2009 vw jetta iam
jbt1969
CT, USA
C?ID=438213
iam having the worst i purchase a jetta and the vehicle had the wrong abs madule now that i got the wright one iam lost for a coding i
jbt1969
CT, USA
C?ID=438213
Wednesday,31,March,2021,12:06:33:41971
VIN: 3VWRM71K19M006546   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRM71K19M006546   Mileage: 147950km-91931miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 P    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9970
   Revision: G6H01---    Serial number: VWX7Z0H524T0D9
   Coding: 0000075
   Shop #: WSC 48579 000 1048576
   VCID: 3B233D7FEF6F9FE39A1-806E
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - Intermittent - MIL ON
                    Fault Status: 10100000
                    Fault Frequency: 36
                    Mileage: 147955 km
                    Time: 09:20:05
                    Temperature: 64.0°C
                    Temperature: 20.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.700 V
Readiness: 0000 0100
   Part No SW: 09G 927 750 JE    HW: 09G 927 750 JE
   Component: AQ 250 6F           1377
   Revision: 00H76000    Serial number:
   Coding: 0000840
   Shop #: WSC 00066 000 00000
   VCID: 7DA7F367B1FB51D3E45-8028
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   VCID: 78A9E27392D974FBB73-802C
                    Fault Status: 00101101
                    Reset counter: 146
                    Mileage: 124537 km
                    Date: 2045.14.03
                    Time: 18:25:34
                    Count: 32768
                    Count: 12800
                    Count: 8193
                    Count: 50983
                    Reset counter: 18
                    Mileage: 147955 km
                    Count: 3
                    Count: 28672
                    Count: 195
                    Count: 43264
                    Count: 65280
                    Fault Status: 01100101
                    Reset counter: 18
                    Mileage: 147955 km
                    Count: 16391
                    Count: 16896
                    Count: 279
                    Count: 43520
                    Count: 65280
Hi and welcome.
Threads merged.
Please post the complete scan, not just the first three modules.
We received a nearly complete scan via email so I built the coding.
I believe 1K0 907 375 AD was factory installed using the 18 Byte coding scheme of:
113B400D49220000881002E8921F00413000
The new module is a revised 19 Byte version so that coding length won't fit. Instead you need to add a pair of zeros to the end of the factory string resulting in:
113B400D49220000881002E8921F0041300000
The Replacement steps on this page apply and the video in this thread should be helpful.
Full scan:
> www.Ross-Tech.com
> 01-Engine -- Status: Malfunction 0010
> 02-Auto Trans -- Status: OK 0000
> 03-ABS Brakes -- Status: Malfunction 0010
> 04-Steering Angle -- Status: OK 0000
> 08-Auto HVAC -- Status: Malfunction 0010
> 09-Cent. Elect. -- Status: Malfunction 0010
> 17-Instruments -- Status: Malfunction 0010
> 19-CAN Gateway -- Status: Malfunction 0010
> 25-Immobilizer -- Status: OK 0000
> 42-Door Elect, Driver -- Status: Malfunction 0010
> 46-Central Conv. -- Status: Malfunction 0010
> 62-Door, Rear Left -- Status: Malfunction 0010
> 72-Door, Rear Right -- Status: Malfunction 0010
>    Coding: 0000075
> 1 Fault Found:
> 001378 - System Voltage
>                P0562 - 000 - Too Low - Intermittent
>              Freeze Frame:
>                     Fault Status: 00100000
>                     Fault Priority: 0
>                     Fault Frequency: 1
>                     Reset counter: 255
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 22:03:35
>              Freeze Frame:
>                     RPM: 0 /min
>                     Load: 0.0 %
>                     Speed: 0.0 km/h
>                     Temperature: 8.0°C
>                     Temperature: 6.0°C
>                     Absolute Pres.: 1000.0 mbar
>                     Voltage: 7.620 V
> Readiness: 0110 1101
>    Coding: 0000840
> No fault code found.
>    Revision: 00H30001
> 5 Faults Found:
> 00668 - Supply Voltage Terminal 30
>             002 - Lower Limit Exceeded - Intermittent
>              Freeze Frame:
>                     Fault Status: 00100010
>                     Fault Priority: 1
>                     Fault Frequency: 1
>                     Reset counter: 18
>                     Mileage: 147955 km
>                     Time Indication: 0
>              Freeze Frame:
>                     Count: 7
>                     Count: 13
>                     Count: 12288
>                     Count: 128
>                     Count: 28416
>                     Count: 0
>                     Count: 65280
>                     Count: 0
>             000 - -
>              Freeze Frame:
>                     Fault Priority: 2
>                     Fault Frequency: 1
>                     Reset counter: 18
>                     Time Indication: 0
>              Freeze Frame:
>                     Count: 3
>                     Count: 12
>                     Count: 20992
>                     Count: 195
>                     Count: 39168
>                     Count: 0
>                     Count: 0
>                     Count: 0
>              Freeze Frame:
>                     Fault Priority: 2
>                     Fault Frequency: 1
>                     Reset counter: 18
>                     Mileage: 147955 km
>                     Time Indication: 0
>              Freeze Frame:
>                     Count: 3
>                     Count: 12
>                     Count: 12288
>                     Count: 279
>                     Count: 39424
>                     Count: 0
>                     Count: 0
>                     Count: 0
> 00778 - Steering Angle Sensor (G85)
>              Freeze Frame:
>                     Fault Priority: 2
>                     Fault Frequency: 1
>                     Reset counter: 18
>                     Mileage: 147955 km
>                     Time Indication: 0
>              Freeze Frame:
>                     Count: 3
>                     Count: 12
>                     Count: 12288
>                     Count: 295
>                     Count: 39424
>                     Count: 0
>                     Count: 0
>                     Count: 0
> 01423 - Lateral Acceleration Sensor (G200)
>              Freeze Frame:
>                     Fault Priority: 2
>                     Fault Frequency: 1
>                     Reset counter: 18
>                     Mileage: 147955 km
>                     Time Indication: 0
>              Freeze Frame:
>                     Count: 3
>                     Count: 12
>                     Count: 12288
>                     Count: 270
>                     Count: 39424
>                     Count: 0
>                     Count: 0
>                     Count: 0
> Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
>    Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
>    Component: Climatic PQ35   142 1111
>    Revision: 00142031    Serial number: 00000000000000
>    Shop #: WSC 00000 000 00000
>    VCID: 7CA1FE63AAE158DBD3B-8028
> 1 Fault Found:
> 00532 - Supply Voltage B+
> Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-M.lbl
>    Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
>    Component: Bordnetz-SG     H54 2202
>    Revision: 00H54000    Serial number: 00000000994772
>    Coding: 14058E234004150007140000001400000008730B5C000120000000000000
>    VCID: 6FBBD92FEB973343669-803A
>    Subsystem 1 - Part No: 1K1 955 119 E  Labels: 1KX-955-119.CLB
>    Component: Wischer 261008 021  0501
>    Coding: 00038805
>    Shop #: WSC 00066
> 1 Fault Found:
> 00446 - Function Limitation due to Under-Voltage
>              Freeze Frame:
>                     Fault Priority: 4
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2005.09.13
>                     Time: 31:63:63
>              Freeze Frame:
>                         OFF
>                     Voltage: 7.70 V
>                         OFF
>                         ON
>                         OFF
>                         OFF
>                         OFF
> Address 0F: Digital Radio        Labels: 8E0-035-593-SIR.lbl
>    Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
>    Component: SDAR SIRIUS     H07 0150
>    Revision: 00000000    Serial number: AUZ4Z7H0352722
>    Coding: 0000100
>    VCID: 3333155FC73F57A3421-8066
> 3 Faults Found:
>              Freeze Frame:
>                     Fault Priority: 7
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 21:59:41
>              Freeze Frame:
>                     Voltage: 8.40 V
>              Freeze Frame:
>                     Fault Priority: 7
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 21:59:09
>              Freeze Frame:
>                     Voltage: 8.40 V
> 02635 - Tuner Not Enabled/Activated
>             000 - -
>              Freeze Frame:
>                     Fault Priority: 7
>                     Fault Frequency: 1
>                     Reset counter: 18
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 21:30:58
> Address 15: Airbags        Labels: 1K0-909-605.lbl
>    Part No SW: 1K0 909 605 AB    HW: 1K0 909 605 AB
>    Component: 6A AIRBAG VW8R  034 8000
>    Revision: 05034000    Serial number: 003B6M05RWFZ
>    Coding: 0013889
>    VCID: 6C81CE23DA81C85B43B-8038
>    Subsystem 1 - Part No: 1K0 959 339 H
>    Component: BF-Gewichtsens. 007 0006
>    Subsystem 2 - Serial number: 6332MSME3B652A4FR
>    Subsystem 3 - Serial number: 6342MSME2C620778G
>    Subsystem 4 - Serial number: 6351HSME16504E4AB
>    Subsystem 5 - Serial number: 6361HSME1625192D7
>    Subsystem 6 - Serial number: 63727SME1557065D2
>    Subsystem 7 - Serial number: 63827SME1557296B7
> 1 Fault Found:
> Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
>    Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
>    Component: J0527           051 0101
>    Coding: 0010021
>    VCID: 0353859FD71F2723921-8056
> 6 Faults Found:
> 00576 - Terminal 15
>             012 - Electrical Fault in Circuit - Intermittent
> 00883 - Ignition Switch (D) Terminal S
> 00884 - Ignition Switch (D) Terminal X
> 01744 - Ignition Switch Terminal P (D)
> Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
>    Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
>    Component: KOMBIINSTRUMENT 3HL 1222
>    Revision: V0003000    Serial number: VWX7Z0H524T0D9
>    Coding: 0023203
>    VCID: 3C213E63EA6198DB93B-8068
> 2 Faults Found:
>              Freeze Frame:
>                     Fault Priority: 2
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 21:59:27
>              Freeze Frame:
>                     Fault Priority: 2
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 22:00:23
> Address 19: CAN Gateway        Labels:. 1K0-907-530-V3.clb
>    Part No SW: 1K0 907 530 Q    HW: 1K0 907 951
>    Component: J533  Gateway   H07 0062
>    Revision:   H07 01    Serial number: 110508F1001365
>    Coding: ED807F070003021002
>    VCID: 35372B47C94B49936C5-8060
> 1 Fault Found:
>              Freeze Frame:
>                     Fault Priority: 3
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 21:59:49
> Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
>    Component: IMMO            3HL 1222
> Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
>    Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
>    Component: J386  TUER-SG FT    1519
>    Revision: 72009005    Serial number: 00000063788617
>    Coding: 0001205
> 1 Fault Found:
> 01811 - Supply Voltage for Door Controller; Drivers Side (J386)
>              Freeze Frame:
>                     Fault Priority: 4
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
> Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
>    Part No: 1K0 909 144 C
>    Component: EPS_ZFLS Kl. 70     2301
>    Revision: 00H15000
>    Shop #: WSC 02069 000 90108
>    VCID: 2A0D083B10F5166BF17-807E
> 2 Faults Found:
>             005 - No or Incorrect Basic Setting / Adaptation - MIL ON
>              Freeze Frame:
>                     Fault Status: 11100101
>                     Fault Priority: 2
>                     Fault Frequency: 1
>                     Reset counter: 255
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 09:20:07
>              Freeze Frame:
>                     Battery Volts: 12.6 V
>                         DU
>                     Temperature: 15.0°C
>                     Count: 3
>                     Steering Angle: 0.00°
>                     Count: 1
>                         SteerAng n.Init
>              Freeze Frame:
>                     Fault Status: 00100100
>                     Fault Priority: 3
>                     Fault Frequency: 1
>                     Reset counter: 68
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 09:20:07
>              Freeze Frame:
>                     Voltage: 12.63 V
>                         DU
>                     Temperature: 15.0°C
>                     RPM: 0 /min
>                     Speed: 50.0 km/h
>                     Speed: 50.0 km/h
>                     Count: 0
> Address 46: Central Conv.        Labels:. 1K0-959-433-MAX.clb
>    Part No SW: 1K0 959 433 CT    HW: 1K0 959 433 CT
>    Component:    KSG PQ35 RDK 052 0221
>    Revision: 00052000    Serial number: 00000000000000
>    Coding: 13900F880186281B0904058FB0880F0488DCA0
>    VCID: 04518683D211201BABB-8050
>    Subsystem 1 - Component:   Sounder n.mounted
>    Subsystem 2 - Component:       NGS n.mounted
>    Subsystem 3 - Component:      IRUE n.mounted
> 1 Fault Found:
>              Freeze Frame:
>                     Fault Priority: 4
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 21:59:57
> Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
>    Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
>    Component: J387  TUER-SG BT    1519
>    Revision: 72009005    Serial number: 00000336688619
>    Coding: 0001204
>    VCID: 70B9DA53F6A92CBB7F3-8024
> 1 Fault Found:
> 01812 - Supply Voltage for Door Controller; Pass. Side (J387)
>              Freeze Frame:
>                     Fault Priority: 4
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
> Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
>    Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
>    Component: Radio DE2       016 0020
>    Revision: 00016000    Serial number: VWZ4Z7H2211214
>    Coding: 0010400
>    VCID: 290FF73715F31D73F8D-807C
> 1 Fault Found:
> 00003 - Control Module
>             014 - Defective
> Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
>    Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
>    Component: J388   TUER-SG HL   1120
>    Revision: 12006001    Serial number: 00000003189707
>    Coding: 0001168
>    VCID: 3E25346BFC7D8ACBBDF-806A
> 1 Fault Found:
> 01813 - Supply Voltage for Door Controller; Rear Left (J388)
>              Freeze Frame:
>                     Fault Priority: 4
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
> Address 65: Tire Pressure        Labels: 3C0-959-433-65.lbl
>    Component:    RDK              0450
>    Coding: 0100101
>    Shop #: WSC 131071 1023 2097151
> 2 Faults Found:
> 00625 - Vehicle Speed Signal
>             008 - Implausible Signal - Intermittent
>              Freeze Frame:
>                     Fault Status: 00111000
>                     Fault Priority: 4
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 21:59:18
> 00667 - Ambient Temperature Signal
>              Freeze Frame:
>                     Fault Priority: 4
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 22:03:35
> Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
>    Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
>    Component: J389   TUER-SG HR   1401
>    Revision: 12006001    Serial number: 00000003212688
>    Coding: 0001168
>    VCID: 77ABE14F93C77B83BE9-8022
> 1 Fault Found:
> 01814 - Supply Voltage for Door Controller; Rear Right (J389)
>              Freeze Frame:
>                     Fault Priority: 4
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
Relevant PR-codes:
Vehicle Identification No.    3VWRM71K19M006546
Model    Jetta
JEM
Date of production    04.07.2008
Model year    2009
Sales type    1K27S3
Engine Code    CBTA
Transmission Code    KGL
 G1A    6-speed automatic transmission
L0L    Left-hand drive
B0D    Part set, complying with vehicle type for USA (without California), various parts
0YG    Weight range 7 installation control only, no requirement forecast
1N3    Speed-related variable steering assist (Servotronic)
2UA    Standard design
1AT    Electronic stability control (ESC)
1ZP    Disc brakes in front (Geomet D)
1KE    Disc brakes in rear
7K4    Tire pressure monitoring system 315 MHz High
UG0    Without hill start assist/hill descent control/comfort driving assist
jbt1969
CT, USA
C?ID=438213
Hi and welcome.
Threads merged.
   Coding: 0000075
                    Fault Frequency: 36
                    Mileage: 147955 km
                    Time: 09:20:05
                    Temperature: 64.0°C
                    Temperature: 20.0°C
                    Voltage: 12.700 V
   Coding: 0000840
   Revision: 00H30001
                    Reset counter: 146
                    Mileage: 124537 km
                    Date: 2045.14.03
                    Time: 18:25:34
                    Count: 32768
                    Count: 12800
                    Count: 8193
                    Count: 50983
                    Reset counter: 18
                    Mileage: 147955 km
                    Count: 3
                    Count: 28672
                    Count: 195
                    Count: 43264
                    Count: 65280
                    Reset counter: 18
                    Mileage: 147955 km
                    Count: 16391
                    Count: 16896
                    Count: 279
                    Count: 43520
                    Count: 65280
                    Reset counter: 18
                    Mileage: 147955 km
                    Count: 16391
                    Count: 16896
                    Count: 295
                    Count: 43520
                    Count: 65280
                    Reset counter: 18
                    Mileage: 147955 km
                    Count: 16391
                    Count: 16896
                    Count: 270
                    Count: 43520
                    Count: 65280
   Coding: 00038805
   Shop #: WSC 00066
   Coding: 0000100
                    Reset counter: 5
                    Mileage: 147955 km
                    Time: 09:20:11
   Coding: 0013889
   Coding: 0010021
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
   Coding: 0023203
                    Fault Frequency: 51
                    Reset counter: 58
                    Mileage: 147955 km
                    Time: 09:20:00
                    Fault Status: 00110100
                    Reset counter: 58
                    Mileage: 147955 km
                    Time: 09:20:01
   Coding: 0001205
   Revision: 00H15000
                    Mileage: 147955 km
                    Time: 09:20:07
                        DU
                    Temperature: 15.0°C
                    Count: 3
                    Count: 1
                        SteerAng n.Init
                    Reset counter: 68
                    Mileage: 147955 km
                    Time: 09:20:07
                    Voltage: 12.63 V
                        DU
                    Temperature: 15.0°C
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
@jbt1969 -- The above scan ends at module 44. That's better than ending at 03, but it's still missing 46, 52, 56, 62, 65, and 72. ;)
jbt1969
CT, USA
C?ID=438213
jbt1969
CT, USA
C?ID=438213
   Coding: 0000075
                    Fault Frequency: 36
                    Mileage: 147955 km
                    Time: 09:20:05
                    Temperature: 64.0°C
                    Temperature: 20.0°C
                    Voltage: 12.700 V
   Coding: 0000840
   Revision: 00H30001
                    Reset counter: 146
                    Mileage: 124537 km
                    Date: 2045.14.03
                    Time: 18:25:34
                    Count: 32768
                    Count: 12800
                    Count: 8193
                    Count: 50983
                    Reset counter: 18
                    Mileage: 147955 km
                    Count: 3
                    Count: 28672
                    Count: 195
                    Count: 43264
                    Count: 65280
                    Reset counter: 18
                    Mileage: 147955 km
                    Count: 16391
                    Count: 16896
                    Count: 279
                    Count: 43520
                    Count: 65280
                    Reset counter: 18
                    Mileage: 147955 km
                    Count: 16391
                    Count: 16896
                    Count: 295
                    Count: 43520
                    Count: 65280
                    Reset counter: 18
                    Mileage: 147955 km
                    Count: 16391
                    Count: 16896
                    Count: 270
                    Count: 43520
                    Count: 65280
   Coding: 00038805
   Shop #: WSC 00066
   Coding: 0000100
                    Reset counter: 5
                    Mileage: 147955 km
                    Time: 09:20:11
   Coding: 0013889
   Coding: 0010021
00576 - Terminal 15
   Coding: 0023203
                    Fault Frequency: 51
                    Reset counter: 58
                    Mileage: 147955 km
                    Time: 09:20:00
                    Reset counter: 58
                    Mileage: 147955 km
                    Time: 09:20:01
   Coding: 0001205
   Revision: 00H15000
                    Mileage: 147955 km
                    Time: 09:20:07
                        DU
                    Temperature: 15.0°C
                    Count: 3
                    Count: 1
                        SteerAng n.Init
                    Reset counter: 68
                    Mileage: 147955 km
                    Time: 09:20:07
                    Voltage: 12.63 V
                        DU
                    Temperature: 15.0°C
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
:banghead:
South Molton, UK
@jbt1969 - open the .txt file of the Auto-Scan that VCDS auto-saves in the C:\Ross-Tech\VCDS\Scans folder (IIRC) in Notepad, The click on Edit-Select All and Copy.
Then paste that here using the </> icon in the forum editor.
That will copy and paste the complete Auto-Scan which Uwe is asking for.
jbt1969
CT, USA
C?ID=438213
72-Door, Rear Right -- Status: OK 0000 i hope this is what u ask for i am very desper trying to fix this isue
South Molton, UK
Nope, that's just an edited version of mostly the Gateway Installation List - we REALLY need the complete Auto-Scan, don't edit ANYTHING just Select All and Copy & Paste the entire Auto-Scan :banghead:
jbt1969
CT, USA
C?ID=438213
thank you for the coding work but my abs stay on do to value 60 error
jbt1969
CT, USA
C?ID=438213
   Coding: 0000075
                    Mileage: 147955 km
                    Time: 22:03:35
                    Temperature: 8.0°C
                    Temperature: 6.0°C
                    Voltage: 7.620 V
Readiness: 0010 0101
   Coding: 0000840
   Revision: 00H30001
   Coding: 113B400D49220000881002E8921F0041300000
   Shop #: WSC 00066 123 12345
01486 - System Function Test Activated
                    Reset counter: 21
                    Mileage: 147955 km
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 320
                    Count: 43520
                    Count: 65280
                    Reset counter: 21
                    Mileage: 147955 km
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 279
                    Count: 43520
                    Count: 65280
                    Reset counter: 21
                    Mileage: 147955 km
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 270
                    Count: 43520
                    Count: 65280
   Coding: 00038805
   Shop #: WSC 00066
   Coding: 0000100
                    Reset counter: 21
                    Mileage: 147955 km
                    Time: 22:15:35
   Coding: 0013889
   Coding: 0010021
00576 - Terminal 15
   Coding: 0023203
   Coding: 0001205
   Revision: 00H15000
   Coding: 0001204
   Coding: 0010400
            014 - Defective
   Coding: 0001168
   Coding: 0100101
   Coding: 0001168
End----(Elapsed Time: 01:19, VBatt start/end: 12.1V/11.8V. VIgn 11.9V)-----
jbt1969
CT, USA
C?ID=438213
Full scan:
> www.Ross-Tech.com
>    Coding: 0000075
> 1 Fault Found:
>              Freeze Frame:
>                     Fault Priority: 0
>                     Fault Frequency: 1
>                     Reset counter: 255
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 22:03:35
>              Freeze Frame:
>                     RPM: 0 /min
>                     Load: 0.0 %
>                     Speed: 0.0 km/h
>                     Temperature: 8.0°C
>                     Temperature: 6.0°C
>                     Voltage: 7.620 V
>    Coding: 0000840
>    Revision: 00H30001
> 5 Faults Found:
>              Freeze Frame:
>                     Fault Priority: 1
>                     Fault Frequency: 1
>                     Reset counter: 18
>                     Mileage: 147955 km
>                     Time Indication: 0
>              Freeze Frame:
>                     Count: 7
>                     Count: 13
>                     Count: 12288
>                     Count: 128
>                     Count: 28416
>                     Count: 0
>                     Count: 65280
>                     Count: 0
>             000 - -
>              Freeze Frame:
>                     Fault Priority: 2
>                     Fault Frequency: 1
>                     Reset counter: 18
>                     Time Indication: 0
>              Freeze Frame:
>                     Count: 3
>                     Count: 12
>                     Count: 20992
>                     Count: 195
>                     Count: 39168
>                     Count: 0
>                     Count: 0
>                     Count: 0
>              Freeze Frame:
>                     Fault Priority: 2
>                     Fault Frequency: 1
>                     Reset counter: 18
>                     Mileage: 147955 km
>                     Time Indication: 0
>              Freeze Frame:
>                     Count: 3
>                     Count: 12
>                     Count: 12288
>                     Count: 279
>                     Count: 39424
>                     Count: 0
>                     Count: 0
>                     Count: 0
>              Freeze Frame:
>                     Fault Priority: 2
>                     Fault Frequency: 1
>                     Reset counter: 18
>                     Mileage: 147955 km
>                     Time Indication: 0
>              Freeze Frame:
>                     Count: 3
>                     Count: 12
>                     Count: 12288
>                     Count: 295
>                     Count: 39424
>                     Count: 0
>                     Count: 0
>                     Count: 0
>              Freeze Frame:
>                     Fault Priority: 2
>                     Fault Frequency: 1
>                     Reset counter: 18
>                     Mileage: 147955 km
>                     Time Indication: 0
>              Freeze Frame:
>                     Count: 3
>                     Count: 12
>                     Count: 12288
>                     Count: 270
>                     Count: 39424
>                     Count: 0
>                     Count: 0
>                     Count: 0
> 1 Fault Found:
>    Coding: 00038805
>    Shop #: WSC 00066
> 1 Fault Found:
>              Freeze Frame:
>                     Fault Priority: 4
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2005.09.13
>                     Time: 31:63:63
>              Freeze Frame:
>                         OFF
>                     Voltage: 7.70 V
>                         OFF
>                         ON
>                         OFF
>                         OFF
>                         OFF
>    Coding: 0000100
> 3 Faults Found:
>              Freeze Frame:
>                     Fault Priority: 7
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 21:59:41
>              Freeze Frame:
>                     Voltage: 8.40 V
>              Freeze Frame:
>                     Fault Priority: 7
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 21:59:09
>              Freeze Frame:
>                     Voltage: 8.40 V
>             000 - -
>              Freeze Frame:
>                     Fault Priority: 7
>                     Fault Frequency: 1
>                     Reset counter: 18
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 21:30:58
>    Coding: 0013889
> 1 Fault Found:
>    Coding: 0010021
> 6 Faults Found:
> 00576 - Terminal 15
>    Coding: 0023203
> 2 Faults Found:
>              Freeze Frame:
>                     Fault Priority: 2
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 21:59:27
>              Freeze Frame:
>                     Fault Priority: 2
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 22:00:23
> 1 Fault Found:
>              Freeze Frame:
>                     Fault Priority: 3
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 21:59:49
>    Coding: 0001205
> 1 Fault Found:
>              Freeze Frame:
>                     Fault Priority: 4
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>    Revision: 00H15000
> 2 Faults Found:
>              Freeze Frame:
>                     Fault Priority: 2
>                     Fault Frequency: 1
>                     Reset counter: 255
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 09:20:07
>              Freeze Frame:
>                         DU
>                     Temperature: 15.0°C
>                     Count: 3
>                     Count: 1
>                         SteerAng n.Init
>              Freeze Frame:
>                     Fault Priority: 3
>                     Fault Frequency: 1
>                     Reset counter: 68
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 09:20:07
>              Freeze Frame:
>                     Voltage: 12.63 V
>                         DU
>                     Temperature: 15.0°C
>                     RPM: 0 /min
>                     Speed: 50.0 km/h
>                     Speed: 50.0 km/h
>                     Count: 0
> 1 Fault Found:
>              Freeze Frame:
>                     Fault Priority: 4
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 21:59:57
>    Coding: 0001204
> 1 Fault Found:
>              Freeze Frame:
>                     Fault Priority: 4
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>    Coding: 0010400
> 1 Fault Found:
>             014 - Defective
>    Coding: 0001168
> 1 Fault Found:
>              Freeze Frame:
>                     Fault Priority: 4
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>    Component:    RDK              0450
>    Coding: 0100101
> 2 Faults Found:
>              Freeze Frame:
>                     Fault Priority: 4
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 21:59:18
>              Freeze Frame:
>                     Fault Priority: 4
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
>                     Date: 2000.00.00
>                     Time: 22:03:35
>    Coding: 0001168
> 1 Fault Found:
>              Freeze Frame:
>                     Fault Priority: 4
>                     Fault Frequency: 1
>                     Reset counter: 58
>                     Mileage: 147955 km
>                     Time Indication: 0
Relevant PR-codes:
Model    Jetta
JEM
Model year    2009
Sales type    1K27S3
Engine Code    CBTA
L0L    Left-hand drive
2UA    Standard design
   Coding: 0000075
                    Mileage: 147955 km
                    Time: 22:03:35
                    Temperature: 8.0°C
                    Temperature: 6.0°C
                    Voltage: 7.620 V
   Coding: 0000840
   Revision: 00H30001
                    Reset counter: 21
                    Mileage: 147955 km
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 320
                    Count: 43520
                    Count: 65280
                    Reset counter: 21
                    Mileage: 147955 km
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 279
                    Count: 43520
jbt1969
CT, USA
C?ID=438213
is that is what is 60 value error because i try to doit again stiill come back error
jbt1969
CT, USA
C?ID=438213
@jbt1969 It looks like you have not done all the Basic Settings yet.
goodmorning the coding is good everything is in good standing the jetta is done no more abs tration brake light all good because of ur help thank you very much i never worke on vw i only work on gm honda chrysler ford i am a mechanich at the job i work i apriciated thank you
