Move PID to measuring block
David_GTi_700
C?ID=426963
Hi guys.
I currently have a 2019 MQB GTI, the car has been tuned for flex fuel capabilities. My understanding of this is the actual flex fuel code is written by VW for the Brazilian market the tuners are highjacking this bit of code for use in euro/usa cars, and linking boost and timing tables to the reading.
Anyway, I am able to view fuel type and alcohol % under the OBDII section and this is great as a reference point for checking my blends when fuelling up.
Would it be possible to have this value added to the Advanced measuring blocks, having this as a reference point will make life a lot simpler when working with custom boost vs ethanol content in the logs.
Many Thanks
Please post an Auto-Scan from your car so we can see exactly what ECU the car has and what software is in it.
David_GTi_700
C?ID=426963
I will grab one when the car is back from the tuner.
ECU is a simos 18.10 with software 5G0 906 259 S
Check in your Scans sub-folder:
C:\Ross-Tech\VCDS\Scans
If you're ever done an Auto-Scan, there should be a copy there.
BTW, which OBD PID are you watching for the Fuel Composition?
David_GTi_700
C?ID=426963
Tuesday,14,April,2020,14:46:09:49607
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 20.4.0.1 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWZZZAUZKW102668   License Plate: PK19NTN
Mileage: 19202km-11931mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 29 2B 32 39 42 44 4B 52 5F
          75 A5 A9 D6 D7
VIN: WVWZZZAUZKW102668   Mileage: 19202km-11931miles
Address 01: Engine (J623-DKTB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 S    HW: 06K 907 425 J
   Revision: --H13---
   Coding: 0A2540124464050B3000
   ASAM Dataset: EV_ECM20TFS0205G0906259S 001003
   ROD: EV_ECM20TFS0205G0906259S.rod
   VCID: 3E24CED6D0FBA98B61E-806B
Readiness: 1110 0001
   Part No SW: 0GC 300 020 G    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2403
   Revision: 00H06V07
   ROD: EV_TCMDQ381061.rod
   VCID: 261406B6286B114B09E-8073
   Part No SW: 5Q0 614 517 EF    HW: 5Q0 614 517 BP
   Component: ESC           H35 0107
   Revision: 00000000    Serial number: 63558000000517
   Coding: 01FA93A15020216E477D060660CB6980C90A84E26006967738425079D2284B0B0000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 79AE1DCA89554EB314C-802D
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0503849326
   Coding: 132C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D2BF22BB19C4630E0-8017
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0012000420011001110500400010102A
   VCID: 6D86399ACD1DE213884-8039
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Air quality sensor:
   Part No SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H38 0273
   Serial number: 00001900800099
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7CA004DE86677B9B0FA-8029
   Component: WWS    181103  042 0551
   Serial number:         181206071613
   Component: RLHS  052 0107
   Serial number: SAY19M01D16H19M31S00
   Coding: 00A8DD
   Serial number: 000000000ZY183300J00
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000012121808491700
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418019004
   Coding: 0471151811
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CC0941E96470B1BFFA-8019
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 330067C159FFC728949C810580400600000000000000000004
   VCID: 44D0BC3EBE17C35B37A-8011
   Part No SW: 5Q0 959 655 BT    HW: 5Q0 959 655 BT
   Component: AirbagVW21    007 0403
   Serial number: 003FNR4Y134S
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 13724F628BF994E3FE0-8047
   Belt Pretensioner left:
   Serial number: 34169677E14011920594
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676E15011951088
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 101 19
   Serial number: 3570000000056C60B53K
   Subsystem 4 - Part No SW: -----------    HW: 480 001 001 19
   Serial number: 358000000008819CE63Y
   Subsystem 5 - Part No SW: -----------    HW: 480 401 501 19
   Component: SideSensor_Dr  004 6149
   Serial number: 3510001042B72273576N
   Subsystem 6 - Part No SW: -----------    HW: 480 401 501 19
   Component: SideSensor_Pr  004 6149
   Serial number: 35200010C2B805B5C2B4
   Subsystem 7 - Part No SW: -----------    HW: 480 401 101 19
   Serial number: 35500012C2BFB78422EI
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         403 4191
   Coding: 23AD11186F84060001886B031401000800000000
   VCID: 2B02F78233892C23D60-807F
   Serial number: 12121810521635
   Coding: 030100047F085900FB00027F1C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E843E96C01B190BB1E-803B
   Component: 0-00-03-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29180002995350018506
   Coding: 2DFFFF
   Serial number: 9089320105
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   VCID: 47CAAB328F21E843D28-8013
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 18000402765011
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313EE5EA11A546F3ECC-8065
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H55 8043
   Serial number: HA1-00030.11.18
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52FC8A6674635DEBB56-8007
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007RLH06515
   Coding: 003F1220D001048000001000
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000026379878
   Coding: 0D0000
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 91170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C20C4DEC6E7BB9B4FA-8069
   Component: FCM MQB Low   002 0345
   Serial number: 22121811600198
   Coding: 00000005090016CE01204F01020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 3536D1FAE5CD6AD3B04-8061
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007RLE1289A
   Coding: 003F1020DC01048000001000
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000026228284
   Coding: 150000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0891
   Coding: 02731001FF00000041110101008808001F0503F6012000008E
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 323CEAE614A37DEB956-8067
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHW0033062
   Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------
   Coding: 02730001EA42180D3F1CBE000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   VCID: 3D26C9DADDFDB293784-8069
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0272
   Serial number: 05091815P12297
   Coding: 0003070000000401000213448150A90094000E300040
   Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
   Serial number: 181128200530
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392EDDCAC9D58EB354C-806D
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----(Elapsed Time: 01:40, VBatt start/end: 11.7V/11.6V. VIgn 11.6V)-----
David_GTi_700
C?ID=426963
Pid 51 is fuel type
pid 52 is Alcohol %
   Revision: --H13---
Was this before the "Flex Fuel" code was put in the ECU?
Pid 51 is fuel type
pid 52 is Alcohol %
Measuring values in that ECU should already have:
IDE00608-ENG167462 -- Fuel type
But I'm not seeing anything resembling fuel composition or alcohol percentage.
David_GTi_700
C?ID=426963
yes this was a fair bit of time ago before we added the flex fuel code ( will get a updated scan when I get it back)
The part about it being missing was my point, would it be possible to have this field added to advanced measuring blocks? I have no idea if its a simple task since its available elsewhere in the software, or a total nightmare meaning its not worth it for the sub 250 people that might find it useful.
Thank you for taking the time to come back to me.
Eric
HC800000
It's somewhere inbetween. Are all 250 people going to be the same ASAM ID (EV_ECM20TFS0205G0906259S or whatever comes back in your new scan)?
David_GTi_700
C?ID=426963
I suspect not, the tuner has this running on 5 or 6 different box codes.
More people will join the party when Cobb release their version on the flex fuel code but for now its limited to code written in Winols, united motorsports platform or hp tuners platform.
That's the part I'm curious about. If the tuner uses software from a real flex-fuel ECU, and it properly identifies as such, then I'd expect to see "Fuel Composition" available in the Measuring Values. However, if they're doing a hack-job on the software (and it sounds like they are), then all bets are off.
David_GTi_700
C?ID=426963
I will attempt to find out from him ( and run a new scan when I have the car back)
My limited understanding is the base code is poached from the Brazilian ECU and pushed in to our ecus using Bflash tool in the relevant sectors
