CHANGE light usa of europ
Nicotech
France
C?ID=398148
I have audi s5 from canada. I want change turn red with turn orange. possible coding?
I send autoscan
Tuesday,06,April,2021,13:51:53:41448
VCDS Version: 21.3.0.0  HEX-V2 CB: 0.4543.4
Dealer/Shop Name: WWW.TECHTRONIC.FR
VIN: WAUCVBFR4AA028795   License Plate:
Mileage: 220400km-136950mi   Repair Order:
Chassis Type: FR-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 2E 36 42 46 47 52 53 55
          56 77
VIN: WAUCVBFR4AA028795   Mileage: 220400km-136950miles
05-Acc/Start Auth. -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
Address 01: Engine (J623-CAUA)       Labels:. 079-907-560-CAU.clb
   Part No SW: 8T0 907 560 C    HW: 8T0 907 560
   Component: 4.2l V8/4V    H10 0002
   Revision: 76H10---
   Coding: 01140003190F0120
   Shop #: WSC 01211 210 175149
   VCID: 3A2D3471CC55875B817-806E
005493 - Right Engine Mount Solenoid Valve (N145)
               P1575 - 001 - Short to Plus
                    Fault Status: 01100001
                    Mileage: 220402 km
                    Date: 2009.08.16
                    Time: 17:17:21
                    RPM: 1817 /min
                    Load: 46.3 %
                    Temperature: 15.0°C
                    Temperature: 23.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 10.033 V
Readiness: 0110 1101
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 H    HW: 0B6 927 156
   Component: 0B6 42 FSIRdW H05 0005
   Revision: --H05---
   Coding: 001011
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMAL651 A01006
   ROD: EV_TCMAL651.rod
   VCID: 3B233175C3EFBE539A1-806E
4785 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [032] - -
                    Mileage: 220338 km
                    Date: 2009.06.28
                    Time: 01:45:25
                    Engine RPM: 0.00 /min
                    Transmission input speed: 0 /min
                    Engine torque: 0 Nm
                    ATF temperature: 11 °C
                    Accelerator pedal position: 60.0 %
                    Clutch status: 0
                    Unlearning counter according OBD: 18
2469 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [032] - -
                    Mileage: 220338 km
                    Date: 2009.06.28
                    Time: 01:45:25
                    Engine torque: 0 Nm
                    Clutch status: 0
2505 - Torque Management Feedback Signal A
          P2637 00 [032] - -
                    Mileage: 220338 km
                    Date: 2009.06.26
                    Time: 05:03:38
                    Engine torque: 0 Nm
                    Accelerator pedal position: 0.0 %
                    Clutch status: 0
4774 - Body Control Module (Central Electric 2)
          U0141 00 [032] - No Communications
                    Mileage: 220338 km
                    Date: 2009.06.26
                    Time: 00:07:44
                    Engine torque: 0 Nm
                    ATF temperature: 9 °C
                    Clutch status: 0
4778 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [040] - -
                    Mileage: 220338 km
                    Date: 2009.06.28
                    Time: 01:45:26
                    Engine torque: 0 Nm
                    Clutch status: 0
                    Unlearning counter according OBD: 27
   Part No SW: 8K0 907 379 AL    HW: 8K0 907 379 AL
   Component: ESP8 quattro  H04 0080
   Coding: 120500
   VCID: 03538995FB1F0693921-8056
7 Faults Found:
                    Fault Frequency: 28
                    Reset counter: 92
                    Mileage: 220338 km
                    Date: 2009.06.27
                    Time: 05:59:08
                    Hex Value: 0x0040
                    Hex Value: 0x0782
                    Hex Value: 0x0027
                    Hex Value: 0xB9A3
                    Hex Value: 0x00FF
                    Fault Status: 00101101
                    Fault Frequency: 23
                    Reset counter: 92
                    Mileage: 220338 km
                    Date: 2009.06.27
                    Time: 05:59:08
                    Hex Value: 0x0000
                    Hex Value: 0x2782
                    Hex Value: 0x002E
                    Hex Value: 0x02A3
                    Hex Value: 0x00FF
                    Reset counter: 92
                    Mileage: 220338 km
                    Date: 2009.06.29
                    Time: 03:52:02
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x001C
                    Hex Value: 0x7AC4
                    Hex Value: 0x00FF
                    Fault Status: 00100001
                    Fault Frequency: 26
                    Reset counter: 92
                    Mileage: 220338 km
                    Date: 2009.06.29
                    Time: 03:52:17
                    Hex Value: 0x0040
                    Hex Value: 0x0280
                    Hex Value: 0x0003
                    Hex Value: 0x22D2
                    Hex Value: 0x00FF
                    Reset counter: 92
                    Mileage: 220338 km
                    Date: 2009.06.26
                    Time: 00:00:42
                    Hex Value: 0x0000
                    Hex Value: 0x1280
                    Hex Value: 0x0003
                    Hex Value: 0x2460
                    Hex Value: 0x00FF
                    Fault Frequency: 28
                    Reset counter: 92
                    Mileage: 220338 km
                    Date: 2009.06.27
                    Time: 05:59:08
                    Hex Value: 0x0040
                    Hex Value: 0x0782
                    Hex Value: 0x0027
                    Hex Value: 0xB9A3
                    Hex Value: 0x00FF
                    Reset counter: 92
                    Mileage: 220338 km
                    Date: 2009.06.27
                    Time: 17:46:56
                    Hex Value: 0x00C0
                    Hex Value: 0x1782
                    Hex Value: 0x0025
                    Hex Value: 0x86D8
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
   Component: BCM2 1.1      H02 0326
   Coding: 0D0000
   VCID: 78A9EE79B2D9554BB73-802C
   Serial number: 0209000075062010
02241 - Engine Control Module; Immobilizer Data not Adapted
                    Reset counter: 92
                    Mileage: 220338 km
                    Date: 2009.06.26
                    Time: 00:08:05
03286 - Sensor for Contact with Door Handle; Front Right
                    Fault Status: 00100111
                    Reset counter: 103
                    Mileage: 220388 km
                    Date: 2009.06.26
03287 - Sensors for Contact with Door Handles
                    Fault Status: 00101010
                    Reset counter: 103
                    Mileage: 220388 km
                    Date: 2009.07.08
                    Time: 23:28:25
South Molton, UK
Do the light fittings even have orange lenses?
siLc
Tallinn, Estonia
C?ID=330192
Most of the stuff that matter in regards to lights (modules 09 and 46) is missing from the autoscan.
Didn't NAR vehicles lack the rear fog light, which is definetly a legal requirement here in Europe? So probably in addition to coding, at least rear lights need to be changed to RoW lights?
Nicotech
France
C?ID=398148
the problem and when I brake the brake light shares the same location as the turn signal in the USA. in europe the indicators are amber and separate from the brake lights. europe turn is orange and separate brake
South Molton, UK
Sounds like you need to change the rear light clusters to Europe ones.
  • Agree
Nicotech
France
C?ID=398148
I think too. how found a europe modèle. Because my ref on the light cluster is usa.
my ref is 8t0945095e
