BeeTDi
Hello everyone.
Ima just make this short and sweet. If you need more info i can reply.
My abs module got its long code deleted and i have no record of the original and this was the only place where i can find where people know how to get them.
The car is from canada. If you need more codes pulled i will try ky best to get them. I am not sure how to get advanced id codes as i have obdeleven.
Thank you very much.
This is the code i pulled.
OBDeleven data log
OBDeleven data log
Date: 2021-04-06 14:50
VIN: 3VWHL81KX9M171760
Car: Volkswagen Jetta
Year: 2009
Body type: Saloon
Engine: CBEA 103 kW (140 HP) 2.0 l
Mileage: 228040 KM
01 Engine
System description: R4 2,0L EDC G000AG
Software number: 03L997016P
Software version: 8681
Hardware number: 03L906022J *
Hardware version: 78
Serial number: VWX7Z0I424L0DG
Coding: 0350078
Trouble codes:
No trouble codes found
02 Transmission
System description: GSG DSG AG6 440
Software number: 02E300052
Software version: 1914
Hardware number: 02E927770AJ
Hardware version: E10
Serial number: 00000904070466
Trouble codes:
03 Brakes
System description: ESP MK60EC1
Software number: 1K0907379CE
Software version: 0120
Hardware number: 1K0907379AE
Hardware version: H35
Long coding: 000000000000000000000000000000000000
Trouble codes:
00003 - Control module no or incorrect basic setting/adaptation
static
04 Steering Angle Sensor
Trouble codes:
08 Air Conditioning
System description: Climatic PQ35 143
Software number: 1K0820047JE
Software version: 1313
Hardware number: 1K0820047JE
Trouble codes:
00229 - Refrigerant pressure Lower limit not reached
static
09 Central Electrics
System description: Bordnetz-SG H54
Software number: 3C8937049D
Software version: 2602
Hardware number: 3C8937049D
Hardware version: 063
Serial number: 00000009265919
Long coding: 10018E234004150007140000001400000008730B5C000120000000000000
Trouble codes:
15 Airbag
System description: 08 AIRBAG VW8R 036
Software number: 1K0909605AD
Software version: 8900
Hardware number: 1K0909605AD
Hardware version: 003
Serial number: 003EVM00CN2L
Coding: 0012344
Trouble codes:
16 Steering Column
System description: J0527 053
Software number: 1K0953549CP
Software version: 0111
Hardware number: 1K0953549CP
Coding: 0001031
Trouble codes:
00576 - Terminal 15 Electrical error in circuit
Intermittent
00883 - Ignition/starter switch (terminal S) Electrical error in circuit
Intermittent
00884 - Ignition/starter switch (terminal X) Electrical error in circuit
Intermittent
01744 - Ignition/Starter Switch D (terminal P) Electrical error in circuit
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
17 Dashboard
System description: KOMBIINSTRUMENT 3HL
Software number: 1K0920854D
Software version: 1222
Hardware number: 1K0920854D
Hardware version: 000
Coding: 0023303
Trouble codes:
19 Gateway
System description: J533 Gateway H07
Software number: 1K0907530S
Software version: 0071
Hardware number: 1K0907951
Serial number: 220409F1001826
Long coding: ED807F06000202001002
Trouble codes:
25 Immobilizer
System description: IMMO 3HL
Trouble codes:
42 Driver Door
System description: J386 TUER-SG FT
Software number: 1K0959701AC
Software version: 1519
Hardware number: 1K0959793N
Hardware version: 222
Serial number: 00000511598505
Coding: 0001205
Trouble codes:
44 Steering Assistance
System description: EPS_ZFLS Kl. 70
Software number: 1K0909144E
Software version: 2501
Trouble codes:
46 Comfort System
System description: KSG PQ35 G2 020
Software number: 1K0959433CA
Software version: 0204
Hardware number: 1K0959433CA
Long coding: 13900F880106281B0904058FB0880F0488FCA0
Trouble codes:
52 Passenger Door
System description: J387 TUER-SG BT
Software number: 1K0959702AC
Hardware number: 1K0959792N
Hardware version: 157
Serial number: 08122604341101
Coding: 0001204
Trouble codes:
56 Radio
System description: Radio DE2 016
Software number: 1K0035180M
Software version: 0020
Hardware number: 1K0035180M
Serial number: VWZ4Z7J3168291
Coding: 0040401
Trouble codes:
62 Rear Left Door
System description: J388 TUER-SG HL
Software number: 1K0959703AH
Software version: 1401
Hardware number: 1K0959795T
Hardware version: 159
Serial number: 00000003923737
Coding: 0001168
Trouble codes:
72 Rear Right Door
System description: J389 TUER-SG HR
Software number: 1K0959704AH
Hardware number: 1K0959794T
Hardware version: 161
Serial number: 00000003930840
Coding: 0001168
Trouble codes:
