Are these MAP sensor connector readings nominal?
Nimbus2100
C?ID=434390
I have a 2011 VW Jetta SE (manual) and I've been dealing with a MAP sensor problem for a while now. The sensor was replaced at a dealer and the car was back to rough running, misfiring, P0106, P0300, and P0507 after just a few weeks. With the key on and ignition off, I took a multimeter and measured the voltage coming from the MAP sensor connectors and these were the readings that I got:
1) 7.4mV
2) 4.71V
3) 5.04V
4) 5.70V
Do these numbers seem nominal? I think #1 is be the ground wire and shouldn't that read 0? Where does one even check what these readings should be? Thank you for the help.
- VCDS Rookie
Nimbus2100
C?ID=434390
Hi and welcome. Please post an Auto-Scan for context.
Do you have a wiring diagram for this car yet? If not, you should probably get one.
Thank you for the link; I don't have a wiring diagram for the car and can definitely use one.
Here's the auto scan from about a month ago:
Wednesday,03,March,2021,18:08:43:19599
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 56 77
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 DJ    HW: 07K 906 055
   Component: 2,5l R5/4V      G01 5684
   Revision: T4H04---    Serial number:
   Coding: 0000071
   Shop #: WSC 25145 444 100151
   VCID: 79AFE7DB75DD9A3334C-802C
001287 - Idle Control System RPM
               P0507 - 000 - Higher than Expected. - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 203425 km
                    Date: 2015.06.20
                    Time: 04:58:03
                    RPM: 919 /min
                    Load: 46.6 %
                    Temperature: 81.0°C
                    Temperature: 54.0°C
                    Absolute Pres.: 820.0 mbar
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
               P0106 - 000 - Implausible Signal
                    Mileage: 203426 km
                    Date: 2015.06.20
                    Time: 04:59:51
                    RPM: 730 /min
                    Load: 18.4 %
                    Speed: 40.0 km/h
                    Temperature: 85.0°C
                    Temperature: 53.0°C
               P0300 - 000 -
                    Mileage: 203433 km
                    Date: 2015.07.01
                    Time: 00:02:27
                    RPM: 894 /min
                    Load: 36.1 %
                    Temperature: 4.0°C
                    Temperature: 4.0°C
                    Absolute Pres.: 810.0 mbar
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected
                    Mileage: 203433 km
                    Date: 2015.07.01
                    Time: 00:03:21
                    RPM: 934 /min
                    Load: 29.8 %
                    Temperature: 13.0°C
                    Temperature: 4.0°C
   Revision: 00H31001
   Coding: B14B440C492B08FC8D1022E4921B1061A70000
   Shop #: WSC 00066 000 00000
   VCID: 7BA3FDD373E1A823260-802E
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 251
                    Mileage: 203426 km
                    Date: 2015.06.20
                    Time: 04:59:52
                    Count: 16384
                    Count: 32768
                    Count: 12800
                    Count: 8193
                    Count: 47360
                    Count: 1010
                    Count: 4608
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 Q    HW: 5C0 820 047 Q
   Component: J301  Klimaanlage   0103
   Revision: 2000908S    Serial number: 00000000402837
   VCID: 2E050487FC138D8BD1E-807A
03934 - Control Circuit for Seat Heating; Front Left
                    Fault Status: 00111011
                    Reset counter: 245
                    Mileage: 203353 km
                    Date: 2015.06.13
                    Time: 18:55:45
   Part No SW: 5C0 937 086 C    HW: 5C0 937 086 A
   Component: BCM25 JLB M3  H67 0226
   Revision: B0067001    Serial number: 03291155110085
   Coding: 7B994B1808AB0B0000382000240884C500C2502E60000000300000000000
   VCID: 2C010E8FC60FFF9BFFA-8078
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3464
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3464
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H07 0013
   Serial number: 0256348
   Coding: 020000
   Subsystem 4 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3464
   Coding: 800000
   Subsystem 5 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3464
   Coding: 800000
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   013 0807
   Serial number: 003GTM0048FB
   Coding: 00003936
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 343116EF1EBFA75BA7A-8060
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y1100004N0B07
   Coding: 303241
   Serial number: 3572MSME7005135EZZZS
   Serial number: 3582MSME4016135EZZZS
   Serial number: 3516KSME60684E10ZZZS
   Serial number: 3526KSME7A255010ZZZK
   Serial number: 3556LSME130A3E0FZZZ/
   Serial number: 3566LSME16243E0FZZZ/
   Part No SW: 5C6 920 950 D    HW: 5C6 920 950 D
   Component: KOMBI         H07 0407
   Coding: 270201
   Shop #: WSC 00066 000 00145
   VCID: 2B030D93C381F8A3F60-807E
   Part No SW: 6N0 909 901     HW: 5C0 937 086 A
   Component: GW-K-CAN TP20 0226
   Coding: 102200
   VCID: 70B9DAFF2AA7DB7B832-8024
   Component: IMMO          H07 0407
   VCID: 6A8DC8970CFB21ABCD6-803E
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Revision: A1001003    Serial number: 7669761661
   VCID: 2809F29FD2F7D3BB1B2-807C
03138 - Input AUX IN
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 220
                    Mileage: 202723 km
                    Date: 2015.05.11
                    Time: 03:01:59
   Part No SW: 1K0 035 164     HW: 1K0 035 164
   Component: LOW NAR SDARS H14 0043
   Revision: -----06S    Serial number: VWZ4Z6L3143582
   Coding: 0100040002
   VCID: 5F9BA943C73954032A8-800A
                    Reset counter: 220
                    Mileage: 202723 km
                    Date: 2015.05.11
                    Time: 03:01:58
   Part No SW: 5K0 035 730 G    HW: 5K0 035 730 G
   Component: TELEFON       H09 1031
   Revision: 1B001001    Serial number: 00007661963999
   Coding: 0A00000000010100
   Shop #: WSC 25145 444 04885
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 290FF79BC97DEAB304C-807C
End----(Elapsed Time: 01:09, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Since then, I've removed the MAP sensor, cleaned it with electronic cleaner, reinstalled, cleaned the throttle body, readapted throttle body, cleared codes. Different codes came back (P0108 and P0113) but the car still runs rough, I can still hear it misfiring, and is much the same. This is also when I used the multimeter to test the connections to the MAP sensor and got the readings in my first post. I can also provide this auto scan if you think it'll help.
The newer scan may add clarity but 001287 combined with 000262 is likely the end result of a vac leak and the PCV system (the entire valve cover on this model) was a very common issue on the 2.5L.
Nimbus2100
C?ID=434390
Thank you for the reply. Is replacing the circular pcv diaphragm enough or are you saying the whole cover and gasket should be replaced? I've added the newer scan in case it would help.
Monday,05,April,2021,19:32:19:19599
   Coding: 0000071
   VCID: 79AFE7DB75DD9A33C8D-802C
000264 - Manifold / Barometric Pressure Sensor (G71) / (F96)
               P0108 - 000 - Signal too High
                    Mileage: 203433 km
                    Date: 2015.08.27
                    Time: 02:42:34
                    Temperature: 45.0°C
                    Temperature: -40.0°C
000275 - Intake Air Temp. Sensor (G42)
               P0113 - 000 - Signal too High
                    Mileage: 203433 km
                    Date: 2015.08.27
                    Time: 02:42:38
                    Temperature: 45.0°C
Readiness: 1110 0101
   Revision: 00H31001
   VCID: 7BA3FDD373E1A823DA1-802E
                    Reset counter: 251
                    Mileage: 203433 km
                    Date: 2015.08.27
                    Time: 02:43:09
                    Count: 2
                    Count: 12544
                    Count: 8193
                    Count: 42496
                    Count: 513
                    Count: 512
   VCID: 2E050487FC138D8B2DF-807A
   VCID: 2C010E8FC60FFF9B03B-8078
   Coding: 820000
   Coding: 820000
   Coding: 020000
   Coding: 800000
   Coding: 800000
   Coding: 00003936
   VCID: 343116EF1EBFA75B5BB-8060
   Coding: 303241
   Coding: 270201
   VCID: 2B030D93C381F8A30A1-807E
   Coding: 102200
   VCID: 70B9DAFF2AA7DB7B7F3-8024
   VCID: 6A8DC8970CFB21AB317-803E
   VCID: 2809F29FD2F7D3BBE73-807C
                    Reset counter: 251
                    Mileage: 203433 km
                    Date: 2015.08.27
                    Time: 02:45:29
   Coding: 0100040002
   VCID: 5F9BA943C7395403D69-800A
                    Reset counter: 251
                    Mileage: 203433 km
                    Date: 2015.08.27
                    Time: 02:43:09
   ROD: EV_UHVNA_A01_VW25.rod
   VCID: 290FF79BC97DEAB3F8D-807C
End----(Elapsed Time: 01:07, VBatt start/end: 12.1V/11.8V. VIgn 11.9V)-----
Nimbus2100
C?ID=434390
This worked like a charm. I spent $20 on a pcv diaphragm and sure enough the old one was cracked and causing the vac leak. All my stupid guessing, 2 trips to the dealership paying hundreds doesn't compare to a forum's response. Who knew. I can't thank you enough.
