW: 0D5 927 156 P
   Component: 0D5  30RTDRdW H05 1001
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002015
   ROD: EV_TCMALX52011_VW53.rod
   VCID: 323D183574A488BB497-8066
   ATF pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
   Component: V552 ATFP  H02 0810
   Serial number: 1908150116
   Part No SW: 4N0 907 379 AL    HW: 4N0 907 379 P
   Component: ESP9 Premium  H06 0856
   Coding: 2CAA369731A40B9E51A74C98587E91EAF5B9C9346C8CD08A321A8957AF9D93
   ROD: EV_ESP9BOSCHCMP_004_AU65.rod
   VCID: 025D88F58484F83B997-8056
   Part No SW: 4N0 907 063 FG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0690
   Coding: 07000143C13900DD070C57889CBB9C68131B3710000E009701010A00BB3216810A450A3A9257050800000100004108190D02000144010100000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016.rod
   VCID: 78A9EA1DD258A2EBB73-802C
   Subsystem 1 - Part No SW: 4K1 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0740
   Serial number: 00000001907180404204
   Coding: 7DC727
   Serial number: 23617463X81A955555A0
   Coding: 0200FF
   Subsystem 3 - Part No SW: 4K1 941 501 A    HW: 4K1 941 501 A
   Component: E1 - LTM  H09 0086
   Serial number: 14S26.09.1900690297
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z018V02
   Coding: 210000
   Subsystem 5 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Serial number: GX1CE110071923811152
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 BE    HW: 4K0 947 135 BE
   Component: Dachmodul  H42 0415
   Serial number: C00358645
   Coding: 0D0101
   Front windshield washer pump:
   Subsystem 7 - Part No SW: 4N0 907 605 C    HW: 4N0 907 605 A
   Component: J1100/SWP  H21 0015
   Serial number: 00000000001924701018
   Coding: 040000
   Part No SW: 4K0 907 561 G    HW: 760 907 561 A
   Component: LRR4R         H04 0332
   Coding: 5265FF5A78082C00010360E00000003E4A1246484401009E01
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_AU58.rod
   Part No SW: 4N0 959 655 R    HW: 4N0 959 655 R
   Component: AirbagVW31    H20 2720
   Serial number: 003Z0M00TNJ2
   Coding: AAFCF0C00CC00000985400FFF00D41AC00C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x.rod
   VCID: 4BC365D1F34EF9732A1-801E
   Left seat belt tensioner:
   Serial number: 00AI2019237008100000
   Coding: 04F001
   Right seat belt tensioner:
   Serial number: 00AI2019253713400000
   Coding: 04F001
   Subsystem 3 - Part No SW: -----------    HW: 480 001 609 19
   Serial number: 35700000000C609C904O
   Subsystem 4 - Part No SW: -----------    HW: 480 001 609 19
   Serial number: 35800000000C8C75904U
   Subsystem 5 - Part No SW: -----------    HW: 480 032 309 19
   Serial number: 351001C24455B140891X
   Subsystem 6 - Part No SW: -----------    HW: 480 032 309 19
   Serial number: 352001C24455F6B0AC8J
   Subsystem 7 - Part No SW: -----------    HW: 480 032 309 19
   Serial number: 355001C24938B4C04DEO
   Subsystem 8 - Part No SW: -----------    HW: 480 032 309 19
   Serial number: 356001C2445530F13E52
   Subsystem 9 - Part No SW: -----------    HW: 480 031 809 19
   Component: PedP_Sensor_C  002 0149
   Serial number: 230001C2463A29901C8+
   Subsystem 10 - Part No SW: -----------    HW: 480 001 809 19
   Serial number: I0M0000000093C91A0CA
   Subsystem 11 - Part No SW: -----------    HW: 480 001 809 19
   Serial number: I0N00000000B3C91A0CD
   Belt tensioner second row left:
   Subsystem 12 - Part No SW: 4N0 980 965 A    HW: 4N0 980 965 A
   Component: BeltPretRevRL  H10 0115
   Serial number: 00AI2019238045700000
   Coding: 04F001
   Belt tensioner second row right:
   Subsystem 13 - Part No SW: 4N0 980 966 A    HW: 4N0 980 966 A
   Component: BeltPretRevRR  H10 0115
   Serial number: 00AI2019248327000000
   Coding: 04F001
   Part No SW: 4N0 907 129 AJ    HW: 4N0 907 129 AJ
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 79AFEF19E952BBE3C8D-802C
   Part No SW: 4K0 920 790 B    HW: 4K0 920 790 B
   Component: FBenRDWACC--- H12 0210
   Coding: 858D40EE7CA8000800B7E5609180680008002000
   Shop #: WSC 12345 123 61029
   ROD: EV_DashBoardAU65X_001_AU58.rod
   VCID: 2C01064D5680DE4B03B-8078
Address 18: Aux. Heat (J364)       Labels:* None
   Part No SW: 4M0 265 105 E    HW: 4M0 265 105 E
   Component: HSG           H12 0110
   Coding: 050B01
   ASAM Dataset: EV_AuxilParkHeateEBEAU736 001019
   ROD: EV_AuxilParkHeateEBEAU736_AU58.rod
   VCID: 290FFF595972CB63F8D-807C
   Part No SW: 4N2 907 468 BB    HW: 4N2 907 468 AB
   Component: Gateway       H16 0052
   Revision: BD000001    Serial number: 018BD502919919
   Coding: 02010005008406408C960000005B0132FC99004F98000000097D07CF10000000
   ASAM Dataset: EV_CGateCONTIAU491 004190
   ROD: EV_CGateCONTIAU491_004_VW53.rod
   VCID: 7AADF015EC54B0FBC17-802E
   Subsystem 1 - Part No SW: 4K0 951 523 H    HW: 4K0 951 523 H
   Component: E221__MFL  H06 0003
   Subsystem 2 - Part No SW: 4K0 915 181     HW: 4K0 915 181
   Serial number: 74186313001909160C6E
   Part No SW: 4N0 907 144 D    HW: 8W0 907 144 C
   Component: SCU_MLBevo    H03 0803
   Serial number: 30303030303030
   ASAM Dataset: EV_SCUZFLSAU65X 003019
   ROD: EV_SCUZFLSAU65X.rod
   VCID: 2F3B11416796A553269-807A
Address 32: Differential Locks (J187)       Labels: None
   Part No SW: 8W0 907 163     HW: 8W0 907 163
   Component: QSP QCU Gen2  H08 0060
   Revision: 5WK12700    Serial number: 605937519202707
   Coding: 0001
   ASAM Dataset: EV_TVDCQSP22 001008
   ROD: EV_TVDCQSP22.rod
   Serial number: 00000388764335
   Coding: 00581A400000B4010003010101010000000000000000000000000000004000
   Part No SW: 4N0 907 566 H    HW: 4N0 907 566 A
   Component: MRR_HR H16 0267
   Coding: 1FFB00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651.rod
   VCID: 3B233511A3EE49F39A1-806E
   Part No SW: 4M1 959 793 D    HW: 4M1 959 793 D
   Component: TSG FS002 0189
   Serial number: YE007SG611548
   Coding: 001DDA0152000480A009B032
   ROD: EV_DCU2DriveSideMAXHCONT_VW38.rod
   VCID: 40D942FDCA082A2BCF3-8014
   Coding: E1042101010000
   ROD: EV_EPSVWBSAU426_010.rod
   Part No SW: 4N0 907 064 DP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H15 0183
   Coding: 013400034FB103606309A0046C04C80203004004804F06502F0400000504823B001F0100011F11
   ASAM Dataset: EV_BCM2CONTIAU651 010009
   ROD: EV_BCM2CONTIAU651_010.rod
   VCID: 005982FD8A88EA2B8F3-8054
   ID - sensor:
   Serial number: 000000000ZY1923512VP
   Serial number: 00000000000047714976
   Heated Windshield Control Module:
   Subsystem 4 - Part No SW: 4N0 907 133 A    HW: 4N0 907 133 A
   Component: J505-FSH  H20 0600
   Serial number: 19182003564021120081
   left tail lamp 1:
   Subsystem 5 - Part No SW: 4K0 945 217     HW: 4K0 945 217
   Component: SHL_li1  004 0002
   Serial number: 00000000000002254435
   Subsystem 6 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 14009341
   Rear spoiler control module:
   Antenna for short-range communication:
   Subsystem 8 - Part No SW: 4N1 927 753     HW: 4N1 927 753
   Component: NFCTGS  H13 0050
   Serial number:            396546320
   Antenna 2 for short-range communication:
   Subsystem 9 - Part No SW: 4N0 959 428 A    HW: 4N0 959 428 A
   Component: NFCMIKO  H41 0034
   Serial number: 44190001002570056320
   left tail lamp 2:
   Subsystem 10 - Part No SW: 4K5 945 093 C    HW: 4K5 945 093 C
   Component: SHL_li2  004 0002
   Serial number: 00000000000002274589
   Right rear tail lamp 1:
   Subsystem 11 - Part No SW: 4K0 945 218     HW: 4K0 945 218
   Component: SHL_re1  004 0002
   Serial number: 00000000000002254908
   Right rear tail lamp 2:
   Subsystem 12 - Part No SW: 4K5 945 094 C    HW: 4K5 945 094 C
   Component: SHL_re2  004 0002
   Serial number: 00000000000002199812
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAK7D02GMNG
   Coding: 0185020000AAAA2FAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001006
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 2411EE6D3E50160BCBB-8070
   Part No SW: 4M1 959 792 D    HW: 4M1 959 792 D
   Component: TSG BFS002 0189
   Serial number: YE007SH812258
   Coding: 001DDA015E000480A009B030
   ROD: EV_DCU2PasseSideMAXHCONT_VW38.rod
   VCID: 3FDB4101B7F655D3B69-806A
   Part No SW: 4K0 035 063 C    HW: 4K0 035 063 A
   Component: MU-H-LND-EU   054 2647
   Coding: 0185520100000000C3111102C00800302F0009E403F008008E
   VCID: 2313ED713B5E1133B21-8076
   Subsystem 1 - Part No: V03 959 804 LN
   Component: MIB2P_EU_Q219  0371
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4K0 919 605 C    HW: 4K0 919 605 A
   Component: DU AU58x High  H42 0147
   Serial number: INX00103071900060039
   Compact disc data bank:
   Component: Gracenote2  1010
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Serial number: 00004419000100147041
   Multimedia System 5:
   Subsystem 5 - Part No SW: 4K0 919 603 B    HW: 4K0 919 603
   Component: DU AU58x Bot  H41 0147
   Serial number: INX00110071900080933
   Media Player 1:
   Subsystem 6 - Part No SW: 4N0 035 123     HW: 4N0 035 123
   Component: DISC PLAYER  H06 0006
   Serial number: AUZ8ZCKKJ03G979
   Media socket:
   Subsystem 7 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051900528451014
Address 61: Battery Regul. (J1120)       Labels: None
   Part No SW: 4N0 915 105 D    HW: 4N0 915 105 D
   Component: BMS_48V_LiIon H09 0206
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   VCID: 2B030551538ED9730A1-807E
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
   Component: RDKHUFAU736   H05 0010
   Serial number: 30000000046495
   ROD: EV_RDKHUFAU736_AU58.rod
   Part No SW: 4M0 907 383 F    HW: 4M0 907 383 B
   Revision: 9A001003    Serial number: 0528079785
   Coding: 0110000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 3537232985CA9F836C5-8060
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 760 980 568     HW: 760 980 568
   Component: RVC Compact+  H09 0250
   Coding: 0285020103002025C2004C
   ASAM Dataset: EV_CamSysRVRVCARPANAMLBEv 001001
   ROD: EV_CamSysRVRVCARPANAMLBEv.rod
   VCID: 619FA77961C24323E0D-8034
   Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C737-6252-4
   Coding: 12F0
   VCID: 34311E2D8EB0868B5BB-8060
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4K0 907 777 CA    HW: 4K0 907 777 C
   Component: Fahrwerk-SG   H52 2135
   Serial number: 2309190227
   Coding: F46C4050DA42
   ASAM Dataset: EV_ChassContrContiAU651 002016
   ROD: EV_ChassContrContiAU651_002.rod
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130731448
   Coding: 303030
   Part No SW: 4K1 713 041 G    HW: 4K1 713 041 H
   Component: GSM-LL H14 0051
   Serial number: 19.257 40189
   ASAM Dataset: EV_GSMKAMAU581 001005
   ROD: EV_GSMKAMAU581.rod
   VCID: 270BF9614F66FD13EE9-8072
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4K1 919 617 B    HW: 4K1 919 617 B
   Component: HeadupDisplay H11 4910
   Coding: 4700E0
   ASAM Dataset: EV_HeadUpDisplAU65X 001011
   ROD: EV_HeadUpDisplAU65X_AU58.rod
   VCID: 33331D318BBE81B3421-8066
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AL    HW: 4N0 907 107 G
   Component: zFAS Var B    H09 0293
   Coding: 040184000000000000F8060000D0D73C199F5200000000000000000000000000001900000000000000000000000000000000000000000000F980400000000000000078D00080009000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001.rod
   VCID: 094F9FD9B9B2AB63D8D-805C
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 4K0 907 159 C    HW: 4K0 907 159
   Component: SAS-GEN 2.5   H08 0001
   Serial number: 190830200255
   VCID: 313F173971A2B3A330D-8064
Address AC: Reductant Control (J880)       Labels: None
   Part No SW: 80A 907 355 F    HW: 80A 907 355 D
   Component: SCR-Stg-G4H08 0004
   ASAM Dataset: EV_RDCMHelbaAU426 003011
   ROD: EV_RDCMHelbaAU426_003.rod
   Part No SW: 4M1 959 795 D    HW: 4M1 959 795 D
   Component: TSG HFS004 0189
   Serial number: YE007SHN1285A
   Coding: 000DD80100000480A008B020
   ROD: EV_DCU2RearDriveMAXHKLO_VW53.rod
   VCID: 42DD48F5C404383BD97-8016
   Component: TSG HBFS004 0189
   Serial number: YE007SHN09622
   ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C0: Act. for Ext. Noise (J943)       Labels: None
   Part No SW: 4K0 907 160 A    HW: 4K0 907 160
   Component: SAS-GEN2.5AGA H11 0001
   Serial number: 190822201165
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
Address C4: DC/DC Converter (A7)       Labels: 4M0-959-663.clb
   Part No SW: 4M0 959 663 C    HW: 4M0 959 663 C
   Component: PCU10         022 0324
   ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
   ROD: EV_DCDC48V210ABOSCHAU736.rod
   VCID: 3A2D3015ACD470FB817-806E
   Coding: 668040058203
   ROD: EV_SunRoofCONTIAU736_009_AU58.rod
   VCID: 75B7E329C54ADF83AC5-8020
Address CB: Rear Axle Steering (J1019)       Labels:* None
   Part No SW: 4N0 909 145 K    HW: 4N0 909 145 C
   Component: HAL_MLBevoH03 0398
   Revision: --------    Serial number: CCC_098_B_9056_
   Coding: 42246600
   ASAM Dataset: EV_RearAxleSteerZFAU736 010018
   ROD: EV_RearAxleSteerZFAU736_010.rod
   VCID: 392F2F19A9D27BE388D-806C
Address CC: Starter-Generator (----)       Labels:* None
   Part No SW: 4N0 903 028 M    HW: 4N0 903 028 M
   Component: BSG-HP1-65    H17 0523
   Serial number: 10091900020365
   Coding: 28000000000000
   ASAM Dataset: EV_Start48VAU651 001006
   ROD: EV_Start48VAU651_001.rod
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H16 0267
   Coding: 1FFB00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651.rod
   Part No SW: 4K0 941 592 BC    HW: 4K0 941 592 B
   Component: LMS_MLBevo    H11 0031
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 72BDD835B424C8BB897-8026
   Dynamic left front turn signal:
   Subsystem 1 - Part No SW: 4K0 941 035     HW: 4K0 941 035
   Component: M134DynTurnFL  003 0004
   Serial number: 12091900031488001011
   Dynamic right front turn signal:
   Subsystem 1 - Part No SW: 4K0 941 036     HW: 4K0 941 036
   Component: M135DynTurnFR  003 0004
   Serial number: 29081900032305001011
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 H    HW: 4N0 907 669 A
   Component: MRR_VR H16 0267
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
   ROD: EV_FrontCorneRadarS1AU651.rod
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H16 0267
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
   ROD: EV_FrontCorneRadarS2AU651.rod
Address DD: Sunroof 2 (J392)       Labels:* None
   Part No SW: 4K0 907 594 AD    HW: 4K0 907 594
   Component: SAD_STG_2     006 0002
   Coding: 629000058204
   ASAM Dataset: EV_SunRoof2CONTIPO623 009011
   ROD: EV_SunRoof2CONTIPO623_009_AU58.rod
   VCID: 76B5E425D84CD49BA5F-8022
Address DE: Charger 1 for mobile dev (J1146)       Labels:* None
   Part No SW: 4K0 035 773 B    HW: 4K0 035 773 B
   Component: WLC Front NFC H14 0061
   Coding: 808000
   VCID: 2A0D00555C74C07BF17-807E
IDE00001-MAS10842-Production mode-Deactivate exterior lighting,not active ,3
IDE00001-MAS10843-Production mode-Deactivate interior lighting,not active ,3
IDE00001-MAS10844-Production mode-Deactivate rear windshield wiper,not active ,3
IDE00001-MAS10847-Production mode-Deactivate windshield wipers,not active ,3
IDE00001-MAS10848-Production mode-Deactivate left-/right hand driving switch-over,not active ,3
IDE00001-MAS10849-Production mode-Switch parking assist to mute,not active ,3
IDE00001-MAS10850-Production mode-Deactivate massage function,not active ,3
IDE00001-MAS10871-Production mode-Deactivate AC compressor,not active ,3
IDE00001-MAS13264-Production mode-Activate headlamp cleaning system directly,not active ,3
IDE00001-MAS15400-Production mode-Continuation of basic settings without tester,not active ,3
IDE00001-MAS15622-Production mode-Cleaning of rearview camera: changed actuation time,not active ,3
IDE00001-MAS16746-Production mode-Deactivate air recirculation door,not active ,3
IDE01169-Audio lowering request,On ,1
IDE01476-Store air recirculation setting with terminal 15 OFF,According to country version ,1
IDE01482-After-run of parking heater or parking ventilation,activated ,1
IDE01485-Shut-off temperature for solar sunroof,-35 °C,1
IDE01493-Sensitivity of air quality sensor,Medium ,1
IDE01495-After-run time of auxiliary heater with air conditioner off,120 s,1
IDE01500-Reduction of window condensation with high humidity,Matching coding ,1
IDE01501-Air leak to footwell,automatic ,1
IDE01503-Running time of basic setting for compressor break-in,60 s,1
IDE01506-Tolerance range for flap end stops,0 ,1
IDE01536-Post heating of auxiliary heating,10 min,1
IDE01550-Service position,153.00 ,2
IDE01996-SFT00009-Installation list: specified installations-Electronic central electric,installed ,1
IDE01996-SFT00041-Installation list: specified installations-Left light control,not installed ,1
IDE01996-SFT00057-Installation list: specified installations-Right light control,not installed ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,installed ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,installed ,1
IDE01996-SFT00216-Installation list: specified installations-Projection module in left matrix headlamp,not installed ,1
IDE01996-SFT00217-Installation list: specified installations-Projection module in right matrix headlamp,not installed ,1
IDE01996-SFT33232-Installation list: specified installations-Central control for digital matrix light,not installed ,1
IDE03641-Presentation run dynamic AFS light,not active ,1
IDE03782-Switch-off speed for parking assist,10 ,1
IDE05274-Acoustic warning for rear lid assistant,not active ,1
IDE05318-Retrofitted components installed,Default ,1
IDE05569-Compressor control in efficiency mode,Comfort mode ,1
IDE06547-Air distribution for production routines,Air distribution upper body vents and footwell ,1
IDE06593-Air recirculation for production routines,Recirculating air ,1
IDE06769-Blower regulator for production routines,7 ,1
IDE07356-Position during interval mode,41.00 ,2
IDE08209-Speed of motors,Default ,1
IDE08373-Offset of fresh air blower speed,Default ,1
IDE10118-Fan speed reduction for telephony,Not available ,1
IDE10119-Blower reduction during voice control,available. ,1
IDE10296-upper turn position,174.00 ,2
IDE10297-lower turn position,41.00 ,2
IDE10298-Alternating park position 1,30.00 ,2
IDE10299-Alternating park position 2,35.00 ,2
IDE10307-Presentation mode of multicolor ambient and contour lighting,not active ,1
IDE10321-MAS01364-Seat heater: micro adjust.-Stage 1,0 °C,3
IDE10321-MAS01365-Seat heater: micro adjust.-Stage 2,0 °C,3
IDE10321-MAS01366-Seat heater: micro adjust.-Stage 3,0 °C,3
IDE10322-MAS01364-Seat ventilation: micro adjust.-Stage 1,0 %,3
IDE10322-MAS01365-Seat ventilation: micro adjust.-Stage 2,0 %,3
IDE10322-MAS01366-Seat ventilation: micro adjust.-Stage 3,0 %,3
IDE10331-MAS02201-Roof electronics control module: temperature-related dim.-Temperature,65 °C,2
IDE10331-MAS10404-Roof electronics control module: temperature-related dim.-max. brightness,10 %,2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,not active ,1
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,not active ,1
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,not active ,1
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,not active ,1
IDE10661-Deactivation of start-stop function (climate control),not active ,1
IDE10729-Runtime measurement,on task level ,1
IDE10914-Seat occupancy-depending A/C,Matching coding ,1
IDE11217-Show parking space,not activated ,1
IDE11549-Automatic query of the identification data on LIN-Bus,activated: no backup ,1
IDE11613-MAS01364-Rear seat ventilation: micro adjustment-Stage 1,0 %,3
IDE11613-MAS01365-Rear seat ventilation: micro adjustment-Stage 2,0 %,3
IDE11613-MAS01366-Rear seat ventilation: micro adjustment-Stage 3,0 %,3
IDE11794-MAS13241-Fragrance diffuser system control module-Aroma 1,6 ,2
IDE11794-MAS13242-Fragrance diffuser system control module-Aroma 2,7 ,2
IDE11954-Automatic activation of parking distance control,active ,1
IDE12224-MAS14154-Rear parking aid warning buzzer with open convertible top-Volume at Level 1,4 ,2
IDE12224-MAS14155-Rear parking aid warning buzzer with open convertible top-Increment between the volume levels,20 ,2
IDE12225-MAS14154-Front parking aid warning buzzer with open convertible top-Volume at Level 1,4 ,2
IDE12225-MAS14155-Front parking aid warning buzzer with open convertible top-Increment between the volume levels,20 ,2
IDE12291-A/C control and display heads: dimming,Dimming: no dimming when approaching ,1
IDE13059-Cleaning of rearview camera: actuation time in production mode,2500 ms,2
IDE13064-Wiper motor control module: dataset,41 01 06 04 00 D2 00 D2 00 64 00 96 05 32 00 0A 00 E6 05 32 00 55 00 55 28 3C 14 04 78 1E 23 00 28 2B 2E 32 37 3A 3C 00 D2 01 FE 05 6E 00 0F 50 00 14 96 00 1E C8 00 2D FA 00 00 00 14 B8 AE 42 4C 78 96 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C2 8C DD 87 ,90
IDE13354-Wiper motor control module: dataset 2,41 01 04 04 B4 64 0A 0A 05 05 0A 04 0A 00 03 0A 32 32 32 14 14 14 14 14 14 14 14 14 14 1E 5A 05 02 03 01 05 05 01 02 01 03 04 03 04 04 0C 6E 04 04 0C 01 04 04 00 00 00 00 00 00 00 00 00 00 00 00 00 9E 3A FA 7F ,70
IDE13355-Wiper motor control module: dataset 3,30 00 01 6C 00 00 0F A0 FF FF F6 3C FF FF E0 C0 FF FF B9 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 34 00 44 00 ,50
IDE13356-Wiper motor control module: dataset 4,5A 10 00 00 00 00 00 00 00 00 00 00 00 00 00 34 4B 31 39 35 35 31 31 39 20 20 34 4B 31 39 35 35 31 31 39 20 20 30 36 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8C CB 0B 69 ,70
MAS01426-Rear parking aid buzzer: volume,Stage 4 ,1
MAS01427-Speaker frequency for rear park assist,Stage 6 ,1
MAS01428-Front parking aid buzzer: volume,Stage 4 ,1
MAS01429-Speaker frequency for front park assist,Stage 4 ,1
MAS12843-Maneuvering brake function,activated ,1
MAS15621-Restart information,activated ,1
ENG133836-Fehlermaske 2,00 00 00 00 ,4
ENG117283-Frontwaschfunktion,20 ,2
ENG133832-sLWR_counter_left,0 ,4
ENG133833-sLWR_counter_right,0 ,4
My car don't have always ON Auto High Beam assist, and here is a my auto scan and adaptations:
Thursday,08,April,2021,18:52:08:48786
VIN: WAUZZZF27KN005127   License Plate:
Mileage: 11340km-7046mi   Repair Order:
Scan: 01 02 03 06 09 13 15 16 17 19 1B 32 36 3C 42 44 46 47 52 5F
          61 74 81 82 84 A5 AC BB BC C4 CB CC CD CF D6 D7 DB DC DE
VIN: WAUZZZF27KN005127   Mileage: 11340km-7046miles
CD-Laser Scanner -- Status: OK 0000
Address 01: Engine (J623-DDVB)       Labels: None
   Part No SW: 4K0 907 401 K    HW: 059 907 309 L
   Component: 3.0l V6 TDI   H25 0003
   Revision: CAH25---
   Coding: 0A2A4012056E050334286000000400000000000000000000
   Shop #: WSC 48429 004 1048576
   ASAM Dataset: EV_ECM30TDI0114K0907401K 001003
   ROD: EV_ECM30TDI0114K0907401J.rod
   Part No SW: 4K0 927 158 AP    HW: 0D5 927 156 P
   Component: 0D5  30TDIRdW H05 0001
   Revision: --H05---
   Coding: 100000
   Shop #: WSC 00022 000 00000
   ATF pump:
   Component: V552 ATFP  H01 0705
   Serial number: 1803062136
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4N0 907 379 AC    HW: 4N0 907 379 P
   Component: ESP9 Premium  H06 0850
   Coding: 1CAA329731A20B9B119F4D93588451E6F5B9C9384C8CD088B21A8A67AF9D93
   Shop #: WSC 00022 123 12345
490240 - Databus
          U1121 00 [047] - Missing Message
          [ComScl:_PDU_PLA2_01_-_timeout_error]
                    Mileage: 11340 km
                    Date: 2021.04.08
                    Time: 18:45:52
                    93 00 80 00 CA 03 00 00 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 28
491008 - Databus
          [ComScl:_PDU_PLA2_02_-_timeout_error]
                    Mileage: 11340 km
                    Date: 2021.04.08
                    Time: 18:45:52
   Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0042
   Serial number: 00000305447935
   Coding: 0018B2400001BEA14843010101010000810000070700878700000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
   VCID: 3D273B09BDFA47C3A45-8068
   Valve block 1 in front seat passenger side:
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ80010801184025833D
   Coding: BF2F00
   Valve block 2 in front seat passenger side:
   Subsystem 2 - Part No SW: 4N0 907 182 D    HW: 4N0 907 182 D
   Component: N478 VB2 BFSv  H04 0010
   Serial number: SJ80011412171147002F
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V1.clb
   Part No SW: 4N0 907 063 BE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0633
   Coding: 07000143C13900CD074E57091CEB8C68131B331004060097810108003B3316810A450A0280120000000003030041001A0C00000144010100000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 013006
   ROD: EV_BCM1BOSCHAU651_013.rod
   Component: J400FRWISCH  063 0730
   Serial number: 00000001801110401142
   Coding: 7DC727
   Serial number: 21187930X81A955555A0
   Coding: 0200FF
   Serial number: 12S10.02.1800300201
   Serial number: GX1CE108011823811902
   Subsystem 5 - Part No SW: 4K0 947 135 B    HW: 4K0 947 135 B
   Component: Dachmodul B9  H42 0412
   Serial number: C00029065
   Coding: 0D0104
   Subsystem 6 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V512 LLR1SLvL  H01 0012
   Serial number: L84AH32700533
   Subsystem 7 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V514 LLR1SKvL  H01 0012
   Serial number: L84AH32700482
   Subsystem 8 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V516 LLR1SLvR  H01 0012
   Serial number: L84AH32700548
   Subsystem 9 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V518 LLR1SKvR  H01 0012
   Serial number: L84AH32700542
   Subsystem 10 - Part No SW: 4N0 907 605 A    HW: 4N0 907 605 A
   Component: J1100/SWP  H09 0004
   Serial number: 00000000001803800219
   Coding: 040000
   Part No SW: 4K0 907 561 E    HW: 760 907 561 A
   Coding: 5265FF5478082C00010360E0000000BE4A1246484481009E00
   VCID: 3039123D7AA8BAAB3F3-8064
   Part No SW: 4N0 959 655 R    HW: 4N0 959 655 H
   Component: AirbagVW31    H35 2710
   Serial number: 003U1M007F3
   Coding: AACCF0C00CC00000985400FFF01D41AC00C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001028
   Component: BeltPretRevFL  H09 0115
   Serial number: 00AI2017347020500000
   Coding: 04F001
   Component: BeltPretRevFR  H09 0115
   Serial number: 00AI2018037005300000
   Coding: 04F001
   Subsystem 3 - Part No SW: -----------    HW: 480 001 710 17
   Serial number: 35700000000061A0A829
   Subsystem 4 - Part No SW: -----------    HW: 480 001 710 17
   Serial number: 3580000000049924F72P
   Subsystem 5 - Part No SW: -----------    HW: 480 032 502 18
   Serial number: 351001C0C6E086202E22
   Subsystem 6 - Part No SW: -----------    HW: 480 032 502 18
   Serial number: 352001C0CE7B5D00199I
   Subsystem 7 - Part No SW: -----------    HW: 480 032 702 18
   Serial number: 355001C0C7B99150C93I
   Subsystem 8 - Part No SW: -----------    HW: 480 032 702 18
   Serial number: 356001C0C7B99220DCEW
   Subsystem 9 - Part No SW: -----------    HW: 480 032 502 18
   Serial number: 230001C0C6E5CE60EE8.
   Subsystem 10 - Part No SW: -----------    HW: 480 001 602 18
   Serial number: I0M00000000AFB7155AI
   Subsystem 11 - Part No SW: -----------    HW: 480 001 602 18
   Serial number: I0N00000000CEB7155AK
   Part No SW: 4N0 907 129 AF    HW: 4N0 907 129 AF
   Part No SW: 4K0 920 790 C    HW: 4K0 920 790 C
   Component: FBenRDWACC--- H10 0153
   Coding: 858C20E27CA8000801B3E5609080480008002200
   VCID: 2D070B496D9AD743145-8078
   Part No SW: 4N2 907 468 AB    HW: 4N2 907 468 B
   Component: Gateway       H12 0037
   Revision: 7N010003    Serial number: 0387N773018303
   Coding: 02010005008406408C960000005B0132DC9A004F98000000097D078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 003150
   ROD: EV_CGateCONTIAU491_003_AU58.rod
   Subsystem 1 - Part No SW: 4N0 951 523 B    HW: 4N0 951 523 B
   Serial number: 741863110018012506B2
   Part No SW: 4N0 907 144 C    HW: 8W0 907 144 C
   Component: SCU_MLBevo    H03 0802
   VCID: 2E050C45609CAC5B2DF-807A
   Revision: 5WK12700    Serial number: 605807323200507
   Coding: 0001
   Component: MEM-FS        009 0042
   Serial number: 00000304638947
   Coding: 00189A400001BEA14803010101010000810000070700878700000000004000
   Valve block 1 in front seat driver side:
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ8001080118402581B1
   Coding: BF2F00
   Valve block 2 in front seat driver side:
   Component: N476 VB2 FSv  H04 0010
   Serial number: SJ80011812171147003B
   Part No SW: 4N0 907 566 F    HW: 4N0 907 566 A
   Component: MRR_HR H12 0266
   Coding: 0FFC00
   Component: TSG FS001 0188
   Serial number: YE007RC510792
   Coding: 005DDA0152000482A001B032
   Part No SW: 4N0 909 144 C    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H20 0503
   Coding: A1002301010000
   ASAM Dataset: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009.rod
   Part No SW: 4N0 907 064 AD    HW: 4N0 907 064 D
   Component: BCM2 MLBevo H14 0126
   Coding: 013400004FB000606309A0040C00000203004004804F02502F0400000104823F001F0100011F01
   ASAM Dataset: EV_BCM2CONTIAU651 007005
   ROD: EV_BCM2CONTIAU651_007.rod
   VCID: 71BFD739B122F3A370D-8024
   ID - sensor:
   Serial number: 000000000ZY180291P4Z
   Serial number: 00000000000099748695
   Subsystem 4 - Part No SW: 4N0 907 133     HW: 4N0 907 133
   Component: J505-FSH  H08 0040
   Serial number: 18053001358021120081
   left tail lamp 1:
   Component: SHL_li1  003 0001
   Serial number: 00000000000000028986
   Subsystem 6 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
   Component: GEB.F.Heckoef  H17 0904
   Serial number: 58405615
   left tail lamp 2:
   Subsystem 8 - Part No SW: 4K5 945 093 C    HW: 4K5 945 093 C
   Component: SHL_li2  003 0001
   Serial number: 00000000000000030627
   Subsystem 9 - Part No SW: 4K0 945 218     HW: 4K0 945 218
   Component: SHL_re1  003 0001
   Serial number: 00000000000000029048
   Subsystem 10 - Part No SW: 4K5 945 094 C    HW: 4K5 945 094 C
   Component: SHL_re2  003 0001
   Serial number: 00000000000000030406
   Part No SW: 4N0 035 466 C    HW: 4N0 035 466
   Component: 8RF           H01 0033
   Serial number: 2530279554
   Coding: 0185010000A2AAAAAAA00A010000
   Shop #: WSC 22615 181 00000
   ASAM Dataset: EV_AMPMst24C1Gen2pBAO 001005
   ROD: EV_AMPMst24C1Gen2pBAO.rod
   Component: TSG BFS001 0188
   Serial number: YE007RBL03067
   Coding: 005DDA015E000482A001B030
   Part No SW: 4K0 035 063 D    HW: 4K0 035 063
   Component: MU-H-LND-EU   045 2711
   Coding: 0185010100000000C3111102C00800302F0001E401F008008E
   Subsystem 1 - Part No: V03 959 807 SD
   Component: MIB2P_EU_Q320  0480
   Subsystem 2 - Part No SW: 4K0 919 605 D    HW: 4K0 919 605
   Component: DU AU58x High  H41 0147
   Serial number: INX00110011800060231
   Component: Gracenote2  1006
   Volume Control 1:
   Serial number: 00004418000023210047
   Serial number: INX00125121700080006
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Serial number: 051800114703003
   Part No SW: 4N0 915 105 B    HW: 4N0 915 105 B
   Component: BMS_48V_LiIon H06 0108
   Part No SW: 4K0 907 777 AS    HW: 4K0 907 777 A
   Component: Fahrwerk-SG   H51 2016
   Serial number: 1002180056
   Coding: 746C3838DA40
   ASAM Dataset: EV_ChassContrContiAU651 001011
   ROD: EV_ChassContrContiAU651_001_AU58.rod
   VCID: 08499ADDA2B8D26BC73-805C
   Serial number: 00000000004130254741
   Coding: 303030
   Component: GSM-LL H14 0042
   Serial number: 18.054 40011
   Part No SW: 4K1 919 617 A    HW: 4K1 919 617
   Component: HeadupDisplay H10 1815
   Coding: 5700E0
   ASAM Dataset: EV_HeadUpDisplAU65X 001010
Address 84: Night Vision (J853)       Labels:* None
   Part No SW: 4K0 907 547     HW: 4M0 907 547
   Component: NV-ECU-Gen3   H11 0145
   Serial number: 643208500201805
   Coding: 400113
   ASAM Dataset: EV_NightVisioG3AUTOLAU58x 001003
   ROD: EV_NightVisioG3AUTOLAU58x.rod
   VCID: 6FBBD141A716E553669-803A
   Night vision system camera:
   Subsystem 1 - Part No SW: 4G0 980 552 A    HW: 4G0 980 552
   Component: NV-CAM-Gen3  H06 0007
   Serial number: 639589400B1805800160
   Part No SW: 4KE 907 107 AC    HW: 4N0 907 107 H
   Component: zFAS Var C    H08 0291
   Coding: 040184000000000000FFD60000F0D4045B9F760000000000000000000096D401009BA8000000000000000080E00000000000000000000000F98040000000000000007CD0008000B000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 001005
   Component: SCR-Stg-G4H07 0004
   Component: TSG HFS002 0188
   Serial number: YE007RBL02274
   Coding: 004DD80100000482A000B020
   Component: TSG HBFS002 0188
   Serial number: YE007RBL02318
   Coding: 42244200
   Part No SW: 4N0 903 028 H    HW: 4N0 903 028 H
   Component: BSG-HP1-65    H16 0523
   Serial number: 08031800010093
Address CD: Laser Scanner (J1122)       Labels: None
   Part No SW: 4K8 907 660 B    HW: 4N0 907 660
   Component: LASER_SCANNER H34 0202
   ASAM Dataset: EV_LaserScannAU651 013013
   ROD: EV_LaserScannAU651_013.rod
   Component: MRR_HL H12 0266
   Coding: 0FFC00
   Part No SW: 4K0 941 592 BB    HW: 4K0 941 592 B
   Component: LMS_MLBevo    H10 0021
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001012
   Serial number: 01111700000751001011
   ASAM Dataset: EV_LMSRightHELLAAU58X 001012
   Serial number: 02111700000685001011
   Part No SW: 4N0 907 669 F    HW: 4N0 907 669 A
   Component: MRR_VR H12 0266
   Coding: 003000
   Component: MRR_VL H12 0266
   Coding: 003000
   Part No SW: 4K0 035 502     HW: 4K0 035 502
   Component: WLC Front     H06 0042
   Coding: 800000
   VCID: 5EE59C8550BC7CDBDDF-800A
IDE05274-Acoustic warning for rear lid assistant,active ,1
IDE10321-MAS01364-Seat heater: micro adjust.-Stage 1,5 °C,3
IDE10321-MAS01365-Seat heater: micro adjust.-Stage 2,4 °C,3
IDE10321-MAS01366-Seat heater: micro adjust.-Stage 3,3 °C,3
IDE10322-MAS01366-Seat ventilation: micro adjust.-Stage 3,5 %,3
IDE12224-MAS14155-Rear parking aid warning buzzer with open convertible top-Increment between the volume levels,4 ,2
IDE12225-MAS14155-Front parking aid warning buzzer with open convertible top-Increment between the volume levels,4 ,2
MAS15621-Restart information,not activated ,1
downtime
Finland
C?ID=280813
What is that? It's activated on the car with auto high beam always on and not activated on your car.
CuturiloD
Serbia
C?ID=361908
Tnx for this information, I don't saw this detail.
I will check today afternoon.
CuturiloD
Serbia
C?ID=361908
I was change this chanal. Without any diference.
downtime
Finland
C?ID=280813
Do you have adaptations from other modules? Could be that this setting is not in BCM. Audi A4,A6 are so different than other brand models.
CuturiloD
Serbia
C?ID=361908
I have admaps from my friend car for next module #09, #A5, #D6 and D7.
For my car I can scan every module.
What you think which module can be?
Here is a5, D6 and D7 from S6:
IDE00001-MAS14900-Production mode-Block laser beam,not active ,3
IDE00001-MAS15334-Production mode-Prevention of automatic parking,not active ,3
IDE00001-MAS15687-Production mode-Coding in two steps,not active ,3
IDE00001-MAS15689-Production mode-Deactivate crossing assistant,not active ,3
IDE00001-MAS15690-Production mode-Front camera: deactivate safety mechanisms,not active ,3
IDE00001-MAS16302-Production mode-Peripheral camera system: block partial function,not active ,3
IDE07596-Personalization of lane dept. warning Cl. 15 on,activated ,1
IDE13325-Emergency assistant: status after switching on terminal 15,As prior to switching off terminal 15 (personalized) ,1
IDE13367-MAS16343-Automatic headlamp calibration: settings-Image quality threshold value,0 %,7
IDE13367-MAS16344-Automatic headlamp calibration: settings-Time limit total duration,0 ms,7
IDE13367-MAS16345-Automatic headlamp calibration: settings-Time-limit for image processing,0 ms,7
IDE13367-MAS16346-Automatic headlamp calibration: settings-Time-limit for headlamp positioning,0 ms,7
IDE13369-MAS16358-Automatic headlamp calibration: correction angle-Right headlamp: horizontal,-1.00 °,4
IDE13369-MAS16359-Automatic headlamp calibration: correction angle-Right headlamp: vertical,-1.00 °,4
IDE13369-MAS16360-Automatic headlamp calibration: correction angle-Left headlamp: horizontal,-1.00 °,4
IDE13369-MAS16361-Automatic headlamp calibration: correction angle-Left headlamp: vertical,-1.00 °,4
IDE13370-MAS16358-Auto. headlamp calibration: correction of standard deviations-Right headlamp: horizontal,-0.50 ,4
IDE13370-MAS16359-Auto. headlamp calibration: correction of standard deviations-Right headlamp: vertical,-0.50 ,4
IDE13370-MAS16360-Auto. headlamp calibration: correction of standard deviations-Left headlamp: horizontal,-0.50 ,4
IDE13370-MAS16361-Auto. headlamp calibration: correction of standard deviations-Left headlamp: vertical,-0.50 ,4
IDE13583-Lane departure warning: intensity of the steering wheel vibration,Medium ,1
ENG153826-Emergency_assist_activation_override,EA_activation_over_menu ,1
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not activated ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not activated ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not activated ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not activated ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not activated ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not activated ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not activated ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not activated ,1
IDE01550-Service position,not active ,1
IDE09392-Light distribution,not active ,1
IDE13847-Parking light for signature lights,not active ,1
IDE14258-Headlamp light classes,00 00 00 00 ,4
IDE14259-Headlamp Reset light class,Reset ,1
MAS06010-Ambient light,not active ,1
ENG168388-ENG168424-Activation of Write Service for Brightness Classes-Brightness_class_ch1_1,1 ,7
ENG168388-ENG168425-Activation of Write Service for Brightness Classes-Brightness_class_ch1_2,3 ,7
ENG168388-ENG168426-Activation of Write Service for Brightness Classes-Brightness_class_ch1_3,3 ,7
ENG168388-ENG168427-Activation of Write Service for Brightness Classes-Brightness_class_ch2_1,1 ,7
ENG168388-ENG168428-Activation of Write Service for Brightness Classes-Brightness_class_ch2_2,3 ,7
ENG168388-ENG168429-Activation of Write Service for Brightness Classes-Brightness_class_ch2_3,3 ,7
ENG168388-ENG168430-Activation of Write Service for Brightness Classes-Brightness_class_ch3_1,1 ,7
ENG168388-ENG168431-Activation of Write Service for Brightness Classes-Brightness_class_ch3_2,3 ,7
ENG168388-ENG168432-Activation of Write Service for Brightness Classes-Brightness_class_ch3_3,3 ,7
ENG168388-ENG168433-Activation of Write Service for Brightness Classes-Brightness_class_ch4_1,1 ,7
ENG168388-ENG168434-Activation of Write Service for Brightness Classes-Brightness_class_ch4_2,3 ,7
ENG168388-ENG168435-Activation of Write Service for Brightness Classes-Brightness_class_ch4_3,3 ,7
ENG168388-ENG168436-Activation of Write Service for Brightness Classes-Brightness_class_ch5_1,1 ,7
ENG168388-ENG168437-Activation of Write Service for Brightness Classes-Brightness_class_ch5_2,1 ,7
ENG168388-ENG168438-Activation of Write Service for Brightness Classes-Brightness_class_ch5_3,3 ,7
ENG168388-ENG168439-Activation of Write Service for Brightness Classes-Brightness_class_ch6_1,3 ,7
ENG168388-ENG168440-Activation of Write Service for Brightness Classes-Brightness_class_ch6_2,3 ,7
ENG168388-ENG168441-Activation of Write Service for Brightness Classes-Brightness_class_ch6_3,3 ,7
ENG168388-ENG168442-Activation of Write Service for Brightness Classes-Brightness_class_ch7_1,3 ,7
ENG168388-ENG168443-Activation of Write Service for Brightness Classes-Brightness_class_ch7_2,3 ,7
ENG168388-ENG168444-Activation of Write Service for Brightness Classes-Brightness_class_ch7_3,3 ,7
ENG168388-ENG168445-Activation of Write Service for Brightness Classes-Brightness_class_ch8_1,3 ,7
ENG168388-ENG168446-Activation of Write Service for Brightness Classes-Brightness_class_ch8_2,3 ,7
ENG168388-ENG168447-Activation of Write Service for Brightness Classes-Brightness_class_ch8_3,3 ,7
ENG168388-ENG168448-Activation of Write Service for Brightness Classes-Brightness_class_slave_1,1 ,7
ENG168388-ENG168449-Activation of Write Service for Brightness Classes-Brightness_class_slave_2,3 ,7
ENG168389-ENG168451-Activation of Write Service for headlamp data-Headlamp_construction_release,1 ,32
ENG168389-ENG168452-Activation of Write Service for headlamp data-Headlamp_manufacturer,HELLA        ,32
ENG168389-ENG168453-Activation of Write Service for headlamp data-Headlamp_part_number,01337801    ,32
ENG168389-ENG168454-Activation of Write Service for headlamp data-Headlamp_production_day,27 d,32
ENG168389-ENG168455-Activation of Write Service for headlamp data-Headlamp_production_hours,18 H,32
ENG168389-ENG168456-Activation of Write Service for headlamp data-Headlamp_production_minutes,40 min,32
ENG168389-ENG168457-Activation of Write Service for headlamp data-Headlamp_production_month,9 Months,32
ENG168389-ENG168458-Activation of Write Service for headlamp data-Headlamp_production_seconds,53 s,32
ENG168389-ENG168459-Activation of Write Service for headlamp data-Headlamp_production_year,2019 yr,32
ENG168389-ENG168460-Activation of Write Service for headlamp data-Headlamp_serial_number,1 ,32
ENG168390-ENG168462-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED1,100 %,108
ENG168390-ENG168463-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED10,100 %,108
ENG168390-ENG168464-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED11,100 %,108
ENG168390-ENG168465-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED12,100 %,108
ENG168390-ENG168466-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED2,100 %,108
ENG168390-ENG168467-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED3,100 %,108
ENG168390-ENG168468-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED4,100 %,108
ENG168390-ENG168469-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED5,100 %,108
ENG168390-ENG168470-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED6,100 %,108
ENG168390-ENG168471-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED7,100 %,108
ENG168390-ENG168472-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED8,100 %,108
ENG168390-ENG168473-Activation of Write Service for LED calibration values-LED_calibration_value_LMM1_LED9,100 %,108
ENG168390-ENG168474-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED1,37 %,108
ENG168390-ENG168475-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED10,37 %,108
ENG168390-ENG168476-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED11,37 %,108
ENG168390-ENG168477-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED12,37 %,108
ENG168390-ENG168478-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED2,37 %,108
ENG168390-ENG168479-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED3,37 %,108
ENG168390-ENG168480-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED4,37 %,108
ENG168390-ENG168481-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED5,37 %,108
ENG168390-ENG168482-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED6,37 %,108
ENG168390-ENG168483-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED7,37 %,108
ENG168390-ENG168484-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED8,37 %,108
ENG168390-ENG168485-Activation of Write Service for LED calibration values-LED_calibration_value_LMM10_LED9,37 %,108
ENG168390-ENG168486-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED1,37 %,108
ENG168390-ENG168487-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED10,37 %,108
ENG168390-ENG168488-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED11,37 %,108
ENG168390-ENG168489-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED12,37 %,108
ENG168390-ENG168490-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED2,37 %,108
ENG168390-ENG168491-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED3,37 %,108
ENG168390-ENG168492-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED4,37 %,108
ENG168390-ENG168493-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED5,37 %,108
ENG168390-ENG168494-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED6,37 %,108
ENG168390-ENG168495-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED7,37 %,108
ENG168390-ENG168496-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED8,37 %,108
ENG168390-ENG168497-Activation of Write Service for LED calibration values-LED_calibration_value_LMM11_LED9,37 %,108
ENG168390-ENG168498-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED1,37 %,108
ENG168390-ENG168499-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED10,37 %,108
ENG168390-ENG168500-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED11,37 %,108
ENG168390-ENG168501-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED12,37 %,108
ENG168390-ENG168502-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED2,37 %,108
ENG168390-ENG168503-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED3,37 %,108
ENG168390-ENG168504-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED4,37 %,108
ENG168390-ENG168505-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED5,37 %,108
ENG168390-ENG168506-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED6,37 %,108
ENG168390-ENG168507-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED7,37 %,108
ENG168390-ENG168508-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED8,37 %,108
ENG168390-ENG168509-Activation of Write Service for LED calibration values-LED_calibration_value_LMM12_LED9,37 %,108
ENG168390-ENG168510-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED1,100 %,108
ENG168390-ENG168511-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED10,100 %,108
ENG168390-ENG168512-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED11,100 %,108
ENG168390-ENG168513-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED12,100 %,108
ENG168390-ENG168514-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED2,100 %,108
ENG168390-ENG168515-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED3,100 %,108
ENG168390-ENG168516-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED4,100 %,108
ENG168390-ENG168517-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED5,100 %,108
ENG168390-ENG168518-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED6,100 %,108
ENG168390-ENG168519-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED7,100 %,108
ENG168390-ENG168520-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED8,100 %,108
ENG168390-ENG168521-Activation of Write Service for LED calibration values-LED_calibration_value_LMM2_LED9,100 %,108
ENG168390-ENG168522-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED1,100 %,108
ENG168390-ENG168523-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED10,100 %,108
ENG168390-ENG168524-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED11,100 %,108
ENG168390-ENG168525-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED12,100 %,108
ENG168390-ENG168526-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED2,100 %,108
ENG168390-ENG168527-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED3,100 %,108
ENG168390-ENG168528-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED4,100 %,108
ENG168390-ENG168529-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED5,100 %,108
ENG168390-ENG168530-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED6,100 %,108
ENG168390-ENG168531-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED7,100 %,108
ENG168390-ENG168532-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED8,100 %,108
ENG168390-ENG168533-Activation of Write Service for LED calibration values-LED_calibration_value_LMM3_LED9,100 %,108
ENG168390-ENG168534-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED1,100 %,108
ENG168390-ENG168535-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED10,100 %,108
ENG168390-ENG168536-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED11,100 %,108
ENG168390-ENG168537-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED12,100 %,108
ENG168390-ENG168538-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED2,100 %,108
ENG168390-ENG168539-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED3,100 %,108
ENG168390-ENG168540-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED4,100 %,108
ENG168390-ENG168541-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED5,100 %,108
ENG168390-ENG168542-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED6,100 %,108
ENG168390-ENG168543-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED7,100 %,108
ENG168390-ENG168544-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED8,100 %,108
ENG168390-ENG168545-Activation of Write Service for LED calibration values-LED_calibration_value_LMM4_LED9,100 %,108
ENG168390-ENG168546-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED1,100 %,108
ENG168390-ENG168547-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED10,100 %,108
ENG168390-ENG168548-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED11,100 %,108
ENG168390-ENG168549-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED12,100 %,108
ENG168390-ENG168550-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED2,100 %,108
ENG168390-ENG168551-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED3,100 %,108
ENG168390-ENG168552-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED4,100 %,108
ENG168390-ENG168553-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED5,100 %,108
ENG168390-ENG168554-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED6,100 %,108
ENG168390-ENG168555-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED7,100 %,108
ENG168390-ENG168556-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED8,100 %,108
ENG168390-ENG168557-Activation of Write Service for LED calibration values-LED_calibration_value_LMM5_LED9,100 %,108
ENG168390-ENG168558-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED1,100 %,108
ENG168390-ENG168559-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED10,100 %,108
ENG168390-ENG168560-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED11,100 %,108
ENG168390-ENG168561-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED12,100 %,108
ENG168390-ENG168562-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED2,100 %,108
ENG168390-ENG168563-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED3,100 %,108
ENG168390-ENG168564-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED4,100 %,108
ENG168390-ENG168565-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED5,100 %,108
ENG168390-ENG168566-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED6,100 %,108
ENG168390-ENG168567-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED7,100 %,108
ENG168390-ENG168568-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED8,100 %,108
ENG168390-ENG168569-Activation of Write Service for LED calibration values-LED_calibration_value_LMM6_LED9,100 %,108
ENG168390-ENG168570-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED1,100 %,108
ENG168390-ENG168571-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED10,100 %,108
ENG168390-ENG168572-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED11,100 %,108
ENG168390-ENG168573-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED12,100 %,108
ENG168390-ENG168574-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED2,100 %,108
ENG168390-ENG168575-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED3,100 %,108
ENG168390-ENG168576-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED4,100 %,108
ENG168390-ENG168577-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED5,100 %,108
ENG168390-ENG168578-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED6,100 %,108
ENG168390-ENG168579-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED7,100 %,108
ENG168390-ENG168580-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED8,100 %,108
ENG168390-ENG168581-Activation of Write Service for LED calibration values-LED_calibration_value_LMM7_LED9,100 %,108
ENG168390-ENG168582-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED1,100 %,108
ENG168390-ENG168583-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED10,100 %,108
ENG168390-ENG168584-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED11,100 %,108
ENG168390-ENG168585-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED12,100 %,108
ENG168390-ENG168586-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED2,100 %,108
ENG168390-ENG168587-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED3,100 %,108
ENG168390-ENG168588-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED4,100 %,108
ENG168390-ENG168589-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED5,100 %,108
ENG168390-ENG168590-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED6,100 %,108
ENG168390-ENG168591-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED7,100 %,108
ENG168390-ENG168592-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED8,100 %,108
ENG168390-ENG168593-Activation of Write Service for LED calibration values-LED_calibration_value_LMM8_LED9,100 %,108
ENG168390-ENG168594-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED1,37 %,108
ENG168390-ENG168595-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED10,37 %,108
ENG168390-ENG168596-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED11,37 %,108
ENG168390-ENG168597-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED12,37 %,108
ENG168390-ENG168598-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED2,37 %,108
ENG168390-ENG168599-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED3,37 %,108
ENG168390-ENG168600-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED4,37 %,108
ENG168390-ENG168601-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED5,37 %,108
ENG168390-ENG168602-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED6,37 %,108
ENG168390-ENG168603-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED7,37 %,108
ENG168390-ENG168604-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED8,37 %,108
ENG168390-ENG168605-Activation of Write Service for LED calibration values-LED_calibration_value_LMM9_LED9,37 %,108
ENG168403-Reset_of_laser_error_counter,Reset ,1
ENG168388-ENG168437-Activation of Write Service for Brightness Classes-Brightness_class_ch5_2,2 ,7
ENG168388-ENG168445-Activation of Write Service for Brightness Classes-Brightness_class_ch8_1,2 ,7
ENG168389-ENG168453-Activation of Write Service for headlamp data-Headlamp_part_number,01337802    ,32
ENG168389-ENG168456-Activation of Write Service for headlamp data-Headlamp_production_minutes,44 min,32
ENG168389-ENG168458-Activation of Write Service for headlamp data-Headlamp_production_seconds,27 s,32
This is A5, D6 and D7 from my A6:
IDE01167-Convertible offset for volume level 1,20 ,1
IDE01168-Increment for convertible volume levels,4 ,1
IDE01170-Visual display for park assist,OPS display ,1
IDE03782-Switch-off speed for parking assist,30 km/h,1
IDE13216-Wheel protection assistant,active ,1
IDE13230-Parking assistant: additional length of vehicle extensions,0 cm,1
IDE13231-Parking assistant: additional width of vehicle extensions,0 cm,1
IDE13232-Parking assistant: distance from curb,15 cm,1
IDE13233-Parking assistant: parking space fade-in,not activated ,1
IDE13234-Parking assistant: parking speed,Medium ,1
IDE13235-Parking assistant: parking speed menu,active ,1
MAS12579-IDE13023-Maneuvering assistant-Functional deactivation,not active ,1
MAS12579-MAS00086-Maneuvering assistant-active,active ,1
MAS12579-MAS05122-Maneuvering assistant-Braking intervention,active ,1
MAS12579-MAS14210-Maneuvering assistant-Steering intervention,active ,1
ENG153929-PP_GP_Deactivating_through_zFAS_Thermal_Helath_Status,not active ,1
ENG153930-PP_GP_limit_zFAS_Thermal_Helath_Status_function_abort,0 ,1
ENG153931-PP_GP_limit_zFAS_Thermal_Helath_Status_function_activation,0 ,1
ENG168388-ENG168445-Activation of Write Service for Brightness Classes-Brightness_class_ch8_1,1 ,7
ENG168389-ENG168454-Activation of Write Service for headlamp data-Headlamp_production_day,15 d,32
ENG168389-ENG168455-Activation of Write Service for headlamp data-Headlamp_production_hours,11 H,32
ENG168389-ENG168456-Activation of Write Service for headlamp data-Headlamp_production_minutes,3 min,32
ENG168389-ENG168457-Activation of Write Service for headlamp data-Headlamp_production_month,2 Months,32
ENG168389-ENG168458-Activation of Write Service for headlamp data-Headlamp_production_seconds,33 s,32
ENG168389-ENG168459-Activation of Write Service for headlamp data-Headlamp_production_year,2018 yr,32
ENG168389-ENG168454-Activation of Write Service for headlamp data-Headlamp_production_day,21 d,32
ENG168389-ENG168455-Activation of Write Service for headlamp data-Headlamp_production_hours,8 H,32
ENG168389-ENG168456-Activation of Write Service for headlamp data-Headlamp_production_minutes,33 min,32
ENG168389-ENG168458-Activation of Write Service for headlamp data-Headlamp_production_seconds,41 s,32
CuturiloD
Serbia
C?ID=361908
hmm........... in D6, D7 admap, perhaps:
  • IDE14259-Headlamp Reset light class
I am afraid to change this value, because on my friend car this value is same, but he have Auto Main Beam always ON.
lukkii
Czech Republic
C?ID=337474
Nothing easier: just DEactivate the reset-channel at BCM -
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,aktiv ,6
downtime
Finland
C?ID=280813
Somehow I doubt OPs A6 has this channel. Remember, Audi is a different beast.
For MQB BCM that what you wrote applies, but Audi is MLBEvo If you look at the second post, OP posted adamap from 09 and that channel is missing (or I’m blind)
@downtime: I agree 101%. My hunch (guess really) is that the answer has to do with channels in BCM1 with the primary tag number IDE03679.
In OP's hex09 admap above, there is only one channel with this primary tag (IDE03679-Adaptive light functions,active). However in the MLBEvo BCM HERE (different module), the admap reports the following:
IDE03679-MAS09575,Adaptive light functions-High beam request,OFF,
IDE03679-MAS10260,Adaptive light functions-Request for automatic high beam,OFF,
IDE03679-MAS10261,Adaptive light functions-Automatic high beam availability,not coded/not installed,
IDE03679-MAS10264,Adaptive light functions-High beam: status,not coded/not installed,
IDE03679-MAS10265,Adaptive light functions-Left high beam: error status,not coded/not installed,
IDE03679-MAS10266,Adaptive light functions-Right high beam: error status,not coded/not installed,
IDE03679-MAS10268,Adaptive light functions-Matrix automatic high beam availability,not coded/not installed,
IDE03679-MAS10271,Adaptive light functions-Matrix high beam: status,not coded/not installed,
IDE03679-MAS10272,Adaptive light functions-Left Matrix high beam: error status,not coded/not installed,
IDE03679-MAS10273,Adaptive light functions-Right Matrix high beam: error status,not coded/not installed,
IDE03679-MAS10274,Adaptive light functions-Sensor status: auto. high beam,not coded/not installed,
IDE03679-MAS10275,Adaptive light functions-Matrix auto. high beam: sensor status,not coded/not installed,
Question is where (if at all) are the software switches in the missing adaptation channels - perhaps in the hex46 (central convenience) module - maybe (Shirley not?)
Anyhow, assuming that a HBA reset software switch isn't in the very long, long-code string, the answer could be that in OP's hex09 module, the behavior of the HBA is set in the module firmware (and it is enabled if the setting for IDE03679 is "active"). Notice that the equipment is different in the S6 and A6 like this:
  • BCM1 in S6 = Part No SW: 4N0 907 063 FG HW: 4N0 907 063 AG Component: BCM1 MLBevo H10 0690
  • BCM1 in A6 = Part No SW: 4N0 907 063 BE HW: 4N0 907 063 AE Component: BCM1 MLBevo H10 0633
So, it could be that the firmware in the different BCMs treat HBA reset differently -whereas the version of MLBEvo BCM in my link brings-out these switches into adaptation channels - I'm speculating, of course!
downtime
Finland
C?ID=280813
Thanks Don. Very very good analysis once again :thumbs:
CuturiloD
Serbia
C?ID=361908
Thank You for good alalysis.
What is Your advice for my issue?
If I good understand only way is flashing BCM with newer firmware?
lukkii
Czech Republic
C?ID=337474
Yes Audi A6 may have differnt BCM and certains channels are covered in long coding - in this case I recommend to go through BCM coding- but - the right BIT can be signed by not well called label..
downtime
Finland
C?ID=280813
^ I would expect Audi to be that new that it does not use conventional label files but instead it gets the descriptions from the ASAM data. So if there's a bad labeling, it would be from VAG and not from RT or community.
lukkii
Czech Republic
C?ID=337474
In case of Audi A6 4G , it should be byte 2 BIT 7, in case of FL 2018 and higher, it may work the BIT called SL_AT_DRL (activate). Without guarantee but possible to have a look...
CuturiloD
Serbia
C?ID=361908
This is picture for byte 2:
CuturiloD
Serbia
C?ID=361908
I activate bit 4.
Unfortunately HighBeamAssist still OFF.
Also in this moment I don’t see what is difference now.
What can be drl_at_sl?
