VW Caddy no start.
PARFITTMOBILE
C?ID=276150
Hi all!
Little strange one on a 2011 VW Caddy today.
No start, instrument cluster dead, only lighting up when you open the door. Did an autoscan and although it show Engine OK and ABS OK, Airbag OK etc I can't communicate with them. In other modules such as the gateway (but not only this module), I try to delete the fault codes and it just says the module does not approve the request or words to that effect. There are some low voltage codes stored but I know the voltage is ok at the time of testing and the relevant controllers have good 12v but still no go. The vehicle has had some battery issues in the recent past. Any ideas?
VCDS Version: 21.3.0.0 (x64)
VIN:    License Plate: BD61MDK
Mileage: 214740km-133433mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
VIN: WV1ZZZ2KZCX066512   Mileage: 214740km-133433miles
42-Door Elect, Driver -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 1010
Address 01: Engine
Address 03: ABS Brakes
   Part No SW: 7N0 907 426 AT    HW: 7N0 907 426 AT
   Component: AC Manuell    H19 0304
   Revision: 00001016
   Coding: 0000004002
   Shop #: WSC 35110 790 50316
   VCID: 0604289AB97699BBF9-8052
9481748 - High Pressure Sensor
          B10AE 14 [009] - Open or Short to Ground
                    Reset counter: 125
                    Mileage: 214749 km
                    Date: 2021.03.30
                    Time: 00:00:09
          B10AB F0 [009] - Too Low
                    Reset counter: 232
                    Mileage: 189982 km
                    Date: 2018.11.22
                    Time: 14:01:32
13635840 - Supply voltage
                    Reset counter: 165
                    Mileage: 214746 km
                    Date: 2021.03.22
                    Time: 09:53:43
   Part No SW: 2K5 937 085     HW: 2K5 937 085
   Component: BCM PQ35 B+   011 1044
   Revision: BB011001
   Coding: 411A581A8025186B08800082900000640301728852028060648000000040
   Shop #: WSC 35110 377 00147
   VCID: 72EC644AADFE951BC5-8026
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 04101  26  0512
   Coding: 009795
18 Faults Found:
                    Fault Status: 00101011
                    Fault Frequency: 9
                    Reset counter: 165
                    Mileage: 214749 km
                    Date: 2015.08.14
                    Time: 00:15:06
                        Term 15 Off
                    Voltage: 12.40 V
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 165
                    Mileage: 214749 km
                    Date: 2015.08.21
                    Time: 00:00:05
                    Voltage: 12.20 V
                    Reset counter: 164
                    Mileage: 214746 km
                    Date: 2015.08.13
                    Time: 11:58:17
                        Term 15 Off
                    Voltage: 9.45 V
                    Fault Frequency: 18
                    Reset counter: 165
                    Mileage: 214746 km
                    Date: 2015.08.13
                    Time: 09:54:30
                    Voltage: 8.70 V
                    Reset counter: 164
                    Mileage: 214746 km
                    Date: 2015.08.13
                    Time: 09:55:34
                    Voltage: 8.25 V
                    Reset counter: 125
                    Mileage: 214749 km
                    Date: 2015.08.21
                    Time: 00:00:05
                    Voltage: 12.20 V
                    Fault Status: 01101000
                    Reset counter: 125
                    Mileage: 214749 km
                    Date: 2015.08.28
                    Time: 00:00:19
                    Voltage: 10.35 V
                    Reset counter: 165
                        Term 15 Off
                    Voltage: 12.40 V
                    Reset counter: 125
                    Mileage: 214749 km
                    Date: 2015.08.21
                    Time: 00:00:05
                    Voltage: 12.20 V
                    Fault Frequency: 87
                    Reset counter: 125
                    Mileage: 214749 km
                    Date: 2015.08.21
                    Time: 00:00:04
                    Voltage: 12.20 V
                    Reset counter: 125
                    Mileage: 214749 km
                    Date: 2015.08.21
                    Time: 00:00:04
                    Voltage: 12.20 V
                    Reset counter: 165
                    Mileage: 214749 km
                    Date: 2015.08.21
                    Time: 00:00:04
                        Term 15 Off
                    Voltage: 12.15 V
                    Reset counter: 165
                    Mileage: 214749 km
                    Date: 2015.08.22
                    Time: 00:35:15
                        Term 15 Off
                    Voltage: 12.15 V
01516 - Terminal 30; Left
                    Reset counter: 165
                    Mileage: 214749 km
                    Date: 2015.08.21
                    Time: 00:02:33
                        Term 15 Off
                    Voltage: 12.35 V
01800 - Light Switch (E1)
                    Reset counter: 165
                    Mileage: 214749 km
                    Date: 2015.08.14
                    Time: 00:15:06
                        Term 15 Off
                    Voltage: 12.40 V
02391 - Terminal 30 Reference
                    Reset counter: 165
                    Mileage: 214749 km
                    Date: 2015.08.14
                    Time: 00:10:06
                        Term 15 Off
                    Voltage: 12.35 V
                    Fault Status: 00101001
                    Reset counter: 165
                    Mileage: 214749 km
                    Date: 2015.08.14
                    Time: 00:15:06
                        Term 15 Off
                    Voltage: 12.40 V
                    Reset counter: 165
                    Mileage: 214749 km
                    Date: 2015.08.14
                    Time: 00:15:06
                        Term 15 Off
                    Voltage: 12.40 V
Address 15: Airbags
   Part No SW: 1K5 953 507 M    HW: 5K0 953 549
   Revision: --------    Serial number:  90440KJD001LO
   Coding: 0080060000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 3B72896EB2341453D6-806E
136194 - Supply voltage
                    Reset counter: 164
                    Mileage: 214746 km
                    Date: 2021.03.22
                    Time: 09:54:34
   Part No SW: 2K0 920 965 E    HW: 2K0 920 965 E
   Component: KOMBI         H03 0606
   Coding: 480001
   VCID: 316EAB466078EE037C-8064
                    Reset counter: 164
                    Mileage: 214746 km
                    Date: 2021.03.22
                    Time: 09:54:32
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 121011F2002286
   Coding: 357401
   VCID: 35669F569C10C22320-8060
                    Fault Status: 00110100
                    Reset counter: 165
                    Mileage: 214749 km
                    Date: 2015.08.21
                    Time: 00:00:02
                    Reset counter: 165
                    Mileage: 214749 km
                    Date: 2015.08.22
                    Time: 00:35:12
00469 - Infotainment Databus in Single Wire Operation
                    Reset counter: 165
                    Mileage: 214749 km
                    Date: 2015.08.21
                    Time: 00:03:48
                    Reset counter: 164
                    Mileage: 214746 km
                    Date: 2015.08.13
                    Time: 09:55:33
   Component: IMMO          H03 0606
   VCID: 6ADC7C2A8D2E5DDB7D-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0000560
   VCID: 4898E6A23BE24FCB4B-801C
Address 44: Steering Assist
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000560
   VCID: 479AE59E36FC40B342-8012
   Part No SW: 5K0 035 156 A    HW: 5K0 035 156 A
   Component: Radio         H42 0105
   Revision: R0000000    Serial number: VWZAZ1L2131110
   Coding: 0500020001
   VCID: 25464F162CB0B2A390-8070
00625 - Vehicle Speed Signal
                    Fault Status: 01110100
                    Reset counter: 125
                    Mileage: 214749 km
                    Date: 2015.08.21
                    Time: 00:00:07
                    Reset counter: 165
                    Mileage: 214749 km
                    Date: 2015.08.21
                    Time: 00:10:03
                    Reset counter: 165
                    Mileage: 214746 km
                    Date: 2015.08.13
                    Time: 09:55:38
End-------------------------(Elapsed Time: 02:08)--------------------------
Jef
HQ
First verify battery and battery cables are to factory design... no crappy battery with rotted cables and loose clamps.
Lets poke sticks at the airbag module since it is off line... it get powered by fuse SC15. Fuse SC15 gets powered by the terminal 15 J329 relay. To that end, when you turn the ignition on, does fuse SC15 have power? If not, locate and inspect J329 relay.
