2014 Q5 Tweaks - Windows and Drive Select - Doesn't work the same as S4
Jackp311
C?ID=168364
Hi there!
There are a few tweaks I am trying to implement on the Q5 that I have on the S4. But, they don't seem to be working correctly.
The most notable is the comfort window operation. In module 46, using the long coding helper to adjust byte 16, I enabled keyless access, remote, and left the door lock enabled for comfort operation. Yet the feature does not work and I do not see the requisite menu listed in the MMI that is used to turn on and off the various areas to be controlled by the comfort operation.
The other large item is the setting of the default drive select mode. Any other insight to doing this with the Q5? The stock values: 63=0, 64=218, 65=0, 66=15. I changed 66 to 47 and got the efficiency program listed in the MMI. Seems kind of neat but haven't played with it much.
Any ideas?
United States
Hello Jack,
Are you sure Adaptation Channels 001, 002, 003, 004, 061 and 062 aren't available in that BCM for the comfort window operation?
Audi A4/S4/A5/S5 (8K/8T) Tweaks
-Dana
Jackp311
C?ID=168364
Thanks Dana - Unfortunately - this did not work wither. Most of those channels are NA. The one I did see had a value of 100 and no pop up balloon. The other that came up had a tie in to the known channels bar that read turn signal dimming. (Disable the winking DRL)
United States
OK Jack. Type #2 PLA and PLB Control module maps from the 09 controller would be helpful at some point so we can see which Adaptation channels and/or Measuring Block values changed. Control Module Maps
If you send the maps via email please include a scan.
Thanks,
Jackp311
C?ID=168364
The autoscan and the PLA and PLB logs can be found here:
http://www.filedropper.com/logs
EDIT: FYI - Just click on the link that says download this file. The link that references a file opener is spam.
Jack, since those files are plain text, we'd prefer people to just post 'em here, like this:
Friday,21,March,2014,22:00:39:61963
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WA1DMAFP4EA087493   License Plate:
Mileage: 230km-142mi   Repair Order:
Chassis Type: FP (8R0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 36 42 44 46 47 52 53 56 5F
          62 6C 6D 72 AC
VIN: WA1DMAFP4EA087493   Mileage: 230km/142miles
Address 01: Engine (J623-CPNB)       Labels: None
   Part No SW: 8K5 907 401 J    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  H14 0003
   Revision: 58H14---
   Coding: 2A2A4012052603050000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TDI0118K5907401J 001004
   ROD: EV_ECM30TDI0118K5907401J.rod
   VCID: 377DE9A48EBF8FA66AD-8062
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 8R0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H16 1003
   Revision: --H16---
   ROD: EV_TCMAL551211_AU48.rod
   VCID: 4B95A554E2371B463E5-801E
   Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
   Component: ESP8 quattro  H09 0020
   Coding: 231D1C03
   Shop #: WSC 06335 000 00000
   VCID: 9129F73C489BF196849-80C4
   Part No SW: 8K0 907 064 JP    HW: 8K0 907 064 JP
   Component: BCM2 2.0      H14 0650
   Coding: 0DA54040000000000000
   VCID: 871DD96436DFBF265AD-80D2
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01010220140268
   Coding: 3621228080
   VCID: 3979EF9CB0AB99D69C9-806C
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000060543401
   Coding: 26000091803CAFE00901408300003D0D0F9CC708A6090221000008004000070100000034000000
   Shop #: WSC 06335 123 12345
   VCID: 78FF2A98CB2140DEA37-802D
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 140120  H11 0050
   Coding: 01DD13
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Component: USHL4.2  H30 0030
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8R0 907 364 C    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H09 0054
   Revision: 00000000    Serial number: 14011400930001
   Coding: 010181
   VCID: 3A7BF090B5AD92CE953-806F
Address 15: Airbags (J234)       Labels: 8R0-959-655.clb
   Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003GPDB0WNF9
   Coding: 303634313432303030304A55304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 479D9964FE5FFF261AD-8012
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R140000H6U2
   Serial number: 6334MSME410D3769G
   Serial number: 6344MSME41085739B
   Serial number: 6352QSME5A3A5662O
   Serial number: 6362QSME3C3C0B42P
   Serial number: 63732SME753A307A1
   Crash sensor for front airbag; passenger side:
   Serial number: 63832SME753A1B40+
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NB20019A
   Coding: 000037
   VCID: 489F9A58FB41F05E137-801D
Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 982 A    HW: 8R0 920 982 A
   Component: KOMBIINSTR.   H35 0564
   Revision: 00100000    Serial number: ZD6371W1F
   Coding: 8BBF22001301D705020000
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0060
   Revision: 1Y080030    Serial number: 3041Y14120053E
   Coding: 80CF07FF00
   VCID: 4A9BA050E54D024E053-801F
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 43
                    Mileage: 39 km
                    Date: 2014.03.17
                    Time: 23:00:48
                    Bin. Bits:    10000
                    Voltage: 12.20 V
                    Count: 9
                    Bin. Bits:    00000
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0076
   Revision: AA000000    Serial number: 00000088137492
   Coding: 01581B00000000000000
   VCID: 428B8870DD7DDA0ECD3-8017
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000088923873
   Coding: 011D13205E00440004
   VCID: 4FADB1441E2F276652D-801A
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 8R0 909 144 G    HW: 8R0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0018228498
   Coding: 100000010001
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X.rod
   VCID: 3C77F688B799ACFE87F-8069
   Revision: 00002001    Serial number: 0324985440
   Coding: 01260E3A20FA709584A0053600040047
   Shop #: WSC 06334 123 12345
   Component: GTO BF  H01 0080
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Revision: 00005001    Serial number: 94813024926404
   VCID: 2D51CBCC74E33576001-8078
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000089572031
   VCID: 4E93AC4019252E6E59B-801B
Address 53: Parking Brake (----)       Labels: None
   Component: EPB-4         H01 0005
   Revision: --------    Serial number: 30000000160843
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7BF090BDAD92CE953-806F
   Revision: AB001007    Serial number: 156A+0E7960475
   Coding: 020007010000000001
   VCID: 24472EE82729F43EDFF-8071
   Part No SW: 8R1 035 746 E    HW: 8R1 035 746 D
   Component: H-BNT-NA      H41 0756
   Revision: --------    Serial number: 204BX0E7637714
   Coding: 160200060005E1EF45828F5E00000403140000000000000000
   Subsystem 1 - Part No: 8R0 060 884 BL
   Component: NAR 2014  0902
   Component: DU7 High  H42 0104
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Component: CD-Database  5571
02067 - Optical Databus; Unpermitted Wake-Up Request
                    Reset counter: 43
                    Mileage: 39 km
                    Date: 2014.03.17
                    Time: 22:59:52
                    Voltage: 12.40 V
                    Reset counter: 11
                    Mileage: 236 km
                    Date: 2014.03.21
                    Time: 21:21:27
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000100
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000088664962
   Coding: 010C13204000240004
   VCID: 46839460F155E62EE1B-8013
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-J3XA5FY
   Coding: 1020010
   VCID: 3467DEA857C964BE4FF-8061
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H53 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D71FB8CA483A5F6B01-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H53 0330
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000088665016
Address AC: Reductant Control (J880)       Labels: None
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H09 0010
   Revision: 00000000    Serial number: 140140911
   ROD: EV_RDCMA00100.rod
   VCID: 2B55C5D442F73B461E5-807E
;SW:8K0-907-063-DH   HW:8K0-907-063-DH ---  Cent. Elect.
;Component:BCM1 1.0      H16 0103, Coding:26000091803CAFE00901408300003D0D0F9CC708A6090221000008004000070100000034000000
;Wednesday,16,April,2014,20:11:34:61963
;VCDS Version: Release 12.12.2  Data version: 20140212
;VCID: 78FF2A98CB2140DEA37-802D
A01,0,
;100
A01,1,
A01,2,
A01,3,
A01,4,
;02 N/A
A03,0,
;64
A03,1,
A03,2,
A03,3,
A03,4,
;04 N/A
;05 N/A
A06,0,
;550
A06,1,
;OFF
A06,2,
;N/A
A06,3,
;N/A
A06,4,
;N/A
A07,0,
;1000
A07,1,
;OFF
A07,2,
;N/A
A07,3,
;N/A
A07,4,
;N/A
;08 N/A
;09 N/A
;10 N/A
;11 N/A
A12,0,
;120
A12,1,
;N/A
A12,2,
;N/A
A12,3,
;N/A
A12,4,
;N/A
A13,0,
;60
A13,1,
;N/A
A13,2,
;N/A
A13,3,
;N/A
A13,4,
;N/A
A14,0,
;15
A14,1,
;N/A
A14,2,
;N/A
A14,3,
;N/A
A14,4,
;N/A
;15 N/A
A16,0,
;3
A16,1,
;N/A
A16,2,
;N/A
A16,3,
;N/A
A16,4,
;N/A
A17,0,
;15
A17,1,
;N/A
A17,2,
;N/A
A17,3,
;N/A
A17,4,
;N/A
A18,0,
;255
A18,1,
;N/A
A18,2,
;N/A
A18,3,
;N/A
A18,4,
;N/A
A19,0,
;1
A19,1,
;N/A
A19,2,
;N/A
A19,3,
;N/A
A19,4,
;N/A
A20,0,
;0
A20,1,
;N/A
A20,2,
;N/A
A20,3,
;N/A
A20,4,
;N/A
A21,0,
;1
A21,1,
;N/A
A21,2,
;N/A
A21,3,
;N/A
A21,4,
;N/A
A22,0,
;1
A22,1,
;N/A
A22,2,
;N/A
A22,3,
;N/A
A22,4,
;N/A
A23,0,
;1
A23,1,
;N/A
A23,2,
;N/A
A23,3,
;N/A
A23,4,
;N/A
A24,0,
;1
A24,1,
;N/A
A24,2,
;N/A
A24,3,
;N/A
A24,4,
;N/A
A25,0,
;8000
A25,1,
;N/A
A25,2,
;N/A
A25,3,
;N/A
A25,4,
;N/A
A26,0,
;8
A26,1,
;N/A
A26,2,
;N/A
A26,3,
;N/A
A26,4,
;N/A
;27 N/A
;28 N/A
;29 N/A
;30 N/A
;31 N/A
;32 N/A
;33 N/A
A34,0,
;60
A34,1,
;N/A
A34,2,
;N/A
A34,3,
;N/A
A34,4,
;N/A
A35,0,
;0
A35,1,
;N/A
A35,2,
;N/A
A35,3,
;N/A
A35,4,
;N/A
;36 N/A
A37,0,
;3
A37,1,
;N/A
A37,2,
;N/A
A37,3,
;N/A
A37,4,
;N/A
A38,0,
;1000
A38,1,
;N/A
A38,2,
;N/A
A38,3,
;N/A
A38,4,
;N/A
A39,0,
;550
A39,1,
;N/A
A39,2,
;N/A
A39,3,
;N/A
A39,4,
;N/A
A40,0,
;117
A40,1,
;32.5°C
A40,2,
;OFF
A40,3,
;N/A
A40,4,
;N/A
A41,0,
;1
A41,1,
;N/A
A41,2,
;N/A
A41,3,
;N/A
A41,4,
;N/A
A42,0,
;1
A42,1,
;N/A
A42,2,
;N/A
A42,3,
;N/A
A42,4,
;N/A
A43,0,
;20
A43,1,
;N/A
A43,2,
;N/A
A43,3,
;N/A
A43,4,
;N/A
A44,0,
;1
A44,1,
;N/A
A44,2,
;N/A
A44,3,
;N/A
A44,4,
;N/A
A45,0,
;0
A45,1,
;N/A
A45,2,
;N/A
A45,3,
;N/A
A45,4,
;N/A
A46,0,
;1
A46,1,
;N/A
A46,2,
;N/A
A46,3,
;N/A
A46,4,
;N/A
A47,0,
;1
A47,1,
;N/A
A47,2,
;N/A
A47,3,
;N/A
A47,4,
;N/A
A48,0,
;120
A48,1,
;N/A
A48,2,
;N/A
A48,3,
;N/A
A48,4,
;N/A
A49,0,
;120
A49,1,
;N/A
A49,2,
;N/A
A49,3,
;N/A
A49,4,
;N/A
A50,0,
;120
A50,1,
;N/A
A50,2,
;N/A
A50,3,
;N/A
A50,4,
;N/A
A51,0,
;120
A51,1,
;N/A
A51,2,
;N/A
A51,3,
;N/A
A51,4,
;N/A
A52,0,
;120
A52,1,
;N/A
A52,2,
;N/A
A52,3,
;N/A
A52,4,
;N/A
A53,0,
;0
A53,1,
;N/A
A53,2,
;N/A
A53,3,
;N/A
A53,4,
;N/A
;54 N/A
A55,0,
;1
A55,1,
;N/A
A55,2,
;N/A
A55,3,
;N/A
A55,4,
;N/A
A56,0,
;1
A56,1,
;N/A
A56,2,
;N/A
A56,3,
;N/A
A56,4,
;N/A
A57,0,
;0
A57,1,
;N/A
A57,2,
;N/A
A57,3,
;N/A
A57,4,
;N/A
A58,0,
;1
A58,1,
;N/A
A58,2,
;N/A
A58,3,
;N/A
A58,4,
;N/A
A59,0,
;60
A59,1,
;N/A
A59,2,
;N/A
A59,3,
;N/A
A59,4,
;N/A
A60,0,
;1
A60,1,
;N/A
A60,2,
;N/A
A60,3,
;N/A
A60,4,
;N/A
;61 N/A
;62 N/A
A63,0,
;0
A63,1,
;N/A
A63,2,
;N/A
A63,3,
;N/A
A63,4,
;N/A
A64,0,
;218
A64,1,
;N/A
A64,2,
;N/A
A64,3,
;N/A
A64,4,
;N/A
A65,0,
;0
A65,1,
;N/A
A65,2,
;N/A
A65,3,
;N/A
A65,4,
;N/A
A66,0,
;47
A66,1,
;N/A
A66,2,
;N/A
A66,3,
;N/A
A66,4,
;N/A
A67,0,
;2
A67,1,
;N/A
A67,2,
;N/A
A67,3,
;N/A
A67,4,
;N/A
A68,0,
;2
A68,1,
;N/A
A68,2,
;N/A
A68,3,
;N/A
A68,4,
;N/A
A69,0,
;600
A69,1,
;N/A
A69,2,
;N/A
A69,3,
;N/A
A69,4,
;N/A
A70,0,
;14
A70,1,
;N/A
A70,2,
;N/A
A70,3,
;N/A
A70,4,
;N/A
A71,0,
;15015
A71,1,
;N/A
A71,2,
;N/A
A71,3,
;N/A
A71,4,
;N/A
A72,0,
;3003
A72,1,
;N/A
A72,2,
;N/A
A72,3,
;N/A
A72,4,
;N/A
A73,0,
;2639
A73,1,
;N/A
A73,2,
;N/A
A73,3,
;N/A
A73,4,
;N/A
A74,0,
;2093
A74,1,
;N/A
A74,2,
;N/A
A74,3,
;N/A
A74,4,
;N/A
A75,0,
;2548
A75,1,
;N/A
A75,2,
;N/A
A75,3,
;N/A
A75,4,
;N/A
A76,0,
;8450
A76,1,
;N/A
A76,2,
;N/A
A76,3,
;N/A
A76,4,
;N/A
A77,0,
;42
A77,1,
;N/A
A77,2,
;N/A
A77,3,
;N/A
A77,4,
;N/A
A78,0,
;16426
A78,1,
;N/A
A78,2,
;N/A
A78,3,
;N/A
A78,4,
;N/A
A79,0,
;11568
A79,1,
;N/A
A79,2,
;N/A
A79,3,
;N/A
A79,4,
;N/A
A80,0,
;13368
A80,1,
;N/A
A80,2,
;N/A
A80,3,
;N/A
A80,4,
;N/A
A81,0,
;15424
A81,1,
;N/A
A81,2,
;N/A
A81,3,
;N/A
A81,4,
;N/A
;82 N/A
;83 N/A
;84 N/A
;85 N/A
;86 N/A
;87 N/A
;88 N/A
;89 N/A
;90 N/A
;91 N/A
;92 N/A
;93 N/A
;94 N/A
;95 N/A
;96 N/A
;97 N/A
;98 N/A
;99 N/A
A100,0,
;26
A100,1,
;N/A
A100,2,
;N/A
A100,3,
;N/A
A100,4,
;N/A
A101,0,
;28
A101,1,
;N/A
A101,2,
;N/A
A101,3,
;N/A
A101,4,
;N/A
A102,0,
;36
A102,1,
;N/A
A102,2,
;N/A
A102,3,
;N/A
A102,4,
;N/A
A103,0,
;38
A103,1,
;N/A
A103,2,
;N/A
A103,3,
;N/A
A103,4,
;N/A
A104,0,
;46
A104,1,
;N/A
A104,2,
;N/A
A104,3,
;N/A
A104,4,
;N/A
A105,0,
;48
A105,1,
;N/A
A105,2,
;N/A
A105,3,
;N/A
A105,4,
;N/A
A106,0,
;66
A106,1,
;N/A
A106,2,
;N/A
A106,3,
;N/A
A106,4,
;N/A
A107,0,
;68
A107,1,
;N/A
A107,2,
;N/A
A107,3,
;N/A
A107,4,
;N/A
A108,0,
;86
A108,1,
;N/A
A108,2,
;N/A
A108,3,
;N/A
A108,4,
;N/A
A109,0,
;88
A109,1,
;N/A
A109,2,
;N/A
A109,3,
;N/A
A109,4,
;N/A
A110,0,
;110
A110,1,
;N/A
A110,2,
;N/A
A110,3,
;N/A
A110,4,
;N/A
A111,0,
;112
A111,1,
;N/A
A111,2,
;N/A
A111,3,
;N/A
A111,4,
;N/A
;112 N/A
;113 N/A
;114 N/A
;115 N/A
;116 N/A
;117 N/A
;118 N/A
;119 N/A
;120 N/A
A121,0,
;10
A121,1,
;N/A
A121,2,
;N/A
A121,3,
;N/A
A121,4,
;N/A
A122,0,
;13
A122,1,
;N/A
A122,2,
;N/A
A122,3,
;N/A
A122,4,
;N/A
A123,0,
;6
A123,1,
;N/A
A123,2,
;N/A
A123,3,
;N/A
A123,4,
;N/A
A124,0,
;20
A124,1,
;N/A
A124,2,
;N/A
A124,3,
;N/A
A124,4,
;N/A
A125,0,
;0
A125,1,
;N/A
A125,2,
;N/A
A125,3,
;N/A
A125,4,
;N/A
A126,0,
;200
A126,1,
;N/A
A126,2,
;N/A
A126,3,
;N/A
A126,4,
;N/A
A127,0,
;0
A127,1,
;N/A
A127,2,
;N/A
A127,3,
;N/A
A127,4,
;N/A
A128,0,
;30
A128,1,
;N/A
A128,2,
;N/A
A128,3,
;N/A
A128,4,
;N/A
;129 N/A
;130 N/A
;131 N/A
;132 N/A
;133 N/A
;134 N/A
;135 N/A
;136 N/A
;137 N/A
;138 N/A
;139 N/A
;140 N/A
;141 N/A
;142 N/A
;143 N/A
;144 N/A
;145 N/A
;146 N/A
;147 N/A
;148 N/A
;149 N/A
;150 N/A
;151 N/A
;152 N/A
;153 N/A
;154 N/A
;155 N/A
;156 N/A
;157 N/A
;158 N/A
;159 N/A
;160 N/A
;161 N/A
;162 N/A
;163 N/A
;164 N/A
;165 N/A
;166 N/A
;167 N/A
;168 N/A
;169 N/A
;170 N/A
;171 N/A
;172 N/A
;173 N/A
;174 N/A
;175 N/A
;176 N/A
;177 N/A
;178 N/A
;179 N/A
;180 N/A
;181 N/A
;182 N/A
;183 N/A
;184 N/A
;185 N/A
;186 N/A
;187 N/A
;188 N/A
;189 N/A
A190,0,
;0
A190,1,
;N/A
A190,2,
;N/A
A190,3,
;N/A
A190,4,
;N/A
A191,0,
;0
A191,1,
;N/A
A191,2,
;N/A
A191,3,
;N/A
A191,4,
;N/A
A192,0,
;0
A192,1,
;N/A
A192,2,
;N/A
A192,3,
;N/A
A192,4,
;N/A
A193,0,
A193,1,
;ERROR:
A193,2,
;Security
A193,3,
;access
A193,4,
;required
A194,0,
A194,1,
;ERROR:
A194,2,
;Security
A194,3,
;access
A194,4,
;required
A195,0,
A195,1,
;ERROR:
A195,2,
;Security
A195,3,
;access
A195,4,
;required
A196,0,
A196,1,
;ERROR:
A196,2,
;Security
A196,3,
;access
A196,4,
;required
A197,0,
A197,1,
;ERROR:
A197,2,
;Security
A197,3,
;access
A197,4,
;required
A198,0,
A198,1,
;ERROR:
A198,2,
;Security
A198,3,
;access
A198,4,
;required
A199,0,
;0
A199,1,
;N/A
A199,2,
;N/A
A199,3,
;N/A
A199,4,
;N/A
;200 N/A
A201,0,
A201,1,
;ERROR:
A201,2,
;Security
A201,3,
;access
A201,4,
;required
A202,0,
A202,1,
;ERROR:
A202,2,
;Security
A202,3,
;access
A202,4,
;required
A203,0,
A203,1,
;ERROR:
A203,2,
;Security
A203,3,
;access
A203,4,
;required
A204,0,
A204,1,
;ERROR:
A204,2,
;Security
A204,3,
;access
A204,4,
;required
A205,0,
;1
A205,1,
;N/A
A205,2,
;N/A
A205,3,
;N/A
A205,4,
;N/A
A206,0,
;1
A206,1,
;not available
A206,2,
;not available
A206,3,
;N/A
A206,4,
;N/A
A207,0,
;0
A207,1,
;N/A
A207,2,
;N/A
A207,3,
;N/A
A207,4,
;N/A
A208,0,
;1
A208,1,
;N/A
A208,2,
;N/A
A208,3,
;N/A
A208,4,
;N/A
A209,0,
;1
A209,1,
;N/A
A209,2,
;N/A
A209,3,
;N/A
A209,4,
;N/A
A210,0,
;1
A210,1,
;not available
A210,2,
;N/A
A210,3,
;N/A
A210,4,
;N/A
A211,0,
;1
A211,1,
;not available
A211,2,
;N/A
A211,3,
;N/A
A211,4,
;N/A
A212,0,
;1
A212,1,
;not available
A212,2,
;N/A
A212,3,
;N/A
A212,4,
;N/A
A213,0,
;1
A213,1,
;not available
A213,2,
;N/A
A213,3,
;N/A
A213,4,
;N/A
A214,0,
;1
A214,1,
;not available
A214,2,
;N/A
A214,3,
;N/A
A214,4,
;N/A
A215,0,
A215,1,
;ERROR:
A215,2,
;Security
A215,3,
;access
A215,4,
;required
;216 N/A
A217,0,
A217,1,
;ERROR:
A217,2,
;Security
A217,3,
;access
A217,4,
;required
;218 N/A
A219,0,
A219,1,
;ERROR:
A219,2,
;Security
A219,3,
;access
A219,4,
;required
A220,0,
;0
A220,1,
;N/A
A220,2,
;N/A
A220,3,
;N/A
A220,4,
;N/A
A221,0,
;0
A221,1,
;N/A
A221,2,
;N/A
A221,3,
;N/A
A221,4,
;N/A
A222,0,
;150
A222,1,
;N/A
A222,2,
;N/A
A222,3,
;N/A
A222,4,
;N/A
A223,0,
;197
A223,1,
;N/A
A223,2,
;N/A
A223,3,
;N/A
A223,4,
;N/A
A224,0,
;1
A224,1,
;N/A
A224,2,
;N/A
A224,3,
;N/A
A224,4,
;N/A
A225,0,
;20
A225,1,
;N/A
A225,2,
;N/A
A225,3,
;N/A
A225,4,
;N/A
A226,0,
;4
A226,1,
;N/A
A226,2,
;N/A
A226,3,
;N/A
A226,4,
;N/A
A227,0,
;1
A227,1,
;N/A
A227,2,
;N/A
A227,3,
;N/A
A227,4,
;N/A
A228,0,
;2
A228,1,
;N/A
A228,2,
;N/A
A228,3,
;N/A
A228,4,
;N/A
A229,0,
;4
A229,1,
;N/A
A229,2,
;N/A
A229,3,
;N/A
A229,4,
;N/A
A230,0,
;4
A230,1,
;N/A
A230,2,
;N/A
A230,3,
;N/A
A230,4,
;N/A
A231,0,
;4
A231,1,
;N/A
A231,2,
;N/A
A231,3,
;N/A
A231,4,
;N/A
A232,0,
;6
A232,1,
;N/A
A232,2,
;N/A
A232,3,
;N/A
A232,4,
;N/A
A233,0,
;10
A233,1,
;N/A
A233,2,
;N/A
A233,3,
;N/A
A233,4,
;N/A
A234,0,
;27
A234,1,
;N/A
A234,2,
;N/A
A234,3,
;N/A
A234,4,
;N/A
A235,0,
;0
A235,1,
;N/A
A235,2,
;N/A
A235,3,
;N/A
A235,4,
;N/A
A236,0,
;0
A236,1,
;N/A
A236,2,
;N/A
A236,3,
;N/A
A236,4,
;N/A
A237,0,
A237,1,
;ERROR:
A237,2,
;Security
A237,3,
;access
A237,4,
;required
A238,0,
A238,1,
;ERROR:
A238,2,
;Security
A238,3,
;access
A238,4,
;required
A239,0,
A239,1,
;ERROR:
A239,2,
;Security
A239,3,
;access
A239,4,
;required
A240,0,
A240,1,
;ERROR:
A240,2,
;Security
A240,3,
;access
A240,4,
;required
A241,0,
A241,1,
;ERROR:
A241,2,
;Security
A241,3,
;access
A241,4,
;required
A242,0,
A242,1,
;ERROR:
A242,2,
;Security
A242,3,
;access
A242,4,
;required
A243,0,
A243,1,
;ERROR:
A243,2,
;Security
A243,3,
;access
A243,4,
;required
;244 N/A
;245 N/A
;246 N/A
;247 N/A
;248 N/A
;249 N/A
A250,0,
A250,1,
;ERROR:
A250,2,
;Security
A250,3,
;access
A250,4,
;required
;251 N/A
;252 N/A
;253 N/A
A254,0,
A254,1,
;ERROR:
A254,2,
;Security
A254,3,
;access
A254,4,
;required
A255,0,
A255,1,
;ERROR:
A255,2,
;Security
A255,3,
;access
A255,4,
;required
;Wednesday,16,April,2014,20:10:39:61963
1,0,,
1,1,,,
;11.90 V,,
1,2,,,
;12.00 V,,
1,3,,,
1,4,,,
2,0,,
2,1,,,
;12.00 V,,
2,2,,,
;11.90 V,,
2,3,,,
;12.00 V,,
2,4,,,
3,0,,
3,1,,,
;Inactive,,
3,2,,,
;Inactive,,
3,3,,,
;Inactive,,
3,4,,,
;N/A,,
4,0,,
4,1,,,
;ON,,
4,2,,,
;ON,,
4,3,,,
;ON,,
4,4,,,
;7.20 V,,
5,0,,
5,1,,,
;100.0 %,,
5,2,,,
5,3,,,
5,4,,,
6,0,,
6,1,,,
;Not Oper.,,
6,2,,,
;0.0,,
6,3,,,
;0.0,,
6,4,,,
7,0,,
7,1,,,
;center,,
7,2,,,
;2.0,,
7,3,,,
;Not Oper.,,
7,4,,,
;Not Oper.,,
8,0,,
8,1,,,
;100.0 %,,
8,2,,,
8,3,,,
;Not Oper.,,
8,4,,,
;2.0,,
9,0,,
9,1,,,
;100.0 %,,
9,2,,,
;100.0 %,,
9,3,,,
;100.0 %,,
9,4,,,
;100.0 %,,
10,0,,
10,1,,,
10,2,,,
10,3,,,
10,4,,,
11,0,,
11,1,,,
;OFF,,
11,2,,,
;OFF,,
11,3,,,
;0.0 %,,
11,4,,,
;0.0 %,,
12,0,,
12,1,,,
;100.0 %,,
12,2,,,
;100.0 %,,
12,3,,,
;157.0,,
12,4,,,
;23.0,,
13,0,,
13,1,,,
;OFF,,
13,2,,,
;Not Oper.,,
13,3,,,
;0.0 %,,
13,4,,,
;0.0 %,,
14,0,,
14,1,,,
;64.0 %,,
14,2,,,
;64.0 %,,
14,3,,,
14,4,,,
15,0,,
15,1,,,
;OFF,,
15,2,,,
15,3,,,
15,4,,,
16,0,,
16,1,,,
;100.0 %,,
16,2,,,
;100.0 %,,
16,3,,,
;100.0 %,,
16,4,,,
;19.0 %,,
17,0,,
17,1,,,
17,2,,,
17,3,,,
17,4,,,
18,0,,
18,1,,,
;Stage Int.,,
18,2,,,
;0x0001,,
18,3,,,
;0.000 A,,
18,4,,,
19,0,,
19,1,,,
;OFF,,
19,2,,,
;0.0,,
19,3,,,
;Reached,,
19,4,,,
;OFF,,
20,0,,
20,1,,,
;ON,,
20,2,,,
;ON,,
20,3,,,
;0.00 km/h,,
20,4,,,
;Closed,,
21,0,,
21,1,,,
;0.0 %,,
21,2,,,
;ON,,
21,3,,,
;Inactive,,
21,4,,,
22,0,,
22,1,,,
;OFF,,
22,2,,,
;Inactive,,
22,3,,,
;0.0,,
22,4,,,
;3.0,,
23,0,,
23,1,,,
;9.85 bar,,
23,2,,,
23,3,,,
;0x0042,,
23,4,,,
;0x0002,,
24,0,,
24,1,,,
24,2,,,
;0x0005,,
24,3,,,
;Not Oper.,,
24,4,,,
;14.0,,
25,0,,
25,1,,,
;Not Oper.,,
25,2,,,
;OFF,,
25,3,,,
25,4,,,
26,0,,
26,1,,,
;0.0,,
26,2,,,
;Not Oper.,,
26,3,,,
26,4,,,
;Not Oper.,,
27,0,,
27,1,,,
27,2,,,
;0x0002,,
27,3,,,
;Activated,,
27,4,,,
;Full,,
28,0,,
28,1,,,
;Full,,
28,2,,,
;Not Oper.,,
28,3,,,
;Inactive,,
28,4,,,
;Inactive,,
29,0,,
29,1,,,
;32.5°C,,
29,2,,,
29,3,,,
29,4,,,
30,0,,
30,1,,,
;Not Oper.,,
30,2,,,
;ON,,
30,3,,,
30,4,,,
31,0,,
31,1,,,
;Closed,,
31,2,,,
31,3,,,
31,4,,,
32,0,,
32,1,,,
;Inactive,,
32,2,,,
;Inactive,,
32,3,,,
32,4,,,
33,0,,
33,1,,,
33,2,,,
;0.0 %,,
33,3,,,
;0.0 %,,
33,4,,,
34,0,,
34,1,,,
;OFF,,
34,2,,,
;0.0 mA,,
34,3,,,
;0.0 %,,
34,4,,,
37,0,,
37,1,,,
;OFF,,
37,2,,,
;0.000 A,,
37,3,,,
;0.000 A,,
37,4,,,
40,0,,
40,1,,,
40,2,,,
40,3,,,
40,4,,,
41,0,,
41,1,,,
;2.0,,
41,2,,,
;Not Oper.,,
41,3,,,
;43.0 %,,
41,4,,,
;0.0 %,,
42,0,,
42,1,,,
;58h,,
43,0,,
43,1,,,
;6.0 %,,
43,2,,,
;3.0 %,,
43,3,,,
;43.0 %,,
43,4,,,
;5.0 %,,
44,0,,
44,1,,,
44,2,,,
44,3,,,
44,4,,,
45,0,,
45,1,,,
;0.0,,
45,2,,,
;0.00 km/h,,
45,3,,,
;12.5°,,
45,4,,,
46,0,,
46,1,,,
46,2,,,
46,3,,,
46,4,,,
47,0,,
47,1,,,
47,2,,,
47,3,,,
47,4,,,
48,0,,
48,1,,,
;0.0,,
48,2,,,
;0.0,,
48,3,,,
;0.0,,
48,4,,,
;0.0,,
49,0,,
49,1,,,
;0103,,
50,0,,
50,1,,,
;0.00 ms,,
50,2,,,
;5.80 ms,,
50,3,,,
;0.12 ms,,
50,4,,,
;0.26 ms,,
51,0,,
51,1,,,
;2760.0,,
51,2,,,
;0.0,,
51,3,,,
51,4,,,
52,0,,
52,1,,,
;58435-33782-56015-0,,
53,0,,
53,1,,,
;C7500063 0060,,
54,0,,
54,1,,,
;FBL-Version: 24031.1.7.0,,
55,0,,
55,1,,,
;0.0,,
55,2,,,
55,3,,,
55,4,,,
56,0,,
56,1,,,
;0.0,,
56,2,,,
;0.0,,
56,3,,,
;0.0,,
56,4,,,
57,0,,
57,1,,,
;0.0,,
57,2,,,
;0.0,,
57,3,,,
;21.0,,
57,4,,,
58,0,,
58,1,,,
;0.0,,
58,2,,,
;0.0,,
58,3,,,
58,4,,,
59,0,,
59,1,,,
;OFF,,
59,2,,,
;OFF,,
59,3,,,
59,4,,,
60,0,,
60,1,,,
;0.0°C,,
60,2,,,
;31.5°C,,
60,3,,,
;0.0 A,,
60,4,,,
61,0,,
61,1,,,
;0.0°C,,
61,2,,,
;31.5°C,,
61,3,,,
;0.0 A,,
61,4,,,
62,0,,
62,1,,,
;0.0,,
62,2,,,
;0x0000,,
62,3,,,
;0.0,,
62,4,,,
;0x0000,,
63,0,,
63,1,,,
63,2,,,
63,3,,,
63,4,,,
64,0,,
64,1,,,
64,2,,,
64,3,,,
64,4,,,
65,0,,
65,1,,,
65,2,,,
65,3,,,
65,4,,,
66,0,,
66,1,,,
66,2,,,
66,3,,,
66,4,,,
67,0,,
67,1,,,
67,2,,,
67,3,,,
67,4,,,
68,0,,
68,1,,,
68,2,,,
68,3,,,
68,4,,,
69,0,,
69,1,,,
69,2,,,
69,3,,,
69,4,,,
70,0,,
70,1,,,
70,2,,,
70,3,,,
70,4,,,
71,0,,
71,1,,,
71,2,,,
71,3,,,
71,4,,,
72,0,,
72,1,,,
72,2,,,
72,3,,,
72,4,,,
73,0,,
73,1,,,
;0.0,,
73,2,,,
;0.0,,
73,3,,,
;0.0,,
73,4,,,
;0.0,,
74,0,,
74,1,,,
;0x0003,,
74,2,,,
;0x0003,,
74,3,,,
74,4,,,
75,0,,
75,1,,,
;33.0°C,,
75,2,,,
;9.0,,
75,3,,,
;-3.0°C,,
75,4,,,
;33.0°C,,
76,0,,
76,1,,,
;0.0,,
76,2,,,
76,3,,,
76,4,,,
77,0,,
77,1,,,
;-2.1°C,,
77,2,,,
;35.7°C,,
77,3,,,
;6.50 %,,
77,4,,,
;0.0,,
78,0,,
78,1,,,
;3.0,,
78,2,,,
;3.0,,
78,3,,,
;41.4°C,,
78,4,,,
;Inactive,,
79,0,,
79,1,,,
79,2,,,
79,3,,,
79,4,,,
80,0,,
80,1,,,
80,2,,,
80,3,,,
80,4,,,
81,0,,
81,1,,,
81,2,,,
81,3,,,
81,4,,,
82,0,,
82,1,,,
82,2,,,
82,3,,,
82,4,,,
83,0,,
83,1,,,
83,2,,,
83,3,,,
83,4,,,
84,0,,
84,1,,,
;0.0,,
84,2,,,
;0.0,,
84,3,,,
;0.0,,
84,4,,,
;0.0,,
85,0,,
85,1,,,
;0.0,,
85,2,,,
;0.0,,
85,3,,,
;5.0,,
85,4,,,
;4.0,,
86,0,,
86,1,,,
;0.0,,
86,2,,,
;0.0,,
86,3,,,
;0.0,,
86,4,,,
;0.0,,
87,0,,
87,1,,,
;2.0,,
87,2,,,
;0.0,,
87,3,,,
;0.0,,
87,4,,,
;0.0,,
88,0,,
88,1,,,
;0.0,,
88,2,,,
88,3,,,
88,4,,,
89,0,,
89,1,,,
;0.0,,
89,2,,,
;0.0,,
89,3,,,
;0.0,,
89,4,,,
;0.0,,
90,0,,
90,1,,,
;29,,
90,2,,,
;0,,
90,3,,,
;0,,
90,4,,,
;0,,
91,0,,
91,1,,,
;4,,
91,2,,,
;175,,
91,3,,,
;0,,
91,4,,,
;0,,
92,0,,
92,1,,,
;0,,
92,2,,,
;0,,
92,3,,,
;8,,
92,4,,,
;44,,
93,0,,
93,1,,,
;0,,
93,2,,,
;0,,
93,3,,,
;0,,
93,4,,,
;83,,
94,0,,
94,1,,,
;8,,
94,2,,,
;44,,
94,3,,,
;8,,
94,4,,,
;44,,
98,0,,
98,1,,,
;0.70 kOhm,,
98,2,,,
;0.00 kOhm,,
98,3,,,
;Closed,,
98,4,,,
;Closed,,
99,0,,
99,1,,,
;0x0034,,
99,2,,,
;0x0103,,
99,3,,,
;0.0,,
99,4,,,
;0.0,,
100,0,,
100,1,,,
;not available,,
100,2,,,
;not available,,
100,3,,,
;Occupied,,
100,4,,,
;Not Occup.,,
101,0,,
101,1,,,
;0.0 %,,
101,2,,,
;0.0 %,,
101,3,,,
;0.0 %,,
101,4,,,
;0.0 %,,
102,0,,
102,1,,,
;Intermed pos.,,
102,2,,,
;Inactive,,
102,3,,,
;not available,,
102,4,,,
;not available,,
103,0,,
103,1,,,
103,2,,,
103,3,,,
103,4,,,
104,0,,
104,1,,,
104,2,,,
104,3,,,
104,4,,,
105,0,,
105,1,,,
105,2,,,
105,3,,,
105,4,,,
106,0,,
106,1,,,
106,2,,,
106,3,,,
106,4,,,
107,0,,
107,1,,,
;Stage 0,,
107,2,,,
;Stage 0,,
107,3,,,
;32.5°C,,
107,4,,,
;33.5°C,,
108,0,,
108,1,,,
;0.0,,
108,2,,,
108,3,,,
;N/A,,
108,4,,,
;N/A,,
110,0,,
110,1,,,
110,2,,,
110,3,,,
110,4,,,
111,0,,
111,1,,,
111,2,,,
111,3,,,
111,4,,,
112,0,,
112,1,,,
112,2,,,
112,3,,,
112,4,,,
113,0,,
113,1,,,
113,2,,,
113,3,,,
113,4,,,
114,0,,
114,1,,,
114,2,,,
114,3,,,
114,4,,,
115,0,,
115,1,,,
115,2,,,
115,3,,,
115,4,,,
116,0,,
116,1,,,
116,2,,,
116,3,,,
116,4,,,
117,0,,
117,1,,,
117,2,,,
117,3,,,
117,4,,,
120,0,,
120,1,,,
120,2,,,
120,3,,,
120,4,,,
;N/A,,
121,0,,
121,1,,,
121,2,,,
121,3,,,
121,4,,,
122,0,,
122,1,,,
122,2,,,
122,3,,,
122,4,,,
125,0,,
125,1,,,
125,2,,,
125,3,,,
125,4,,,
126,0,,
126,1,,,
126,2,,,
126,3,,,
126,4,,,
127,0,,
127,1,,,
127,2,,,
127,3,,,
127,4,,,
128,0,,
128,1,,,
128,2,,,
128,3,,,
128,4,,,
129,0,,
129,1,,,
129,2,,,
129,3,,,
129,4,,,
;N/A,,
132,0,,
132,1,,,
;64.0 %,,
132,2,,,
;63.0 %,,
132,3,,,
;N/A,,
132,4,,,
;N/A,,
140,0,,
140,1,,,
;0.0 V,,
140,2,,,
;not available,,
140,3,,,
;OFF,,
140,4,,,
;not available,,
141,0,,
141,1,,,
;OFF,,
141,2,,,
;-2.0 mm,,
141,3,,,
;-9.0 mm,,
141,4,,,
;not available,,
142,0,,
142,1,,,
;60.40 %,,
142,2,,,
;50.00 %,,
142,3,,,
;61.20 %,,
142,4,,,
;52.40 %,,
143,0,,
143,1,,,
;-24,,
143,2,,,
;-24,,
143,3,,,
;0.0,,
143,4,,,
;0.0,,
144,0,,
144,1,,,
;56.00 %,,
144,2,,,
;-24,,
144,3,,,
;56.00 %,,
144,4,,,
;-24,,
145,0,,
145,1,,,
;not available,,
145,2,,,
;not available,,
145,3,,,
;not available,,
145,4,,,
;not available,,
146,0,,
146,1,,,
;not available,,
146,2,,,
;not available,,
146,3,,,
;not available,,
146,4,,,
;not available,,
147,0,,
147,1,,,
;101.60 %,,
147,2,,,
;101.60 %,,
147,3,,,
;0.0,,
147,4,,,
;0.0,,
148,0,,
148,1,,,
;not available,,
148,2,,,
;not available,,
148,3,,,
;not available,,
148,4,,,
;not available,,
149,0,,
149,1,,,
;not available,,
149,2,,,
;not available,,
149,3,,,
;not available,,
149,4,,,
;not available,,
150,0,,
150,1,,,
;not available,,
150,2,,,
;not available,,
150,3,,,
;not available,,
150,4,,,
;ON,,
151,0,,
151,1,,,
;14.6°,,
151,2,,,
;not available,,
151,3,,,
;Inactive,,
151,4,,,
;Inactive,,
152,0,,
152,1,,,
;0.0 %,,
152,2,,,
;Inactive,,
152,3,,,
;0.0,,
152,4,,,
;not available,,
153,0,,
153,1,,,
;not available,,
153,2,,,
;not available,,
153,3,,,
;not available,,
153,4,,,
;not available,,
154,0,,
154,1,,,
;not available,,
154,2,,,
;not available,,
154,3,,,
;not available,,
154,4,,,
;not available,,
155,0,,
155,1,,,
;not available,,
155,2,,,
;not available,,
155,3,,,
;not available,,
155,4,,,
;not available,,
156,0,,
156,1,,,
;not available,,
156,2,,,
;not available,,
156,3,,,
;not available,,
156,4,,,
;not available,,
157,0,,
157,1,,,
;not available,,
157,2,,,
;not available,,
157,3,,,
;not available,,
157,4,,,
;not available,,
158,0,,
158,1,,,
;not available,,
158,2,,,
;not available,,
158,3,,,
;not available,,
158,4,,,
;not available,,
159,0,,
159,1,,,
;Reg. Position,,
159,2,,,
;Learned,,
159,3,,,
;not available,,
159,4,,,
;not available,,
160,0,,
160,1,,,
;255 cm,,
160,2,,,
;255 cm,,
160,3,,,
;not available,,
160,4,,,
;not available,,
161,0,,
161,1,,,
;Reverse: No,,
161,2,,,
;Not Installed,,
161,3,,,
;0x0023,,
161,4,,,
;not available,,
162,0,,
162,1,,,
;65535 cm,,
162,2,,,
;65535 cm,,
162,3,,,
;65535 cm,,
162,4,,,
;65535 cm,,
163,0,,
163,1,,,
;65535 cm,,
163,2,,,
;65535 cm,,
163,3,,,
;65535 cm,,
163,4,,,
;65535 cm,,
164,0,,
164,1,,,
;Not Installed,,
164,2,,,
;Not Installed,,
164,3,,,
;Not Installed,,
164,4,,,
;Not Installed,,
165,0,,
165,1,,,
;0.00 ms,,
165,2,,,
;0.00 ms,,
165,3,,,
;0.00 ms,,
165,4,,,
;0.00 ms,,
166,0,,
166,1,,,
;0.00 ms,,
166,2,,,
;0.00 ms,,
166,3,,,
;0.00 ms,,
166,4,,,
;0.00 ms,,
167,0,,
167,1,,,
;Not Installed,,
167,2,,,
;Not Installed,,
167,3,,,
;Not Installed,,
167,4,,,
;Not Installed,,
168,0,,
168,1,,,
;Stage 4,,
168,2,,,
;Stage 4,,
168,3,,,
;Stage 4,,
168,4,,,
;Stage 6,,
169,0,,
169,1,,,
;OFF,,
169,2,,,
;Not Oper.,,
169,3,,,
;ON,,
169,4,,,
;not available,,
170,0,,
170,1,,,
;Not Installed,,
170,2,,,
;Not Installed,,
170,3,,,
;BackUpCam,,
170,4,,,
;not available,,
171,0,,
171,1,,,
;No,,
171,2,,,
;not Active,,
171,3,,,
;c.Switchoff,,
171,4,,,
;No,,
172,0,,
172,1,,,
;Not Installed,,
172,2,,,
;Not Installed,,
172,3,,,
;Yes,,
172,4,,,
;BackUpCam,,
173,0,,
173,1,,,
;not Active,,
173,2,,,
;BackUpCam,,
173,3,,,
;not available,,
173,4,,,
;not available,,
174,0,,
174,1,,,
;Stage 4,,
174,2,,,
;Stage 4,,
174,3,,,
;Stage 4,,
174,4,,,
;Stage 6,,
175,0,,
175,1,,,
;Active,,
175,2,,,
;BackUpCam,,
175,3,,,
;not available,,
175,4,,,
;not available,,
176,0,,
176,1,,,
;Stage 4,,
176,2,,,
;Stage 4,,
176,3,,,
;Stage 4,,
176,4,,,
;Stage 6,,
177,0,,
177,1,,,
;not Active,,
177,2,,,
;BackUpCam,,
177,3,,,
;not available,,
177,4,,,
;not available,,
178,0,,
178,1,,,
;Stage 4,,
178,2,,,
;Stage 4,,
178,3,,,
;Stage 4,,
178,4,,,
;Stage 6,,
179,0,,
179,1,,,
;not Active,,
179,2,,,
;BackUpCam,,
179,3,,,
;not available,,
179,4,,,
;not available,,
180,0,,
180,1,,,
;Stage 4,,
180,2,,,
;Stage 4,,
180,3,,,
;Stage 4,,
180,4,,,
;Stage 6,,
181,0,,
181,1,,,
;Stage 4,,
181,2,,,
;Stage 4,,
181,3,,,
;Stage 4,,
181,4,,,
;Stage 6,,
182,0,,
182,1,,,
;Not Installed,,
182,2,,,
;32.0°C,,
182,3,,,
;0.0,,
182,4,,,
;not available,,
183,0,,
183,1,,,
;0,,
183,2,,,
;0.0,,
183,3,,,
;0.0,,
183,4,,,
;0:00 h,,
184,0,,
184,1,,,
;0,,
184,2,,,
;0.0,,
184,3,,,
;0.0,,
184,4,,,
;0:00 h,,
185,0,,
185,1,,,
;0,,
185,2,,,
;0.0,,
185,3,,,
;0.0,,
185,4,,,
;0:00 h,,
186,0,,
186,1,,,
;0,,
186,2,,,
;0.0,,
186,3,,,
;0.0,,
186,4,,,
;0:00 h,,
187,0,,
187,1,,,
;0,,
187,2,,,
;0.0,,
187,3,,,
;0.0,,
187,4,,,
;0:00 h,,
188,0,,
188,1,,,
;0,,
188,2,,,
;0.0,,
188,3,,,
;0.0,,
188,4,,,
;0:00 h,,
189,0,,
189,1,,,
;0,,
189,2,,,
;0.0,,
189,3,,,
;0.0,,
189,4,,,
;0:00 h,,
190,0,,
190,1,,,
;0,,
190,2,,,
;0.0,,
190,3,,,
;0.0,,
190,4,,,
;0:00 h,,
191,0,,
191,1,,,
;0,,
191,2,,,
;0.0,,
191,3,,,
;0.0,,
191,4,,,
;0:00 h,,
192,0,,
192,1,,,
;0,,
192,2,,,
;0.0,,
192,3,,,
;0.0,,
192,4,,,
;0:00 h,,
193,0,,
193,1,,,
;1.0,,
193,2,,,
;20.0,,
193,3,,,
;3.0,,
193,4,,,
;6:48 h,,
194,0,,
194,1,,,
;not available,,
194,2,,,
;not available,,
194,3,,,
;not available,,
194,4,,,
;not available,,
195,0,,
195,1,,,
;not available,,
195,2,,,
;not available,,
195,3,,,
;not available,,
195,4,,,
;not available,,
196,0,,
196,1,,,
;not available,,
196,2,,,
;not available,,
196,3,,,
;not available,,
196,4,,,
;not available,,
197,0,,
197,1,,,
;not available,,
197,2,,,
;not available,,
197,3,,,
;not available,,
197,4,,,
;not available,,
198,0,,
198,1,,,
;2,,
198,2,,,
;Not Installed,,
198,3,,,
;not available,,
198,4,,,
;not available,,
199,0,,
199,1,,,
;0.0,,
199,2,,,
;not Active,,
199,3,,,
;Not Installed,,
199,4,,,
;1.0,,
200,0,,
200,1,,,
200,2,,,
200,3,,,
200,4,,,
201,0,,
201,1,,,
201,2,,,
201,3,,,
201,4,,,
202,0,,
202,1,,,
202,2,,,
202,3,,,
202,4,,,
203,0,,
203,1,,,
203,2,,,
203,3,,,
203,4,,,
204,0,,
204,1,,,
204,2,,,
204,3,,,
204,4,,,
205,0,,
205,1,,,
205,2,,,
205,3,,,
205,4,,,
206,0,,
206,1,,,
206,2,,,
206,3,,,
206,4,,,
207,0,,
207,1,,,
207,2,,,
207,3,,,
207,4,,,
208,0,,
208,1,,,
208,2,,,
208,3,,,
208,4,,,
209,0,,
209,1,,,
209,2,,,
209,3,,,
209,4,,,
210,0,,
210,1,,,
210,2,,,
210,3,,,
210,4,,,
211,0,,
211,1,,,
211,2,,,
211,3,,,
211,4,,,
212,0,,
212,1,,,
212,2,,,
212,3,,,
212,4,,,
213,0,,
213,1,,,
213,2,,,
213,3,,,
213,4,,,
214,0,,
214,1,,,
214,2,,,
214,3,,,
214,4,,,
215,0,,
215,1,,,
215,2,,,
215,3,,,
215,4,,,
216,0,,
216,1,,,
216,2,,,
216,3,,,
216,4,,,
217,0,,
217,1,,,
217,2,,,
217,3,,,
217,4,,,
218,0,,
218,1,,,
;511,,
218,2,,,
;511,,
218,3,,,
;not available,,
218,4,,,
;0,,
251,0,,
251,1,,,
;0.0,,
251,2,,,
;2760.0,,
251,3,,,
;0.0,,
251,4,,,
;0.0,,
252,0,,
252,1,,,
;1.0,,
252,2,,,
;0.0,,
252,3,,,
;4096.0,,
252,4,,,
;0.0,,
253,0,,
253,1,,,
;0.0,,
253,2,,,
;N/A,,
253,3,,,
;N/A,,
253,4,,,
;N/A,,
Jackp311
C?ID=168364
Thanks, Uwe. I wasn't aware that I could do that. I appreciate you dropping them in for me.
Let me know what you and the team think about the tweaks. Really hoping I can get those both working.
Thanks to all of those from Ross Tech who have jumped in already to help out!
United States
Thanks,
Sorry about that Jack, I just noticed an error in that old post. BCM2 is address 46 and the maps from that controller would be helpful for the comfort window inquiry. (The BCM1 / 09 maps are still helpful because this is one of the newer units)
If you haven't sorted this already please post the PLA / PLB maps from 46 so we can take a look at those.
-Dana
Jackp311
C?ID=168364
No Problem - here are the files from module 46
Let me know if you need anything else.
;SW:8K0-907-064-JP   HW:8K0-907-064-JP ---  Central Conv.
;Component:BCM2 2.0      H14 0650, Coding:01260E3A20FA709584A0053600040047
;Tuesday,29,April,2014,19:18:15:61963
;VCID: 871DD96436DFBF265AD-80D2
A01,0,
;53344
A01,1,
;N/A
A01,2,
;N/A
A01,3,
;N/A
A01,4,
;N/A
A02,0,
;53344
A02,1,
;N/A
A02,2,
;N/A
A02,3,
;N/A
A02,4,
;N/A
A03,0,
;36961
A03,1,
;N/A
A03,2,
;N/A
A03,3,
;N/A
A03,4,
;N/A
A04,0,
;36961
A04,1,
;N/A
A04,2,
;N/A
A04,3,
;N/A
A04,4,
;N/A
A05,0,
;0
A05,1,
;N/A
A05,2,
;N/A
A05,3,
;N/A
A05,4,
;N/A
A06,0,
;0
A06,1,
;N/A
A06,2,
;N/A
A06,3,
;N/A
A06,4,
;N/A
A07,0,
;0
A07,1,
;N/A
A07,2,
;N/A
A07,3,
;N/A
A07,4,
;N/A
A08,0,
;0
A08,1,
;N/A
A08,2,
;N/A
A08,3,
;N/A
A08,4,
;N/A
A09,0,
;36961
A09,1,
;N/A
A09,2,
;N/A
A09,3,
;N/A
A09,4,
;N/A
A10,0,
;0
A10,1,
;N/A
A10,2,
;N/A
A10,3,
;N/A
A10,4,
;N/A
;11 N/A
;12 N/A
A13,0,
;87
A13,1,
;N/A
A13,2,
;N/A
A13,3,
;N/A
A13,4,
;N/A
;14 N/A
;15 N/A
A16,0,
;5
A16,1,
;N/A
A16,2,
;N/A
A16,3,
;N/A
A16,4,
;N/A
;17 N/A
;18 N/A
;19 N/A
;20 N/A
;21 N/A
;22 N/A
;23 N/A
;24 N/A
;25 N/A
;26 N/A
;27 N/A
;28 N/A
;29 N/A
;30 N/A
;31 N/A
;32 N/A
;33 N/A
;34 N/A
;35 N/A
;36 N/A
;37 N/A
;38 N/A
;39 N/A
;40 N/A
;41 N/A
;42 N/A
;43 N/A
;44 N/A
;45 N/A
;46 N/A
;47 N/A
;48 N/A
;49 N/A
;50 N/A
;51 N/A
;52 N/A
;53 N/A
;54 N/A
;55 N/A
;56 N/A
;57 N/A
;58 N/A
;59 N/A
A60,0,
;15
A60,1,
;N/A
A60,2,
;N/A
A60,3,
;N/A
A60,4,
;N/A
A61,0,
;9947
A61,1,
;N/A
A61,2,
;N/A
A61,3,
;N/A
A61,4,
;N/A
A62,0,
;48059
A62,1,
;N/A
A62,2,
;N/A
A62,3,
;N/A
A62,4,
;N/A
A63,0,
;40
A63,1,
;N/A
A63,2,
;N/A
A63,3,
;N/A
A63,4,
;N/A
A64,0,
;40
A64,1,
;N/A
A64,2,
;N/A
A64,3,
;N/A
A64,4,
;N/A
A65,0,
;63
A65,1,
;N/A
A65,2,
;N/A
A65,3,
;N/A
A65,4,
;N/A
A66,0,
;21
A66,1,
;N/A
A66,2,
;N/A
A66,3,
;N/A
A66,4,
;N/A
A67,0,
;6425
A67,1,
;N/A
A67,2,
;N/A
A67,3,
;N/A
A67,4,
;N/A
A68,0,
A68,1,
;ERROR:
A68,2,
;Security
A68,3,
;access
A68,4,
;required
A69,0,
;0
A69,1,
;N/A
A69,2,
;N/A
A69,3,
;N/A
A69,4,
;N/A
;70 N/A
;71 N/A
;72 N/A
;73 N/A
;74 N/A
;75 N/A
;76 N/A
;77 N/A
;78 N/A
;79 N/A
;80 N/A
;81 N/A
;82 N/A
;83 N/A
;84 N/A
;85 N/A
;86 N/A
;87 N/A
;88 N/A
;89 N/A
;90 N/A
;91 N/A
;92 N/A
;93 N/A
;94 N/A
A95,0,
;1
A95,1,
;N/A
A95,2,
;N/A
A95,3,
;N/A
A95,4,
;N/A
A96,0,
;30
A96,1,
;N/A
A96,2,
;N/A
A96,3,
;N/A
A96,4,
;N/A
A97,0,
;50
A97,1,
;N/A
A97,2,
;N/A
A97,3,
;N/A
A97,4,
;N/A
A98,0,
;1
A98,1,
;N/A
A98,2,
;N/A
A98,3,
;N/A
A98,4,
;N/A
;99 N/A
;100 N/A
;101 N/A
A102,0,
A102,1,
;ERROR:
A102,2,
;Security
A102,3,
;access
A102,4,
;required
;103 N/A
A104,0,
;190
A104,1,
;N/A
A104,2,
;N/A
A104,3,
;N/A
A104,4,
;N/A
;105 N/A
;106 N/A
;107 N/A
;108 N/A
;109 N/A
;110 N/A
;111 N/A
;112 N/A
;113 N/A
;114 N/A
;115 N/A
;116 N/A
;117 N/A
;118 N/A
;119 N/A
;120 N/A
;121 N/A
;122 N/A
;123 N/A
;124 N/A
;125 N/A
;126 N/A
;127 N/A
;128 N/A
;129 N/A
;130 N/A
;131 N/A
;132 N/A
;133 N/A
;134 N/A
;135 N/A
;136 N/A
;137 N/A
;138 N/A
;139 N/A
;140 N/A
;141 N/A
;142 N/A
;143 N/A
;144 N/A
;145 N/A
;146 N/A
;147 N/A
;148 N/A
;149 N/A
A150,0,
;0
A150,1,
;N/A
A150,2,
;N/A
A150,3,
;N/A
A150,4,
;N/A
;151 N/A
;152 N/A
;153 N/A
;154 N/A
;155 N/A
;156 N/A
;157 N/A
;158 N/A
;159 N/A
;160 N/A
;161 N/A
;162 N/A
;163 N/A
;164 N/A
;165 N/A
;166 N/A
;167 N/A
;168 N/A
;169 N/A
;170 N/A
;171 N/A
;172 N/A
;173 N/A
;174 N/A
;175 N/A
;176 N/A
;177 N/A
;178 N/A
A179,0,
A179,1,
;ERROR:
A179,2,
;Security
A179,3,
;access
A179,4,
;required
A180,0,
A180,1,
;ERROR:
A180,2,
;Security
A180,3,
;access
A180,4,
;required
A181,0,
A181,1,
;ERROR:
A181,2,
;Security
A181,3,
;access
A181,4,
;required
A182,0,
A182,1,
;ERROR:
A182,2,
;Security
A182,3,
;access
A182,4,
;required
A183,0,
A183,1,
;ERROR:
A183,2,
;Security
A183,3,
;access
A183,4,
;required
A184,0,
A184,1,
;ERROR:
A184,2,
;Security
A184,3,
;access
A184,4,
;required
A185,0,
A185,1,
;ERROR:
A185,2,
;Security
A185,3,
;access
A185,4,
;required
A186,0,
A186,1,
;ERROR:
A186,2,
;Security
A186,3,
;access
A186,4,
;required
A187,0,
A187,1,
;ERROR:
A187,2,
;Security
A187,3,
;access
A187,4,
;required
A188,0,
A188,1,
;ERROR:
A188,2,
;Security
A188,3,
;access
A188,4,
;required
A189,0,
A189,1,
;ERROR:
A189,2,
;Security
A189,3,
;access
A189,4,
;required
A190,0,
A190,1,
;ERROR:
A190,2,
;Security
A190,3,
;access
A190,4,
;required
A191,0,
A191,1,
;ERROR:
A191,2,
;Security
A191,3,
;access
A191,4,
;required
A192,0,
A192,1,
;ERROR:
A192,2,
;Security
A192,3,
;access
A192,4,
;required
A193,0,
A193,1,
;ERROR:
A193,2,
;Security
A193,3,
;access
A193,4,
;required
A194,0,
;7
A194,1,
;N/A
A194,2,
;N/A
A194,3,
;N/A
A194,4,
;N/A
A195,0,
A195,1,
;ERROR:
A195,2,
;Security
A195,3,
;access
A195,4,
;required
A196,0,
A196,1,
;ERROR:
A196,2,
;Security
A196,3,
;access
A196,4,
;required
A197,0,
A197,1,
;ERROR:
A197,2,
;Security
A197,3,
;access
A197,4,
;required
A198,0,
A198,1,
;ERROR:
A198,2,
;Security
A198,3,
;access
A198,4,
;required
A199,0,
A199,1,
;ERROR:
A199,2,
;Security
A199,3,
;access
A199,4,
;required
A200,0,
A200,1,
;ERROR:
A200,2,
;Security
A200,3,
;access
A200,4,
;required
A201,0,
A201,1,
;ERROR:
A201,2,
;Security
A201,3,
;access
A201,4,
;required
A202,0,
A202,1,
;ERROR:
A202,2,
;Security
A202,3,
;access
A202,4,
;required
A203,0,
A203,1,
;ERROR:
A203,2,
;Security
A203,3,
;access
A203,4,
;required
A204,0,
A204,1,
;ERROR:
A204,2,
;Security
A204,3,
;access
A204,4,
;required
A205,0,
A205,1,
;ERROR:
A205,2,
;Security
A205,3,
;access
A205,4,
;required
A206,0,
A206,1,
;ERROR:
A206,2,
;Security
A206,3,
;access
A206,4,
;required
A207,0,
A207,1,
;ERROR:
A207,2,
;Security
A207,3,
;access
A207,4,
;required
A208,0,
A208,1,
;ERROR:
A208,2,
;Security
A208,3,
;access
A208,4,
;required
A209,0,
A209,1,
;ERROR:
A209,2,
;Security
A209,3,
;access
A209,4,
;required
A210,0,
A210,1,
;ERROR:
A210,2,
;Security
A210,3,
;access
A210,4,
;required
A211,0,
A211,1,
;ERROR:
A211,2,
;Security
A211,3,
;access
A211,4,
;required
A212,0,
A212,1,
;ERROR:
A212,2,
;Security
A212,3,
;access
A212,4,
;required
A213,0,
A213,1,
;ERROR:
A213,2,
;Security
A213,3,
;access
A213,4,
;required
A214,0,
A214,1,
;ERROR:
A214,2,
;Security
A214,3,
;access
A214,4,
;required
A215,0,
A215,1,
;ERROR:
A215,2,
;Security
A215,3,
;access
A215,4,
;required
A216,0,
A216,1,
;ERROR:
A216,2,
;Security
A216,3,
;access
A216,4,
;required
A217,0,
A217,1,
;ERROR:
A217,2,
;Security
A217,3,
;access
A217,4,
;required
A218,0,
A218,1,
;ERROR:
A218,2,
;Security
A218,3,
;access
A218,4,
;required
A219,0,
A219,1,
;ERROR:
A219,2,
;Security
A219,3,
;access
A219,4,
;required
A220,0,
A220,1,
;ERROR:
A220,2,
;Security
A220,3,
;access
A220,4,
;required
A221,0,
A221,1,
;ERROR:
A221,2,
;Security
A221,3,
;access
A221,4,
;required
A222,0,
A222,1,
;ERROR:
A222,2,
;Security
A222,3,
;access
A222,4,
;required
A223,0,
A223,1,
;ERROR:
A223,2,
;Security
A223,3,
;access
A223,4,
;required
A224,0,
A224,1,
;ERROR:
A224,2,
;Security
A224,3,
;access
A224,4,
;required
A225,0,
A225,1,
;ERROR:
A225,2,
;Security
A225,3,
;access
A225,4,
;required
A226,0,
A226,1,
;ERROR:
A226,2,
;Security
A226,3,
;access
A226,4,
;required
A227,0,
A227,1,
;ERROR:
A227,2,
;Security
A227,3,
;access
A227,4,
;required
A228,0,
A228,1,
;ERROR:
A228,2,
;Security
A228,3,
;access
A228,4,
;required
A229,0,
A229,1,
;ERROR:
A229,2,
;Security
A229,3,
;access
A229,4,
;required
A230,0,
A230,1,
;ERROR:
A230,2,
;Security
A230,3,
;access
A230,4,
;required
A231,0,
A231,1,
;ERROR:
A231,2,
;Security
A231,3,
;access
A231,4,
;required
A232,0,
A232,1,
;ERROR:
A232,2,
;Security
A232,3,
;access
A232,4,
;required
A233,0,
A233,1,
;ERROR:
A233,2,
;Security
A233,3,
;access
A233,4,
;required
A234,0,
A234,1,
;ERROR:
A234,2,
;Security
A234,3,
;access
A234,4,
;required
A235,0,
A235,1,
;ERROR:
A235,2,
;Security
A235,3,
;access
A235,4,
;required
A236,0,
A236,1,
;ERROR:
A236,2,
;Security
A236,3,
;access
A236,4,
;required
A237,0,
A237,1,
;ERROR:
A237,2,
;Security
A237,3,
;access
A237,4,
;required
A238,0,
A238,1,
;ERROR:
A238,2,
;Security
A238,3,
;access
A238,4,
;required
A239,0,
A239,1,
;ERROR:
A239,2,
;Security
A239,3,
;access
A239,4,
;required
A240,0,
A240,1,
;ERROR:
A240,2,
;Security
A240,3,
;access
A240,4,
;required
A241,0,
A241,1,
;ERROR:
A241,2,
;Security
A241,3,
;access
A241,4,
;required
A242,0,
A242,1,
;ERROR:
A242,2,
;Security
A242,3,
;access
A242,4,
;required
A243,0,
A243,1,
;ERROR:
A243,2,
;Security
A243,3,
;access
A243,4,
;required
A244,0,
A244,1,
;ERROR:
A244,2,
;Security
A244,3,
;access
A244,4,
;required
A245,0,
A245,1,
;ERROR:
A245,2,
;Security
A245,3,
;access
A245,4,
;required
A246,0,
A246,1,
;ERROR:
A246,2,
;Security
A246,3,
;access
A246,4,
;required
A247,0,
A247,1,
;ERROR:
A247,2,
;Security
A247,3,
;access
A247,4,
;required
;248 N/A
;249 N/A
;250 N/A
;251 N/A
;252 N/A
;253 N/A
;254 N/A
;255 N/A
;Tuesday,29,April,2014,19:16:32:61963
1,0,,
1,1,,,
;12.10 V,,
1,2,,,
;12.10 V,,
1,3,,,
;12.10 V,,
1,4,,,
;    0000,,
2,0,,
2,1,,,
;Not Oper.,,
2,2,,,
;Not Oper.,,
2,3,,,
;Closed,,
2,4,,,
;Closed,,
3,0,,
3,1,,,
3,2,,,
3,3,,,
;      00,,
3,4,,,
;Not Oper.,,
4,0,,
4,1,,,
4,2,,,
4,3,,,
4,4,,,
;Not Oper.,,
5,0,,
5,1,,,
;Not Installed,,
5,2,,,
;Not Installed,,
5,3,,,
;Not Installed,,
5,4,,,
;Not Installed,,
6,0,,
6,1,,,
;Door Open,,
6,2,,,
;Not Oper.,,
6,3,,,
;Unlocked,,
6,4,,,
;Not Safe,,
7,0,,
7,1,,,
;Door Closed,,
7,2,,,
;Not Oper.,,
7,3,,,
;Unlocked,,
7,4,,,
;Not Safe,,
8,0,,
8,1,,,
;Door Closed,,
8,2,,,
;Not Oper.,,
8,3,,,
;Unlocked,,
8,4,,,
;Not Installed,,
9,0,,
9,1,,,
;Door Closed,,
9,2,,,
;Not Oper.,,
9,3,,,
;Unlocked,,
9,4,,,
;Not Installed,,
10,0,,
10,1,,,
;    1111,,
10,2,,,
;    0000,,
10,3,,,
;    0000,,
10,4,,,
12,0,,
12,1,,,
12,2,,,
12,3,,,
;OFF,,
12,4,,,
;OFF,,
13,0,,
13,1,,,
;Not Installed,,
13,2,,,
;Not Installed,,
13,3,,,
;0.0,,
13,4,,,
;0.0,,
14,0,,
14,1,,,
;0.00 km/h,,
14,2,,,
;Init. value,,
14,3,,,
14,4,,,
15,0,,
15,1,,,
;Not Installed,,
15,2,,,
;Not Installed,,
15,3,,,
;0.000 A,,
15,4,,,
;33.0°C,,
16,0,,
16,1,,,
;Retracted,,
16,2,,,
;Connected,,
16,3,,,
;      00,,
16,4,,,
;OFF,,
17,0,,
17,1,,,
;Not Installed,,
17,2,,,
;Not Installed,,
17,3,,,
;Not Installed,,
17,4,,,
;Not Installed,,
18,0,,
18,1,,,
;0.0,,
18,2,,,
;0.0,,
18,3,,,
;0.0,,
18,4,,,
;0.0,,
19,0,,
19,1,,,
;Not Installed,,
19,2,,,
;Not Installed,,
19,3,,,
;Not Installed,,
19,4,,,
;Not Installed,,
20,0,,
20,1,,,
;Not Installed,,
20,2,,,
;Inactive,,
20,3,,,
;Not Installed,,
20,4,,,
;Not Installed,,
21,0,,
21,1,,,
;255,,
21,2,,,
;2127:15:31,,
21,3,,,
;255:255 h,,
21,4,,,
22,0,,
22,1,,,
;255,,
22,2,,,
;2127:15:31,,
22,3,,,
;255:255 h,,
22,4,,,
23,0,,
23,1,,,
;255,,
23,2,,,
;2127:15:31,,
23,3,,,
;255:255 h,,
23,4,,,
24,0,,
24,1,,,
;255,,
24,2,,,
;2127:15:31,,
24,3,,,
;255:255 h,,
24,4,,,
25,0,,
25,1,,,
;     000,,
25,2,,,
;      00,,
25,3,,,
;OFF,,
25,4,,,
26,0,,
26,1,,,
;Not Oper.,,
26,2,,,
;Lid close,,
26,3,,,
;Not Connected,,
26,4,,,
;Not Oper.,,
27,0,,
27,1,,,
;No,,
27,2,,,
;ON,,
27,3,,,
;0,,
27,4,,,
;    0000,,
28,0,,
28,1,,,
;  001000,,
28,2,,,
;00000000,,
28,3,,,
;11110000,,
28,4,,,
;      01,,
29,0,,
29,1,,,
; 0000000,,
29,2,,,
; 0000000,,
29,3,,,
; 0000000,,
29,4,,,
30,0,,
30,1,,,
;0.0,,
30,2,,,
; 0000110,,
30,3,,,
;      00,,
30,4,,,
;10000110,,
31,0,,
31,1,,,
;Not Installed,,
31,2,,,
;Not Installed,,
31,3,,,
;Not Installed,,
31,4,,,
;Not Installed,,
32,0,,
32,1,,,
;0.0,,
32,2,,,
; 0000111,,
32,3,,,
;      00,,
32,4,,,
;10000110,,
33,0,,
33,1,,,
;0.0,,
33,2,,,
;31.0°C,,
33,3,,,
;  000001,,
33,4,,,
; 0000000,,
34,0,,
34,1,,,
;    0000,,
34,2,,,
;     000,,
34,3,,,
;     101,,
34,4,,,
;   00000,,
35,0,,
35,1,,,
;     000,,
35,2,,,
;100 %,,
35,3,,,
;10000110,,
35,4,,,
;0.0,,
36,0,,
36,1,,,
;Not Installed,,
36,2,,,
;Not Installed,,
36,3,,,
;Not Installed,,
36,4,,,
;Not Installed,,
38,0,,
38,1,,,
38,2,,,
;Not Installed,,
38,3,,,
38,4,,,
39,0,,
39,1,,,
;00000000,,
39,2,,,
;0.0,,
39,3,,,
;0.0,,
39,4,,,
;0.0,,
41,0,,
41,1,,,
;OFF,,
41,2,,,
;OFF,,
41,3,,,
;OFF,,
41,4,,,
;OFF,,
42,0,,
42,1,,,
;      00,,
42,2,,,
;Not Installed,,
42,3,,,
;5.0,,
42,4,,,
;      11,,
43,0,,
43,1,,,
;10100111,,
43,2,,,
;00010000,,
43,3,,,
;00000000,,
43,4,,,
;      01,,
44,0,,
44,1,,,
;      00,,
44,2,,,
;Not Installed,,
44,3,,,
;OFF,,
44,4,,,
;Not Installed,,
45,0,,
45,1,,,
;ON,,
45,2,,,
;OFF,,
45,3,,,
;ON,,
45,4,,,
46,0,,
46,1,,,
;Not Installed,,
46,2,,,
;Not Installed,,
46,3,,,
;     000,,
46,4,,,
;      00,,
47,0,,
47,1,,,
;OPEN,,
47,2,,,
;Closed,,
47,3,,,
;Closed,,
47,4,,,
48,0,,
48,1,,,
;2.0,,
48,2,,,
;1.0,,
48,3,,,
;1.0,,
48,4,,,
;0.0,,
50,0,,
50,1,,,
;6,,
50,2,,,
;OPEN,,
50,3,,,
;Unlock,,
50,4,,,
;2,,
51,0,,
51,1,,,
;8,,
51,2,,,
;Closed,,
51,3,,,
;Lock,,
51,4,,,
;2,,
52,0,,
52,1,,,
;19,,
52,2,,,
;OPEN,,
52,3,,,
;Unlock,,
52,4,,,
;0,,
53,0,,
53,1,,,
;18,,
53,2,,,
;Closed,,
53,3,,,
;Lock,,
53,4,,,
;0,,
54,0,,
54,1,,,
;19,,
54,2,,,
;OPEN,,
54,3,,,
;Unlock,,
54,4,,,
;0,,
55,0,,
55,1,,,
;2014:04:29,,
55,2,,,
;20:14 h,,
55,3,,,
55,4,,,
56,0,,
56,1,,,
;2014:04:29,,
56,2,,,
;16:37 h,,
56,3,,,
56,4,,,
57,0,,
57,1,,,
;2014:04:29,,
57,2,,,
;16:37 h,,
57,3,,,
57,4,,,
58,0,,
58,1,,,
;2014:04:29,,
58,2,,,
;16:36 h,,
58,3,,,
58,4,,,
59,0,,
59,1,,,
;2014:04:29,,
59,2,,,
;16:35 h,,
59,3,,,
59,4,,,
60,0,,
60,1,,,
;Not Installed,,
60,2,,,
;Not Installed,,
60,3,,,
;Not Installed,,
60,4,,,
;Not Installed,,
61,0,,
61,1,,,
;1.0,,
61,2,,,
;  000000,,
61,3,,,
;Not Installed,,
61,4,,,
;10000110,,
68,0,,
68,1,,,
;Not Installed,,
68,2,,,
68,3,,,
68,4,,,
73,0,,
73,1,,,
;0,,
73,2,,,
;00011000,,
73,3,,,
;    0010,,
73,4,,,
;0.0,,
74,0,,
74,1,,,
;11000111,,
74,2,,,
;  000100,,
74,3,,,
;      00,,
74,4,,,
75,0,,
75,1,,,
;01000000,,
75,2,,,
;00100010,,
75,3,,,
;00010010,,
75,4,,,
;01111100,,
76,0,,
76,1,,,
;0.0,,
76,2,,,
;0.0,,
76,3,,,
;0.0,,
76,4,,,
;0.0,,
77,0,,
77,1,,,
;0.0,,
77,2,,,
;0.0,,
77,3,,,
;0.0,,
77,4,,,
;55.0,,
78,0,,
78,1,,,
;120.0,,
78,2,,,
;251.0,,
78,3,,,
;0.0,,
78,4,,,
;0.0,,
79,0,,
79,1,,,
;0.0,,
79,2,,,
;15.0,,
79,3,,,
;0.0,,
79,4,,,
;25.0,,
80,0,,
80,1,,,
;0.0,,
80,2,,,
;0.0,,
80,3,,,
;0.0,,
80,4,,,
;0.0,,
81,0,,
81,1,,,
;0.0,,
81,2,,,
81,3,,,
81,4,,,
85,0,,
85,1,,,
;00000000,,
85,2,,,
;00000000,,
85,3,,,
;00000000,,
85,4,,,
;00000000,,
86,0,,
86,1,,,
;0x0000,,
86,2,,,
;0x0000,,
86,3,,,
;0x0000,,
86,4,,,
;0x0000,,
87,0,,
87,1,,,
;0x0000,,
87,2,,,
;0x0000,,
87,3,,,
;0x0000,,
87,4,,,
88,0,,
88,1,,,
;0.0,,
88,2,,,
;0.0,,
88,3,,,
;0.0,,
88,4,,,
;0.0,,
89,0,,
89,1,,,
;00000101 01111100,,
89,2,,,
;10000101,,
89,3,,,
;00010000,,
89,4,,,
;00000000,,
90,0,,
90,1,,,
;Not Installed,,
90,2,,,
;Not Installed,,
90,3,,,
;Not Installed,,
90,4,,,
;Not Installed,,
91,0,,
91,1,,,
;Not Installed,,
91,2,,,
;Not Installed,,
91,3,,,
;Not Installed,,
91,4,,,
;Not Installed,,
92,0,,
92,1,,,
;Not Installed,,
92,2,,,
;Not Installed,,
92,3,,,
;Not Installed,,
92,4,,,
;Not Installed,,
93,0,,
93,1,,,
;Not Occup.,,
93,2,,,
;Not Installed,,
93,3,,,
;Not Occup.,,
93,4,,,
;Not Occup.,,
98,0,,
98,1,,,
;0.0,,
98,2,,,
;0.0,,
98,3,,,
;1583.0,,
98,4,,,
;255.0,,
99,0,,
99,1,,,
;00000000 00000000,,
99,2,,,
99,3,,,
99,4,,,
100,0,,
100,1,,,
;J8,,
100,2,,,
100,3,,,
100,4,,,
101,0,,
101,1,,,
;0.0,,
101,2,,,
;0.0,,
101,3,,,
;0.0,,
101,4,,,
;0.0,,
102,0,,
102,1,,,
;0.0,,
102,2,,,
;0.0,,
102,3,,,
;0.0,,
102,4,,,
;0.0,,
103,0,,
103,1,,,
;0.0,,
103,2,,,
;0.0,,
103,3,,,
;0.0,,
103,4,,,
;0.0,,
104,0,,
104,1,,,
;0.0,,
104,2,,,
;0.0,,
104,3,,,
;0.0,,
104,4,,,
;0.0,,
105,0,,
105,1,,,
;0.0,,
105,2,,,
;0.0,,
105,3,,,
;0.0,,
105,4,,,
;0.0,,
106,0,,
106,1,,,
;0.0,,
106,2,,,
;0.0,,
106,3,,,
;0.0,,
106,4,,,
;0.0,,
107,0,,
107,1,,,
;0.0,,
107,2,,,
;0.0,,
107,3,,,
;0.0,,
107,4,,,
;0.0,,
108,0,,
108,1,,,
;11111111,,
108,2,,,
;1.0,,
108,3,,,
;01011011 11100111,,
108,4,,,
;124.0,,
110,0,,
110,1,,,
110,2,,,
110,3,,,
110,4,,,
111,0,,
111,1,,,
;Not Installed,,
111,2,,,
;Not Installed,,
111,3,,,
;Not Installed,,
111,4,,,
;Not Installed,,
112,0,,
112,1,,,
112,2,,,
112,3,,,
112,4,,,
113,0,,
113,1,,,
113,2,,,
113,3,,,
113,4,,,
120,0,,
120,1,,,
;Not Installed,,
120,2,,,
;Not Installed,,
120,3,,,
;Not Installed,,
120,4,,,
;Not Installed,,
160,0,,
160,1,,,
;Not Installed,,
160,2,,,
;Not Installed,,
160,3,,,
;Not Installed,,
160,4,,,
;Not Installed,,
161,0,,
161,1,,,
;Not Installed,,
161,2,,,
;Not Installed,,
161,3,,,
;Not Installed,,
161,4,,,
;Not Installed,,
162,0,,
162,1,,,
;Not Installed,,
162,2,,,
;Not Installed,,
162,3,,,
;Not Installed,,
162,4,,,
;Not Installed,,
163,0,,
163,1,,,
;Not Installed,,
163,2,,,
;Not Installed,,
163,3,,,
;Not Installed,,
163,4,,,
;Not Installed,,
164,0,,
164,1,,,
;Not Installed,,
164,2,,,
;Not Installed,,
164,3,,,
;Not Installed,,
164,4,,,
;Not Installed,,
165,0,,
165,1,,,
;Not Installed,,
165,2,,,
;Not Installed,,
165,3,,,
;Not Installed,,
165,4,,,
;Not Installed,,
166,0,,
166,1,,,
;Not Installed,,
166,2,,,
;Not Installed,,
166,3,,,
;Not Installed,,
166,4,,,
;Not Installed,,
167,0,,
167,1,,,
;Not Installed,,
167,2,,,
;Not Installed,,
167,3,,,
;Not Installed,,
167,4,,,
;Not Installed,,
168,0,,
168,1,,,
;Not Installed,,
168,2,,,
;Not Installed,,
168,3,,,
;Not Installed,,
168,4,,,
;Not Installed,,
169,0,,
169,1,,,
;Not Installed,,
169,2,,,
;Not Installed,,
169,3,,,
;Not Installed,,
169,4,,,
;Not Installed,,
200,0,,
200,1,,,
;     111,,
200,2,,,
;0.0,,
200,3,,,
;0.0,,
200,4,,,
;0.0,,
201,0,,
201,1,,,
;     000,,
201,2,,,
;2.0,,
201,3,,,
;00000010,,
201,4,,,
;499.0,,
235,0,,
235,1,,,
;10010101,,
235,2,,,
;10101000,,
235,3,,,
;00011011,,
235,4,,,
;01010110,,
236,0,,
236,1,,,
;00000101,,
236,2,,,
;0,,
236,3,,,
;0,,
236,4,,,
;01010000,,
237,0,,
237,1,,,
;10010101,,
237,2,,,
;00001000,,
237,3,,,
;00001111,,
237,4,,,
;00000000,,
238,0,,
238,1,,,
;00010011,,
238,2,,,
;0,,
238,3,,,
;0,,
238,4,,,
;00110101,,
239,0,,
239,1,,,
;0.0,,
239,2,,,
;50.0,,
239,3,,,
;0.0,,
239,4,,,
;300,,
240,0,,
240,1,,,
;10101100 11110101,,
240,2,,,
;10101000 11110101,,
240,3,,,
;0.0,,
240,4,,,
;0.0,,
241,0,,
241,1,,,
;00001010 00100010,,
241,2,,,
;00100010 00110011,,
241,3,,,
;00001010 00001010,,
241,4,,,
242,0,,
242,1,,,
;11110011 11111111,,
242,2,,,
;00000100 00000000,,
242,3,,,
242,4,,,
;01001010 00000000,,
243,0,,
243,1,,,
;01011010 10100101,,
243,2,,,
;10100101 01011010,,
243,3,,,
;511.0,,
243,4,,,
;53.0,,
244,0,,
244,1,,,
;0.0,,
244,2,,,
;0.0,,
244,3,,,
;0.0,,
244,4,,,
;0.0,,
245,0,,
245,1,,,
;0.0,,
245,2,,,
;0.0,,
245,3,,,
;0.0,,
245,4,,,
;0.0,,
246,0,,
246,1,,,
;0.0,,
246,2,,,
;0.0,,
246,3,,,
;0.0,,
246,4,,,
;0.0,,
United States
OK, I believe the old B8 window tweak applies but these cars use 2 BCMs so Address 46 is the window man :-) I shortened the 46 map so the stored values from channels 001, 002, 003, 004, 061 and 062 are included:
A01
;53344
A02
;53344
A03
;36961
A04
;36961
A61,0,
;9947
A62,0,
;48059
[HR][/HR]
I don't think these cars came with any more than 2 remote keys so adapt channels 003/004 really don't apply.
  1. Channels 001 and 002 (Personalization (Key 1 and Key 2) break down to:
    53344
    +32 = Auto-Lock (Locking at 15 kph/10 mph)
    +64 = Auto-Unlock (Unlocking with Key Removal)
    +4096 = Anti-Theft-System Confirmation (Horn/Siren)
    +16384 = Folding Mirrors installed/active
    +32768 = Highway/Comfort Turn Signals
    ... but comfort opening functions are NOT enabled:
    +00128 = Comfort Opening Driver Door Window
    +00256 = Comfort Opening Passenger Door Window
    +00512 = Comfort Opening Rear Left Window
    +01024 = Comfort Opening Rear Right Window
    Please add 1920 to 53344 for a new sum of 55264 and Test/Save that into channels 001 and 002.
  2. 061 (Comfort Operation: Opening) looks slightly odd but if that was the factory configuration I wouldn't mess with it:
    09947
    +1 = Power Windows via Remote Control
    +2 = Power Windows via Door Locks
    +8 = Front Sliding Roof via Remote Control
    +16 = Front Sliding Roof via Door Locks
    +64 = Rear Sliding Roof via Remote Control
    +128 = Rear Sliding Roof via Door Locks
    +512 = Roof Blinds via Remote Control
    +1024 = Roof Blinds via Door Locks
    +8192 = Front Sliding Roof to Tilt Position
  3. 062 (Comfort Operation: Closing) breaks down to:
    48059
    +8 = Power Windows via KESSY
    +16 = Front Sliding Roof via Remote Control
    +32 = Front Sliding Roof via Door Locks
    +128 = Front Sliding Roof via KESSY
    +256 = Rear Sliding Roof via Remote Control
    +512 = Rear Sliding Roof via Door Locks
    +2048 = Rear Sliding Roof via KESSY
    +4096 = Roof Blinds via Remote Control
    +8192 = Roof Blinds via Door Locks
    +32768 = Roof Blinds via KESSY
In conclusion I believe tweaks to channels 001 and 002 will get the comfort windows operating via remote.
