Hex-net not working on french version
mbahi
Algeria
C?ID=389389
So bought hex-net but when i run it using the french version it doesn't work it says " version non licencée" but it work when i use the english version
langers2k
C?ID=224085
Where did you buy VCDS from?
Only those from certain French distributors support the French version I'm afraid :(
Bruce
Near Philadelphia, PA, USA
That is correct langers2k. Only the French distributor distributes the French translation. If the unit is not licensed for French, the French translation is not supported on that device. Adding a license by an end user is not normally permitted. The unit has to be sent to the language distributor for re-licensing.
Looks like it came from a distributor in Canada...
Eric
HC800000
You're not getting a french license for free at this point, but the french translation overlord has been known to make exceptions upon receipt of a $100 donation to SAF.org :)
mbahi
Algeria
C?ID=389389
Yes guys I bought it from canada so what should i do now to make it run on the french version ? Keeping in mind am not located in canada
