2013 jetta 2.0l tdi timing belt replace question
mecjp2216
Canada
C?ID=236885
NIV: 3VWWL7AJ6DM400405
2013
Volkswagen
Jetta TDI
2.0 L 1968 CC L4 Diesel
first hello gang forum member
i have a question after replace the timing belt according to the procedure
is there a relearning to do
and where can I find the procedure on ross-tech if available
thank you very much
Nope, no scan tool procedure needed for a timing belt replacement on a car that new. The requirement to check pump timing with a scan tool was for the original distributor-pump TDI engines made between about 1992 and 2003.
mecjp2216
Canada
C?ID=236885
good news for me this is the first time I replace the timing belt on this car.I work on US and Asian cars often, thank for help
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Actually I would add this:
2004-2006 torsion value needs to be check with VCDS.
But like UWE said on 2009 + VCDS no need for timing belt.
