Audi B7 Valet key operation
BobFisher
C?ID=324180
I have owned my 2007 B7 Quattro Avant 2.0T for the past 3+ years. It came with a valet key as well as the two remotes. The handbook has only minimal instructions for the valet key but implies that it should open and start the car. I read somewhere that it only allows the car to be driven "slowly" but can't find where I read that. My valet key opens the car, fits the ignition and the car starts but the engine runs for 1 second only then shuts down in a way that "suggests" the management system is shutting it down. It has behaved like this for at least the past year (the previous and only time I tried it).
I did have one thought: I was told by the shop that replaced the fuel injectors a few months ago (after one went out) that they got a low fuel pressure code when testing the engine after the work. I assume they ran it at full rpm. I suspect the fuel filter needs changing. I was already aware, from idle browsing in the registers, that the duty cycle on the low pressure fuel pump was looking high (40% from memory). Also, when I open the car (causing the fuel pump to start, to prime the HP pump) the pump runs for 3 or 4 seconds before stopping which I think is too long? I'm wondering if the valet key causes the fuel pump to run at a much lower speed, so as not to allow the engine much power. With a partially blocked filter this might prevent the engine running. Anyone know? Any suggestions how to diagnose? Could this also be a worn-out fuel pump? is there a VCDS measurement of LP fuel pressure?
Please note: the valet key operates differently on the B8 A4's (i.e. 2008/9 onward) so any experience with these may not be relevant.
I really doubt that is the case.
It sounds like your valet key isn't matched to the immobilizer. This can happen if any key-matching was done that didn't include the valet key.
BobFisher
C?ID=324180
The bulb errors are due to LEDs I am using. I have new motor mounts but not fitted them yet. The lambda sensor errors were prior to the injector replacement. The rest all seem to be related to the valet key use and were not present last time I ran a log.
I guess the "key" one is 001299 - Incorrect Immobilizer Key. Didn't know those had any electronics in them: can't find a battery cover on it. Can I rematch it myself? The handbook procedure for key re-matching appears to be only for the regular fobs. I did try that process (which I'm familiar with) with the valet key in the ignition lock but it made no difference - I think it just looks for the signature in the fob signal when you press a button after turning on the ignition.
Tuesday,30,March,2021,13:13:55:28835
VIN: WAUKF78E07A112234   License Plate:
Mileage: 195340km-121378mi   Repair Order:
          67 69 75 76 77
VIN: WAUKF78E07A112234   Mileage: 195340km-121378miles
   Part No SW: 8E0 910 115 P    HW: 8E0 907 115 D
   Revision: 5EH14---    Serial number:
   Coding: 010C010A190F0120
   Shop #: WSC 94827 999 59168
   VCID: 2E05F3AFFC104F4B2DF-807A
005491 - Left Engine Mount Solenoid Valve (N144)
               P1573 - 004 - Open Circuit - Intermittent
                    Mileage: 194020 km
                    RPM: 927 /min
                    Load: 40.0 %
                    Temperature: 96.0°C
                    Temperature: 25.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.811 V
000313 - Oxygen (Lambda) Sensor B1 S2
               P0139 - 004 - Response too Slow - Intermittent
                    Mileage: 194691 km
                    RPM: 1667 /min
                    Load: 10.2 %
                    Speed: 36.0 km/h
                    Temperature: 95.0°C
                    Temperature: 38.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.462 V
004372 - Oxygen (Lambda) Sensor; B1 S2
               P1114 - 008 - Internal Resistance too High - Intermittent
                    Mileage: 194691 km
                    RPM: 1653 /min
                    Load: 10.6 %
                    Speed: 35.0 km/h
                    Temperature: 95.0°C
                    Temperature: 38.0°C
                    Voltage: 13.335 V
               P0513 - 008 -  - Intermittent
                    Mileage: 195285 km
                    RPM: 1355 /min
                    Load: 22.7 %
                    Temperature: 21.0°C
                    Temperature: 21.0°C
                    Voltage: 11.557 V
   Part No SW: 8E1 910 156 K    HW: 09L 927 156 B
   Component: AG6 09L 2,0TFSI USA 0040
   Revision: --H01---    Serial number:        4237869
   Coding: 0000002
   Shop #: WSC 06335 000 00000
   VCID: 2F3BEEABFB1A4643269-807A
   Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
   Component: ESP8 quattro    H06 0140
   Coding: 0004528
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   2833
   Coding: 00000
   VCID: 6D8734A33486F453545-5118
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  USA 0907
   Coding: 11023
   Shop #: WSC 06325
   VCID: 3D27C4E32466A4D3A45-4B00
            30-00 - Open or Short to Plus
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H12 3840
   Revision: 91H12384    Serial number: 0036N0G0E74U
   Coding: 0033607
   VCID: 3C21C9E73A6CADDB93B-8068
   Subsystem 1 - Serial number: 6332DRB403E24BA3U
   Subsystem 2 - Serial number: 6342DRB40418D316K
   Subsystem 3 - Serial number: 6352ARB401B38067I
   Subsystem 4 - Serial number: 6362ARB401B39537M
   Subsystem 5 - Serial number: 63729RB401ABB202K
   Subsystem 6 - Serial number: 63829RB401AB9244P
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0701
   Coding: 02042
   Shop #: WSC 06335
   VCID: 41DFB813589EC033C0D-4B00
   Part No SW: 8E0 920 901 E    HW: 8E0 920 901 E
   Component: KOMBI+WFS 4     H14 0120
   Revision: 0120        Serial number: 00000000000000
   Coding: 0023261
   Shop #: WSC 49857 512 00000
   VCID: 270B068BD3FA1E03EE9-5184
01176 - Key
   Coding: 0023261
01176 - Key
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   VCID: 71BF28D3288E10B370D-4B3C
   Part No: 8E0 959 433 CG
   Component: Komfortgerát T7B    4135
   Coding: 12076
   Shop #: WSC 06335
   VCID: 78A915F74BC441FBB73-4B00
   Subsystem 1 - Part No: 8E1959801G
   Component: Tõrsteuer.FS BRM 0706
   Subsystem 2 - Part No: 8E1959802G
   Component: Tõrsteuer.BF BRM 0706
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
00962 - Alarm via. Tilt Sensor
            35-00 - -
01374 - Alarm triggered by Terminal 15
            35-00 - -
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000019
   VCID: 290F00B3C5FE2873F8D-807C
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H03 0020
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH03 0020
End----(Elapsed Time: 05:18, VBatt start/end: 11.6V/11.5V. VIgn 11.4V)-----
It's a passive transponder chip. Very small. Powered by the car's reader coil.
On this car, no. The B7 uses a challenge/response mechanism rather than a simple PIN.
But put that valet key in the ignition. Do not attempt to start the engine. Go to 25-Immobilizer and show us what you have in MVBs 022, 023, and 024. That will at least show if the key is good. It's relatively rare, but those transponders can fail.
Gone But Not Forgotten
Ross-Tech: VAG-COM: Immobilizer 3 Measuring Blocks
Indeed and in addition to Uwe's fine suggestion......
Did you know a battery Jesus Easter Bunny reset will sometimes realign an IMMO and it must be done with a bridge for capacitor discharge at battery terminals & with key left in on position after battery disconnected for a few minutes?
BobFisher
C?ID=324180
22 0 1 1 2
23 1 1 0 6
24 0 0 N/A
I'll wait for addition instruction before inquiring about Easter Bunnies :)
23 1 1 0 6
24 0 0 N/A
So the valet key looks to be in working condition, but there are only two keys matched to this immobilizer. I assume those are your two "full" keys?
The transponder in the valet key is locked. If that key was locked to this immobilizer, it should be possible to re-match it (along with the "full" keys) and have it working again.
BobFisher
C?ID=324180
What I am missing is the process to re-match it.
BobFisher
C?ID=324180
.... and yes, I have two key fobs matched to this car.
It needs to be done on-line to the servers at VW/Audi's mothership.
On your car, fobs are different than keys. Fob provide remote locking and unlocking. They are matched to the CCM or the BCM. Keys allow the car to be started and are matched to the Immobilizer.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
It is possible that ex owner add extra remote key and did not bring at time of programing that valet key and valet key was not regiter to immobilizer so it does not work now, So it needs to be readopted along with 2 other remote keys .
  • Agree
