Wednesday,07,April,2021,12:17:22:15623
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
VIN: VSSZZZ5FZL6530399 License Plate: CY69FFX
Mileage: 11297km-7019mi Repair Order: 07042021
Chassis Type: 5F-SE37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 42 44 4B 52 5F 69 BB BC D6 D7
VIN: VSSZZZ5FZL6530399 Mileage: 11297km-7019miles
Address 01: Engine (J623-DFFA) Labels: None
Part No SW: 04L 906 027 AB HW: 04L 907 309 P
Component: R4 2.0l TDI H26 9600
Revision: B4H26---
Coding: 01190032032405092000
Shop #: WSC 00033 790 00164
ASAM Dataset: EV_ECM20TDI01104L906027AB 004003
ROD: EV_ECM20TDI01104L906027AB.rod
VCID: 6B83C202A30620234A1-803E
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Q0 614 517 ER HW: 5Q0 614 517 BN
Component: ESC H35 0190
Revision: 00000000 Serial number: 62939000000759
Coding: 21EE8A9230230C6C077A060962CC2484510C30E0604624733060F078C0024B0B00002D641212131A1E35351919323200
Shop #: WSC 00033 790 00115
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 055794BAA5A2F653BC5-8050
Part No SW: 5F0 907 044 BE HW: 5F0 907 044 BE
Component: Climatronic H06 2201
Revision: 00001K10
Coding: 06100104200114011005000000101020
ASAM Dataset: EV_ACClimaBHBVW37X 006150
VCID: 6A8DC706ACFC392B317-803E
Air quality sensor:
Part No SW: 5Q0 937 084 DH HW: 5Q0 937 084 CG
Component: BCM MQBAB H H40 0312
Serial number: 01001928400395
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020_VW26.rod
VCID: 015F80AAB18ADA7380D-8054
Subsystem 1 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 23779542X81A955555A0
Coding: 80007E
Subsystem 2 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY191800GDP
Subsystem 3 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000674237
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 J HW: 5Q1 953 569 A
Component: Lenks.Modul H13 0170
Serial number: 0100151020190C400520
Part No SW: 5QA 919 298 H HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0061
Serial number: 000150057319299
Coding: 0371061241
ASAM Dataset: EV_EPHVA2CAU3700000 009048
ROD: EV_EPHVA2CAU3700000.rod
VCID: 55F784FA158286D38C5-8000
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 2A00608B58FF8728749C814500408700000000000000000004
ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
VCID: 43D34AA2EB160863D21-8016
Part No SW: 3Q0 959 655 CM HW: 3Q0 959 655 CM
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z2PL6T394
Coding: 98CCC0C0000000005C5400CC008800000065
VCID: 0B43A28283C68023EA1-805E
Subsystem 1 - Part No SW: ----------- HW: 454 000 210 19
Serial number: 35700000000BC98D804.
Subsystem 2 - Part No SW: ----------- HW: 454 000 110 19
Serial number: 35800000000A041C604A
Subsystem 3 - Part No SW: ----------- HW: 454 800 210 19
Serial number: 351009203CA19000000C
Subsystem 4 - Part No SW: ----------- HW: 454 800 410 19
Serial number: 35200345BCA19000000M
Subsystem 5 - Part No SW: ----------- HW: 454 801 909 19
Serial number: 355005A97CB19000000Y
Part No SW: 5F0 920 790 B HW: 5F0 920 790 B
Component: KOMBI 504 4190
Coding: 24A40A022B800600018862011001000080000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_AU37.rod
VCID: 2809FD0E7270CB3BE73-807C
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 25101910802120
Coding: 030500F40F086A00E9000248080F00010001070000000000000000000000
Shop #: WSC 00033 790 00137
ROD: EV_GatewNF_AU37.rod
VCID: 70B9D56E8A20C3FB7F3-8024
Generator:
Component: 4-01-13-01-04
Subsystem 2 - Part No SW: 5F0 959 537 E HW: 5F0 959 537 E
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000I1522130919
Coding: 002000
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1051
Serial number: 758860030019101700E9
Part No SW: 5Q4 959 593 K HW: 5Q4 959 593 K
Component: TSG FS 007 0485
Serial number: 0000393337389
Coding: 00350220D001020000001000
VCID: 4DC76C9A3D52CE13345-8018
Subsystem 1 - Part No SW: 5Q0 959 408 A HW: 5Q0 959 164
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000035025223
Coding: 3D0000
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 83170000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C21315E96E8779B93B-8068
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 22101910520828
Coding: 000000070900064601000900000000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_003_SE37.rod
VCID: 372B2E72AFCE54C37E9-8062
Part No SW: 5Q4 959 592 K HW: 5Q4 959 592 K
Component: TSG BFS 007 0485
Serial number: 0000393117909
Coding: 00350020DE01020000001000
VCID: 4CC1619EC648C71B23B-8018
Subsystem 1 - Part No SW: 5Q0 959 407 A HW: 5Q0 959 163
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000034985870
Coding: 250000
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-STD2.clb
Part No SW: 5F0 035 877 HW: 5F0 035 877
Component: MU-S-ND-ER H50 0514
Serial number: SEZAZ2W0700328
Coding: 04230601D70A000011110101008808002F0101E601200400CE
Shop #: WSC 00033 790 00129
ASAM Dataset: EV_MUStd6C1TSAT 001015
ROD: EV_MUStd6C1TSAT_SK25.rod
VCID: 698FB80AA9FA323338D-803C
Subsystem 1 - Part No SW: 5FJ 919 605 B HW: 5FJ 919 605 B
Component: ABT_Std-2_Nav H31 8130
Serial number: SEZ6ZHW2972628
Component: ECE1 2021 --- 1520
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0544692868
Coding: 0100000202000000
VCID: 42DD4FA6F40C016BD97-8016
Address BB: Door Rear Drv
Address BC: Door Rear Pass
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AH HW: 7P5 941 591 A
Component: LED1L H07 0009
ROD: EV_LED_PLUS_L_KEBODAVW416.rod
VCID: 025D8FA6B48CC16B997-8056
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H07 0009
ROD: EV_LEDPLUSRightKEBODVW416.rod
End----(Elapsed Time: 01:37, VBatt start/end: 11.6V/11.5V. VIgn 11.5V)-----
Friday,09,April,2021,11:01:31:15623
VIN: VSSZZZ5FZL6530399 Mileage: 11298km-7020miles
Revision: B4H26---
Coding: 01190032033405092000
Revision: 00001K10
Air quality sensor:
Coding: 80007E
Coding: 0371061241
Generator:
Coding: 002000
Coding: 3D0000
Coding: 83170000
Coding: 250000
End----(Elapsed Time: 01:37, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
Saturday,10,April,2021,10:51:32:15623
VIN: License Plate: CY ORIGINAL ECU
Address 69: Trailer
Control Module Part Number: 5Q0 907 383 N
Component and/or Version: Anhaenger H27 0264
Software Coding: 0100000202000000
Work Shop Code: WSC 12345
Advanced Identification/FAZIT
Serial number: 0548834372
Identification: HLH-W42
Revision: 8A001003
Date: 23.06.20
Manufacturer number: P011
Test stand number: 2480
Flash Status
Programming Attempts(application): 1/0
Programming Attempts(data): 0/0/0
Successful Attempts(data): 0/0/0
Flash Date: 00.01.01
Flash Tool Code(data): 00000 000 00000
Misc.
Hardware number: 5Q0 907 383 N
Workshop System Name: J345
Equipment/PR Code: 000000000000000000000000
Dataset Number: -----------
Dataset Version: ----
ASAM Dataset Revision: 001008
VCDS Info:
Labels: 5Q0-907-383.clb
Saturday,10,April,2021,11:00:55:15623
VIN: VSSZZZ5FZL6530399 License Plate: CY NEW ECU
Address 69: Trailer
Work Shop Code: WSC 00000
Revision: 8A001003
Date: 16.03.20
Manufacturer number: P009
Test stand number: 0598
Flash Status
Misc.
VCDS Info:
If that was installed in the shown Autoscan, with the Serial number: 0544692868, it is not Parameterized!I was led to believe it was because the ecu was not Parameterized so ai have purchased a pre Parameterized one from car systems
