Tiguan mk2 Front wiper teardrop wipe
Andy4195
Yorkshire, UK
C?ID=426740
As the title says does anyone know how to activate the front wiper teardrop wipe, the rear wiper has the teardrop wipe must be standard as ive not activated it’s, i notice from reading threads about the golf it’s in 09 central electric however when connected to my 2017 tiguan I’m unable to make any changes or even read anything in 09 central electrics,it won’t allow me is this normal.
downtime
Finland
C?ID=280813
Have you tried to do it with your hood open?
Andy4195
Yorkshire, UK
C?ID=426740
No I was sat in with the doors shut and ignition on,
downtime
Finland
C?ID=280813
That age Tiguan should not have security ”gate” yet but try it, open the hood and try to do the coding again.
and for the sake of it, please post a full autoscan of your car here so we know what we’re dealing with :)
Andy: when you say this - are you attempting to change long-code? If so, given the build date of your Tiggy it's entirely likely that the BCM on your car doesn't use long-code.
Check how the hex09 module is reported on your auto-sacn (as @downtime suggests - post-up copy here). If auto-scan reports a zero-string for long-code, or if long-code is NOT reported at all, then all the software switches that were in older BCM s are included in adaptation channels on your car
Andy4195
Yorkshire, UK
C?ID=426740
Friday,12,March,2021,08:16:22:61337
VIN: WVGZZZ5NZHW414411   License Plate:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 39 42 44 4B 52
          5F 6D A5 BB BC CA D6 D7
VIN: WVGZZZ5NZHW414411   Mileage: 40551km-25197miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 HT    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 3617
   Revision: B4H25---
   Coding: 0125001203661D083000
   ASAM Dataset: EV_ECM20TDI01104L906026HT 004003
   ROD: EV_ECM20TDI01104L906026GP_004.rod
   VCID: 0353848D3B9BE183921-8056
   Part No SW: 0DL 300 011 N    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2012
   Revision: 00H06V07
   VCID: 3333144D2BBB9103421-8066
   Revision: 00000000    Serial number: 60627000001365
   Coding: 0AEE929A34210B70477B070162C44950492CD0E2E046927D38625078C22A4200002F641A1B13111435351919323200
   VCID: 77ABE05D7F43BD23BE9-8022
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0435174247
   Coding: 032C2C070F
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3C213F7106E55E7B93B-8068
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98148664
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NA 907 044 N    HW: 5NA 907 044 N
   Component: AC Automat    H35 4301
   Revision: 20K08000    Serial number: 00000E00435660
   Coding: 0012012420211001110510000010102A
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   VCID: 4ACD69A95C31F0CB117-801E
   Humidity sensor: exterior:
   Rear A/C control head:
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001706104738
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F5B087D57738563F69-802A
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 170130  033 0372
   Serial number: 00000001701250302811
   Component: RLHS  042 0105
   Serial number: S3Y17M03D07H16M53S23
   Coding: 00A8DD
   Serial number: 000000000ZY17032197G
   Serial number: 00000000000068601356
   Part No SW: 3QD 919 294 A    HW: 3QD 919 294
   Component: PDC 8 Kanal   H07 0020
   Serial number: 000901178877031
   Coding: 0071451811
   ASAM Dataset: EV_EPHBO18VW481CN00 001007
   ROD: EV_EPHBO18VW4810000_VW37.rod
   VCID: 4BC36CAD534BE9C32A1-801E
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 320147C158FF8728749C8065804085
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_001.rod
   VCID: 3B233C6D03EB59439A1-806E
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR2PGD0%
   Coding: 98CCC0C00C0000005C5400CF008800000065
   VCID: 1079BBC17AED8A1B1F3-8044
   Left seat belt tensioner:
   Serial number: 5NC857705C0048R00191
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 5NC857706C0059R01901
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 000 803 17
   Serial number: 357000000009B9DC202U
   Subsystem 4 - Part No SW: -----------    HW: 480 000 803 17
   Serial number: 358000000008B9DC202U
   Subsystem 5 - Part No SW: -----------    HW: 480 400 203 17
   Serial number: 3510001B3249E3C6234/
   Subsystem 6 - Part No SW: -----------    HW: 480 400 603 17
   Serial number: 35200019925ACAB3E4DR
   Subsystem 7 - Part No SW: -----------    HW: 480 402 802 17
   Serial number: 3550001C124996D1A5CC
   Subsystem 8 - Part No SW: -----------    HW: 480 400 203 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001A125ACAB553BC
   Subsystem 9 - Part No SW: -----------    HW: 480 400 203 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001A125ACAB436FH
   Subsystem 10 - Part No SW: -----------    HW: 480 400 203 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001A125ACAB544E8
   Subsystem 11 - Part No SW: -----------    HW: 480 000 303 17
   Serial number: I0M000000003AADCA12F
   Subsystem 12 - Part No SW: -----------    HW: 480 000 303 17
   Serial number: I0N00000000E1DC80227
   Part No SW: 3Q0 953 521 DM    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20170304300068
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 7EA5F57950798C6BFDF-802A
   Part No SW: 5NA 920 791 A    HW: 5NA 920 791 A
   Component: KOMBI         408 2170
   Coding: 23A500186F84060001886B031401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   VCID: 41DF4E8561073393C0D-8014
10485826 - Internal Control Module Memory Check Sum Error
          B2000 41 [009] - General checksum failure
          [Steuergerät defekt (CRC Check ROM)]
                    Mileage: 10415 km
                    Date: 2017.11.26
                    Time: 14:27:09
1048578 - No Basic Setting
          B2010 00 [009] - -
          [Steuergerät keine oder falsche Grundeinstellung]
                    Reset counter: 101
                    Mileage: 40551 km
                    Date: 2021.03.12
                    Time: 08:11:05
   Component: GW MQB High   418 4286
   Revision: --------    Serial number: 0006011697
   Coding: 030500045F087300FB07225E1E0F00010001050000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F3B183DC793B5E3269-807A
   Generator:
   Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 0661712552001266AS2B
   Coding: 2D0000
   Serial number: 2580193204
   Serial number: HA1-00006.02.17
   Coding: 0101
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH07 0014
   VCID: 45D75A95752F1FB3FC5-8010
   Serial number: 17000050798001
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFDE451127E31370D-8024
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 210217EBK27499
   Coding: 003F1A20D001048000001000
   VCID: 43D3448D7B1B2183D21-8016
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 9107
   ROD: EV_SteerAssisMQB_013.rod
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Component: FCM MQB Low   001 0285
   Serial number: 18021710803227
   Coding: 000000050100085600104F010A0000000000000000000000000000000000
   VCID: 72BDD1491421D80B897-8026
   Serial number: 220217EBM2608A
   Coding: 003F1020DE01048000001000
   VCID: 42DD41896401288BD97-8016
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0751
   Coding: 02730601FF00000051110101008808001F0100E6012000008F
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 313F1E45D1A7A31330D-8064
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL07RAX
   Subsystem 2 - Part No SW: 3G0 919 866 AQ    HW: -----------
   Component: ECE1 2017  --- 0730
   Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0261
   Revision: --------    Serial number: 31208900000000
   Coding: 0A28
   Serial number: 06031712K20087
   Coding: 0003070600000401000213448050A90094000E200040
   Serial number: 070217EB509682
   Coding: 002A10200100048000001000
   Serial number: 080217EB61238C
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     013 0005
   Coding: 308040732602
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3D2732751DFF5773A45-8068
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 1675CDD95809642B45F-8042
   Component: LED1R         H09 0003
End----------(Elapsed Time: 02:04, VBatt start/end: 14.8V/14.8V)-----------
Winner, winner, chicken dinner! :thumbs:
@Andy4195: Thanks for the auto-scan
Perhaps try this on the BCM:
  • ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz > active
  • ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status > active
