VW Passat Estate - MY2021 tweaks & problems
hex.v2.belgium
Belgium
C?ID=293974
Hi,
back again after a few years with a new car...
Again a VW Passat, but now a MY2021
First did a full autoscan and the adaptation channel that I wanted to adapt but had some issues...
Will post the issue in the 2nd post as not to pollute the autoscan.
Monday,29,March,2021,22:43:05:43967
VIN: xxxxxxxxxxxxxxxxx   License Plate:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 3C 42 44 4B 52 5F 6C
          6D 75 A5 BB BC D6 D7
VIN: xxxxxxxxxxxxxxxxx   Mileage: 6612km-4108miles
Address 01: Engine (J623-DTSB)       Labels: None
   Part No SW: 05L 906 022 A    HW: 05L 907 309 B
   Component: R4 2.0l TDI   H30 0827
   Revision: E3H30---
   Coding: 0125041203641D0830000000000000000000000000000000
   Shop #: WSC 05311 115 00064
   ASAM Dataset: EV_ECM20TDI01105L906022A 006005
   ROD: EV_ECM20TDI01105L906022A.rod
   VCID: 2514FB15B56BBDD3DC5-8070
   Part No SW: 0GC 300 046 P    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2805
   Revision: 00H06V11
   ASAM Dataset: EV_TCMDQ381061 001001
   ROD: EV_TCMDQ381061_VW48.rod
   VCID: 3728215D1FC73F437E9-8062
   No subsystems:
   Part No SW: 5Q0 614 517 GD    HW: 5Q0 614 517 BR
   Component: ESC           H82 0114
   Revision: 00000000    Serial number: 62770000000592
   Coding: 0FEC7A8FA1203B71477E060460C849F05E85DCE2600692713872F078D2A24A0B0003010312121212B435351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049.rod
   VCID: 79ACE7656953E933C8D-802C
   Part No SW: 3Q0 959 435 M    HW: 3Q0 959 435 M
   Component: VWKESSYMQB    027 1307
   Revision: 00027000    Serial number: 0556717988
   Coding: 002F0F0723
   Shop #: WSC 05311 115 00302
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 44D246915E1164DBEBB-8010
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 3G8 907 044 A    HW: 3G8 907 044 A
   Component: Climatronic   H10 0205
   Coding: 1202010420211401111510008010D836
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 001050
   ROD: EV_AirCondiBHTCMQB3rTranc_VW37.rod
   VCID: 2B000D2DD38F8BA30A1-807E
   Air quality sensor:
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H04 0010
   Serial number: A4F1004400PAG0MUFU04
   Rear A/C control head:
   Subsystem 3 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
          B10CD 00 [044] - -
                    Mileage: 6599 km
                    Date: 2021.03.29
                    Time: 18:59:45
                    Control Module Voltage: 0.000 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up lamp: OFF
                    Blower reduction: No switch-off: no reduction
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [040] - -
          [PTC-Reduzierung durch MSG]
                    Fault Frequency: 12
                    Mileage: 3085 km
                    Date: 2021.01.08
                    Time: 09:44:54
                    Unlearning counter according OBD: 31
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                    Auxiliary heater: in stages-Act.val.: 3
                    Auxiliary heater: in stages-Target value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
   Part No SW: 5Q0 937 086 CK    HW: 5Q0 937 086 BR
   Component: BCM PQ37BOSCH 040 0400
   Revision: --------    Serial number: J53F1909200622
   ASAM Dataset: EV_BodyContrModul1UDSBosc 021001
   ROD: EV_BCMBOSCH_021_VW26.rod
   VCID: 05549B9515AB9DD3BC5-8050
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    200817  042 0607
   Serial number:         200826135059
   Subsystem 2 - Part No SW: 5Q0 955 555 A    HW: 5Q0 955 555 A
   Component: RLHSS  054 0207
   Serial number: S6Y20M09D16H22M32S31
   Coding: 0008DD
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 09 04 2020  10001184
   Subsystem 4 - Part No SW: 3G0 947 105 C    HW: 3G0 947 105 C
   Component: J528 Dachelek  H08 0009
   Serial number: 20092300010058C
   Coding: F38380
   Humidity sensor: interior:
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 521 GE    HW: 5Q1 953 569 D
   Component: Lenks.Modul  H04 0180
   Serial number: 0100180820200C103049
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0073
   Serial number: 000150058020260
   Coding: 8471155811
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 53F075CDAB7FF363621-8006
   Part No SW: 5Q0 907 572 R    HW: 3Q0 907 567 A
   Component: ACC BOSCH MQB H01 0771
   Coding: 32057F5255FFC728949C812481408680000000000000000066
   ASAM Dataset: EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003_VW48.rod
   VCID: 46D65C99682D56CBF5F-8012
0858 - Databus
          [FAULT_KAMERA_SYSTEMZUSTAND_KAMERA_IM_INIT]
                    Reset counter: 190
                    Mileage: 5653 km
                    Date: 2021.02.27
                    Time: 11:18:48
                    Control Module temperature: 32 °C
                    Voltage terminal 15-Voltage: 14.4 V
                    Vehicle speed: 9.42 m/s
                    Longitudinal acceleration: 0.63 m/s²
                    Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
   Part No SW: 5QF 959 655 S    HW: 5QF 959 655 S
   Component: Airbag VW22   015 0639
   Revision: --------    Serial number: 003014APJMJ7K1
   Coding: 98CCC0C0000000005C5400CF000C40000065
   ASAM Dataset: EV_AirbaVW22TS6VW48X 001030
   ROD: EV_AirbaVW22TS6VW48X.rod
   VCID: 6696BC1908ED76CB15F-8032
   Left seat belt tensioner:
   Component: BeltPretRevFL  106 1040
   Serial number: 3G0857705B0263U00427
   Coding: 80000D
   Right seat belt tensioner:
   Component: BeltPretRevFR  106 1040
   Serial number: 3G0857706B0277U00444
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 003 108 20
   Serial number: 35700000000793E0894Q
   Subsystem 4 - Part No SW: -----------    HW: 454 003 108 20
   Serial number: 358000000004D3E0894S
   Subsystem 5 - Part No SW: -----------    HW: 454 800 509 20
   Serial number: 35100D3B6471C000000N
   Subsystem 6 - Part No SW: -----------    HW: 454 800 509 20
   Serial number: 35200016A2D1C000000C
   Subsystem 7 - Part No SW: -----------    HW: 454 802 608 20
   Serial number: 35500F169291C000000P
   Part No SW: 3G0 920 751 G    HW: 3G0 920 751 G
   Component: KOMBI         301 9510
   Coding: 07A409186F8C0008018B6A0B1001000880600000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009018
   ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
   VCID: 290CF725D97399B3F8D-807C
9634544 - Control Module for Electric Steering Column Lock
          B1302 F0 [008] - Not Authorized
                    Mileage: 6539 km
                    Date: 2021.03.26
                    Time: 10:53:26
16777022 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_NAV SD_0x32 keine Kommunikation]
                    Fault Frequency: 16
                    Reset counter: 39
                    Mileage: 5 km
                    Date: 2000.02.11
                    Time: 19:07:44
   Part No SW: 3Q0 907 530 AG    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4424
   Revision: --------    Serial number: 0001124621
   Coding: 030900045F087300FB1042DE180F00000001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 74B2D6514E31945B9BB-8020
   Generator:
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 3G0 959 442 R    HW: 3G0 959 442 R
   Component: E221__MFL-PR6  H07 0110
   Serial number: PR6-0440036263202580
   Coding: 2D0B00
   Serial number: 758860030020091801F6
8526361 - LV Energy Management
          B1802 F1 [008] - Warning Triggered
                    Reset counter: 209
                    Mileage: 6599 km
                    Date: 2021.03.29
                    Time: 19:02:40
                    Terminal 30 power supply: 11.1 V
                    Terminal 15: On
   Part No SW: 3Q0 909 059 AA    HW: 3Q0 909 059 A
   Component: EBKV          H06 0074
   Serial number: BPA085100920013
   Coding: 0102C100340000C618638C31000049922449920400
   ASAM Dataset: EV_BrakeBoostG2BoschVW48X 012121
   ROD: EV_BrakeBoostG2BoschVW48X_012.rod
   VCID: 76B6EC59584D864BA5F-8022
172400 - System Voltage
          P0562 00 [032] - Too Low
          [PSCUnderVoltageLevel1]
   Component: ELV-MQBB      H06 0020
   Serial number: 20000237756004
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 3330154D0BBFD363421-8066
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 14520004175463
   Coding: 52A54640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15.rod
   VCID: 392C276529D3293388D-806C
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 14520003955586
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0330
   Serial number: YE007TI118573
   Coding: 003F0B20D000028000001000
   VCID: 49CC57A57933B9B318D-801C
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 077028 00
   Coding: 0100001100400010
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 19092010523899
   Coding: 00000007090003CA00000F11000000040000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0330
   Serial number: YE007TI30950D
   Coding: 003F0120DC00028000001000
   VCID: 48CA52A1623940BB073-801C
   Part No SW: 3G5 035 820 B    HW: 3G5 035 820 B
   Component: MU-O-ND-EU    H22 0270
   Serial number: VWZAZ2X0798125
   Coding: 24820000000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_VW48.rod
   VCID: 2310E50DBB5F43E3B21-8076
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  361 8214
   Serial number: VWZ6ZHX2794400
   Subsystem 2 - Part No: V03 959 809 BN
   Component: EU 2020/21     3085
12301 - Ethernet Databus Branch 4
          U122F 00 [008] - No Communication
                    Reset counter: 13
                    Mileage: 5241 km
                    Date: 2021.02.23
                    Time: 18:01:32
                    Ethernet counter checksum error: branch 4: 0
                    Ethernet counter connection interruptions: branch 4: 1
12291 - Ethernet Databus Branch 4
          U11BE 00 [008] - Electrical Malfunction
                    Mileage: 5241 km
                    Date: 2021.02.23
                    Time: 18:01:44
   Coding: 0184020162002017000040
   Part No SW: 5Q0 959 107 AA    HW: 5Q0 959 107 H
   Component: HDSG-Modul    H13 0272
   Revision: --------    Serial number: A2-C737-6331-9
   Coding: 0200
   VCID: 77A8E15D5F47FF43BE9-8022
   Part No SW: 5WA 035 284 B    HW: 5WA 035 284 B
   Component: OCUGen3High   H20 0035
   Serial number: 0000000007VIVR2
   Coding: 024820001968A8209005460161102607
   ASAM Dataset: EV_OCUGen3High 003005
   ROD: EV_OCUGen3High_003_VW27.rod
   VCID: 45D45B95552B5DD3FC5-8010
0081 - Databus
          [Ethernet Databus missing message - Infotainment Unit]
                    Reset counter: 39
                    Mileage: 6599 km
                    Date: 2021.03.29
                    Time: 10:57:15
                    Voltage terminal 30: 11.6 V
   Part No SW: 2Q0 980 653     HW: 2Q0 980 653
   Component: MQB MFK 3.0   H13 1030
   Serial number: E57829512202710
   Coding: 00000888116C4020109E10001030008000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005035
   ROD: EV_MFK3ValeoMQB_005_VW27.rod
   VCID: 72BED04934259A6B897-8026
1124198 - Development code 1
          B2F01 00 [008] - -
          [VZF_Init]
                    Fault Priority: 9
                    Reset counter: 20
                    Mileage: 5653 km
                    Date: 2021.02.27
                    Time: 11:18:44
   Part No SW: 5Q0 959 595 K    HW: 8W1 959 595 D
   Component: TSG HFS004 0330
   Serial number: YE007TI50861C
   Coding: 000E01200100028000001000
   ROD: EV_DCU2RearDriveMAXHCONT_VW41.rod
   VCID: 4BC06DAD734FABA32A1-801E
   Component: TSG HBFS004 0330
   Serial number: YE007TI508618
   ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
   Part No SW: 992 941 572 CA    HW: 992 941 572 C
   Component: LED1L         H08 9002
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: 6492A611FED104DB0BB-8030
131353 - Databus
          U1121 00 [032] - Missing Message
   Component: LED1R         H08 9002
131353 - Databus
End----(Elapsed Time: 01:56, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
hex.v2.belgium
Belgium
C?ID=293974
Now for my issue, it seems some of my control modules are too recent? There is no long coding available?
For example, my 09-Cent. Elect. shows all zero's in the long coding helper.
I did a full adaptation channel scan, so is there anything I can submit to help?
hex.v2.belgium
Belgium
C?ID=293974
First tweaks done via 'adaptations':
Rear Daytime Running Lights
Select Control unit 09 (Central Electrics)
Security access
Access Code 31347
Adaptation
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht
Default ‘not active’ - Put to ‘active’
Daytime Running Lights only with switch on ‘Auto’
Security access
Access Code 31347
Adaptation
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO
Comfort open of windows with long press of key
Security access
Access Code 31347
Adaptation
ENG141681-IDE02022-ZV Komfort-Comfort opening
(edited with the 100% correct terms found in adaptations)
hex.v2.belgium
Belgium
C?ID=293974
Hi Uwe,
I was not aware, as most adaptation I found on the net still use the long coding helper, so now trying to figure out what I can do via Adaptations.
One feature which is bugging me is the fact I cannot 'comfort' close my trunk ???
On my previous Passat, I could long-press the trunk button on my keyfob and it would open or close the trunk.
In my new Passat, I can open the trunk via the keyfob, but I cannot close it ???
Can't seem to find the coding to enable this?
One thing I can think of is that my old Passat had Kessy and the new one does not...?
Any help...?
In the meantime I'm preparing a lot more adaptations... Will post them as soon as I was able to implement and test them.
@hex.v2.belgium: Hi.
For trunk unlock with fob, perhaps check the setting of the channel below on the BCM:
  • ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel > active
hex.v2.belgium
Belgium
C?ID=293974
Hi Don,
the problem is not the unlock, my car opens the trunk when I longpress the fob... But I cannot close the trunk with a longpress? (Was able to do that on my previous passat...)
The setting you mentioned is active: ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel,active
Attached a 'dumb' of my original configuration before any adaptations:
SW:5Q0-937-086-CK   HW:5Q0-937-086-BR ---  Cent. Elect.
Component:BCM PQ37BOSCH 040 0400, Coding:000000000000000000000000000000000000000000000000000000000000
EV_BodyContrModul1UDSBosc,021001,EV_BCMBOSCH_021_VW26.rod
Monday,29,March,2021,22:49:25:43967
VCDS Version: Release 21.3.0 (x64)  Data version: 20210226 DS325.0
IDE01550-Service position,153.296551 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,250 ms,10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,250 ms,10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,250 ms,10
IDE02711-ENG112304-Rear wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,active ,8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset,0.3 °,16
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit,100.0 %/s,16
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur,100.0 °C,16
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur,95.0 °C,16
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel,120 °,16
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur,80.0 °C,16
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel,80 °,16
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift,ECE R119 ,16
IDE03638-ENG115830-Stationary cornering lamp-Zeitwert Einschaltzeit Abbiegelicht,15 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage,not installed ,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv,-2.0 °C,11
IDE04927-ENG154810-Window heater-window heating front activation time pause,320 s,11
IDE04928-MAS01577-Anti-theft protection-Parking heater,not installed ,8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG115864-Anti-theft protection-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm system,not active ,8
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklick,activ ,8
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMI,not_active ,8
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung,not active ,8
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Sounder,not installed ,8
IDE04928-ENG141961-Anti-theft protection-Heckscheibenbruchsensor,not installed ,8
IDE04928-ENG142006-Anti-theft protection-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft protection-OBD Alarm,not_active ,8
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarm,activ ,8
IDE04928-ENG142009-Anti-theft protection-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_Innenraumueberwachung,No ,8
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft protection-tilt_sensor,No ,8
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel,not active ,8
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm,keine verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-Light configuration,26 08 00 16 24 00 7F 06 00 80 02 00 7F 00 00 00 26 18 00 18 24 00 7F 07 00 80 04 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 38 00 22 12 16 7F 00 00 00 00 00 00 00 00 00 01 42 00 23 13 17 7F 00 00 00 00 00 00 00 00 00 35 52 00 5D 52 00 7F 08 09 7F 00 00 00 00 00 00 35 53 00 5E 52 00 7F 08 0A 7F 00 00 00 00 00 00 20 00 00 00 1E 00 7F 28 00 80 00 00 00 00 00 00 24 00 00 00 3F 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 04 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00 ,224
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,1 ,30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,18.50 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,17.50 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,18.50 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,17.50 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,27.50 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,26.50 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,27.50 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,26.50 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,40.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,40.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Sollspannungsanforderung 14.7 ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
IDE06507-MAS13132-Button in center console-Function of button 3,not coded/not installed ,8
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG249923-Air conditioning/heating function via remote control-pa_RSt_MOD_verbaut,not installed ,8
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07356-Position during interval mode,24.890085 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor,installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,1 ,19
IDE09731-ENG249826-Int. light: 2nd generation-Ambiente_Fahrprofil_Offroad_Individual,11 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,50 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,50 %,19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,50 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,50 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,50 %,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior lighting,Keine_Spannungsanforderung ,19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht,installed ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,1 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,active ,5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,installed ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,active ,5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,installed ,5
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting,installed ,5
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE10298-Alternating park position 1,8.296695 °,2
IDE10299-Alternating park position 2,24.890085 °,2
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,0.40 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.40 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,0.60 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.60 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000101  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00111100  ,256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000010  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00011100  ,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,127 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,127 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,96 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,127 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,127 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,96 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,127 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,96 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,96 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,127 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,0 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,127 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,96 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,127 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,127 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,127 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,127 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,126 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,126 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,60 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,96 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,96 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,127 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,127 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,96 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,96 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,127 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,96 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit,0.5 s,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,2.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.5 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,64 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,20 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,170 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,30 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,30 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,11 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,255 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,255 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,250 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,100 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,160 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,190 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,230 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,238 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,255 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,175 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,170 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,250 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,230 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,230 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,230 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,255 ,30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,230 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,210 ,30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,210 ,30
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber,active ,3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,active ,3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,active ,3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module,Not available ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor,Not available ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,Not available ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,Not available ,6
IDE12302-SFT271877-Identification of sub-bus participant-Garage door opener control head,Not available ,6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor,Not available ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
IDE12302-SFT271904-Identification of sub-bus participant-Sunroof control module,Not available ,6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module,Not available ,6
IDE12302-SFT271928-Identification of sub-bus participant-Roof shade control module,Not available ,6
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior,Not available ,6
IDE12302-SFT271966-Identification of sub-bus participant-Left head area heater,Not available ,6
IDE12302-SFT271967-Identification of sub-bus participant-Right head area heater,Not available ,6
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest,Not available ,6
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion,Not available ,6
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest,Not available ,6
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion,Not available ,6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control,Not available ,6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch,Not available ,6
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,64 ,30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin,3 ,30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,24 ,30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,1 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,4 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,5 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,4 ,30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,3 ,30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,3 ,30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,255 ,30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,255 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,226 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,3 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,88 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,178 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,198 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,255 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,255 ,30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,255 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,175 ,30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,78 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,138 ,30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,255 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,255 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,255 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,255 ,30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,182 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,149 ,30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,114 ,30
MAS05055-lower turn position,26.296677 °,2
MAS05056-upper turn position,171.296533 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11,30 ,60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12,30 ,60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13,110 ,60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14,140 ,60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15,160 ,60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16,200 ,60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17,255 ,60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18,255 ,60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19,255 ,60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20,255 ,60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21,255 ,60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22,255 ,60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23,255 ,60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24,255 ,60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25,255 ,60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26,255 ,60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27,115 ,60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28,90 ,60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29,70 ,60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30,100 ,60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11,255 ,60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12,235 ,60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13,235 ,60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14,255 ,60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15,225 ,60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16,225 ,60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17,200 ,60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18,160 ,60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19,120 ,60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20,90 ,60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21,40 ,60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22,30 ,60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23,30 ,60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24,30 ,60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28,40 ,60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29,90 ,60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30,110 ,60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11,60 ,60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14,50 ,60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20,10 ,60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21,30 ,60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22,65 ,60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23,120 ,60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24,195 ,60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25,220 ,60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26,255 ,60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27,255 ,60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28,255 ,60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29,255 ,60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30,240 ,60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin,3 ,60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin,2 ,60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin,27 ,60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin,17 ,60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin,60 ,60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin,43 ,60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin,125 ,60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin,200 ,60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin,255 ,60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin,255 ,60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin,255 ,60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin,255 ,60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin,247 ,60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin,255 ,60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin,255 ,60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin,244 ,60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin,42 ,60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin,19 ,60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin,19 ,60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin,42 ,60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin,255 ,60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin,255 ,60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin,255 ,60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin,255 ,60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin,255 ,60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin,255 ,60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin,255 ,60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin,255 ,60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin,146 ,60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin,65 ,60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin,20 ,60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin,3 ,60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin,38 ,60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin,60 ,60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin,30 ,60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin,32 ,60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin,8 ,60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin,34 ,60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin,79 ,60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin,138 ,60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin,59 ,60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin,6 ,60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin,24 ,60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin,70 ,60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin,19 ,60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin,3 ,60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin,1 ,60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin,32 ,60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin,20 ,60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin,9 ,60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin,1 ,60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin,28 ,60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin,63 ,60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin,142 ,60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin,188 ,60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin,255 ,60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin,255 ,60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin,255 ,60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin,255 ,60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin,255 ,60
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,I-panel ,30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,multicolor ,30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,multicolor ,30
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,1 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,2 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,3 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,4 ,60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,5 ,60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,6 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,04 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,8 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,12 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,16 ,60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,20 ,60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,21 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,installed ,60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,installed ,60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,installed ,60
ENG126650-ENG126926-Ambiente_light-Dimmung_auf_Zielwert deaktivieren_Suchbeleuchtung,not active ,13
ENG126650-ENG126927-Ambiente_light-Dimmung_auf_Zielwert_deaktivieren_Innen_und_Leselicht,not active ,13
ENG126650-ENG126922-Ambiente_light-Korrekturfaktor_ Flaechenlicht_vorne_Farbe_1,1.00 ,13
ENG126650-ENG126924-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_1,1.00 ,13
ENG126650-ENG126925-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_2,0.78 ,13
ENG126650-ENG126923-Ambiente_light-Korrekturfaktor_Flaechenlicht_vorne_Farbe_2,0.14 ,13
ENG126650-ENG126921-Ambiente_light-Korrekturfaktor_Funktionsbeleuchtung,1.00 ,13
ENG126650-ENG126918-Ambiente_light-Korrekturfaktor_Leselicht_hinten,0.86 ,13
ENG126650-ENG126919-Ambiente_light-Korrekturfaktor_Leselicht_Reihe_3,1.00 ,13
ENG126650-ENG126917-Ambiente_light-Korrekturfaktor_Leselicht_vorne,0.86 ,13
ENG126650-ENG126920-Ambiente_light-Korrekturfaktor_Schalter_und_Suchbeleuchtung,1.00 ,13
ENG128378-ENG115658-Ambiente_Light_Kennlinie_Hochdimmen-x0,0 ms,22
ENG128378-ENG101574-Ambiente_Light_Kennlinie_Hochdimmen-X1,200 ms,22
ENG128378-ENG115664-Ambiente_Light_Kennlinie_Hochdimmen-x10,2000 ms,22
ENG128378-ENG99557-Ambiente_Light_Kennlinie_Hochdimmen-X2,400 ms,22
ENG128378-ENG102140-Ambiente_Light_Kennlinie_Hochdimmen-X3,600 ms,22
ENG128378-ENG102936-Ambiente_Light_Kennlinie_Hochdimmen-X4,800 ms,22
ENG128378-ENG103548-Ambiente_Light_Kennlinie_Hochdimmen-X5,1000 ms,22
ENG128378-ENG113992-Ambiente_Light_Kennlinie_Hochdimmen-X6,1200 ms,22
ENG128378-ENG115661-Ambiente_Light_Kennlinie_Hochdimmen-x7,1400 ms,22
ENG128378-ENG115662-Ambiente_Light_Kennlinie_Hochdimmen-x8,1600 ms,22
ENG128378-ENG115663-Ambiente_Light_Kennlinie_Hochdimmen-x9,1800 ms,22
ENG128378-ENG115659-Ambiente_Light_Kennlinie_Hochdimmen-y0,0.0 %,22
ENG128378-ENG99777-Ambiente_Light_Kennlinie_Hochdimmen-Y1,0.5 %,22
ENG128378-ENG115668-Ambiente_Light_Kennlinie_Hochdimmen-y10,100.0 %,22
ENG128378-ENG100480-Ambiente_Light_Kennlinie_Hochdimmen-Y2,2.0 %,22
ENG128378-ENG100773-Ambiente_Light_Kennlinie_Hochdimmen-Y3,5.0 %,22
ENG128378-ENG100631-Ambiente_Light_Kennlinie_Hochdimmen-Y4,10.0 %,22
ENG128378-ENG102174-Ambiente_Light_Kennlinie_Hochdimmen-Y5,20.0 %,22
ENG128378-ENG113993-Ambiente_Light_Kennlinie_Hochdimmen-Y6,40.0 %,22
ENG128378-ENG115665-Ambiente_Light_Kennlinie_Hochdimmen-y7,80.0 %,22
ENG128378-ENG115666-Ambiente_Light_Kennlinie_Hochdimmen-y8,95.0 %,22
ENG128378-ENG115667-Ambiente_Light_Kennlinie_Hochdimmen-y9,99.0 %,22
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,6 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,19 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,3 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,8 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,18 ,23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6,21 ,23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8,21 ,23
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,active ,10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,active ,10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Wechselblinken_Warnblinken_Bremsblinken ,10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,active ,10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS,PreCrash_aktiv ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,active ,10
ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinken,active ,10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,active ,10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,active ,10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,active ,10
ENG141649-ENG251922-Außenlicht_Blinker-Travel_Assist_Blinken,not active ,10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,active ,10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,active ,10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max,120 min,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,active ,10
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren,not active ,9
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag,Daytime running lamps ,9
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141656-ENG249813-Außenlicht_uebergreifend-ABL_Abschaltung_nach_ECE48_Rev6,No ,18
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather light,not installed ,18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf,3000 ms,18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,manual ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp,Keine_Spannungsanforderung ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,696 lx,18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,800 lx,18
ENG141656-ENG249901-Außenlicht_uebergreifend-Licht_Schaltung_nach_ECE48_Rev6,not active ,18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),LIN ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG141656-ENG249943-Außenlicht_uebergreifend-TFL_Abschaltung_nach_ECE48_Rev6,No ,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp,Keine_Spannungsanforderung ,18
ENG246955-ENG246967-digital_key-central_locking_digital_key_general,not installed ,3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle,not active ,3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle,not active ,3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246991-digital_key-pa_Two_Keys,active ,3
ENG122934-erase_error_table,55 00 00 ,3
ENG122933-error_mask,0 bit,2
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht (GLW:MDF) ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv,active ,8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung,installed ,8
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer,installed ,8
ENG126651-ENG115658-Kennlinie Abdimmen-x0,0 ,22
ENG126651-ENG101574-Kennlinie Abdimmen-X1,200 ,22
ENG126651-ENG115664-Kennlinie Abdimmen-x10,2000 ,22
ENG126651-ENG99557-Kennlinie Abdimmen-X2,400 ,22
ENG126651-ENG102140-Kennlinie Abdimmen-X3,600 ,22
ENG126651-ENG102936-Kennlinie Abdimmen-X4,800 ,22
ENG126651-ENG103548-Kennlinie Abdimmen-X5,1000 ,22
ENG126651-ENG113992-Kennlinie Abdimmen-X6,1200 ,22
ENG126651-ENG115661-Kennlinie Abdimmen-x7,1400 ,22
ENG126651-ENG115662-Kennlinie Abdimmen-x8,1600 ,22
ENG126651-ENG115663-Kennlinie Abdimmen-x9,1800 ,22
ENG126651-ENG115659-Kennlinie Abdimmen-y0,100.0 ,22
ENG126651-ENG99777-Kennlinie Abdimmen-Y1,99.0 ,22
ENG126651-ENG115668-Kennlinie Abdimmen-y10,0.0 ,22
ENG126651-ENG100480-Kennlinie Abdimmen-Y2,95.0 ,22
ENG126651-ENG100773-Kennlinie Abdimmen-Y3,80.0 ,22
ENG126651-ENG100631-Kennlinie Abdimmen-Y4,40.0 ,22
ENG126651-ENG102174-Kennlinie Abdimmen-Y5,20.0 ,22
ENG126651-ENG113993-Kennlinie Abdimmen-Y6,10.0 ,22
ENG126651-ENG115665-Kennlinie Abdimmen-y7,5.0 ,22
ENG126651-ENG115666-Kennlinie Abdimmen-y8,2.0 ,22
ENG126651-ENG115667-Kennlinie Abdimmen-y9,0.5 ,22
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,49.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,49.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,49.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,49.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,45.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,40.5 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,35.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,30.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,25.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,20.0 %,30
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0,minimize ,16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,127 ,16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0,127 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,16 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,08 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,38 - LED Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Quittierungsfunktion 1 ,16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,Blinken links aktiv (beide Phasen) ,16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,Blinken links Hellphase ,16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Warnblinktaster_Suchbeleuchtung ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,4 - LED Tagfahrlichtmodul Signal ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,4 - LED Tagfahrlichtmodul Signal ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,39 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,10 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,43 - allgemeine LED ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,3A ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,20 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,43 - allgemeine LED ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parking light right ,16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,minimize ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,127 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,Quittierungsfunktion 1 ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,Blinken links aktiv (beide Phasen) ,16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,Blinken links Hellphase ,16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,minimize ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,127 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,Quittierungsfunktion 1 ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,Blinken rechts aktiv (beide Phasen) ,16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,Blinken rechts Hellphase ,16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1,minimize ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,127 ,16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1,127 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,18 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,18 ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,38 - LED Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Quittierungsfunktion 1 ,16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,Blinken rechts aktiv (beide Phasen) ,16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,Blinken rechts Hellphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake lamp ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake lamp ,16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,minimize ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,25 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,127 ,16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,25 ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,2E ,16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,0C ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,only_if_closed ,16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Brake lamp ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,Rear lid open ,16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,Brake lamp ,16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,minimize ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,38 ,16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,00 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,34 - LED Bremsleuchten ,16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Brake lamp ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,29 ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0A ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,32 - allgemeine LED bis 12W ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2A ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1A ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,Parking light right ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,37 - allgemeine LED bis 12W ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,37 - allgemeine LED bis 12W ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,22 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,38 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Nebellicht links ,16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,Abbiegelicht links ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,23 ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,42 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Nebellicht rechts ,16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,Abbiegelicht rechts ,16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,5D ,16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,52 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,53 - LED LeiMo3G o Open Load ,16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Versorgungsbedarf der LED-LeiMo3G-Module ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,5E ,16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,53 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,53 - LED LeiMo3G o Open Load ,16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Versorgungsbedarf der LED-LeiMo3G-Module ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,Parking light right ,16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,minimize ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,00 ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,00 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,32 - allgemeine LED bis 12W ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Coming Home oder Leaving Home aktiv ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,00 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,00 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,36 - LED Kleinleistung ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 24 00 7F 06 00 80 02 00 7F 00 00 00 26 18 00 18 24 00 7F 07 00 80 04 00 7F 00 00 00 22 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 2B 0C 00 2E 18 00 99 1A 00 7F 21 00 80 18 00 19 22 00 00 38 18 00 7F 1A 00 80 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 20 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 20 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 25 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 25 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,2B 10 00 39 08 09 7F 00 00 00 00 00 00 00 00 00 2B 20 00 3A 08 0A 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-114.3 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1,2.0 s,7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang,10 s,7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS,Nicht_verbaut ,7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark,not active ,7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze,100 m,7
ENG246957-ENG246981-Lichttaster-Lichttastermodul,lds ,7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config,00000001  ,7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle,30 km/h,7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig,active ,7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig,active ,7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig,not active ,7
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.50 ,27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,5 °C,27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,25.0 %,27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,40 °C,27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,45 °C,27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,50 °C,27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,57 °C,27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,0 ms,27
ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung,0 ms,27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,30 s,27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Horn operation,Always ,2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear wiper,installed ,2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition Switch Key Lock Solenoid,not installed ,2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation,not installed ,2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,installed ,2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation,not active ,2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,not installed ,2
ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button,not installed ,2
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
ENG124714-ENG142044-OCU-DWA_push,active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG124714-ENG246970-OCU-IAA -Nutzer_management,installed ,8
ENG124714-OCU-,installed ,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via BAP / Fazit ,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,7 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 2.x) ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG249801-ENG249833-PKW-Schiebetueren-CAN_TSG_HBFS_verbaut,No ,4
ENG249801-ENG249834-PKW-Schiebetueren-CAN_TSG_HFS_verbaut,No ,4
ENG249801-ENG249925-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_nachverriegeln,No ,4
ENG249801-ENG249926-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_verbaut,No ,4
ENG249801-ENG249927-PKW-Schiebetueren-PKW_Schiebetuer_HFS_nachverriegeln,No ,4
ENG249801-ENG249928-PKW-Schiebetueren-PKW_Schiebetuer_HFS_verbaut,No ,4
ENG249801-ENG251921-PKW-Schiebetueren-SBT_Entr_im_Zustand_entriegelt,No ,4
ENG249801-ENG249939-PKW-Schiebetueren-STSG_HBFS_verbaut,No ,4
ENG249801-ENG249940-PKW-Schiebetueren-STSG_HFS_verbaut,No ,4
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG249802-ENG249933-Rear_view_camera_wash-RVC_Speed_Hysteresis,5 km/h,8
ENG249802-ENG249934-Rear_view_camera_wash-RVC_Speed_max,50 km/h,8
ENG249802-ENG249935-Rear_view_camera_wash-RVC_Time_cleaning_Pumpe_active_BCM,1.5 s,8
ENG249802-ENG249936-Rear_view_camera_wash-RVC_Waschen_HMI,not active ,8
ENG249802-ENG249937-Rear_view_camera_wash-RVC_Wash,not installed ,8
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG249900-Scheinwerferreinigung-Init Versatz Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2550 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,1200 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,1200 ms,10
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,0 ms,48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,0 ms,48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,0 ms,48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 s,48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,0 ,48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,0 ms,48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,0 ms,48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,0 ms,48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,0 ms,48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,0 s,48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,0.0 s,48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,0 s,48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG,not installed ,4
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,1000 ms,10
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,1.1 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,11 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 %,21
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,CAN ,4
ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3
ENG141969-ENG249832-UGDO-Bedienfeld,not installed ,3
ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,installed ,9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar,not active ,9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version,Version_1_2 ,9
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern,active ,7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum,ZV_Wiederveriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,not active ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Kontaktsteuerung mit Mindestansteuerzeit ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,Tuersteuergeraet im Fond verbaut oder keine Fondtuer ,5
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal,Inverted ,5
@hex.v2.belgium: hmm....... OK- my bad!! I'm not aware of such a facility. However, on MQB platform cars it's possible to automatically re-lock the hatch after it has been closed (having first unlocked the hatch with the key fob). If this is a suitable alternative, try this (again on the BCM):
  • ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt > active
hex.v2.belgium
Belgium
C?ID=293974
Some extra tweaks for control unit 09 (Central Electrics):
Select Control unit 09 (Central Electrics)
Security access
Access Code 31347
Adaptation
Daytime running lights setting available via menu:
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich not active to active
Automatic coming home lights
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus manual to automatic
Front wiper extra wipe
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status not active to active
Windows do not stop when opening doors
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen active to not active
hex.v2.belgium
Belgium
C?ID=293974
Some extra tweaks for Control unit 44 (Steering):
Adapt steering response when not having driving profile option
Select Control unit 44 (Steering)
Security access
Access Code 19249
Adaptation
Steering adaptation
Change to Comfort / Automatic / Dynamic (depending your linking)
hex.v2.belgium
Belgium
C?ID=293974
Some extra tweaks for Control unit 03 (ABS Brakes)
Select Control unit 03 (ABS Brakes)
Adaptation
IDE04871-Dynamic starting assist normal to Early (Faster release of the handbrake with launch)
MAS02138-Hill-start assistant normal to Early (Faster release of the handbrake on hill)
But!!! I'm having some problems in trying to activate the XDS...
Normally I should just do the following adaptation:
IDE05286-Expanded electronic differential lock Standard to Strong
This get's rejected and is now asking for a security code ??? That was not the case on my previous Passat.
Anybody have an idea for the security code of the Control unit 03 (ABS Brakes)
EDIT: FOUND IT! After some searching on the internet, security code 20103 works!
So XDS is now also fully activated.
I added the original ADPMAP if this helps...
Also seems this is a new control module, because when I wanted to check the long coding, it mentioned is was a new module and unknown at this time...
SW:5Q0-614-517-GD   HW:5Q0-614-517-BR ---  ABS Brakes
Component:ESC           H82 0114, Coding:0FEC7A8FA1203B71477E060460C849F05E85DCE2600692713872F078D2A24A0B0003010312121212B435351919323200
EV_Brake1UDSContiMK100IPB,049015,EV_Brake1UDSContiMK100IPB_049.rod
Tuesday,30,March,2021,21:23:59:43967
VCDS Version: Release 21.3.0 (x64)  Data version: 20210226 DS325.0
VCID: 79ACE7656953E933C8D-802C
IDE00252-Brake system vacuum pump,5 ,1
IDE00820-Activating and deactivating all development messages,0 ,1
IDE01763-Dimming,activated ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE03493-Driver's door status,activated ,1
IDE03659-Roller test bench mode,Manual activation: possible ,1
IDE04456-Brake disk drying,Medium ,1
IDE04508-Hydraulic brake booster,8 ,1
IDE04643-Overboost in brake system,activated ,1
IDE04645-Electromechanical parking brake,not activated ,1
IDE04774-Vehicle and trailer stabilization,not activated ,1
IDE04871-Dynamic starting assist,normal ,1
IDE04939-Tire Pressure Monitoring System (TPMS),2 ,1
IDE04944-Brake pedal evaluation,activated ,1
IDE04949-Engine drag torque control,activated ,1
IDE04951-Brake Boost,4 ,1
IDE04952-Braking torque boost for distance regulation,3 ,1
IDE05055-Hydraulic brake assistant,normal ,1
IDE05057-Brake prefill,activated ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE05263-AUTO HOLD functionality,not activated ,1
IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %,1
IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %,1
IDE05286-Expanded electronic differential lock,Standard ,1
IDE05711-Automatic application during engine stalling,activated ,1
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7 ,2
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7 ,2
IDE06139-AUTO HOLD slippage recognition,activated ,1
IDE06505-Electromechanical parking brake: delay level,6 ,1
IDE07006-Tire pressure monitoring display: tire selection,2 ,1
IDE07565-ABS in lower speed range,activated ,1
IDE07848-Thresholds for brake performance,activated ,1
IDE12030-Rough road optimization,activated ,1
MAS00122-Electronic Stability Program,not activated ,1
MAS00970-Running manufacturer number,activated ,1
MAS01180-AUTO HOLD functional status,Last setting ,1
MAS01299-Offroad,0 ,1
MAS02080-XCP calibration protocol,not activated ,1
MAS02138-Hill-start assistant,normal ,1
MAS02666-Seat belt buckle scan,activated ,1
MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,3
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,3
MAS09008-MAS10668-Plausibility check-Clutch movement,activated ,3
MAS11606-Electromechanical parking brake: emergency braking,activated ,1
ENG130301-Developer_Function_121,not activated ,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,10 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,50 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,100 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,220 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,253 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,6 ,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 ,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,8 ,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,12 ,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 ,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 ,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,6 ,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,6 ,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,8 ,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,12 ,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,80 ,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 ,12
kreativ
Hidden
C?ID=108852
Closing trunk with key fob requires other tool to make it work.
dieseltje
Groningen, The Netherlands
C?ID=148044
On the dutch Passat forum I spoke with TS. He still has a problem with Lane Assist.
Lane Assist is in the new cars devault status on. In the headunit or on MFL steer you can switch it of, but after restart of the car LA is again on.
There is no option to set it (like previous Passat types) to last stored position.
I've noticed that this problem is also with other new type cars, like T-Cross and Polo.
Is it some way changeable via adaptions?
I will copy the complete log of TS. But what adaption map should be the right one?
As I look into A5 adaptations, you will only find camera settings.
Monday,29,March,2021,22:44:35:43967
VIN: WVWZZZXXXXXXXXXXX   License Plate:
Mileage: xxxxkm-xxxxmi   Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 3C 42 44 4B 52 5F 6C
          6D 75 A5 BB BC D6 D7
VIN: WVWZZZXXXXXXXXXXX   Mileage: xxxxkm-xxxxmi
Address 01: Engine (J623-DTSB)       Labels: None
   Part No SW: 05L 906 022 A    HW: 05L 907 309 B
   Component: R4 2.0l TDI   H30 0827
   Revision: E3H30---
   Coding: 0125041203641D0830000000000000000000000000000000
   Shop #: WSC 05311 115 00064
   ASAM Dataset: EV_ECM20TDI01105L906022A 006005
   ROD: EV_ECM20TDI01105L906022A.rod
   VCID: 2514FB15B56BBDD3DC5-8070
   Part No SW: 0GC 300 046 P    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2805
   Revision: 00H06V11
   ASAM Dataset: EV_TCMDQ381061 001001
   ROD: EV_TCMDQ381061_VW48.rod
   VCID: 3728215D1FC73F437E9-8062
   No subsystems:
   Part No SW: 5Q0 614 517 GD    HW: 5Q0 614 517 BR
   Component: ESC           H82 0114
   Revision: 00000000    Serial number: 62770000000592
   Coding: 0FEC7A8FA1203B71477E060460C849F05E85DCE2600692713872F078D2A24A0B0003010312121212B435351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049.rod
   Part No SW: 3Q0 959 435 M    HW: 3Q0 959 435 M
   Component: VWKESSYMQB    027 1307
   Revision: 00027000    Serial number: 0556717988
   Coding: 002F0F0723
   Shop #: WSC 05311 115 00302
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 44D246915E1164DBEBB-8010
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 3G8 907 044 A    HW: 3G8 907 044 A
   Component: Climatronic   H10 0205
   Coding: 1202010420211401111510008010D836
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 001050
   ROD: EV_AirCondiBHTCMQB3rTranc_VW37.rod
   VCID: 2B000D2DD38F8BA30A1-807E
   Air quality sensor:
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H04 0010
   Serial number: A4F1004400PAG0MUFU04
   Rear A/C control head:
   Subsystem 3 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
          B10CD 00 [044] - -
                    Mileage: 6599 km
                    Date: 2021.03.29
                    Time: 18:59:45
                    Control Module Voltage: 0.000 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up lamp: OFF
                    Blower reduction: No switch-off: no reduction
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [040] - -
          [PTC-Reduzierung durch MSG]
                    Fault Frequency: 12
                    Mileage: 3085 km
                    Date: 2021.01.08
                    Time: 09:44:54
                    Unlearning counter according OBD: 31
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                    Auxiliary heater: in stages-Act.val.: 3
                    Auxiliary heater: in stages-Target value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
   Part No SW: 5Q0 937 086 CK    HW: 5Q0 937 086 BR
   Component: BCM PQ37BOSCH 040 0400
   Revision: --------    Serial number: J53F1909200622
   ASAM Dataset: EV_BodyContrModul1UDSBosc 021001
   ROD: EV_BCMBOSCH_021_VW26.rod
   VCID: 05549B9515AB9DD3BC5-8050
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    200817  042 0607
   Serial number:         200826135059
   Subsystem 2 - Part No SW: 5Q0 955 555 A    HW: 5Q0 955 555 A
   Component: RLHSS  054 0207
   Serial number: S6Y20M09D16H22M32S31
   Coding: 0008DD
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 09 04 2020  10001184
   Subsystem 4 - Part No SW: 3G0 947 105 C    HW: 3G0 947 105 C
   Component: J528 Dachelek  H08 0009
   Serial number: 20092300010058C
   Coding: F38380
   Humidity sensor: interior:
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 521 GE    HW: 5Q1 953 569 D
   Component: Lenks.Modul  H04 0180
   Serial number: 0100180820200C103049
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0073
   Serial number: 000150058020260
   Coding: 8471155811
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 53F075CDAB7FF363621-8006
   Part No SW: 5Q0 907 572 R    HW: 3Q0 907 567 A
   Component: ACC BOSCH MQB H01 0771
   Coding: 32057F5255FFC728949C812481408680000000000000000066
   ASAM Dataset: EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003_VW48.rod
   VCID: 46D65C99682D56CBF5F-8012
0858 - Databus
          [FAULT_KAMERA_SYSTEMZUSTAND_KAMERA_IM_INIT]
                    Reset counter: 190
                    Mileage: 5653 km
                    Date: 2021.02.27
                    Time: 11:18:48
                    Control Module temperature: 32 °C
                    Voltage terminal 15-Voltage: 14.4 V
                    Vehicle speed: 9.42 m/s
                    Longitudinal acceleration: 0.63 m/s²
                    Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
   Part No SW: 5QF 959 655 S    HW: 5QF 959 655 S
   Component: Airbag VW22   015 0639
   Revision: --------    Serial number: 003014APJMJ7K1
   Coding: 98CCC0C0000000005C5400CF000C40000065
   ASAM Dataset: EV_AirbaVW22TS6VW48X 001030
   ROD: EV_AirbaVW22TS6VW48X.rod
   VCID: 6696BC1908ED76CB15F-8032
   Left seat belt tensioner:
   Component: BeltPretRevFL  106 1040
   Serial number: 3G0857705B0263U00427
   Coding: 80000D
   Right seat belt tensioner:
   Component: BeltPretRevFR  106 1040
   Serial number: 3G0857706B0277U00444
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 003 108 20
   Serial number: 35700000000793E0894Q
   Subsystem 4 - Part No SW: -----------    HW: 454 003 108 20
   Serial number: 358000000004D3E0894S
   Subsystem 5 - Part No SW: -----------    HW: 454 800 509 20
   Serial number: 35100D3B6471C000000N
   Subsystem 6 - Part No SW: -----------    HW: 454 800 509 20
   Serial number: 35200016A2D1C000000C
   Subsystem 7 - Part No SW: -----------    HW: 454 802 608 20
   Serial number: 35500F169291C000000P
   Part No SW: 3G0 920 751 G    HW: 3G0 920 751 G
   Component: KOMBI         301 9510
   Coding: 07A409186F8C0008018B6A0B1001000880600000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009018
   ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
   VCID: 290CF725D97399B3F8D-807C
9634544 - Control Module for Electric Steering Column Lock
          B1302 F0 [008] - Not Authorized
                    Mileage: 6539 km
                    Date: 2021.03.26
                    Time: 10:53:26
16777022 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_NAV SD_0x32 keine Kommunikation]
                    Fault Frequency: 16
                    Reset counter: 39
                    Mileage: 5 km
                    Date: 2000.02.11
                    Time: 19:07:44
   Part No SW: 3Q0 907 530 AG    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4424
   Revision: --------    Serial number: 0001124621
   Coding: 030900045F087300FB1042DE180F00000001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 74B2D6514E31945B9BB-8020
   Generator:
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 3G0 959 442 R    HW: 3G0 959 442 R
   Component: E221__MFL-PR6  H07 0110
   Serial number: PR6-0440036263202580
   Coding: 2D0B00
   Serial number: 758860030020091801F6
8526361 - LV Energy Management
          B1802 F1 [008] - Warning Triggered
                    Reset counter: 209
                    Mileage: 6599 km
                    Date: 2021.03.29
                    Time: 19:02:40
                    Terminal 30 power supply: 11.1 V
                    Terminal 15: On
   Part No SW: 3Q0 909 059 AA    HW: 3Q0 909 059 A
   Component: EBKV          H06 0074
   Serial number: BPA085100920013
   Coding: 0102C100340000C618638C31000049922449920400
   ASAM Dataset: EV_BrakeBoostG2BoschVW48X 012121
   ROD: EV_BrakeBoostG2BoschVW48X_012.rod
   VCID: 76B6EC59584D864BA5F-8022
172400 - System Voltage
          P0562 00 [032] - Too Low
          [PSCUnderVoltageLevel1]
   Component: ELV-MQBB      H06 0020
   Serial number: 20000237756004
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 3330154D0BBFD363421-8066
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 14520004175463
   Coding: 52A54640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15.rod
   VCID: 392C276529D3293388D-806C
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 14520003955586
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0330
   Serial number: YE007TI118573
   Coding: 003F0B20D000028000001000
   VCID: 49CC57A57933B9B318D-801C
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 077028 00
   Coding: 0100001100400010
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 19092010523899
   Coding: 00000007090003CA00000F11000000040000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0330
   Serial number: YE007TI30950D
   Coding: 003F0120DC00028000001000
   VCID: 48CA52A1623940BB073-801C
   Part No SW: 3G5 035 820 B    HW: 3G5 035 820 B
   Component: MU-O-ND-EU    H22 0270
   Serial number: VWZAZ2X0798125
   Coding: 24820000000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_VW48.rod
   VCID: 2310E50DBB5F43E3B21-8076
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  361 8214
   Serial number: VWZ6ZHX2794400
   Subsystem 2 - Part No: V03 959 809 BN
   Component: EU 2020/21     3085
12301 - Ethernet Databus Branch 4
          U122F 00 [008] - No Communication
                    Reset counter: 13
                    Mileage: 5241 km
                    Date: 2021.02.23
                    Time: 18:01:32
                    Ethernet counter checksum error: branch 4: 0
                    Ethernet counter connection interruptions: branch 4: 1
12291 - Ethernet Databus Branch 4
          U11BE 00 [008] - Electrical Malfunction
                    Mileage: 5241 km
                    Date: 2021.02.23
                    Time: 18:01:44
   Coding: 0184020162002017000040
   Part No SW: 5Q0 959 107 AA    HW: 5Q0 959 107 H
   Component: HDSG-Modul    H13 0272
   Revision: --------    Serial number: A2-C737-6331-9
   Coding: 0200
   VCID: 77A8E15D5F47FF43BE9-8022
   Part No SW: 5WA 035 284 B    HW: 5WA 035 284 B
   Component: OCUGen3High   H20 0035
   Serial number: 0000000007VIVR2
   Coding: 024820001968A8209005460161102607
   ASAM Dataset: EV_OCUGen3High 003005
   ROD: EV_OCUGen3High_003_VW27.rod
   VCID: 45D45B95552B5DD3FC5-8010
0081 - Databus
          [Ethernet Databus missing message - Infotainment Unit]
                    Reset counter: 39
                    Mileage: 6599 km
                    Date: 2021.03.29
                    Time: 10:57:15
                    Voltage terminal 30: 11.6 V
   Part No SW: 2Q0 980 653     HW: 2Q0 980 653
   Component: MQB MFK 3.0   H13 1030
   Serial number: E57829512202710
   Coding: 00000888116C4020109E10001030008000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005035
   ROD: EV_MFK3ValeoMQB_005_VW27.rod
   VCID: 72BED04934259A6B897-8026
1124198 - Development code 1
          B2F01 00 [008] - -
          [VZF_Init]
                    Fault Priority: 9
                    Reset counter: 20
                    Mileage: 5653 km
                    Date: 2021.02.27
                    Time: 11:18:44
   Part No SW: 5Q0 959 595 K    HW: 8W1 959 595 D
   Component: TSG HFS004 0330
   Serial number: YE007TI50861C
   Coding: 000E01200100028000001000
   ROD: EV_DCU2RearDriveMAXHCONT_VW41.rod
   VCID: 4BC06DAD734FABA32A1-801E
   Component: TSG HBFS004 0330
   Serial number: YE007TI508618
   ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
   Part No SW: 992 941 572 CA    HW: 992 941 572 C
   Component: LED1L         H08 9002
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: 6492A611FED104DB0BB-8030
131353 - Databus
          U1121 00 [032] - Missing Message
   Component: LED1R         H08 9002
131353 - Databus
End----(Elapsed Time: 01:56, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
Monday,29,March,2021,22:47:52:43967
VIN: WVWZZZxxxxxxxxxxxx   License Plate:
UDS Adaptation Channel (-1/28): IDE00001-Production mode
Stored value 300.0 km/h
@dieseltje : Hi.
Lane Assist (as distinct from "Lane departure") is managed by the front facing camera - so the normal instruction for this tweak is on A5 - Frt Sens. Drv. Assist module and the reference channel is :-
  • IDE10407-Personalization of intervention moment at T. 15 on
The channel has 3 x allowable settings; early, late and last setting
The channel is present on 3Q0 series modules - not sure about your 2Q0 module. Are you certain that it's not there?
hex.v2.belgium
Belgium
C?ID=293974
@dieseltje : Hi.
The normal instruction for this tweak is on A5 - Frt Sens. Drv. Assist module:-
The channel is present on 3QO series modules - not sure about your 2Q0 module. Are you certain that it's not there?
Hi DV52,
@dieseltje is asking the question on my behalf as I also asked on a Dutch VW Passat forum...
Issue is that the adpmap for the A5 module almost has no parameters anymore. Clearly this module has changed significantly...
ADPMAP for A5 Frt Sens. Drv. Assist:
SW:2Q0-980-653   HW:2Q0-980-653 ---  Frt Sens. Drv. Assist
Component:MQB MFK 3.0   H13 1030, Coding:00000888116C4020109E10001030008000418000000000000000000000000000
EV_MFK3ValeoMQB,005035,EV_MFK3ValeoMQB_005_VW27.rod
Tuesday,30,March,2021,21:37:18:43967
IDE06425-Dynamometer mode: functional-,not activated ,1
IDE06425-ENG98891-Dynamometer mode: functional-Reserved,0 ,1
IDE10924-MAS02479-Initial calibration: result-Yaw angle,0.000 °,8
IDE10924-MAS05286-Initial calibration: result-Roll angle,0.000 °,8
IDE10924-MAS05287-Initial calibration: result-Pitch angle,0.000 °,8
IDE10924-MAS10678-Initial calibration: result-Camera height,0 mm,8
Elapsed Time: 00:08
@hex.v2.belgium : Bummer - a clear case of newer modules restricting user flexibility - doubtless VAG call this "progress" (not) !! :confused:
EDIT: I note that your 2Q0 module has a long-code string with over 30 x Bytes - whereas the older 3Q0 module Byte count is 21. Your auto-scan hasn't picked-up a label file for the Helper screens - but maybe these newer modules have software switches for some of the missing adaptation channels. Wild guess but worth a look - when a label file is developed by RT
hex.v2.belgium
Belgium
C?ID=293974
Any idea how to proceed with this? When I try to do long coding for most of my modules VAG-COM indicates the module is unknown?
Is there anything I can help with so RT can make progress on this?
Yes - indeed you can help!! Ross-Tech enjoys receiving "Debug level 2" maps of new modules for which there has not been any label files created. It's always been a mystery to me as to what happens behind the heavy security doors @ RT HQ when they receive these maps - but as I understand from HERE, the process expedites the creation of new label files.
hex.v2.belgium
Belgium
C?ID=293974
Done!
Just did a full level2 debug scan and sent to RT together with the autoscan...
Actually, this created ADPmap and Blockmap files with the CSV extension and not PLB/PLA, so hope this is ok... Actually checked twice and debug level 2 was correctly set...
Hope they are able to look into this soon. Eager to start understanding those new modules and what options they have.
hex.v2.belgium
Belgium
C?ID=293974
Hey, small update...
Found the way to adapt the lane assist on the new Passat with MIB3...
Setting is now in the 'Long Coding' of the A5 Frt Sens. Drv. Assist module...
In the long coding I now found the lane assist and was able to adapt it !!!
Was able to change it to 'last setting' and now indeed the lane assist remembers my last setting instead of being always on.
