Wednesday,07,April,2021,12:17:22:15623
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
VIN: VSSZZZ5FZL6530399 License Plate: CY69FFX
Mileage: 11297km-7019mi Repair Order: 07042021
Chassis Type: 5F-SE37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 42 44 4B 52 5F 69 BB BC D6 D7
VIN: VSSZZZ5FZL6530399 Mileage: 11297km-7019miles
Address 01: Engine (J623-DFFA) Labels: None
Part No SW: 04L 906 027 AB HW: 04L 907 309 P
Component: R4 2.0l TDI H26 9600
Revision: B4H26---
Coding: 01190032032405092000
Shop #: WSC 00033 790 00164
ASAM Dataset: EV_ECM20TDI01104L906027AB 004003
ROD: EV_ECM20TDI01104L906027AB.rod
VCID: 6B83C202A30620234A1-803E
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Q0 614 517 ER HW: 5Q0 614 517 BN
Component: ESC H35 0190
Revision: 00000000 Serial number: 62939000000759
Coding: 21EE8A9230230C6C077A060962CC2484510C30E0604624733060F078C0024B0B00002D641212131A1E35351919323200
Shop #: WSC 00033 790 00115
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 055794BAA5A2F653BC5-8050
Part No SW: 5F0 907 044 BE HW: 5F0 907 044 BE
Component: Climatronic H06 2201
Revision: 00001K10
Coding: 06100104200114011005000000101020
ASAM Dataset: EV_ACClimaBHBVW37X 006150
VCID: 6A8DC706ACFC392B317-803E
Air quality sensor:
Part No SW: 5Q0 937 084 DH HW: 5Q0 937 084 CG
Component: BCM MQBAB H H40 0312
Serial number: 01001928400395
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020_VW26.rod
VCID: 015F80AAB18ADA7380D-8054
Subsystem 1 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 23779542X81A955555A0
Coding: 80007E
Subsystem 2 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY191800GDP
Subsystem 3 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000674237
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 J HW: 5Q1 953 569 A
Component: Lenks.Modul H13 0170
Serial number: 0100151020190C400520
Part No SW: 5QA 919 298 H HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0061
Serial number: 000150057319299
Coding: 0371061241
ASAM Dataset: EV_EPHVA2CAU3700000 009048
ROD: EV_EPHVA2CAU3700000.rod
VCID: 55F784FA158286D38C5-8000
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 2A00608B58FF8728749C814500408700000000000000000004
ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
VCID: 43D34AA2EB160863D21-8016
Part No SW: 3Q0 959 655 CM HW: 3Q0 959 655 CM
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z2PL6T394
Coding: 98CCC0C0000000005C5400CC008800000065
VCID: 0B43A28283C68023EA1-805E
Subsystem 1 - Part No SW: ----------- HW: 454 000 210 19
Serial number: 35700000000BC98D804.
Subsystem 2 - Part No SW: ----------- HW: 454 000 110 19
Serial number: 35800000000A041C604A
Subsystem 3 - Part No SW: ----------- HW: 454 800 210 19
Serial number: 351009203CA19000000C
Subsystem 4 - Part No SW: ----------- HW: 454 800 410 19
Serial number: 35200345BCA19000000M
Subsystem 5 - Part No SW: ----------- HW: 454 801 909 19
Serial number: 355005A97CB19000000Y
Part No SW: 5F0 920 790 B HW: 5F0 920 790 B
Component: KOMBI 504 4190
Coding: 24A40A022B800600018862011001000080000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_AU37.rod
VCID: 2809FD0E7270CB3BE73-807C
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 25101910802120
Coding: 030500F40F086A00E9000248080F00010001070000000000000000000000
Shop #: WSC 00033 790 00137
ROD: EV_GatewNF_AU37.rod
VCID: 70B9D56E8A20C3FB7F3-8024
Generator:
Component: 4-01-13-01-04
Subsystem 2 - Part No SW: 5F0 959 537 E HW: 5F0 959 537 E
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000I1522130919
Coding: 002000
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1051
Serial number: 758860030019101700E9
Part No SW: 5Q4 959 593 K HW: 5Q4 959 593 K
Component: TSG FS 007 0485
Serial number: 0000393337389
Coding: 00350220D001020000001000
VCID: 4DC76C9A3D52CE13345-8018
Subsystem 1 - Part No SW: 5Q0 959 408 A HW: 5Q0 959 164
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000035025223
Coding: 3D0000
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 83170000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C21315E96E8779B93B-8068
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 22101910520828
Coding: 000000070900064601000900000000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_003_SE37.rod
VCID: 372B2E72AFCE54C37E9-8062
Part No SW: 5Q4 959 592 K HW: 5Q4 959 592 K
Component: TSG BFS 007 0485
Serial number: 0000393117909
Coding: 00350020DE01020000001000
VCID: 4CC1619EC648C71B23B-8018
Subsystem 1 - Part No SW: 5Q0 959 407 A HW: 5Q0 959 163
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000034985870
Coding: 250000
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-STD2.clb
Part No SW: 5F0 035 877 HW: 5F0 035 877
Component: MU-S-ND-ER H50 0514
Serial number: SEZAZ2W0700328
Coding: 04230601D70A000011110101008808002F0101E601200400CE
Shop #: WSC 00033 790 00129
ASAM Dataset: EV_MUStd6C1TSAT 001015
ROD: EV_MUStd6C1TSAT_SK25.rod
VCID: 698FB80AA9FA323338D-803C
Subsystem 1 - Part No SW: 5FJ 919 605 B HW: 5FJ 919 605 B
Component: ABT_Std-2_Nav H31 8130
Serial number: SEZ6ZHW2972628
Component: ECE1 2021 --- 1520
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0544692868
Coding: 0100000202000000
VCID: 42DD4FA6F40C016BD97-8016
Address BB: Door Rear Drv
Address BC: Door Rear Pass
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AH HW: 7P5 941 591 A
Component: LED1L H07 0009
ROD: EV_LED_PLUS_L_KEBODAVW416.rod
VCID: 025D8FA6B48CC16B997-8056
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H07 0009
ROD: EV_LEDPLUSRightKEBODVW416.rod
End----(Elapsed Time: 01:37, VBatt start/end: 11.6V/11.5V. VIgn 11.5V)-----
Friday,09,April,2021,11:01:31:15623
VIN: VSSZZZ5FZL6530399 Mileage: 11298km-7020miles
Revision: B4H26---
Coding: 01190032033405092000
Revision: 00001K10
Air quality sensor:
Coding: 80007E
Coding: 0371061241
Generator:
Coding: 002000
Coding: 3D0000
Coding: 83170000
Coding: 250000
End----(Elapsed Time: 01:37, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
Saturday,10,April,2021,10:51:32:15623
VIN: License Plate: CY ORIGINAL ECU
Address 69: Trailer
Control Module Part Number: 5Q0 907 383 N
Component and/or Version: Anhaenger H27 0264
Software Coding: 0100000202000000
Work Shop Code: WSC 12345
Advanced Identification/FAZIT
Serial number: 0548834372
Identification: HLH-W42
Revision: 8A001003
Date: 23.06.20
Manufacturer number: P011
Test stand number: 2480
Flash Status
Programming Attempts(application): 1/0
Programming Attempts(data): 0/0/0
Successful Attempts(data): 0/0/0
Flash Date: 00.01.01
Flash Tool Code(data): 00000 000 00000
Misc.
Hardware number: 5Q0 907 383 N
Workshop System Name: J345
Equipment/PR Code: 000000000000000000000000
Dataset Number: -----------
Dataset Version: ----
ASAM Dataset Revision: 001008
VCDS Info:
Labels: 5Q0-907-383.clb
Saturday,10,April,2021,11:00:55:15623
VIN: VSSZZZ5FZL6530399 License Plate: CY NEW ECU
Address 69: Trailer
Work Shop Code: WSC 00000
Revision: 8A001003
Date: 16.03.20
Manufacturer number: P009
Test stand number: 0598
Flash Status
Misc.
VCDS Info:
If that was installed in the shown Autoscan, with the Serial number: 0544692868, it is not Parameterized!I was led to believe it was because the ecu was not Parameterized so ai have purchased a pre Parameterized one from car systems
Hi Maikel,Hi Glyn,
I think I have the same issue you have. The button from the towbar is not working.
My dataset number and version is also -------.
Are there numbers now, with your new parameterized module?
Thanks.
Maikel
Hi,Ok, clear. Thanks.
But your car was OE equipped with a towbar module, correct?
I think I have also already changed al the coding needed with VCDS. So only option should be parameterization.
I'm thinking of buying ODIS or VCP by myself and try to fix it, but it is a bit too expensive just to 'try out'. So I am still in doubt.
Otherwise I have to accept the price and pay for parameterization of the current module.
Since my towbar is pulled in I can not use it at all..
