Golf MK7 seat retrofit
kakubaz
Zgorzelec, Poland
C?ID=314093
Hi, happy Easter!
I installed memory seats in my golf. For a long time I drove without pushing the lumbar out because it was not coded. Recently I decided to code it, but I am getting 4 errors popping up:
3 errors about missing calibration and 1 about basic settings. I have tried doing them both vcds, odis and manually. I have read on the forum that for each axis you have to hold the button all the way down, hold it for about 5 seconds, and hold it again in the same direction for another 5 seconds. For all the buttons on the seat this was successful except for the lumbar. Also the seat memory is gone and the position cannot be saved.
VIN: WVWZZZAUZFW088687   License Plate:
Mileage: 27067km-16818mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 2B 36 3C 42 44 47
          52 55 57 5F 65 69 6C 75 A5 A9 C0
VIN: WVWZZZAUZFW088687   Mileage: 27067km-16818miles
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EQ    HW: 04L 907 309 A
   Component: R4 2,0L EDC   H22 7540
   Revision: 81H22---
   Coding: 091D003A037405083000
   Shop #: WSC 50340 123 12345
   ASAM Dataset: EV_ECM20TDI01104L906021EQ 002008
   ROD: EV_ECM20TDI_002_VW37.rod
   VCID: 78AAE066C258167B4B2-802C
   Part No SW: 0D9 300 041 Q    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4504
   Revision: 03253104    Serial number: TFK01407271011
   ROD: EV_TCMDQ250021.rod
   VCID: 2616FE1E586C508B29E-8072
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 61036000000861
   Coding: 01FA6BA134280974037D0608C1CAA980D62C90C0608395F7386250884209
   Shop #: WSC 00046 000 00000
   VCID: 79ACE562F9520F7334C-802C
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0334274407
   Coding: 030C0C
   VCID: 3C223C76B6E0FA5B6FA-8068
   Part No SW: 5G1 907 044 AC    HW: 5G1 907 044 AC
   Revision: 00001K08
   Coding: 0302010420440101110501020010102A
   ASAM Dataset: EV_ACClimaBHBVW37X 006143
   VCID: 698CB52289F2BFF3C4C-803C
   Air quality sensor:
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001721001594
   ROD: EV_BCMBOSCH_018.rod
   VCID: 084A90A6B2B866FB3B2-805C
   Component: WWS    140719  043 0551
   Serial number:         140728004303
   Component: RLHS  042 0105
   Serial number: S2Y16M06D11H04M32S47
   Coding: 00A8DD
   Serial number: 000000000ZY161121VJ0
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000031321832
   Part No SW: 5QA 919 298 H    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0061
   Serial number: 000150057319299
   Coding: 0271667851
   Shop #: WSC 00029 028 00023
   ASAM Dataset: EV_EPHVA2CAU3700000 009048
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 55F489D2358A0B13704-8000
   Part No SW: 5Q0 907 572 R    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0771
   Coding: 33057FCBDDFFC728949F812781400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003_VW37.rod
   VCID: 46D65E9EF82CB08B09E-8012
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H15 0114
   Serial number: 06101241357420
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 76B6EE5EC84C600B59E-8022
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR07UCG9
   VCID: 7F580B7AE77621430A8-802A
   Left seat belt tensioner:
   Serial number: 34169667B15081440234
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169668B14081470562
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 708 14
   Serial number: 35767000000619A0701J
   Subsystem 4 - Part No SW: -----------    HW: 480 000 708 14
   Serial number: 35867000000917A0701L
   Subsystem 5 - Part No SW: -----------    HW: 480 401 208 14
   Serial number: 3516502AB16DB814339G
   Subsystem 6 - Part No SW: -----------    HW: 480 400 908 14
   Serial number: 3526502C316DB810F2AJ
   Subsystem 7 - Part No SW: -----------    HW: 480 401 308 14
   Serial number: 3556502A716FC223A12B
   Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 20111404220911
   Coding: 8C11
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 7BA0FF6AF36E3D63260-802E
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         403 4191
   Coding: 03ED21987E8C000807887F0F5501000080000000
   Shop #: WSC 12345 123 61029
   VCID: 2B000F2A438E6DE3F60-807E
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 G    HW: 5Q0 963 272 G
   Component: STH-MQB       008 0075
   Coding: 9309
   Shop #: WSC 00020 999 00000
   VCID: 3A2E3A6EBCD4C46B7D6-806E
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000325607
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   439 4344
   Revision: --------    Serial number: 0006901133
   Coding: 030100040B087300DB00027E9C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW37.rod
   VCID: 3D243172ADFAF353584-8068
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29160001206140056256
   Coding: 2D0000
   Serial number: 3553154103
131595 - Tire Pressure Monitoring Module
          U0127 00 [008] - No Communications
          [Timeout Knoten 0x0B / 65 - Steuergerät für Reifendrucküberwachung]
                    Fault Frequency: 23
                    Reset counter: 139
                    Mileage: 26947 km
                    Date: 2021.03.31
                    Time: 19:58:56
                    Terminal 30 power supply: 12.6 V
                    Terminal 15: OFF
          U1101 00 [008] - Active
                    Fault Frequency: 13
                    Reset counter: 139
                    Mileage: 26947 km
                    Date: 2021.03.31
                    Time: 19:56:14
                    Terminal 30 power supply: 12.8 V
                    Terminal 15: On
   Revision: 00000000    Serial number: 16000110545004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 343214569EB0321BA7A-8060
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0022
   Serial number: Y0006PGK12928
   Coding: 0010000000000500018280808080000000008080000000F400
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_SeatMemorDriveSide 002022
9654530 - Motor for Lumbar Support Height Adjustment
          B1351 02 [009] - Signal Failure
                    Reset counter: 99
                    Mileage: 27067 km
                    Date: 2021.04.05
                    Time: 11:18:34
9654868 - Motor for Lumbar Support Fore/Aft Adjustment
          B1352 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 99
                    Mileage: 27067 km
                    Date: 2021.04.05
                    Time: 11:18:34
9654612 - Motor for Lumbar Support Height Adjustment
          B1351 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 99
                    Mileage: 27067 km
                    Date: 2021.04.05
                    Time: 11:18:34
10489856 - No Basic Setting
          B2010 00 [009] - -
          [keine oder falsche Grundeinstellung/Adaption]
                    Reset counter: 99
                    Mileage: 27067 km
                    Date: 2021.04.05
                    Time: 11:18:34
   Part No SW: 5Q0 907 686 C    HW: 5Q0 907 686 B
   Serial number: 0420751365
   Coding: 02012103
   ROD: EV_HREntryHella_VW37.rod
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 B
   Component: HRE_Slave  H11 0081
   Serial number: 0372481293
   Coding: 020121
   Serial number: 27071401100114
   Coding: 003F1320DE00048200011000
   VCID: 43D0478ACB1E85A32E0-8016
   Serial number: 00000000000002348397
   Coding: 011000
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 9707
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3534295295CA2B13904-8060
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
   Coding: 12000000008AAA8A000000000000
   Shop #: WSC 73977 282 607910
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001004
   ROD: EV_AMPMst11CGen2ALPI.rod
   VCID: 2E06063E709C18CBD1E-807A
   Serial number: 17101300120325
   Coding: 003F1320DE00048200001000
   VCID: 42DE428ED4048CAB256-8016
   Serial number: 00000000000013255629
   Coding: 091000
   Coding: 029203000B000200
   VCID: 40DA4886DA089EBB332-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
Address 57: TV Tuner
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
   Part No SW: 565 035 021 D    HW: 565 035 021
   Component: MU-H-LND-EU   H54 1367
   Serial number: A853G0HB026915
   Coding: 02730201000000005111120200880833AF0102E481200400FF
   VCID: 0F78BBBAD7D631C3FA8-805A
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H40 9074
   Serial number: VWZ6ZFT0452530
   Subsystem 2 - Part No SW: V03 959 806 FN    HW: -----------
   Component: ECE 2020  --- 0184
   Compact disc data bank:
   Component: Gracenote2  --- 1016
   Serial number: 30000000001722
   ROD: EV_RDKBERU30_006_VW37.rod
   Part No SW: 5Q0 907 383 F    HW: 5Q0 907 383 C
   Component: Anhaenger     H14 0137
   Revision: 8B001001    Serial number: 0358080141
   Coding: 0100000202000000
   Part No SW: 5Q0 980 568 A    HW: 5Q0 980 568 A
   Component: RVC Compact+  H07 0180
   Coding: 01730001E3002017000040
   ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
   ROD: EV_CamSysRVRVCARPANAMQBAB_006_VW37.rod
   VCID: 3B203F6AB3EEFD63660-806E
   Component: OCULowMQBUS   007 0568
   Coding: 02730001C2820A017F1E06000000
   ROD: EV_OCULowMQB.rod
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H06 0272
   Serial number: 04121612K20228
   Coding: 000307000000040100262355C150A80099000E100020
   Component: SAS-GEN 2     H06 0014
   Serial number: 140716202679
   VCID: 6B80CF2A830EADE3B60-803E
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 5G0 907 160     HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0006
   Serial number: 150506200368
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   VCID: 6390A70A6BDEE5A30E0-8036
End----(Elapsed Time: 02:11, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
downtime
Finland
C?ID=280813
I would first try to fix the mechanical problem with the lumbar support motor :
                    Reset counter: 99
                    Mileage: 27067 km
                    Date: 2021.04.05
                    Time: 11:18:34
After it's fixed most likely the basic settings will go through successfully as well. You can do it two ways, either with the buttons moving the seat to all extremes + lumbar support or easier way to do it with ODIS, then it's fully automatic
kakubaz
Zgorzelec, Poland
C?ID=314093
Hi,
I looked in the seat and the motor and cables look fine. Everything works as it should. Could this error be due to incorrect coding?
downtime
Finland
C?ID=280813
It still could be the motor. Or one of the sensors inside the motor.
kakubaz
Zgorzelec, Poland
C?ID=314093
Hi,
I replaced both lumbar motors. This error has stopped appearing, but the error about missing calibration is still there. I have tried doing basic settings via vcds, odis and manually. Each time the error remains.
 Saturday,10,April,2021,19:05:16:46555
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4543.4
VIN: WVWZZZAUZFW088687   Mileage: 27144km-16866miles
   Revision: 81H22---
          P1734 00 [002] - -
   Coding: 030C0C
   Revision: 00001K08
   Air quality sensor:
          B10CD 00 [008] - -
                    Reset counter: 139
                    Mileage: 27067 km
                    Date: 2021.04.07
                    Time: 04:25:30
                    Voltage terminal 30: 11.1 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up lamp: OFF
   Coding: 00A8DD
   Coding: 0271667851
   Coding: 333135
   Coding: 333135
   Coding: 8C11
   Coding: 9309
   Generator:
   Coding: 2D0000
          U1101 00 [009] - Active
                    Reset counter: 103
                    Mileage: 27144 km
                    Date: 2021.04.10
                    Time: 19:01:20
                    Terminal 30 power supply: 11.9 V
                    Terminal 15: On
   Coding: 0010000000000500018280808080000000008181000000F400
                    Reset counter: 103
                    Mileage: 27144 km
                    Date: 2021.04.10
                    Time: 18:56:58
                    Reset counter: 103
                    Mileage: 27144 km
                    Date: 2021.04.10
                    Time: 18:56:58
          B2010 00 [009] - -
                    Reset counter: 103
                    Mileage: 27144 km
                    Date: 2021.04.10
                    Time: 18:56:58
   Coding: 02012103
   Coding: 020121
   Coding: 011000
   Coding: 9707
   Revision: 00000001    Serial number: ˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙
   Coding: 091000
   Coding: 2E0000
   Coding: 2E0000
End----------(Elapsed Time: 02:07, VBatt start/end: 12.1V/12.1V)-----------
downtime
Finland
C?ID=280813
When doing basic settings with ODIS, does it move the seat automatically to all extremes?
also are the seats complete unit meaning you also have the controller from the same seats originally?
myounus
Northwest UK
C?ID=321059
I don’t think that you can do basic settings on these seats using any tool - I think it’s like HVAC, thus it has to be done on the seats themselves.
Use the seat controls to move the seat to the end of each motion as downtime suggested but hold it at the end for about 3-5 seconds. Once you’ve done them all it should be done.
downtime
Finland
C?ID=280813
Yes you can. ODIS does it fully automatic. I’ve personally done it many times.
It will automatically move the seat to all extremes.
Same goes for as an example to window motors. Normally you’d do the basic settings manually pushing the button and running the motor. ODIS does this automatic. It will run window down and then up.
kakubaz
Zgorzelec, Poland
C?ID=314093
Yes when done by ODIS, it looks like the seat moves in every direction to the extreme.
Yes, it's a complete unit. Nothing has been changed there before.
I have tried doing this manually, holding for 5s, release and again holding for 5s in each axis, but nothing has worked.
downtime
Finland
C?ID=280813
And these are from Golf 7 originally? Maybe check the coding?
As a comparison, upper is your, lower is from my ex-Tiguan with retrofitted memory seat :
001000020000050001C281808181000000008181000000F400
Especially check the hall sensor settings, for some reason they're set to Audi and not VW.
kakubaz
Zgorzelec, Poland
C?ID=314093
I'll try your coding, but I compared mine with two golf mk7 scans from this forum and they were identical.
downtime
Finland
C?ID=280813
No no, don't put the coding directly in. Look for the differences. You need to use the experimental coding to see the bit descriptions.
kakubaz
Zgorzelec, Poland
C?ID=314093
I replaced the seat module and everything works as it should, unfortunately I don't know why the previous one was giving me errors. But I still have a problem with the memory of the left mirror. After adjusting the position on the seat, the mirror does not return to the memorized position. The right mirror works as it should.
Monday,19,April,2021,19:13:51:46555
Mileage: 27319km-16975mi   Repair Order:
VIN: WVWZZZAUZFW088687   Mileage: 27319km-16975miles
   Revision: 81H22---
   Coding: 030C0C
   Revision: 00001K08
   Air quality sensor:
   Coding: 00A8DD
   Coding: 0271667851
   Coding: 333135
   Coding: 333135
   Coding: 8C11
   Coding: 9309
   Generator:
   Coding: 2D0000
                    Fault Frequency: 11
                    Reset counter: 150
                    Mileage: 27302 km
                    Date: 2021.04.17
                    Time: 20:32:04
                    Terminal 30 power supply: 12.4 V
                    Terminal 15: OFF
                    Reset counter: 109
                    Mileage: 27302 km
                    Date: 2021.04.17
                    Time: 20:31:16
                    Terminal 30 power supply: 12.9 V
                    Terminal 15: On
   Part No SW: 3Q0 959 760 D    HW: 3Q0 959 760 D
   Component: Sitzmemory    H06 0023
   Serial number: Y0006RA913186
   Coding: 001400020000050081C280808080000000008181000000F400
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   Coding: 02012103
   Coding: 020121
   Coding: 003F13205A00048200011000
   Coding: 011000
   Coding: 9707
   Coding: 003F13205E00048200001000
   Coding: 091000
   Coding: 2E0000
   Coding: 2E0000
3086 - Antenna for Telephone Mount
          B1564 01 [008] - Electrical Failure
                    Reset counter: 149
                    Mileage: 27310 km
                    Date: 2021.04.19
                    Time: 17:13:35
                    Voltage terminal 30: 14.8 V
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): not selected
                    Status of telephone-Handset holder (cradle): not connected
End----------(Elapsed Time: 02:09, VBatt start/end: 14.5V/14.4V)-----------
downtime
Finland
C?ID=280813
Because the left mirror does not have the appropriate adjustment motor. The mirror adjustment motor is different on memory and non memory mirrors
kakubaz
Zgorzelec, Poland
C?ID=314093
Doesn't every mirror with 13 pins have a memory?
@kakubaz :..... Or, you could check for a mirror memory module by using your trusty VCDS cable/dongle like this:
  1. Select Door Elect, Passenger (@ address hex52)
  2. Select Advanced Measuring Values
  3. Enter "memory" into search box on RHS list shown below
  4. Tick boxes shown below
If mirror memory module NOT installed:
If mirror memory module installed:
note: the X/Y coordinate values can be different to those shown, but they can't be 255%
kakubaz
Zgorzelec, Poland
C?ID=314093
Yeah, I saw these values for both mirrors, when moving the mirror these values changed, so I didn't understand why the right mirror had memory and the left mirror didn't. In the link @downtime provided they write that the mirror motor must necessarily be with the letter C. There are no motors with the letter C for the Golf 7.
EDIT: I checked both mirrors, on the right side there is a motor number 1K0 959 578A, while on the left side there is 1K0 959 578. I installed on the left side an identical motor as on the right side and still the same thing happens. After pressing the button on the seat, the left mirror searches for some strange position.
downtime
Finland
C?ID=280813
1K0 959 578 according to ETKA should be suitable for PR code 6XG and 6XR which mean exterior mirror with memory function. A is only for passenger side mirror motor.
So yours should be fine from the part number.
Wasn't there a coding in door control module to tell mirror memory is installed?
hmm......... I must be missing something in your response!! Isn't it obvious why the driver side mirror won't have a memory module?
The ONLY purpose for the memory module is to record the return position after mirror-dip has completed, Mirror-dip ONLY applies to the passenger side mirror - therefore on cars with the steering wheel on the left side, ONLY the right side mirror will have the memory module
Ain't no point installing mirror-dip equipment on the driver-side mirror because the facility ONLY works on the passenger side
