VW Passat B8 2017 Lane Assist activation.
Dp41n8w
Finland
C?ID=372411
Hi. Is there possibility to activate Lane assist to that car? Car has camera in windscreen, HBA. I Tried to activate lane assist to b8 but worked out. In A5, when I tried to activate bites it said that request out of range..
Thanks.
Thursday,08,April,2021,16:21:31:19148
VIN: WVWZZZ3CZHE010716   License Plate: COO-602
Mileage: 168813km-104895mi   Repair Order:
Chassis Type: 3C-VW48 (5QE)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 23 2B 42 44 51 52 55
          5F 69 6C 75 8C A5 A9 BB BC C6
VIN: WVWZZZ3CZHE010716   Mileage: 168813km-104895miles
Address 01: Engine (J623-CUKC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 AH    HW: 04E 907 309 F
   Component: R4 1.4l TFS   H22 3379
   Revision: X3H22---
   Coding: 011D001A647405083000
   Shop #: WSC 40110 222 00000
   ASAM Dataset: EV_ECM14TFS01104E906023AH 006006
   ROD: EV_ECM14TFS01104E906023AH_006.rod
   VCID: 6695B68F78E361FB15F-8032
25358 - Fuel Tank Door
          P04B6 00 [096] - Stuck Closed
   Part No SW: 0DD 300 045 T    HW: 0DD 927 770 B
   Component: GSG DQ400E    H31 1601
   Revision: 00031033    Serial number: TFK01605070313
   ROD: EV_TCMDQ400021_VW48.rod
   VCID: 382928F762D7270B773-806C
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 BL    HW: 5Q0 614 517 AH
   Component: ESC           H62 0855
   Revision: 00000000    Serial number: 61356000000540
   Coding: 0FEC408F3821236C477E060141C949F0021CC4E26082927118A1F078C20202
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
   ROD: EV_Brake1UDSContiMK100OMG_003.rod
   VCID: 7CA1F4E7166FCB2BD3B-8028
8400 - Databus
          U1123 00 [044] - Received Error Message
          [FCAN: AB_Gurt_FA signal is invalid]
                    Mileage: 168684 km
                    Date: 2021.04.04
                    Time: 15:15:27
16401 - Tire Pressure Warning
          C102D 00 [044] - -
                    Mileage: 167699 km
                    Date: 2021.03.16
                    Time: 18:41:38
   Part No SW: 3Q0 959 435 D    HW: 3Q0 959 435 D
   Component: VWKESSYMQB    026 0811
   Revision: 00026000    Serial number: 0405620591
   Coding: 002F0F0F0F
   Shop #: WSC 05311 115 00318
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3B2337FB53E10C139A1-806E
   Part No SW: 5GE 907 044 AL    HW: 5GE 907 044 AL
   Component: Climatronic   H04 1502
   Revision: 00001K07
   Coding: 1202100420010101091550000010182A
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_ACClimaBHBVW37X 006140
   VCID: 0655960F58A381FBB5F-8052
   Subsystem 3 - Part No SW: 3Q0 963 231 C    HW: 3Q0 963 231 C
   Component: J848 HV-PTC  200 0203
   Serial number: -00102.2T.2B20340262
   Air quality sensor:
   Humidity sensor: exterior:
   A/C compressor sub:
H02
328196 - Motor for Right Temperature Flap
          B108D 71 [008] - Actuator stuck
                    Reset counter: 107
                    Mileage: 168168 km
                    Date: 2021.03.26
                    Time: 13:45:57
                    Voltage terminal 30: 14.5 V
                    Outside temperature: 2.0 °C
                    Inside temperature: 25.5 °C
                    Right temperature flap: actual value: 63
                    Right temperature flap: actual value: 17.5 %
                    Temperature door right - Specified value: 60
   Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 032 0222
   Revision: --------    Serial number: 8658270516018S
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 015F8513718DA6C380D-8054
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    160426  042 0607
   Serial number:         160510201104
   Component: RLHS  042 0105
   Serial number: S6Y16M06D02H14M36S49
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 J    HW: 3G0 941 633 J
   Serial number: 05 03 2016  10000710
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY1610205V5
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000065984357
   Humidity sensor: interior:
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39331614604472
   Coding: 0071151911
   Shop #: WSC 05311 115 00083
   VCID: 44D14C072E1F73EBEBB-8010
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0194
   Coding: 520067CA11FFC428949C8045
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 34311CC77EBFC36B5BB-8060
   Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
   Component: AirbagVW20    010 0870
   Serial number: 003MFR0270C2
   Coding: 88CCC000002000005C5400CF004800000065
   Shop #: WSC 05311 000 08193
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 50F97057EA679F4B5F3-8004
   Left seat belt tensioner:
   Serial number: 3G1857705G0149Q01021
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 3G1857706G0141Q01170
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 001 905 16
   Serial number: 35700000000BC6902B1O
   Subsystem 4 - Part No SW: -----------    HW: 480 001 905 16
   Serial number: 358000000000B6902B1D
   Subsystem 5 - Part No SW: -----------    HW: 480 401 105 16
   Serial number: 3510002C7205728502DV
   Subsystem 6 - Part No SW: -----------    HW: 480 402 301 16
   Serial number: 3520002A31E9F0E3E1DN
   Subsystem 7 - Part No SW: -----------    HW: 480 401 105 16
   Serial number: 3550002C72057284F0B2
   Part No SW: 3Q0 953 521 DJ    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20160505500560
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 7BA3F7FB1361CC13DA1-802E
   Part No SW: 3G0 920 754 B    HW: 3G0 920 754 B
   Component: KOMBI         303 8315
   Coding: 07250B182FC0000801882B111200002000000000
   VCID: 270BFB8BBF69B8F3EE9-8072
1048578 - No Basic Setting
          B2010 00 [009] - -
          [Steuergerät keine oder falsche Grundeinstellung]
                    Reset counter: 224
                    Mileage: 164910 km
                    Date: 2021.01.28
                    Time: 15:45:27
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 H    HW: 5Q0 963 272 H
   Component: STH-MQB       008 0075
   Coding: 13C1
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000058561
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 5QE 907 530 F    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3265
   Revision: --------    Serial number: 21051610803803
   Coding: 020300172EF21000FB00527E5C1D00000001070100010000000300000000
   ASAM Dataset: EV_GatewEVConti 013020
   ROD: EV_GatewEVConti_013.rod
   VCID: 49CF5D33093DAE8318D-801C
   Subsystem 1 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29160000976790036201
   Coding: 2DFFFF
   Subsystem 2 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
   Serial number: 7104200104
   Analog clock:
   Subsystem 3 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
8526357 - No Function Support for HV to LV while standing; HV SOC
          P30F4 00 [008] - -
                    Reset counter: 71
                    Mileage: 167532 km
                    Date: 2021.03.13
                    Time: 05:46:11
                    Terminal 30 power supply: 14.4 V
                    Terminal 15: OFF
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 E    HW: 5QE 909 059 B
   Component: EBKV          H14 0200
   Serial number:   085430010664
   Coding: 05720100431900020002060500
   Shop #: WSC 05311 115 00314
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004001
   ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
   Brake pressure reservoir:
   Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0152
   Serial number: 05802861090516124609
   Serial number: 16000109978004
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD5D3412DB64370D-8024
   Serial number: 010416ECV07538
   Coding: 003F0E208000028000001000
   VCID: 43D34F1B2B1174D3D21-8016
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000815728
   Coding: 01000010005101
   Shop #: WSC 00015 115 00318
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_008.rod
   VCID: 3D2739E34DF50223A45-8068
   Part No SW: 3G0 907 080 E    HW: 3G0 907 080 C
   Component: LE Gen 3.3H09 0072
   Revision: 00H09000
   Coding: C0020000000000000000
   Shop #: WSC 28406 001 1048576
   ASAM Dataset: EV_DMCM08530113G0907080E 001017
   ROD: EV_DMCM08530113G0907080E.rod
   Serial number: 130516EED15693
   Coding: 003F00208C00028000001000
   VCID: 42DD4A1F340B7DDBD97-8016
   Component: AFS-ECU       H01 0120
   Coding: 039A00004F200200
   Shop #: WSC 05311 000 00001
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   VCID: 3FDB43EB47F91033B69-806A
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
13705995 - Databus
          [Kamera_Status: Fehlerwert im Signal Kamera_FDD_Funktionsstatus]
                    Fault Frequency: 8
                    Reset counter: 88
                    Mileage: 165063 km
                    Date: 2021.01.30
                    Time: 15:54:18
   Part No SW: 3Q0 035 824 B    HW: 3Q0 035 824 B
   Component: MU-S--ER      710 0744
   Coding: 02840200FF0000005111000100080A001F0209C40120010003
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2C0104A7A68F9BAB03B-8078
   Subsystem 1 - Part No SW: 3G0 919 605 B    HW: 3G0 919 605 B
   Component: ABT_Std-2  H43 4064
   Serial number: VWZ6Z9S1481177
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0204
   Revision: 8A001003    Serial number: 0405585298
   Coding: 0100000202000000
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H09 0170
   Coding: 0184020163002017000041
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
   ROD: EV_CamSysRVRVCPANAMQBAB_005.rod
   VCID: 77ABEBCB2F49E873BE9-8022
   Part No SW: 5QE 035 284 C    HW: 5QE 035 284 C
   Component: OCULowMQBEU   012 0715
   Coding: 0284720110169A0300F800000000
   ROD: EV_OCULowMQB.rod
Address 8C: Hybrid Battery (J840)       Labels: 5QE-915-227.clb
   Part No SW: 3Q0 915 227 P    HW: 3Q0 915 227 K
   Component: K8C           H05 0520
   Serial number: 21041616010046
   ASAM Dataset: EV_BECM09620213Q0915227P 002009
   ROD: EV_BECM09620213Q0915227P.rod
   VCID: 3E253EEF40F3193BBDF-806A
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 3Q0 915 227 J    HW: 3Q0 915 227 J
   Component: A2 HVSMBJBECU  H08 0410
   Serial number: 00000011031615010131
   Cell module control module 1:
   Subsystem 2 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC1  H04 0442
   Serial number: 16302ZKK311A01041769
   Cell module control module 2:
   Subsystem 3 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC2  H04 0442
   Serial number: 16302ZKK311A01041810
   Cell module control module 3:
   Subsystem 4 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC3  H04 0442
   Serial number: 16302ZKK311A01041770
   Cell module control module 4:
   Subsystem 5 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC4  H04 0442
   Serial number: 16302ZKK311A01041820
   Cell module control module 5:
   Subsystem 6 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC5  H04 0442
   Serial number: 16223ZKK311A01040106
   Cell module control module 6:
   Subsystem 7 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC6  H04 0442
   Serial number: 16302ZKK311A01041704
   Cell module control module 7:
   Subsystem 8 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC7  H04 0442
   Serial number: 16303ZKK311A01040192
   Cell module control module 8:
   Subsystem 9 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC8  H04 0442
   Serial number: 16223ZKK311A01040226
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0220
   Serial number: 25051611K11124
   Coding: 0004080207000401002200458050A10000000E300040
   Shop #: WSC 38905 003 104857
   VCID: 3A2D32FF5CDB351B817-806E
   Part No SW: 3G0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0006
   Serial number: 160506201445
   VCID: 698FBDB369FD4E8338D-803C
   Serial number: 050516EE50211C
   Coding: 000E00200100028000001000
   VCID: 45D7510325254AE3FC5-8010
   Serial number: 050516EE502113
65593 - Switch for Central Locking
          B122D 29 [008] - Signal Implausible
                    Fault Frequency: 60
                    Reset counter: 106
                    Mileage: 165916 km
                    Date: 2021.02.18
                    Time: 07:50:51
   Part No SW: 5QE 915 682 M    HW: 5QE 915 682 M
   Component: OBC KOSTAL    H31 4006
   Revision: --------    Serial number: 0105160DR000U0
   Coding: 115068222000
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB11P 004001
   ROD: EV_OBCSinglPhaseKLOMQB11P.rod
   VCID: 57EB8B4BCF89C8739E9-8002
2098720 - AirConditioning not possible because Battery SOC too Low
          P33EF 00 [008] - -
                    Reset counter: 72
                    Mileage: 167615 km
                    Date: 2021.03.14
                    Time: 19:42:27
13705540 - Databus
          [Errorvalue_ ESP_21_CHK]
                    Reset counter: 107
                    Mileage: 164910 km
                    Date: 2021.01.28
                    Time: 15:50:28
End----------(Elapsed Time: 02:30, VBatt start/end: 12.8V/12.7V)-----------
chr
Romania
C?ID=79671
I think, your A5: Frt Sens. Drv. Assist (R242) is broken. When wiring between PCB and camera is broken, you will have ,,No fault code found,, but in fact communication between PCB and camera missing.
Maybe is a good ideea to check internal camera wiring or to change your A5: Frt Sens. Drv. Assist.
Dp41n8w
Finland
C?ID=372411
In A5 There is no errors. Problem is that i cant change coding. Cos request is out of range.
