Activation of camshaft (tensioner) adjuster on AMW engine
Glance
Bryson, QC, Canada
C?ID=71902
I have replaced the camshaft tensioner, camshaft chain and camshaft position sensor on my 1.8T Passat and now engine stalls when temperature reach normal position. Is there a way to activate tensioner's solenoid with my VCDS? In the repair manual it is written to check activation of the solenoid valve for camshaft adjustment via the Output Diagnostic test mode (function 03) and an editor's note that reads: Component activation is accomplished using Volkswagen diagnostic scan tool, output diagnostic test mode (function 03). When reading the display in function 04 I do see the tensioner's status and when I put the cursor on "Test OFF" a message appears that activation is not ok???Here is the last scan I did after the engine stalling:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
VIN: WVWVD63B84E222840   Mileage: 346480km-215292miles
Address 01: Engine        Labels: 06B-906-018-AWM.clb
   Part No SW: 4B0 906 018 DP    HW: 8E0 909 018 A
   Component: 1.8L R4/5VT     G   0002
   Coding: 0016501
   Shop #: WSC 05311 000 00000
   VCID: 72E00EC96ED7CB1BC5-513C
16706 - Engine Speed Sensor (G28)
            P0322 - 004 - No Signal
16395 - Bank 1: Camshaft A (Intake)
            P0011 - 002 - Retard Setpoint not Reached (Over-Advanced)
16705 - Engine Speed Sensor (G28)
            P0321 - 008 - Implausible Signal
Readiness: 0000 1100
Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
   Part No: 4B0 614 517 G
   Component: ABS/ESP front       3428
   Coding: 04275
   Shop #: WSC 05311
   VCID: 254A2595BF99ECA390-513C
   Part No: 1C0 909 605 C
   Component: 09 AIRBAG VW61 04   0003
   Coding: 12345
   Shop #: WSC 05311
   VCID: 244C3891B4A315AB87-5102
   Part No: 1J0 907 487 A
   Component: Lenkradelektronik   0005
   Coding: 00118
   Shop #: WSC 05311
   VCID: 2F66C7BDED65A6F36A-513C
Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
   Part No: 3B0 920 829 C
   Component: KOMBI+WEGFAHRSP VDO V04
   Coding: 07305
   VCID: 26482299C29FE7BB99-5120
   WVWVD63B84E222840     VWZ7Z0C8525953
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 05311
   VCID: 70E404C130DBF90B33-5102
   Part No: 1C0 959 799 C
   Component: 80 Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 05311
   VCID: 3776FFDD15356E3332-4B18
   Subsystem 1 - Part No: 1C1959801
   Component: 80 Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C1959802
   Component: 80 Tõrsteuer.BF KLO 0202
   Subsystem 3 - Part No: 1C0959811
   Component: 80 Tõrsteuer.HL KLO 0202
   Subsystem 4 - Part No: 1C0959812
   Component: 80 Tõrsteuer.HR KLO 0202
00955 - Key 1
            09-10 - Adaptation Limit Surpassed - Intermittent
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 180 F
   Component:    Radio NP2        0016
   Coding: 04401
   Shop #: WSC 05311
   VCID: 234E3B8DB1AD1293FE-5120
End-------------------------(Elapsed Time: 04:36)--------------------------
Hi and welcome.
IMO, you need to fix whatever is ailing the Engine Speed Sensor (G28) signal first. That's the most important sensor on the engine.
Your ECU does support Output Tests, but only "Sequential" not "Selective", so you'll need to work through the sequence until you get to the right test. The sequence is determined by the ECU itself, so I have no way to tell you where in the sequence the test you're looking for will be.
See also:
Glance
Bryson, QC, Canada
C?ID=71902
Hey Uwe,
Thank you for your quick reply. I replaced the engine speed sensor as recommended and guess what, the engine doesn't stall after it warms up! It was idling a little rough after it warmed up and the check engine light came on, but scanned and erased the fault and then took it for a test drive for 16 km. Runs really well and lots of pep and engine restarts immediately and no more check engine.
Also did the sequential output tests and did see the tensioner in the auto sequence but still reads "off" and "activation not ok"???
Here is the scan I got after check engine light came on:
   Coding: 0016501
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
            P1340 - 001 - Incor. Correlation - MIL ON
Readiness: 0110 0101
   Coding: 04275
   Shop #: WSC 05311
   VCID: 254A2595BF99ECA390-5120
   Coding: 12345
   Shop #: WSC 05311
   Coding: 00118
   Shop #: WSC 05311
   Coding: 07305
   VCID: 26482299C29FE7BB99-5102
   Coding: 00006
   Shop #: WSC 05311
   VCID: 70E404C130DBF90B33-5120
   Coding: 00259
   Shop #: WSC 05311
   VCID: 3776FFDD15356E3332-4B00
00955 - Key 1
   Coding: 04401
   Shop #: WSC 05311
   VCID: 234E3B8DB1AD1293FE-5102
End-------------------------(Elapsed Time: 04:37)--------------------------
Gabriel
