VW T6 infotainment system won't turn on
Justin0
Wales, UK
HN1-2H(?)
Good evening all,
I have a 2017 T6 and the radio has stopped working. The screen is blank, nothing seems to operate. I've tried holding power for 10 seconds but nothing. There are no codes stored, so I'm at a loss.
Anyone have any advice?
Cheers
Justin: Wild guess (but more than a tad obvious)- fuse?
Justin0
Wales, UK
HN1-2H(?)
No mate, checked fuses and supply to unit. I don't have a wiring diagram but there's feed into the unit on a larger cable in quadlock.
@Justin: Ok -so, I'm just surmising but pure logic suggests that because there are no DTC s ( I assme this is what's meant by "there are no codes stored"), the hex5F module in the vehicle is happy for the current arrangement to persist (i.e. a blank screen).
I'm not sure if it's the same, but some time ago I had a MQB platform car visit here with the very same symptoms (i.e. no MIB screen and no DTCs). After much head-scratching and even more failed attempts at fault-finding, I finally tracked-down the cause of the problem, which was missing software on the MIB.
As eventually admitted by the car owner (I wish he had told me earlier), he had changed the hex5F software switches on Byte 18 on the long-code string. These switches have the descriptor "screenings", but they determine the screen version that the MIB selects at start-up. The car owner had changed the factory setting on Byte 18 because he wanted the MIB to show a different model version. However, whilst the coding change was accepted, I found-out (deduced, really) that the option chosen wasn't programmed into the module firmware. This resulted in the MIB failing to load any GUI version at start-up which meant a blank screen!! To my surprise, the MIB was quite happy to remain in this state and no DTCs were present on the scan report
So, notwithstanding no DTCs, given the absence of an obvious cause and the lack of any diagnostic detail about the problem (other than the quad-lock has volts), it might be worthwhile to post a copy of an auto-scan for the car. At least then we can see how the vehicle is equipped -and how the MIB is coded - which might result in further insights maybe.
Justin0
Wales, UK
HN1-2H(?)
Thank you DV52,
Here is a copy of the scan which I ran yesterday. It has been fully functioning up until Wednesday without any coding intervention from me.
Saturday,03,April,2021,16:37:47:26259
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
VIN: WV1ZZZ7HZJX000824   License Plate: CN67ZNO
Mileage: 61820km-38413mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZJX000824   Mileage: 61820km-38413miles
Address 01: Engine (2D2D2-CXGB)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KA    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 4047
   Revision: 23002001
   Coding: 00114014432401090000
   Shop #: WSC 16026 004 1048576
   ASAM Dataset: EV_ECM20TDI03004L906056KA 004003
   ROD: EV_ECM20TDI03004L906056KA.rod
   VCID: 76A011FAC9A1AE3BE9-8022
Readiness: N/A
   Revision: 00000000    Serial number: 41377000001021
   Coding: 517E40982562847E8A7D0278A48621E679F100
   Shop #: WSC 35110 790 50316
   VCID: 3FCEB4DEA61B2F73FA-806A
   Serial number: 10051713471110
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EB009DAE191E67BB1-802A
   Part No SW: 7E0 907 047 AK    HW: 7E0 907 047 AK
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ROD: EV_ClimaT5Basis.rod
   VCID: 73A628EEDAD3BB13CE-8026
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Component: BCM PQ25 Max4 H82 0752
   Revision: B9082001    Serial number: 4000 133170697
   Coding: B8A4303A0A63343193284F746CEB8E750F84708F60CC6D60330400220840
   Shop #: WSC 35110 377 08192
   VCID: 2B16F08E4A63A3D346-807E
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 110517 04  42  0106
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU011051771314592
   Coding: 1400B0
   Subsystem 3 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU011051771318472
   Coding: 0400A0
   Subsystem 4 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 1K0 951 605 F
   Subsystem 6 - Part No: 7E1 951 172
   Subsystem 7 - Part No SW: 7E0 959 442     HW: 7E0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 46170001171230077195
   Coding: B0FFFF
   Part No SW: 7E0 919 475 T    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0212
   Revision: --------    Serial number: 32931710800279
   Coding: 10800A
   ASAM Dataset: EV_VW75XParkAssis4K 001013
   ROD: EV_VW75XParkAssis4K_001.rod
   VCID: 43C6B82ECAF34B939E-8016
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Serial number: 0605170440A2C0
   Coding: 00004000FE0779
   ROD: EV_ACCBEGVW361.rod
   VCID: 3620D1FA8921EE3B29-8062
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag021 H08 0018
   Revision: --------    Serial number: 003V3004WGDG
   Coding: 000000000000000000000000000000003231
   ROD: EV_AirbaVW10BPAVN750_VN75.rod
   VCID: 3A38C5CABD390A5BCD-806E
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Component: KOMBI         H03 1107
   Coding: 750B010300
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Component: GW-K-CAN TP20 H82 0752
   Revision: B9082001
   Coding: 042305
   VCID: 689C4F829B1548CB6B-803C
   Component: IMMO          H03 1107
   VCID: 6A98358A8D197ADB7D-803E
   Part No SW: 5K7 035 200 K    HW: 5K7 035 200 K
   Component: MU-S-D-ER     H41 0449
   Serial number: VWZAZ2T5217466
   Coding: 06570000BE00000011111101008808001F0100C60020010003
   ROD: EV_MUStd4CTSAT_VN35.rod
   VCID: 2C14F392476DA4EB4F-8078
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 030B7A73
   Shop #: WSC 08004 003 1048576
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Serial number: 758857000017051807E0
End----------(Elapsed Time: 01:50, VBatt start/end: 12.4V/12.3V)-----------
Justin0
Wales, UK
HN1-2H(?)
Hi Don,
Thank you for your reply. I've added a scan result to my post. See what you make of it, I can't see anything obvious.
Cheers
Justin
@Justin0: I've compared your long-code string with a similar module HERE (the other module doesn't have DAB) - nothing jumps-out!!
And the Byte 18 value on your unit is OK. Clearly the infotainment system is talking to the CAN network (no DTCs). Does the module sound obstacles when backing?
I note that the vehicle has only travelled 38.5K kms - so still under warranty. Not sure if this is a known problem on T6 - but worth a chat with dealer (I think)
Justin0
Wales, UK
HN1-2H(?)
Hi,
Yeah the park sensors work acoustically only with nothing on dash. The warranty ran out in November so I doubt they will help. I'm in conversations with an electronic repairer to check what's wrong. I couldn't see anything obvious in the scan, but you have far more experience with the VCDS operations etc.
Thank you for your assistance so far, I'll let you know how I get on.
Cheers
Justin
@Justin0: I hope that the problem can be found - but notwithstanding your "electronic repairer", this very-odd fault might be a known problem for the T6. Regardless of the warranty status, it might still be worth a chat with a dealer (I suggest) to confirm that there is no residual warranty liability by VW
Spacewalker
Poland
C?ID=159607
1) did radio can be turn On from knob when engine is running or when ign is off ?
2) did someone did some coding changes , and after that is "dead" ?
3) did radio illuminate separate , or illuminate with dasch buttons ?
4) when you do diagnostic - you see single knock in speakers ?
Justin0
Wales, UK
HN1-2H(?)
None of the buttons do anything at all, screen blank and no input to MID?
The only coding done was adding fader for rear speaker addition but that was months ago.
