Golf 5k cluster issue - blank in centre rest lights up immo issue coding issue?
justjames
C?ID=330612
have an odd issue with a 2013 golf cabrio
cluster lights up in each side binacle but the centre does not light up
not when you open door nor when you start car
car runs and stops immo active
cluster has coding of 010000 which can't be correct
here is a scan (ignore codes for items removed like light switches etc)
Monday,29,March,2021,15:53:18:10958
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
VIN: WVWZZZ1KZDK013177   License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 20 25 26 2E 42 44 46 52 56 61 62
          72 77
Address 01: Engine (J623-CFHC)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 GF    HW: 03L 907 309 N
   Component: R4 2.0l TDI   H28 9979
   Revision: 41H28---    Serial number: 00000000000000
   Coding: 00190012042501080000
   Shop #: WSC 64343 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018GF 003010
   ROD: EV_ECM20TDI01103L906018GA_VW36.rod
   VCID: 74A42C32DF91E12BD7-8020
4923 - Please Check Fault Codes in Instrument Cluster
          U1024 00 [039] - -
          [Instrument cluster control moduleRead out DTC]
                    Date: 2000.14.00
                    Time: 03:05:03
                    Engine RPM: 0.00 /min
                    Coolant temperature: 12 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 12.400 V
                    Exhaust gas temperature sensor 1: 20.0 °C
                    Exhaust gas temperature sensor 2: -0.0 °C
                    Exhaust gas temperature sensor 3: 8.4 °C
                    Exhaust gas temperature sensor 4: 7.2 °C
                    Shut-off timer: last engine shut-off time: 259 s
10065 - Mass Air Flow Sensor (G70)
          P0104 00 [167] - Intermittent
                    Date: 2000.14.00
                    Time: 03:05:01
                    Throttle valve adapter: specified value: 100.00 %
                    EGR Solen.val.: actual value: 98.44 %
                    Charge air pressure: specified value: 1025 hPa
                    Charge air pressure actuator: acknowledgment: 16.20 %
                    Air mass: specified value: 812.0 mg/stroke
                    Air mass: actual value (mg/stroke): 0.0 mg/stroke
4715 - No Communication with Instrument Cluster
          U0155 00 [038] - -
          [Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 11.700 V
                    Limitation: accelerator pedal: 126.7 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 40
                    selected gear-Bits 0-7: 0
   Revision: 00H31001
   Coding: 163B600D092300FD680C06EB90200092351050
   Shop #: WSC 00040 040 00001
   VCID: 7DB20916E4DBA063A8-8028
                    Reset counter: 48
                    Count: 2
                    Count: 20480
                    Count: 8208
                    Count: 43264
                    Count: 65280
03391 - Coding Not Possible
                    Reset counter: 48
                    Count: 2
                    Count: 20480
                    Count: 8254
                    Count: 44288
                    Count: 65280
                    Reset counter: 48
                    Count: 2
                    Count: 20480
                    Count: 8211
                    Count: 44288
                    Count: 65280
   Part No SW: 3AA 907 044 AG    HW: 3AA 907 044 AG
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 1010004003
   Shop #: WSC 00040 040 00015
   VCID: 75A21136D4EBF823E0-8020
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                    Reset counter: 88
   Part No SW: 1K0 937 086 R    HW: 1K0 937 086 R
   Component: BCM PQ35  M   111 0709
   Revision: AC111709
   Coding: 48000A3A8A25F100408820C8340481644B511588412085606480C7200051
   VCID: 3FCEB31EAE577273FA-806A
   Subsystem 1 - Part No SW: 5K7 955 119 A    HW: 5K7 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 16071  10  0605
   Coding: 009795
   Subsystem 2 - Part No: 5K7 955 559 A  Labels: 5K7-955-559.CLB
   Component: RLS 220213 02  24  0042
   Coding: 0228DD
   Subsystem 3 - Part No: 1Q0 951 171 A
   Component: DWA-Sensor 00  002 0205
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 48
                    Date: 2000.14.00
                    Time: 03:05:05
                    Voltage: 12.25 V
                        Term 50 Off
                    Reset counter: 88
                    Date: 2000.14.00
                    Voltage: 12.05 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 5K7 919 475 A    HW: 5K0 919 475 E
   Component: PARKHILFE 8K  H01 0007
   Revision: --------    Serial number: 12561304900729
   Coding: 108001
   VCID: 3B36C70EBA4F6E53D6-806E
                    Reset counter: 88
                    Temperature: 0.0°C
   Part No SW: 5C0 959 655 A    HW: 5C0 959 655 A
   Component: AirbagVW10    012 0906
   Serial number: 003EPD099GJM
   Coding: 00004348
   Shop #: WSC 01383 790 00003
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 302CE0226B099D0B73-8064
   Serial number: 3572MSME79165376ZZZ.
   Serial number: 3582MSME18175376ZZZW
12670208 - No Communication with Instrument Cluster
          U0155 00 [008] - -
                    Reset counter: 88
12674816 - Immobilizer Control Module
          U0167 00 [009] - No Communications
          [Lost Comminication with Immobilizer]
                    Reset counter: 48
                    Date: 2000.14.00
                    Time: 03:05:17
   Part No SW: 1K5 953 507 T    HW: 5K0 953 549 B
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90440MBK0019B
   Coding: 0082140000
   Shop #: WSC 00040 040 00016
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 42C8BAEAD5A51F9B95-8016
   Component: E221__MFL-TK6  H07 0022
   Serial number: 70000000000000591272
   Coding: E20000
Address 17: Instruments (J285)       Labels: None
   Component: KOMBI
   VCID: 55E271B6342B9823C0-8000
No ASAM data for: "Unknown" (VW36)
9453074 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 48
                    Date: 2000.14.00
                    Time: 00:00:24
10485825 - ROD - Unknown Error Code
          - 00 [137]
10485824 - ROD - Unknown Error Code
          - 00 [137]
13636608 - ROD - Unknown Error Code
          - 00 [009]
13635840 - ROD - Unknown Error Code
          - 00 [009]
   Part No SW: 7N0 907 530 AG    HW: 7N0 907 530 AG
   Component: J533  Gateway H53 1634
   Revision:   H53       Serial number: 050213F1000155
   Coding: 365001
   VCID: 75A21136DCEBF823E0-8020
                    Reset counter: 88
   Part No SW: 5K7 857 511 C    HW: 8J0 857 511 C
   Component: FLA           H03 0012
   Revision: AA002001
   Coding: 0102906B74745D545420363E01
   VCID: 3522D1369C6BB82320-8060
Address 25: Immobilizer
Address 26: Auto Roof        Labels: None
   Part No: 5K7 959 255 A
   Component: VSG GOLF  6     H16 0370
   VCID: 3B36C70E7A4F6E53D6-806E
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664463085
   Coding: 010100
   VCID: 2A18F24A45D5E7DBBD-807E
                    Reset counter: 88
   Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
   Component: Tuer-SG         009 2160
   Coding: 0152246
   VCID: 393ADD0670735C43C4-806C
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   VCID: 373EDB3E46674A3332-8062
            000 - - - MIL ON
                    Fault Status: 11100000
                    Date: 2000.14.00
                    Time: 03:05:46
                    Battery Volts: 12.4 V
                        DD
                    Temperature: 18.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
                    Reset counter: 88
                    Voltage: 12.00 V
                        DD
                    Temperature: 16.0°C
   Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
   Coding: 0152502
   VCID: 3A38C20A7575575BCD-806E
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195 H    HW: 3C8 035 195 H
   Component: Radio RCD510  005 0246
   Revision: 00000001    Serial number: VWZ1Z3N1910680
   Coding: 01000400020008
   VCID: 2D12F956743BF0E358-8078
                    Reset counter: 88
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AG
   Component: Batt.regelung H53 1634
   Coding: 030F1859
   VCID: 71AA2526A883D4033C-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000001491051111
   Part No SW: 8P7 959 811 B    HW: 8P7 959 811 B
   Component: Tuer-SG         H01 2103
   Coding: 0131216
   Shop #: WSC 00040 040 1012545
   VCID: 42C8BAEA1DA51F9B95-8016
   Part No SW: 8P7 959 812 B    HW: 8P7 959 812 B
   Coding: 0131216
   VCID: 43C6BFEE02BF16939E-8016
   Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
   Revision: 1B001001    Serial number: 00007664490079
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002_VW25.rod
   VCID: 393ADD06B8735C43C4-806C
          U0155 00 [008] - -
          [Kombiinstument: keine Kommunikation]
                    Reset counter: 88
End----------(Elapsed Time: 01:19, VBatt start/end: 12.3V/12.3V)-----------
justjames
C?ID=330612
forgot to say we can connect to the cluster with diag
It looks like you can connect to it, but it refuses to properly identify itself.
I don't suppose someone has been into this cluster with back-door tools?
First thing I would try is a cold boot. Disconnect both battery cables. Turn the ignition on. Then short the battery cables together (away from the battery!). Turn the ignition off. Reconnect the battery. I don't have real high hopes for this, but it doesn't cost much to try.
justjames
C?ID=330612
Hi UWE
no backdoor tools, its not like the cluster is dark and needs a reset as per mileage correction gone bad
do you know the login for it? not sure if it is refusing coding because needs a login? skc or 5 digit
all options greyed out except login and coding -
thanks
Spacewalker
Poland
C?ID=159607
For me seems is corrupted
Component: KOMBI
  • Agree
