Audi A3 8V retrofitting Audi Music Interface (AMI)
Rooster
Finland
Happy to be part of this community. My case is following:
I have successfully retrofitted the Audi Music Interface (AMI) to my A3 sedan (8V0). Original AUX interface has been replaced with the AMI/USB combination and required wire harness has been installed and connected to the MMI Radio as well.
Retrofit kit what I have used is this:
http://www.carsystems.pl/audi-a3-8v...face-audi-music-interface-retrofit,id961.html
There is a note saying: VAS programming is required after installation
The problem is that MMI still thinks that original AUX is present not the AMI and thus the MMI should be re-coded. I have tried to figure it out with VCDS but unfortunately even the latest beta software doesn't support labels for module 5F - Information Electronics. Are there any ideas how I could proceed or do I just have to wait for the next VCDS release where the support for my car is present?
I have already sent the Auto-scan and Controller Channel Maps for you by mail (those where taken by version 14.10.2.0 but Auto-scan with the latest beta 15.3.0 gave the same result set though).
Thanks and regards,
Rooster
Wednesday,25,March,2015,15:38:54:43720
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WAUZZZ8V7F1043297   License Plate:
Mileage: 7108km-4416mi   Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V7F1043297   Mileage: 7108km-4416miles
Address 01: Engine (J623-CZEA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BL    HW: 04E 907 309 AB
   Component: 1.4l R4 TSI   H21 8139
   Revision: R6H21---
   Coding: 02250032242401082000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM14TFS01104E906027BL 001006
   ROD: EV_ECM14TFS01104E906027BL.rod
   VCID: 6FED1358B637C459875-803A
   Part No SW: 0CW 300 047 T    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5202
   Revision: 00043014    Serial number: CU501406226128
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_AU37.rod
   VCID: 4C97A4D4E761DF41C27-8019
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 L    HW: 5Q0 907 379 G
   Component: ESC           H31 0471
   Revision: 00000000    Serial number: 61924000001910
   Coding: 13F16AA22424126F0179060941CA29C856244880608294F2022100788608
   VCID: 458191F0C40B2E091D9-8010
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Component: AC Automat    H13 0052
   Revision: 20026000    Serial number: 00000000380730
   Coding: 03000014000000011000000000001100
   VCID: 3365DF289A9FA0B9A3D-8066
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011416702002
   Coding: 04141A46C24122FD43C04004001807A80000000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 000F40E49BA9CB216EF-8055
   Slave 1:
   Subsystem 1 - Part No SW: 8V1 955 119 C    HW: 8V1 955 119 A
   Component: WWS371 140711  042 0585
   Serial number:         140715225852
   Coding: 0A47F7
   Slave 2:
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Serial number: 22867854
   Coding: 00006C
   Slave 3:
   Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
   Serial number: 30 03 2014  00000637
   Subsystem 4 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO3006111T
   Coding: 901E00
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0051
   Revision: --------    Serial number: 39231418901291
   Coding: 0000050011
   ASAM Dataset: EV_EPHVA14AU3700000 002022
   ROD: EV_EPHVA14AU3700000_AU37.rod
   VCID: 3B75F708B2CF68F97BD-806E
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Serial number: 003MMR01N4V4
   Coding: 98CCC0000C0000005C5400CA004800000065
   Subsystem 1 - Part No SW: -----------    HW: 480 000 707 14
   Serial number: 35767000000413BC001H
   Subsystem 2 - Part No SW: -----------    HW: 480 000 707 14
   Serial number: 35867000000D6875101R
   Subsystem 3 - Part No SW: -----------    HW: 480 400 807 14
   Serial number: 3516502AD1656B84928J
   Subsystem 4 - Part No SW: -----------    HW: 480 400 807 14
   Serial number: 3526502C31697523C186
   Subsystem 5 - Part No SW: -----------    HW: 480 400 207 14
   Serial number: 3556502C7156E9E1D0BX
   Pedestrian protection crash sensor; driver side:
   Subsystem 6 - Part No SW: -----------    HW: 480 401 207 14
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502BF165690461DG
   Pedestrian protection crash sensor; front passenger side:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 207 14
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502B51656905C189
   Subsystem 8 - Part No SW: -----------    HW: 480 001 704 14
   Serial number: I0M800000009938D6F0P
   Subsystem 9 - Part No SW: -----------    HW: 480 001 704 14
   Serial number: I0N80000000A938D6F0R
   Part No SW: 8V0 953 521 CB    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 14071404220163
   Coding: A018
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 7CF73414F741AFC1327-8029
   Part No SW: 8V0 920 871     HW: 8V0 920 871
   Component: KOMBI         H02 4291
   Coding: 07A519082B8000080100A8001000000000000000
   VCID: 79F92D00F8739AE9291-802C
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2186
   Revision: --------    Serial number: 07071410801857
   Coding: 030100042F0857005B0002481C0B00000001010000000000000000000000
   ASAM Dataset: EV_GatewConti 011017
   ROD: EV_GatewConti_AU37.rod
   VCID: 428B8AECD525193138B-8017
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 02 07 2014  E0001942
   Serial number: 0222073903
   Serial number: 01071403110396
   Coding: 001C8F204000040000001002
   VCID: 408F80E4DB290B212EF-8015
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   VCID: 418985E0D0230229211-8014
   Serial number: 11071403111530
   Coding: 001C87204C00040000001002
   VCID: 3F8D8318A6D774D9575-806A
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 019A000001000000
   ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
   VCID: 75E12130D46BFE894D9-8020
   Part No SW: 8V0 035 840 B    HW: 8V0 035 840 B
   Component: MU-S--ER      041 0420
   Serial number: A3E01107142410
   Coding: 01730100FF00000011110001000A00002F0001040100010002
   ASAM Dataset: EV_MUStd6C3PASE 002010
   ROD: EV_MUStd6C3PASE_AU37.rod
   VCID: 3467DC349F91A781BA7-8061
   Seat Adjustment Driver Side:
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0013
   Serial number: AUZ8Z9EY304XMC
   Sound System:
   Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Component: ControlUnit_B  H41 0054
   Serial number: C1000003071400020201
End---------------------(Elapsed Time: 03:45, Deb=2)-----------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Try 01730100FF00000021110001000A00002F0001040100010002 as your new coding.
Rooster
Finland
Hi Sebastian,
And thanks for the new coding! That was one major step forward, because now the MMI identifies AMI correctly.
But unfortunately even if I connect the proper AMI adapter, MMI radio states AMI not connected.
VCDS error log for 5F prompts the following:
   Coding: 01730100FF00000021110001000A00002F0001040100010002
   VCID: 346D15609F5F409813-8061
   Sound System:
1024 - Interface for External Media Devices (MEDIA-IN)
          B1288 13 [009] - Open Circuit
                    Reset counter: 125
                    Mileage: 7420 km
                    Date: 2015.04.04
                    Time: 14:45:54
Any further tips?
Thanks and regards,
Rooster
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Assuming the coding I provided is correct (which is indicated by the DTC), the only thing I can think of is either an issue with your wiring or an issue with the parts you installed.
Rooster
Finland
Thanks Sebastian for your reply.
With the original coding I was able to get sound through even though the MMI showed that media input is AUX (and thus the steering wheel controls etc. didn't work at all).
So based on that I think that wiring is correctly in place and at least the AMI interface is also working properly. With new coding MMI shows AMI input in source selection but I cannot select it because of not connected message.
Last thing what I can do is to try the AMI with another adapter and let see what happens.
United States
If you purchased VCDS from one of our distributors, please register with us for technical support using this page: http://www.ross-tech.com/vca/hex-com-reg.php. After doing so one of the guys can change your forum status to Verified VCDS User so this can me moved to the Retrofit sub-forum.
However, if the VCDS system you are using belongs to someone else please do not attempt to register it using that form.
C?ID=169848 | C?ID=126314
Rooster
Finland
Tried today with another AMI adapter; iPhone Lightning (4F0051510AL) and still the same unwanted result.
Adapter is not recognized even thought the sound goes through if the coding is reverted back to the original (AUX input).
If there are no other coding option available then my last option is to try refitting the wires... :banghead:
Edit: Noticed today that iPhone gets power via AMI Lightning adapter but still the audio input is not triggered.
Rooster
Finland
Tried today with the latest VCDS beta 15.5.0 and still no labels for 5F module. I'm quite sure that wiring is correctly in place... Any ideas what could cause this 'Open Circuit' error.
lala30
Croatia
C?ID=71949
did you have AUX and MDI?
because in your coding is mark MDI and AUX!!!!
Rooster
Finland
Hi Lala30,
And thanks for your reply. Originally I only had the AUX input and the coding for AUX was:
Now I have retrofitted the AMI interface and changed the coding as proposed:
I assume that MDI is the same as AMI, am I right? So what should be changed then if there is mismatch in coding?
Can you point out which part of the code is still indicating that AUX is present?
Br,
Rooster
lala30
Croatia
C?ID=71949
hello
this is code without AUX only AMI ( MDI)
01730100FF00000020110001000A00002F0001040100010002
Rooster
Finland
hello
Just tried your coding but still the same Open circuit error in VCDS and MMI says "No device is connected to the system." :(
USB is getting power though and Lightning adapter is charging my phone as well.
Rooster
Finland
Finally I was able to get rid of that 'Open circuit' error in 5F module, meaning there is no single error in my auto-scan anymore. :)
But still the AMI adapter is not recognized in MMI Radio. :(
Measurement data in VCDS is showing the following when AMI Lightning adapter is connected:
<code>
Address 5F: Information Electr. (8V0 035 840 B)
175 External multimedia device interface-Adapter lead Adapter line for iPod (multimedia)
176 External multimedia device interface-Adapter voltage 328
</code>
So it seems AMI is correctly recognized but for some reason it cannot be chosen in MMI Radio; MMI prompts:
"No device is connected to the system." when selecting AMI as audio source.
Rooster
Finland
And here is the latest auto-scan taken with version 15.5.0
Still no labels for module 5F but hopefully in the next release. :)
Tuesday,19,May,2015,22:03:29:43720
VCDS Version: 15.5.0.0 (x64)
Data version: 20150510
VIN:    License Plate:
Mileage: 9252km-5748mi   Repair Order:
VIN:   Mileage: 9252km-5748miles
   Revision: R6H21---
   VCID: 6FED1358B637C44766-803A
Address 02: Auto Trans (J743)       Labels: None
   VCID: 4C97A4D4E761DF5F23-8019
   VCID: 458191F0C40B2E17FC-8010
   VCID: 3365DF289A9FA0A742-8066
   VCID: 000F40E49BA9CB3F8F-8055
   Slave 1:
   Coding: 0A47F7
   Slave 2:
   Coding: 00006C
   Slave 3:
   Coding: 901E00
   Coding: 0000050011
   VCID: 3B75F708B2CF68E79A-806E
   Coding: A018
   VCID: 7CF73414F741AFDFD3-8029
   Coding: 07A519082B8000080100AA001000000000000000
   VCID: 79F92D00F8739AF7C8-802C
   VCID: 428B8AECD525192FD9-8017
   VCID: 408F80E4DB290B3FCF-8015
   Coding: 8103
   VCID: 418985E0D0230237C0-8014
   VCID: 3F8D8318A6D774C7B6-806A
   VCID: 75E12130D46BFE97AC-8020
   VCID: 3467DC349F91A79F5B-8061
   Sound System:
End-------------------------(Elapsed Time: 03:48)--------------------------
sVnsation
C?ID=228088 (NRRT)
I have the exact same issue with my golf mk7. (A3 an Golf7 MQB)
Cable-Adapters are visible in the adaption channels.
But it is not possible to switch to mdi (VW) / AMI (Audi).
I think this feature is protected as SWaP (Software as a Product)?!
Xander409
Pirate
Italy
Hi all,
Any news about that?
I have a mmi radio with default aux port, and i'd like to have AMI or connectivity kit. Do you think it will be possible?
Thanks in advance
Rooster
Finland
Finally got this sorted out! :thumbs:
For my car's setup the correct software coding for 5F module was the following:
01730100FF00000031110001000A00002F0001040100010002
It took almost half a year but now I have fully working AMI with USB port retrofitted in my A3 sedan.
Over and out!
Xander409
Pirate
Italy
Over and out!
this code is associated only to the ami, or not?
if i need to code the ami, i can use this, or it will be different for each car?
Over and out!
Rooster: Hi. I also have an interest in this matter but I desperately need your help in trying to understand your solution (I've been reading this thread, but it's messin'-with-my-membrane!).
From what I have understood, the Coding values for address 5F are as shown below for:
  1. your original posting (post #1 autoscan),
  2. Sebatian's preliminary advice (post #2)
  3. Your advice regarding the fix (post # 17)
If my understanding (and my hex-to-binary conversion) is correct, it seems to me that the only change that you made was to set Bit 4 and Bit 5 of Byte 08 to "1". Is this the fix for enabling AMI/USB - what have I missed?
Cheers
Rooster
Finland
Hi,
Xander: Coding is for overall 5F module, which contains everything regarding information electronics (and yes, it depends on your car's features); thus it is not just for AMI. But the actual code change what I did corresponds with AMI, though. :)
Don: Exactly! Bits 4 and 5 of Byte 08 was changed to 1. After the code change I made a soft reset and when MMI was up and running again, I had the AMI as a selectable Media source.
