Thursday,08,April,2021,15:31:33:14672
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
Version 21.3.0.0 (x64) HEX-V2 : 0.4543.4
VIN: WVGZZZ5NZJM132963 License Plate:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 22 29 2B 36 39 42
44 47 4B 52 5F 69 6C 6D 75 A5 BB BC D6 D7
VIN: WVGZZZ5NZJM132963 Mileage: 52044km-32338miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: Malfunction 0010
Address 01: Engine (J623-CUAA) Labels:. 03N-906-026-CUA.clb
Part No SW: 03N 906 026 D HW: 03N 907 309
Component: R4 2.0l BTD H24 3680
Revision: A1H24---
Coding: 0125003A047605083000
Shop #: 00066 790 00150
Dataset: EV_ECM20BTD01103N906026D 004005
ROD: EV_ECM20BTD_VW37.rod
VCID: 2C010F4F9688A26B03B-8079
17161 - Databus
4976 - Glow Plug Control Module (J179)
P0684 00 [096] - Implausible Signal
4714 - Steering Column Control Module
U0212 00 [032] - No Communications
Mileage: 50317 km
Date: 2021.03.21
Time: 07:42:39
Engine RPM: 845.00 /min
Normed load value: 23.5 %
Coolant temperature: 50 °C
Intake air temperature: 34 °C
Voltage terminal 30: 11.340 V
Cruise Control System (): status-Bits 0-7: 1
CAN status - transmission control module-Bits 0-7: 8
selected gear-Bits 0-7: 1
Part No SW: 0DL 300 012 P HW: 0GC 927 711 G
Component: GSG DQ500 H06 2103
Revision: 00H06V07
Shop #: 00000 000 00000
Dataset: EV_TCMDQ500021 001001
VCID: 36352D2758C4E8BB65F-8063
Address 03: Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 50358000000838
Coding: 0BEE6B9A54231B6E4780070662C669D0D62AD8E2E046967D386250F8C22A4200002864121A1C230935351919323200
Shop #: 01383 790 50316
Dataset: EV_Brake1UDSContiMK100IPB 036010
VCID: 77ABE0231F4ED1B3BE9-8023
Address 05: /Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0907
Revision: 00037000 Serial number: 0467359805
Coding: 132C2C0723
Dataset: EV_KessyHellaMQBAB 004041
ROD: EV_KessyHellaMQBAB.rod
VCID: 3E25350770F420FBBDF-806B
Subsystem 1 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: >9000881
65794 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Function restriction due to temp low voltage]
Fault Frequency: 33
Reset counter: 72
Mileage: 48480 km
Date: 2020.12.26
Time: 12:17:47
Terminal_15_Kessy_specified_value: On
Terminal_15_Kessy_actual_value: On
Terminal_15_central electric_actual_value: On
Terminal_15red_Kessy_specified_value: On
Terminal_15red_Kessy_actual_value: On
Terminal_S_Kessy_specified_value: On
Terminal_S_Kessy_actual_value: On
Terminal_S_central electric_actual_value: On
Terminal_50_Kessy_specified_value: OFF
Terminal_50_Kessy_actual_value: OFF
ZAT_pressed: OFF
Request active: Condition not met
Enabling Steering Column Lock: Condition not met
Enabling immobilizer: Condition met
Control Module Voltage: 8.321 V
Vehicle speed: 0.0 km/h
Engine RPM: 0.0 /min
Status of vehicle locking: Vehicle unlocked
Coding information: coded
Coding information: Not coded
Driver door: closed
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: Init
ID-sensor 1 authentication: status: No response
ID-sensor 2 authentication: status: No response
ID-sensor 3 authentication: status: No response
ID-sensor 4 authentication: status: No response
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NA 907 044 P HW: 5NA 907 044 P
Component: AC Automat H35 4301
Revision: 20K08000 Serial number: 00000B00573596
Coding: 0002010420411101110510000010142A
Dataset: EV_ACClimaPrehVW37X 002023
VCID: 4CC16FCF3648826B23B-8019
Humidity sensor: exterior:
Rear A/C control head:
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
263425 - Air Quality Sensor
B10AF 04 [008] - Internal System Fault
Fault Frequency: 117
Reset counter: 102
Mileage: 48936 km
Date: 2021.02.03
Time: 23:40:57
Outside temperature: -7.5 °C
Voltage terminal 30: 14.0 V
System run time-Engine running time: 253 s
Air quality status: Malfunction
Part No SW: 5Q0 937 086 BL HW: 5Q0 937 086 BG
Component: PQ37BOSCH 034 0246
Revision: -------- Serial number: C86421021800IR
Dataset: EV_BodyContrModul1UDSBosc 018001
ROD: EV_BCMBOSCH_018.rod
VCID: 05579AEB55A2B323BC5-8051
Subsystem 1 - Part No SW: 5NN 955 119 HW: 5NN 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 180221 034 0373
Serial number: 18022021008030
Component: 047 0105
Serial number: S9Y18M02D26H14M44S25
Coding: 00A8DD
Serial number: 000000000ZY1802308QX
Serial number: 00000000000099861389
Humidity sensor: interior:
U1400 00 [008] - -
[Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten >]
6154 - Bulb for Rear Right Turn Signal
B11EB 15 [008] - Open or Short to Plus
5642 - Bulb for Rear Left Turn Signal
B11E9 15 [008] - Open or Short to Plus
204290 - Remote key 1
B1479 18 [008] - Current Too Low
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0045
Serial number: 000116644R18054
Coding: 0271563951
Dataset: EV_EPHVA2CAU3700000 009037
ROD: EV_EPHVA2CAU3700000.rod
VCID: 50F97BBFDA60A68B5F3-8005
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H02 0233
Coding: 320067CB18FF8728749C8145804087
Dataset: EV_ACCMRRCONTIVW376 002012
1076 - Databus
[FAULT_TIMEOUT_GRA_ACC_01]
Reset counter: 104
Mileage: 50317 km
Date: 2021.03.21
Time: 07:42:40
Voltage terminal 15: 11.6 V
Control Module temperature: 4 °C
Longitudinal_acceleration_vehicle_reference: -0.16 m/s²
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Fault Frequency: 13
Reset counter: 104
Mileage: 48955 km
Date: 2021.03.08
Time: 18:50:28
Voltage terminal 15: 14.3 V
Control Module temperature: 25 °C
Velocity_vehicle_reference: 0.96 m/s
Longitudinal_acceleration_vehicle_reference: -0.06 m/s²
1116 - Databus
[FAULT_TSK_CODING_IN_PLAUS_PHASE_FAIL]
Reset counter: 104
Mileage: 50317 km
Date: 2021.03.21
Time: 07:43:09
Voltage terminal 15: 14.2 V
Control Module temperature: 8 °C
196746 - Sensor for Automatic Distance Control
C110B F0 [008] - Limited Visibility
[FCTSEN_OBJ_NOT_MEASURED]
Reset counter: 91
Mileage: 48779 km
Date: 2021.01.06
Time: 10:09:06
Voltage terminal 15: 14.4 V
Control Module temperature: 12 °C
Velocity_vehicle_reference: 5.80 m/s
Longitudinal_acceleration_vehicle_reference: -0.03 m/s²
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 03011841350308
Dataset: EV_DRCONTITEMIC 001019
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 3829231F52D01ECB773-806D
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 005 0336
Serial number: 003VWM05SM6K
Coding: 98CCC0C0008000005C5400CF004800000065
Dataset: EV_AirbaVW20SMEVW37X 002158
VCID: 094F96DB79BAD743D8D-805D
Left seat belt tensioner:
Serial number: 5NB857705C0346R02247
Coding: 80000D
Right seat belt tensioner:
Serial number: 5NB857706C0349R01023
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 002 112 17
Serial number: 35700000000A1B41392D
Subsystem 4 - Part No SW: ----------- HW: 480 002 212 17
Serial number: 35800000000DA189DA2$
Subsystem 5 - Part No SW: ----------- HW: 480 402 912 17
Serial number: 3510001A128C2082F3D0
Subsystem 6 - Part No SW: ----------- HW: 480 402 912 17
Serial number: 3520001BD284E2D5337A
Subsystem 7 - Part No SW: ----------- HW: 480 401 302 18
Serial number: 3550001C729485956476
Part No SW: 5Q0 953 507 HW: 5Q0 953 549 E
Revision: -------- Serial number: 12011804221187
Coding: 0C10
Dataset: EV_SMLSKLOMQB 020002
Part No SW: 5NA 920 790 B HW: 5NA 920 790 B
Component: KOMBI 408 3195
Coding: 07A40018FF80000801882B031401000000000000
Dataset: EV_DashBoardVDDMQBAB 009058
VCID: 41DF4EFB010A5F03C0D-8015
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 G HW: 5Q0 963 272 G
Component: STH- 008 0075
Coding: 9309
Dataset: EV_AuxilParkiHeateWOS 002018
VCID: 3A2D39176CDC0CDB817-806F
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000266321
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW High 518 5323
Serial number: 26111700840126
Coding: 030500345F017300FB07225E9E0F00010001070000000000000000000000
Shop #: 00066 790 00443
Dataset: EV_GatewNF 013023
ROD: EV_GatewNF_VW37.rod
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29180000139060028065
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5QA 915 181 E HW: 5QA 915 181 E
Serial number: 5895974304
197169 - Controls in Steering Wheel
U108E 00 [008] - No Communications
[MFL (#2) Timeout]
Fault Frequency: 20
Reset counter: 104
Mileage: 48937 km
Date: 2021.02.05
Time: 14:29:26
Terminal 30 power supply: 11.8 V
Terminal 15: OFF
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Serial number: HA1-00018.09.17
Coding: 0101
Dataset: EV_AllWheelContrHA1VW37X 004013
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH08 0014
Dataset: EV_LCMLeftHELLAAU736 001012
VCID: 45D75AEB15227323FC5-8011
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 18000012587006
Coding: 0800000000000000
Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 333314334BB6FD93421-8067
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 C HW: 5Q0 959 760 C
Component: Sitzmemory H09 0023
Serial number: Y0006RAU19706
Coding: 0010000000000500018280808080000000008181000000F400
Dataset: EV_SeatMemorDriveSide 002021
VCID: 3D27320B7DF23BE3A45-8069
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Dataset: EV_LCMRightHELLAAU736 001012
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: FS 011 0032
Serial number: 5038805401177
Coding: 003F1A20D200028000001000
Dataset: EV_DCUDriveSideEWMAXCONT 006001
VCID: 47CB50E32F2E61330E9-8013
Part No SW: 5QF 909 144 HW: 5QF 909 144 _
Component: EPS_MQB_ZFLS 506 5572
Coding: 9307
Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
VCID: 074B90E36FAEA133CE9-8053
Address 47: Sound System (J525) Labels:| 3Q0-035-466.clb
Part No SW: 3Q0 035 465 HW: 3Q0 035 465
Component: MIB2_amp_P_VW H60 0440
Revision: 00000001 Serial number: VWZ8Z1HJD01A9VR
Coding: 1223060001A00A2AAA0000000000
Dataset: EV_AMPMst16C3Gen2ALPI 001016
ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
VCID: 6B83CC53530665534A1-803F
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM Low 002 0286
Serial number: 11021800840601
Coding: 0000000501001D5207104F000A0000000000000000000000000000000000
Dataset: EV_MultiModulContiVW48X 001010
VCID: 72BDD137742CB49B897-8027
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: BFS 011 0032
Serial number: 6038801200571
Coding: 003F1220DE00028000001000
Dataset: EV_DCUPasseSideEWMAXCONT 006001
VCID: 46D55DE72824783BF5F-8013
Address 5F: Information Electr. (J794) Labels:| 5G0-035--STD2.clb
Part No SW: 3Q0 035 840 C HW: 3Q0 035 840 C
Component: MU-S--ER 722 0867
Coding: 02730600000000005111000200080A001F0506E40120000002
Shop #: 00066 790 00326
Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 2B030C539386A5530A1-807F
Subsystem 1 - Part No SW: 5G6 919 605 A HW: 5G6 919 605 A
Component: ABT_Std-2 H50 8130
Serial number: VWZ6ZJV0516721
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0454170523
Coding: 0100000202000000
Dataset: EV_TrailFunctGener2Hella 001008
VCID: 42DD41F7040C441BD97-8017
Component: RVC Compact H12 0231
Coding: 0123060123002017000040
Dataset: EV_CamSysRVRVCPANAMQBAB 006009
VCID: 392F261B69DA07C388D-806D
Part No SW: 5Q0 959 107 M HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0261
Revision: -------- Serial number: A2-C758-8700-0
Coding: 0AA8
Dataset: EV_DeckLidCONTIAU736 001014
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 B HW: 5NA 035 284 B
Component: OCULowMQBLGE H17 0717
Revision: --------
Coding: 02230601EA16180D3F1CBE020045400382E708
Dataset: EV_OCULowMQBLGE 004044
ROD: EV_OCULowMQBLGE_004_VW25.rod
VCID: 3C213F0F66E832EB93B-8069
9457426 - Speaker for Emergency Calling
B14A6 12 [008] - Short to Plus
Mileage: 48942 km
Time: 31:63:63
Voltage terminal 30: 11.8 V
Part No SW: 3QD 980 654 HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 1272
Serial number: 10111741P10164
Coding: 000307060102040100220045C150A90084000E300040
Dataset: EV_MFKBoschMQBB 001001
VCID: 084993DF62B0AE4BC73-805D
Part No SW: 5Q4 959 595 E HW: 5Q4 959 595 B
Component: HFS 012 0032
Serial number: 0000296746392
Coding: 002A10200101028000001000
Dataset: EV_DCURearDriveMAXCONT 006001
VCID: 49CF56DB393A974318D-801D
Component: HBFS 012 0032
Serial number: 0000296746385
Dataset: EV_DCURearPasseMAXCONT 006001
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
Dataset: EV_LEDModLeftMELCOAU736 001004
VCID: 1675CDA7380408BB45F-8043
Component: LED1R H09 0003
Dataset: EV_LEDModRightMELCOAU736 001004
End----(Elapsed Time: 02:22, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
