So I have a 1999 Audi A6 quattro Avant (Norwegian/European model, LHD), with power windows acting up. I've been reading up for weeks, and checked pretty much anything I could think off and come across, and conferred with several other forums for a long time. I'm at the point where I'm just about to give up - but I would very much like to hear what the more competent people here have to say first.
All 4 windows are moving only 2-3 inches at a time, then they stop. Behavior is the same going up and down, and wether operated from driver master or respective door switch. Short tug or holding makes no apparent difference. Same behavior if operated by holding lock/unlock on key FOB. At a few occations, the rear windows would completely stop responding to for 10-15-20 seconds. Movement is smooth, and when it stops it does not retract - suggesting it is not the "pinch safety" somehow triggered (?). Stuck a folded blanket in the window to test, and when triggered - the "pinch safety" does indeed stop and retract the window. I've inspected gliders and regulators, door wiring loom etc, all seem sound. Had the carpet out to theck the Comfort (control) module, seems this car don't have one. The box in the floor contained what could identify by part number as the [35] Central Locks module. Box, contacts, plugs, module circuit board and components inspected - all sound and bone dry. Visual inspection of under-carpet loom and connectors, show no signs of moisture or corrosion.
Some say visuals say more than a thousand words, so -here- is a 30-second video clip of window operation.
The only (partly potential) issues with car/wiring I know about - I mention here just in case one might rely on the other. Most of these have been successfully diagnosed, just haven't gotten to fix/replace the respective part(s) yet:
Just in case it shows anything relevant, here's an auto-scan log.
Small note: According to some resources here @ Ross-Tech, the coding for 45 Interior Monitor, suggest the car is coded for for (3-door?) Audi A3/8L..? Could this be related? And if so, can this unit be recoded? I have not experienced any alarm issues.
- Driver seat, bottom cushion heater element broken/no continuity.
- Driver door, side mirror heater element broken/no continuity (checked at mirror connector, loom checked and in sound condition).
- One or more fuel senders reporting incorrect resistance. (Have not pulled all 3 out of tank for inspection, fix and/or replacement yet - waiting for new tank seals)
- Passenger rear door lock reports "01562 59-00 Can't Unlock" and "01562 61-00 Won't De-Safe". Operates normally, but door courtesy light and instrument panel doesn't register when door is opened. (Suspect broken micro-switch in lock mecanism).
- Car is European spec 1999, thus no OBD2/EOBD, nor can-bus. Just K-line. All modules communicate on KW1281 protocol).
- Car has aftermarket Pioneer stereo, stock passive speakers. Wired by adapter, no splicing. No K-line connected to stereo loom/adapter. Option sheet says stock radio was "RCD 4002".
Friday,03,April,2015,13:11:10:25704
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WAUZZZ4BZXN055772 License Plate:
Mileage: 165023 Repair Order:
Chassis Type: 4B - Audi A6 C5 (1998 > 2006)
75 76 77
Address 01: Engine Labels: 078-907-552-AMM.lbl
Part No: 4B0 907 552 C
Component: 2.4L V6/5V MOTR HS D05
Coding: 04202
Shop #: WSC 00785
VCID: 25411716BF410B36C75-4B36
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D00
Shop #: BB 24334
VCID: 1C3732F28C0BCAFE68B-515E
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 J
Component: A6-Klimavollautomat D64
Coding: 00060
Shop #: WSC 00785
VCID: 21490306AB69E716BBD-25AE
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4B0 959 655 G
Component: Airbag Front+Seite 0001
Coding: 00206
Shop #: WSC 02324
VCID: 3467FA52049B62BE40B-51D4
Address 17: Instruments Labels: 4B0-919-xxx-17.lbl
Part No: 4B0 919 880 H
Component: C5-KOMBIINSTR. VDO D10
Coding: 05162
Shop #: WSC 00940
VCID: 3169F346FB8957962BD-5198
Subsystem 1 - Part No: IMMO
Component: IDENTNR: AUZ7Z0W0780423
IMMO-IDENTNR: AUZ7Z0W0780423
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 E
Component: Zentralverrieg.,DWA D32
Coding: 04683
Shop #: WSC 00380
VCID: 2B55E12ED9A53D46111-4F3E
01562 - Rear Right Door
59-00 - Can't Unlock
61-00 - Won't De-Safe
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00002
Shop #: WSC 02325
VCID: E0CFC60260E32E1E743-4B82
