I have audi s5 from canada. I want change turn red with turn orange. possible coding?
I send autoscan
Thanks
I send autoscan
Tuesday,06,April,2021,13:51:53:41448
VCDS Version: 21.3.0.0 HEX-V2 CB: 0.4543.4
Dealer/Shop Name: WWW.TECHTRONIC.FR
VIN: WAUCVBFR4AA028795 License Plate:
Mileage: 220400km-136950mi Repair Order:
Chassis Type: FR-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 2E 36 42 46 47 52 53 55
56 77
VIN: WAUCVBFR4AA028795 Mileage: 220400km-136950miles
05-Acc/Start Auth. -- Status: Malfunction 1010
2E-Media Player 3 -- Status: Malfunction 0010
Address 01: Engine (J623-CAUA) Labels:. 079-907-560-CAU.clb
Part No SW: 8T0 907 560 C HW: 8T0 907 560
Component: 4.2l V8/4V H10 0002
Revision: 76H10---
Coding: 01140003190F0120
Shop #: WSC 01211 210 175149
VCID: 3A2D3471CC55875B817-806E
005493 - Right Engine Mount Solenoid Valve (N145)
P1575 - 001 - Short to Plus
Fault Status: 01100001
Mileage: 220402 km
Date: 2009.08.16
Time: 17:17:21
RPM: 1817 /min
Load: 46.3 %
Temperature: 15.0°C
Temperature: 23.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 10.033 V
Readiness: 0110 1101
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8K0 927 158 H HW: 0B6 927 156
Component: 0B6 42 FSIRdW H05 0005
Revision: --H05---
Coding: 001011
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMAL651 A01006
ROD: EV_TCMAL651.rod
VCID: 3B233175C3EFBE539A1-806E
4785 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [032] - -
Mileage: 220338 km
Date: 2009.06.28
Time: 01:45:25
Engine RPM: 0.00 /min
Transmission input speed: 0 /min
Engine torque: 0 Nm
ATF temperature: 11 °C
Accelerator pedal position: 60.0 %
Clutch status: 0
Unlearning counter according OBD: 18
2469 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [032] - -
Mileage: 220338 km
Date: 2009.06.28
Time: 01:45:25
Engine torque: 0 Nm
Clutch status: 0
2505 - Torque Management Feedback Signal A
P2637 00 [032] - -
Mileage: 220338 km
Date: 2009.06.26
Time: 05:03:38
Engine torque: 0 Nm
Accelerator pedal position: 0.0 %
Clutch status: 0
4774 - Body Control Module (Central Electric 2)
U0141 00 [032] - No Communications
Mileage: 220338 km
Date: 2009.06.26
Time: 00:07:44
Engine torque: 0 Nm
ATF temperature: 9 °C
Clutch status: 0
4778 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [040] - -
Mileage: 220338 km
Date: 2009.06.28
Time: 01:45:26
Engine torque: 0 Nm
Clutch status: 0
Unlearning counter according OBD: 27
Part No SW: 8K0 907 379 AL HW: 8K0 907 379 AL
Component: ESP8 quattro H04 0080
Coding: 120500
VCID: 03538995FB1F0693921-8056
7 Faults Found:
Fault Frequency: 28
Reset counter: 92
Mileage: 220338 km
Date: 2009.06.27
Time: 05:59:08
Hex Value: 0x0040
Hex Value: 0x0782
Hex Value: 0x0027
Hex Value: 0xB9A3
Hex Value: 0x00FF
Fault Status: 00101101
Fault Frequency: 23
Reset counter: 92
Mileage: 220338 km
Date: 2009.06.27
Time: 05:59:08
Hex Value: 0x0000
Hex Value: 0x2782
Hex Value: 0x002E
Hex Value: 0x02A3
Hex Value: 0x00FF
Reset counter: 92
Mileage: 220338 km
Date: 2009.06.29
Time: 03:52:02
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x001C
Hex Value: 0x7AC4
Hex Value: 0x00FF
Fault Status: 00100001
Fault Frequency: 26
Reset counter: 92
Mileage: 220338 km
Date: 2009.06.29
Time: 03:52:17
Hex Value: 0x0040
Hex Value: 0x0280
Hex Value: 0x0003
Hex Value: 0x22D2
Hex Value: 0x00FF
Fault Frequency: 6
Reset counter: 92
Mileage: 220338 km
Date: 2009.06.26
Time: 00:00:42
Hex Value: 0x0000
Hex Value: 0x1280
Hex Value: 0x0003
Hex Value: 0x2460
Hex Value: 0x00FF
Fault Frequency: 28
Reset counter: 92
Mileage: 220338 km
Date: 2009.06.27
Time: 05:59:08
Hex Value: 0x0040
Hex Value: 0x0782
Hex Value: 0x0027
Hex Value: 0xB9A3
Hex Value: 0x00FF
Reset counter: 92
Mileage: 220338 km
Date: 2009.06.27
Time: 17:46:56
Hex Value: 0x00C0
Hex Value: 0x1782
Hex Value: 0x0025
Hex Value: 0x86D8
Hex Value: 0x00FF
Part No SW: 8K0 907 064 DG HW: 8K0 907 064 DG
Component: BCM2 1.1 H02 0326
Coding: 0D0000
VCID: 78A9EE79B2D9554BB73-802C
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000075062010
02241 - Engine Control Module; Immobilizer Data not Adapted
Reset counter: 92
Mileage: 220338 km
Date: 2009.06.26
Time: 00:08:05
03286 - Sensor for Contact with Door Handle; Front Right
Fault Status: 00100111
Reset counter: 103
Mileage: 220388 km
Date: 2009.06.26
Time: 00:00:00
03287 - Sensors for Contact with Door Handles
Fault Status: 00101010
Reset counter: 103
Mileage: 220388 km
Date: 2009.07.08
Time: 23:28:25
